Effective May 2017
Supersedes October 2009
Technical Data 2006
C515
5 mm x 15 mm Axial-leaded, time-delay, glass tube fuses
Electrical Characteristics
Amp Rating
Opening Time
135%
60 minutes max.
125mA - 250mA
3 seconds min.
200%
120 seconds max.
100%
4 hours min.
470mA
30 minutes max.
350mA
600mA
90 seconds max.
2A
2 seconds max.
6A
500 milliseconds max.
135%
60 minutes max.
375mA - 7A
3 seconds min.
200%
120 seconds max.
Rated Current
Product features
5 x 15mm physical size
Nickel-plated brass endcap construction
Leads are tin coated
Optional sleeve is flexible flouropolymer
(UL Flammability rating VW-1).
• UL Listed product meets standard UL 248-14
Ordering
Agency information
• UL Listed Card: C515 125mA-250mA and
375mA-3A (Guide JDYX, File E19180)
• UL Recognized Card: C515 350mA, and 3.5A-7A
(Guide JDYX2, File E19180)
Specify product code
Insert packaging code prefix before
part number.
E.g., BK (or TR2)/C515-2-R
With TR2 packaging code, lead wire
length is 20.3mm Specify option code,
if desired
For insulation sleeve, insert “S” after
part series.
E.g., BK/C515S-2-R
• CSA Certification Card: C515 125mA-250mA and
375mA-3A (Class 1422-01, 53787
Product Code
C515-125-R
C515-250-R
C515-350-R
C515-375-R
C515-500-R
C515-600-R
C515-750-R
C515-800-R
C515-1-R
C515-1.25-R
C515-1.5-R
C515-1.6-R
C515-2-R
C515-2.25-R
C515-2.5-R
C515-3-R
C515-3.5-R
C515-4-R
C515-5-R
C515-6-R
C515-7-R
Voltage
Rating
Vac
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
250
125
125
125
125
125
Specifications
600Vac
25
Interrupting
Rating (amps)
250Vac
35
35
35
35
35
35
35
35
35
100
100
100
100
100
100
100
125Vac
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
10000
400
400
400
400
400
*DC Cold Resistance (Measured at
很抱歉,暂时无法提供与“BK/C515-750-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+14.82357
- 1000+5.17495
