FAZ-D40/1
FAZ-D40/1
    EATON(伊顿)
    EATON MOELLER - FAZ-D40/1 - Thermal Magnetic Circuit Breaker, FAZ, 40 A, 1 Pole, 48 V, 240 V, DIN Ra...
FAZ-D40/1 数据手册
DATASHEET - FAZ-D40/1-NA Miniature circuit breaker (MCB), 40A, 1p, D-Char, AC Part no.  Catalog No.  Alternate Catalog No.  EL-Nummer (Norway)  FAZ-D40/1-NA 102116 FAZ-D40/1-NA 0001691641 Similar to illustration Delivery program Basic function     Miniature circuit-breakers Number of poles     1 pole Tripping characteristic     D Application     Switchgear for export to North America (UL-listed) Rated current In A 40 Rated switching capacity acc. to IEC/EN 60947-2 Icu kA 15 Product range     FAZ-NA Standards     UL 489, CSA C22.2 No. 5 IEC 60947-2 Rated operational voltage Ue V     Ue V AC 240   Technical data Electrical   V DC 60 Rated voltage according to IEC/EN 60947-2 Un V AC 240/415 Rated voltage according to UL Un V AC 240 Rated switching capacity acc. to IEC/EN 60947-2 Icu kA 15 Characteristic     B, C, D Selectivity Class     3 lifespan       Operations   > 20000 Direction of incoming supply Lifespan     as required Standard front dimension   mm 45 Enclosure height   mm 105 Mounting width per pole   mm 17.7 Mounting     IEC/EN 60715 top-hat rail Degree of Protection     IP20, IP40 (when fitted) Terminals top and bottom     Twin-purpose terminals Terminal protection     Finger and back-of-hand proof to BGV A2 Tightening torque of fixing screws   N/m max. 2.4 UL: #18-12 AWG: 2.4 Nm (21 lb-in) #10-8 AWG: 2.8 Nm (25 lb-in) #6 AWG: 4 Nm (36 lb-in) Mounting position     As required       Rated operational current for specified heat dissipation In A 40 Heat dissipation per pole, current-dependent Pvid W 0 Mechanical Design verification as per IEC/EN 61439 Technical data for design verification 05/05/2020 Eaton 102116 ED2020 V67.0 EN 1/5 Equipment heat dissipation, current-dependent Pvid W 3.9 Static heat dissipation, non-current-dependent Pvs W 0 Heat dissipation capacity Pdiss W 0 Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 75       linear, per +1 °C, results in a 0.5% reduction of current carrying capacity IEC/EN 61439 design verification       10.2 Strength of materials and parts       10.2.2 Corrosion resistance     Meets the product standard's requirements. 10.2.3.1 Verification of thermal stability of enclosures     Meets the product standard's requirements. 10.2.3.2 Verification of resistance of insulating materials to normal heat     Meets the product standard's requirements. 10.2.3.3 Verification of resistance of insulating materials to abnormal heat and fire due to internal electric effects     Meets the product standard's requirements. 10.2.4 Resistance to ultra-violet (UV) radiation     Meets the product standard's requirements. 10.2.5 Lifting     Does not apply, since the entire switchgear needs to be evaluated. 10.2.6 Mechanical impact     Does not apply, since the entire switchgear needs to be evaluated. 10.2.7 Inscriptions     Meets the product standard's requirements. 10.3 Degree of protection of ASSEMBLIES     Does not apply, since the entire switchgear needs to be evaluated. 10.4 Clearances and creepage distances     Meets the product standard's requirements. 10.5 Protection against electric shock     Does not apply, since the entire switchgear needs to be evaluated. 10.6 Incorporation of switching devices and components     Does not apply, since the entire switchgear needs to be evaluated. 10.7 Internal electrical circuits and connections     Is the panel builder's responsibility. 10.8 Connections for external conductors     Is the panel builder's responsibility. 10.9 Insulation properties       10.9.2 Power-frequency electric strength     Is the panel builder's responsibility. 10.9.3 Impulse withstand voltage     Is the panel builder's responsibility. 10.9.4 Testing of enclosures made of insulating material     Is the panel builder's responsibility. 10.10 Temperature rise     The panel builder is responsible for the temperature rise calculation. Eaton will provide heat dissipation data for the devices. 10.11 Short-circuit rating     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.12 Electromagnetic compatibility     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.13 Mechanical function     The device meets the requirements, provided the information in the instruction leaflet (IL) is observed. Technical data ETIM 7.0 Circuit breakers and fuses (EG000020) / Miniature circuit breaker (MCB) (EC000042) Electric engineering, automation, process control engineering / Electrical installation, device / Miniature circuit breaker system (MCB) / Miniature circuit breaker (MCB) (ecl@ss10.0.1-27-14-19-01 [AAB905014]) Release characteristic     D Number of poles (total)     1 Number of protected poles     1 Rated current   A 40 Rated voltage   V 240 Rated insulation voltage Ui   V 440 Rated impulse withstand voltage Uimp   kV 4 Rated short-circuit breaking capacity Icn EN 60898 at 230 V   kA 0 Rated short-circuit breaking capacity Icn EN 60898 at 400 V   kA 0 Rated short-circuit breaking capacity Icu IEC 60947-2 at 230 V   kA 15 Rated short-circuit breaking capacity Icu IEC 60947-2 at 400 V   kA 15 Voltage type     AC Frequency   Hz 50 - 60 Current limiting class     3 Suitable for flush-mounted installation     No Concurrently switching N-neutral     No Over voltage category     3 05/05/2020 Eaton 102116 ED2020 V67.0 EN 2/5 Pollution degree     2 Additional equipment possible     Yes Width in number of modular spacings     1 Built-in depth   mm 70.5 Degree of protection (IP)     IP20 Ambient temperature during operating   °C -25 - 75 Connectable conductor cross section multi-wired   mm² 1 - 25 Connectable conductor cross section solid-core   mm² 1 - 25 Product Standards     IEC/EN 60947-2; UL 489; CSA-C22.2 No. 5-09; CE marking UL File No.     E235139 UL Category Control No.     DIVQ CSA File No.     204453 CSA Class No.     1432-01 North America Certification     UL listed, CSA certified Specially designed for North America     Yes, suitable as BCPD Suitable for     Feeder circuits, branch circuits Current Limiting Circuit-Breaker     Yes Max. Voltage Rating     > 32 A Degree of Protection     IEC: IP20, UL/CSA Type: - 05/05/2020 Eaton 102116 ED2020 V67.0 EN Approvals 3/5 Characteristics 2 Let-through energy I t Characteristic D (0.5 - 20 A), 277 V 05/05/2020 Eaton 102116 ED2020 V67.0 EN 4/5 Characteristic D (25 - 40 A), 240 V Additional product information (links) Temperature dependency, derating 05/05/2020 https://www.eaton.com/content/dam/eaton/technicaldocumentation/technical-data-tables/Derating table FAZ-NA-RT.pdf Eaton Industries GmbH http://www.eaton.eu © 04/2020 by Eaton Industries GmbH Eaton 102116 ED2020 V67.0 EN 5/5
FAZ-D40/1 价格&库存
很抱歉,暂时无法提供与“FAZ-D40/1”相匹配的价格&库存,您可以联系我们找货
FAZ-D40/1
  • 1+175.314421+22.74690
  • 3+163.644213+21.23270
  • 12+151.9740012+19.71850
