EMR6-I1-A-1
EMR6-I1-A-1
    EATON(伊顿)
    EATON MOELLER - EMR6-I1-A-1 - CURRENT MONITORING RELAY, DPDT, 0.003-1A
EMR6-I1-A-1 数据手册
EMR6 EMT6 ETR4 www.eaton.eu Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays The measuring and monitoring of industrial applications made simple - with the EMR6 With the new EMR6 devices, the existing range of the ETR4 / EMR5 measuring relays is being updated to reflect the latest technology. The EMR6 series will seamlessly replace and even expand the existing product range. The EMR6 measuring and monitoring relays are designed for a wide range of switchgear applications. Thanks to their ability to monitor overloads, power fluctuations, phase sequences, machine temperatures and fill levels, the EMR6 relays protect machines and plants and help to prevent unscheduled downtime in production processes. The device has been approved for global use and can therefore be used to monitor plants reliably and seamlessly, anywhere in the world. The EMR6 is available in the following versions: 2 • Phase sequence relay • Phase imbalance monitoring relay • Multi-function relay • Current monitoring relay • Voltage monitoring relay • Insulation-monitoring relay • Level relay • Temperature relay EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays The next generation At a glance With the new EMR6 product line, Eaton’s existing range of EMR4 / EMR5 measuring relays is being updated to reflect the latest technology. ✓ Suitable for universal use, thanks to multi-voltage power supplies ✓ Reduced machine downtime and early detection of possible failures during operation ✓ The universal, multi-functional devices reduce inventory costs and save time during the equipment selection process ✓ An expanded product range with additional functionalities ✓ Relays for monitoring machine temperatures The new enclosure design of the EMR6 is based on that of our existing relay portfolio (EMT6 / ETR4). The EMR6 completely replaces the existing product range, consisting of the EMR4 and EMR5 devices. In addition to replacing the existing series, the launch of nine new relay types with additional functionalities (for monitoring current, voltage and temperature) will expand Eaton’s product range to 35 devices. The EMR4 / EMR5 series will be fully replaced by the end of February 2019. Name Article no. Will replace Name Article no. EMR6-F500-G-1 184789 1:1 Replacement EMR4-F500-2 221784 EMR6-I1-A-1 184790 1:1 Replacement EMR4-I1-1-A 106942 EMR6-I15-A-1 184754 1:1 Replacement EMR4-I15-1-A 106943 EMR6-I15-B-1 184755 1:1 Replacement EMR4-I15-1-B 106944 EMR6-N1000-N-1 184756 1:1 Replacement EMR4-N100-1-B 221789 EMR4-N500-2-A 221791 EMR6-N1000-A-1 184757 Consolidation of two types EMR4-N500-2-B 221790 EMR6-N100-N-1 184758 1:1 Replacement EMR4-N080-1-B 134232 EMR6-PH22 184759 Suitable only for EMR6 EMR4-PH22 221794 EMR6-PH45 184760 Suitable only for EMR6 EMR4-PH45 221795 EMR6-A300-C-1 184761 1:1 Replacement EMR5-A300-1-C 134230 EMR6-A500-D-1 184762 1:1 Replacement EMR5-A400-1 134222 EMR6-AW300-C-1 184763 1:1 Replacement EMR5-AW300-1-C 134223 EMR6-AW500-D-1 184764 1:1 Replacement EMR5-AW500-1-D 134224 EMR6-AWM580-H-1 184765 1:1 Replacement EMR5-AWM580-2 134235 EMR6-AWM720-I-1 184766 1:1 Replacement EMR5-AWM720-2 134236 EMR6-AWM820-J-1 184767 1:1 Replacement EMR5-AWM820-2 134237 EMR6-AWN170-E-1 184768 1:1 Replacement EMR5-AWN170-1-E 134225 EMR6-AWN280-K-1 184769 1:1 Replacement EMR5-AWN280-1 134233 EMR6-AWN280-D-1 184770 1:1 Replacement EMR5-AWN280-1-F 134226 EMR6-AWN500-D-1 184771 1:1 Replacement EMR5-AWN500-1 134234 EMR6-R250-A-1 184772 1:1 Replacement EMR5-R250-1-A 153442 EMR6-R400-A-1 184773 1:1 Replacement EMR5-R400-1-A 153443 EMR6-R400-A-2 184774 1:1 Replacement EMR5-R400-2-A 153444 EMR6-RC690 184775 1:1 Replacement EMR5-RC690 153445 EMR6-W300-C-1 184776 1:1 Replacement EMR5-W300-1-C 134227 EMR6-W380-L-1 184777 1:1 Replacement EMR5-W380-1 134228 EMR6-W400-M-1 184778 1:1 Replacement EMR5-W400-1 134229 EMR6-W500-D-1 184779 1:1 Replacement EMR5-W500-1-D 134221 Extension of the product range EMR6-IM1-A-1 184780 NEW EMR6-IM15-A-1 184781 NEW EMR6-IF1-A-1 184782 NEW EMR6-IF15-A-1 184783 NEW EMR6-VM600-A-1 184784 NEW EMR6-VF600-A-1 184785 NEW EMR6-T50-A-1 184786 NEW EMR6-T100-A-1 184787 NEW EMR6-T200-A-1 184788 NEW EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays 3 Three-phase measuring relays Single-phase measuring relays For the monitoring of... For the monitoring of... • Phase imbalances • Voltage • Over-voltage and under-voltage • Voltage windows • Voltage • Over-voltage and under-voltage • Voltage windows Currents • Phase failure • Over-current and under-current • Phase sequences • Current windows • Cable breaks Features: Features: • Adjustable ON- and OFF-delay • Three or four measurement ranges in one device • Power supply via the measuring circuit • Power supply via the measuring circuit Applications: Applications: • Monitoring the operating direction of conveyor belt motors • Measuring the current consumption of motors, e.g. that of pumps, elevators or cranes • Detection of overloads and phase imbalances in voltage-sensitive machines and plants • Monitoring of electrical systems, e.g. lighting circuits, heating circuits or charging stations • Activation of emergency or backup power supplies in case of under-voltage or phase failure • Monitoring the supply minimum for emergency lighting systems • Monitoring the rated voltage of portable / mobile three-phase loads • Detection of overloads in DC motors • Monitoring of screw conveyors, e.g. those used in wastewater treatment plants • Detection of overload situations in hoisting gear and handling equipment • Monitoring of locking devices or of impacts on end stops Protection of… • 4 • Three-phase motors against phase failure and phase change • Transformers through the detection of asymmetric loads • Personnel and equipment during rotation reversal • Consumer loads against destruction in the case of unstable power supplies • Motors against destruction in the case of phase imbalance and phase failure Protection against… • Voltage drops in sensitive or essential systems • Damage to or destruction of individual loads in the case of overload or over-current • Deviations from standard operating sequences EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays Level relays Temperature relays For the monitoring of... For the monitoring of... • Fill levels • Mixing ratios • Features: • Temperatures in machine or plant environments Applications: For the monitoring of... • Temperatures that are too high or too low • Insulation resistance in ungrounded it networks • Temperature windows • Cable breaks Features: Adjustable ON- and OFF-delay to prevent the device from triggering due to temporary fill-level fluctuations Insulation-monitoring relays • Adjustable hysteresis, 2 - 20 % • Short-circuit and open-circuit monitoring Applications: Features: • Test or reset function either via a button on the device, or via the control input • Configurable fault memory / memory function Applications: • Measuring of fill levels in production tanks • Monitoring the operating temperatures of machines and plants • Monitoring of power networks in hospitals • Monitoring of mixing rations of conductive liquids • Analyzing the data provided by the PT100 temperature sensors • Monitoring of renewable energy systems such as wind or solar facilities • Monitoring of overflow or dry-running in liquid storage tanks • • Monitoring of ship networks • • Monitoring of applications that rely on filling and draining Control of heating and cooling units in order to keep the temperature within a pre-defined range Monitoring the power supplies of crane systems Functionality: Functionality: • Fill-level monitoring relays report the fill levels of conductive liquids or any changes in electrical resistance. • In the case of conductive fill-level monitoring, the relays detect to what extent the sensor rods are covered by water. The resistance changes if the sensors are wetted when immersed in the medium. • To detect, report and regulate the temperature, the PT100 sensors are immersed in the medium, which can be solid, liquid or gaseous. • The relay then processes the feeler data to check if temperatures exceed or undershoot the pre-defined parameters. • In addition, output relays make it possible to further regulate the temperature. Functionality: • To this end, the relay measures the insulation resistance between the network conductors and the signal ground. If the value falls below the pre-defined adjustable threshold, the output relay will drop off. EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays 5 Reliable protection against over-temperature - EMT6 thermistor overload relays for machine protection The EMT6 thermistor relay protects machines against over-temperature caused by heavy starting duties, braking, under-voltage, over-voltage, and high switching frequencies. The temperature is monitored by means of a thermistor directly at the motor winding. In the event of over-temperature, the corresponding signal is relayed to the EMT6 unit. Once the unit receives the signal, it trips, and the fault signal can be reliably detected in the corresponding control cabinet. The EMT6 is also suitable for monitoring the temperatures of motor bearings, gearboxes, oils and coolants. In addition, depending on the model, additional functionalities are available, including zero-voltage protection, short-circuit monitoring, and the ability to choose between automatic and manual switch-off. All relays have UL/CSA approval and are suitable for global use in line with IEC/EN standards. 6 EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays Function tests The functionality of the relay needs to be tested on a regular basis, both during commissioning and maintenance. To make this as easy as possible, all EMT6 models feature an integrated test button that can be used to simulate an error condition. Sample application: Tripping in case of over-temperature due to overload N PTC L1 A1 21 22 13 T1 14 T2 A2 Two sensor circuits for enhanced functionality The EMT6 product line also includes the option to install two separate sensor circuits. These two-circuit models make it possible to monitor the temperature at two different points – either on a single motor or on two separate motors – in a cost-effective and space-saving manner. This not only means that multiple motors can be monitored simultaneously with a single device, but also that these devices can be used to implement a cost-effective early warning system, by monitoring two sensor circuits with different triggering temperatures. N PTC L1 A1 21 22 13 14 T1 T2 A2 EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays 7 Flexible planning thanks to a broad range of possible solutions – the ETR4 and ETR2 timing relays The design of the ETR4 timing relays is based on that of our measuring and monitoring relays and our safety relays. As a result, they save space inside the control cabinet and lend a uniform design appearance to your entire system. The ETR2 is a compact timing relay specifically for use in installation cabinets. Two supply voltages are available: a multi-voltage model with 24 - 240 V AC / V DC, and a single-voltage model with 400 V AC. This reduces inventory costs while enhancing flexibility. Depending on the application at hand, you can choose between single-function and multi-function relays. The timing relays cover a total of 10 different functions. All relays have UL/CSA approval and are suitable for global use in line with DIN EN 61812-1. 8 EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays Precise settings along a wide time spectrum Whether you are dealing with short signal extensions or extremely long processes: our multi-range time delay relays allow you to choose the right interval, from 0.05 seconds to 100 hours. First, a time range has to be selected, using the "Range" indicator. The specific interval can then be set using the "Time" indicator. This way, the time is set directly on the device, so that the scale shows the "actual” time. Sample application: Coordinated timing Universal applications N L1 A1 15 B1 16 18 A2 Time Whether your application involves conveyor belts, fan controls, or escalator control systems – the ETR4 timing relays offer maximum reliability across a broad range of applications. In fact, Eaton’s ETR4 devices are the ideal choice for any application that requires reliable switching with highly precise time delays. With their sleek design and wide voltage range, they are also the perfect option for manufacturers of control cabinets, switchgear systems, or control systems. Moreover, their broad range of up to 10 functions (in case of the multi-function models) ensures that all important time sequences can be covered by a single device, thereby minimizing inventory even where applications vary. N L1 A1 15 B1 16 18 A2 Time EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays 9 Phase sequence relay Phase failure Imbalance Overvoltage Undervoltage Neutral cable break EMR6 measuring and monitoring relays Monitoring voltage per phase X X - - - - 200 - 500 V AC 50/60 Hz 200 - 500 V AC 50/60 Hz EMR6-F500-G-1 184789 X X X - - - 160 - 300 V AC 50/60 Hz 160 - 300 V AC 50/60 Hz EMR6-A300-C-1 184761 X X X - - - 300 - 500 V AC 50/60 Hz 300 - 500 V AC 50/60 Hz EMR6-A500-D-1 184762 On- and Off-delayed X X - X X - 160 - 300 V AC 50/60 Hz 160 - 300 V AC 50/60 Hz EMR6-W300-C-1 184776 On- and Off-delayed X X - X X - 300 - 500 V AC 50/60 Hz 300 - 500 V AC 50/60 Hz EMR6-W500-D-1 184779 On- and Off-delayed X X - X X - 380 V AC 50/60 Hz 380 V AC 50/60 Hz EMR6-W380-L-1 184777 On- and Off-delayed X X - X X - 400 V AC 50/60 Hz 400 V AC 50/60 Hz EMR6-W400-M-1 184778 X X X X X - 160 - 300 V AC 50/60 Hz 160 - 300 V AC 50/60 Hz EMR6-AW300-C-1 184763 X X X X X - 300 - 500 V AC 50/60 Hz 300 - 500 V AC 50/60 Hz EMR6-AW500-D-1 184764 X X X X X X 90 - 170 V AC 50/60 Hz 90 - 170 V AC 50/60 Hz EMR6-AWN170-D-1 184768 X X X X X X 180 - 280 V AC 50/60 Hz 180 - 280 V AC 50/60 Hz EMR6-AWN280-D-1 184770 X X X X X X 180 - 280 V AC 50/60/400 Hz 180 - 280 V AC 50/60/400 Hz EMR6-AWN280-K-1 184769 X X X X X X 300 - 500 V AC 50/60 Hz 300 - 500 V AC 50/60 Hz EMR6-AWN500-D-1 184771 Automatic phase sequence correction X X X X X X 350 - 580 V AC 50/60 Hz 350 - 580 V AC 50/60 Hz EMR6-AWM580-H-1 184765 Automatic phase sequence correction X X X X X X 450 - 720 V AC 50/60 Hz 450 - 720 V AC 50/60 Hz EMR6-AWM720-I-1 184766 Automatic phase sequence correction X X X X X X 530 - 820 V AC 50/60 Hz 530 - 820 V AC 50/60 Hz EMR6-AWM820-J-1 184767 Measuring range 3-30, 6-60, 30-300, 60-600 V - - - X X - Single phase 24 - 240 V 50/60 Hz AC/DC EMR6-VM600-A-1 184784 Measuring range 3-30, 6-60, 30-300, 60-600 V - - - X X - Single phase 24 - 240 V 50/60 Hz AC/DC EMR6-VF600-A-1 184785 Measuring range 3-30 mA; 10-100 mA; 0.1-1 A Single phase 24 - 240 V 50/60 Hz AC/DC EMR6-I1-A-1 184790 Measuring range 0.3-1.5 A; 1-5 A; 3-15 A Single phase 24 - 240 V 50/60 Hz AC/DC EMR6-I15-A-1 184754 Measuring range 0.3-1.5 A; 1-5 A; 3-15 A Single phase 24 - 240 V AC 50/60 Hz EMR6-I15-B-1 184755 Measuring range 3-30 mA; 10-100 mA; 0.1-1 A Single phase 24 - 240 V 50/60 Hz AC/DC EMR6-IM1-A-1 184780 Measuring range 0.3-1.5 A; 1-5 A; 3-15 A Single phase 24 - 240 V 50/60 Hz AC/DC EMR6-IM15-A-1 184781 Measuring range 3-30 mA; 10-100 mA; 0.1-1 A Single phase 24 - 240 V 50/60 Hz AC/DC EMR6-IF1-A-1 184782 Measuring range 0.3-1.5 A; 1-5 A; 3-15 A Single phase 24 - 240 V 50/60 Hz AC/DC EMR6-IF15-A-1 184783 On- and Off-delayed Response value 0.1 - 1000 kOhm 220 - 240 V 50/60 Hz AC EMR6-N1000-N-1 184756 On- and Off-delayed Response value 0.1 - 1000 kOhm 220 - 240 V 50/60 Hz AC EMR6-N1000-A-1 184757 On- and Off-delayed Response value 5 - 100 kOhm 24 - 240 V 50/60 Hz AC/DC EMR6-N100-N-1 184758 Monitoring of Supply voltage Part no. Article no. Phase sequence relay Phase imbalance monitoring relay Mulit-functional phase monitoring relay Automatic phase sequence correction Voltage monitoring relay Current monitoring relay Level monitoring relay 10 EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays EMR6 measuring and monitoring relays Insulation monitoring relay Insulation resistance in non-earthed AC supply systems Monitoring voltage per phase Supply voltage Part no. Article no. Response value 1 - 110 kOhm 24 - 240 V 13.5 - 400 Hz AC/DC EMR6-R250-A-1 184772 Response value 1 - 110 kOhm 24 - 240 V 13.5 - 400 Hz AC/DC EMR6-R400-A-1 184773 1 - 110 kOhm or 2 - 200 kOhm 24 - 240 V 13.5 - 400 Hz AC/DC EMR6-R400-A-2 184774 --- EMR6-RC690 184775 Extension of the measuring range to 690 V AC and 1000 V DC Temperature monitonring relay Measuring range -50 - +50 °C PT100 - Sensor 24 - 240 V 50/60 Hz AC/DC EMR6-T50-A-1 184786 Measuring range 0 - +100 °C PT100 - Sensor 24 - 240 V 50/60 Hz AC/DC EMR6-T100-A-1 184787 Measuring range 0 - +200 °C PT100 - Sensor 24 - 240 V 50/60 Hz AC/DC EMR6-T200-A-1 184788 Accessories Part no. Article no. Sealable shroud 22.5 mm EMR6-PH22 184759 Sealable shroud 45 mm EMR6-PH45 184760 EMR6 Dimensions 68.5 85.6 22.5 45 68.5 113.2 105.7 5.5 1 103.7 22.5 20 45 EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays 20 11 EMT6 thermistor overload relays for machine protection Part no. Article no. Thermistor overload relays Without manual reset, Mains and fault LED display EMT6 066166 Without manual reset, Mains and fault LED display, With 2 sensor circuits EMT62 171889 Without manual reset, Mains and fault LED display, Trips with short-circuit in the sensor cable EMT6-K 269470 Selector switch with/without manual reset, for manual or remote resetting, Test button, Mains and fault LED display EMT6-DB 066167 Selector switch with/without manual reset, for manual or remote resetting, Test button, Mains and fault LED display, with 2 sensor circuits EMT62-DB 171890 Selector switch with/without manual reset, for manual or remote resetting, Test button, Mains and fault LED display, Trip with short-circuit in the sensor cable EMT6-KDB 269471 Multifunction device, selector switch with/without manual reset, for manual or remote resetting, test button, Mains and fault LED display, Trip with short-circuit in the sensor cable, zero-voltage safe, short-circuit recognition and zero-voltage safety can be deactivated EMT6-DBK 066168 Accessories Part no. Article no. Screw adapter for screw fastening CS-TE 095853 Documentation: Overload monitoring of machines in EX e-area MN03407006Z-DE/EN 151983 EMT6 78 Dimensions 22.5 102 >_ 3 12 EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays EMT6 (230 V) 066400 EMT6-DB (230 V) 066401 Off-delayed Flashing, pulse initiating On- and Off-delayed Pulse forming Pulse generating Star-delta switching Flashing, pause initiating ETR4 Changeover contact with a changeover time of 50 ms - - - - - - - - - X - 3 - 60 s 1 EMR6-F500-G-1 184789 ETR4-51-W 031885 Fixed timing function X - - - - - - - - - - 0.05 s - 100 h 1 ETR4-11-A 031882 ETR4-11-W 031883 Adjustable timing functions X X X X X X X X X - - 0.05 s - 100 h 1 ETR4-69-A 031891 ETR4-69-W 031887 With connection of potentiometer, Changeover contact can be converted X X X X X X X X X - - 0.05 s - 100 h 2 ETR4-70-A 031888 Fleeting contact on de-energization Multi-functional Time range Funktion Fleeting contact on energization On-delayed ETR Timing relay Number of changeover contacts Part no. Article no. 24 - 240 V 50/60 Hz AC/DC 400 V 50/60 Hz AC 12 - 240 V 24 - 240 V 50/60 Hz AC/DC ETR2 Fixed timing function X - - - - - - - - - - 0.05 s - 100 h 1 ETR2-11 262684 Fixed timing function X - - - - - - - - - - 0.05 s - 100 h 2 ETR2-11-D 119426 Fixed timing function - - X - - - - - - - - 0.05 s - 100 h 1 ETR2-12 262686 Fixed timing function - - X - - - - - - - - 0.05 s - 100 h 2 ETR2-12-D 119427 Fixed timing function - - - X - - - - - - - 0.05 s - 100 h 1 ETR2-21 262687 Fixed timing function - - - - - X - - - - - 0.05 s - 100 h 1 ETR2-42 262688 Pulse and pause times independently - - - - - X - - - - X 0.05 s - 100 h 1 ETR2-44 262730 Adjustable timing functions X X X X X X - X - - X 0.05 s - 100 h 1 ETR2-69 262689 Adjustable timing functions X X X X X X - X - - X 0.05 s - 100 h 2 ETR2-69-D 119428 Dimensions ETR4-… ETR2-… ETR2-…D 43.4 103 80 45 70 78 82.5 45 98 22.5 17.5 5 43.4 17.5 5 58 58 EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays 13 Technical Data EMR6 Measuring and monitoring relays Measuring and monitoring relays Standards EMR6-I EMR6-V EMR6-N EMR6-R EMR6-A EMR6-F EMR6-W EMR6-T UL 508, CAN/CSA C22.2 No.14, GL, EAC, CCC, RMRS, RCM UL 508, CAN/CSA C22.2 No.14, GL, EAC, CCC, RMRS, RCM IEC/EN 60255-6, EN 61557, UL, CSA, GL, DNV, RMRS, EAC, RCM IEC/EN 60255-6, EN 61557, UL, CSA, GL IEC, UL, CSA, CCC, GL IEC/EN 60255-6, EN 61557, UL, CSA, GL IEC, UL, CSA, CCC, GL UL 508, CAN/CSA 22.2 No.14, EAC, CCC, GL, CE Ambient temperature Operating temperatur -25 - +60 °C -25 - +60 °C -25 - +60 °C -25 - +60 °C -25 - +60 °C -25 - +60 °C -25 - +60 °C -40 - +60 °C Storage temperatur -40 - +85 °C -40 - +85 °C -40 - +85 °C -40 - +85 °C -40 - +85 °C -40 - +85 °C -40 - +85 °C -40 - +85 °C Mounting position as required as required as required as required as required as required as required as required Shock resistance Class 2 Class 2 Class 2 Class 2 Class 2 Class 2 Class 2 Class 2 Degree of protection Terminals IP20 IP20 IP20 IP20 IP20 IP20 IP20 IP20 Housing IP50 IP50 IP50 IP50 IP50 IP50 IP50 IP50 Terminal capacities Solid 1 x 0.5 - 2.5 mm² (1 x 18 - 14 AWG) Flexible with ferrule 2 x 0.5 - 1.5 mm² (2 x 18 - 16 AWG) Pick-up voltage 0.6 - 0.8 Nm Rated impulse withstand voltage 4000 V AC Overvoltage category/ pollution degree III/3 Voltage tolerance 0.85 - 1.1 x Uc Duty factor 100 % DF Lifespan Electrical 0.1 x 10^6 Operations Mechanical 30 x 10^6 Operations Power consumption 2.6 VA 2.6 VA 2.6 VA 3.5 VA Datasheet 11 VA 10 / 18 VA 2.9 VA Rated operational current 250 V AC 500 V AC 400 V AC 250 V AC / 300 V DC 250 V AC 250 V AC 250 V AC 250 V AC / 300 V DC On-delay IF 0; 0.1 - 30 s IM 0; 0.1 - 30 s VF 0; 0.1 - 30 s VM 0; 0.1 - 30 s --- --- 0.2 s --- 0.2 s --- Off-delay I 0; 0.1 - 30 s IF 0; 0.1 - 30 s IM 0; 0.1 - 30 s --- --- 0; 0.1 - 30 s --- 0; 0.1 - 30 s --- Monitoring / Measuring ..1.. 0 - 0.03 A 0.01 - 0.1 A 0.1 - 1 A ..15.. 0.3 - 1.5 A 1-5A 3 - 15 A …100… 5 - 100 kΩ …1000… 0.1 1000 kΩ ...-A-1 1 - 100 kΩ …-A-2 1 - 100 kΩ 2 - 200 kΩ 90 - 170 V 180 - 280 V 300 - 500 V 350 - 580 V 450 - 720 V 530 - 820 V 200 - 500 V AC ...-W300 160 - 300 V …-W500 300 - 500 V …-W380 380 V …-W400 400 V …-T50 -50 - + 50 °C …-T100 0 - +100 °C …-T200 0 - +200 °C 3 - 30 V 6 - 60 V 30 - 300 V 60 - 600 V Measuring sensor B1 - Reference B2 - Maximum B3 - Minimal Pt 100 Hysteresis I 3 - 30 % IF 5 % IM 3 - 30 % VM 3 - 30 % VF 5 % --- 25 % A AW AWM AWN 20 % 5/20 % 5/20 % 5/20 % Dimensions (Width x Height x Depth) 22.5 x 85.6 x 103.7 mm 22.5 x 85.6 x 103.7 mm 22.5 x 85.6 x 103.7 mm …-A-1 22.5 x 85.6 x 103.7 mm …-A-2 / RC 45 x 85.6 x 103.7 mm …-A / AW 22.5 x 85.6 x 103.7 mm …-AWM 45 x 85.6 x 103.7 mm --- 5% 2 - 20 % 22.5 x 85.6 x 103.7 mm 22.5 x 85.6 x 103.7 mm 22.5 x 85.6 x 103.7 mm Weight 0.152 kg 0.155 kg 0.14 - 0.15 kg 0.14 - 0.24 kg 0.13 - 0.23 kg 0.128 kg 0.139 kg 0.151 kg Status-LEDs I (red) - Failure R (yellow) - Relay status U/T (green) - Supply voltage. U (red) - Failure R (yellow) - Relay status U/T (green) - Supply voltage. Min/max (green) Min + Max wetted R (yellow) - Relay status U (green) Supply voltage. F (red) - Failure R (yellow) - No Failure U (green) Supply voltage. Pleasee see IL's F (yellow) - Relay status R (red) Failure R/T (yellow) Relay status F1/F2 (red) - Failure T (red) - Failure R (yellow) - Relay status U (green) Supply voltage. Electromagnetic compatibility Interference immunity EC/EN 61000-6-2 Electrostatic discharge IEC/EN 61000-4-2 Electromagnetic fields IEC/EN 61000-4-3 Fast transients (Burst) IEC/EN 61000-4-4 Power pulses (Surge) IEC/EN 61000-4-5 Cable-borne HF IEC/EN 61000-4-6 Level 3 (6 kV / 8 kV) Level 3 (10 V/m) Level 3 (2 kV / 2 kHz) Level 4 (2 kV) Level 3 (10 V) Interference emission Class 3 Electromagnetic fields IEC/EN 61000-6-3 IEC/CISPR 22, EN 55022 Class B Cable-borne HF IEC/CISPR 22, EN 55022 Class B 14 EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays Technical Data EMT6 thermistor overload relays for machine protection Thermistor overload relays for machine protection EMT6 General Standards and Climatic proofing IEC/EN 60947, VDE 0660, EN 55011 Damp heat, constant, to IEC 60068-2-78; Damp heat, cyclic, to IEC 60068-2-30 Ambient temperature Open -25 - +60 °C Enclosed -25 - +45 °C Storage -45 - +60 °C Mounting position as required Weight 0.15 kg Mechanical shock resistance half-sinusoidal shock 10 ms to IEC 60068-2-27 10 g Protection against direct contact when actuated from front (EN 50274) IP20, Finger and back-of-hand proof Safe isolation to EN 61140 Between the contacts 250 V AC Between contacts and power supply 250 V AC Auxiliary and control circuits Rated impulse withstand voltage 6000 V AC Overvoltage category/pollution degree III/3 Terminal capacities Auxiliary and control circuits Solid 1 x 2.5 mm² 2 x (0.5 - 1.5) mm² Flexible with ferrule 1 x 2.5 mm² 2 x (0.5 - 1.5) mm² Solid or stranded 20 - 14 AWG Terminal screw M3.5 Tightening torque 1.2 Nm Tools Pozidriv screwdriver Size 2 Standard screwdriver 1 x 6 mm Auxiliary power circuit Rated insulation voltage 400 V Rated operational current AC-14, N/O, 415 V Ie 3A AC-14, N/C, 415 V le 3A AC-15, N/O, 240 V Ie 3A AC-15, N/O, 415 V Ie 1A AC-15, N/C, 415 V Ie 3A AC-15, N/C, 240 V Ie 1A Max. short-circuit protective device Fuse gG/gL 6A Control circuit Rated insulation voltage 240 V Rated operational voltage 240 V (EMT6(-DB)230V: Ue = 230 V) Pick-up and drop-out values 0.85 - 1.1 x Uc Power consumption AC 3.5 VA DC 2W Trip at approx. Recovery at approx. ≧3600 Ω ≦1600 Ω EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays 15 Technical Data ETR Timing Relay Timing relay ETR2-11 (12, 21, 42, 44, 69) ETR2-69-D ETR2-11-D / ETR2-12-D ETR4-A ETR4-W Standards IEC/EN 61812 VDE 0435 IEC/EN 61812 VDE 0435 Lifespan, mechanical 30 x 10^6 30 x 10^6 30 x 10^6 30 x 10^6 30 x 10^6 Lifespan, electrical 0.1 x 10^6 0.1 x 10^6 0.1 x 10^6 0.1 x 10^6 0.1 x 10^6 General Climatic proofing IEC 61812-1, EN 61812-1 + A11, DIN VDE 0435 Teil 2021 Damp heat, constant, to IEC 60068-2-78; Damp heat, cyclic, to IEC 60068-2-30 Ambient temperature Ambient temperature, storage -45 - +60 °C -45 - +60 °C -40 - +85 °C -40 - +85 °C -40 - +85 °C Open -25 - +60 °C -25 - +60 °C -20 - +60 °C -20 - +60 °C -20 - +60 °C Enclosed -25 - +45 °C -25 - +45 °C Mounting position as required as required as required as required as required Mechanical shock resistance (IEC/EN 60068-227) Half-sinusoidal shock, 20 ms Make contact 4g 4g 10 g 10 g 10 g Degree of protection Terminals IP20 IP20 IP20 IP20 IP20 Weight 0.1 kg 0.1 kg 0.06 kg 0.065 kg 0.065 kg 1 x (0.75 - 2.5) mm² 1 x (0.75 - 2.5) mm² 1 x (0.5 - 2.5) mm² 1 x (0.5 - 2.5) mm² 1 x (0.5 - 2.5) mm² 2 x (0.75 - 1.5) mm² 2 x (0.75 - 1.5) mm² 2 x (0.5 - 1.5) mm² 3 x (0.5 - 1.5) mm² 4 x (0.5 - 1.5) mm² 1 x (0.75 - 2.5) mm² 1 x (0.75 - 2.5) mm² 1 x (0.5 - 4) mm² 1 x (0.5 - 4) mm² 1 x (0.5 - 4) mm² 2 x (0.75 - 1.5) mm² 2 x (0.75 - 1.5) mm² 2 x (0.5 - 1.5) mm² 2 x (0.5 - 1.5) mm² 2 x (0.5 - 1.5) mm² 1 x (20 - 14) AWG 1 x (20 - 14) AWG 2 x (20 - 14) AWG 2 x (20 - 14) AWG 2 x (20 - 14) AWG Terminal capacities Solid Flexible with ferrule Solid or stranded Contacts Rated impulse withstand voltage Uimp Overvoltage category/pollution degree 6000 V AC 6000 V AC 4000 V AC; 12/15 μs 4000 V AC; 12/15 µs 4000 V AC; 12/15 µs III/2 III/2 III/3 III/3 III/3 Rated insulation voltage Ui 600 V AC 600 V AC 300 V AC 300 V AC 300 V AC Rated operational voltage Ue 440 V AC 440 V AC 300 V AC 300 V AC 300 V AC Between coil and auxiliary contacts 250 V AC 250 V AC 250 V AC 250 V AC 250 V AC Between the auxiliary contacts 250 V AC 250 V AC 250 V AC 250 V AC 250 V AC 48 A 48 A 50 A 50 A 1.1 x Ie 1.1 x Ie 3A 3A Safe isolation to EN 61140 Making capacity AC-14 cos ϕ = 0.3 440 V AC-15 cos ϕ = 0.3 220 V DC-11 L/R ≦ 40 ms Breaking capacity AC-14 cos ϕ = 0.3 440 V AC-15 cos ϕ = 0.3 220 V DC-11 L/R ≦ 40 ms 3A 3A 1.1 x Ie 1.1 x Ie Rated operational current AC-12 230 V Ie 6A 5A 5A 3A 3A 3A 3A 3A 3A 0.75 A 0.75 A DC12 24 V 6A 5A 5A DC13 24 V N/O 2A 3A 3A DC13 24 V N/C 2A 1A 1A AC-14 440 V Ie 3A 3A AC-15 220 V (230 V) N/O Ie 3A AC-15 220 V (230 V) N/C Ie 3A 1.5 A 1.5 A 1.2 A 1.2 A (DC-111) L/R max. 15 ms, 24 V Ie L/R max. 50 ms Ie Conv. thermal current Ith 6A 6A 5A 5A 5A AC-operated 250 V 250 V 300 V 300 V 300 V 6A 6A 5A 5A 5A B300 B300 B300 B300 B300 Pilot Duty / AC-operated 16 EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays ETR4-A ETR4-W ETR2-11 (12, 21, 42, 44, 69) ETR2-69-D ETR2-11-D / ETR2-12-D Max. fuse, make contacts 6 A gG/gL 6 A gG/gL 10 A gG/gL 10 A gG/gL 10 A gG/gL Max. fuse, break contacts 6 A gG/gL 6 A gG/gL 6 A gG/gL 6 A gG/gL 6 A gG/gL Max. overcurrent protective device, 220/230 V FAZ-B4/1-HI FAZ-B4/1-HI AC 24 - 240 400 24 - 240 12 - 240 24 - 240 DC 24 - 240 - 24 - 48 12 - 240 24 - 48 47 - 63 Hz 47 - 63 Hz DC / 47 - 63 Hz DC / 47 - 63 Hz DC / 47 - 63 Hz AC-operated 0.85 - 1.1 x Uc 0.85 - 1.1 x Uc 0.85 - 1.1 x Uc 0.85 - 1.1 x Uc 0.85 - 1.1 x Uc DC-operated 0.7 - 1.1 x Uc - Pick-up AC 2 VA 0.5 VA 1.3 VA 6.25 mA 31.3 mA Sealing AC 2 VA 0.5 VA 1.3 VA 6.25 mA 31.3 mA Pick-up DC 1.8 W - 0.6 W 24.1 mA Sealing DC 1.8 W - 0.6 W 24.1 mA Duty factor 100 % DF 100 % DF 100 % DF 100 % DF 100 % DF Maximum operating frequency 4000 Ops/h 4000 Ops/h AC 50 ms 50 ms 30 ms 30 ms 30 ms DC 30 ms - 30 ms 30 ms 30 ms ≦ 0.5 % ≦ 0.5 % ≦ 0.5 % ≦ 0.5 % ≦ 0.5 % 70 ms 70 ms < 50 ms < 50 ms < 50 ms 4 ms 4 ms Timing relay Short-circuit rating without welding 2) Magnet systems Rated operational voltage Rated frequency Power consumption Minimum command time Repetition accuracy (deviation) Recovery time (after 100% time delay) Contact changeover time Electromagnetic compatibility (EMC) Electrostatic discharge (IEC/EN 61000-4-2, Level 3, ESD) Air discharge 8 kV 8 kV Contact discharge 6 kV 6 kV Electromagnetic fields (IEC/EN 61000-4-3, RFI) 10 V/m 10 V/m Radio interference suppression (EN 55011) EN 55011 Class A EN 55011 Class A Burst (IEC/EN 61000-4-4, Level 3) 2 2 Power pulses (Surge) (IEC/EN 61000-4-5, Level 2) 1 kV 1 kV Immunity to line-conducted interference to (IEC/EN 61000-4-6) 10 V 10 V EATON Easy measuring, reliable monitoring and flexible planning - the EMR, ETR and EMT relays 17 At Eaton, we are solution-driven, supplying energy to a world that is ever more demanding. With over 100 years of expertise in the area of power management, we are ready for the future. Core industries all around the globe rely on Eaton and on our pioneering products, total solutions and engineering services. Companies know they can always trust our reliable, efficient, and safe power management solutions. Together with our personalized service and support, as well as our forward-looking attitude, these solutions meet the needs of tomorrow, today. Follow the charge. Visit eaton.eu. Eaton Industries GmbH Hein-Moeller-Str. 7–11 D-53115 Bonn / Germany © 2018 Eaton All rights reserved Publication No. BR049003EN / CSSC-945 February 2018 www.eaton.en Eaton is a registered trademark of Eaton Corporation All other trademarks are property of their respective owners.
EMR6-I1-A-1 价格&库存
很抱歉,暂时无法提供与“EMR6-I1-A-1”相匹配的价格&库存,您可以联系我们找货
