BK2-HTC-609M
BK2-HTC-609M
    EATON(伊顿)
    保险丝 支座 10 A 250V 1 电路 盒 面板安装
BK2-HTC-609M 数据手册
Technical Data ELX1019 Effective February 2021 HTC 5 mm panel mount fuse holder Agency information Environmental compliance Ordering part number BK1-HTC-30M Packaging prefix Product features • For 5 mm fuse • Panel mount fuse holder • 250 Vac rating and up to 20 A Family name Type Packaging prefix • BK1- (1000 parts per case pack) • BK2- (2000 parts per case pack) • BK8- (800 parts per carton) • BK14- (1400 parts per carton) HTC 5 mm panel mount fuse holder  Technical Data ELX1019 Effective February 2021 Specifications Part number Voltage rating (Vac) Current rating (A) Body material Contact/clip material Agency BK1-HTC-30M* 250 20 Thermoplastic, UL 94V-0 Copper alloy Ni+Sn cURus, CE BK1-HTC-35M* 250 20 Thermoplastic, UL 94V-0 Copper alloy Ni+Sn cURus, CE BK1-HTC-40M* 250 20 Thermoplastic, UL 94V-0 Copper alloy Ni+Sn cURus, CE BK1-HTC-55M* 250 20 Thermoplastic, UL 94V-0 Copper alloy Ni+Sn cURus, CE BK1-HTC-70M* 250 20 Thermoplastic, UL 94V-0 Copper alloy Ni+Sn cURus, CE 10 Bakelite, UL 94V-0, Black Clip: copper alloy, nickel plated Terminals: copper alloy, nickel plated Spring: steel CE 10 Clip: copper alloy, nickel plated Shrapnel: copper alloy Body: Bakelite, UL 94V-0, Black Terminals: brass, tin plated Cover: PBT, UL 94V-0 Black Spring: steel cURus, CE 10 Bakelite, UL 94V-0, Black Clip: copper alloy, nickel plated Terminals: brass, nickel plated Spring: steel cURus, CE Bakelite, UL 94V-0 Black Terminals: brass, nickel plated Spring: steel cURus, CE Nylon PA-66, UL 94V-2 Clip: copper alloy, nickel plated Terminals: brass, tin plated Spring: steel CE- BK8-HTC-603M 250 BK2-HTC-609M 250 BK14-HTC- 613M 250 BK2-HTC-623M 250 BK2-HTC-607M 250 10 10 *Degree of protection: IP40 Dimensions- mm HTC-35M HTC-30M (*) (*) 4 13 6.8 11 37.5 (*) 0.8 to 2.8 (*) 0.8 to 6.5 www.eaton.com/electronics Ø16 11 34.0 2 4 0 12 -0,1 14 Ø16 0 12,7 -0,1 Ø15 1.8 5.5 Technical Data ELX1019 HTC 5 mm panel mount fuse holder  Effective February 2021  Dimensions- mm HTC-40M HTC-55M (*) (*) 0 12,7 -0,1 4 Ø15 0 12 -0,1 Ø22 Ø15 0 12 -0,1 Ø16 0 12,7 -0,1 11 6.5 5,5 0,5 36 37.5 (*) 0.8 to 2.5 (*) 0.8 to 6.5 HTC-70M 4.8 x 0.5 1 x 21 HTC-603M (*) 9.0±0.2 4 8.0±0.2 Ø16 M13 0.55±0.05 13.5±0.2 Ø15 0 12 -0,1 0 12,7 -0,1 11.2±0.2 11 10.2 35.5 Recommended mounting hole 5.5 0.5 4.0±0.1 45,7 16.5±.5 (*) 0.8 to 6.5 Ø9.0±0.2 10.8±0.2 15.5±.5 31.0±0.7 37.0±1.0 (After inserting the fuse MAX.40) HTC-613M HTC-609M 12.3±0.2 36.5±1.0 After inserting the fuse Max38 8.6±0.15 20.5±0.25 R3-12 13.0±0.2 Recommended mounting hole 15.1±0.2 15.0±0.15 4.0±0.1 4.2±0.3 R3-11 US 2.3 13.0±0.15 8.9±0.15 4.0±0.1 C US 0.5±0.05 10A125V/250V C 10A250VAC 7.0±0.2 11.2±0.2 14.0±0.15 Recommended mounting hole www.eaton.com/electronics 3 HTC 5 mm panel mount fuse holder  Technical Data ELX1019 Effective February 2021 Dimensions- mm HTC-623M HTC-607M 13.2±0.3 39.8 ±1.0 After insert the fuse Max.42 10.8±0.2 2±0.2 4.0±0.1 Ø16±0.2 10.9 4±0.1 19 ±.5 32.6±0.3 0.5±0.05 R3-26 11.1±0.1 10A 250V 0.4±0.05 C 11.2±0.2 12.5±0.2 0 -0.2 0.4±0.05 2.0±0.2 16 ±.2 US Recommended mounting hole Recommended mounting hole Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2021 Eaton All Rights Reserved Printed in USA Publication No. ELX1019 BU-ELX21020 February 2021 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
BK2-HTC-609M 价格&库存
很抱歉,暂时无法提供与“BK2-HTC-609M”相匹配的价格&库存,您可以联系我们找货
BK2-HTC-609M
  • 1+46.245211+5.96190
  • 5+38.394305+4.94977
  • 10+35.4294010+4.56754
  • 50+29.3901050+3.78895
  • 100+27.10590100+3.49448
  • 250+24.34460250+3.13849
  • 500+22.43282500+2.89203
  • 2000+19.013642000+2.45123
库存:1818
BK2-HTC-609M
  • 10+27.90805
库存:1240
BK2-HTC-609M
  • 1+36079.93605
  • 5+35358.33004
库存:750
