Technical Data ELX1019
Effective February 2021
HTC
5 mm panel mount fuse holder
Agency information
Environmental compliance
Ordering part number
BK1-HTC-30M
Packaging prefix
Product features
For 5 mm fuse
Panel mount fuse holder
250 Vac rating and up to 20 A
Family name
Type
Packaging prefix
BK1- (1000 parts per case pack)
BK2- (2000 parts per case pack)
BK8- (800 parts per carton)
BK14- (1400 parts per carton)
HTC
Specifications
Part number
Voltage rating
(Vac)
Current rating
(A)
Body material
Contact/clip material
Agency
BK1-HTC-30M*
250
Thermoplastic, UL 94V-0
Copper alloy Ni+Sn
cURus, CE
BK1-HTC-35M*
250
Copper alloy Ni+Sn
cURus, CE
BK1-HTC-40M*
250
Copper alloy Ni+Sn
cURus, CE
BK1-HTC-55M*
250
Copper alloy Ni+Sn
cURus, CE
BK1-HTC-70M*
250
Copper alloy Ni+Sn
cURus, CE
10
Bakelite, UL 94V-0, Black
Clip: copper alloy, nickel plated
Terminals: copper alloy, nickel plated
Spring: steel
CE
10
Shrapnel: copper alloy
Body: Bakelite, UL 94V-0, Black Terminals: brass, tin plated
Cover: PBT, UL 94V-0 Black
Spring: steel
cURus, CE
10
Terminals: brass, nickel plated
Spring: steel
cURus, CE
Bakelite, UL 94V-0 Black
Spring: steel
cURus, CE
Nylon PA-66, UL 94V-2
Spring: steel
CE-
BK8-HTC-603M
250
BK2-HTC-609M
250
BK14-HTC- 613M
250
BK2-HTC-623M
250
BK2-HTC-607M
250
10
10
*Degree of protection: IP40
Dimensions- mm
HTC-35M
HTC-30M
4
13
6.8
11
37.5
(*) 0.8 to 2.8
(*) 0.8 to 6.5
www.eaton.com/electronics
Ø16
11
34.0
2
4
14
Ø16
Ø15
1.8
5.5
HTC
Dimensions- mm
HTC-40M
HTC-55M
4
Ø15
Ø22
Ø15
Ø16
11
6.5
5,5
0,5
36
37.5
(*) 0.8 to 2.5
(*) 0.8 to 6.5
HTC-70M
4.8 x 0.5 1 x 21
HTC-603M
9.0±0.2
4
8.0±0.2
Ø16
M13
0.55±0.05
13.5±0.2
Ø15
11.2±0.2
11
10.2
35.5
Recommended mounting hole
5.5
0.5
4.0±0.1
45,7
16.5±.5
(*) 0.8 to 6.5
Ø9.0±0.2
10.8±0.2
15.5±.5
31.0±0.7
37.0±1.0
(After inserting the fuse MAX.40)
HTC-613M
HTC-609M
12.3±0.2
36.5±1.0
After inserting the fuse Max38
8.6±0.15
20.5±0.25
R3-12
13.0±0.2
15.1±0.2
15.0±0.15
4.0±0.1
4.2±0.3
R3-11
US
2.3
13.0±0.15
8.9±0.15
4.0±0.1
C
US
0.5±0.05
10A125V/250V
C
10A250VAC
7.0±0.2
11.2±0.2
14.0±0.15
3
HTC
Dimensions- mm
HTC-623M
HTC-607M
13.2±0.3
39.8 ±1.0
After insert
the fuse Max.42
10.8±0.2
2±0.2
4.0±0.1
Ø16±0.2
10.9
4±0.1
19 ±.5
32.6±0.3
0.5±0.05
R3-26
11.1±0.1
10A 250V
0.4±0.05
C
11.2±0.2
12.5±0.2
0.4±0.05
2.0±0.2
16 ±.2
US
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2021 Eaton
All Rights Reserved
Printed in USA
Publication No. ELX1019 BU-ELX21020
February 2021
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
