DEL-M22M-D-G-GB1-K10
    EATON(伊顿)
    EATON CUTLER HAMMER  M22M-D-G-GB1-K10  PUSHBUTTON SWITCH, SPST-NO, SCREW New
DEL-M22M-D-G-GB1-K10 数据手册
Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Contents 22.5 mm Modular Pushbuttons—M22 Description Page 22.5 mm Modular Pushbuttons—M22 Product Selection Guide . . . . . . . . . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . Coding Adapter Guide . . . . . . . . . . . . . . . . . . . Technical Data and Specifications . . . . . . . . . . Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . Symbols Library. . . . . . . . . . . . . . . . . . . . . . . . . V7-T1-48 V7-T1-111 V7-T1-118 V7-T1-119 V7-T1-123 V7-T1-129 1 1 1 1 1 1 Drawings Online 1 1 1 1 Product Description Eaton’s M22 industrial heavyduty pushbutton line offers a wide array of functional, attractive and ergonomically designed illuminated and nonilluminated pushbuttons, selector switches, push-pulls, alternate action and twist-torelease operators. The complete illuminated line is only offered in LED light units to ensure high-quality brightness and up to 100,000 hours of LED illumination. M22 operators are available with either a silver or black nylon colored or chrome metal bezel. The spacesaving modular construction of the M22 line makes onthe-job assembly fast and simplifies the stocking of both components and complete devices. Highly Modular and Versatile Line ● ● Field convertible functions (pushbuttons and selector switches), maintained to momentary Customizable laser engraving capabilities LED Indicators ● ● All operators and components are IEC/EN 60947 VDE 0660. All operators carry an IP66 rating with some rated for washdown environment with IP67 and IP69K. All pushbuttons, emergencystops, indicating lights, potentiometers and selector switches carry NEMA 4X, 13. 1 Marine classification societies: Bureau Veritas (BV), Germanischer Lloyd (GL), and Lloyd’s Register of Shipping (LR) approved. 1 100,000 hours of life in high-vibration environments Lenses specifically designed for LED illumination ● ● ● 1 1 1 1 1 Most pushbutton operators and contact blocks exceed 5 million mechanical operations All components have IP66 rating, and some carry IP67 and IP69K for washdown environment; see Page V7-T1-119 for further technical data 1 1 1 1 Innovative Technologies ● 1 1 Rugged Design NEW Eaton has expanded M22 pilot devices with a metal bezel option. The new M22M pushbutton is an elegant chrome metal bezel that is attractive, durable and rugged for heavy-duty environments. M22M devices are configurable and complement components within the M22 line. 1 Standards and Certifications 1 ASi communicating devices Palm switches 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-47 1.5 1 ● 1 1 1 ● ● ● 1 1 1 1 1 22.5 mm Modular Pushbuttons—M22 Features 1 1 Pushbuttons and Indicating Lights ● Benefits Field convertible pushbuttons and mushroom operators from maintained to momentary status Field convertible selector switches from momentary to maintained operation and vice versa LED offering only for all illuminated operators Laser engraved pushbuttons, lenses and enclosures Heavy-duty construction with a minimum of IP66 and UL NEMA® type 4X / 13 on front of panel operators. Many operators even carry IP67 and IP69K, for the toughest applications ● ● ● ● ● ● ● Silver, black or chrome metal bezel now available Snap-lock contact blocks and light units for front or base mounting Notched hole mounting with anti-rotation tab and central nut mounting on each operator Over 5 million mechanical operations and 1.6 million electrical (reference specification sheet) Direct opening action normally closed contacts Unique and innovative offerings, such as four-way pushbuttons and USB/ RJ45 bulkhead interfaces Screw or spring-cage terminals 1 ● ● ● ● Modular construction makes assembly fast and simplifies stocking of components and complete devices Field convertibility of operator status for pushbuttons and selector switches helps distributors and customers reduce inventory and increase functionality LED offering only for improved brightness quality and up to 100,000 hours of operation Plastic construction is corrosion resistant. Operators are designed for rugged environments, ideal for washdown applications (reference each operator’s IP ratings and IEC/EN 60529 for ingress protection definition) ● ● ● ● ● ● Anti-rotation tab saves installation time and prevents operator rotation High mechanical and electrical life allows for use in tough and challenging applications Laser inscription capabilities allow for highquality, wear-resistant markings All normally closed (NC) contacts are direct opening action, i.e., NC contacts are physically forced open by direct linkage with the pushbutton operator in the unlikely event of contact weld Some M22 operators are capable of communication via ASi protocol M22 offers USB and RJ45 connections 1 1 Product Selection Guide 1 Pushbuttons 1 1 1 1 1 1 Description Non-illuminated, flush Operator Momentary Product Selection Pages V7-T1-53 to Pages V7-T1-56, V7-T1-55 V7-T1-57 Maintained Non-illuminated, extended Illuminated, flush Illuminated, extended Momentary Maintained Momentary Pages V7-T1-58, V7-T1-59 Pages V7-T1-60, V7-T1-61 Pages V7-T1-63 to Pages V7-T1-66, V7-T1-65 V7-T1-67 Maintained Momentary Maintained Pages V7-T1-68, V7-T1-69 Pages V7-T1-70, V7-T1-71 Indicating Lights 1 1 1 1 1 Description Flat Conical Product Selection Pages V7-T1-72, V7-T1-73 Pages V7-T1-72, V7-T1-73 1 1 1 1 V7-T1-48 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Emergency Stops 1 1 1 Description Non-illuminated Illuminated Key release Mechanical indication Product Selection Page V7-T1-75 Page V7-T1-75 Page V7-T1-76 Page V7-T1-76 1 1 1 Selector Switches 1 1 1 Non-illuminated knob type Non-illuminated rotary type Illuminated Key-operated Description 1 Product Selection Pages V7-T1-80, V7-T1-81 Pages V7-T1-82, V7-T1-83 Pages V7-T1-85 to V7-T1-87 Pages V7-T1-88 to V7-T1-91 1 1 Mushroom Head Pushbuttons 1 1 1 Description Non-illuminated Non-illuminated Operator Momentary Maintained Product Selection Pages V7-T1-94, V7-T1-95 Pages V7-T1-96, V7-T1-97 1 1 1 1 Double Pushbuttons 1 1 1 Description Extended pushbuttons and center light Flush top and center light, extended bottom Flush pushbuttons and center light Operator Momentary Momentary — Product Selection Page V7-T1-99 Page V7-T1-100 Page V7-T1-100 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-49 1.5 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Four-Way Pushbuttons Bulkhead Interfaces 1 1 1 1 1 Description Non-interlocked Interlocked Description Bulkhead interfaces Operator Momentary Maintained Product Selection Page V7-T1-107 Product Selection Page V7-T1-103 Page V7-T1-103 1 1 ASi Adapter Modules Joysticks 1 1 1 1 1 Description Joysticks Description ASi adapter modules Product Selection Page V7-T1-104 Product Selection Page V7-T1-108 Palm Switches Potentiometers 1 1 1 1 Description Potentiometers Description Palm switches 1 Product Selection Page V7-T1-106 Product Selection Page V7-T1-109 1 Acoustic Devices Assembled Control Stations 1 1 1 Description Acoustic devices Description Assembled control stations 1 Product Selection Page V7-T1-106 Product Selection Page V7-T1-16 1 Through-the-Door Operators 1 1 1 1 Description Through-the-door operators Product Selection Page V7-T1-107 1 1 V7-T1-50 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 M22-_ 1.5 Point-of-Purchase Units 1 Color Type Contact Configuration 1 Catalog Number Black Flush momentary NO/NC M22-D-S-K11-P Red Extended momentary NO/NC M22-DH-R-K11-P Green Flush momentary NO/NC M22-D-G-K11-P Red Ext. illuminated (12–30V) momentary NO/NC M22-DLH-R-K11-R-P Red Ext. illuminated (85–264V) momentary NO/NC M22-DLH-R-K11-230R-P White Flush illuminated (12–30V) maintained NO/NC M22-DRL-W-K11-W-P White Flush illuminated (85–264V) maintained NO/NC M22-DRL-W-K11-230W-P Red Indicating light (12–30V) — M22-L-R-R-P Green Indicating light (12–30V) — M22-L-G-G-P Red Indicting light (85–264V) — M22-L-R-230R-P Green Indicating light (85–264 Vac) — M22-L-G-230G-P Red Twist-to-release E-stop 1NO/2NC M22-PVT-K12-P Red Illuminated (12–30V) push-pull E-stop 1NO/2NC M22-PVL-K12-R-P Red Illuminated (85–264V) push-pull E-stop 1NO/2NC M22-PVL-K12-230R-P — Two-position maintained V selector switch NO/NC M22-WKV-K11-P — Three-position momentary selector switch NO/NC M22-WK3-K22-P 1 1 1 1 1 1 1 1 1 1 Note 1 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-51 1.5 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Contents Pushbuttons—Non-Illuminated and Illuminated Description 1 Pushbuttons—Non-Illuminated and Illuminated Non-Illuminated, Flush, Momentary . . . . . . . . Non-Illuminated, Flush, Maintained . . . . . . . . . Non-Illuminated, Extended, Momentary . . . . . Non-Illuminated, Extended, Maintained . . . . . . Illuminated, Flush, Momentary . . . . . . . . . . . . Illuminated, Flush, Maintained . . . . . . . . . . . . . Illuminated, Extended, Momentary . . . . . . . . . Illuminated, Extended, Maintained . . . . . . . . . 1 1 1 1 1 1 1 1 1 Pushbuttons—Non-Illuminated and Illuminated 1 Product Description Features Eaton’s M22 pushbutton line is a complete, modular and versatile offering. From field-convertible maintained operators to customizable laser engraved buttons, the M22 pushbutton line provides endless opportunity for flexibility and reduced inventory. Each operator type provides options for ordering as complete or component parts allowing for a perfect fit for each application. All of this flexibility comes in a very rugged design. ● 1 1 1 1 1 1 1 1 ● ● ● Field convertible from maintained to momentary (available on maintained pushbuttons only) Customizable laser engraving on all buttons LED offering only for improved brightness quality and up to 100,000 hours of operation More than five million mechanical operations on momentary and 1 million on maintained pushbuttons ● ● Modular construction makes assembly fast and simplifies stocking of components and complete devices Capable of communicating via ASi protocol with ASi adapter modules Protection Type ● IP67, IP69K ● NEMA 4X, 13 1 1 1 1 1 1 1 1 1 1 V7-T1-52 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Page V7-T1-53 V7-T1-56 V7-T1-58 V7-T1-60 V7-T1-63 V7-T1-66 V7-T1-68 V7-T1-70 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Catalog Number Selection Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. 1 Non-Illuminated Pushbuttons 1 1 M22 – D – S – X0 – K10 1 Bezel M22 = Silver M22S = Black M22M = Metal D= DH = DG = DR = DGH = DRH = 1 Operator Type Flush momentary Extended momentary Flush with guard 1 Flush maintained Extended momentary with guard 1 Extended maintained Button Plate Color G = Green S = Black Y = Yellow R = Red B = Blue W = White GB0 = GB1 = GB2 = GB3 = GB4 = GB5 = GB6 = GB14 = GB15 = GB16 = Inscription STOP START CLOSE UP DOWN OFF ON RESET FORWARD REVERSE X0 = X1 = X4 = X5 = X6 = X7 = X8 = K10 = K01 = K20 = K02 = K11 = Contact Blocks 1NO K30 = 3NO 1NC K03 = 3NC 2NO K21 = 2NO-1NC 2NC K12 = 1NO-2NC 1NO-1NC 1 1 1 1 1 Silver bezel only. 1 Product Selection 1 Non-Illuminated Pushbuttons, Flush, Momentary M22-D-G-K10 1 Complete Devices Button Color Contact Block Configuration 1 Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number 1 Black NO M22-D-S-K10 M22S-D-S-K10 M22M-D-S-K10 1 NC M22-D-S-K01 M22S-D-S-K01 M22M-D-S-K01 2NO M22-D-S-K20 M22S-D-S-K20 M22M-D-S-K20 2NC M22-D-S-K02 M22S-D-S-K02 M22M-D-S-K02 1NO-1NC M22-D-S-K11 M22S-D-S-K11 M22M-D-S-K11 NO M22-D-R-K10 M22S-D-R-K10 M22M-D-R-K10 NC M22-D-R-K01 M22S-D-R-K01 M22M-D-R-K01 2NO M22-D-R-K20 M22S-D-R-K20 M22M-D-R-K20 2NC M22-D-R-K02 M22S-D-R-K02 M22M-D-R-K02 1NO-1NC M22-D-R-K11 M22S-D-R-K11 M22M-D-R-K11 M22S-D-G-K10 Red M22M-D-G-K10 Green NO M22-D-G-K10 M22S-D-G-K10 M22M-D-G-K10 NC M22-D-G-K01 M22S-D-G-K01 M22M-D-G-K01 2NO M22-D-G-K20 M22S-D-G-K20 M22M-D-G-K20 2NC M22-D-G-K02 M22S-D-G-K02 M22M-D-G-K02 1NO-1NC M22-D-G-K11 M22S-D-G-K11 M22M-D-G-K11 1 1 1 1 1 1 1 1 Note 1 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-53 1.5 1 1 22.5 mm Modular Pushbuttons—M22 Non-Illuminated Pushbuttons, Flush, Momentary M22-D-G 1 1 1 Pushbuttons and Indicating Lights M22S-D-G Operators Only 1 Button Color Inscription Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Black — M22-D-S M22S-D-S M22M-D-S Red — M22-D-R M22S-D-R M22M-D-R STOP M22-D-R-GB0 M22S-D-R-GB0 — M22M-D-R-X0 Green 1 1 1 1 M22M-D-G M22-D-R-X0 M22S-D-R-X0 — M22-D-G M22S-D-G M22M-D-G START M22-D-G-GB1 M22S-D-G-GB1 M22M-D-G-GB1 M22-D-G-X1 M22S-D-G-X1 M22M-D-G-X1 White — M22-D-W M22S-D-W M22M-D-W Blue — M22-D-B M22S-D-B M22M-D-B Yellow — M22-D-Y M22S-D-Y M22M-D-Y — — M22-D-X-SRG 2 M22S-D-X-SRG 2 M22M-D-X-SRG 2 — M22-D-X-SWRGYB 3 M22S-D-X-SWRGYB 3 M22M-D-X-SWRGYB 3 1 1 1 1 M22-DG-G Silver Guarded Button Color Inscription Silver Bezel Catalog Number Black — M22-DG-S 1 Red — M22-DG-R Green — M22-DG-G 1 White — M22-DG-W Blue — M22-DG-B 1 Yellow — M22-DG-Y 1 — — M22-DG-X-SRG 2 — M22-DG-X-SWRGYB 3 1 Notes 1 Includes contact block mounting adapter. 2 Buttonless operator comes with three color buttons (black, red, green). 3 Buttonless operator comes with all six color buttons (black, white, red, green, yellow, blue). 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-54 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Non-Illuminated Pushbuttons, Flush, Momentary 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 Components M22-XD-G Button Plates 1 M22-D-X Color Inscription Catalog Number Black — Custom STOP START CLOSE UP DOWN OFF ON TEST FORWARD REVERSE RAISE LOWER M22-XD-S 2 M22-XD-S-ETCH 3 M22-XD-S-GB0 M22-XD-S-GB1 M22-XD-S-GB2 M22-XD-S-GB3 M22-XD-S-GB4 M22-XD-S-GB5 M22-XD-S-GB6 M22-XD-S-GB9 M22-XD-S-GB15 M22-XD-S-GB16 M22-XD-S-GB17 M22-XD-S-GB18 Red Green Blue — Custom STOP OFF — Custom START ON — Custom RESET White Yellow — Custom START — Custom Black, red, green — Black, white, — red, green, yellow, blue M22-XD-S-X0 M22-XD-S-X1 M22-XD-S-X2 M22-XD-S-X4 M22-XD-S-X5 M22-XD-S-X7 M22-XD-R 2 M22-XD-R-ETCH 3 M22-XD-R-GB0 M22-XD-R-GB5 M22-XD-R-X0 M22-XD-G 2 M22-XD-G-ETCH 3 M22-XD-G-GB1 M22-XD-G-GB6 M22-XD-G-X1 M22-XD-B 2 M22-XD-B-ETCH 3 M22-XD-B-GB14 M22-XD-B-X6 M22-XD-W 2 M22-XD-W-ETCH 3 M22-XD-W-GB1 M22-XD-W-X1 M22-XD-Y 2 M22-XD-Y-ETCH 3 M22-XD-SRG M22-XD-SWRGYB 1 Buttonless Operator Silver Bezel Catalog Number 4 Black Bezel Catalog Number 4 Metal Bezel Catalog Number 4 1 M22-D-X M22S-D-X M22M-D-X 1 M22S-D-X 1 1 1 M22M-D-X 1 1 M22-DG-X 1 Silver Guarded Silver Bezel Catalog Number 4 1 M22-DG-X M22-K10 1 1 Contact Blocks 1 Terminal Type Contact Configuration 5 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage Notes 1 For complete listing of available button plates and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 Minimum order quantity of (10). 3 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XD-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 4 Includes contact block mounting adapter. 5 All NC contact blocks are positively driven contact. Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1 1 1 1 1 1 1 1 1 1 1 V7-T1-55 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Non-Illuminated Pushbuttons, Flush, Maintained 1 M22-DR-S Operators Only 2 1 Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Black M22-DR-S M22S-DR-S M22M-DR-S 1 Red M22-DR-R M22S-DR-R M22M-DR-R Green M22-DR-G M22S-DR-G M22M-DR-G White M22-DR-W M22S-DR-W M22M-DR-W Blue M22-DR-B M22S-DR-B M22M-DR-B Yellow M22-DR-Y M22S-DR-Y M22M-DR-Y 3 M22-DR-X-SRG M22S-DR-X-SRG M22M-DR-X-SRG 4 M22-DR-X-SWRGYB M22S-DR-X-SWRGYB M22M-DR-X-SWRGYB 1 M22S-DR-S 1 1 1 1 M22M-DR-S 1 1 1 Notes 1 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 2 Includes contact block mounting adapter. 3 Buttonless operator comes with three color buttons (black, red, green). 4 Buttonless operator comes with all six color buttons (black, white, red, green, yellow, blue). 1 1 1 1 1 1 1 1 Note: This pilot device features a selectable function switch that enables the device to be set to either maintained or momentary operation. 1 1 1 1 1 1 1 1 1 1 V7-T1-56 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Non-Illuminated Pushbuttons, Flush, Maintained 1 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 Components M22-XD-S Button Plates 2 M22-DR-X Color Inscription Catalog Number Black — Custom M22-XD-S 3 M22-XD-S-ETCH 4 STOP START CLOSE UP DOWN OFF ON TEST FORWARD REVERSE RAISE LOWER M22-XD-S-GB0 M22-XD-S-GB1 M22-XD-S-GB2 M22-XD-S-GB3 M22-XD-S-GB4 M22-XD-S-GB5 M22-XD-S-GB6 M22-XD-S-GB9 M22-XD-S-GB15 M22-XD-S-GB16 M22-XD-S-GB17 M22-XD-S-GB18 — Custom M22-XD-S-X0 M22-XD-S-X1 M22-XD-S-X2 M22-XD-S-X4 M22-XD-S-X5 M22-XD-S-X7 M22-XD-R 3 M22-XD-R-ETCH 4 Red STOP OFF Green Blue — Custom START ON — Custom RESET White — Custom START Yellow — Custom — — Black, red, green Black, white, red, green, yellow, blue M22-XD-R-GB0 M22-XD-R-GB5 M22-XD-R-X0 M22-XD-G 3 M22-XD-G-ETCH 4 M22-XD-G-GB1 M22-XD-G-GB6 M22-XD-G-X1 M22-XD-B 3 M22-XD-B-ETCH 4 M22-XD-B-GB14 M22-XD-B-X6 M22-XD-W 3 M22-XD-W-ETCH 4 M22-XD-W-GB1 M22-XD-W-X1 M22-XD-Y 3 M22-XD-Y-ETCH 4 M22-XD-SRG M22-XD-SWRGYB 1 Buttonless Operator Silver Bezel Catalog Number 5 Black Bezel Catalog Number 5 Metal Bezel Catalog Number 5 1 M22-DR-X M22S-DR-X M22M-DR-X 1 1 M22S-DR-X 1 1 M22M-DR-X 1 1 1 M22-K10 1 Contact Blocks 2 Terminal Type Contact Configuration 6 Catalog Number Screw NO M22-K10 NO, early-make M22-K10P NC M22-K01 NC, late-break M22-K01D NO M22-CK10 NC M22-CK01 NC, late-break M22-CK01D 2NO M22-CK20 2NC M22-CK02 NO-NC M22-CK11 Spring-cage Notes 1 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 2 For complete listing of available button plates and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 3 Minimum order quantity of (10). 4 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XD-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 5 Includes contact block mounting adapter. 6 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-57 1.5 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Non-Illuminated Pushbuttons, Extended, Momentary M22-DH-R-K10 Complete Devices 1 Button Color Contact Block Configuration 1 Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number 1 Red NO M22-DH-R-K10 M22S-DH-R-K10 M22M-DH-R-K10 NC M22-DH-R-K01 M22S-DH-R-K01 M22M-DH-R-K01 2NO M22-DH-R-K20 M22S-DH-R-K20 M22M-DH-R-K20 2NC M22-DH-R-K02 M22S-DH-R-K02 M22M-DH-R-K02 1NO-1NC M22-DH-R-K11 M22S-DH-R-K11 M22M-DH-R-K11 1 M22S-DH-R-K10 1 1 1 M22M-DH-R-K10 1 1 1 M22-DGH-R-K10 Silver Guarded Button Color Contact Block Configuration 1 Silver Bezel Catalog Number Red NO M22-DGH-R-K10 1 NC M22-DGH-R-K01 2NO M22-DGH-R-K20 1 2NC M22-DGH-R-K02 1NO-1NC M22-DGH-R-K11 1 1 M22-DH-R Operators Only 2 1 Button Color Inscription Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number 1 Black — M22-DH-S M22S-DH-S M22M-DH-S Red — M22-DH-R M22S-DH-R M22M-DH-R STOP M22-DH-R-GB0 M22S-DH-R-GB0 M22M-DH-R-GB0 M22-DH-R-X0 M22S-DH-R-X0 M22M-DH-R-X0 1 M22S-DH-R 1 1 1 M22M-DH-R 1 1 1 M22-DGH-R-K10 1 1 Green — M22-DH-G M22S-DH-G M22M-DH-G White — M22-DH-W M22S-DH-W M22M-DH-W Blue — M22-DH-B M22S-DH-B M22M-DH-B Yellow — M22-DH-Y M22S-DH-Y M22M-DH-Y 3 — M22-DH-X-SRG M22S-DH-X-SRG M22M-DH-X-SRG 4 — M22-DH-X-SWRGYB M22S-DH-X-SWRGYB M22M-DH-X-SWRGYB Silver Guarded Button Color Inscription Silver Bezel Catalog Number Black — M22-DGH-S Red — M22-DGH-R STOP M22-DGH-R-GB0 M22-DGH-R-X0 1 Green — M22-DGH-G 1 White — M22-DGH-W Blue — M22-DGH-B 1 Yellow — M22-DGH-Y Notes 1 All NC contact blocks are positively driven contact. 2 Includes contact block mounting adapter. 3 Buttonless operator comes with three color buttons (black, red, green). 4 Buttonless operator comes with all six color buttons (black, white, red, green, yellow, blue). 1 1 V7-T1-58 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Non-Illuminated Pushbuttons, Extended, Momentary 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 Components M22-XDH-R Button Plates 1 M22-D-X Color Inscription Catalog Number Black — Custom STOP START CLOSE UP DOWN OFF ON TEST FORWARD REVERSE RAISE LOWER M22-XDH-S 2 M22-XDH-S-ETCH 3 M22-XDH-S-GB0 M22-XDH-S-GB1 M22-XDH-S-GB2 M22-XDH-S-GB3 M22-XDH-S-GB4 M22-XDH-S-GB5 M22-XDH-S-GB6 M22-XDH-S-GB9 M22-XDH-S-GB15 M22-XDH-S-GB16 M22-XDH-S-GB17 M22-XDH-S-GB18 Red Green — Custom STOP OFF — Custom START ON Blue — Custom RESET White Yellow Black, red, green Black, white, red, green, yellow, blue — Custom START — Custom — — M22-XDH-S-X0 M22-XDH-S-X1 M22-XDH-S-X2 M22-XDH-S-X4 M22-XDH-S-X5 M22-XDH-S-X7 M22-XDH-R 2 M22-XDH-R-ETCH 3 M22-XDH-R-GB0 M22-XDH-R-GB5 M22-XDH-R-X0 M22-XDH-G 2 M22-XDH-G-ETCH M22-XDH-G-GB1 M22-XDH-G-GB6 M22-XDH-G-X1 M22-XDH-B 2 Silver Bezel Catalog Number 4 Black Bezel Catalog Number 4 Metal Bezel Catalog Number 4 1 M22-D-X M22S-D-X M22M-D-X 1 M22S-D-X 1 1 1 M22M-D-X 1 1 M22-DG-X 1 Silver Guarded Silver Bezel Catalog Number 4 1 M22-DG-X M22-K10 1 1 Contact Blocks 1 Terminal Type Contact Configuration 5 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 3 M22-XDH-B-ETCH 3 M22-XDH-B-GB14 M22-XDH-B-X6 M22-XDH-W 2 M22-XDH-W-ETCH 3 M22-XDH-W-GB1 M22-XDH-W-X1 M22-XDH-Y 2 M22-XDH-Y-ETCH 3 M22-XDH-SRG M22-XDH-SWRGYB 1 Buttonless Operator Spring-cage Notes 1 For complete listing of available button plates and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 Minimum order quantity of (10). 3 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XDH-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 4 Includes contact block mounting adapter. 5 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-59 1.5 1 1 M22-DRH-W 1 M22S-DRH-W 1 1 1 22.5 mm Modular Pushbuttons—M22 Non-Illuminated Pushbuttons, Extended, Maintained 1 1 1 Pushbuttons and Indicating Lights Operators Only 2 Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Black M22-DRH-S M22S-DRH-S M22M-DRH-S Red M22-DRH-R M22S-DRH-R M22M-DRH-R Green M22-DRH-G M22S-DRH-G M22M-DRH-G White M22-DRH-W M22S-DRH-W M22M-DRH-W Blue M22-DRH-B M22S-DRH-B M22M-DRH-B Yellow M22-DRH-Y M22S-DRH-Y M22M-DRH-Y 3 M22-DRH-X-SRG M22S-DRH-X-SRG M22M-DRH-X-SRG 4 M22-DRH-X-SWRGYB M22S-DRH-X-SWRGYB M22M-DRH-X-SWRGYB M22M-DRH-W 1 1 1 Notes 1 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 2 Includes contact block mounting adapter. 3 Buttonless operator comes with three color buttons (black, red, green). 4 Buttonless operator comes with all six color buttons (black, white, red, green, yellow, blue). 1 1 1 1 1 1 1 1 Note: This pilot device features a selectable function switch that enables the device to be set to either maintained or momentary operation. 1 1 1 1 1 1 1 1 1 1 1 V7-T1-60 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Non-Illuminated Pushbuttons, Extended, Maintained 1 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 Components M22-XDH-W Button Plates 2 M22-DR-X Color Inscription Catalog Number Black — Custom M22-XDH-S 3 M22-XDH-S-ETCH 4 STOP START CLOSE UP DOWN OFF ON TEST FORWARD REVERSE RAISE LOWER M22-XDH-S-GB0 M22-XDH-S-GB1 M22-XDH-S-GB2 M22-XDH-S-GB3 M22-XDH-S-GB4 M22-XDH-S-GB5 M22-XDH-S-GB6 M22-XDH-S-GB9 M22-XDH-S-GB15 M22-XDH-S-GB16 M22-XDH-S-GB17 M22-XDH-S-GB18 — Custom M22-XDH-S-X0 M22-XDH-S-X1 M22-XDH-S-X2 M22-XDH-S-X4 M22-XDH-S-X5 M22-XDH-S-X7 M22-XDH-R 3 M22-XDH-R-ETCH 4 Red STOP OFF Green Blue — Custom START ON — Custom RESET White — Custom START Yellow — Custom — — Black, red, green Black, white, red, green, yellow, blue M22-XDH-R-GB0 M22-XDH-R-GB5 M22-XDH-R-X0 M22-XDH-G 3 M22-XDH-G-ETCH 4 M22-XDH-G-GB1 M22-XDH-G-GB6 M22-XDH-G-X1 M22-XDH-B 3 M22-XDH-B-ETCH 4 M22-XDH-B-GB14 M22-XDH-B-X6 M22-XDH-W 3 M22-XDH-W-ETCH 4 M22-XDH-W-GB1 M22-XDH-W-X1 M22-XDH-Y 3 M22-XDH-Y-ETCH 4 M22-XDH-SRG M22-XDH-SWRGYB 1 Buttonless Operator Silver Bezel Catalog Number 5 Black Bezel Catalog Number 5 Metal Bezel Catalog Number 5 1 M22-DR-X M22S-DR-X M22M-DR-X 1 1 M22S-DR-X 1 1 M22M-DR-X 1 1 1 M22-K10 1 Contact Blocks 2 Terminal Type Contact Configuration 6 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage Notes 1 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 2 For complete listing of available button plates and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 3 Minimum order quantity of (10). 4 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XDH-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 5 Includes contact block mounting adapter. 6 All NC contact blocks are positively driven contact. Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-61 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Catalog Number Selection Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. Illuminated Pushbuttons 1 M22 – DRL – R – GB0 – K10 – 230R 1 Bezel M22 = Silver M22S = Black M22M = Metal 1 1 1 DL = DLH = DGL = DRL = DGLH = DRLH = 1 1 1 1 Operator Type Illuminated flush momentary Illuminated extended momentary Illuminated flush momentary with guard 1 Illuminated flush maintained Illuminated extended momentary with guard 1 Illuminated extended maintained W= R= G= Y= B= A= Lens Color White Red Green Yellow Blue Amber K10 = K01 = K20 = K02 = K11 = Contact Blocks 1NO K30 = 3NO 1NC K03 = 3NC 2NO K21 = 2NO-1NC 2NC K12 = 1NO-2NC 1NO-1NC Light Units 12–30 Vac/Vdc W = White R = Red G = Green B = Blue 85–264 Vac 230W = White 230R = Red 230G = Green 230B = Blue Silver bezel only. Inscription GB0 = STOP GB1 = START GB2 = CLOSE GB3 = UP GB4 = DOWN GB5 = OFF GB6 = ON GB14 = RESET GB15 = FORWARD GB16 = REVERSE X0 = X1 = X4 = X5 = X6 = 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-62 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Product Selection 1 Illuminated Pushbuttons, Flush, Momentary M22-DL-G-K01-G 1 Complete Devices Button Color Contact Block Configuration 1 Light Unit Voltage Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number 1 Red NC 12–30 Vac/Vdc M22-DL-R-K01-R M22S-DL-R-K01-R M22M-DL-R-K01-R NC 85–264 Vac M22-DL-R-K01-230R M22S-DL-R-K01-230R M22M-DL-R-K01-230R 1 2NC 12–30 Vac/Vdc M22-DL-R-K02-R M22S-DL-R-K02-R M22M-DL-R-K02-R 2NC 85–264 Vac M22-DL-R-K02-230R M22S-DL-R-K02-230R M22M-DL-R-K02-230R 1NO/1NC 12–30 Vac/Vdc M22-DL-R-K11-R M22S-DL-R-K11-R M22M-DL-R-K11-R 1NO/1NC 85–264 Vac M22-DL-R-K11-230R M22S-DL-R-K11-230R M22M-DL-R-K11-230R NO 12–30 Vac/Vdc M22-DL-G-K10-G M22S-DL-G-K10-G M22M-DL-G-K10-G NO 85–264 Vac M22-DL-G-K10-230G M22S-DL-G-K10-230G M22M-DL-G-K10-230G 2NO 12–30 Vac/Vdc M22-DL-G-K20-G M22S-DL-G-K20-G M22M-DL-G-K20-G 2NO 85–264 Vac M22-DL-G-K20-230G M22S-DL-G-K20-230G M22M-DL-G-K20-230G 1NO/1NC 12–30 Vac/Vdc M22-DL-G-K11-G M22S-DL-G-K11-G M22M-DL-G-K11-G 1NO/1NC 85–264 Vac M22-DL-G-K11-230G M22S-DL-G-K11-230G M22M-DL-G-K11-230G NO 12–30 Vac/Vdc M22-DL-W-K10-W M22S-DL-W-K10-W — NO 85–264 Vac M22-DL-W-K10-230W M22S-DL-W-K10-230W M22M-DL-W-K10-230W 2NO 12–30 Vac/Vdc M22-DL-W-K20-W M22S-DL-W-K20-W — 2NO 85–264 Vac M22-DL-W-K20-230W M22S-DL-W-K20-230W M22M-DL-W-K20-230W 1NO/1NC 12–30 Vac/Vdc M22-DL-W-K11-W M22S-DL-W-K11-W — 1NO/1NC 85–264 Vac M22-DL-W-K11-230W M22S-DL-W-K11-230W M22M-DL-W-K11-230W M22S-DL-G-K01-G Green M22M-DL-G-K01-G White 1 1 1 1 1 1 1 1 1 Note 1 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-63 1.5 1 22.5 mm Modular Pushbuttons—M22 Illuminated Pushbuttons, Flush, Momentary M22-DL-G 1 1 1 1 Pushbuttons and Indicating Lights M22S-DL-G 1 Operators Only 1 Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Red M22-DL-R M22S-DL-R M22M-DL-R Green M22-DL-G M22S-DL-G M22M-DL-G White M22-DL-W M22S-DL-W M22M-DL-W Blue M22-DL-B M22S-DL-B M22M-DL-B Yellow M22-DL-Y M22S-DL-Y M22M-DL-Y Amber M22-DL-A M22S-DL-A M22M-DL-A 1 1 M22M-DL-G 1 1 1 M22-DGL-G 1 1 1 1 Silver Guarded Button Color Silver Bezel Catalog Number Red M22-DGL-R Green M22-DGL-G White M22-DGL-W Blue M22-DGL-B Yellow M22-DGL-Y Note 1 Includes contact block mounting adapter. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-64 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Illuminated Pushbuttons, Flush, Momentary 1 1 1 1 ma x thic . 5mm kne ss 1 1 Note: Included with operator. 1 Components M22-XDL-G Button Lenses 1 Color Inscription Catalog Number Red — Custom STOP OFF M22-XDL-R 2 M22-XDL-R-ETCH 3 M22-XDL-R-GB0 M22-XDL-R-GB5 M22-XDL-R-X0 M22-XDL-G 2 M22-XDL-G-ETCH 3 M22-XDL-G-GB1 M22-XDL-G-GB6 M22-XDL-G-X1 M22-XDL-B 2 Green Blue — Custom START ON — Custom RESET White Yellow Amber M22-DL-X M22-LED-W — Custom — Custom — Custom M22-XDL-B-ETCH 3 M22-XDL-B-GB14 M22-XDL-B-X6 M22-XDL-W 2 M22-XDL-W-ETCH 3 M22-XDL-Y 2 M22-XDL-Y-ETCH 3 M22-XDL-A M22-XDL-A-ETCH Buttonless Operator Silver Bezel Catalog Number 4 Black Bezel Catalog Number 4 Metal Bezel Catalog Number 4 M22-DL-X M22S-DL-X M22M-DL-X M22S-DL-X Terminal Type LED Color Light Unit Voltage Screw White Red Green Blue White Red Green Blue 12–30 Vac/Vdc Screw M22-K10 1 Light Units 1 85–264 Vac Catalog Number M22-LED-W M22-LED-R M22-LED-G M22-LED-B M22-LED230-W M22-LED230-R M22-LED230-G M22-LED230-B 1 1 1 1 1 Contact Blocks 1 Terminal Type Contact Configuration 5 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage 1 Notes 1 For complete listing of available button lenses, light units and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 Minimum order quantity of (10). 3 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XDL-R-ETCH; Order Notes: Mark with symbol X91, Line item #_. 4 Includes contact block mounting adapter. 5 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 M22M-DL-X 1 1 M22-DGL-X Silver Guarded 1 Silver Bezel Catalog Number 4 1 M22-DGL-X 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-65 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Illuminated Pushbuttons, Flush, Maintained 2 M22-DRL-W-K10-W Complete Devices Button Color 1 White 1 1 M22S-DRL-W-K10-W 1 1 1 M22M-DRL-W-K10-W Contact Block Configuration 1 Light Unit Voltage Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number NO 12–30 Vac/Vdc M22-DRL-W-K10-W M22S-DRL-W-K10-W M22M-DRL-W-K10-W NO 85–264 Vac M22-DRL-W-K10-230W M22S-DRL-W-K10-230W M22M-DRL-W-K10-230W NC 12–30 Vac/Vdc M22-DRL-W-K01-W M22S-DRL-W-K01-W M22M-DRL-W-K01-W NC 85–264 Vac M22-DRL-W-K01-230W M22S-DRL-W-K01-230W M22M-DRL-W-K01-230W 2NO 12–30 Vac/Vdc M22-DRL-W-K20-W M22S-DRL-W-K20-W M22M-DRL-W-K20-W 2NO 85–264 Vac M22-DRL-W-K20-230W M22S-DRL-W-K20-230W M22M-DRL-W-K20-230W 2NC 12–30 Vac/Vdc M22-DRL-W-K02-W M22S-DRL-W-K02-W M22M-DRL-W-K02-W 2NC 85–264 Vac M22-DRL-W-K02-230W M22S-DRL-W-K02-230W M22M-DRL-W-K02-230W 1NO/1NC 12–30 Vac/Vdc M22-DRL-W-K11-W M22S-DRL-W-K11-W M22M-DRL-W-K11-W 1NO/1NC 85–264 Vac M22-DRL-W-K11-230W M22S-DRL-W-K11-230W M22M-DRL-W-K11-230W 1 1 1 1 M22-DRL-W Operators Only 3 1 Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Red M22-DRL-R M22S-DRL-R M22M-DRL-R 1 Green M22-DRL-G M22S-DRL-G M22M-DRL-G White M22-DRL-W M22S-DRL-W M22M-DRL-W Blue M22-DRL-B M22S-DRL-B M22M-DRL-B Yellow M22-DRL-Y M22S-DRL-Y M22M-DRL-Y Amber M22-DRL-A M22S-DRL-A M22M-DRL-A 1 M22S-DRL-W 1 1 1 1 M22M-DRL-W 1 1 1 Notes 1 All NC contact blocks are positively driven contact. 2 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 3 Includes contact block mounting adapter. 1 1 1 1 1 1 1 Note: This pilot device features a selectable function switch that enables the device to be set to either maintained or momentary operation. 1 V7-T1-66 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Illuminated Pushbuttons, Flush, Maintained 1 1 1 1 1 ma x thic . 5mm kne ss 1 1 Note: Included with operator. 1 1 Components M22-XDL-W Button Lenses 2 Color Inscription Catalog Number Red — M22-XDL-R 3 Custom STOP OFF White — Custom M22-XDL-R-ETCH 4 M22-XDL-R-GB0 M22-XDL-R-GB5 M22-XDL-R-X0 M22-XDL-G 3 M22-XDL-G-ETCH 4 M22-XDL-G-GB1 M22-XDL-G-GB6 M22-XDL-G-X1 M22-XDL-B 3 M22-XDL-B-ETCH 4 M22-XDL-B-GB14 M22-XDL-B-X6 M22-XDL-W 3 M22-XDL-W-ETCH 4 Yellow — Custom — Custom M22-XDL-Y 3 M22-XDL-Y-ETCH 4 M22-XDL-A M22-XDL-A-ETCH Green Blue Amber M22-DRL-X M22S-DRL-X M22-LED-W — Custom START ON — Custom RESET Buttonless Operator Silver Bezel Catalog Number 5 Black Bezel Catalog Number 5 Metal Bezel Catalog Number 5 M22-DRL-X M22S-DRL-X M22M-DRL-X Light Units 2 Terminal Type LED Color Light Unit Voltage Screw White Red Green Blue White Red Green Blue 12–30 Vac/Vdc Screw 85–264 Vac Catalog Number M22-LED-W M22-LED-R M22-LED-G M22-LED-B M22-LED230-W M22-LED230-R M22-LED230-G M22-LED230-B 1 1 1 1 1 1 M22-K10 Contact Blocks 2 1 Terminal Type Contact Configuration 6 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage Notes 1 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 2 For complete listing of available button lenses, light units and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 3 Minimum order quantity of (10). 4 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XDL-R-ETCH; Order Notes: Mark with symbol X91, Line item #_. 5 Includes contact block mounting adapter. 6 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 M22M-DRL-X 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-67 1.5 1 1 22.5 mm Modular Pushbuttons—M22 Illuminated Pushbuttons, Extended, Momentary M22-DLH-R-K11-R Complete Devices Button Color 1 1 Pushbuttons and Indicating Lights Red M22S-DLH-R-K11-R 1 Green White 1 Contact Block Configuration 1 Light Unit Voltage Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number M22M-DLH-R-K11-R 1NO/1NC 12–30 Vac/Vdc M22-DLH-R-K11-R M22S-DLH-R-K11-R 1NO/1NC 85–264 Vac M22-DLH-R-K11-230R M22S-DLH-R-K11-230R M22M-DLH-R-K11-230R 2NO 12–30 Vac/Vdc M22-DLH-G-K20-G M22S-DLH-G-K20-G M22M-DLH-G-K20-G 2NO 85–264 Vac M22-DLH-G-K20-230G M22S-DLH-G-K20-230G M22M-DLH-G-K20-230G 2NO 12–30 Vac/Vdc M22-DLH-W-K20-W M22S-DLH-W-K20-W M22M-DLH-W-K20-W 2NO 85–264 Vac M22-DLH-W-K20-230W M22S-DLH-W-K20-230W M22M-DLH-W-K20-230W 1 1 Complete Press-to-Test Units 1 Button Color Light Unit Voltage Silver Bezel Catalog Number Black Bezel Catalog Number Red 12–30 Vac/Vdc M22-T-R-R M22S-T-R-R 1 Blue M22-T-B-B M22S-T-B-B Yellow M22-T-Y-W M22S-T-Y-W Green M22-T-G-G M22S-T-G-G 1 White M22-T-W-W M22S-T-W-W M22-T-R-230R M22S-T-R-230R 1 Blue M22-T-R-230B M22S-T-B-230B Yellow M22-T-Y-230W M22S-T-Y-230W 1 Green M22-T-G-230G M22S-T-G-230G White M22-T-W-230W M22S-T-W-230W 1 Red 1 1 M22-DLH-R 85–264 Vac Operators Only 2 Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Red M22-DLH-R M22S-DLH-R M22M-DLH-R Green M22-DLH-G M22S-DLH-G M22M-DLH-G White M22-DLH-W M22S-DLH-W M22M-DLH-W 1 Blue M22-DLH-B M22S-DLH-B M22M-DLH-B Yellow M22-DLH-Y M22S-DLH-Y M22M-DLH-Y 1 Amber M22-DLH-A M22S-DLH-A M22M-DLH-A 1 1 1 M22S-DLH-R M22M-DLH-R 1 1 1 1 M22-DGLH-R Silver Guarded Button Color Silver Bezel Catalog Number 1 Red M22-DGLH-R Green M22-DGLH-G 1 White M22-DGLH-W Blue M22-DGLH-B Yellow M22-DGLH-Y 1 1 Notes 1 All NC contact blocks are positively driven contact. 2 Includes contact block mounting adapter. 1 V7-T1-68 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Illuminated Pushbuttons, Extended, Momentary 1 1 1 1 ma x thic . 5mm kne ss 1 1 Note: Included with operator. 1 Components M22-XDH-R Button Lenses 1 Color Inscription Catalog Number Red — Custom STOP OFF M22-XDLH-R 2 M22-XDLH-R-ETCH 3 M22-XDLH-R-GB0 M22-XDLH-R-GB5 M22-XDLH-R-X0 M22-XDLH-G 2 M22-XDLH-G-ETCH 3 M22-XDLH-G-GB1 M22-XDLH-G-GB6 M22-XDLH-G-X1 M22-XDLH-B 2 M22-XDLH-B-ETCH 3 M22-XDLH-B-GB14 M22-XDLH-B-X6 M22-XDLH-W 2 M22-XDLH-W-ETCH 3 M22-XDLH-Y 2 M22-XDLH-Y-ETCH 3 M22-XDLH-A M22-XDLH-A-ETCH Green Blue White Yellow Amber M22-DL-X M22-LED-W — Custom START ON — Custom RESET — Custom — Custom — Custom Buttonless Operator Silver Bezel Catalog Number 4 Black Bezel Catalog Number 4 Metal Bezel Catalog Number 4 M22-DL-X M22S-DL-X M22M-DL-X M22S-DL-X 1 Light Units 1 Terminal Type LED Color Light Unit Voltage Screw White Red Green Blue White Red 12–30 Vac/Vdc Screw 85–264 Vac Green Blue Catalog Number 1 M22-LED-W M22-LED-R M22-LED-G M22-LED-B M22-LED230-W M22-LED230-R 1 M22-LED230-G M22-LED230-B 1 1 1 1 M22-K10 Contact Blocks 1 1 Terminal Type Contact Configuration 5 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage Notes 1 For complete listing of available button lenses, light units and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 Minimum order quantity of (10). 3 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XDH-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 4 Includes contact block mounting adapter. 5 All NC contact blocks are positively driven contact. M22M-DL-X 1 1 1 1 1 1 1 1 1 1 1 1 M22-DGL-X 1 Silver Guarded Silver Bezel Catalog Number 4 1 1 M22-DGL-X Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-69 1.5 1 1 22.5 mm Modular Pushbuttons—M22 Illuminated Pushbuttons, Extended, Maintained 1 M22-DRLH-W 1 1 1 Pushbuttons and Indicating Lights M22S-DRLH-W 1 Operators Only 2 Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Red M22-DRLH-R M22S-DRLH-R M22M-DRLH-R Green M22-DRLH-G M22S-DRLH-G M22M-DRLH-G White M22-DRLH-W M22S-DRLH-W M22M-DRLH-W Blue M22-DRLH-B M22S-DRLH-B M22M-DRLH-B Yellow M22-DRLH-Y M22S-DRLH-Y M22M-DRLH-Y Amber M22-DRLH-A M22S-DRLH-A M22M-DRLH-A 1 1 M22M-DRLH-W 1 1 1 Notes 1 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 2 Includes contact block mounting adapter. 1 1 1 1 1 1 1 Note: This pilot device features a selectable function switch that enables the device to be set to either maintained or momentary operation. 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-70 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Illuminated Pushbuttons, Extended, Maintained 1 1 1 1 1 ma x thic . 5mm kne ss 1 1 Note: Included with operator. 1 Components M22-XDLH-W Button Lenses 2 Color Inscription Catalog Number Red — Custom STOP OFF M22-XDLH-R 3 M22-XDLH-R-ETCH 4 M22-XDLH-R-GB0 M22-XDLH-R-GB5 M22-XDLH-R-X0 M22-XDLH-G 3 M22-XDLH-G-ETCH 4 M22-XDLH-G-GB1 M22-XDLH-G-GB6 M22-XDLH-G-X1 M22-XDLH-B 3 M22-XDLH-B-ETCH 4 M22-XDLH-B-GB14 M22-XDLH-B-X6 M22-XDLH-W 3 M22-XDLH-W-ETCH 4 M22-XDLH-Y 3 M22-XDLH-Y-ETCH 4 M22-XDLH-A M22-XDLH-A-ETCH Green Blue White Yellow Amber M22-DRL-X M22S-DRL-X M22-LED-W — Custom START ON — Custom RESET — Custom — Custom — Custom Buttonless Operator Silver Bezel Catalog Number 5 Black Bezel Catalog Number 5 Metal Bezel Catalog Number 5 M22-DRL-X M22S-DRL-X M22M-DRL-X 1 Light Units 2 Terminal Type LED Color Light Unit Voltage Screw White Red Green Blue White Red 12–30 Vac/Vdc Screw 85–264 Vac Green Blue Catalog Number 1 M22-LED-W M22-LED-R M22-LED-G M22-LED-B M22-LED230-W M22-LED230-R 1 M22-LED230-G M22-LED230-B 1 1 1 1 M22-K10 Contact Blocks 2 1 Terminal Type Contact Configuration 6 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage Notes 1 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 2 For complete listing of available button lenses, light units and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 3 Minimum order quantity of (10). 4 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XDLH-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 5 Includes contact block mounting adapter. 6 All NC contact blocks are positively driven contact. M22M-DRL-X 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-71 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1 Indicating Lights 1 Eaton’s M22 indicating lights use the combination of a durable, bright LED unit and modern lenses designed specifically for this type of LED to create a bright and visible indicating light. 1 1 1 Product Description Features As with the pushbuttons, the indicating light lenses can be laser engraved. Indicating lights can be ordered as complete devices, including lens and LED unit, or as modular components. ● ● ● 1 Customizable laser engraving on all lenses LED offering only for improved brightness quality and up to 100,000 hours of operation Lenses designed specifically for LED illumination 1 1 1 Catalog Number Selection Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. Indicating Lights M22 - L – B – GB8 – B 1 Operator Type M22-L = Flush indicating light 1 W= R= G= Y= B= 1 1 Plate Inscription ETCH = GB5 = GB6 = GB8 = GB15 = GB16 = Note: Light unit should match color of lens. Use white light unit with yellow lens. Custom 1 OFF ON FAULT FORWARD REVERSE 12–30 Vac/Vdc W = White R = Red G = Green B = Blue Light Units 85–264 Vac 230W = White 230R = Red 230G = Green 230B = Blue When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-L-B-ETCH; Order Notes: Mark with symbol X91, Line item #_. Product Selection 1 Indicating Lights, Flush 1 M22-L-R-R 1 1 1 1 1 1 1 Complete Devices Lens Color Light Color Light Unit Voltage Catalog Number White Red Green Yellow Blue Amber White Red Green Yellow Blue Amber White Red Green White Blue White White Red Green White Blue White 12–30 Vac/Vdc M22-L-W-W M22-L-R-R M22-L-G-G M22-L-Y-W M22-L-B-B M22-L-A-W M22-L-W-230W M22-L-R-230R M22-L-G-230G M22-L-Y-230W M22-L-B-230B M22-L-A-230W 85–264 Vac Operators Only 1 1 1 Lens Color White Red Green Yellow Blue 1 1 1 Modular construction makes assembly fast and simplifies stocking of components and complete devices ● Capable of communicating via ASi protocol with ASi adapter modules Protection Type ● IP67, IP69K ● NEMA 4X, 13 ● Lens Color M22-L-R 1 1 1 Flat White Red Green Yellow Blue Amber Catalog Number Lens Color Catalog Number M22-L-W M22-L-R M22-L-G M22-L-Y M22-L-B M22-L-A Conical White Red Green Yellow Blue Amber M22-LH-W M22-LH-R M22-LH-G M22-LH-Y M22-LH-B M22-LH-A M22-LH-R Note 1 Includes contact block mounting adapter. 1 V7-T1-72 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Indicating Lights, Flush 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 Components M22-XL-R Lenses 1 Color M22-LED-W Inscription Catalog Number Flat Red Green Blue White Yellow Amber Conical Red Green Blue White Yellow Amber M22-L-X — Custom OFF — Custom ON REVERSE — Custom M22-XL-R 2 M22-XL-R-ETCH 3 M22-XL-R-GB5 M22-XL-G 2 M22-XL-G-ETCH 3 M22-XL-G-GB6 M22-XL-G-GB16 M22-XL-B 2 M22-XL-B-ETCH 3 FAULT — Custom M22-XL-B-GB8 M22-XL-W 2 M22-XL-W-ETCH 3 OFF ON FAULT FORWARD — Custom — Custom M22-XL-W-GB5 M22-XL-W-GB6 M22-XL-W-GB8 M22-XL-W-GB15 M22-XL-Y 2 M22-XL-Y-ETCH 3 M22-XL-A 2 M22-XL-A-ETCH 3 — — — — — — M22-XLH-R M22-XLH-G M22-XLH-B M22-XLH-W M22-XLH-Y M22-XLH-A Light Units 14 Terminal Type LED Color Light Unit Voltage Screw White Red Green Blue White Red Green Blue 12–30 Vac/Vdc Screw 85–264 Vac Catalog Number M22-LED-W M22-LED-R M22-LED-G M22-LED-B M22-LED230-W M22-LED230-R M22-LED230-G M22-LED230-B 1 1 1 1 1 1 Notes 1 For complete listing of available lenses and light units, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 Minimum order quantity of (10). 3 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XL-R-ETCH; Order Notes: Mark with symbol X91, Line item #_. 4 Select the same color LED element as lens color; for yellow and amber lenses, choose a white LED. 1 1 1 1 1 1 1 1 1 1 Lensless Indicating Light Catalog Number 1 M22-L-X 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-73 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1 Emergency Stops Product Description Features 1 Eaton’s M22 emergency stops are a durable and reliable solution to a variety of e-stop applications. With standard push-pull, as well as twist-to-release and keyrelease, illuminated options and red or black operators, the M22 e-stop is a robust solution. As with all operators, they can be ordered as a ready to install complete device or as modular components for the perfect fit. ● 1 1 1 1 1 1 ● ● ● Push-pull and twist to release options available as well as illuminated and keyed release LED offering only for improved brightness quality and up to 100,000 hours of operation More than 100,000 mechanical operations Capable of communicating via ASi protocol with ASi adapter modules ● Suitable for use in safety applications up to Category-4 or Sil-3 Protection Type ● IP67, IP69K (IP66 key-release) ● NEMA 4X, 13 1 1 Catalog Number Selection 1 Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. 1 Emergency Stops M22 – PVT – MS2 – K10 – 230R 1 1 Operator Color M22 = Silver M22S = Black 1 1 1 1 1 1 1 1 1 PV = PV45P = PV60P = PV45P-MPI = PV60P-MPI = PVT = PVT45P = PVT60P = PVT45P-MPI = PVT60P-MPI = PVS = PVS45P = PVS60P = PVL = PVLT = PVLT45P = PVLT60P = Operator Type Non-illuminated push-pull emergency stop Non-illuminated 45 mm emergency stop Non-illuminated 60 mm emergency stop Non-illuminated mechanical indication, 45 mm Non-illuminated mechanical indication, 60 mm Non-illuminated twist-to-release emergency stop Non-illuminated twist-to-release 45 mm emergency stop Non-illuminated twist-to-release 60 mm emergency stop Non-illuminated twist-to-release with mechanical indication, 45 mm Non-illuminated twist-to-release with mechanical indication, 60 mm Non-illuminated keyed release (red operator only) Non-illuminated keyed release 45 mm (red only) Non-illuminated keyed release 60 mm (red only) Illuminated push-pull emergency stop Illuminated twist-to-release emergency stop Illuminated twist-to-release 45 mm emergency stop Illuminated twist-to-release 60 mm emergency stop Key Release Code Blank = MS1 MS2 = MS2 MS3 = MS3 MS4 = MS4 MS5 = MS5 MS6 = MS6 MS7 = MS7 MS8 = MS8 RS = Ronis (45 and 60 mm only) Contact Blocks K10 = NO K10P = NO, early-make K01 = NC K01D = NC, late-break CK10 = NO CK01 = NC CK01D = NC, late-break Ck20 = 2NO CK02 = 2NC CK11 = NO-NC Light Units 12–30 Vac/Vdc W = White R = Red G = Green B = Blue 85–264 Vac 230W = White 230R = Red 230G = Green 230B = Blue 1 1 1 1 1 1 1 V7-T1-74 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Product Selection 1 Non-Illuminated and Illuminated Emergency Stops 1 Complete Devices Type M22-PV-K01 LED Color Contact Block Configuration 1 Light Unit Voltage Catalog Number — NC — M22-PV-K01 1 1 Non-Illuminated Push-pull Twist-to-release Key release M22-PVL-K01-R Button Color Red Red Red — — 2NC M22-PV-K02 1NO-2NC M22-PV-K12 NC — M22-PVT-K02 1NO-2NC M22-PVT-K12 — 1 M22-PVT-K01 2NC NC 1 1 1 M22-PVS-K01 2NC M22-PVS-K02 1NO-2NC M22-PVS-K12 1 M22-PVL-K01-R 1 Illuminated Push-pull Red Red NC 2NC M22-PVL-K02-R 1NO-2NC M22-PVL-K12-R NC Twist-to-release Red Red 12–30 Vac/Vdc 85–264 Vac M22-PVL-K02-230R 1NO-2NC M22-PVL-K12-230R 12–30 Vac/Vdc 2NC 1 M22-PVLT-K01-R 1 M22-PVLT-K02-R 1NO-2NC NC 1 M22-PVL-K01-230R 2NC NC 1 1 M22-PVLT-K12-R 85–264 Vac M22-PVLT-K01-230R 2NC M22-PVLT-K02-230R 1NO-2NC M22-PVLT-K12-230R 1 1 Note 1 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-75 1.5 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Non-Illuminated and Illuminated Emergency Stops 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 1 1 Components M22-PVL 1 Push-Pull Emergency Stops Actuator Size Catalog Number Actuator Size Key Code Catalog Number None 35 mm M22-PV 35 mm MS1 M22-PVS 3 45 mm M22-PV45P MS2 M22-PVS-MS2 60 mm M22-PV60P MS3 M22-PVS-MS3 35 mm M22-PVL MS4 M22-PVS-MS4 45 mm M22-PVL45P MS5 M22-PVS-MS5 60 mm M22-PVL60P MS6 M22-PVS-MS6 45 mm M22-PV45P-MPI MS7 M22-PVS-MS7 60 mm M22-PV60P-MPI MS8 M22-PVS-MS8 MS1 M22-PVS45P MS2 M22-PVS45P-MS2 MS3 M22-PVS45P-MS3 MS4 M22-PVS45P-MS4 MS5 M22-PVS45P-MS5 MS6 M22-PVS45P-MS6 MS7 M22-PVS45P-MS7 MS8 M22-PVS45P-MS8 Ronis M22-PVS45P-RS MS1 M22-PVS60P MS2 M22-PVS60P-MS2 MS3 M22-PVS60P-MS3 MS4 M22-PVS60P-MS4 MS5 M22-PVS60P-MS5 MS6 M22-PVS60P-MS6 MS7 M22-PVS60P-MS7 MS8 M22-PVS60P-MS8 Ronis M22-PVS60P-RS LED illumination 1 Mechanical indication 1 1 1 45 mm M22-PVT45P-MPI Twist-to-Release Emergency Stops Illumination/Indication 1 None 1 Actuator Size 35 mm 45 mm 60 mm 1 LED illumination 35 mm 1 1 Mechanical indication M22S-PVLT 1 1 1 M22-PVT M22-PVT45P M22-PVT60P M22-PVLT M22-PVLT45P 60 mm M22-PVLT60P 45 mm M22-PVT45P-MPI M22-PVT60P-MPI Machine Stop Operators (Black) 1 Illumination Type Actuator Size Catalog Number Non-illuminated Push-pull 35 mm M22S-PV Twist-torelease 35 mm M22S-PVT Push-pull 35 mm M22S-PVL Twist-torelease 35 mm M22S-PVLT LED illumination 1 Catalog Number 45 mm 60 mm 1 1 Key Release Emergency Stops 2 Illumination/Indication 1 1 M22-PVS60P-MS1 60 mm Notes 1 Includes contact block mounting adapter. 2 Key included. For identical locks and keys, use the same key code. One key is included with actuator; additional keys are available as accessories. 3 Includes Key Code MS1. 1 1 V7-T1-76 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 M22-K10 Contact Blocks 1 Accessories Terminal Type Mounting Contact Location 2 Configuration 3 Catalog Number Screw Front Base Springcage Front NO M22-K10 NO, early-make M22-K10P NC M22-K01 NC, late-break M22-K01D SMCB, NC M22-K01SMC10 SMCB, 2NC M22-K02SMC10 SMCB, NC M22-KC01SMC10 SMCB, 2NC M22-KC02SMC10 NO M22-CK10 NC M22-CK01 NC, late-break M22-CK01D 2NO M22-CK20 2NC M22-CK02 NO-NC M22-CK11 M22-XGPV Voltage Catalog Number Yellow guard ring — M22-XGPV M22G-XGPV Gray guard ring — M22G-XGPV Screw Screw Screw LED Color Light Unit Voltage Catalog Number White 12–30 Vac/Vdc M22-LED-W Red 12–30 Vac/Vdc M22-LED-R M22-MGTA Rectangular guard — M22-MGTA — M22-PL-PV M22-XPV60-Y-120 85–264 Vac M22-LED230-W M22-LED230-R 230 Vac White 207–264 Vac M22-LED230H-W Red 207–264 Vac M22-LED230H-R M22-ES-MS1 MS2 M22-ES-MS2 MS3 M22-ES-MS3 MS4 M22-ES-MS4 MS5 M22-ES-MS5 MS6 M22-ES-MS6 MS7 M22-ES-MS7 MS8 M22-ES-MS8 1 1 85–264 Vac MS1 1 1 Sealing shroud White Catalog Number 1 1 Red For Key Code 1 1 24 Vac/Vdc 120 Vac Extra Keys 4 1 1 Light Units 1 Terminal Type M22-ES-MS1 Description 1 M22-PL-PV M22-LED-W 1.5 Illuminated ring M22-XPV60-Y-24 M22-XPV60-Y-120 M22-XPV60-Y-230 1 1 1 Notes 1 For complete listing of available contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 Self-monitoring contact blocks (SMCB type) cannot be used with illuminated emergency stops. 3 All NC contact blocks are positively driven contact. 4 For use with key release operators only. One key included with operator. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-77 1.5 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Contents Selector Switches Description 1 Selector Switches Non-Illuminated Switches . . . . . . . . . . . . . . . . . Illuminated Switches . . . . . . . . . . . . . . . . . . . . Key Operated . . . . . . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 1 1 1 1 Selector Switches 1 Product Description Features Eaton’s M22 selector switch line offers an almost endless variety of options in maintained/momentary, keyremoval and illuminated devices. The coding adapters used for maintained/ momentary and key removal positions make the M22 stand out from competitive devices. By simply adding or removing a coding adapter from inside the operator, the end-user can change the function of the button. Operator options include standard knob, rotary head, illuminated and keyed versions. As with all operators, they can be ordered as a ready to install complete device or as modular components to meet application specific requirements. ● 1 1 1 1 1 1 1 1 1 1 1 ● ● Adding or removing coding adapters allows for field convertibility of maintained/momentary and key removal positions LED offering only for improved brightness quality and up to 100,000 hours of operation More than 100,000 mechanical operations ● ● Coding adapter options make assembly fast and simplify stocking of different configurations of selector switches Capable of communicating via ASi protocol with ASi adapter modules Protection Type ● IP66 ● NEMA 4X, 13 1 1 1 1 1 1 1 V7-T1-78 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Page V7-T1-79 V7-T1-84 V7-T1-88 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Catalog Number Selection Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. 1 Non-Illuminated Selector Switches 1 1 M22 – WRK – – X91 – K10 1 Bezel M22 = Silver M22S = Black M22M = Metal Inscription 2 X91 = AUTO-HAND X92 = II-I 2 W= WK = WKV = WR = WRK = 1 Handle Type 1 Momentary rotary Momentary knob Maintained V-position knob Maintained rotary Maintained knob Number of Positions Blank = Two-position 3 = Three-position 4 = Four-position Contact Blocks K10 = NO K10P = NO, early-make Rotary type only. K11 = K22 = K20 = K02 = 1 1 Options NO-NC 2NO-2NC 2NO 2NC 1 1 1 All momentary selector switches can be converted in the field to maintained operation with the removal of a colorcoded adapter. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-79 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Product Selection Non-Illuminated Selector Switches M22-WKV-K10 1 1 Complete Devices, Knob Type 1 Type Switching Position Two-position Maintained 40° 1 1 Contact Block Configuration 2 Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number NO M22-WRK-K10 M22S-WRK-K10 M22M-WRK-K10 1NO-1NC M22-WRK-K11 M22S-WRK-K11 M22M-WRK-K11 2NO-2NC M22-WRK-K22 M22S-WRK-K22 M22M-WRK-K22 M22M-WKV-K10 Maintained V 60° 1 1 Three-position 1 Maintained 60° 1 NO M22-WKV-K10 M22S-WKV-K10 M22M-WKV-K10 1NO-1NC M22-WKV-K11 M22S-WKV-K11 M22M-WKV-K11 2NO-2NC M22-WKV-K22 M22S-WKV-K22 M22M-WKV-K22 2NO M22-WRK3-K20 M22S-WRK3-K20 M22M-WRK3-K20 2NO-2NC M22-WRK3-K22 M22S-WRK3-K22 M22M-WRK3-K22 60° Notes 1 Includes contact block mounting adapter. 2 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-80 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Non-Illuminated Selector Switches 1 Components M22-WK 1 Operators Only, Knob Type 1 Type Switching Position Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number 1 Two-position Momentary 2 M22-WK M22S-WK M22M-WK 1 M22-WRK M22S-WRK M22M-WRK M22-WKV M22S-WKV M22M-WKV 40° 1 Maintained 1 40° M22M-WK Maintained V 1 1 60° Three-position Momentary 40° 2 Four-position Maintained M22-WRK3 M22S-WRK3 M22M-WRK3 M22-WRK3-2 M22S-WRK3-2 M22M-WRK3-2 M22-WRK3-1 M22S-WRK3-1 M22M-WRK3-1 1 1 60° 1 40° 60° 40° 60° 1 60° Maintained, return from right 40° M22M-WK3 1 Maintained, return from left 40° M22S-WK3 40° Maintained 60° M22-WK3 1 1 60° M22-WRK4 M22S-WRK4 1 M22M-WRK4 1 1 1 Notes 1 Includes contact block mounting adapter. 2 Momentary selector switches can be converted in the field to maintained operation with the removal of a color coded adapter. See Page V7-T1-118. 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-81 1.5 1 22.5 mm Modular Pushbuttons—M22 Non-Illuminated Selector Switches Components 1 1 Pushbuttons and Indicating Lights M22S-WR3-X94 1 Operators Only, Rotary Type 1 Type Switching Position Inscription Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Two-position Momentary 2 I-O M22-W M22S-W M22M-W I-O M22-WR M22S-WR M22M-WR Custom M22-WR-ETCH 3 M22S-WR-ETCH 3 M22M-WR-ETCH 3 AUTO-HAND M22-WR-X91 M22S-WR-X91 M22M-WR-X91 II-I M22-WR-X92 M22S-WR-X92 M22M-WR-X92 I-O-II M22-W3 M22S-W3 M22M-W3 I-O-II M22-WR3 M22S-WR3 M22M-WR3 Custom M22-WR3-ETCH 3 M22S-WR3-ETCH 3 M22M-WR3-ETCH 3 AUTO-O-MAN M22-WR3-X94 M22S-WR3-X94 M22M-WR3-X94 0-1-0-2-0-3-0-4 M22-WR4 M22S-WR4 M22M-WR4 40° 1 1 Maintained 40° 1 1 Three-position Momentary 2 1 40° 1 Maintained 1 60° 1 Four-position Maintained 40° 60° 1 1 1 Notes 1 Includes contact block mounting adapter. 2 Momentary selector switches can be converted in the field to maintained operation with the removal of a color coded adapter. See Page V7-T1-118. 3 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-WR3-ETCH; Order Notes: Mark with symbol X88, Line item #_. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-82 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Non-Illuminated Selector Switches 1 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 Components M22-K10 Contact Blocks 1 Terminal Type Contact Configuration 2 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage 1 Accessories M22-XW Description Catalog Number Plunger bridge 3 M22-XW 1 1 1 M22-XWS Key cover M22-XWS 1 1 M22-XC-R Key withdraw adapter 4 M22-XC-R 1 1 M22-XC-Y Coding adapter M22-XC-Y 1 1 1 M22-XGWK Guard ring M22-XGWK 1 1 Notes 1 For complete listing of available contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 All NC contact blocks are positively driven contact. 3 Plunger needed to actuate center-mounted contact blocks. Used for non-illuminated three-position selector switches only. 4 Enables a keyed selector switch to be set to user-selected key withdraw position. 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-83 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Catalog Number Selection Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. Illuminated Selector Switches 1 M22 – WLK – R – K10 – R 1 Bezel M22 = Silver M22S = Black M22M = Metal 1 1 1 Handle Type WLK = Illuminated knob type momentary, two-position WLKV = Illuminated Knob type momentary, V-position WLK3 = Illuminated knob type momentary, three-position 1 1 Handle Color W = White R = Red G = Green Y = Yellow B = Blue K10 = K01 = K20 = K02 = K11 = Contact Blocks 1NO K30 = 3NO 1NC K03 = 3NC 2NO K21 = 2NO-1NC 2NC K12 = 1NO-2NC 1NO-1NC Light Units 12–30 Vac/Vdc W = White R = Red G = Green B = Blue 85–264 Vac 230W = White 230R = Red 230G = Green 230B = Blue 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-84 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Product Selection 1 Illuminated Selector Switches 1 Components M22-WLK-W 1 Operators Only, Knob Type 1 Type Switching Position Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number 1 Two-position Momentary 2 White M22-WLK-W M22S-WLK-W M22M-WLK-W Red M22-WLK-R M22S-WLK-R M22M-WLK-R 1 Green M22-WLK-G M22S-WLK-G M22M-WLK-G Yellow M22-WLK-Y M22S-WLK-Y M22M-WLK-Y Blue M22-WLK-B M22S-WLK-B M22M-WLK-B 40° Maintained 40° Maintained V 60° 1 1 White M22-WRLK-W M22S-WRLK-W M22M-WRLK-W Red M22-WRLK-R M22S-WRLK-R M22M-WRLK-R Green M22-WRLK-G M22S-WRLK-G M22M-WRLK-G Yellow M22-WRLK-Y M22S-WRLK-Y M22M-WRLK-Y Blue M22-WRLK-B M22S-WRLK-B M22M-WRLK-B White M22-WLKV-W M22S-WLKV-W M22M-WLKV-W Red M22-WLKV-R M22S-WLKV-R M22M-WLKV-R Green M22-WLKV-G M22S-WLKV-G M22M-WLKV-G Yellow M22-WLKV-Y M22S-WLKV-Y M22M-WLKV-Y Blue M22-WLKV-B M22S-WLKV-B M22M-WLKV-B Notes 1 Includes contact block mounting adapter. 2 Momentary selector switches can be converted in the field to maintained operation with the removal of a color coded adapter. See Page V7-T1-118. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-85 1.5 1 22.5 mm Modular Pushbuttons—M22 Illuminated Selector Switches Components 1 1 Pushbuttons and Indicating Lights M22-WLK3-W 1 1 Operators Only, Knob Type 1 Type Switching Position Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Three-position Momentary 2 White M22-WLK3-W M22S-WLK3-W M22M-WLK3-W Red M22-WLK3-R M22S-WLK3-R M22M-WLK3-R Green M22-WLK3-G M22S-WLK3-G M22M-WLK3-G Yellow M22-WLK3-Y M22S-WLK3-Y M22M-WLK3-Y Blue M22-WLK3-B M22S-WLK3-B M22M-WLK3-B White M22-WRLK3-W M22S-WRLK3-W M22M-WRLK3-W Red M22-WRLK3-R M22S-WRLK3-R M22M-WRLK3-R Green M22-WRLK3-G M22S-WRLK3-G M22M-WRLK3-G Yellow M22-WRLK3-Y M22S-WRLK3-Y M22M-WRLK3-Y Blue M22-WRLK3-B M22S-WRLK3-B M22M-WRLK3-B M22M-WRLK3-1-W 40° 40° 1 1 Maintained 1 60° 60° 1 1 Maintained, return from right 1 40° 40° 60° 60° 1 1 Maintained, return from left 1 40° 1 40° 60° 60° White M22-WRLK3-1-W M22S-WRLK3-1-W Red M22-WRLK3-1-R M22S-WRLK3-1-R M22M-WRLK3-1-R Green M22-WRLK3-1-G M22S-WRLK3-1-G M22M-WRLK3-1-G Yellow M22-WRLK3-1-Y M22S-WRLK3-1-Y M22M-WRLK3-1-Y Blue M22-WRLK3-1-B M22S-WRLK3-1-B M22M-WRLK3-1-B White M22-WRLK3-2-W M22S-WRLK3-2-W M22M-WRLK3-2-W Red M22-WRLK3-2-R M22S-WRLK3-2-R M22M-WRLK3-2-R Green M22-WRLK3-2-G M22S-WRLK3-2-G M22M-WRLK3-2-G Yellow M22-WRLK3-2-Y M22S-WRLK3-2-Y M22M-WRLK3-2-Y Blue M22-WRLK3-2-B M22S-WRLK3-2-B M22M-WRLK3-2-B Notes 1 Includes contact block mounting adapter. 2 Momentary selector switches can be converted in the field to maintained operation with the removal of a color coded adapter. See Page V7-T1-118. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-86 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Illuminated Selector Switches 1 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. M22-LED-W Light Units 1 5 LED Color Light Unit Voltage Screw White Red Green Blue White Red Green Blue 12–30 Vac/Vdc 85–264 Vac Catalog Number M22-LED-W M22-LED-R M22-LED-G M22-LED-B M22-LED230-W M22-LED230-R M22-LED230-G M22-LED230-B M22-XW Description Catalog Number Plunger bridge 2 M22-XW 1 M22-XWS Key cover M22-XWS Contact Configuration Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC Spring-cage 3 Key withdraw adapter 4 M22-XC-R 1 1 Catalog Number M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 1 1 Contact Blocks 1 Terminal Type 1 1 M22-XC-R M22-K10 1 Accessories Terminal Type Screw 1 M22-XC-Y Coding adapter M22-XC-Y 1 1 M22-XGWK Guard ring M22-XGWK 1 1 Notes 1 For complete listing of available light units and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 Plunger needed to actuate center-mounted contact blocks. Used for non-illuminated three-position selector switches only. 3 All NC contact blocks are positively driven contact. 4 Enables a keyed selector switch to be set to user-selected key withdraw position. 5 Select the same color LED element as lens color; for yellow lens, choose a white LED. 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-87 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Catalog Number Selection Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. Key-Operated Selector Switches 1 M22 – WS – MS2 – A1 1 Bezel M22 = Silver M22S = Black M22M = Metal 1 1 WS = WS3 = WRS = WRS3 = Handle Type Two-position, momentary Three-position, momentary Two-position, maintained Three-position, maintained 1 1 1 1 1 Key Code Blank = MS1 MS2 = MS2 MS3 = MS3 MS4 = MS4 MS5 = MS5 MS6 = MS6 MS7 = MS7 MS8 = MS8 Key Removal Position Refer to coding adapter assembly and functional test guide on Page V7-T1-118. Product Selection Key-Operated Selector Switches 12 Components M22-WS 1 Operators Only 3 Type Switching Position Key Removal Position Key Code Silver Bezel Catalog Number Two-position Momentary 4 Return from right, key removable left MS1 M22-WS M22S-WS M22M-WS MS2 M22-WS-MS2 M22S-WS-MS2 M22M-WS-MS2 MS3 M22-WS-MS3 M22S-WS-MS3 M22M-WS-MS3 MS4 M22-WS-MS4 M22S-WS-MS4 M22M-WS-MS4 MS5 M22-WS-MS5 M22S-WS-MS5 M22M-WS-MS5 1 MS6 M22-WS-MS6 M22S-WS-MS6 M22M-WS-MS6 MS7 M22-WS-MS7 M22S-WS-MS7 M22M-WS-MS7 1 MS8 M22-WS-MS8 M22S-WS-MS8 M22M-WS-MS8 MS1 M22-WRS-A1 M22S-WRS-A1 M22M-WRS-A1 MS2 M22-WRS-MS2-A1 M22S-WRS-MS2-A1 M22M-WRS-MS2-A1 1 MS3 M22-WRS-MS3-A1 M22S-WRS-MS3-A1 M22M-WRS-MS3-A1 MS4 M22-WRS-MS4-A1 M22S-WRS-MS4-A1 M22M-WRS-MS4-A1 1 MS5 M22-WRS-MS5-A1 M22S-WRS-MS5-A1 M22M-WRS-MS5-A1 MS6 M22-WRS-MS6-A1 M22S-WRS-MS6-A1 M22M-WRS-MS6-A1 1 MS7 M22-WRS-MS7-A1 M22S-WRS-MS7-A1 M22M-WRS-MS7-A1 MS8 M22-WRS-MS8-A1 M22S-WRS-MS8-A1 M22M-WRS-MS8-A1 MS1 M22-WRS M22S-WRS M22M-WRS 1 MS2 M22-WRS-MS2 M22S-WRS-MS2 M22M-WRS-MS2 MS3 M22-WRS-MS3 M22S-WRS-MS3 M22M-WRS-MS3 1 MS4 M22-WRS-MS4 M22S-WRS-MS4 M22M-WRS-MS4 MS5 M22-WRS-MS5 M22S-WRS-MS5 M22M-WRS-MS5 1 MS6 M22-WRS-MS6 M22S-WRS-MS6 M22M-WRS-MS6 MS7 M22-WRS-MS7 M22S-WRS-MS7 M22M-WRS-MS7 MS8 M22-WRS-MS8 M22S-WRS-MS8 M22M-WRS-MS8 1 40° 1 1 M22S-WRS Two-position 1 Maintained Key removable left 40° 1 Key removable left/right 1 1 Black Bezel Catalog Number Metal Bezel Catalog Number Notes 1 Includes one key. 2 Key removal positions can be modified in the field using coding adapters; see chart on Page V7-T1-118. 3 Includes contact block mounting adapter. 4 Momentary selector switches can be converted in the field to maintained operation with the removal of a color coded adapter. See Page V7-T1-118. 1 1 1 V7-T1-88 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Key-Operated Selector Switches 12 Components M22-WS3-X93 1 Operators Only, continued 3 Type Switching Position Key Removal Position Key Code Silver Bezel Catalog Number Three-position Momentary 4 Return from left/right, key removable center MS1 M22-WS3 M22S-WS3 M22M-WS3 MS2 M22-WS3-MS2 M22S-WS3-MS2 M22M-WS3-MS2 MS3 M22-WS3-MS3 M22S-WS3-MS3 M22M-WS3-MS3 MS4 M22-WS3-MS4 M22S-WS3-MS4 M22M-WS3-MS4 MS5 M22-WS3-MS5 M22S-WS3-MS5 M22M-WS3-MS5 MS6 M22-WS3-MS6 M22S-WS3-MS6 M22M-WS3-MS6 MS7 M22-WS3-MS7 M22S-WS3-MS7 M22M-WS3-MS7 MS8 M22-WS3-MS8 M22S-WS3-MS8 M22M-WS3-MS8 MS1 M22-WRS3-A1 M22S-WRS3-A1 M22M-WRS3-A1 MS2 M22-WRS3-MS2-A1 M22S-WRS3-MS2-A1 M22M-WRS3-MS2-A1 MS3 M22-WRS3-MS3-A1 M22S-WRS3-MS3-A1 M22M-WRS3-MS3-A1 MS4 M22-WRS3-MS4-A1 M22S-WRS3-MS4-A1 M22M-WRS3-MS4-A1 MS5 M22-WRS3-MS5-A1 M22S-WRS3-MS5-A1 M22M-WRS3-MS5-A1 MS6 M22-WRS3-MS6-A1 M22S-WRS3-MS6-A1 M22M-WRS3-MS6-A1 MS7 M22-WRS3-MS7-A1 M22S-WRS3-MS7-A1 M22M-WRS3-MS7-A1 MS8 M22-WRS3-MS8-A1 M22S-WRS3-MS8-A1 M22M-WRS3-MS8-A1 MS1 M22-WRS3-A2 M22S-WRS3-A2 MS2 M22-WRS3-MS2-A2 M22S-WRS3-MS2-A2 M22M-WRS3-MS2-A2 MS3 M22-WRS3-MS3-A2 M22S-WRS3-MS3-A2 M22M-WRS3-MS3-A2 MS4 M22-WRS3-MS4-A2 M22S-WRS3-MS4-A2 M22M-WRS3-MS4-A2 MS5 M22-WRS3-MS5-A2 M22S-WRS3-MS5-A2 M22M-WRS3-MS5-A2 MS6 M22-WRS3-MS6-A2 M22S-WRS3-MS6-A2 M22M-WRS3-MS6-A2 MS7 M22-WRS3-MS7-A2 M22S-WRS3-MS7-A2 M22M-WRS3-MS7-A2 MS8 M22-WRS3-MS8-A2 M22S-WRS3-MS8-A2 M22M-WRS3-MS8-A2 MS1 M22-WRS3-A3 M22S-WRS3-A3 MS2 M22-WRS3-MS2-A3 M22S-WRS3-MS2-A3 M22M-WRS3-MS2-A3 MS3 M22-WRS3-MS3-A3 M22S-WRS3-MS3-A3 M22M-WRS3-MS3-A3 MS4 M22-WRS3-MS4-A3 M22S-WRS3-MS4-A3 M22M-WRS3-MS4-A3 MS5 M22-WRS3-MS5-A3 M22S-WRS3-MS5-A3 M22M-WRS3-MS5-A3 MS6 M22-WRS3-MS6-A3 M22S-WRS3-MS6-A3 M22M-WRS3-MS6-A3 MS7 M22-WRS3-MS7-A3 M22S-WRS3-MS7-A3 M22M-WRS3-MS7-A3 MS8 M22-WRS3-MS8-A3 M22S-WRS3-MS8-A3 M22M-WRS3-MS8-A3 MS1 M22-WRS3 M22S-WRS3 M22M-WRS3 MS2 M22-WRS3-MS2 M22S-WRS3-MS2 M22M-WRS3-MS2 MS3 M22-WRS3-MS3 M22S-WRS3-MS3 M22M-WRS3-MS3 MS4 M22-WRS3-MS4 M22S-WRS3-MS4 M22M-WRS3-MS4 MS5 M22-WRS3-MS5 M22S-WRS3-MS5 M22M-WRS3-MS5 MS6 M22-WRS3-MS6 M22S-WRS3-MS6 M22M-WRS3-MS6 MS7 M22-WRS3-MS7 M22S-WRS3-MS7 M22M-WRS3-MS7 MS8 M22-WRS3-MS8 M22S-WRS3-MS8 M22M-WRS3-MS8 40° 40° M22M-WS3-X93 Three-position Maintained 60° Key removable left/center/right 60° Key removable center/left Key removable center/right Key removable left/right Black Bezel Catalog Number Metal Bezel Catalog Number M22M-WRS3-A2 M22M-WRS3-A3 Notes 1 Includes one key. 2 Key removal positions can be modified in the field using coding adapters; see chart on Page V7-T1-118. 3 Includes contact block mounting adapter. 4 Momentary selector switches can be converted in the field to maintained operation with the removal of a color coded adapter. See Page V7-T1-118. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-89 1.5 1 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Key-Operated Selector Switches 12 Components M22-WS3-X93 1 Operators Only, continued 3 Type Switching Position Three-position Maintained Key Removal Position Key Code Black Bezel Catalog Number Metal Bezel Catalog Number M22-WRS3-A7 M22S-WRS3-A7 M22M-WRS3-A7 M22-WRS3-MS2-A7 M22S-WRS3-MS2-A7 M22M-WRS3-MS2-A7 MS3 M22-WRS3-MS3-A7 M22S-WRS3-MS3-A7 M22M-WRS3-MS3-A7 MS4 M22-WRS3-MS4-A7 M22S-WRS3-MS4-A7 M22M-WRS3-MS4-A7 MS5 M22-WRS3-MS5-A7 M22S-WRS3-MS5-A7 M22M-WRS3-MS5-A7 MS6 M22-WRS3-MS6-A7 M22S-WRS3-MS6-A7 M22M-WRS3-MS6-A7 MS7 M22-WRS3-MS7-A7 M22S-WRS3-MS7-A7 M22M-WRS3-MS7-A7 MS8 M22-WRS3-MS8-A7 M22S-WRS3-MS8-A7 M22M-WRS3-MS8-A7 MS1 M22-WRS3-A6 M22S-WRS3-A6 M22M-WRS3-A6 MS2 M22-WRS3-MS2-A6 M22S-WRS3-MS2-A6 M22M-WRS3-MS2-A6 MS3 M22-WRS3-MS3-A6 M22S-WRS3-MS3-A6 M22M-WRS3-MS3-A6 MS4 M22-WRS3-MS4-A6 M22S-WRS3-MS4-A6 M22M-WRS3-MS4-A6 MS5 M22-WRS3-MS5-A6 M22S-WRS3-MS5-A6 M22M-WRS3-MS5-A6 MS6 M22-WRS3-MS6-A6 M22S-WRS3-MS6-A6 M22M-WRS3-MS6-A6 MS7 M22-WRS3-MS7-A6 M22S-WRS3-MS7-A6 M22M-WRS3-MS7-A6 MS8 M22-WRS3-MS8-A6 M22S-WRS3-MS8-A6 M22M-WRS3-MS8-A6 MS1 M22-WRS3-A4 M22S-WRS3-A4 M22M-WRS3-A4 MS2 M22-WRS3-MS2-A4 M22S-WRS3-MS2-A4 M22M-WRS3-MS2-A4 MS3 M22-WRS3-MS3-A4 M22S-WRS3-MS3-A4 M22M-WRS3-MS3-A4 MS4 M22-WRS3-MS4-A4 M22S-WRS3-MS4-A4 M22M-WRS3-MS4-A4 MS5 M22-WRS3-MS5-A4 M22S-WRS3-MS5-A4 M22M-WRS3-MS5-A4 MS6 M22-WRS3-MS6-A4 M22S-WRS3-MS6-A4 M22M-WRS3-MS6-A4 1 MS7 M22-WRS3-MS7-A4 M22S-WRS3-MS7-A4 M22M-WRS3-MS7-A4 MS8 M22-WRS3-MS8-A4 M22S-WRS3-MS8-A4 M22M-WRS3-MS8-A4 1 Return from right, MS1 key removable center MS2 M22-WRS3-A5 M22S-WRS3-A5 M22M-WRS3-A5 M22-WRS3-MS2-A5 M22S-WRS3-MS2-A5 M22M-WRS3-MS2-A5 MS3 M22-WRS3-MS3-A5 M22S-WRS3-MS3-A5 M22M-WRS3-MS3-A5 1 MS4 M22-WRS3-MS4-A5 M22S-WRS3-MS4-A5 M22M-WRS3-MS4-A5 MS5 M22-WRS3-MS5-A5 M22S-WRS3-MS5-A5 M22M-WRS3-MS5-A5 1 MS6 M22-WRS3-MS6-A5 M22S-WRS3-MS6-A5 M22M-WRS3-MS6-A5 MS7 M22-WRS3-MS7-A5 M22S-WRS3-MS7-A5 M22M-WRS3-MS7-A5 MS8 M22-WRS3-MS8-A5 M22S-WRS3-MS8-A5 M22M-WRS3-MS8-A5 1 1 60° Return from left, MS1 key removable center MS2 Silver Bezel Catalog Number 60° M22M-WS3-X93 1 1 Return from left, key removable center/right 1 1 1 1 1 Three-position 1 Maintained 60° 1 1 1 1 60° Return from right, key removable left/ center Notes 1 Includes one key. 2 Key removal positions can be modified in the field using coding adapters; see chart on Page V7-T1-118. 3 Includes contact block mounting adapter. 1 1 1 1 1 1 1 1 V7-T1-90 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Key-Operated Selector Switches 1 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 Components M22-K10 1 Contact Blocks 1 Accessories Terminal Type Contact Configuration 2 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage Description M22-XW Plunger bridge Catalog Number 3 M22-XW 1 1 1 M22-XWS Key cover M22-XWS 1 1 M22-XC-R Key withdraw adapter 4 M22-XC-R 1 1 M22-ES-MS1 Extra Keys Key Code Catalog Number MS1 MS2 MS3 MS4 MS5 MS6 MS7 MS8 M22-ES-MS1 M22-ES-MS2 M22-ES-MS3 M22-ES-MS4 M22-ES-MS5 M22-ES-MS6 M22-ES-MS7 M22-ES-MS8 M22-XC-Y Coding adapter M22-XC-Y 1 1 1 M22-XGWK Guard ring M22-XGWK 1 1 Notes 1 For complete listing of available contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 All NC contact blocks are positively driven contact. 3 Plunger needed to actuate center-mounted contact blocks. Used for non-illuminated three-position selector switches only. 4 Enables a keyed selector switch to be set to user-selected key withdraw position. 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-91 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1 Mushroom Head Pushbuttons Product Description Features 1 Eaton’s M22 mushroom head operators are a durable and unique way to include standard pushbutton functionality. Like the standard pushbutton line, the maintained pushbuttons are field convertible to momentary. They also offer laser engraving and a robust five million mechanical operations on the standard momentary operator. As with all operators, they can be ordered as a ready to install complete device or as modular components. ● 1 1 1 1 1 1 1 ● ● Field convertible from maintained to momentary (available on maintained pushbuttons only) Customizable laser engraving on all buttons More than five million mechanical operations on momentary and one million on maintained pushbuttons ● ● Modular construction makes assembly fast and simplifies stocking of components and complete devices Capable of communicating via ASi protocol with ASi adapter modules Protection Type ● IP67, IP69K ● NEMA 4X, 13 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-92 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Catalog Number Selection Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. 1 Mushroom Head Pushbuttons 1 1 M22 – DP – R – GB4 – K01 1 Bezel M22 = Silver M22S = Black M22M = Metal Operator Type DP = Non-illuminated momentary mushroom head pushbutton DRP = Non-illuminated maintained mushroom head pushbutton Plate Inscription Operator Color R = Red S = Black G = Green Y = Yellow ETCH = GB0 = GB1 = GB3 = GB4 = GB5 = GB6 = GB15 = GB16 = 1 Custom 1 STOP START UP DOWN OFF ON FORWARD REVERSE X0 = X1 = X4 = X5 = X6 = X7 = K01 = K10 = K11 = K12 = 1 Contact Blocks NC NO NO-NC 1NO-2NC 1 1 1 1 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-DP-R-ETCH; Order Notes: Mark with symbol X91, Line item #_. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-93 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Product Selection Mushroom Head Pushbuttons, Momentary 1 M22-DP-R-K01 Complete Devices 1 Button Color Contact Block Configuration 2 Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number 1 Red NC M22-DP-R-K01 M22S-DP-R-K01 M22M-DP-R-K01 2NC M22-DP-R-K02 M22S-DP-R-K02 M22M-DP-R-K02 1NO-2NC M22-DP-R-K12 M22S-DP-R-K12 M22M-DP-R-K12 1NO-1NC M22-DP-R-K11 M22S-DP-R-K11 M22M-DP-R-K11 1 M22S-DP-R-K01 1 1 1 M22M-DP-R-K01 1 1 1 1 M22-DP-G 1 1 1 1 M22S-DP-G Operators Only 2 Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Black M22-DP-S M22S-DP-S M22M-DP-S Red M22-DP-R M22S-DP-R M22M-DP-R Green M22-DP-G M22S-DP-G M22M-DP-G Yellow M22-DP-Y M22S-DP-Y M22M-DP-Y 1 1 1 M22M-DP-G 1 1 1 Notes 1 35 mm diameter mushroom head button. 2 Includes contact block mounting adapter. 1 1 1 1 1 1 1 1 V7-T1-94 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Non-Illuminated Mushroom Head Pushbuttons, Momentary 1 1 1 1 1 1 1 1 Note: Included with operator. 1 Components M22-XDP-G Mushroom Head Plates Color Black Red Inscription 2 -— M22-XDP-S Custom STOP START FORWARD REVERSE UP DOWN OFF ON M22-XDP-S-ETCH 3 M22-XDP-S-GB0 M22-XDP-S-GB1 M22-XDP-S-GB15 M22-XDP-S-GB16 M22-XDP-S-GB3 M22-XDP-S-GB4 M22-XDP-S-GB5 M22-XDP-S-GB6 M22-XDP-S-X0 M22-XDP-S-X1 M22-XDP-S-X4 — Custom STOP OFF Green M22-DP-G-X Catalog Number — M22-XDP-S-X5 M22-XDP-S-X7 M22-XDP-R 2 M22-XDP-R-ETCH 3 M22-XDP-R-GB0 M22-XDP-R-GB5 M22-XDP-R-X0 M22-XDP-G 2 White — M22-XDP-G-ETCH 3 M22-XDP-G-GB1 M22-XDP-G-GB6 M22-XDP-G-X0 M22-XDP-G-X1 M22-XDP-W 2 Yellow Custom — Custom M22-XDP-W-ETCH 3 M22-XDP-Y 2 M22-XDP-Y-ETCH 3 Custom START ON Insertless Mushroom Head Operators Bezel Color Catalog Number Silver Black Red Green Yellow Black Red Green Yellow Black Red Green Yellow M22-DP-S-X M22-DP-R-X M22-DP-G-X M22-DP-Y-X M22S-DP-S-X M22S-DP-R-X M22S-DP-G-X M22S-DP-Y-X M22M-DP-S-X M22M-DP-R-X M22M-DP-G-X M22M-DP-Y-X Black Metal M22-K10 1 1 1 1 1 1 1 Contact Blocks 4 Terminal Type Contact Configuration 5 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage 1 Notes 1 35 mm diameter mushroom head button. 2 Minimum order quantity of (10). 3 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XDP-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 4 For complete listing of available contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 5 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-95 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Product Selection Non-Illuminated Mushroom Head Pushbuttons, Maintained 1 2 M22-DRP-R-K01 Complete Devices 1 Button Color Contact Block Configuration 2 Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number 1 Red NC M22-DRP-R-K01 M22S-DRP-R-K01 M22M-DRP-R-K01 2NC M22-DRP-R-K02 M22S-DRP-R-K02 M22M-DRP-R-K02 1NO-2NC M22-DRP-R-K12 M22S-DRP-R-K12 M22M-DRP-R-K12 1NO-1NC M22-DRP-R-K11 M22S-DRP-R-K11 M22M-DRP-R-K11 1 M22S-DRP-R-K01 1 1 1 1 M22M-DRP-R-K01 1 1 1 1 M22-DRP-G 1 1 1 M22S-DRP-G Operators Only Button Color Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number Black M22-DRP-S M22S-DRP-S M22M-DRP-S Red M22-DRP-R M22S-DRP-R M22M-DRP-R Green M22-DRP-G M22S-DRP-G M22M-DRP-G Yellow M22-DRP-Y M22S-DRP-Y M22M-DRP-Y 1 1 1 M22M-DRP-G 1 1 1 Notes 1 35 mm diameter mushroom head button. 2 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 3 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 Note: This pilot device features a selectable function switch that enables the device to be set to either maintained or momentary operation. 1 V7-T1-96 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Non-Illuminated Mushroom Head Pushbuttons, Maintained 12 1 1 1 1 1 1 1 Note: Included with operator. 1 Components M22-XDP-G Mushroom Head Plates 5 Color Black Red Green White Yellow Inscription — Custom STOP START FORWARD REVERSE UP DOWN OFF ON — Custom STOP OFF — Custom START ON — Custom — Custom M22-DRP-G-X Catalog Number 3 M22-XDP-S M22-XDP-S-ETCH 4 M22-XDP-S-GB0 M22-XDP-S-GB1 M22-XDP-S-GB15 M22-XDP-S-GB16 M22-XDP-S-GB3 M22-XDP-S-GB4 M22-XDP-S-GB5 M22-XDP-S-GB6 M22-XDP-S-X0 M22-XDP-S-X1 M22-XDP-S-X4 M22-XDP-S-X5 M22-XDP-S-X7 M22-XDP-R 3 M22-XDP-R-ETCH 4 M22-XDP-R-GB0 M22-XDP-R-GB5 M22-XDP-R-X0 M22-XDP-G 3 M22-XDP-G-ETCH 4 M22-XDP-G-GB1 M22-XDP-G-GB6 M22-XDP-G-X0 M22-XDP-G-X1 M22-XDP-W 3 M22-XDP-W-ETCH 4 M22-XDP-Y 3 M22-XDP-Y-ETCH 4 Insertless Mushroom Head Operators Bezel Color Catalog Number Silver Black Red Green Yellow Black Red Green Yellow Black Red Green M22-DRP-S-X M22-DRP-R-X M22-DRP-G-X M22-DRP-Y-X M22S-DRP-S-X M22S-DRP-R-X M22S-DRP-G-X M22S-DRP-Y-X M22M-DRP-S-X M22M-DRP-R-X M22M-DRP-G-X Yellow M22M-DRP-Y-X Black Metal M22-K10 1 1 1 1 1 1 1 Contact Blocks 5 Terminal Type Contact Configuration 6 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Spring-cage 1 1 1 1 1 1 1 Notes 1 35 mm diameter mushroom head button. 2 Maintained pushbuttons can be converted in the field to momentary operation by switching the locking ring, which is accessible through the side of the operator body. 3 Minimum order quantity of (10). 4 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XDP-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 5 For complete listing of available button plates and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 6 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-97 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1 Double Pushbuttons Product Description Features 1 ● 1 Eaton’s M22 double pushbutton line is perfect for applications such as motor and pump starting, as well as anytime space is limited. In addition to the two buttons that fit in one 22 mm hole is the integrated white indicating light between them. These three operators allow for multiple functions to occur in a single space. Green/red, black/white and black/black color options along with laser engraving allow for further custom applications. 1 Catalog Number Selection 1 1 1 1 1 1 ● ● ● Flush and extended, as well as color options allow for the perfect combination button Integrated indicating light adds even more functionality in one standard 22 mm hole Customizable laser engraving on all buttons LED offering only for improved brightness quality and up to 100,000 hours of operation ● ● More than 200,000 mechanical operations Capable of communicating via ASi protocol with ASi adapter modules Protection Type ● IP66 ● NEMA 4X, 13 1 Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. 1 Double Pushbuttons M22 – DDL – GR – GB5 – K10 – G 1 1 Bezel M22 = Silver M22S = Black 1 1 1 1 Operator Type DDL = Extended buttons and light DDLF = Flush buttons and light DDLM = Extended bottom button 1 1 Button Plate Color Top Bottom GR = Green Red WS = White Black S = Black Black Inscription GB0 = STOP GB1 = START GB3 = UP GB4 = DOWN GB5 = OFF GB6 = ON GB14 = RESET GB15 = FORWARD GB16 = REVERSE X0 = X1 = X5 = X5 = X6 = X7 = X5 = K10 = K01 = K20 = K02 = K11 = Contact Blocks 1NO K30 = 3NO 1NC K03 = 3NC 2NO K21 = 2NO-1NC 2NC K12 = 1NO-2NC 1NO-1NC Light Units 12–30 Vac/Vdc W = White R = Red G = Green B = Blue 85–264 Vac 230W = White 230R = Red 230G = Green 230B = Blue 1 1 1 1 1 1 1 1 1 1 V7-T1-98 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Product Selection 1 Components 1 Double Pushbuttons, Extended Pushbuttons and Center Light, Momentary 1 Operators Only 1 M22-DDL-GR-GB1-GB0 Bezel Color Top Bottom Silver Green Red White Black M22S-DDL-GR-X1-X0 Black Green White Black Black Black Red Inscription Top Bottom Catalog Number — Custom — Custom M22-DDL-GR M22-DDL-GR-ETCH 2 START — Custom STOP — Custom START STOP — Custom — — Custom — — Custom — Custom Black START — Custom STOP — Custom Black START — Custom STOP — Custom — 1 1 M22-DDL-GR-X1-X0 M22-DDL-GR-GB1-GB0 M22-DDL-WS M22-DDL-WS-ETCH 2 M22-DDL-WS-X1-X0 M22-DDL-WS-GB1-GB0 1 1 1 M22-DDL-S M22-DDL-S-ETCH 2 M22-DDL-S-X4-X5 M22-DDL-S-X7-X7 M22S-DDL-GR M22S-DDL-GR-ETCH 2 1 1 M22S-DDL-GR-X1-X0 M22S-DDL-GR-GB1-GB0 M22S-DDL-WS M22S-DDL-WS-ETCH 2 M22S-DDL-WS-X1-X0 M22S-DDL-WS-GB1-GB0 M22S-DDL-S M22S-DDL-S-ETCH 2 M22S-DDL-S-X4-X5 M22S-DDL-S-X7-X7 Notes 1 Includes contact block mounting adapter. 2 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-DDL-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-99 1.5 1 22.5 mm Modular Pushbuttons—M22 Double Pushbuttons, Flush Top Pushbuttons and Center Light, Momentary Operators Only 1 1 1 Pushbuttons and Indicating Lights M22-DDLF-GR Bezel Color Top Bottom Inscription Top Bottom Catalog Number Silver Green Red — — M22-DDLF-GR Custom Custom M22-DDLF-GR-ETCH 2 — — M22-DDLF-WS Custom Custom 1 White Black 1 Green Red M22-DDLF-GR-X1-X0 White Black M22-DDLF-WS-X1-X0 Green Red 1 1 M22S-DDLF-GR-X1-X0 Black M22-DDLF-WS-ETCH 2 — — Custom Custom M22S-DDLF-GR M22S-DDLF-GR-ETCH 2 — — M22S-DDLF-WS Custom Custom 1 White Black 1 Green Red M22S-DDLF-GR-X1-X0 White Black M22S-DDLF-WS-X1-X0 1 1 M22S-DDLF-WS-ETCH 2 Double Pushbuttons, Flush Top Pushbutton and Center Light, Extended Bottom Pushbutton, Momentary 1 Operators Only 1 1 Bezel Color Top Bottom Silver Green Red M22-DDLM-GR 1 Bottom Catalog Number — — M22-DDLM-GR Custom Custom M22-DDLM-GR-ETCH 2 — — M22-DDLM-WS Custom Custom M22-DDLM-WS-ETCH 2 1 White 1 Green Red M22-DDLM-GR-X1-X0 White Black M22-DDLM-WS-X1-X0 Green Red 1 M22-DDLM-GR-X1-X0 Black Black Inscription Top 1 White 1 1 1 Black — — M22S-DDLM-GR Custom Custom M22S-DDLM-GR-ETCH 2 — — M22S-DDLM-WS Custom Custom M22S-DDLM-WS-ETCH 2 Green Red M22S-DDLM-GR-X1-X0 White Black M22S-DDLM-WS-X1-X0 Notes 1 Includes contact block mounting adapter. 2 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-DDLM-GR-ETCH; Order Notes: Mark with symbol X91, Line item #_. 1 1 1 1 1 1 1 1 1 V7-T1-100 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Double Pushbuttons 1 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 M22-LED-W Light Units 1 M22-K10 Terminal Type LED Color Light Unit Voltage Screw White Contact Blocks 1 1 Catalog Number Terminal Type Contact Configuration 2 Catalog Number 12–30 Vac/Vdc M22-LED-W Screw NO NO, early-make M22-K10 M22-K10P NC M22-K01 85–264 Vac M22-LED230-W Spring-cage NC, late-break M22-K01D NO M22-CK10 NC M22-CK01 NC, late-break M22-CK01D 2NO M22-CK20 2NC M22-CK02 NO-NC M22-CK11 Notes 1 For complete listing of available light units and contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-101 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1 Four-Way Pushbuttons Product Description Features 1 Eaton’s M22 four-way pushbutton is a truly unique offering. A four-way pushbutton offers four different buttons mounted in a single 22 mm hole. This is ideal not only for an application with limited space, but also directional applications (when ordered with the four arrow engraving option). Another unique option is the interlocked version, which prevents two opposite buttons from being actuated at the same time. ● 1 1 1 1 1 1 1 1 1 ● Four buttons in one operator allows for increased functionality in limited space Optional interlocking option, which prevents two buttons from being actuated at the same time ● ● Customizable laser engraving on all buttons for directional or other applications Capable of communicating via ASi protocol with ASi adapter modules Protection Type ● IP66 Catalog Number Selection Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. Four-Way Pushbuttons 1 M22 – D4 – S – X7 – K01 1 1 Bezel M22 = Silver M22S = Black 1 1 1 1 Button Color S = Black Inscription ETCH = Custom 1 X7 = 1 Operator Type D4 = Four-way pushbutton, momentary, non-interlocked DI4 = Four-way pushbutton, momentary, interlocked When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-D4-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. K10 = K01 = K20 = K02 = K11 = Contact Blocks 1NO K30 =3NO 1NC K03 =3NC 2NO K21 =2NO-1NC 2NC K12 =1NO-2NC 1NO-1NC 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-102 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Product Selection 1 Four-Way Pushbuttons, Momentary 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. 1 1 Components M22-D4-S-X7 Operators Only 1 Type Bezel Color Inscription Catalog Number Non-interlocked Silver Black — M22-D4-S Custom M22-D4-S-ETCH 3 Directional arrows — M22-D4-S-X7 M22S-D4-S Custom M22S-D4-S-ETCH 3 Directional arrows — M22S-D4-S-X7 M22-DI4-S Custom M22-DI4-S-ETCH 3 Directional arrows — M22-DI4-S-X7 M22S-DI4-S Custom M22S-DI4-S-ETCH 3 Directional arrows M22S-DI4-S-X7 Black Interlocked Silver Black M22-K10 Black Black Black 1 1 1 1 1 1 1 1 1 Contact Blocks 2 Terminal Type Contact Configuration 4 Catalog Number 1 Screw NO NO, early-make M22-K10 M22-K10P 1 NC M22-K01 NC, late-break M22-K01D 1 Spring-cage NO M22-CK10 NC M22-CK01 NC, late-break M22-CK01D 2NO M22-CK20 2NC M22-CK02 NO-NC M22-CK11 1 1 1 1 Notes 1 Includes contact block mounting adapter. 2 For complete listing of available contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 3 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-D4-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 4 All NC contact blocks are positively driven contact. 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-103 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1 Joysticks Product Description Features 1 Eaton’s M22 joystick line comes in a wide variety of options. From vertical and horizontal two-position switches to the maintained four-position, these operators fit a variety of applications. An additional option, two switch points, allows for eight isolated circuits to be actuated individually on a single operator. ● 1 1 1 1 1 1 Product Selection 1 Joysticks 1 ● Available in four-position and two-position Two switch point option allows for two contacts in each direction (up to eight total contacts in one operator) ● Capable of communicating via ASi protocol with ASi adapter modules Protection Type ● IP66 Components M22-WJ2H Operators 1 Number of Directions Switching Position Silver Bezel Catalog Number Black Bezel Catalog Number Metal Bezel Catalog Number 1 Two-position horizontal Momentary M22-WJ2H M22S-WJ2H M22M-WJ2H M22-WJ2H-2P M22S-WJ2H-2P M22M-WJ2H-2P 1 Two-position horizontal Maintained M22-WRJ2H M22S-WRJ2H M22M-WRJ2H Two-position vertical Momentary M22-WJ2V M22S-WJ2V M22M-WJ2V M22-WJ2V-2P M22S-WJ2V-2P M22M-WJ2V-2P 1 Two switch points M22M-WJ2H 1 Two switch points 1 Two-position vertical Maintained M22-WRJ2V M22S-WRJ2V M22M-WRJ2V Four-position Momentary M22-WJ4 M22S-WJ4 M22M-WJ4 1 Two switch points M22-WJ4-2P M22S-WJ4-2P M22M-WJ4-2P M22-WRJ4 M22S-WRJ4 M22M-WRJ4 Four-position 1 Maintained Note Includes contact block mounting adapter. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-104 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Joysticks 1 1 1 ma x thic . 5mm kne ss 1 1 1 Note: Included with operator. M22-K10 Terminal Type Contact Configuration 3 Catalog Number Screw NO NO, early-make NC NC, late-break NO NC NC, late-break 2NO 2NC NO-NC M22-K10 M22-K10P M22-K01 M22-K01D M22-CK10 M22-CK01 M22-CK01D M22-CK20 M22-CK02 M22-CK11 Notes 1 Includes contact block mounting adapter. 2 For complete listing of available contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 3 All NC contact blocks are positively driven contact. 1 Joystick with Double Contact Contact Blocks 12 Spring-cage 1 The joystick allows the control of up to four directions of movement on machines. Different variants of the joystick have two/fourpositions and other variants have two settings for each position. This allows, for example, two-speed settings for each direction. For this application, a standard normally open contact and an early-make contact are fitted in series. Momentary contact and latching contact versions are available. 1 0 1 1 1 1 0 1 1 2 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-105 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1 Potentiometers Acoustic Devices Product Description Product Description 1 Eaton’s M22 potentiometers allow for a ready to use operator in a conveniently sized package. M22 potentiometers include the resistive element, instead of just a knob, and a built in legend surrounding the knob. The slim design, with integrated contacts and the range of resistances available, allows for a quick install. Eaton’s M22 acoustic devices are a simple and aesthetic way to add a buzzer or indicator to any application. Fitting in the same 22 mm hole, these devices can be ordered in continuous or pulsed tone and with or without the IP40 enclosure. Features Features 1 1 1 1 ● ● ● 1 1 1 1 1 Scale markings on the knob allows the operator to be used without an additional legend plate Oversized knob option available Slim design allows for space saving and simple wiring and installation ● ● Continuous or pulsed tone available 83 dB / 10 cm decibel rating Slim design allows for space saving and simple wiring and installation Protection Type ● IP66 ● NEMA 4X, 13 Protection Type ● IP40 ● NEMA 12 Product Selection Product Selection Potentiometers Acoustic Devices M22-R10K 1 Complete Devices Description 1 4.7 10 47 100 470 1 4.7 10 47 100 M22-R1K M22-R4K7 M22-R10K M22-R47K M22-R100K M22-R470K M22S-R1K M22S-R4K7 M22S-R10K M22S-R47K M22S-R100K Indicator with buzzer, black continuous tone, 18–30 Vac/Vdc Indicator with buzzer, black pulsed tone, 18–30 Vac/Vdc 470 Metal 1 4.7 10 47 100 470 Oversized Knob Silver 1 4.7 10 47 100 470 Black 1 4.7 10 47 100 470 Metal 1 4.7 10 47 100 470 M22S-R470K M22M-R1K M22M-R4K7 M22M-R10K M22M-R47K M22M-R100K M22M-R470K M22M-R10K 1 Black 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-106 Complete Devices Catalog Number Silver 1 M22-AMC-XAM Resistance Rk Bezel 1 1 ● M22-XAM Decibel Rating Catalog Number 83 dB/ 10 cm M22-AMC-XAM 83 dB/ 10 cm M22-AMC-XAMP Buzzers Description Indicator without buzzer, black Buzzer only, continuous tone, 18–30 Vac/Vdc Buzzer only, pulsed tone, 18–30 Vac/Vdc Decibel Rating Catalog Number 83 dB/ 10 cm 83 dB/ 10 cm M22-AMC 83 dB/ 10 cm M22-XAMP M22-R1K-RH M22-R4K7-RH M22-R10K-RH M22-R47K-RH M22-R100K-RH M22-R470K-RH M22S-R1K-RH M22S-R4K7-RH M22S-R10K-RH M22S-R47K-RH M22S-R100K-RH M22S-R470K-RH M22M-R1K-RH M22M-R4K7-RH M22M-R10K-RH M22M-R47K-RH M22M-R100K-RH M22M-R470K-RH Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com M22-XAM Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Through-the-Door Operators Bulkhead Interfaces Product Description Product Description Eaton’s M22 through-the-door operators use the same familiar flush pushbutton look with the addition of a cut-to-length rod that allows for a simple reset operator. Eaton’s M22 bulkhead interfaces are another unique offering in the M22 line. This device allows for a secure connection to any USB or RJ45 connected device within an enclosure or panel. With an IP65 rating when closed, these devices are not only convenient, but robust and reliable. Features Features ● ● ● Customizable laser engraving on all buttons More than five million mechanical operations Pushrod can be cut to length ● 1 Convenient and safe way to make a data connection to inside of the panel without opening the panel door 1 1 1 1 1 1 Protection Type ● IP67, IP69K ● NEMA 4X, 13 Protection Type ● IP65 when closed, IP20 when connected Product Selection Product Selection 1 Through-the-Door Operators 1 Bulkhead Interfaces 1 M22-DZ-B-X6 Complete Devices M22-USB-SA Color Inscription Catalog Number Blue — RESET M22-DZ-B M22-DZ-B-GB14 M22-DZ-B-X6 M22-DZ-R M22-DZ-R-X0 M22-DZ-R-GB0 Red — STOP 1 USB Socket 45 Used for USB connection plug IP65 when closed, IP20 when connected. Bezel Catalog Number Silver M22-USB-SA 1 1 1 1 1 M22-DZ-X M22-XD-B Buttonless Operator Bezel Catalog Number Silver Metal M22-DZ-X M22M-DZ-X M22-RJ45-SA RJ45 Socket 6 Used for RJ45 Ethernet connection IP65 when closed, IP20 when connected. Bezel Catalog Number Silver M22-RJ45-SA 1 1 1 Button Plates 2 Color Inscription Catalog Number Blue — RESET Red — M22-XD-B 3 M22-XD-B-GB14 M22-XD-B-X6 M22-XD-R 3 M22-XD-R-X0 M22-XD-R-GB0 STOP 1 1 Notes 1 The pushrod is 3.24 in long and can be cut to length. 2 Any combination of plate color and inscription is available. 3 Minimum order quantity of (10). 4 USB interface is complete with 2-ft-long USB cable. 5 USB interface is UL Listed, CSA approved and USB 3.0. 6 RJ45 interface is an eight-wire connector. 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-107 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1 ASi Adapter Modules 1 Eaton’s M22 ASi adapter modules add functionality to every operator in the M22 line. These devices can be connected to any operator that uses contact blocks or LED units. The simple snapon design allows for a quick integration of an entire application of operators to a communicating network. 1 1 1 Product Description Features ● Allows compatible operators to communicate on an ASi network Not only can the status of a contact block be read, but LEDs can be illuminated by an ASi adapter ASi adapters simply clip on to the back of the contact blocks and LEDs Insulation displacement connectors allow for installation of adapters without any tools Two integrated LEDs indicate status of communications 1 ● 1 ● 1 ● 1 ● 1 Protection Type ● IP20 1 1 1 Product Selection ASi Adapter Modules M22-ASI 1 1 1 1 Complete Devices Description Catalog Number ASi adapter module ASi adapter module for base mounting ASi adapter module for E-stop ASi adapter module for E-stop base mounting M22-ASI M22-ASI-C M22-ASI-S M22-ASI-CS 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-108 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Palm Switches Catalog Number Selection Catalog Number Selection is for illustrative purposes only and not to be used to create new catalog numbers. Palm Switches, Type 4X/13 Enclosure Product Description Eaton’s M22 palm switches are an oversized button that mount directly to an enclosure base. This allows for a standalone button that can be mounted anywhere. The enclosure uses basemounted contact blocks, which allows for quick wiring and mounting. The palm switches come in momentary or maintained versions. As with other M22 operators, the palm switches are available as complete devices, including the enclosure and contact blocks or as modular components. Operator Color S = Black R = Red Y = Yellow ● ● ● Oversized operator in black, red and yellow color options Button integrated directly into an enclosure Base mounting contact blocks allow for simple wiring and installation More than one million mechanical operations on momentary and 100,000 on maintained operators Enclosure Top Color I = Gray IY = Yellow 1 1 1 1 Product Selection 1 Complete Devices FAK-S-KC11-I Operator, Base and Contact Blocks 1 1 Button Color 1 Contact Block Configuration 2 Momentary Black 1NO-1NC Red 1NO-1NC Yellow 1NO-1NC Catalog Number FAK-S-KC11-I FAK-R-KC11-I FAK-Y-KC11-I 1 1 1 FAK-R-V-KC01-IY Protection Type ● IP67, IP69K ● NEMA 4X, 13 1 1 Features ● Contact Blocks KC10 = NO KC01 = NC CKC10 = NO CKC01 = NC 1 1 FAK – S – KC10 – I Operator Type FAK = Palm switch 1 Maintained Red NC 2NC 1NO-2NC 1NO-1NC FAK-R-V-KC01-IY FAK-R-V-KC02-IY FAK-R-V-KC12-IY FAK-R-V-KC11-IY 1 1 1 Notes 1 For complete listing of available contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-109 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Components FAK-S 1 1 Operators Only Type Button Color Catalog Number Momentary Black Red Yellow Red FAK-S FAK-R FAK-Y FAK-R-V-Y Maintained 1 1 FAK-IU Palm Switch Enclosure Base Catalog Number 1 FAK-IU 1 1 M22-KC10 Contact Blocks 1 1 Terminal Type Contact Configuration 2 Catalog Number 1 Screw 1 Spring-cage NO NC NO NC M22-KC10 M22-KC01 M22-CKC10 M22-CKC01 1 1 Notes 1 For complete listing of available contact blocks, see Accessories, Pages V7-T1-111 to V7-T1-116. 2 All NC contact blocks are positively driven contact. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 V7-T1-110 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Accessories M22-XD-S M22-XDH-R M22-XDP-G 1 Button Plates Color Inscription Catalog Number Flush Pushbutton Catalog Number Extended Pushbutton Catalog Number Mushroom Head Button 1 Black — M22-XD-S M22-XDH-S M22-XDP-S White Red Green — — — M22-XD-W M22-XD-R M22-XD-G M22-XDH-W M22-XDH-R M22-XDH-G M22-XDP-W M22-XDP-R M22-XDP-G 1 Yellow Blue Black, white, red, green, yellow, blue Black, red, green Black White Red Green Yellow — — — — Custom Custom Custom Custom Custom M22-XD-Y M22-XD-B M22-XD-SWRGYB M22-XD-SRG M22-XD-S-ETCH M22-XD-W-ETCH M22-XD-R-ETCH M22-XD-G-ETCH M22-XD-Y-ETCH M22-XDH-Y M22-XDH-B M22-XDH-SWRGYB M22-XDH-SRG M22-XDH-S-ETCH M22-XDH-W-ETCH M22-XDH-R-ETCH M22-XDH-G-ETCH M22-XDH-Y-ETCH M22-XDP-Y — — — M22-XDP-S-ETCH M22-XDP-W-ETCH M22-XDP-R-ETCH M22-XDP-G-ETCH M22-XDP-Y-ETCH Blue Black Red Black White Green Black Black Black Black Red Black Green Black Blue Black Black Black Black Black Red Green Black White Green Black Green Black Black Blue Black Black Black Custom STOP STOP START START START CLOSE UP DOWN OFF OFF ON ON TEST RESET FORWARD REVERSE RAISE LOWER M22-XD-B-ETCH M22-XD-S-GB0 M22-XD-R-GB0 M22-XD-S-GB1 M22-XD-W-GB1 M22-XD-G-GB1 M22-XD-S-GB2 M22-XD-S-GB3 M22-XD-S-GB4 M22-XD-S-GB5 M22-XD-R-GB5 M22-XD-S-GB6 M22-XD-G-GB6 M22-XD-S-GB9 M22-XD-B-GB14 M22-XD-S-GB15 M22-XD-S-GB16 M22-XD-S-GB17 M22-XD-S-GB18 M22-XD-S-X0 M22-XD-R-X0 — M22-XD-S-X1 M22-XD-W-X1 M22-XD-G-X1 M22-XD-S-X2 M22-XD-G-X2 M22-XD-S-X4 M22-XD-S-X5 M22-XD-B-X6 M22-XD-S-X7 M22-XD-S-X8 M22-XDH-B-ETCH M22-XDH-S-GB0 M22-XDH-R-GB0 M22-XDH-S-GB1 M22-XDH-W-GB1 M22-XDH-G-GB1 M22-XDH-S-GB2 M22-XDH-S-GB3 M22-XDH-S-GB4 M22-XDH-S-GB5 M22-XDH-R-GB5 M22-XDH-S-GB6 M22-XDH-G-GB6 M22-XDH-S-GB9 M22-XDH-B-GB14 M22-XDH-S-GB15 M22-XDH-S-GB16 M22-XDH-S-GB17 M22-XDH-S-GB18 M22-XDH-S-X0 M22-XDH-R-X0 — M22-XDH-S-X1 M22-XDH-W-X1 M22-XDH-G-X1 M22-XDH-S-X2 M22-XDH-G-X2 M22-XDH-S-X4 M22-XDH-S-X5 M22-XDH-B-X6 M22-XDH-S-X7 M22-XDH-S-X8 — M22-XDP-S-GB0 M22-XDP-R-GB0 M22-XDP-S-GB1 — M22-XDP-G-GB1 — M22-XDP-S-GB3 M22-XDP-S-GB4 M22-XDP-S-GB5 M22-XDP-R-GB5 M22-XDP-S-GB6 M22-XDP-G-GB6 — — M22-XDP-S-GB15 M22-XDP-S-GB16 — — M22-XDP-S-X0 M22-XDP-R-X0 M22-XDP-G-X0 M22-XDP-S-X1 — M22-XDP-G-X1 — — M22-XDP-S-X4 M22-XDP-S-X5 — M22-XDP-S-X7 — Black Black See 1 below See 1 below Black Black Black See 1 below See 1 below See 1 below See 1 below See 1 below See 1 below M22-XD-S-X9 M22-XD-S-X10 M22-XD-S-X11 M22-XD-S-X12 M22-XD-S-X13 M22-XD-S-X14 M22-XD-S-X15 M22-XD-S-X16 M22-XD-S-X17 M22-XDH-S-X9 M22-XDH-S-X10 M22-XDH-S-X11 M22-XDH-S-X12 M22-XDH-S-X13 M22-XDH-S-X14 M22-XDH-S-X15 M22-XDH-S-X16 M22-XDH-S-X17 — — — — — — — — — Black Black Black See 1 below 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Note 1 Refer to the Symbols Library, (see Pages V7-T1-129 to V7-T1-136), for symbol image. 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-111 1.5 1 M22-XDLH-W 1 1 M22-XDL-G 1 1 1 1 Button Lenses Color Inscription Catalog Number Flush Catalog Number Extended Color Inscription Catalog Number Flush Catalog Number Extended White Red — — M22-XDL-W M22-XDL-R M22-XDLH-W M22-XDLH-R Blue Red Custom STOP M22-XDL-B-ETCH M22-XDL-R-GB0 M22-XDLH-B-ETCH M22-XDLH-R-GB0 Green Yellow Blue White Red Green Yellow — — — Custom Custom Custom Custom M22-XDL-G M22-XDL-Y M22-XDL-B M22-XDL-W-ETCH M22-XDL-R-ETCH M22-XDL-G-ETCH M22-XDL-Y-ETCH M22-XDLH-G M22-XDLH-Y M22-XDLH-B M22-XDLH-W-ETCH M22-XDLH-R-ETCH M22-XDLH-G-ETCH M22-XDLH-Y-ETCH Green Red Green Blue Red Green Blue START OFF ON RESET M22-XDL-G-GB1 M22-XDL-R-GB5 M22-XDL-G-GB6 M22-XDL-B-GB14 M22-XDL-R-X0 M22-XDL-G-X1 M22-XDL-B-X6 M22-XDLH-G-GB1 M22-XDLH-R-GB5 M22-XDLH-G-GB6 M22-XDLH-B-GB14 M22-XDLH-R-X0 M22-XDLH-G-X1 M22-XDLH-B-X6 Description Catalog Number M22-A Contact block mounting adapter M22-A M22-A4 Contact block mounting adapter, four-position (for use with four-way pushbuttons, joysticks and four-position selector switches only). M22-A4 M22-LS Allows mounting of M22 pushbuttons to LS-Titan limit switch bodies (for the full LS-Titan catalog section, see PG08301004E). M22-LS 1 1 1 22.5 mm Modular Pushbuttons—M22 Mounting Adapters 1 1 Pushbuttons and Indicating Lights 1 1 1 M22-K10 Contact Blocks 1 Mounting Location Terminal Type 1 Front Screw 1 1 1 1 Base 1 1 1 1 Front 1 1 1 Base 1 Spring-cage Contact Configuration 1 Package Qty. Catalog Number NO NO NO NO, early-make NC NC NC NC, late-break SMCB, NC SMCB, 2NC NO NO NO NC NC NC SMCB, NC SMCB, 2NC NO NC NC, late-break 2NO 2 2NC 2 NO-NC 2 1 25 100 1 1 25 100 1 1 1 1 25 100 1 25 100 1 1 1 1 1 M22-K10 M22-K10-B25 M22-K10-B100 M22-K10P M22-K01 M22-K01-B25 M22-K01-B100 M22-K01D M22-K01SMC10 M22-K02SMC10 M22-KC10 M22-KC10-B25 M22-KC10-B100 M22-KC01 M22-KC01-B25 M22-KC01-B100 M22-KC01SMC10 M22-KC02SMC10 M22-CK10 M22-CK01 M22-CK01D 1 1 1 1 1 M22-CK20 M22-CK02 M22-CK11 M22-CKC10 M22-CKC01 NO NC Notes 1 All NC contact blocks are positively driven contact. 2 Not stackable. 1 V7-T1-112 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 M22-LED-W Light Units Terminal Type Mounting Location Screw Front 1 LED Color Light Unit Voltage Catalog Number White Red 12–30 Vac/Vdc M22-LED-W M22-LED-R Green Blue White Red Green Blue White Red Green Base Blue White Red Green Blue White Red Green Blue Spring-cage Front Base M22-XLED60 1.5 White Red Green Blue White Red Green Blue White Red Green Blue White Red Green Blue White Red Green Blue 85–264 Vac 207–264 Vac 12–30 Vac/Vdc 85–264 Vac 207–264 Vac 12–30 Vac/Vdc 85–264 Vac 12–30 Vac/Vdc 85–264 Vac 1 1 M22-LED-G M22-LED-B M22-LED230-W M22-LED230-R M22-LED230-G M22-LED230-B 1 1 1 M22-LED230H-W M22-LED230H-R M22-LED230H-G 1 M22-LED230H-B M22-LEDC-W M22-LEDC-R 1 M22-LEDC-G M22-LEDC-B M22-LEDC230-W M22-LEDC230-R M22-LEDC230-G M22-LEDC230-B 1 M22-LEDC230H-W M22-LEDC230H-R M22-LEDC230H-G M22-LEDC230H-B M22-CLED-W M22-CLED-R M22-CLED-G M22-CLED-B M22-CLED230-W M22-CLED230-R M22-CLED230-G M22-CLED230-B M22-CLEDC-W M22-CLEDC-R M22-CLEDC-G M22-CLEDC-B M22-CLEDC230-W M22-CLEDC230-R M22-CLEDC230-G M22-CLEDC230-B 1 1 1 1 1 1 1 1 1 1 1 1 1 LED Resistor and Test Elements Terminal Type Mounting Location Element Type Screw Front Resistor 12 Test Voltage Catalog Number 42–60 Vac/Vdc 220 Vdc 12–240 Vac/Vdc 85–264 Vac M22-XLED60 M22-XLED220 M22-XLED-T M22-XLED230-T 1 1 1 1 Notes 1 Resistor units to be used with 12–30V light units. 2 Refer to IL04716002E for use of resistor elements in series for higher DC voltage. 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-113 1.5 22.5 mm Modular Pushbuttons—M22 Legend Plate Holders and Inserts, Pushbuttons and Double Pushbuttons 2 1 1 Pushbuttons and Indicating Lights M22S-ST-X 1 Description Inscription Catalog Number Legend plate holder, without legend plate insert, for pushbuttons Legend plate holder, without legend plate insert, for double pushbuttons — M22S-ST-X — M22S-STDD-X Legend plate insert — Custom STOP START M22-XST M22-XST-ETCH 1 M22-XST-GB0 M22-XST-GB1 OFF ON RUN FAULT OFF ON MAN. AUTO MAN. O AUTO HAND AUTO HAND O AUTO M22-XST-GB5 M22-XST-GB6 M22-XST-GB7 M22-XST-GB8 M22-XST-GB10 M22-XST-GB11 M22-XST-GB12 M22-XST-D11 M22-XST-D12 1 2 OI O-I I O II M22-XST-X52 M22-XST-X53 M22-XST-X88 M22-XST-X89 M22-XST-X93 1 1 M22-XST-GB0 1 1 1 1 1 1 1 1 Notes 1 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XD-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 2 Legend plates are IP66 and NEMA 4X/13. 1 1 1 1 Example To order a legend plate for a pushbutton with non-standard markings (FORWARD): 1. Select legend plate holder—M22S-ST-X. 1 2. Select legend plate insert—M22-XST-ETCH. 1 3. Select FORWARD from the Symbols Library, Pages V7-T1-129 to V7-T1-136, identified by GB15 suffix. 1 4. Indicate on the order form in the order notes—suffix GB15, line item # ___ . 1 1 1 1 1 1 1 1 1 1 V7-T1-114 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Legend Plates, Complete 2 M22S-ST-GB0 For use with pushbuttons and indicating lights Selector switches M22-XZK Emergency-stop operators 1 Description Inscription Catalog Number Legend plate holder with insert STOP START OFF ON RUN FAULT M22S-ST-GB0 M22S-ST-GB1 M22S-ST-GB5 M22S-ST-GB6 M22S-ST-GB7 M22S-ST-GB8 1 1 2 OFF ON M22S-ST-X52 M22S-ST-X53 M22S-ST-GB10 1 MAN. AUTO MAN. O AUTO HAND AUTO HAND O AUTO OI O-I I O II — Custom M22S-ST-GB11 M22S-ST-GB12 M22S-ST-D11 M22S-ST-D12 M22S-ST-X88 M22S-ST-X89 M22S-ST-X93 M22-XZK M22-XZK-ETCH 1 EMERGENCY-STOP M22-XZK-GB99 — Rectangular yellow legend plate 1 1 1 1 1 1 1 1 Square yellow legend plate M22-XYK Round yellow legend plate, 90 mm M22-XBK1 Round yellow legend plate, 60 mm — — EMERGENCY-STOP four-language EMERGENCY-STOP (top and bottom) — Custom M22-XYK M22-XYK-ETCH 1 M22-XYK1 M22-XYK5 M22-XAK M22-XAK-ETCH 1 EMERGENCY-STOP four-language EMERGENCY-STOP (top and bottom) M22-XAK1 M22-XAK5 — Custom M22-XBK M22-XBK-ETCH 1 EMERGENCY-STOP four-language EMERGENCY-STOP (top and bottom) M22-XBK1 M22-XBK5 1 1 1 1 1 1 1 M22-XCK1 Four-way pushbutton, joystick and four-position selector switches Silver square legend plate — Custom Four directional arrows 0-1-0-2-0-3-0-4 Two directional arrows 1 M22-XCK M22-XCK-ETCH 1 M22-XCK1 M22-XCK2 M22-XCK3 1 1 1 Notes 1 When ordering, specify inscription per catalog number suffix from the Symbols Library (see Pages V7-T1-129 to V7-T1-136) into the Order Notes. For example, M22-XD-S-ETCH; Order Notes: Mark with symbol X91, Line item #_. 2 Legend plates are IP66 and NEMA 4X/13. 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-115 1.5 22.5 mm Modular Pushbuttons—M22 Surface Mounting Enclosures 1 1 1 Pushbuttons and Indicating Lights M22-IY1-PG Description Catalog Number Yellow top, black base for emergency-stop operators M22-IY1-PG Selector Switch Accessories Description Catalog Number M22-XW Plunger bridge 2 M22-XW M22-XWS Key cover M22-XWS M22-XC-R Key withdraw adapter 3 M22-XC-R M22-XC-Y Coding adapter M22-XC-Y M22-XGWK Guard ring M22-XGWK 1 1 1 M22-IY-PG 1 1 1 1 M22-EY1 M22-I1-PG M22-I2-PG M22-I3-PG Four-element enclosure Six-element enclosure M20 connecting screw M22-I4-PG M22-I6-PG M22-XI M20 cord grip V-M20 Flush Mounting Plates, Aluminum Finish 1 Rating Catalog Number — M22-EY1 IP65 M22-E1 IP65 M22-E2 IP65 M22-E3 IP65 M22-E4 IP65 M22-E5 IP40 M22-E6 Description Rating Catalog Number One-element Two-element Three-element Four-element Five-element Six-element Mounting plate Plaster keys for flush mounting IP55 IP55 IP55 IP40 IP40 IP40 — — M22-H1 M22-H2 M22-H3 M22-H4 M22-H5 M22-H6 M22-XE5 M22-UPE One Hole Yellow paint for emergency-stop operators Gray anodized Two Holes Gray anodized Three Holes Gray anodized Four Holes Gray anodized Five Holes Gray anodized Six Holes Anodized 1 1 1 1 1 1 1 1 One-element enclosure Two-element enclosure Three-element enclosure M22-H1 1 1 1 1 1 Notes 1 Requires use of base mounted contact blocks. 2 Plunger needed to actuate center-mounted contact blocks. Used for non-illuminated three-position selector switches only. 3 Enables a keyed selector switch to be set to user-selected key withdraw position. Shrouds, Plastic 1 1 1 1 1 1 1 V7-T1-116 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 M22-XGPV M22G-XGPV 1.5 Emergency Stop Operator Accessories Mounting Accessories Description Voltage Catalog Number Description Catalog Number Yellow guard ring — M22-XGPV Telescopic clip with top-hat rail Telescopic clip Telescopic clip extension M22-TC M22-TA M22-TCV DIN rail mounting adapter M22-IVS Gray guard ring — M22G-XGPV M22-TC and M22-TA M22-IVS 1 1 1 1 1 M22-MGTA Rectangular guard — 1 M22-MGTA M22-GR Mounting ring 1 M22-GR 1 M22-PL-PV Sealing shroud — M22-PL-PV M22-MS Mounting ring tool 1 M22-MS 1 1 M22-XPV60-Y-120 1 Illuminated ring 24 Vac/Vdc 120 Vac 230 Vac M22-XPV60-Y-24 M22-XPV60-Y-120 M22-XPV60-Y-230 1 M22S-R30 Adapter ring set for 30 mm holes M22S-R30 1 1 M22-B 1 Blanking Plugs Color Catalog Number Gray Black M22-B M22S-B M22-T-D and M22-T-DD M22-ADC4 Protective Diaphragm 1 For Use with … Catalog Number Flush pushbuttons and indicating lights Double pushbuttons M22-T-D 1 M22-T-DD 1 1 Dust Covers Description Catalog Number Contact block dust cover Operator dust cover, max three contact blocks Operator dust cover, max four contact blocks M22-XKDP M22-ADC M22-ADC4 1 1 1 1 Kits Description Catalog Number Includes one each: M22-XW, M22-XC-R, M22-XC-Y, M22S-B, M22-A, M22-XD-SWRGYB M22-KT1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-117 1.5 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Coding Adapter Guide Selector Switches 1 1 Two-Position Selector Switch Top (B) Top (B) Bottom (A) 1 1 Bottom (A) 1 Catalog Number Function M22(S)-W(L)(K) Momentary M22(S)-WR(L)(K) Maintained Three-Position Selector Switch Catalog Number Function Left Right M22(S)-W(L)(K)3 Momentary Momentary 1 M22(S)-WR(L)(K)3 Maintained Maintained 1 M22(S)-WR(L)(K)3-1 Maintained Momentary 1 M22(S)-WR(L)(K)3-2 Momentary Maintained Top (B) 1 Bottom (A) 1 Two-Position Key-Operated Selector Switch 1 Top (B) Bottom (A) 1 1 Catalog Number Center Key Withdraw Right Function Key Withdraw M22(S)-WS Yes Momentary No M22(S)-WRS Yes Maintained Yes M22(S)-WRS-A1 Yes Maintained No 1 1 Three-Position Key-Operated Selector Switch 1 Top (B) Catalog Number Left Function Key Withdraw Center Key Withdraw Right Function Key Withdraw M22(S)-WS3 Momentary No Yes Momentary No 1 M22(S)-WRS3 Maintained Yes Yes Maintained Yes 1 M22(S)-WRS3-A1 Maintained No Yes Maintained No 1 M22(S)-WRS3-A2 Maintained Yes Yes Maintained No 1 M22(S)-WRS3-A3 Maintained No Yes Maintained Yes M22(S)-WRS3-A4 Maintained Yes Yes Momentary No M22(S)-WRS3-A5 Maintained No Yes Momentary No M22(S)-WRS3-A6 Momentary No Yes Maintained Yes M22(S)-WRS3-A7 Momentary No Yes Maintained No 1 1 1 Bottom (A) 1 1 1 1 1 1 V7-T1-118 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Technical Data and Specifications 1 Pushbuttons, Indicating Lights, Selector Switches and Emergency-Stop Operators Description Momentary Pushbuttons Maintained Pushbuttons Indicating Lights, Buzzers and Potentiometers Emergency-Stop Selector Operators Switches Key-Operated Operators Double Pushbuttons IEC/EN 60947 VDE 0660 UL #E29184 IEC/EN 60947 VDE 0660 UL #E29184 IEC/EN 60947 VDE 0660 UL #E29184 IEC/EN 60947 VDE 0660 UL #340491 IEC/EN 60947 VDE 0660 UL #E29184 IEC/EN 60947 VDE 0660 UL #E29184 IEC/EN 60947 VDE 0660 UL #E29184 >1 >1800 — — >0.1 >600 >0.1 >2000 >0.1 >100 >0.2 >3600 >5 — >50 — — – >0.3 — >0.5 >5 — General Standards x 10 6 Actuating force n >5 >3600 >5 Operating torque (screw terminals) Nm — Lifespan, mechanical Operations Operating frequency Operations/h 1 1 1 1 1 — 1 Protection Type IP IP67, IP69K IP67, IP69K Indicating lights: IP67, 69K IP67, IP69K Buzzers: IP40 Potentiometers: IP66 IP66 IP66 IP66 1 UL type 4X, 13 4X, 13 Indicating lights: 4X/13 Buzzers: 12 Potentiometers: 4X/13 4X, 13 4X, 13 4X, 13 1 Climatic proofing 4X, 13 1 Damp heat, constant, according to IEC 60068-2-78 Damp heat, cyclical to IEC 60068-2-30 Ambient temperature, operating °F (°C) Mounting position Mechanical shock resistance to IEC 60068-2-27 shock duration 11 ms, half-sinusoidal g –13 to 158 (–25 to 70) –13 to 158 (–25 to 70) –13 to 158 (–25 to 70) –13 to 158 (–25 to 70) –13 to 158 (–25 to 70) –13 to 158 (–25 to 70) –13 to 158 (–25 to 70) As required As required As required As required As required As required As required >30 >30 >30 >50 >30 >30 >30 1 1 1 Terminal Capacities Solid AWG — mm2 Stranded AWG — mm2 — 20-16 — — 0.5–1.5 — — 20-16 — — 0.5–1.5 — — — — 1 — 1 — — — — 1 Contacts Rated impulse withstand Uimp voltage Vac — — 4000 — — — — Rated insulation voltage Ui V — — 2500 — — — — — — III/3 — — — — Overvoltage category/ pollution degree 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-119 1.5 1 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Contact Blocks and Light Units Contact Blocks LED Light Units IEC/EN 60947 VDE 0660 UL #E29184 IEC/EN 60947 VDE 0660 UL #E29184 x 10 6 >5 >3600 — Description General Standards 1 Lifespan, mechanical Operations Operating frequency Operations/h 1 Actuating force n >5 — Operating torque (screw terminals) Nm 30 >30 AWG 18–14 18–14 mm2 0.75–2.5 0.75–2.5 AWG 20–14 20–14 mm2 0.5–2.5 0.5–2.5 Mounting position Mechanical shock resistance to IEC 60068-2-27 shock duration 11 ms, half-sinusoidal Terminal Capacities 1 Solid 1 Stranded 1 Contacts Rated impulse withstand voltage Uimp Vac 6000 6000 1 Rated insulation voltage Ui V 500 500 Overvoltage category/ pollution degree III/3 III/3 NEMA contact ratings A600, Q300 — Current draw — 5–15 mA 1 1 1 Control Circuit Reliability at 24 Vdc/5 mA HF Fault probability 0.1 >600 >0.1 >600 Actuating force n 20–40 40–60 15–25 Operating torque Nm — — — Degree of protection, IEC/EN 60529 IP IP67, IP69K IP67, IP69K IP65 4X, 13 4X, 13 4X, 13 1 General Standards Lifespan, mechanical Operations Operating frequency Operations/h UL Type Climatic proofing 1 1 1 1 1 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Ambient temperature, operating °F (°C) –73 to 104 (–25 to 40) g >15 Mounting position –73 to 104 (–25 to 40) –73 to 104 (–25 to 40) 1 >15 >15 1 As required Mechanical shock resistance to IEC 60068-2-27 shock duration 11 ms, half-sinusoidal 1 ASi Adapter Modules Description M22-ASI M22-ASI-C Standards IEC/EN 60947, DIN EN 50295 IEC/EN 60947, DIN EN 50295 Radio interference suppression EN 55011, EN 55022 EN 55011, EN 55022 Limit value class — — Protection type IP20 IP00 Climatic proofing Damp heat, constant, to IEC 60068-2-78, cyclical, to IEC 60068-2-30 1 1 General 1 1 1 Ambient temperature, operating °F (°C) –13 to 131 (–25 to 55) –13 to 131 (–25 to 55) Shock resistance shock duration 11 ms g >30 >30 Vibration to IEC 60068-2-27 (amplitude 1 mm) Hz — — 1 1 Dimensions mm — — Weight kg — — 1 Mounting Front mounting Front mounting Mounting position As required As required 1 26.5–31.6 26.5–31.6 1 Connection technique Yellow plug-in terminal as insulation piercing terminal Two cables onboard 1 Power supply Completely from the AS-interface cable Addressing Via connection to AS-interface cable >40 >40 1 1 Power Supply Rated voltage to AS-interface specification Total power consumption of the AS-interface Vdc mA AS-interface 1 — — Rated operational current at full load mA — — Rated operational current when idle (no I, O set) mA — — 1 POWER AS-interface cable: green LED on the rear side of the element POWER AS-interface cable: green LED on the board 1 Status LEDs 1 ERROR AS-interface, AS-interface master ERROR AS-interface, AS-interface master failure: red LED on the rear side of the element failure: red LED on the board 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-121 1.5 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 ASi-S Adapter Modules M22-ASI-S M22-ASI-CS Number Two (normally 22V/5 mA) Two (normally 22V/5 mA) Voltage range Vdc — — 1 Rated current per input mA — — High signal level V — — 1 Low signal mA — — Length of connecting cables cm — — 1 Outputs Outputs, protected against short-circuit Number One (normally 19V/8 mA) One (normally 19V/8 mA) Voltage range Vdc — — All outputs — — S three external outputs — — 1 1 1 1 1 Description Inputs Inputs, protected against short-circuit Max. Current Carrying Capacity Length of connecting cables 1 Profile 1 Addresses 1 1 1 cm Specification — — S-3.A.E S-3.A.E 2.1 2.1 62 62 Connection of the AS-interface line Yellow plug terminal with insulation piercing Two cables on the circuit board Power supply Complete from AS-interface, cable 26.5–31.6 Vdc Complete from AS-interface, cable 26.5–31.6 Vdc Fixing Front mounted Base mounted Addressing Via AS-interface cable Via AS-interface cable 45 mA Number Emergency-Stop Circuits 1 Max. total current A 45 mA Ambient temperature, operating °F (°C) –13 to 131 (–25 to 55) –13 to 131 (–25 to 55) 1 Shock resistance 30g/11 ms as per IEC 60068-2-27 30g/11 ms as per IEC 60068-2-27 Protection type IP20 IP00 Climatic proofing Damp heat, constant, to IEC 60068-2-78, cyclical, to IEC 60068-2-30 Damp heat, constant, to IEC 60068-2-78, cyclical, to IEC 60068-2-30 1 1 Mounting position As required As required Standards 1 EN 50178 EN 50 295 EN 50178 EN 50 295 Inputs 1 Two-channel input (22V/5 mA) (moduled by code sequence) (two break contact sets M22-K01) Two-channel input (22V/5 mA) (moduled by code sequence) (two break contact sets M22-K01) Outputs 1 One output, typically 19V/8 mA, short-circuit proof One output, typically 19V/8 mA, short-circuit proof Status Displays Power, AS-interface cable Green LED on the back Green LED on the back AS-interface error, AS-interface master failure Red LED on the back Red LED on the back Profile S-7.B.E S-7.B.E 1 1 1 1 1 1 1 1 1 V7-T1-122 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Dimensions Approximate Dimensions in Inches (mm) 1 Operators and Indicating Lights 1 1 Ø 1.16 (29.5) Ø 1.17 (29.7) M22 x 0.06 (1.5) 1 1 1.17 (29.7) 1 0.04 (1)–0.24 (6) 1 0.39 (10) 0.75 (19) 1 Pushbuttons Selector Switches Operators M22…-D-_ M22…-DH-_ M22…-W-_ 1 M22…-WL-_ 1 1 1 1 0.39 (10) 0.65 (16.4) M22-DG(L)-_ 0.93 (23.7) 1.06 (26.9) 1 M22…-DD-_ 1 M22…-W(R)S-_ 0.65 (16.5) 1 1 Ø1.17 (29.7) 2.15 (54.7) Ø1.17 (29.7) Key-Operated Selector Switches 1 1 0.52 (13.2) 0.81 (20.6) 1 1.88 (47.75) M22-D, Base Mounted 1.47 (37.2) 1 >0.01 (0.3) Indicating Light 1 M22-L_ 1 1 0.04 (1) 1 1.78 (45.3) 1 1 0.45 (11.5) 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-123 1.5 1 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Approximate Dimensions in Inches (mm) Illuminated Pushbuttons Contact Block Mounting Adapter M22…-DL-_ M22-A_ M22…-DLH_ M22S-A… 0.85 (21.5) 1.77 (45) 1 1 0.76 (19.3) 1 1.73 (44) 1 1 1 1 Mushroom Head Pushbutton Front Mounted Centering Adapter M22…-DP-_ M22-ZA 0.84 (21.4) 1 0.65 (16.4) Ø1.44 (36.5) 1 1.18 (30) 0.39 (10) 1 1 1 1 0.93 (23.6) 0.7 (17.8) Front Mounted Indicating Light Emergency-Stop Operators M22-PV_ M22S-PV_ M22-PVL_ M22-PVS_ 1.46 (37) 1 1.18 (30) 1.38 (35) 1 1 1 1.5 (38) 1 A 2.96 (75.1) 1 1 1.77 (45) 2.8 (71) 1.18 (30) 1 1 0.39 (10) M22(S)-R_ 0.39 (10) Potentiometer 0.39 (10) 1 Pushbutton, Complete Devices 1.89 (47.9) 1 1 1.77 (45) 1.18 (30) A 1.15 (29.2) 1 x M22-K_ 2 x M22-K_ 1 x M22-CK_ 2 x M22-CK_ 1.46 (37.2) 1.46 (37.2) 1.54 (39.0) 1.54 (39.0) 1.3 (32.9) 1 1 1 V7-T1-124 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1.5 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Approximate Dimensions in Inches (mm) 1 Front Mounted Mounting Plate DIN-Rail Mounting Adapter 1 M22-E_ M22-D... M22-L... M22-W... M22-P... 0.12 (3.1) M22-D_ M22-L_ M22-W_ M22-P_ M22-TCV 1 2.2 (56) 0.12 (3) 1 a1 0.18 (4.5 (M4)) M22-TC 1 0.1 (2.5) 1.3 (33) e Pushbuttons and Indicating Lights with M22-TC Telescopic Clip and M22-TVC Extension 1 1 1 1.39 (35.2) 2.23 (56.7) 1 4 x M4 x 16 2.83 (72) 2.15 (54.5) 0.88 (22.4) 2.54 (64.5) 1.42 (36) 0.88 (22.4) 1 Catalog Number a1 e Catalog Number a1 e M22-E(Y) 1 M22-E2 M22-E3 2.83 (72) 4.13 (105) 5.43 (138) 2.21 (56) 3.50 (89) 4.80 (122) M22-E4 M22-E5 M22-E6 6.73 (171) 8.03 (204) 9.33 (237) 6.10 (155) 7.40 (188) 8.70 (221) 1 M22-I_ A B G H F A B C D E F G H 1.77 (45) 2.36–3.94 (60–100) 0.79 (20) 0.79 (20) 0.18 (4.5) 0.39 (10) 154 (39) 0.39 (10) e 1.3 (33) b a M4 M20/M25 Palm Switches FAK_ M20 L-... 1.57 (40) 1.36 (34.5) M5 x 20 2.56 (65) 1.42 (36) M22-I(Y)1 1 M22-I2 2 M22-I3 3 M22-I4 4 M22-I6 6 0.26 (6.5) – 0.3 (7.5) 3.35 (85) 1 1 1 a b e Cable Entries 2.83 (72.0) 4.72 (120.0) 6.02 (153.0) 7.32 (186.0) 9.92 (252.0) 1.68 (42.6) 3.37 (85.6) 4.67 (118.6) 5.97 (151.6) 8.57 (217.6) 2.30 (58.5) 4.19 (106.5) 5.49 (139.5) 6.79 (172.5) 9.39 (238.5) 2 x M16 3 x M20 2 x M25 2 x M20 3 x M20 2 x M25 1 2 x M20 2 x M25 4 x M20 1 2 x M20 2 x M25 4 x M20 1 1 1 1 1 1 1 1 2 x M20 2 x M25 4 x M20 0.71 (18) 3.98 (101) Ø94 1 1 1.89 (48) Mounting Locations 1 1 M20 Catalog Number 1 1 Top-hat rail to IEC/EN 60715. 0.7 (17.8) 2.2 (56) 1 M20 2.62 (66.5) M20 1.73 (44) 3.15 (80) D E 1 1 Base Mounted Surface Mounting Enclosure C 1 3 x M20 lateral, 1 x M16 in bottom. 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-125 1.5 Approximate Dimensions in Inches (mm) Covers Legend Plates M22-H_ M22S-ST-_ 1 M20 2.32 (59) 1 M20 M20 0.59 (15) 1 1 1 1 1 1 1.18 (30) Catalog Number a2 Cable Entry Style M22-H1 M22-H2 M22-H3 M22-H4 M22-H5 M22-HE6 1.65 (42) 2.95 (75) 4.25 (108) 5.55 (141) 6.85 (174) 8.15 (207) 3 x M20 4 x M20 4 x M20 4 x M20 5 x M20 6 x M20 One-piece 1.18 (30) Split Mounting Hole with Lug Slot 0.13 (3.2) Connecting Screw M22-XI 0.95 (24.1) 1 1 1 1 0.88 (22.3) 1 1 1 1.85 (47) 1 M22S-STDD-X 3.74 (95) a2 1.08 (27.5) 1 22.5 mm Modular Pushbuttons—M22 1.38 (35) 1 Pushbuttons and Indicating Lights 0.04 (1)–0.24 (6) 0.04 (1) 1 Gasket. USB Socket Shroud with Plaster Keys M22-UPE 1 a2 +1.65 (42) a2 +1.26 (32) 1 a2 M22-H... 1 e 1 e + 0.51 (13) 0.35 (9) 1 1 M22-H... 2 2 3 1 1.02 (26) 1 0.31 (8) 1 1 0.35 (9) 4 0.31 (8) 1 2.76 (70) 1 0.16 (4) 2.2 (56) 1 M22-UPE 3 Box for closing off when plastering. Plaster thickness less than 8 mm. Plaster thickness more than 8 mm. 1 V7-T1-126 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Approximate Dimensions in Inches (mm) Grid Dimension to IEC/EN 60947 1 Grid Dimension for M22-DD_ 1 1 1 1.97 (50) 1 1 2.95 (75) 2.48 (63) 1 1 1 1.18 (30) 1 1 Grid Dimension for Various Combinations 1 1 B 1.18 (30) Grid Dimension for M22-DDL_ 1 a 1.18 (30) 1 1 Pushbutton Diaphragm M22-T-DD 1 B> M22(S)-_(IEC/EN 60947) RMQ-Titan min. M22-D_ + M22-T-D M22-D(R)P_ M22-PV_ M22-PV(L) + M22-PL-PV M22-PV(L)(S_) + M22-D_ M22-DDL_ M22-DDL_ + M22-T-DD M22-ST_ M22-STDD_ M22-CK_ M22-CLED_ M22-XAK_ M22-XZK_ M22-XBK_ M22-XYK_ M22-D4 M22-WR…4 M22-W…J4 1.18 (30.0) 1.18 (30.0) 1.30 (33.0) 1.50 (38.0) 1.50 (38.0) 1.89 (48.0) 1.30 (33.0) 1.18 (30.0) 1.30 (33.0) 1.18 (30.0) 1.18 (30.0) 1.18 (30.0) 1.18 (30.0) 3.54 (90.0) 1.30 (33.0) 2.36 (60.0) 1.97 (50.0) 2.17 (55.0) 1.97 (50.0) 1.97 (50.0) 1.97 (50.0) 1.58 (40.0) 1.58 (40.0) 1.58 (40.0) 1.58 (40.0) 2.20 (56.0) 1.58 (40.0) 2.17 (55.0) 2.28 (58.0) 1.97 (50.0) 2.95 (75.0) 1.77 (45.0) 1.77 (45.0) 3.54 (90.0) 2.04 (52.0) 2.36 (60.0) 1.97 (50.0) 2.17 (55.0) 1.97 (50.0) 1.97 (50.0) 1 1 1 1 1 Pushbutton diaphragm cannot be combined with label mount. 1 Emergency Stop Sealing Cover 1 M22-PL-PV 2.03 (51.6) Catalog Number A> 1 1 1 1 0.41 (10.4) 1.89 (48) Pushbutton diaphragm cannot be combined with label mount. b 1.73 (44) Pushbutton Diaphragm 1 b 2.28 (58) A 1 1 1 1.26 (32) Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-127 1.5 1 22.5 mm Modular Pushbuttons—M22 Approximate Dimensions in Inches (mm) Blanking Plugs Emergency Stop Legend Plate M22…B-_ M22-XAK_ M22-X(Y)ZK_ 1.16 (29.5) 1 d= 0.03 (0.8) 0.65 (16.5) 1 1 Pushbutton Diaphragm M22-T-D 3.54 (90) Ø 2.36 (60) M22-XGWK 0.98 (25) Joystick R35 R41 2.68 (68) 1 M22…W…J_ 1.97 (50) 3.07 (78) 2.95 (75) 1.18 (30) Key Cover Four-Way Pushbutton M22-XWS 0.2 (5) M22…-D…4-_ 0.79 (20) 1 1 M22-XGPV Ø 1.42 (36) 1 1 1.97 (50) Guard Ring 1 1 0.67 (17) 0.91 (23) 1 1 5) 0.49 (12.5) 1.3 (33) 1.3 (33) 1 1 2. Ø 1 1 M22-XYK-_ 0.13 (3.2) 0. 1 1 M22-XBK-_ (2 1 89 1 1.97 (50) M22-T-D 2.28 (58) 1 1.3 (33) 0.67 (17) 1 1 1 1.97 (50) 1 Pushbuttons and Indicating Lights 0.47 (12) Ø 0.98 (25) 2.17 (55) 0.45 (11.5) 1 1 1 1 V7-T1-128 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Symbols Library 1 Instructions for Ordering Laser Inscriptions 1. Identify part number to be inscribed. 1 2. Pick symbol from library and identify suffix code associated with the symbol. 1 3. Order part number already listed in the catalog with -ETCH suffix. 1 4. When placing an order by fax or Vistaline on the Web, reference order item number and indicate appropriate suffix code. 1 Example To order a green flush button plate with the inscription AUTO HAND: 1 Order Catalog Number: M22-XD-G-ETCH (see Page V7-T1-55). 1 AUTO HAND inscription is found on Page V7-T1-133 in the Symbols Library, suffix code is X91. 1 In the order notes, reference item number and suffix X91. 1 Letter height 3 mm: max. three lines, max. 12 characters per line. 1 Letter height 5 mm: max. two lines, max. eight characters per line. 1 Note: For symbols or text not found in the Symbols Library, please contact the Eaton Technical Resource Center at 1-877-ETN CARE (386-2273) or TRC@eaton.com. 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com V7-T1-129 1.5 1 22.5 mm Modular Pushbuttons—M22 Letter Height Specifications: < five characters; letter height = 0.197 in (5 mm). > five characters; letter height = 0.118 in (3 mm). Text—English 1 1 Pushbuttons and Indicating Lights Inscription Text—German Catalog Number Suffix Inscription Catalog Number Suffix Inscription Catalog Number Suffix Inscription Catalog Number Suffix GB0 GB18 D0 D25 1 GB1 GB19 D1 D28 1 GB2 GB20 D2 D29 1 GB3 GB21 D3 D30 1 GB4 GB22 D4 D31 1 GB5 GB23 D5 D32 1 GB6 GB24 D6 D33 1 GB7 GB25 D7 D34 1 GB8 GB26 D8 D35 1 GB9 GB27 D9 D36 1 GB10 GB32 D10 D37 1 GB11 GB62 D11 D38 1 GB12 GB63 D12 D39 1 GB14 GB64 D13 D40 1 GB15 GB65 D14 D41 1 GB16 GB66 D15 D42 1 GB17 GB99 D16 D43 1 D17 D44 1 D18 D72 1 D19 D73 1 D20 D74 1 D21 D75 1 D22 D99 1 D23 D100 1 D24 1 1 1 Text Size: 3 mm—Max. eight characters in first line; 10 characters in second line; eight characters in third line. V7-T1-130 Text Size: 5 mm—Max. five characters per line. Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 1.5 Letter Height Specifications: < five characters; letter height = 0.197 in (5 mm). > five characters; letter height = 0.118 in (3 mm). Text—French Inscription Text—Swedish Catalog Number Suffix Inscription Symbols Catalog Number Suffix F0 S0 F1 S1 F2 S2 F3 S3 F4 S4 F5 S5 F6 S6 F7 S7 F8 S8 F9 S9 F10 S10 F11 S11 F12 S12 F14 S14 F15 S15 F16 S16 F17 S17 F18 S18 F19 S19 F20 S20 F67 S21 F68 S22 F99 S23 Inscription Catalog Number Suffix Inscription X0 Catalog Number Suffix 1 X13 1 1 X1 1 X14 1 X2 1 X15 1 X3 X16 1 1 X4 X17 1 1 X5 X18 1 1 X6 X19 X7 X20 X8 X21 X9 X22 X10 X23 X11 X24 X12 X25 1 1 1 1 1 1 1 1 1 1 1 S32 S45 1 1 1 S46 1 S99 1 Text Size: 3 mm—Max. eight characters in first line; 10 characters in second line; eight characters in third line. Text Size: 5 mm—Max. five characters per line. Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1 V7-T1-131 1.5 1 Inscription 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Catalog Number Suffix Inscription Catalog Number Suffix Inscription Catalog Number Suffix Inscription Catalog Number Suffix X26 X40 X54 X68 X27 X41 X55 X69 X28 X42 X56 X70 X29 X43 X57 X71 X30 X44 X58 X72 X31 X45 X59 X73 X32 X46 X60 X74 X33 X47 X61 X75 X34 X48 X62 X76 X35 X49 X63 X77 X36 X50 X64 X78 X37 X51 X65 X79 X38 X52 X66 X80 X39 X53 X67 X81 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Text Size: 3 mm—Max. eight characters in first line; 10 characters in second line; eight characters in third line. V7-T1-132 Text Size: 5 mm—Max. five characters per line. Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Inscription Catalog Number Suffix Inscription X82 Catalog Number Suffix Inscription X104 Catalog Number Suffix Inscription X118 1.5 Catalog Number Suffix 1 X132 1 1 X83 X105 X119 X133 1 1 X88 X106 X120 X134 1 1 X89 X107 X121 X135 1 1 X90 X108 X122 X136 1 1 X91 X109 X123 X137 X92 X110 X124 X138 X93 X111 X125 X139 1 1 1 1 1 1 X94 X112 X126 X140 X95 X113 X127 X141 X100 X114 X128 X142 X101 X115 X129 X143 X102 X116 X130 X144 X103 X117 X131 X145 1 1 1 1 1 1 1 1 1 1 1 1 Text Size: 3 mm—Max. eight characters in first line; 10 characters in second line; eight characters in third line. Text Size: 5 mm—Max. five characters per line. Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1 V7-T1-133 1.5 1 Inscription 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Catalog Number Suffix Inscription Catalog Number Suffix Inscription Catalog Number Suffix Inscription Catalog Number Suffix X146 X160 X174 X188 X147 X161 X175 X189 X148 X162 X176 X190 X149 X163 X177 X191 X150 X164 X178 X192 X151 X165 X179 X193 X152 X166 X180 X194 X153 X167 X181 X195 X154 X168 X182 X196 X155 X169 X183 X197 X156 X170 X184 X198 X157 X171 X185 X199 X158 X172 X186 X200 X159 X173 X187 X201 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Text Size: 3 mm—Max. eight characters in first line; 10 characters in second line; eight characters in third line. V7-T1-134 Text Size: 5 mm—Max. five characters per line. Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Inscription Catalog Number Suffix Inscription X202 Catalog Number Suffix Inscription X216 Catalog Number Suffix Inscription X230 1.5 Catalog Number Suffix 1 X244 1 1 X203 X217 X231 X245 1 1 X204 X218 X232 X246 1 1 X205 X219 X233 X247 1 1 X206 X220 X234 X248 1 1 X207 X221 X235 X249 X208 X222 X236 X250 X209 X223 X237 X251 1 1 1 1 1 1 X210 X224 X238 X252 X211 X225 X239 X253 X212 X226 X240 X254 X213 X227 X241 X255 X214 X228 X242 X256 X215 X229 X243 X257 1 1 1 1 1 1 1 1 1 1 1 1 Text Size: 3 mm—Max. eight characters in first line; 10 characters in second line; eight characters in third line. Text Size: 5 mm—Max. five characters per line. Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com 1 V7-T1-135 1.5 1 Inscription 1 Pushbuttons and Indicating Lights 22.5 mm Modular Pushbuttons—M22 Catalog Number Suffix Inscription Catalog Number Suffix Inscription Catalog Number Suffix Inscription Catalog Number Suffix X258 X265 X272 X279 X259 X266 X273 X280 X260 X267 X274 X281 X261 X268 X275 X282 X262 X269 X276 X283 X263 X270 X277 X284 X264 X271 X278 X285 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Text Size: 3 mm—Max. eight characters in first line; 10 characters in second line; eight characters in third line. V7-T1-136 Text Size: 5 mm—Max. five characters per line. Volume 7—Logic Control, Operator Interface and Connectivity Solutions CA08100008E—March 2014 www.eaton.com
DEL-M22M-D-G-GB1-K10 价格&库存
很抱歉,暂时无法提供与“DEL-M22M-D-G-GB1-K10”相匹配的价格&库存,您可以联系我们找货
