Technical Data ELX1093
Effective September 2021
ECMT1V20
Common mode choke, through-hole
Applications
Product features
Closed magnetic path reduces conductive
EMI emission
High impedance and inductance values
Robust construction
High voltage isolation
Independent winding sections
Rated voltage: 250 Vac
Industrial IoT equipment
Motion controls
Power supplies
Battery backup
Renewable energy products
Smart meters
Solar/wind generators, inverters,
charger controllers
Medical equipment
High tech consumer products
Appliances
Environmental compliance and general
specifications
Storage temperature range (Component):
-40 °C to +85 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Wave solder temperature: +260 °C maximum
HALOGEN
Pb HF
FREE
ECMT1V20
Product specifications
Part number7
OCL1 (mH)
minimum
(1-2), (4-3)
DCR2 (Ω)
maximum
(1-2), (4-3)
@ +25 °C
Irms3 (A)
(1-4) short 2,3
SRF (kHz)
minimum
Hi-pot4
(Vac)
Hi-pot5
(Vac)
Insulation resistance6
(MΩ) minimum
ECMT1V2023S-2R0-R
2.0
0.08
1.5
976
1500
1000
100
ECMT1V2017H-2R0-R
2.0
0.08
1.5
976
1500
1000
100
ECMT1V2023S-200-R
1.0
245
1500
1000
100
ECMT1V2017H-200-R
1.0
245
1500
1000
100
ECMT1V2023S-300-R
30
0.9
0.8
160
1500
1000
100
ECMT1V2017H-300-R
30
0.9
0.8
160
1500
1000
100
ECMT1V2023S-600-R
60
2.1
0.4
96
1500
1000
100
ECMT1V2017H-600-R
60
2.1
0.4
96
1500
1000
100
1. Open circuit inductance (OCL) Test parameters: 1 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. DCR Test parameters: 4-wire method measured from the root of base, +25 °C
3. Irms: Maximum DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for
AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will
affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case
operating conditions verified in the end application.
2
www.eaton.com/electronics
4. Hi-pot: Coil-Coil, 2 seconds, 5 mA
5. Hi-pot: Coil-Core, 2 seconds, 5 mA
6. Insulation Resistance: Coil-Coil and Coil-Core, at 500 Vdc
7. Part Number Definition: ECMT1Vxxxxy-zzz-R
ECMT1V = Product code
xxxx= Size indicator
y= Orientation H= horizontal, S= vertical
zzz=Inductance value in mH, R= decimal point, If no R is present last digit indicates number of zeros
-R= RoHS compliant
ECMT1V20
Mechanical parameters, schematic, pad layout (mm)
ECMT1V2023S-xxx-R
Recommended PCB layout
Schematic
ECMT1V2017H-xxx-R
Schematic
Part number
A
B
C
D
E
F
G
ECMT1V2023S-xxx-R
17.5 max.
20.0 max.
23.0 max.
3.5 ± 0.5
10.0 ± 0.5
13.0 ± 0.5
0.7 ± 0.1
ECMT1V2017H-xxx-R
19.5 max.
19.5 max.
17.0 max.
3.5 ± 0.5
10.0 ± 0.5
13.0 ± 0.5
0.7 ± 0.1
Part marking: xxx-wwyy, xxx =inductance value in mH, wwyy= lot code
Traces or vias underneath the inductor is not recommended
3
ECMT1V20
Packaging information (mm)
ECMT1V2023S-xxx-R
Supplied in tray, 10 trays per carton. (81 parts per tray x 10 trays per box = 810 parts per carton)
(Tray height 22 mm)
ECMT1V2017H-xxx-R
Supplied in tray, 10 trays per carton. (99 parts per tray x 10 trays per box = 990 parts per carton)
(Tray height 24 mm)
4
ECMT1V20
Impedance vs frequency
Measurement method
5
Inductance vs frequency
6
ECMT1V20
ECMT1V20
Wave solder profile
Reference EN 61760-1:2006
Profile feature
Preheat
Standard SnPb solder
Lead (Pb) free solder
• Temperature min. (Tsmin)
100 °C
100 °C
• Temperature typ. (Tstyp)
120 °C
120 °C
• Temperature max. (Tsmax)
130 °C
130 °C
• Time (Tsmin to Tsmax) (ts)
70 seconds
70 seconds
D preheat to max Temperature
150 °C max.
150 °C max.
Peak temperature (TP)*
235 °C – 260 °C
250 °C – 260 °C
Time at peak temperature (tp)
10 seconds max
5 seconds max each wave
10 seconds max
Ramp-down rate
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
~ 2 K/s min
~3.5 K/s typ
~5 K/s max
Time 25 °C to 25 °C
4 minutes
4 minutes
Manual solder
+350 °C, 4-5 seconds. (by soldering iron), generally manual, hand soldering is not recommended.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2021 Eaton
All Rights Reserved
Printed in USA
Publication No. ELX1093 BU-ELX21103
September 2021
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“ECMT1V2017H-2R0-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 75+12.41746
- 200+12.23610
- 400+11.97010
- 750+11.78873
- 990+11.52273
