Pin-Indicating Type
GLD/GBA
Fast-Acting
1
⁄4˝ x 1 1⁄4˝ (6.3mm x 32mm)
Dimensions - in
1.27"
(±0.031)
(32.2mm)
(not blown)
15
8
10
5
3
2
100
0.75
1
Time-Current Characteristic Curves–Average Melt
AMP
RATING
1.44"
(36.5mm)
(blown)
1
CURRENT IN AMPS
Electrical Ratings (Catalog Symbol and Amps)
GLD- ⁄2
GLD-2
GLD-6
GLD-3⁄4
GLD-3
GLD-10
GLD-1
GLD-4
GLD-12
GLD-1-1⁄2
GLD-5
GLD-15
GBA-1⁄2
GBA-2
GBA-6
GBA-3⁄4
GBA-3
GBA-10
GBA-1
GBA-4
GBA-15
GBA-1-1⁄2
GBA-5
1
Amp
Ratings
Carton
Qty.
Carton Quantity and Weight
⁄2-15
1
100
Lbs.
0.86
Weight
200
.01
100
.1
10
Catalog Symbol: GLD/GBA
GLB-albaloy-plated indicating pin
GBA-red indicating pin
Non-Time-Delay: Indicating
Amp Rating: 1⁄2 to 15 Amps
Agency Information:
CE, UL Listed, Std. 248-14
1
⁄2-5A/125Vac, 10kA AIC
Guide JDYX, File E19180
UL Recognized, 6A/125Vac, 1kA AIC
10-15A/50Vac/dc, 300 AIC
Guide JDYX2, File E19180
CSA Certified, 1⁄2-5A/125Vac, 10kA AIC
Class 1422-01, File 53787
1
0.255" Max
0.249˝ Min
.4
(Approximate)
TIME IN SECONDS
10
Kg.
0.390
General Information:
• Use in power electronic circuits in which a fuse opening must
be quickly apparent.
• Opening of fuse results in the ejection of end pin.
• Type GLD has an albaloy-plated pin for positive, electrical
signal circuit activation.
• Type GBA has a red pin for high visibility.
• The Cooper Bussmann Series 8000 fuse blocks are
recommended for visual indication.
• For visual indication use Cooper Bussmann panel-mounted
fuseholder HLD (15A maximum)
• Ferrules: Nickel-plated brass endcaps.
The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of
this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of
any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice,
any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
© 2012 Cooper Bussmann
St. Louis, MO 63178
www.cooperbussmann.com
1012 BU-SB12694
Page 1 of 1
Data Sheet 2012
很抱歉,暂时无法提供与“BK/GLD-2”相匹配的价格&库存,您可以联系我们找货
