FWH-005A6F
FWH-005A6F
    EATON(伊顿)
    3AB,3AG,1/4" x 1-1/4"
    FUSE CARTRIDGE 5A 500VAC/600VDC
FWH-005A6F 数据手册
Technical Data 720038 Effective June, 2015 Supersedes December 2015 BUSSMANN SERIES FWH 6x32mm high speed ferrule fuses Agency information • UL Recognized JFHR2, E91958, 0.25-7A • UL Recognized JDXY2, E19180, 10-30A • CSA Component Acceptance file Class 1422-30, 1422-90 (53787) 0.25-7A • RoHS compliant • CE Opening times: Amp range 0.25-7A 10-30A Catalog symbols: • FWH-(amp)A6F • FWH-(amp)A6FR (RoHS compliant) • FWH5-(amp)A6F • FWH5-(amp)A6FR (RoHS compliant) 200% > 30 min. > 30 min. ≤ 10 sec. 31.8 (1.25) Features: Ratings Low watts loss in a compact size Excellent cycling capability and DC performance • Low arc voltage and low energy let-through (I2t) Typical applications: • 1000 Vac (2 A) • DC common bus • 600 Vdc (1-5 A) • DC drives • Power converters/rectifiers • Reduced voltage starters Interrupting rating • 50 kA AC (0.25-1 A and 3.15-20 A) • 30 kA AC (2 A) • 20 kA AC (25-30 A) • 50 kA DC (1-5 A) 6.4 (0.25) • 500 Vac (0.25-1 A and 3.15-30 A) 0.25-30 A 200 % • • • Min IR 300 % 3.2 (0.125) Eaton’s Bussmann™ series of FWH 6x32mm ferrule high speed fuses are for the protection of DC common bus, DC drives, power converters/ rectifiers and reduced rated voltage starters. Amps 300% Dimensions: Description: Volts 150% Technical Data 720038 FWH 6x32mm high speed ferrule fuses Effective June 2017 Catalog numbers: Amps 0.25 0.5 1 2 3.15 4 5 6.3 7 10 12.5 15 16 20 25 30 Rated voltage Vac Vdc — 500 — 1000 600 500 — — — — — — — — — Pre-arcing 0.01 0.05 0.4 1.3 3.1 — 15 36 50 9.9 20 44 48 75 126 145 I2t (A2s) Clearing @ 500Vac 0.05 0.25 2 3.5 7.7 — 40 90 125 139 60 146 177 259 345 430 Watts loss (W) 2.7 1.2 1.7 3.2 2.9 — 2.1 2.3 2.5 2.86 3.53 3.08 4.48 4.26 — — Catalog no. Standard — FWH5-010A6F FWH5-12-5A6F FWH5-015A6F FWH5-016A6F FWH5-020A6F FWH-025A6F FWH-030A6F RoHS compliant FWH-.250A6F FWH-.500A6F FWH-001A6F FWH-002A6F FWH-3.15A6F FWH-004A6F FWH-005A6F FWH-6.30A6F FWH-007A6F FWH5-010A6FR FWH5-12-5A6FR FWH5-015A6FR FWH5-016A6FR FWH5-020A6FR FWH-025A6FR FWH-030A6FR The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2017 Eaton All Rights Reserved Printed in USA Publication No. 720038 — BU-SB15288 June 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
FWH-005A6F 价格&库存
很抱歉,暂时无法提供与“FWH-005A6F”相匹配的价格&库存,您可以联系我们找货
