C22-L-G-24-P62
C22-L-G-24-P62
    EATON(伊顿)
    EATON CUTLER HAMMER - C22-L-G-24-P62 - INDICATOR LIGHT, 22.5 MM PB SWITCH, 24V
C22-L-G-24-P62 数据手册
DATASHEET - C22-L-G-24-P62 Indicator light, classic, flat, green, 24 V AC/DC, cable (black) with nonterminated end, 4 pole, 1 m Delivery program Part no.  Catalog No.      C22-L-G-24-P62 185140 Product range     RMQ compact solution Basic function     Indicator lights Single unit/Complete unit     Complete unit Design     Flat Connection type     Cable (black) with non-terminated end, 4 pole Cable Length   m 1 Colour       Lens     green Lens     LED     LED     green Rated operational voltage LED     24 V AC/DC Degree of Protection     IP66, IP67, IP69K (front) IP65 (on rear) Connection to SmartWire-DT     no Contact sequence     Standards     IEC/EN 60947-5-1 VDE 0660 Certifications     CE, UL, CSA Tightening torque Threaded ring   Nm 2 Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Degree of Protection     IP66, IP67, IP69K (front) IP65 (on rear) 03/19/2018 Eaton 185140 ED2018 V42.0 EN Technical data General 1/3 Mounting position     As required Mechanical shock resistance, shock duration 11 ms   g > 30 Rated impulse withstand voltage Uimp V AC 800 Rated insulation voltage Ui V 30 Overvoltage category/pollution degree     III/3 Max. short-circuit protective device       gG/gL A 4 Rated conditional short-circuit current Iq kA 1 Cable characteristics       Design     Cable end open Cable Length   m 1 Material characteristic     PUR Diameter ⌀ mm 4.7       Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 70 Contacts Fuse Switching capacity Design verification as per IEC/EN 61439 Technical data for design verification Technical data ETIM 6.0 Low-voltage industrial components (EG000017) / Indicator light complete (EC000272) Electric engineering, automation, process control engineering / Low-voltage switch technology / Command and alarm device / Indicator light complete (ecl@ss8.1-27-37-12-23 [AKF041011]) Number of indicator lights     1 Colour lens     Green Type of lamp socket     LED With lamp     Yes Rated operating voltage Ue   V 24 - 24 Voltage type     AC/DC Type of electric connection     Other Construction type lens     Round Type of lens     Flat Hole diameter   mm 22 Width opening   mm 0 Height meter opening   mm 0 Degree of protection (IP)     Other With front ring     Yes Material front ring     Plastic Colour front ring     Other 03/19/2018 Eaton 185140 ED2018 V42.0 EN 2/3 Dimensions Assets (Links) Declaration of Conformity 00002596 Additional product information (links) IL047016ZU RMQ compact solution IL047016ZU RMQ compact solution 03/19/2018 ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL047016ZU2017_01.pdf Eaton Industries GmbH http://www.eaton.eu © 03/2018 by Eaton Industries GmbH Eaton 185140 ED2018 V42.0 EN 3/3
C22-L-G-24-P62 价格&库存
很抱歉,暂时无法提供与“C22-L-G-24-P62”相匹配的价格&库存,您可以联系我们找货
