DWM2655M
DWM2655M
    EATON(伊顿)
    EATON TRIPP LITE - DWM2655M - WALL MOUNT, ADJ, 26-55INCH DISPLAY, BLK
DWM2655M 数据手册
Full-Motion Wall-Mount for 26" to 55" Flat-Screen Displays MODEL NUMBER: DWM2655M Highlights REPLACES MODEL DWM2342M Can be used to increase available desk/table space in office applications Fits most flat-panel displays from 26” to 55” Convenient one-touch display adjustment for easy view optimization Equipped with a bubble level for accurate display leveling Wide range of motion with -15° to +15° tilt and 120° swivel capability Supports up to 110 lbs. 5-year warranty Package Includes Description Tripp Lite’s VESA-compliant DWM2655M Full-Motion Flat-Screen Wall Mount offers full-motion articulation and can free up valuable space in your workstation by allowing you to effortlessly reposition your display at any time, even after installation. Its sleek design features convenient one-touch display adjustment with tilt and swivel capabilities and fits most 26- to 55-inch flat-panel displays. Its durable, all-metal frame with scratch-resistant, DWM2655M Full-Motion Flat-Screen Wall Mount Mounting Hardware Owner’s Manual powder-coat finish withstands the stress of repeated use and blends easily into any décor. It comes with all necessary mounting hardware and supports weights of up to 110 lbs. A built-in bubble level enables accurate display leveling. For peace of mind, the DWM2655M comes backed by a 5-year warranty. Specifications PHYSICAL Mounting Location Wall Unit Weight (lbs.) 18.45 Unit Weight (kg) 8.37 Color Black Screen Size Compatibility (in.) 26 - 55 Screen Size Compatibility (cm) 66.04 - 139.70 VESA Pattern (mm) 200x200; 400x200; 300x300; 400x400 Motion Full Degrees of Motion -15/+15 Tilt, 120 Swivel, -5/+5 Level Adjustment Min/Max Arm Extension (in.) 4.92 min to 20.27 max 1/2 Min/Max Arm Extension (cm) 12.5 min to 51.5 max Maximum Weight Capacity (lbs.) 110 Maximum Weight Capacity (kg) 49.8 FEATURES & SPECIFICATIONS Tools Necessary Yes Cord Management No WARRANTY Product Warranty Period (U.S. & Canada) 5-year limited warranty © 2015 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: http://www.tripplite.com/products/product-certification-agencies 2/2
DWM2655M
物料型号:DWM2655M
器件简介:这款支架适用于26至55英寸的平板显示器,具有全动态调节功能,可以节省工作空间,并通过一键式显示调整实现轻松查看优化。
引脚分配:VESA模式支持200x200、400x200、300x300和400x400。
参数特性:支架可以进行-15°至+15°的倾斜和120°的旋转,具有5°的水平调整能力。最小和最大臂展分别为4.92英寸至20.27英寸,重量为18.45磅,颜色为黑色。
功能详解:支架设计紧凑,具有一键式显示调整功能,包括倾斜和旋转能力,适用于多种尺寸的显示器。耐用的全金属框架采用抗刮擦的粉末涂层,易于融入任何装饰风格。
应用信息:适用于办公室应用,可以增加可用的桌面或桌下空间。
封装信息:包装包括DWM2655M全动态平板壁挂支架、安装硬件和用户手册。
DWM2655M 价格&库存
很抱歉,暂时无法提供与“DWM2655M”相匹配的价格&库存,您可以联系我们找货
