FRS-R-6-1/4
FRS-R-6-1/4
    EATON(伊顿)
    Cartridge,Non-Standard
    FUSE TRON DUAL ELEMENT FUSE CLAS
FRS-R-6-1/4 数据手册
Technical Data 1017 Effective July 2023 Supersedes October 2019 Fusetron™ 600 V Class RK5 FRS-R — 600 Vac/300 Vdc, 1/10-60 A, dual element, time-delay fuses Catalog symbols: • FRS-R-(amp) (non-indicating) • FRS-R-(amp)ID (indicating) Description: Advanced protection, energy efficient Class RK5 dual-element, current-limiting, time-delay fuses with optional open fuse indication on select ratings. Time-delay — 10 second (minimum) at 500% of rated current. Catalog numbers (amps) FRS-R-1/10 FRS-R-1-8/10 FRS-R-1/8 FRS-R-2 FRS-R-15/100 FRS-R-2-1/4 FRS-R-2/10 FRS-R-2-1/2 FRS-R-1/4 FRS-R-2-8/10 FRS-R-3/10 FRS-R-3 FRS-R-4/10 FRS-R-3-2/10 FRS-R-1/2 FRS-R-3-1/2 FRS-R-6/10 FRS-R-4 FRS-R-8/10 FRS-R-4-1/2 FRS-R-1 FRS-R-5 FRS-R-1-1/8 FRS-R-5-6/10 FRS-R-1-1/4 FRS-R-6* FRS-R-1-4/10 FRS-R-6-1/4* FRS-R-1-1/2 FRS-R-7* FRS-R-1-6/10 FRS-R-7-1/2* * Open fuse indication available by inserting the suffix “ID.” E.g., FRS-R-15ID. 35 to 60 amp indicating fuses are not Vdc rated. Carton quantity • • Volts • 600 Vac, 300 Vdc (1/10-30 A) • 600 Vac, 250 Vdc* (35-60 A) • Amps — 1/10-60 A • Interrupting rating • 200 kA Vac RMS Sym • 20 kA Vdc • Dual-element feature provides the best timedelay performance, allowing closer sizing and superior protection of motors and transformers • Closer sizing allows for smaller fuses and less costly switches • Class RK5 fuses with a 200 kA interrupting rating for use in a broad range of applications • Provides motor overload, ground fault, and short-circuit protection • Helps protect motors against burnout from overloads and single-phasing when sized properly • Dual-element fuses can be applied in circuits subject to temporary motor overloads and surge currents to provide both high performance short-circuit and overload protection • Offers a 10-second time delay at 5 times the rated current • The time-delay feature makes it possible to use fuse amp ratings that are much smaller than those of non-time delay fuses. Considerable cost savings occur by permitting the use of smaller size switches, panels, and fuses themselves. • Provides current limitation to help protect downstream components from high fault currents. • Gives motor running back-up protection to motors without extra costs. * Indicating versions not Vdc rated. Agency Information • cULus Listed file No. JDDZ.E4273 • UL 248-12 – Class RK5 Fuses • • CSA C22.2 No. 248.12 – Class RK5 Fuses 10 Features and benefits Specifications: Ratings FRS-R-8* FRS-R-9* FRS-R-10* FRS-R-12* FRS-R-15* FRS-R-17-1/2* FRS-R-20* FRS-R-25* FRS-R-30* FRS-R-35* FRS-R-40* FRS-R-45* FRS-R-50* FRS-R-60* CE Technical Data 1017 Fusetron™ 600 V Class RK5 FRS-R — 600 Vac/300 Vdc, 1/10-60 A, dual element, time-delay fuses Effective July 2023 Time-current curves - average melt Recommended fuse blocks Amps 30 60 Catalog no. 1-Pole RM60030-1_ RM60060-1_ 1/10 to 8 amps 2-Pole RM60030-2_ RM60060-2_ 3-Pole RM60030-3_ RM60060-3_ AMP RATING For additional information on the 600 volt fuse blocks, see data sheet no. 10489. Fuse reducers for Class R fuses Catalog no. (pairs) 600 V NO.663-R NO.216-R NO.616-R NO.626-R For additional information on Class R fuse reducers, see data sheet no. 1118. Dimensions — in 5.5" (±0.031) 5" (±0.031) TIME IN SECONDS Desired fuse (case) Equipment fuse clips size 60 A 30 A 30 A 100 A 60 A 200 A 60 A 1.06" (±0.008) 0.81" (±0.008) 35 to 60A 1/10 to 30A CURRENT IN AMPS 2 Eaton.com/bussmannseries Technical Data 1017 Fusetron™ 600 V Class RK5 FRS-R — 600 Vac/300 Vdc, 1/10-60 A, dual element, time-delay fuses Time-current curves - average melt Effective July 2023 Current-limitation curves 10 to 60 amps B 400000 300000 AMP RATING AMP RATING INSTANTANEOUS PEAK-LET-THROUGH CURRENT IN AMPS 200000 100000 90000 80000 70000 60000 50000 40000 30000 20000 60A 10000 9000 8000 7000 6000 30A 5000 4000 3000 A TIME IN SECONDS 2000 RMS SYMMETRICAL CURRENT IN AMPS Current-limiting effects A-B = ASYMMETRICAL AVAILABLE PEAK (2.3 X SYM RMS AMPS) Prosp. S.C.C. — 5000 10,000 15,000 20,000 25,000 30,000 35,000 40,000 50,000 60,000 70,000 80,000 90,000 100,000 150,000 200,000 200000 60000 70000 80000 90000 100000 50000 30000 40000 20000 6000 7000 8000 9000 10000 5000 3000 4000 2000 1000 1000 Let-through current (apparent RMS symmetrical vs. fuse rating) 30 A 60 A 1000 1000 1000 2000 1000 2000 2000 2000 2000 2000 2000 3000 2000 3000 2000 3000 2000 3000 2000 3000 3000 4000 3000 4000 3000 4000 3000 4000 3000 5000 4000 6000 CURRENT IN AMPS Eaton.com/bussmannseries 3 Technical Data 1017 Fusetron™ 600 V Class RK5 FRS-R — 600 Vac/300 Vdc, 1/10-60 A, dual element, time-delay fuses Effective July 2023 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2023 Eaton All Rights Reserved Printed in USA Publication No. 1017 July 2023 Eaton, Bussmann and Fusetron are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
FRS-R-6-1/4 价格&库存
很抱歉,暂时无法提供与“FRS-R-6-1/4”相匹配的价格&库存,您可以联系我们找货
