DD160
DD160
    EATON(伊顿)
    Cylindrical,Blade Terminal(Bolt)
    FUSELINK INDUST 160A 415V IEC
DD160 数据手册
Bussmann® Industrial HRC Fuse Link DD 31 x 138mm, BS88, IEC 269-1 Center Bolted Tags 125 160 200 200M250 200M315 Time-Current Characteristic Curve (Full Size Curves Available) 1,000 CURRENT RATING 100 TIME IN SECONDS CATALOG SYMBOL: DD INDUSTRIAL HRC FUSE CENTER BOLTED TAGS PACKAGE QUANTITY: 5 80kA INTERRUPTING RATING MOUNTS IN 200DF FUSEBLOCK Dimensional Data: A B 10 1 H G C D F .1 E 1,000 10 100 .01 10,000 J CURRENT IN AMPERES Electrical Characteristics Catalog Number Ampere Rating I2T (Amp2 Seconds) PreTotal At Arcing 240V Total At 415V Nom Watts Loss DD125 DD160 DD200 DD200M250 DD200M315 125 160 200 200M250 200M315 29,500 57,000 120,000 200,000 265,000 71,000 135,000 290,000 480,000 635,000 11 13 14 18 27 50,000 97,000 205,000 — — Dimensions (Inches/mm) Rated Voltage A B C D E F G H J 415AC 136.0 111.0 47.0 9.0 12.5 19.0 0.13 3.23 22.5 1.22 31.0 The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled.This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 12-17-98 SB98107 Rev. A Form No. DD Page 1 of 1 BIF Doc #4118
DD160 价格&库存
很抱歉,暂时无法提供与“DD160”相匹配的价格&库存,您可以联系我们找货
DD160
  • 1+281.71512
  • 25+270.45777
  • 100+259.17958
库存:56
