DILM65(RDC24)
DILM65(RDC24)
    EATON(伊顿)
DILM65(RDC24) 数据手册
Contactor,30kW/400V,DC-operated Part�no. DILM65(RDC24) Article�no. 277908 Program Product range     Contactors Application     Contactors for Motors Subrange     Contactors up to 170 A, 3 pole Connection technique     Screw terminals Pole     3 pole Rated operational current             Ie A 65                   Ith =Ie A 98             220 V 230 V P kW 20 380 V 400 V P kW 30 660 V 690 V P kW 35 AC-3 380 V 400 V AC-1 Conventional free air thermal current, 3 pole, 50 - 60 Hz Open at 40 °C Max. rating for three-phase motors, 50 - 60 Hz AC-3 AC-4       220 V 230 V P kW 7 380 V 400 V P kW 12 660 V 690 V P kW 17 Contact sequence     Instructions     Contacts to EN 50 012. integrated suppressor circuit in actuating electronics Can be combined with auxiliary contact     DILM150-XHI(V).. DILM1000-XHI(V).. Voltage AC/DC     DC operation Approbationen Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Specially designed for NA General IEC/EN 60947-4-1; UL 508; CSA-C22.2 No. 14-05; CE marking E29096 NLDX 012528 2411-03, 3211-04 UL listed, CSA certified No Standards     IEC/EN 60947, VDE 0660, UL, CSA Lifespan, mechanical       AC operated Operations x DC operated Operations x       AC operated Operations/ h   5000 DC operated Operations/ h   5000 Operating frequency, mechanical 09/28/2011 6 10 6 10 10 10 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 1 / 12 Climatic proofing     Damp heat, constant to IEC 60068-2-78 Damp heat, cyclic to IEC 60068-2-30 Ambient temperature   °C   Open   °C - 25 - 60 Enclosed   °C - 25 - 40 Storage   °C - 40 - 80     Mounting position, AC- and DC operated     Mechanical shock resistance (IEC/EN 60068-2-27) Half-sinusoidal shock, 10 ms Main contacts                   N/O contact   g 10 Auxiliary contacts       N/O contact   g 7 N/C contact   g 5                   N/O contact   g 10 Auxiliary contacts       N/O contact   g 7 N/C contact Mechanical shock resistance (IEC/EN 60068-2-27) when tabletopmounted Half-sinusoidal shock, 10 ms Main contacts   g 5 Protection type     IP00 Protection against direct contact when actuated from front (EN 90274)     Finger- and back-of-hand proof Weight       AC operated   kg 0.9 DC operated   kg 1.1       Solid   mm 2 1 x (0.75 - 16) 2 x (0.75 - 16) Flexible with ferrule   mm 2 1 x (0.75 - 35) 2 x (0.75 - 25) Stranded   mm 2 1 x (16 - 50) 2 x (16 - 35) Solid or stranded   AWG 12 - 2 Flat conductor Number of segments x width x thickness mm 2 x (6 x 9 x 0.8) Main cable connection screw/bolt     M6 Tightening torque   Nm 3.3 Terminal capacity control circuit cables     Terminal capacity main cable Solid   Flexible with ferrule Solid or stranded   mm 2 1 x (0.75 - 4) 2 x (0.75 - 4)   mm 2 1 x (0.75 - 2.5) 2 x (0.75 - 2.5)   AWG 18 - 14 Control circuit cable connection screw/bolt     M3.5 Tightening torque   Nm 1.2 Tool             Pozidriv screwdriver   Size 2 Standard screwdriver   mm 0.8 x 5.5 1x6 Main cable 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 2 / 12 Control circuit cables       Pozidriv screwdriver   Size 2 Standard screwdriver   mm 0.8 x 5.5 1x6     Terminal capacity control circuit cables   Solid   mm 2 Flexible   mm 2 1 x (0.75 - 2.5) 2 x (0.75 - 2.5) Flexible with ferrule   mm 2 1 x (0.75 - 1.5) 2 x (0.75 - 1.5) Solid or stranded   AWG 18 - 14       Stripping length   mm 10 Screwdriver blade width   mm 3.5 Rated impulse withstand voltage Uimp V AC 8000 Overvoltage category/pollution degree     III/3 Rated insulation voltage Ui V AC 690 Rated operational voltage Ue V AC 690 Safe isolation to VDE 0106 Part 101 and Part 101/A1 Tool Main�conducting�paths 1 x (0.75 - 2.5) 2 x (0.75 - 2.5)       between coil and contacts   V AC 440 between the contacts   V AC 440       Up to 690 V A 910       220/230 V   A 650 380/400 V   A 650 500 V   A 650 660/690 V   A 370                   400 V gG/gL 500 V A 125 690 V gG/gL 690 V A 80       400 V gG/gL 500 V A 250 690 V gG/gL 690 V A 100                   at 40 °C Ith =Ie A 98 at 50 °C Ith =Ie A 88 at 55 °C Ith =Ie A 83 at 60 °C Ith =Ie A 80 Ith A 72       open Ith A 200 enclosed Ith A 180       Making capacity (p.f. to IEC/EN 60947)   Breaking capacity Short-circuit rating Short-circuit protection maximum fuse Type “2” coordination Type “1” coordination AC AC-1 duty Conventional free air thermal current, 3 pole, 50 - 60 Hz Open enclosed Conventional free air thermal current, 1 pole AC-3 duty 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 3 / 12 Rated operational current AC-3 open, 50 - 60 Hz, 3 pole Ie     220/230 V Ie A 65 240 V Ie A 65 380/400 V Ie A 65 415 V Ie A 65 440V Ie A 65 500 V Ie A 65 660/690 V Ie A 37 Motor rating P kWh   220/230 V P kW 20 240V P kW 22 380/400 V P kW 30 415 V P kW 39 440 V P kW 41 500 V P kW 47 660/690 V P kW 35       Ie     220/230 V Ie A 25 240 V Ie A 25 380/400 V Ie A 25 415 V Ie A 25 440 V Ie A 25 500 V Ie A 25 AC-4 duty Rated operational current AC-4 open, 50 - 60 Hz, 3 pole 660/690 V Ie A 20 Motor rating P kWh   220/230 V P kW 7 240 V P kW 7.5 380/400 V P kW 12 415 V P kW 13 440 V P kW 14 500 V P kW 16 660/690 V P kW 17       DC Rated operational current, open DC-1 operation       60 V Ie A 72 110 V Ie A 72 220 V Ie A 65 440 V Ie A 2.9 DC-3 operation       60 V Ie A 72 110 V Ie A 72 220 V Ie A 35 440 V Ie A 0.6 DC-5 operation       60 V Ie A 72 110 V Ie A 72 220 V Ie A 35 440 V Ie A 0.6 Current heat loss at Ith   W 28.8 Current heat loss at Ie to AC-3/400 V   W 19 Current�heat�loss�(3�pole) 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 4 / 12 Impedance per pole   mΩ 1.5 Voltage tolerance   x Uc   AC operated Pick-up x Uc 0.8 - 1.1 Drop-out voltage AC operated Dropout x Uc 0.3 - 0.6 Notes     RDC 24 (Umin 24 V DC/Umax 27 V DC) Example: Uc = 0.7 x Umin - 1.2 x Umax / Uc = 0.7 x 24 V - 1.2 x 27 V DC DC operated Pick-up x Uc 0.7 - 1.2 Notes     at least smoothed two-phase bridge rectifier or three-phase rectifier DC operated Dropout x Uc 0.15 - 0.6       50 Hz Pick-up VA 149 50 Hz Sealing VA 16 50 Hz Sealing W 4.3 60 Hz Pick-up VA 178 60 Hz Sealing VA 19 60 Hz Sealing W 5.3 50/60 Hz Pick-up VA 168 154 50/60 Hz Sealing VA 22 14 50/60 Hz Sealing W 5.3 4.3 DC operated Pick-up W 24 DC operated Magnet�systems Power consumption of the coil in a cold state and 1.0 x Uc Sealing W 0.5 Duty factor   % DF 100 Switching times at 100 % Uc (approximate values)                   Closing delay   ms 12 - 18 Opening delay   ms 8 - 13   ms   Closing delay   ms 54 Opening delay   ms 24   ms 10 at 50 Hz   Mechanical lifespan at 50 Hz approx. 30% lower than under “Technical data, general” Emitted interference     to EN 60947-1 Interference immunity     to EN 60947-1 Number of main contacts as N/Os     3 Rated operation current Ie at AC-1, 400 V     98 Connection type main circuit     Screw connection Rated control voltage Us at AC 60HZ   V 0 Number of auxiliary contacts as N/Os     0 Rated control voltage Us at AC 50HZ   V 0 Number of auxiliary contacts as N/Cs     0 Suitable for rail-mounting     No Rated control voltage Us at DC   V 27 Voltage type for actuation     DC Rated operation current Ie at AC-3, 400 V   A 65 Number of N/Cs as main contact     0 Motor rating at AC-3, 400 V   kWh 30 Main contacts AC operated DC operated Arcing time Lifespan, mechanical; Coil 50/60 Hz Electromagnetic�compatibility�(EMC) Technical�data�according�to�ETIM�4.0 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 5 / 12 Characteristics 1: Overload relay 2: Suppressor 3: Auxiliary contact modules 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 6 / 12 on the side: 2 x DILM1000-XHI(V)11-SI; surface mounting: 1 x DILM150-XHIA11 on the side: 2 x DILM1000-XHI(V)11-SA; surface mounting: 1 x DILM150-XHI (2 pole) on the side: 1 x DILM1000-XHI(V)11-SI; surface mounting: 1 x DILM150-XHIA22 on the side: 1 x DILM1000-XHI(V)11-SA; surface mounting: 1 x DILM150-XHI (4 pole) Projektieren 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 7 / 12 Squirrel-cage motor Operating characteristics Starting:from rest Stopping:after attaining full running speed Electrical characteristics Make: up to 6 x rated motor current Break: up to 1 x rated motor current Utilization category 100 % AC-3 Typical applications Compressors Lifts Mixers Pumps Escalators Agitators Fans Conveyor belts Centrifuges Hinged flaps Bucket-elevators Air conditioning system General drives in manufacturing and processing machines 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 8 / 12 Extreme switching duty Squirrel-cage motor Operating characteristics Inching, plugging, reversing Electrical characteristics Make: up to 6 x rated motor current Break: up to 6 x rated motor current Utilization category 100 % AC-4 Typical applications Printing presses Wire-drawing machines Centrifuges Special drives for manufacturing and processing machines CAD-Data Product standards CAD data: http://eaton-moeller.partcommunity.com/PARTcommunity/Portal/eaton-moeller Dimensions 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 9 / 12 Contactor with auxiliary contact module 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 10 / 12 Lateral clearance to earthed parts: 6 mm 09/28/2011 Moeller Electric, www.moeller.net; E-Mail: catalog@moeller.net HPL-ED2009 V0.9 %s 11 / 12 DILM40…DILM72 DILMC40…DILMC65 DILMF40…DILMF65 Additional�product�information�(links) IL03407033Z (AWA2100-2247) Contactor DILM, basic unit ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL03407033Z2010_10.pdf Installation Instructions http://www.moeller.net/en/support/instructions_awa.jsp Documentation http://www.moeller.net/en/support/index.jsp Projektieren Projektieren Motor starters and "Special Purpose Ratings" for the North American market http://www.moeller.net/binary/ver_techpapers/ver953en.pdf Busbar Component Adapters for modern Industrial control panels http://www.moeller.net/binary/ver_techpapers/ver960en.pdf The Interaction of Contactors with PLCs http://www.moeller.net/binary/ver_techpapers/ver957en.pdf Standard Compliant and Functionally Safe Engineering Design with Mechanical Auxiliary Contacts http://www.moeller.net/binary/ver_techpapers/ver956en.pdf Switchgear for Luminaires http://www.moeller.net/binary/ver_techpapers/ver955en.pdf Effect of the Cabel Capacitance of Long Control Cables on the Actuation of Contactors http://www.moeller.net/binary/ver_techpapers/ver949en.pdf X-Start - Modern Switching Installations Efficiently Fitted and Wired Securely http://www.moeller.net/binary/ver_techpapers/ver938en.pdf Mirror Contacts for Highly-Reliable Information Relating to SafetyRelated Control Functions http://www.moeller.net/binary/ver_techpapers/ver944en.pdf X-Start - New Generation:100 years of Moeler contactors - Continous Progress- http://www.moeller.net/binary/ver_techpapers/ver937en.pdf Switchgear of Power Factor Correction Systems http://www.moeller.net/binary/ver_techpapers/ver934en.pdf Engineering 09/28/2011 Eaton Industries GmbH http://www.moeller.net/en © 07/2011 by Eaton Industries GmbH HPL-ED2011 V2.0 EN 12 / 12
DILM65(RDC24)
PDF文档中的物料型号为:ATMEGA328P-AUR。
器件简介指出ATMEGA328P-AUR是一款低功耗、高性能的8位AVR微控制器,具有32KB的系统内可编程Flash、1KB的EEPROM、2KB的SRAM。
引脚分配包括28个引脚,分为多个功能组,如VCC、GND、I/O、RST等。
参数特性包括工作电压范围、工作频率、温度范围等。
功能详解涵盖了CPU、存储器、I/O端口、定时器、ADC、通信接口等。
应用信息指出该芯片适用于工业控制、消费电子、汽车电子等领域。
封装信息显示该芯片采用TQFP-32封装。
DILM65(RDC24) 价格&库存
很抱歉,暂时无法提供与“DILM65(RDC24)”相匹配的价格&库存,您可以联系我们找货
DILM65(RDC24)
    • 1+4207.02362
    • 5+3683.36456
    库存:7
