Technical Data 4337
Effective April 2016
Supersedes December 2008
FP1005R
High frequency, high current power inductors
Applications
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs)
• Server and desktop
Central processing unit (CPU)
Graphics processing unit (GPU)
Application specific integrated circuit (ASIC)
High power density
Data networking and storage systems
Graphics cards and battery power systems
Portable electronics
Point-of-Load modules
Description
High current carrying capacity
Low core loss
Magnetically shielded
Frequency range up to 2 MHz
Inductance range 85 nH to 220 nH
Current range 33 A to 90 A
10.2 mm x 7.0 mm footprint surface mount
package in a 4.95 mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Environmental Data
Storage temperature range (Component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
FP1005R
Technical Data 4337
Product Specifications
OCL1
(nH) ±10%
FLL2
(nH) minimum
Irms3
(A)
Isat14
(A)
Isat25
(A)
DCR (mΩ)
@ 20°C
K-factor6
FP1005R1-R08-R
85
61
53
90
64
0.39 ±7.7%
536
FP1005R1-R10-R
100
72
53
73
57
0.39 ±7.7%
536
FP1005R1-R12-R
120
86
53
60
48
0.39 ±7.7%
536
FP1005R1-R15-R
150
108
53
47
37
0.39 ±7.7%
536
FP1005R1-R22-R
220
158
53
33
26
0.39 ±7.7%
536
FP1005R2-R08-R
85
61
50
90
64
0.47 ±6.7%
536
FP1005R2-R10-R
100
72
50
73
57
0.47 ±6.7%
536
FP1005R2-R12-R
120
86
50
60
48
0.47 ±6.7%
536
FP1005R2-R15-R
150
108
50
47
37
0.47 ±6.7%
536
FP1005R2-R22-R
220
158
50
33
26
0.47 ±6.7%
536
FP1005R3-R08-R
85
61
45
90
64
0.55 ±5.4%
536
FP1005R3-R10-R
100
72
45
73
57
0.55 ±5.4%
536
FP1005R3-R12-R
120
86
45
60
48
0.55 ±5.4%
536
FP1005R3-R15-R
150
108
45
47
37
0.55 ±5.4%
536
FP1005R3-R22-R
220
158
45
33
26
0.55 ±5.4%
536
120
86
45
60
48
0.70 ±10%
536
Part Number7
R1 Version
R2 Version
R3 Version
R4 Version
FP1005R4-R12-R
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.1 Vrms, Isat1, +25 °C
3. Irms : DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed 125 °C under worst case operating
conditions verified in the end application.
4. Isat1 : Peak current for approximately 20% rolloff @ +25 °C
5. Isat2 : Peak current for approximately 20% rolloff @ +125 °C
6. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L *ΔI * 10-3. Bp-p:(Gauss), K: (K-factor from
table), L: (Inductance in nH), Symbol I (Peak to peak ripple current in Amps).
7. Part Number Definition: FP1005Rx-Rxx-R
FP1005R= Product code and size
x= Version indicator
-Rxx= Inductance value in μH, R= decimal point
-R suffix = RoHS compliant
Dimensions (mm)
Part marking: FPT1005Rx = (x=version indicator), Rxx=inductance value in uH, (R=decimal point)
wwllyy=date code, R=revision level.
Tolerances are ±0.25 millimeters unless stated otherwise.
All soldering surfaces must be coplanar within 0.1016 millimeters.
PCB tolerances are ±0.1 millimeters unless stated otherwise.
DCR is measured from point “a” to point “b.”
Do not route traces or vias underneath the inductor.
2
www.eaton.com/elx
FP1005R
Technical Data 4337
Packaging information (mm)
Supplied in tape and reel packaging , 950 parts per 13” diameter reel
Temperature rise vs. total loss
Temperature Rise (
60
50
40
30
0.4
0.6
0.8
1
1.2
1.4
1.6
1.8
2
Total Loss (W)
www.eaton.com/elx
3
FP1005R
Technical Data 4337
Core loss vs. Bp-p
1 MHz
10
500 kHz
300 kHz
200 kHz
1
100 kHz
Core Loss (W)
0.1
0.01
0.001
0.0001
0.00001
100
1000
1000 0
Bp-p (Gauss)
Inductance characteristics
% of OCL vs. % of I sat1
100%
-40 °C
% of OCL
80%
+25 °C
60%
40%
20%
0%
+125 °C
0%
20%
40%
60%
% of Isat1
4
www.eaton.com/elx
80%
100%
120%
FP1005R
Technical Data 4337
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP1005R1-R10-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+19.130311+2.48215
- 10+15.7137310+2.03885
- 100+12.91957100+1.67631
- 国内价格 香港价格
- 950+10.77862950+1.39852
- 1900+10.165761900+1.31900
- 2850+9.823942850+1.27465
- 4750+9.410194750+1.22097
- 6650+9.347296650+1.21281
- 国内价格
- 950+8.49240
- 1900+8.03724
- 2850+7.76174
- 4750+7.48625
- 6650+7.29460
