FWP-40A22F
FWP-40A22F
    EATON(伊顿)
    Cartridge,Non-Standard
    FUSE CARTRIDGE 40A 700VAC/500VDC
FWP-40A22F 数据手册
High Speed Fuses For the Protection of Power Semiconductors February 1998 Bussmann® North American Introduction Table of Contents Catalog Symbol General Information Ampere Range FWA 130V 1000-4000A Page 6-7 FWA 150V 70-1000A 8-9 FWX 250V 35-2500A 10-11 FWH 500V 35-1600A 12-13 KAC 600V 1-1000A 14 KBC 600V 35-800A 15 FWP 700V 5-1200A 16-17 FWJ 1000V 35-2000A 18-19 Accessories Fuse Bases 20 Curves Time-Current & Peak Let-Through Voltage 130 150 250 500 600 700 800 1000 21-26 AC X X X X X X — X DC X X X X — X X — Ampere Range 1000-4000 70-1000 35-2500 35-1600 1-1000 5-1200 40-600 35-2000 Bussmann offers a complete range of North American blade and flush-end style fuses and accessories. Their design and construction were optimized to provide: • • • • • Low energy let-through (I2t) Low watts loss Superior cycling capability Low arc voltage Excellent DC performance North American style fuses provide an excellent solution for medium power applications. While there are currently no published standards for these fuses, the industry has standardized on mounting centers that accept Bussmann fuses. Voltage Rating All Bussmann North American style fuses are tested at their rated voltage. Bussmann should be consulted for applications exceeding those values. Accessories External and internal open fuse indication is available for selected portions of the North American line. Fuseblocks are available for most applications. For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 5 Bussmann® North American FWA 130V 1000-4000A ® Electrical Characteristics Ordering Information I2t (A2 Sec) Rated Current Clearing Watts Part Carton RMS-Amps Pre-arc at 130V Loss Number Qty. 1000 170000 460000 60 FWA-1000AH ______________________________________________________________________________________ Type Dimensions Curves Carton Weight (lbs) Figure Number See Page or (BIF #) 3.3 Fig. 1 1200 270000 730000 70 FWA-1200AH ______________________________________________________________________________________ 1500 520000 1400000 78 FWA-1500AH ______________________________________________________________________________________ FWA 2000 860000 2400000 108 FWA-2000AH 130V ______________________________________________________________________________________ 2500 1500000 4100000 130 FWA-2500AH ______________________________________________________________________________________ 1 3000 2100000 5700000 150 FWA-3000AH ______________________________________________________________________________________ 4000 3400000 9200000 257 FWA-4000AH 䡲 䡲 䡲 䡲 page 21 (35785301) ______________ Fig. 2 Interrupting rating 200kA RMS Symmetrical. Watts loss provided at rated current. 130 Vdc U.L. Recognition on 1000 through 2000 amperes only. See accessories on page 20. 1 kg = 2.2 lbs 1 lb = 0.45 kg Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 1.5 K Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current . The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.0 Kp 0.8 UL 1.0 0.6 0.5 300 0.4 0.5 0.2 0.3 0.2 0.15 26 0.3 200 100 Eg Eg 65 104 130 50 100 Ib 0.1 150 30 40 50 60 70 80 90 100% BIF document: 720001 6 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® North American FWA 130V 1000-4000A ® Dimensions Fig. 1: 1000-3000 Amp Range Fig. 2: 4000 Amp Range 1.875 1.875 D B B C Order # FWA-1000AH-2000AH FWA-3000AH FWA-4000AH Fig. 1 1 2 B 2.0 3.0 3.5 C 1.0 1.5 1.5 D — — 1.5 C Thread Depth Tapped ‹Ω•∑-24 ≈ ⁄Ω™∑ Tapped ⁄Ω™∑-20 ≈ ⁄Ω™∑ Tapped ⁄Ω™∑-20 ≈ ⁄Ω™∑ Dimension in inches. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720001 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 7 Bussmann® North American FWA 150V Rated Current RMS-Amps Type 70-1000A ® Electrical Characteristics I2t (A2 Sec) Clearing Pre-arc at 150V Ordering Information Watts Loss Part Number Dimensions Curves Carton Qty. Carton Weight (lbs) Figure Number See Page or (BIF #) 1 0.18 Fig. 1 70 470 4000 6.9 FWA-70A _____________________________________________________________________________________ 80 670 6000 7.7 FWA-80A ____________________________________________________________________________________ __ 100 1200 12000 9.0 FWA-100A ____________________________________________________________________________________ __ 125 1870 18000 11.2 FWA-125A _____________________________________________________________________________________ 150 2700 26000 13.5 FWA-150A _____________________________________________________________________________________ 200 4780 45000 17.6 FWA-200A _____________________________________________________________________________________ 250 7470 70000 22.5 FWA-250A _____________________________________________________________________________________ page 21 (35785310) FWA _____________________________________________________________________________________ 300 10760 100000 27.0 FWA-300A 150V 350 15700 140000 30.6 FWA-350A _____________________________________________________________________________________ 400 20300 180000 35.2 FWA-400A __________________________________________________________________________________________________________________________ 500 39000 120000 35.0 FWA-500A _____________________________________________________________________________________ 600 46000 140000 47.0 FWA-600A _____________________________________________________________________________________ 700 75000 220000 49.0 FWA-700A _____________________________________________________________________________________ 5 2.42 Fig. 2 800 92000 280000 58.0 FWA-800A _____________________________________________________________________________________ 1000 䡲 䡲 䡲 䡲 170000 510000 60.0 FWA-1000A Interrupting rating 100kA RMS Symmetrical. Watts loss provided at rated current. 150 Vdc U.L. Recognition on 70 through 800 amperes only. Consult Bussmann for additional ratings. See accessories on page 20. 1 kg = 2.2 lbs 1 lb = 0.45 kg Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 1.5 K Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current . The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.0 Kp 0.8 UL 1.0 0.6 0.5 300 0.4 0.5 1) 200 2) 100 0.3 0.2 0.3 0.2 0.15 22 Eg Eg 70 102 150 Ib 0.1 50 100 150 30 40 50 60 70 80 90 100% 1) 500-1000 Amp Range 2) 70-400 Amp Range BIF document: 720002 8 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® North American FWA 150V 70-1000A Dimensions Fig. 1: 70-400 Amp Range 2.656 2.188 1.936 1.156 0.125 0.750 0.312 1.000 0.438 Fig. 2: 500-1000 Amp Range 3.500 2.438 1.250 1.000 0.250 1.500 0.406 Dimension in inches. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720002 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 9 Bussmann® North American FWX 250V Type Rated Current RMS-Amps 35-2500A Electrical Characteristics I2t (A2 Sec) Clearing Pre-arc at 250V ® Ordering Information Watts Loss Part Number Dimensions Carton Qty. Carton Weight (lbs) 5 1.40 Figure Number Curves See Page or (BIF #) 35 50 230 4.2 FWX-35A _____________________________________________________________________________________ _ 40 60 310 5.2 FWX-40A ____________________________________________________________________________________ __ 45 80 390 5.7 FWX-45A ____________________________________________________________________________________ __ 50 100 520 6.0 FWX-50A ____________________________________________________________________________________ __ 60 140 740 8.1 FWX-60A ____________________________________________________________________________________________________________ _ 70 330 1400 7.2 FWX-70A ____________________________________________________________________________________ __ 80 430 1850 8.1 FWX-80A ____________________________________________________________________________________ __ 90 570 2450 9.0 FWX-90A ____________________________________________________________________________________ __ 100 740 3150 10.0 FWX-100A ____________________________________________________________________________________ __ 0.32 125 1130 4850 12.5 FWX-125A ____________________________________________________________________________________ __ 150 1620 6950 15.7 FWX-150A ____________________________________________________________________________________ __ 175 2170 9300 18.5 FWX-175A ____________________________________________________________________________________ __ Fig. 1 200 2790 12000 22 FWX-200A _____________________________________________________________________________________ _ ______________ page 22 (359) 225 3210 14700 24 FWX-225A ____________________________________________________________________________________ __ 250 3960 18100 27 FWX-250A FWX ____________________________________________________________________________________ __ 250V 275 4720 21600 31 FWX-275A ____________________________________________________________________________________ __ 300 6000 27300 32 FWX-300A ____________________________________________________________________________________ __ 350 10600 48600 39 FWX-350A ____________________________________________________________________________________ __ 1 0.52 400 14500 66100 44 FWX-400A ____________________________________________________________________________________ __ 450 22100 101000 49 FWX-450A ____________________________________________________________________________________ __ 500 28000 128000 54 FWX-500A ____________________________________________________________________________________ __ 600 41100 188000 62 FWX-600A ____________________________________________________________________________________ __ 700 48800 190000 72 FWX-700A ____________________________________________________________________________________ __ 800 59000 230000 84 FWX-800A ____________________________________________________________________________________ __ ______________ 0.90 _______________________________________ 1000 44000 360000 100 FWX-1000AH __ ____________________________________________________________________________________ Fig. 2 1200 92000 750000 103 FWX-1200AH ___ ___________________________________________________________________________________ 1500 120000 880000 140 FWX-1500AH ___ ___________________________________________________________________________________ 1600 160000 1200000 140 FWX-1600AH ___ ___________________________________________________________________________________ 2000 320000 2300000 151 FWX-2000AH ___ ___________________________________________________________________________________ 2500 䡲 䡲 䡲 䡲 670000 4700000 Interrupting rating 200kA RMS Symmetrical. Watts loss provided at rated current. 250 Vdc U.L. Recognition on 35 through 800 amperes only. See accessories on page 20. 163 _____________ 2.86 Fig. 3 FWX-2500AH 1 kg = 2.2 lbs BIF document: 720005 10 page 22 (35785299) For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® North American FWX 250V 35-2500A Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.4 1.2 1.0 Kp 0.8 K UL 103 1.0 0.6 0.5 800 0.5 1) 600 500 2) 400 0.3 0.2 0.4 0.3 0.2 1) 300 Eg 0.15 75 125 200 250 2) Eg 200 50 300 1) 35-800 Amp Range 2) 1000-2500 Amp Range 100 150 200 Ib 0.1 30 40 50 250 60 70 80 90 100% 1) 35-800 Amp Range 2) 1000-2500 Amp Range Dimensions Fig. 1: 35-800 Amp Range Fig. 2: 1000-1200 Amp Range Fig. 3: 1500-2500 Amp Range J A A A D E C D C B C B F G H B Order # Fig. A B C D E F G H J FWX-35A-60A 1 3.19 0.81 1.59 2.59 2.25 0.34 0.63 0.13 0.52 Thread Depth — FWX-70A-200A 1 3.13 1.22 1.59 2.44 2.19 0.34 1.00 0.19 0.47 — FWX-225A-600A 1 3.84 1.50 1.59 2.94 2.25 0.41 1.00 0.25 0.75 — FWX-700A-800A 1 3.84 2.00 1.59 3.03 2.28 0.41 1.50 0.25 0.78 — FWX-1000AH-1200AH 2 2.59 3.00 1.50 — — — — — — Tapped ‹Ω•∑-24 ≈ ⁄Ω™∑ FWX-1500AH-2500AH 3 2.59 3.50 1.50 1.50 — — — — — Tapped ‹Ω•∑-24 ≈ ⁄Ω™∑ Dimension in inches. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720005 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 11 Bussmann® North American † FWH 500V Type Rated Current RMS-Amps 35-1600A Electrical Characteristics I2t (A2 Sec) Clearing Pre-arc at 500V ® Ordering Information Watts Loss Part Number Carton Qty. Carton Weight (lbs) 5 0.71 Dimensions Curves Figure Number See Page or (BIF #) 35 34 150 8 FWH-35B ___________________________________________________________________________ 40 76 320 7.5 FWH-40B ___________________________________________________________________________ 45 105 450 7.5 FWH-45B ___________________________________________________________________________ 50 135 670 7.5 FWH-50B ___________________________________________________________________________ 60 210 900 9.9 FWH-60B ______________________________________________________________________________________________ ___ 70 210 900 10.6 FWH-70B ___________________________________________________________________________ 80 305 1400 12.7 FWH-80B ___________________________________________________________________________ page 23 (35785304) 0.21 90 360 1600 15 FWH-90B ___________________________________________________________________________ 100 475 2000 17 FWH-100B ___________________________________________________________________________ ___________ 125 800 3500 25 FWH-125B ___________________________________________________________________________ 150 1100 4600 30 FWH-150B ___________________________________________________________________________ 0.33 175 1450 6200 35 FWH-175B ___________________________________________________________________________ 200 1900 8500 40 FWH-200B ___________________________________________________________________________ ___________ Fig. 1 ____________ FWH ___________________________________________________________________________ 225 4600 23300 39 FWH-225A 500V ___________________________________________________________________________ 250 6300 32200 41 FWH-250A 275 7900 40300 46 FWH-275A ___________________________________________________________________________ 300 9800 49800 51 FWH-300A ___________________________________________________________________________ 325 13700 63800 53 FWH-325A ___________________________________________________________________________ 1 0.57 350 14500 72900 58 FWH-350A ___________________________________________________________________________ 400 19200 96700 65 FWH-400A ___________________________________________________________________________ page 23 (360) ___________ 450 24700 127000 74 FWH-450A ___________________________________________________________________________ 500 29200 149000 84 FWH-500A ___________________________________________________________________________ 1.00 600 41300 206000 108 FWH-600A ___________________________________________________________________________ ___________ 700 55000 298000 120 FWH-700A ___________________________________________________________________________ 800 76200 409000 129 FWH-800A ___________________________________________________________________________ 1000 92000 450000 145 FWH-1000A ___________________________________________________________________________ 1200 122000 600000 180 FWH-1200A ___________________________________________________________________________ 1400 200000 1000000 210 FWH-1400A ___________________________________________________________________________ 1600 290000 1400000 䡲 Interrupting rating 200kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 500 Vdc rating applies to 35 through 800 amperes only. 䡲 See accessories on page 20. †U.L. Recognition on 35 through 1200 amperes only. 230 FWH-1600A 2.14 ___________ ____________ 4.62 ______________________ 11.66 Fig. 2 1 kg = 2.2 lbs BIF document: 720007 12 page 23 (35785304) For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® North American FWH 500V 35-1600A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). 1.5 Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 2.0 K 1.6 1.0 0.5 1) 0.3 0.2 2) 0.15 100 250 400 1.2 0.6 0.5 103 0.4 800 0.3 600 2) 500 0.2 300 100 500 1.0 Kp 0.8 UL 400 Eg Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1) 35-800 Amp Range 2) 1000-1600 Amp Range 1) Eg 200 300 400 Ib 0.1 30 40 50 500 60 70 80 90 100% 1) 35-200 & 1000-1600 Amp Range 2) 225-800 Amp Range Dimensions Fig. 1: 35-1200 Amp Range Fig. 2: 1400-1600 Amp Range 10.219 A D E C 0.125 0.5 3.219 0.625 1.625 1.750 H G F 3.5 B Order # Fig. FWH-35B-60B 1 0.75 4.25 6.219 8.969 J A B C D E F G H J 3.188 0.813 1.593 2.541 2.193 0.344 0.719 0.125 0.518 FWH-70B-100B 1 3.625 0.947 1.736 2.853 2.807 0.352 0.750 0.125 0.375 FWH-125B-200B 1 3.625 1.156 1.836 2.892 2.768 0.344 1.000 0.188 0.406 FWH-225A-400A 1 4.340 1.500 2.090 3.440 2.750 0.410 1.000 0.250 0.750 FWH-450A-600A 1 4.340 2.000 2.090 3.530 2.780 0.410 1.500 0.250 0.780 FWH-700A-800A 1 6.340 2.500 2.090 4.970 3.440 0.530 2.000 0.380 1.300 FWH-1000A-1200A 1 6.969 3.000 3.219 5.465 4.475 0.625 2.375 0.438 1.120 FWH-1400A-1600A 2 See Drawing Dimension in inches. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720007 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 13 Bussmann® North American KAC 600V 1-1000A ® For new installations, Bussmann recommends the 700 volt FWP series fuse. The 600V fuses are supplied as replacements only. Ordering Information Type Dimensions Carton Qty. Part Number KAC-1 KAC-7 KAC-17.5 KAC-2 KAC-8 KAC-20 KAC-3 KAC-9 KAC-25 KAC-4 KAC-10 KAC-30 KAC-5 KAC-12 KAC-6 KAC-15 ________________________________ ___ Carton Weight (lbs) Figure Number 0.50 Fig. 1 10 ______________________ KAC-35 KAC-45 KAC-60 1.40 KAC _____________________________________ KAC-40 KAC-50 _________________ 600V KAC-70 KAC-90 5 1.56 KAC-80 KAC-100 _____________________________________ _________________ KAC-110 KAC-150 KAC-200 0.78 KAC-125 KAC-175 ________________________________ ___ KAC-225 KAC-300 KAC-450 KAC-600 __________ KAC-400 KAC-250 KAC-350 ________________________________ ___ Fig. 2 1 1.92 ______________________ KAC-800 3.16 KAC-500 KAC-700 ________________________________ ___ Fig. 1 __________ KAC-1000 6.24 䡲 Interrupting rating 200kA RMS Symmetrical. 䡲 Consult Bussmann for DC ratings. 䡲 See accessories on page 20. 1 kg = 2.2 lbs 1 lb = 0.45 kg Dimensions Fig. 2: 35-400 Amp Range Fig. 1: 1-30 & 450-1000 Amp Range A B2 B3 C A B1 C G D D F G E F H H Order # KAC-1-30 KAC-35-60 KAC-70-100 KAC-110-200 KAC-225-400 KAC-450-800 KAC-1000 Fig. 1 2 2 2 2 1 1 A 2.875 4.375 5.000 5.140 6.182 6.250 7.250 B1 2.500 — — — — 4.750 4.750 B2 — 3.750 4.063 4.390 4.815 — — B3 — 3.500 3.656 3.766 4.565 — — C 1.875 2.750 2.750 2.906 3.000 3.063 3.063 D 0.406 0.625 0.750 1.000 1.625 2.000 2.750 E — 0.343 0.406 0.406 0.562 — — F 0.563 0.813 1.000 1.500 2.000 2.500 3.500 G 0.063 0.094 0.125 0.250 0.250 0.250 0.375 Dimension in inches. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720009 14 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 H 0.257 0.468 0.609 0.718 0.687 0.563 0.563 Bussmann® North American † KBC 600V 35-800A ® For new installations, Bussmann recommends the 700 Volt FWP series fuse. The 600V fuses are supplied as replacements only. Ordering Information Type Part Number KBC-35 KBC-45 Dimensions Carton Qty. Carton Weight (lbs) Figure Number 10 1.40 Fig. 1 5 1.44 Fig. 2 KBC-60 KBC-40 KBC-50 _____________________________________ _____________________________ KBC-70 KBC-90 KBC-80 KBC-100 _____________________________________ _____________________________ KBC KBC-110 KBC-150 KBC-200 600V ________________________________ KBC-125 KBC-175 ___ KBC-225 KBC-300 KBC-400 KBC-250 KBC-350 ________________________________ ___ 0.48 __________ Fig. 1 0.77 1 __________ KBC-450 KBC-500 KBC-600 ________________________________ ___ 1.32 ______________________ KBC-800 4.50 Fig. 3 䡲 Interrupting rating 200kA RMS Symmetrical. 1 kg = 2.2 lbs 1 lb = 0.45 kg 䡲 Consult Bussmann for DC ratings. 䡲 See accessories on page 20. †U.L. Recognition on 35 through 600 amperes only. Dimensions Fig. 2: 70-100 Amp Range Fig. 1: 35-60 and 110-600 Amp Range A B C D E 0.750 H F G 2.906 I 3.656 4.406 Fig. 3: 800 Amp Range 4.000 3.750 ‹Ω•" - 24 ≈ ⁄Ω™" 0.750 0.312 2.500 2.859 1.000 0.125 0.750 Order # KBC-35-60 KBC-70-100 KBC-110-200 KBC-225-400 KBC-450-600 KBC-800 Fig. 1 2 1 1 1 3 A 4.375 B 3.750 C 3.500 D 2.750 4.406 5.125 5.125 3.719 4.188 4.389 3.594 3.563 3.687 2.906 2.906 2.875 E 0.343 See Drawing 0.312 0.406 0.406 See Drawing F 0.625 G 0.813 H 0.094 I 0.468 0.875 1.000 1.500 1.219 1.500 2.000 0.187 0.250 0.250 0.375 0.719 0.757 Dimension in inches. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720010 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 15 Bussmann® North American FWP 700V Type 5-1200A ® Electrical Characteristics Ordering Information I2t (A2 Sec) Rated Current Clearing Watts Part Carton RMS-Amps Pre-arc at 700V Loss Number Qty. 5 1.6 10 1.5 FWP-5B __________________________________________________________________________ 10 3.6 20 4 FWP-10B __________________________________________________________________________ 15 10 75 5.5 FWP-15B __________________________________________________________________________ 20 26 180 6 FWP-20B __________________________________________________________________________ 25 44 340 7 FWP-25B __________________________________________________________________________ 10 Carton Weight (lbs) Dimensions Curves Figure Number See Page or (BIF #) page 24 2.25 (35785316) 30 58 450 9 FWP-30B ______________________________________________________________________________________ ____________ ____________ 35 34 160 12 FWP-35B __________________________________________________________________________ 40 76 320 12 FWP-40B __________________________________________________________________________ 50 135 600 12 FWP-50B __________________________________________________________________________ 5 1.21 60 210 950 15.5 FWP-60B _________________________________________________________________________________________________ page 24 (35785308) 70 305 2000 18 FWP-70B __________________________________________________________________________ 80 360 2400 21 FWP-80B __________________________________________________________________________ 0.24 90 415 2700 25 FWP-90B __________________________________________________________________________ 100 540 3500 27 FWP-100B __________________________________________________________________________ ____________ 125 1800 7300 28 FWP-125A __________________________________________________________________________ FWP 150 2900 11700 32 FWP-150A __________________________________________________________________________ Fig. 1 ____________ 0.65 700V __________________________________________________________________________ 175 4200 16700 35 FWP-175A 200 5500 22000 43 FWP-200A __________________________________________________________________________ ____________ 225 7700 31300 45 FWP-225A __________________________________________________________________________ 250 10500 42500 48 FWP-250A __________________________________________________________________________ 300 17600 71200 58 FWP-300A __________________________________________________________________________ 1 1.17 page 25 (361) 350 23700 95600 65 FWP-350A __________________________________________________________________________ 400 31000 125000 78 FWP-400A __________________________________________________________________________ ____________ 450 36400 137000 94 FWP-450A __________________________________________________________________________ 500 45200 170000 107 FWP-500A __________________________________________________________________________ 2.39 600 66700 250000 122 FWP-600A __________________________________________________________________________ ____________ 700 54000 300000 125 FWP-700A __________________________________________________________________________ 800 78000 450000 140 FWP-800A __________________________________________________________________________ _______________________ 900 91500 530000 150 FWP-900A __________________________________________________________________________ 1000 120000 600000 170 FWP-1000A __________________________________________________________________________ 1200 䡲 䡲 䡲 䡲 195000 1100000 Interrupting rating 200kA RMS Symmetrical. Watts loss provided at rated current. 700 Vdc U.L. Recognition on 5 through 800 amperes only. See accessories on page 20. 190 FWP-1200A _____________ 1.21 6.60 Fig. 2 ___________ Fig. 3 1 kg = 2.2 lbs BIF document: 720012 16 page 24 (35785308) For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® North American FWP 700V 5-1200A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 2 1.5 1.0 Kp 0.8 UL K 1.6 1.4 1.2 103 1.0 2) 0.5 0.6 0.5 1) 0.4 2) 8 0.3 0.2 0.3 6 5 1) 3) Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 0.2 4 Eg 0.15 316 460 604 Eg 3 300 700 1) 35-100 Amp Range 2) 125-600 Amp Range 3) 700-1200 Amp Range 400 500 600 Ib 0.1 30 40 50 700 60 70 80 90 100% 1) 125-600 Amp Range 2) 35-100 & 700-1200 Amp Range Dimensions Fig. 1: 5-800 Amp Range Fig. 2: 900-1000 Amp Range Fig. 3: 1200 Amp Range 3.500 1.375 J 0.125 0.500 5.966 A D E C 7.594 9.590 6.840 3.844 3.844 10.844 5.154 1.031 0.625 1.625 1.750 0.625 2.750 F 0.750 G 0.500 4.250 H 3.500 B Order # Fig. FWP-5B-30B 1 A B C D E F G H J 2.870 0.563 1.855 2.477 2.477 0.250 0.405 0.063 0.250 FWP-35B-60B 1 4.375 0.813 2.750 3.708 3.312 0.344 0.725 0.125 0.542 FWP-70B-100B 1 4.406 0.947 2.594 3.625 3.563 0.344 0.750 0.125 0.375 FWP-125A-200A 1 5.090 1.500 2.840 4.190 3.500 0.410 1.000 0.250 0.750 FWP-225A-400A 1 5.090 2.000 2.840 4.280 3.530 0.410 1.500 0.250 0.780 FWP-450A-600A 1 7.090 2.500 2.840 5.720 4.190 0.530 2.000 0.380 1.300 FWP-700A-800A 1 6.630 2.000 2.844 5.562 5.062 0.625 1.500 0.250 0.875 FWP-900A-1000A 2 See Drawing FWP-1200A 3 See Drawing Dimension in inches. 1mm = 0.0394∑ 1∑ = 25.4mm For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 BIF document: 720012 17 Bussmann® North American FWJ 1000V Type Rated Current RMS-Amps 35-2000A Electrical Characteristics I2t (A2 Sec) Clearing Pre-arc at 1000V ® Ordering Information Watts Loss Part Number Carton Qty. Carton Weight (lbs) 10 4.18 Dimensions Curves Figure Number See Page or (BIF #) 35 210 2000 7 FWJ-35A __________________________________________________________________________ 40 300 2500 8 FWJ-40A __________________________________________________________________________ 50 470 3500 10 FWJ-50A __________________________________________________________________________ 60 670 5000 11 FWJ-60A __________________________________________________________________________ 70 1100 6900 12 FWJ-70A __________________________________________________________________________ 80 1550 9700 13 FWJ-80A __________________________________________________________________________ 90 1900 12000 14 FWJ-90A __________________________________________________________________________ 100 2800 17500 15 FWJ-100A _________________________________________________________________________________________________ 125 4800 35000 16 FWJ-125A __________________________________________________________________________ 150 6300 45000 25 FWJ-150A __________________________________________________________________________ 4.40 175 7500 65000 30 FWJ-175A __________________________________________________________________________ FWJ 200 11700 80000 32 FWJ-200A __________________________________________________________________________ ___________ 1000V __________________________________________________________________________ 250 16000 112000 50 FWJ-250A 300 23500 164000 56 FWJ-300A __________________________________________________________________________ Fig. 1 350 33000 231000 62 FWJ-350A __________________________________________________________________________ 4.84 400 47000 330000 67 FWJ-400A __________________________________________________________________________ 500 39500 329000 95 FWJ-500A __________________________________________________________________________ 600 61000 520000 105 FWJ-600A __________________________________________________________________________ page 25 (35785303) 1 ___________ ___________ 5.28 page 26 (35785309) 800 87000 500000 182 FWJ-800A __________________________________________________________________________ 1000 190000 1100000 206 FWJ-1000A __________________________________________________________________________ 1200 370000 2100000 240 FWJ-1200A __________________________________________________________________________ 1400 470000 2700000 248 FWJ-1400A __________________________________________________________________________ 1600 700000 4000000 267 FWJ-1600A __________________________________________________________________________ 1800 925000 5300000 239 FWJ-1800A __________________________________________________________________________ 2000 䡲 䡲 䡲 䡲 1330000 7600000 Interrupting rating 200kA. Watts loss provided at rated current. 800 Vdc U.L. Recognition on 40-200 and 500-600 amperes. See accessories on page 20. 244 FWJ-2000A 1 kg = 2.2 lbs BIF document: 720027 18 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® North American FWJ 1000V 35-2000A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). 1.5 Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 1.0 Kp 0.8 2000 K UL 1.0 0.6 0.5 1600 0.4 1200 0.5 0.3 800 0.3 0.2 0.15 200 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 0.2 400 Eg 500 800 Eg 1000 200 600 Ib 0.1 30 40 50 1000 1400 1800 60 70 80 90 100% Dimensions Fig. 1: 35-2000 Amp Range A D E C H G F B J Order # Fig. A B C D E F G H J 1 5.000 0.940 3.110 4.235 4.180 0.352 0.750 0.125 0.380 FWJ-35A-60A FWJ-70A-100A 1 4.932 1.125 3.085 4.266 4.156 0.352 1.000 0.188 0.407 FWJ-125A-200A 1 5.685 1.526 3.261 4.803 4.055 0.445 1.000 0.250 0.819 FWJ-250A-400A 1 5.768 2.000 3.500 4.811 4.150 0.433 1.500 0.250 0.764 FWJ-500A-600A 1 7.201 2.500 3.465 5.984 4.706 0.562 2.000 0.375 1.201 FWJ-800A-2000A 1 6.811 3.500 3.312 5.472 4.962 0.625 2.750 0.500 0.880 Dimension in inches. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720027 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 19 Bussmann® North American – Accessories Fuse Bases (Blocks) Modular Style Bussmann offers a comprehensive line of fuse bases that provide the user with design and manufacturing flexibility. Two identical half bases make up a Buss modular fuse base. These “split” units can be panel mounted any distance apart to accommodate any length fuse. Stud Type Stud Type The simpler design is the C5268 series modular fuse base. With this design, the fuse terminal and cable (with termination) are mounted on the same stud, minimizing labor needed for installation. The stud type base is available in the configuration shown in the table below. Part No. C5268-1 C5268-2 C5268-3 C5268-4 C5268-5 Max. Fuse Current Rating 200A 200A 200A 100A 100A Stud Heights 1.00∑ 1.75∑ 0.75∑ 1.00∑ 1.75∑ Stud Dia. & Threads fiΩ¡§-18 fiΩ¡§-18 fiΩ¡§-18 ⁄Ω¢-20 ⁄Ω¢-20 Connector Type Connector Type Bussmann also offers a modular style fuse base that utilizes a tin-plated connector (for wire termination and heat dissipation) and a plated-steel stud (for fuse mounting). The connector type fuse base is available in the configurations shown below. Consult Bussmann for additional product details. Modular Base Style 1BS101 1BS102 1BS103 1BS104 BH-0 BH-1 BH-2 BH-3 Max. Voltage 600V 600V 600V 600V 700V 2500V 5000V 1250V Max. Fuse Current Rating 100A 400A 400A 600A 100A 400A 500A 700A BIF Document 1206 1207 1208 1209 1200 1201 1202 1203 Fixed Center Fixed Center Base Style Bussmann offers a comprehensive line of fixed mount style fuse bases under the trademark TRON® rectifier fuseblocks. The cable and fuse connections are similar to the stud type fuse base — both are mounted on the same stud. Consult Bussmann for complete product details. BIF document: 720033 20 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® North American Curves FWA-130V (1000-4000)AH FWA-150V (70-1000)A Time-Current Curve Time-Current Curve 104 104 6 4 6 4 2 2 6 4 103 6 4 103 FWA-1000AH FWA-1200AH FWA-1500AH FWA-2000AH FWA-2500AH FWA-3000AH FWA-4000AH 2 102 6 4 102 6 4 2 Virtual Pre-Arcing Time In Seconds 2 Virtual Pre-Arcing Time In Seconds FWA-500A FWA-600A FWA-700A FWA-800A FWA-1000A 2 101 6 4 2 0 10 6 4 2 10–1 6 4 101 6 4 2 100 6 4 2 10–1 6 4 2 2 10–2 6 4 10–2 6 4 FWA-70A FWA-80A FWA-100A FWA-125A FWA-150A 2 10–3 6 4 2 10–3 6 4 2 10–4 2 FWA-200A FWA-250A FWA-300A FWA-350A FWA-400A 2 102 10–4 2 103 4 6 8 2 4 6 104 Prospective Current In Amperes RMS 8 4 6 8 2 4 6 103 Prospective Current In Amperes RMS 8 104 105 Peak Let-Through Curve Peak Let-Through Curve 106 2 6 105 4 FWA-400A 6 FWA-350A 2 FWA-300A 4 2 FWA-4000AH FWA-3000AH 104 FWA-2500AH FWA-2000AH FWA-1500AH 6 FWA-1200AH FWA-1000AH FWA-200A FWA-150A Peak Let-Through Current Peak Let-Through Current FWA-250A 104 6 FWA-100A 4 2 103 4 6 FWA-80A 4 FWA-70A 2 103 1 2 4 6 101 2 4 6 102 2 4 2 6 Prospective Short-Circuit Current Symmetrical RMS 2 10 2 4 6 102 2 103 4 6 2 104 4 6 2 105 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785301 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 BIF document: 35785310 21 Bussmann® North American Curves FWX 250V (35-800)A FWX 250V (1000-2500)AH Time-Current Curve Time-Current Curve 104 6 4 104 2 103 FWX-200A FWX-350A FXW-400A FWX-500A FWX-600A FWX-800A 102 Virtual Pre-arcing Time In Seconds 103 6 4 2 FWX-1000AH FWX-1200AH FWX-1500AH FWX-1600AH FWX-2000AH FWX-2500AH 102 6 4 101 2 Virtual Pre-Arcing Time In Seconds 100 FWX-35A FWX-40A FWX-60A FWX-70A FWX-100A FWX-150A 10–1 10–2 10–3 101 6 4 2 100 6 4 2 10–1 6 4 10–4 2 2 102 103 Prospective Current In Ampere RMS 104 10–2 6 4 2 10–3 6 4 2 10–4 2 103 Peak Let-Through Curve 4 6 8 2 4 6 104 Prospective Current In Amperes RMS 8 105 Peak Let-Through Curve 105 105 B 6 FWX-2500AH 4 Peak Let-Through Current FWX-800A FWX-600A FWX-400A FWX-300A FWX-200A Peak Let-Through Current 104 FWX-2000AH FWX-1600AH FWX-1500AH FWX-1200AH 2 FWX-1000AH 10 4 6 4 2 103 FWX-150A FWX-100A FWX-70A FWX-60A FWX-45A FWX-35A A 1x102 1x102 103 104 103 103 2 4 6 104 2 4 6 105 2 Prospective Short-Circuit Current Symmetrical RMS 105 Prospective Short-Circuit Current Symmetrical RMS BIF document: 359 22 BIF document: 35785299 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 4 6 Bussmann® North American Curves FWH 500V (35-200)B & (900-1600)A FWH 500V (225-800)A Time-Current Curve Time-Current Curve 103 104 6 4 2 103 102 6 4 FWH-350A FWH-400A FWH-500A FWH-600A FWH-800A 2 102 6 4 Virtual Pre-Arcing Time In Seconds 101 6 4 2 100 6 4 FWH-80B FWH-90B FWH-100B FWH-125B FWH-150B FWH-175B FWH-200B FWH-35B FWH-40B FWH-45B FWH-50B FWH-60B FWH-70B 2 10–1 6 4 Virtual Pre-Arcing Time In Seconds 101 FWH-900A FWH-1000A FWH-1200A FWH-1400A FWH-1600A 2 100 10–1 2 10–2 10–2 6 4 2 10–3 6 4 10–3 2 10–4 2 4 6 8 102 2 4 6 8 2 103 Prospective Current In Amper es RMS 4 6 8 104 10–4 102 Peak Let-Through Curve 103 104 Prospective Current In Amperes RMS 105 Peak Let-Through Curve 105 105 B FWH-1600A FWH-1400A 6 FWH-1200A FWH-1000A 4 2 104 Peak Let-Through Current Peak Let-Through Current 104 6 4 2 FWH-800A FWH-600A FWH-500A FWH-400A FWH-300A FWH-250A 103 103 FWH-200B 6 A FWH-150B FWH-125B 4 FWH-100B FWH-80B FWH-60B 1x102 FWH-50B 2 FWH-40B 1x102 103 104 105 Prospective Short-Circuit Current Symmetrical RMS FWH-35B 2 10 102 2 4 6 103 2 4 6 104 2 4 6 105 2 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785304 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 BIF document: 360 23 Bussmann® North American Curves FWP 700V (5-30)B FWP 700V (35-100)B & (700-1200)A Time-Current Curve Time-Current Curve 104 104 6 4 6 4 2 2 103 103 6 4 6 4 2 2 FWP-700A FWP-800A FWP-900A FWP-1000A FWP-1200A 102 102 6 4 6 4 2 Virtual Pre-Arcing Time In Seconds Virtual Pre-Arcing Time In Seconds 2 101 6 4 2 100 6 4 FWP-5B FWP-10B FWP-15B FWP-20B FWP-25B FWP-30B 2 10–1 6 4 101 6 4 100 6 4 2 10–1 6 4 2 10–2 2 6 4 10–2 6 4 2 10–3 2 6 4 10–3 6 4 2 10–4 2 10–4 FWP-35B FWP-40B FWP-50B FWP-60B FWP-70B FWP-80B FWP-90B FWP-100B 2 2 4 6 8 101 2 4 6 8 2 102 4 6 8 2 4 6 8 2 4 6 8 2 103 Prospective Current In Amperes RMS 102 4 6 8 104 103 Prospective Current In Amperes RMS Peak Let-Through Curve Peak Let-Through Curve 104 106 FWP-1200A 6 FWP-1000A 6 4 FWP-800A 4 FWP-700A 2 FWP-30B FWP-25B 2 6 10 4 2 FWP-20B FWP-15B FWP-10B FWP- 5B 102 4 Peak Let-Through Current Peak Let-Through Current 103 6 4 6 4 2 103 2 6 FWP-100B 101 4 10 1 2 4 6 10 2 2 4 6 3 2 4 10 6 4 10 2 4 6 5 FWP-70B 2 10 FWP-60B Prospective Short-Circuit Current FWP-50B 2 FWP-40B FWP-35B 102 2 102 4 6 2 103 4 6 2 4 104 Prospective Short-Circuit Current BIF document: 35785316 24 BIF document: 35785308 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 6 2 105 Bussmann® North American Curves FWP 700V (125-600)A FWJ 1000V (35-600)A Time-Current Curve Time-Current Curve 103 104 6 4 2 103 2 10 6 4 2 FWP-150A FWP-200A FWP-300A FWP-400A FWP-600A FWJ-200A FWJ-250A FWJ-300A FWJ-350A FWJ-400A FWJ-500A FWJ-600A 6 4 2 Virtual Pre-Arcing Time In Seconds Virtual Pre-Arcing Time In Seconds 101 102 100 10–1 101 6 4 2 100 6 4 2 10–1 6 4 10–2 2 10–2 6 4 –3 10 2 10–3 FWJ-40A FWJ-50A FWJ-60A FWJ-70A FWJ-80A FWJ-90A FWJ-100A FWJ-125A FWJ-150A FWJ-175A 6 4 10–4 102 2 103 104 105 10–4 102 Prospective Current In Amperes RMS 2 4 6 8 2 103 4 6 8 104 Prospective Current In Amperes RMS Peak Let-Through Curve Peak Let-Through Curve 105 2 B FWJ-2000A FWJ-1800A FWJ-1600A FWJ-1400A FWJ-1250A FWJ-1000A FWJ-600A FWJ-800A FWJ-400A FWJ-500A FWJ-350A FWJ-300A FWJ-250A FWJ-200A FWJ-175A FWJ-150A FWJ-125A FWJ-100A FWJ-90A FWJ-80A FWJ-70A FWJ-60A FWJ-50A FWJ-40A 105 6 4 Peak Let-Through Current FWP-600A FWP-400A FWP-300A FWP-200A FWP-150A Peak Let-Through Current 2 104 104 6 4 2 10 3 103 6 4 A 2 102 102 1x102 2 4 6 103 2 4 6 104 2 4 6 105 2 4 6 Prospective Short-Circuit Current Symmetrical RMS 1x102 103 104 105 Prospective Short-Circuit Current Symmetrical RMS BIF document: 361 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 BIF document: 35785303 25 Bussmann® North American Curves FWJ 1000V (800-2000)A Time-Current Curve 104 6 4 2 103 6 4 2 102 Virtual Pre-Arcing Time In Seconds 6 4 FWJ-800A FWJ-1000A FWJ-1200A FWJ-1400A FWJ-1600A FWJ-1800A FWJ-2000A 2 101 6 4 2 100 6 4 2 10–1 6 4 2 10–2 6 4 2 10–3 6 4 2 10–4 2 4 6 8 2 103 4 6 8 2 104 4 6 8 105 Prospective Current In Amperes RMS Peak Let-Through Curve 2 FWJ-2000A FWJ-1800A FWJ-1600A FWJ-1400A FWJ-1250A FWJ-1000A FWJ-600A FWJ-800A FWJ-400A FWJ-500A FWJ-350A FWJ-300A FWJ-250A FWJ-200A FWJ-175A FWJ-150A FWJ-125A FWJ-100A FWJ-90A FWJ-80A FWJ-70A FWJ-60A FWJ-50A FWJ-40A 105 6 4 Peak Let-Through Current 2 104 6 4 2 10 3 6 4 2 2 10 102 2 4 6 103 2 4 6 104 2 4 6 105 2 4 6 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785309 26 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Square Body Introduction Table of Contents Voltage Applications Page 28-29 Fuse Style DIN 43 653 660V 1250V 30-35 36-39 DIN 43 620 660V 40-43 Flush End Contact 660V 1250V 44-49 50-51 French Style 660V 52-53 US Style 660V 1250V 54-55 56-57 Accessories Indicator System Fuse Bases Curves Time-Current & Peak Let-Through 58 59 60-65 General Information Designed and tested to: • IEC 269: Part 4 • U.L. Recognized Bussmann offers a complete range of Square Body style fuses and accessories. Their unique design and construction provide: • Minimal energy let-through (I2t) • Low operating temperature • Low watts loss Square Body style fuses are a very attractive solution for high power applications which require a compact design with superior performance. The construction and design of Square Body style fuses make it easy for Bussmann to manufacture custom products. Our cataloged offering provides only a sample of the wide variety of product which is available. Each Square Body style fuse is available with a number of different end fittings. Options include: • • • • • DIN 43 653 DIN 43 620 Flush End (Metric/U.S.) French Style US Style Voltage Rating All Bussmann Square Body style fuses are tested to IEC 269: Part 4. This standard requires a test voltage which is 10% higher than the rated voltage. In North America, fuses are required to clear only their rated voltage. Accessories Square Body style fuses are available with three different open fuse indicator systems. Options include visual indication and indication utilizing a microswitch. Fuseblocks are also available for most applications. Voltage 660 1250 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 AC X X DC — — Ampere Range 10-7500 50-1400 27 Bussmann® Square Body Applications Maximum Permissible Load Current The rated current value of Bussmann fuses is based on the ambient temperature in the space immediately below the fuse of 20°C. The following graph gives correction factors (k) for a range of temperatures (–40°C to +80°C). Maximum permissible continuous load currents can be calculated by applying the following formula: Ib = In ≈ k ≈ (1 + 0.05 V) x Kb where Ib = Maximum permissible continuous load current In = Rated current of fuse k = Temperature correction factor v = Velocity of cooling air in m/s (max. 5 m/s). Kb = Fuse load constant 1.0 The maximum permissible continuous load current Ib of a fuse can be checked empirically (i.e., by satisfying the formula below) by making simple voltage and temperature measurements under actual operating conditions after the fuse has been installed in its operating location and loaded at the calculated Ib value: E2 ≈ (0.92 + 0.004t) ≤ N E1 where E1 = Voltage drop across fuse after 5 seconds E2 = Voltage drop across fuse after 2 hours t = Air temperature at start of test (°C) N = Constant Fuse Rated Voltage (IEC) N 660 1.5 1250 1.6 Temperature Correction Curve 1.4 k 1.2 1 0.8 0.6 — 40 — 20 0 20 40 60 80 C Body Cross Section Standard fuse program includes barrels with different cross sections. 28 Size 000 00 1* 1 2 3 4 Maximum Cross-section mm 21 ≈ 36 30 ≈ 47 45 ≈ 45 53 ≈ 53 61 ≈ 61 76 ≈ 76 105 ≈ 105 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Square Body Applications 170M3669 (400A) Example Application of Square Body High Speed Fuses Subject to Overload and Impulse Loading Select a short-blade indicating fuse with indicator/adapter to permit the use of a single-pole microswitch for remote indication and determine if the fuse selected will meet the following application parameters. 103 Application Parameters Amperes — (2) Overload (3a) (3b) Overload 60 Seconds 10 Seconds 20 Seconds (max.) Once Per Hour 2-3 Times Per Week Once Per Month (4) Impulse 0.5 Seconds Less Than Once Per Month 500A 700A 1100A Voltage Data (5) Voltage Applied to Fuse During Fault Conditions 102 300A 400V (+10%) Temperature Data (6) Temperature Inside Cubicle in Which Fuse is Located (Natural Convection Cooling Only) A 101 60°C 100 Thyrister Data (7) Thyrister Peak Voltage Withstand A Profile Line Frequency of Occurrence Time In Seconds Load Currents Expected Load Type Duration (1) Normal Continuous 1000V (8) Thyrister I2t Withstand at 10 Milliseconds* 90,000A2s *Note: The I2t withstand of the thyrister may be given for other impulse durations (i.e., 1.5 ms, 3.5 ms, or 8.3 ms); however, the stated fuse I2 t is valid for all impulse durations of 10 ms or less. 10–1 Application Procedure Step Procedure Remarks (1) Select a short-blade fuse to permit mounting of microswitch MSW710-1S or 170H0069 1.1 Taking into consideration only the continuous load current and ambient temperature, from Table on page 54 tentatively select fuse 170M3669 400A, 660V). — (2) Determine I2 t (total clearing) at 440V. 2.1 See Table, page 54. Note I2t is 105,000A2s at rated voltage of 660V. 2.2 From the figure on page 55, note that correction factor K = 0.65. 2.3 I2t660V ≈ K = I2t440V 105,000 ≈ 0.65 = 68,250 OK (3) Determine maximum arc voltage at 440V 3.1 From the figure on page 55, note that maximum voltage at 440V is 925V OK (4) Determine maximum permissible continuous load current Ib. 4.1 Per page 28 data, Ib = In ≈ k ≈ (1 + 0.05V) ≈ Kb Ib = 400A ≈ 0.8 ≈ (1 + 0) ≈ 1 Ib = 320A — (5) Plot a “line profile” showing the expected load and overload currents. Determine that overload and impulse load currents do not exceed their maximum permissible values. (Item 2) 5.0 Calculate Imax per Table, page 4, for each overload and impulse load. — (Item 3a) (Item 3b) (Item 4) 5.1 Imax < 60% ≈ It 500A < 60% ≈ 950A 500A < 570A 5.2 Imax < 60% ≈ It 700A < 60% ≈ 1360A 700A < 780A 5.3 Imax < 70% ≈ It 700A < 70% ≈ 1150A 700A < 805A OK OK OK 5.4 Imax < 70% ≈ It 1100A < 70% ≈ 1800A OK 1100A < 1260A The tentatively selected fuse 170M3669 with microswitch 170H0069 meets all application parameters; no further selection would be necessary. 10–2 102 103 Current In Amperes Calculation of Watt Loss From the Table on page 54, watt loss at 400 amperes is 60 watts. The continuous load current of 300 amperes is 75% of rated current (400 amperes). From page 55, the correction factor Kp = 0.5. Watt Loss 75% = Watt Loss 100% ≈ Kp = 60W ≈ 0.5 = 30 watts Special Fuses Other high speed fuses are available from Bussmann with voltage ratings of 380 to 10,000 volts and current ratings up to 10,000 Amp in a single unit configuration. Fuses can be supplied with open fuse, “pin” indicators. Various types of microswitches are also available (see page 58). For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 29 Bussmann® Square Body – DIN 43 653 660V (IEC/U.L.) 10-400A Electrical Characteristics Size 000 00 䡲 䡲 䡲 䡲 Rated Current RMS-Amps 10 16 20 25 32 40 50 63 80 100 125 160 200 250 315 25 32 40 50 63 80 100 125 160 200 250 315 350 400 I2t (A2 ® Ordering Information Pre-arc Sec) Clearing at 660V Watts Loss Protection Class 3.8 7.2 11.5 19 40 69 115 215 380 695 1200 2300 4200 7750 12000 19 28.5 50 95 170 310 620 1000 1900 3400 6250 10000 13500 18000 25.5 48 78 130 270 460 770 1450 2550 4650 8500 16000 28000 51500 80500 130 195 360 640 1200 2100 4150 6950 13000 23000 42000 68500 91500 125000 3.0 5.5 7 9 10 12 15 16 19 24 28 32 37 42 52 6 7 9 10 12 15 20 25 30 35 45 55 60 70 gR gR gR gR gR gR gR gR aR aR aR aR aR aR aR gR gR gR gR gR gR aR aR aR aR aR aR aR aR -U/80 Without Indicator 170M1308 170M1309 170M1310 170M1311 170M1312 170M1313 170M1314 170M1315 170M1316 170M1317 170M1318 170M1319 170M1320 170M1321 170M1322 Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Microswitch indicator ordered separately. See accessories on pages 58-59. U.L. Recognition on Size 000. -/80 Visual Indicator -T/80 Type T Indicator for Micro 170M1358 170M1359 170M1360 170M1361 170M1362 170M1363 170M1364 170M1365 170M1366 170M1367 170M1368 170M1369 170M1370 170M1371 170M1372 170M2608 170M2609 170M2610 170M2611 170M2612 170M2613 170M2614 170M2615 170M2616 170M2617 170M2618 170M2619 170M2620 170M2621 170M1408 170M1409 170M1410 170M1411 170M1412 170M1413 170M1414 170M1415 170M1416 170M1417 170M1418 170M1419 170M1420 170M1421 170M1422 170M2658 170M2659 170M2660 170M2661 170M2662 170M2663 170M2664 170M2665 170M2666 170M2667 170M2668 170M2669 170M2670 170M2671 Curves Carton Qty. Carton Weight (kg) See Page or (BIF #) 10 1.34 page 60 (17056310) 5 1.05 page 60 (17056312) 1 kg = 2.2 lbs. BIF document: 720013 30 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® Square Body – DIN 43 653 660V (IEC/U.L.) 10-400A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). 1.5 Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 1.4 1.2 103 9 8 7 6 K 1.0 0.5 0.4 1.0 Kp 0.8 UL 0.6 0.5 0.4 0.3 5 0.3 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 0.2 4 0.2 Eg Eg 3 100 200 300 400 500 600 660 200 300 400 500 Ib 0.1 30 40 50 600 660 60 70 80 90 100% Dimensions DIN 43 653: Type -U/80, -/80, -T/80 Size 000 00 D 40 51 E 21 30 F 20 28 G 51 67 H 8 10 K 2 2 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm 54 Indicator D K G 100 78 E H F BIF document: 720013 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 31 Bussmann® Square Body – DIN 43 653 660V/700V (IEC/U.L.) 40-2000A Electrical Characteristics Size 1* 1 2 3 䡲 䡲 䡲 䡲 Rated Current RMS-Amps 40 50 63 80 100 125 160 200 250 315 350 400 450 500 550 630 200 250 315 350 400 450 500 550 630 700 800 ‡900 400 450 500 550 630 700 800 900 1000 1100 1250 500 550 630 700 800 900 1000 1100 1250 1400 1500 1600 †1800 ‡2000 Ordering Information Pre-arc Clearing at 660V Watts Loss -/80 Visual Indicator -TN/80 Type T Indicator for Micro 40 77 115 185 360 550 1100 2200 4200 7000 10000 15000 21000 27000 34000 48500 1650 3100 6200 8500 13500 17000 25000 34000 52000 69500 105000 155000 11000 15500 21500 28000 41000 60500 86000 125000 180000 245000 365000 14000 19500 31000 44500 69500 100000 140000 190000 290000 370000 460000 580000 880000 1150000 270 515 770 1250 2450 3700 7500 15000 28500 46500 68500 105000 140000 180000 230000 325000 11500 21000 42000 59000 91500 120000 170000 230000 350000 465000 725000 ‡850000 74000 105000 145000 190000 275000 405000 575000 840000 1250000 1600000 2400000 95000 135000 210000 300000 465000 670000 945000 1300000 1950000 2450000 3100000 3900000 †5250000 ‡6350000 9 11 14 18 21 26 30 35 40 50 55 60 65 70 75 80 45 55 58 60 65 70 72 75 80 85 95 100 65 70 75 80 90 95 105 110 115 120 130 95 100 105 110 115 120 125 130 140 155 160 160 165 175 170M3008 170M3009 170M3010 170M3011 170M3012 170M3013 170M3014 170M3015 170M3016 170M3017 170M3018 170M3019 170M3020 170M3021 170M3022 170M3023 170M4008 170M4009 170M4010 170M4011 170M4012 170M4013 170M4014 170M4015 170M4016 170M4017 170M4018 170M4019 170M5008 170M5009 170M5010 170M5011 170M5012 170M5013 170M5014 170M5015 170M5016 170M5017 170M5018 170M6008 170M6009 170M6010 170M6011 170M6012 170M6013 170M6014 170M6015 170M6016 170M6017 170M6018 170M6019 170M6020 170M6021 170M3058 170M3059 170M3060 170M3061 170M3062 170M3063 170M3064 170M3065 170M3066 170M3067 170M3068 170M3069 170M3070 170M3071 170M3072 170M3073 170M4058 170M4059 170M4060 170M4061 170M4062 170M4063 170M4064 170M4065 170M4066 170M4067 170M4068 170M4069 170M5058 170M5059 170M5060 170M5061 170M5062 170M5063 170M5064 170M5065 170M5066 170M5067 170M5068 170M6058 170M6059 170M6060 170M6061 170M6062 170M6063 170M6064 170M6065 170M6066 170M6067 170M6068 170M6069 170M6070 170M6071 I2t ® (A2S) Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Rated voltage (IEC) †600V ‡550V (Consult Bussmann for U.L. Recognition status.) Microswitch indicator ordered separately. See accessories on pages 58-59. -/110 Visual Indicator -TN/110 Type T Indicator for Micro 170M3158 170M3159 170M3160 170M3161 170M3162 170M3163 170M3164 170M3165 170M3166 170M3167 170M3168 170M3169 170M3170 170M3171 170M3172 170M3173 170M4158 170M4159 170M4160 170M4161 170M4162 170M4163 170M4164 170M4165 170M4166 170M4167 170M4168 170M4169 170M5158 170M5159 170M5160 170M5161 170M5162 170M5163 170M5164 170M5165 170M5166 170M5167 170M5168 170M6158 170M6159 170M6160 170M6161 170M6162 170M6163 170M6164 170M6165 170M6166 170M6167 170M6168 170M6169 170M6170 170M6171 170M3208 170M3209 170M3210 170M3211 170M3212 170M3213 170M3214 170M3215 170M3216 170M3217 170M3218 170M3219 170M3220 170M3221 170M3222 170M3223 170M4208 170M4209 170M4210 170M4211 170M4212 170M4213 170M4214 170M4215 170M4216 170M4217 170M4218 170M4219 170M5208 170M5209 170M5210 170M5211 170M5212 170M5213 170M5214 170M5215 170M5216 170M5217 170M5218 170M6208 170M6209 170M6210 170M6211 170M6212 170M6213 170M6214 170M6215 170M6216 170M6217 170M6218 170M6219 170M6220 170M6221 Curves Carton Qty. Carton Weight (kg) See Page or (BIF #) 5 1.50 page 61 (17056314) 3 (-/80) 1.29 2 (-/110) 0.94 page 61 (17056316) 2 1.20 page 62 (17056318) 2 (-/80) 1.66 1 (-/110) 0.89 1 kg = 2.2 lbs. BIF document: 720014 32 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 page 62 (17056320) 1 lb = 0.45 kg Bussmann® Square Body – DIN 43 653 660V/700V (IEC/U.L.) 40-2000A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.0 Kp 0.8 0.5 0.4 1.4 1.2 103 9 8 7 6 0.3 5 K 2) 1) 1.0 UL 0.6 0.5 0.4 0.3 0.2 4 0.2 Eg Eg 3 100 200 300 400 500 600 660 200 300 400 500 Ib 0.1 600 660 30 40 50 60 70 80 90 100% 1) Rated voltage 600V 2) Rated voltage 550V Dimensions DIN 43 653: Type -/80, -TN/80, -/110, -TN/110 Size 1* 1 2 3 A 50 50 50 51 B 104 108 108 109 B§ 134 138 138 139 C 78 78 78 78 C§ 108 108 108 108 D 58 66 75 90 E 45 53 61 76 H 22 25 25 30 §Valid for fuses type -/110, -TN/110 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm C A H 11 D E B 6 E BIF document: 720014 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 33 Bussmann® Square Body – DIN 43 653 660V/700V (IEC/U.L.) 40-2000A Electrical Characteristics Size 40 50 63 80 100 125 160 200 250 315 350 400 450 500 550 630 200 250 315 350 400 450 500 550 630 700 800 ‡900 400 450 500 550 630 700 800 900 1000 1100 1250 500 550 630 700 800 900 1000 1100 1250 1400 1500 1600 †1800 ‡2000 1* 1 2 3 䡲 䡲 䡲 䡲 Rated Current RMS-Amps I2 t ® Ordering Information (A2S) Pre-arc Clearing at 660V 40 77 115 185 360 550 1100 2200 4200 7000 10000 15000 21000 27000 34000 48500 1650 3100 6200 8500 13500 17000 25000 34000 52000 69500 105000 155000 11000 15500 21500 28000 41000 60500 86000 125000 180000 245000 365000 14000 19500 31000 44500 69500 100000 140000 190000 290000 370000 460000 580000 880000 1150000 270 515 770 1250 2450 3700 7500 15000 28500 46500 68500 105000 140000 180000 230000 325000 11500 21000 42000 59000 91500 120000 170000 230000 350000 465000 725000 ‡850000 74000 105000 145000 190000 275000 405000 575000 840000 1250000 1600000 2400000 95000 135000 210000 300000 465000 670000 945000 1300000 1950000 2450000 3100000 3900000 †5250000 ‡6350000 Watts Loss 9 11 14 18 21 26 30 35 40 50 55 60 65 70 75 80 45 55 58 60 65 70 72 75 80 85 95 100 65 70 75 80 90 95 105 110 115 120 130 95 100 105 110 115 120 125 130 140 155 160 160 165 175 -KN/80 Type K Indicator for Micro -KN/110 Type K Indicator for Micro 170M3108 170M3109 170M3110 170M3111 170M3112 170M3113 170M3114 170M3115 170M3116 170M3117 170M3118 170M3119 170M3120 170M3121 170M3122 170M3123 170M4108 170M4109 170M4110 170M4111 170M4112 170M4113 170M4114 170M4115 170M4116 170M4117 170M4118 170M4119 170M5108 170M5109 170M5110 170M5111 170M5112 170M5113 170M5114 170M5115 170M5116 170M5117 170M5118 170M6108 170M6109 170M6110 170M6111 170M6112 170M6113 170M6114 170M6115 170M6116 170M6117 170M6118 170M6119 170M6120 170M6121 170M3258 170M3259 170M3260 170M3261 170M3262 170M3263 170M3264 170M3265 170M3266 170M3267 170M3268 170M3269 170M3270 170M3271 170M3272 170M3273 170M4258 170M4259 170M4260 170M4261 170M4262 170M4263 170M4264 170M4265 170M4266 170M4267 170M4268 170M4269 170M5258 170M5259 170M5260 170M5261 170M5262 170M5263 170M5264 170M5265 170M5266 170M5267 170M5268 170M6258 170M6259 170M6260 170M6261 170M6262 170M6263 170M6264 170M6265 170M6266 170M6267 170M6268 170M6269 170M6270 170M6271 Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Rated voltage (IEC) †600V ‡550V (Consult Bussmann for U.L. Recognition status.) Microswitch indicator ordered separately. See accessories on pages 58-59. Curves Carton Qty. Carton Weight (kg) See Page or (BIF #) 5 1.60 page 61 (17056314) 3 (-/80) 1.38 2 (-/110) 1.00 2 1.26 page 62 (17056318) 1 0.92 page 62 (17056320) 1 kg = 2.2 lbs. BIF document: 720015 34 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 page 61 (17056316) 1 lb = 0.45 kg Bussmann® Square Body – DIN 43 653 660V/700V (IEC/U.L.) 40-2000A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.0 Kp 0.8 0.5 0.4 1.4 1.2 103 9 8 7 6 0.3 5 K 2) 1) 1.0 UL 0.6 0.5 0.4 0.3 0.2 4 0.2 Eg Eg 3 100 200 300 400 500 600 660 200 300 400 500 600 660 Ib 0.1 30 40 50 60 70 80 90 100% 1) Rated voltage 600V 2) Rated voltage 550V Dimensions DIN 43 653: Type -KN/80, -KN/110 Size 1* 1 2 3 A 50 50 50 51 B 104 108 108 109 B§ 134 138 138 139 C 78 78 78 78 C§ 108 108 108 108 D 59 69 77 92 E 45 53 61 76 H 22 25 25 30 §Valid for fuse type -KN/110. Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm C A H 11 D B E 6 E BIF document: 720015 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 35 Bussmann® Square Body – DIN 43 653 1250V/1300V (IEC/U.L.) 50-1400A Electrical Characteristics Size 1* 1 2 3 䡲 䡲 䡲 䡲 I 2t Rated Current RMS-Amps Pre-arc 50 63 80 100 125 160 200 250 315 350 400 160 200 250 315 350 400 450 500 550 †630 250 280 315 350 400 450 500 550 630 700 800 †900 †1000 315 350 400 450 500 550 630 700 ‡800 ‡900 ‡1000 ‡1100 †1250 †1400 135 215 420 750 1450 2600 5150 9200 18500 27000 53000 1900 3800 7750 15000 20000 29500 42000 69500 95000 130000 6500 9350 13000 16500 23000 34000 48000 62000 115000 160000 245000 360000 480000 9500 13500 19500 31000 39000 55000 83500 115000 205000 305000 450000 575000 810000 1250000 Ordering Information Watts Loss -/110 Visual Indicator -T/110 Type T Indicator for Micro 15 20 25 30 35 40 45 55 60 65 70 45 50 60 65 70 75 80 85 95 100 65 70 75 80 85 90 95 100 110 115 120 125 135 85 90 95 100 105 110 115 120 125 130 135 140 145 150 170M3138 170M3139 170M3140 170M3141 170M3142 170M3143 170M3144 170M3145 170M3146 170M3147 170M3148 170M4138 170M4139 170M4140 170M4141 170M4142 170M4143 170M4144 170M4145 170M4146 170M4147 170M5138 170M5139 170M5140 170M5141 170M5142 170M5143 170M5144 170M5145 170M5146 170M5147 170M5148 170M5149 170M5150 170M6138 170M6139 170M6140 170M6141 170M6142 170M6143 170M6144 170M6145 170M6146 170M6147 170M6148 170M6149 170M6150 170M6151 170M3188 170M3189 170M3190 170M3191 170M3192 170M3193 170M3194 170M3195 170M3196 170M3197 170M3198 170M4188 170M4189 170M4190 170M4191 170M4192 170M4193 170M4194 170M4195 170M4196 170M4197 170M5188 170M5189 170M5190 170M5191 170M5192 170M5193 170M5194 170M5195 170M5196 170M5197 170M5198 170M5199 170M5200 170M6188 170M6189 170M6190 170M6191 170M6192 170M6193 170M6194 170M6195 170M6196 170M6197 170M6198 170M6199 170M6200 170M6201 (A2S) Clearing at 1000V 815 1300 2500 4450 9000 16000 31000 54500 115000 165000 265000 11500 22500 46000 90000 125000 175000 250000 340000 465000 660000 38500 55500 77500 97500 140000 205000 285000 370000 575000 795000 1200000 1750000 2350000 58000 81500 120000 185000 235000 325000 495000 705000 995000 1500000 2150000 2800000 3950000 6000000 ® Clearing at 1250V 1100 1750 3350 5950 11500 21000 41000 73000 150000 220000 335000 15500 30000 61500 120000 165000 235000 335000 435000 590000 51500 74500 105000 135000 180000 270000 380000 495000 730000 1050000 1550000 77500 110000 160000 245000 310000 435000 665000 940000 1300000 1900000 2750000 3600000 Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Rated voltage (IEC) †1100V ‡1250V (Consult Bussmann for U.L. Recognition status.) Microswitch indicator ordered separately. See accessories on pages 58-59. Curves Carton Qty. Carton Weight (kg) See Page or (BIF #) 5 1.90 page 63 (17056630) 2 1.18 page 64 (17056632) 2 1.58 page 64 (17056634) 1 1.23 page 65 (17056636) 1 kg = 2.2 lbs. BIF document: 720029 36 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® Square Body – DIN 43 653 1250V/1300V (IEC/U.L.) 50-1400A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 K 1.25 1.0 3 2.5 1.0 Kp 0.8 UL 0.6 0.5 1.8 1.4 0.4 0.5 0.4 103 8 0.3 0.3 6 5 0.2 0.2 4 Eg 400 600 800 Eg 3 400 1000 1200 1400 600 800 Ib 0.1 1000 1200 1400 30 40 50 60 70 80 90 100% -----Dashed lines apply to the following amperages: Size Amp 1* 400 1 500-630 2 630-1000 3 800-1400 Dimensions DIN 43 653: Type -/110, -T/110 Size A B D E H 1* 1 2 3 80 80 80 81 138 138 138 139 58 66 75 90 45 53 61 76 20 25 25 30 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm 108 A H 11 D E B 6 E BIF document: 720029 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 37 Bussmann® Square Body – DIN 43 653 1250V/1300V (IEC/U.L.) 50-1400A Electrical Characteristics Size 1* 1 2 3 䡲 䡲 䡲 䡲 Rated Current RMS-Amps Pre-arc I2t (A2S) Clearing at 1000V 50 63 80 100 125 160 200 250 315 350 400 160 200 250 315 350 400 450 500 550 †630 250 280 315 350 400 450 500 550 630 700 800 †900 †1000 315 350 400 450 500 550 630 700 ‡800 ‡900 ‡1000 ‡1100 †1250 †1400 135 215 420 750 1450 2600 5150 9200 18500 27000 53000 1900 3800 7750 15000 20000 29500 42000 69500 95000 130000 6500 9350 13000 16500 23000 34000 48000 62000 115000 160000 245000 360000 480000 9500 13500 19500 31000 39000 55000 83500 115000 205000 305000 450000 575000 810000 1250000 815 1300 2500 4450 9000 16000 31000 54500 115000 165000 265000 11500 22500 46000 90000 125000 175000 250000 340000 465000 660000 38500 55500 77500 97500 140000 205000 285000 370000 575000 795000 1200000 1750000 2350000 58000 81500 120000 185000 235000 325000 495000 705000 995000 1500000 2150000 2800000 3950000 6000000 ® Ordering Information Clearing at 1250V Watts Loss -K/110 Type K Visual Indicator for Micro 1100 1750 3350 5950 11500 21000 41000 73000 150000 220000 335000 15500 30000 61500 120000 165000 235000 335000 435000 590000 15 20 25 30 35 40 45 55 60 65 70 45 50 60 65 70 75 80 85 95 100 65 70 75 80 85 90 95 100 110 115 120 125 135 85 90 95 100 105 110 115 120 125 130 135 140 145 150 170M3238 170M3239 170M3240 170M3241 170M3242 170M3243 170M3244 170M3245 170M3246 170M3247 170M3248 170M4238 170M4239 170M4240 170M4241 170M4242 170M4243 170M4244 170M4245 170M4246 170M4247 170M5238 170M5239 170M5240 170M5241 170M5242 170M5243 170M5244 170M5245 170M5246 170M5247 170M5248 170M5249 170M5250 170M6238 170M6239 170M6240 170M6241 170M6242 170M6243 170M6244 170M6245 170M6246 170M6247 170M6248 170M6249 170M6250 170M6251 51500 74500 105000 135000 180000 270000 380000 495000 730000 1050000 1550000 77500 110000 160000 245000 310000 435000 665000 940000 1300000 1900000 2750000 3600000 Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Rated voltage (IEC) †1100V ‡1250V (Consult Bussmann for U.L. Recognition status.) Microswitch indicator ordered separately. See accessories on pages 58-59. Curves Carton Qty. Carton Weight (kg) See Page or (BIF #) 2 0.84 page 63 (17056630) 2 1.26 page 64 (17056632) 2 1.66 page 64 (17056634) 1 1.27 page 65 (17056636) 1 kg = 2.2 lbs. 1 lb = 0.45 kg BIF document: 720030 38 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Square Body – DIN 43 653 1250V/1300V (IEC/U.L.) 50-1400A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 K 1.25 1.0 3 2.5 1.0 Kp 0.8 UL 0.6 0.5 1.8 1.4 0.4 0.5 0.4 103 8 0.3 0.3 6 5 0.2 0.2 4 Eg 400 600 800 Eg 3 400 1000 1200 1400 600 800 Ib 0.1 1000 1200 1400 30 40 50 60 70 80 90 100% -----Dashed lines apply to the following amperages: Size Amp 1* 400 1 500-630 2 630-1000 3 800-1400 Dimensions DIN 43 653: Type -K/110 Size 1* 1 2 3 A B D E H 80 80 80 81 138 138 138 139 59 69 77 92 45 53 61 76 20 25 25 30 108 A Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm H 11 D B E 6 E BIF document: 720030 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 39 Bussmann® Square Body – DIN 43 620 660V (IEC/U.L.) 10-315A ® Electrical Characteristics Size 000 Rated Current RMS-Amps 10 16 20 25 32 40 50 63 80 100 125 160 200 250 315 Ordering Information Pre-arc Clearing at 660V Watts Loss Protection Class DIN 000 Type T Indicator for Micro 3.8 7.2 11.5 19 40 69 115 215 380 695 1200 2300 4200 7750 12000 25.5 48 78 130 270 460 770 1450 2550 4650 8500 16000 28000 51500 80500 3.0 5.5 7 9 10 12 15 16 19 24 28 32 37 42 52 gR gR gR gR gR gR gR gR aR aR aR aR aR aR aR 170M1558 170M1559 170M1560 170M1561 170M1562 170M1563 170M1564 170M1565 170M1566 170M1567 170M1568 170M1569 170M1570 170M1571 170M1572 I2t (A2S) 䡲 Interrupting rating 300kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 Microswitch indicator ordered separately. See accessories on pages 58-59. Curves Carton Qty. Carton Weight (kg) See Page or (BIF #) 10 1.30 page 60 (17056310) 1 kg = 2.2 lbs. 1 lb = 0.45 kg Rated Current The rated current of this fuse range has been given with copper conductors that have a current density of 1.3 A/mm2 (IEC 269-4). For conductor cross section according to IEC 269-1, the fuses with a rated current higher than 125A must be derated. Please contact Bussmann for application assistance. BIF document: 720016 40 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Square Body – DIN 43 620 660V (IEC/U.L.) 10-315A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.0 Kp 0.8 0.5 0.4 1.4 1.2 103 9 8 7 6 0.3 5 K 1.0 UL 0.6 0.5 0.4 0.3 0.2 4 0.2 Eg Eg 3 100 200 300 400 500 600 660 200 300 400 500 600 660 Ib 0.1 30 40 50 60 70 80 90 100% Dimensions DIN 43 620: Type DIN 000 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm 54 Max Indicator 15 48 79 21 6 35 BIF document: 720016 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 41 Bussmann® Square Body – DIN 43 620 660V/700V (IEC/U.L.) 40-1000A Electrical Characteristics Rated Current RMS-Amps 1* 40 50 63 80 100 125 160 200 250 315 350 400 I 2t Ordering Information (A2S) Curves Carton Weight (kg) See Page or (BIF #) 170M3808 170M3809 170M3810 170M3811 170M3812 170M3813 170M3814 170M3815 170M3816 170M3817 170M3818 170M3819 5 1.85 page 61 (17056314) 65 70 75 80 90 95 170M5808 170M5809 170M5810 170M5811 170M5812 170M5813 5 3.00 page 62 (17056318) 95 100 105 110 115 120 125 170M6808 170M6809 170M6810 170M6811 170M6812 170M6813 170M6814 1 1.15 page 62 (17056320) Pre-arc Watts Loss 40 77 115 185 360 550 1100 2200 4200 7000 10000 15000 270 515 770 1250 2450 3700 7500 15000 28500 46500 68500 105000 9 11 14 18 21 26 30 35 40 50 55 60 2 400 450 500 550 630 700 11000 15500 21500 28000 41000 60500 74000 105000 145000 190000 275000 405000 3 500 550 630 700 800 900 1000 14000 19500 31000 44500 69500 100000 140000 95000 135000 210000 300000 465000 670000 945000 䡲 Interrupting rating 300kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 Microswitch indicator ordered separately. See accessories on pages 58-59. DIN Type T Indicator for Micro Carton Qty. Clearing at 660V Size ® 1 kg = 2.2 lbs. Rated Current The rated current of this fuse range has been given with copper conductors that have a current density of 1.3 A/mm2 (IEC 269-4). For conductor cross section according to IEC 269-1, the fuses must be derated. Please contact Bussmann for application assistance. BIF document: 720017 42 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® Square Body – DIN 43 620 660V/700V (IEC/U.L.) 40-1000A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.0 Kp 0.8 0.5 0.4 1.4 1.2 103 9 8 7 6 0.3 5 K 1.0 UL 0.6 0.5 0.4 0.3 0.2 4 0.2 Eg Eg 3 100 200 300 400 500 600 660 200 300 400 500 600 660 Ib 0.1 30 40 50 60 70 80 90 100% Dimensions DIN 43 620: Type DIN 1*, DIN 2, DIN 3 Size A 1* 2 3 69 69 68 B D 135 58 150 71 150 88 E F H 45 55 76 40 48 60 20 26 33 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm A Indicator H D F B E 6 BIF document: 720017 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 43 Bussmann® Square Body – Flush End Contact 660V (IEC) 25-400A Electrical Characteristics Size 00 Rated Current RMS-Amps 25 32 40 50 63 80 100 125 160 200 250 315 350 400 Ordering Information Pre-arc Clearing at 660V Watts Loss Protection Class 00B/60 Visual Indicator 00BT/60 Type T Indicator for Micro 19 28.5 50 95 170 310 620 1000 1900 3400 6250 10000 13500 18000 130 195 360 640 1200 2100 4150 6950 13000 23000 42000 68500 91500 125000 6 7 9 10 12 15 20 25 30 35 45 55 60 70 gR gR gR gR gR gR aR aR aR aR aR aR aR aR 170M2708 170M2709 170M2710 170M2711 170M2712 170M2713 170M2714 170M2715 170M2716 170M2717 170M2718 170M2719 170M2720 170M2721 170M2758 170M2759 170M2760 170M2761 170M2762 170M2763 170M2764 170M2765 170M2766 170M2767 170M2768 170M2769 170M2770 170M2771 I2t (A2S) 䡲 Interrupting rating 300kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 Microswitch indicator ordered separately. See accessories on pages 58-59. Curves Carton Qty. Carton Weight (kg) See Page or (BIF #) 5 1.35 page 60 (17056312) 1 kg = 2.2 lbs. BIF document: 720018 44 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® Square Body – Flush End Contact 660V (IEC) 25-400A Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.0 Kp 0.8 0.5 0.4 1.4 1.2 103 9 8 7 6 0.3 5 K 1.0 UL 0.6 0.5 0.4 0.3 0.2 4 0.2 Eg Eg 3 100 200 300 400 500 600 660 200 300 400 500 600 660 Ib 0.1 30 40 50 60 70 80 90 100% Dimensions Flush End Contact: Type 00B/60, 00BT/60 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm M8 Ø16 6 64 30 54 Max 48 62 Indicator BIF document: 720018 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 45 Bussmann® Square Body – Flush End Contact 660V/700V (IEC/U.L.) 40-2000A Electrical Characteristics Size 40 50 63 80 100 125 160 200 250 315 350 400 450 500 550 630 200 250 315 350 400 450 500 550 630 700 800 ‡900 400 450 500 550 630 700 800 900 1000 1100 1250 500 550 630 700 800 900 1000 1100 1250 1400 1500 1600 †1800 ‡2000 1* 1 2 3 䡲 䡲 䡲 䡲 Rated Current RMS-Amps Ordering Information Pre-arc Clearing at 660V Losses at Rated Current 40 77 115 185 360 550 1100 2200 4200 7000 10000 15000 21000 27000 34000 48500 1650 3100 6200 8500 13500 17000 25000 34000 52000 69500 105000 155000 11000 15500 21500 28000 41000 60500 86000 125000 180000 245000 365000 14000 19500 31000 44500 69500 100000 140000 190000 290000 370000 460000 580000 880000 1150000 270 515 770 1250 2450 3700 7500 15000 28500 46500 68500 105000 140000 180000 230000 325000 11500 21000 42000 59000 91500 120000 170000 230000 350000 465000 725000 ‡850000 74000 105000 145000 190000 275000 405000 575000 840000 1250000 1600000 2400000 95000 135000 210000 300000 465000 670000 945000 1300000 1950000 2450000 3100000 3900000 †5250000 ‡6350000 9 11 14 18 21 26 30 35 40 50 55 60 65 70 75 80 45 55 58 60 65 70 72 75 80 85 95 100 65 70 75 80 90 95 105 110 115 120 130 95 100 105 110 115 120 125 130 140 155 160 160 165 175 I2t (A2S) -B/Visual Indicator -BKN/Type K Indicator for Micro -G/Visual Indicator -GKN/Type K Indicator for Micro 170M3408 170M3409 170M3410 170M3411 170M3412 170M3413 170M3414 170M3415 170M3416 170M3417 170M3418 170M3419 170M3420 170M3421 170M3422 170M3423 170M4408 170M4409 170M4410 170M4411 170M4412 170M4413 170M4414 170M4415 170M4416 170M4417 170M4418 170M4419 170M5408 170M5409 170M5410 170M5411 170M5412 170M5413 170M5414 170M5415 170M5416 170M5417 170M5418 170M6408 170M6409 170M6410 170M6411 170M6412 170M6413 170M6414 170M6415 170M6416 170M6417 170M6418 170M6419 170M6420 170M6421 170M3458 170M3459 170M3460 170M3461 170M3462 170M3463 170M3464 170M3465 170M3466 170M3467 170M3468 170M3469 170M3470 170M3471 170M3472 170M3473 170M4458 170M4459 170M4460 170M4461 170M4462 170M4463 170M4464 170M4465 170M4466 170M4467 170M4468 170M4469 170M5458 170M5459 170M5460 170M5461 170M5462 170M5463 170M5464 170M5465 170M5466 170M5467 170M5468 170M6458 170M6459 170M6460 170M6461 170M6462 170M6463 170M6464 170M6465 170M6466 170M6467 170M6468 170M6469 170M6470 170M6471 170M3508 170M3509 170M3510 170M3511 170M3512 170M3513 170M3514 170M3515 170M3516 170M3517 170M3518 170M3519 170M3520 170M3521 170M3522 170M3523 170M4508 170M4509 170M4510 170M4511 170M4512 170M4513 170M4514 170M4515 170M4516 170M4517 170M4518 170M4519 170M5508 170M5509 170M5510 170M5511 170M5512 170M5513 170M5514 170M5515 170M5516 170M5517 170M5518 170M6508 170M6509 170M6510 170M6511 170M6512 170M6513 170M6514 170M6515 170M6516 170M6517 170M6518 170M6519 170M6520 170M6521 170M3558 170M3559 170M3560 170M3561 170M3562 170M3563 170M3564 170M3565 170M3566 170M3567 170M3568 170M3569 170M3570 170M3571 170M3572 170M3573 170M4558 170M4559 170M4560 170M4561 170M4562 170M4563 170M4564 170M4565 170M4566 170M4567 170M4568 170M4569 170M5558 170M5559 170M5560 170M5561 170M5562 170M5563 170M5564 170M5565 170M5566 170M5567 170M5568 170M6558 170M6559 170M6560 170M6561 170M6562 170M6563 170M6564 170M6565 170M6566 170M6567 170M6568 170M6569 170M6570 170M6571 Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Rated voltage (IEC) †600V ‡550V (Consult Bussmann for U.L. Recognition status.) Microswitch indicator ordered separately. See accessories on pages 58-59. Curves Carton Qty. Carton Weight (kg) 10 (-B/-) 2.40 10 (-G/-) 2.40 page 61 (17056314) 6 (-BKN/-) 1.62 6 (-GKN/-) 1.62 6 2.40 page 61 (17056316) 6 3.30 page 62 (17056318) 3 2.52 page 62 (17056320) 1 kg = 2.2 lbs. BIF document: 720019 46 See Page or (BIF #) For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® Square Body – Flush End Contact 660V/700V (IEC/U.L.) 40-2000A Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.4 1.2 103 9 8 7 6 1.0 Kp 0.8 K 2) 1) 1.0 0.5 0.4 UL 0.6 0.5 0.4 0.3 5 0.3 0.2 4 0.2 Eg Eg 3 200 100 200 300 400 500 600 660 300 400 500 Ib 0.1 600 660 30 40 50 60 70 80 90 100% 1) Rated voltage 600V 2) Rated voltage 550V Dimensions Flush End Contact: Type -B/-, -BKN/-, -G/-, -GKN/Size A B D E F 1* 1 2 3 50 50 50 51 51 51 51 53 59 69 77 92 45 53 61 76 M8 M8 M10 M12 F§ fiΩ¡§∑ - 18 UNC-2B fiΩ¡§∑ - 18 UNC-2B ‹Ω•∑ - 16 UNC-2B ⁄Ω™∑ - 13 UNC-2B G H 5 8 10 10 ø17 ø20 ø24 ø30 B § Valid for fuses type -G/- & -GKN/NB: B = 65 for Size 2, 1100-1250A Size 3, 1600-2000A Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm Carton Quantity = 4 Carton Quantity = 2 Carton Weight = 2.40 kg Carton Weight = 1.82 kg D A E F E H G BIF document: 720019 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 47 Bussmann® Square Body – Flush End Contact 660V (IEC) 1000-4000A Electrical Characteristics Size 4 䡲 䡲 䡲 䡲 䡲 Rated Current RMSNorm. Cool. Rated Current RMSLiquid Cool. 1000 1250 1400 1600 2000 2500 3000 3500 †4000 1350 1700 1900 2200 2700 3400 4100 4700 †5400 Ordering Information Pre-arc Clearing at 660V Watts Loss Norm. Cool. 76000 145000 205000 305000 600000 1200000 2000000 3250000 4700000 505000 965000 1400000 2050000 3950000 7800000 13500000 22000000 †23000000 175 195 205 220 245 275 305 325 355 I2t (A2S) Watts Loss Liquid Cool. 315 355 375 405 445 495 555 585 640 -B/Visual Indicator -BK/Type K Indicator for Micro -G/Visual Indicator -GK/Type K Indicator for Micro 170M7058 170M7059 170M7060 170M7061 170M7062 170M7063 170M7064 170M7065 170M7066 170M7078 170M7079 170M7080 170M7081 170M7082 170M7083 170M7084 170M7085 170M7086 170M7098 170M7099 170M7100 170M7101 170M7102 170M7103 170M7104 170M7105 170M7106 170M7118 170M7119 170M7120 170M7121 170M7122 170M7123 170M7124 170M7125 170M7126 Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Rated voltage (IEC) †500V Liquid Cool. = Liquid cooling. Temperature on the terminals not to exceed 60°C. Microswitch indicator ordered separately. See accessories on pages 58-59. Curves Carton Carton Weight Qty. (kg) 2 page 63 1.80 (17056328) 1 kg = 2.2 lbs. BIF document: 720020 48 See Page or (BIF #) For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® Square Body – Flush End Contact 660V (IEC) 1000-4000A Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.4 1.2 103 9 8 7 6 1.0 Kp 0.8 K 1.0 1) 0.5 0.4 UL 0.6 0.5 0.4 0.3 5 0.3 0.2 4 0.2 Eg Eg 3 200 100 200 300 400 500 600 660 300 400 500 600 660 Ib 0.1 30 40 50 60 70 80 90 100% 1) Rated voltage 500V Dimensions Flush End Contact: Type 4B/-, 4BKN/-, 4G/-, 4GKN/Size 4B 4G F M10 10 deep ⁄Ω™∑ -13 UNC-2B 10 deep G 33 38 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm 105 F Ø4 G 105 15 Ø56 67 53 BIF document: 720020 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 49 Bussmann® Square Body – Flush End Contact 1250V/1300V (IEC/U.L.) Electrical Characteristics Rated Current I2t (A2S) RMSClearing Clearing Size Amps Pre-arc at 1000V at 1250V 50 135 815 1100 63 215 1300 1750 80 420 2500 3350 100 750 4450 5950 125 1450 9000 11500 1* 160 2600 16000 21000 200 5150 31000 41000 250 9200 54500 73000 315 18500 115000 150000 350 27000 165000 220000 400 53000 265000 335000 160 1900 11500 15500 200 3800 22500 30000 250 7750 46000 61500 315 15000 90000 120000 1 350 20000 125000 165000 400 29500 175000 235000 450 42000 250000 335000 500 69500 340000 435000 550 95000 465000 590000 630 130000 660000 250 6500 38500 51500 280 9350 55500 74500 315 13000 77500 105000 350 16500 97500 135000 400 23000 140000 180000 450 34000 205000 270000 2 500 48000 285000 380000 550 62000 370000 495000 630 115000 575000 730000 700 160000 795000 1050000 800 245000 1200000 1550000 †900 360000 1750000 †1000 480000 2350000 315 9500 58000 77500 350 13500 81500 110000 400 19500 120000 160000 450 31000 185000 245000 500 39000 235000 310000 550 55000 325000 435000 630 83500 495000 665000 3 700 115000 705000 940000 800 205000 995000 1300000 900 305000 1500000 1900000 1000 450000 2150000 2750000 1100 575000 2800000 3600000 †1250 810000 3950000 †1400 1250000 6000000 䡲 䡲 䡲 䡲 Watts Loss 15 20 25 30 35 40 45 55 60 65 70 45 50 60 65 70 75 80 85 95 100 65 70 75 80 85 90 95 100 110 115 120 125 135 85 90 95 100 105 110 115 120 125 130 135 140 145 150 -BK/75 Type K Indicator for Micro 170M3388 170M3389 170M3390 170M3391 170M3392 170M3393 170M3394 170M3395 170M3396 170M3397 170M4388 170M4389 170M4390 170M4391 170M4392 170M4393 170M4394 †170M4395 ‡170M4396 ‡170M4397 170M5388 170M5389 170M5390 170M5391 170M5392 170M5393 170M5394 170M5395 †170M5396 ‡170M5397 ‡170M5398 170M6338 170M6339 170M6340 170M6341 170M6342 170M6343 170M6344 170M6345 †170M6346 ‡170M6347 ‡170M6348 ‡170M6349 50-1400A Ordering Information -BK/80 -BK/90 -GK/75 Type K Type K Type K Indicator Indicator Indicator for Micro for Micro for Micro 170M3438 170M3488 170M3439 170M3489 170M3440 170M3490 170M3441 170M3491 170M3442 170M3492 170M3443 170M3493 170M3444 170M3494 170M3445 170M3495 170M3446 170M3496 170M3447 170M3497 170M3448 170M4438 170M4488 170M4439 170M4489 170M4440 170M4490 170M4441 170M4491 170M4442 170M4492 170M4443 170M4493 170M4444 170M4494 170M4445 †170M4495 170M4446 ‡170M4496 †170M4447 ‡170M4497 170M5438 170M5588 170M5439 170M5589 170M5440 170M5590 170M5441 170M5591 170M5442 170M5592 170M5443 170M5593 170M5444 170M5494 170M5594 170M5445 170M5495 170M5595 170M5446 170M5496 †170M5596 †170M5447 170M5497 ‡170M5597 ‡170M5448 170M5498 ‡170M5598 170M5499 170M5500 170M6538 170M6588 170M6539 170M6589 170M6540 170M6590 170M6541 170M6591 170M6542 170M6592 170M6543 170M6593 170M6544 170M6494 170M6594 170M6545 170M6495 170M6595 170M6546 ¥170M6496 †170M6596 †170M6547 ¥170M6497 ‡170M6597 †170M6548 ¥170M6498 ‡170M6598 ‡170M6549 ¥170M6499 ‡170M6599 170M6500 170M6501 Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Rated voltage (IEC) †1100V ‡1000V ¥1250V (Consult Bussmann for U.L. Recognition status.) Individual Fuse Weight: Size 1* = 0.380 kg Size 1 = 0.580 kg Size 2 = 0.900 kg Size 3 = 1.250 kg 䡲 Microswitch indicator ordered separately. See accessories on pages 58-59. ® Curves -GK/90 Type K Indicator for Micro page 63 (17056630) page 64 (17056632) 170M5644 170M5645 170M5646 170M5647 170M5648 170M5649 170M5650 170M6644 170M6645 ¥170M6646 ¥170M6647 ¥170M6648 ¥170M6649 170M6650 170M6651 1 kg = 2.2 lbs. BIF document: 720031 50 See Page or (BIF #) For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 page 64 (17056634) page 65 (17056636) 1 lb = 0.45 kg Bussmann® Square Body – Flush End Contact 1250V/1300V (IEC/U.L.) 50-1400A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 K 1.25 1.0 3 2.5 1.0 Kp 0.8 UL 0.6 0.5 1.8 1.4 0.4 0.5 0.4 103 8 0.3 0.3 6 5 0.2 0.2 4 Eg 400 600 800 Eg 3 400 1000 1200 1400 600 800 Ib 0.1 30 40 50 1000 1200 1400 60 70 80 90 100% -----Dashed lines apply to the following amperages: Size Amp 1* 400 1 500-630 2 630-1000 3 800-1400 Dimensions Flush End Contact: Type -BK/-, -GK/- B D A E F E H G Size 1* 1* 1 1 2 2 2 3 3 3 Type BK + GK/75 BK/80 BK + GK/75 BK/80 BK + GK/75 BK/80 BK + GK/90 BK + GK/75 BK/80 BK + GK/90 A 74 80 74 80 74 80 80 74 81 81 B 75 81 75 81 75 81 91 76 83 91 D 59 59 69 69 77 77 77 92 92 92 E 45 45 53 53 61 61 61 76 76 76 F M8 M8 M8 M8 M10 M10 M10 M12 M12 M12 F§ fiΩ¡§∑ - 18 UNC-2B fiΩ¡§∑ - 18 UNC-2B ‹Ω•∑ - 16 UNC-2B ‹Ω•∑ - 16 UNC-2B ⁄Ω™∑ - 13 UNC-2B ⁄Ω™∑ - 13 UNC-2B G 5 5 8 8 10 10 10 10 10 10 H Ø17 Ø17 Ø20 Ø20 Ø24 Ø24 Ø24 Ø30 Ø30 Ø30 § Valid for fuses type -GK/Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720031 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 51 Bussmann® Square Body – French Style 660V/700V (IEC/U.L.) 40-1500A Electrical Characteristics Size 1* 1 2 3 I2t ® Ordering Information (A2S) -E/ Type T Indicator For Micro -EK/ Type K Indicator for Micro Rated Current RMS-Amps Pre-arc Clearing at 660V 40 50 63 80 100 125 160 200 250 315 350 400 450 500 40 77 115 185 360 550 1100 2200 4200 7000 10000 15000 21000 27000 270 515 770 1250 2450 3700 7500 15000 28500 46500 68500 105000 140000 180000 9 11 14 18 21 26 30 35 40 50 55 60 65 70 170M3308 170M3309 170M3310 170M3311 170M3312 170M3313 170M3314 170M3315 170M3316 170M3317 170M3318 170M3319 170M3320 170M3321 170M3358 170M3359 170M3360 170M3361 170M3362 170M3363 170M3364 170M3365 170M3366 170M3367 170M3368 170M3369 170M3370 170M3371 200 250 315 350 400 450 500 550 630 700 800 400 450 500 550 630 700 800 900 1000 1650 3100 6200 8500 13500 17000 25000 34000 52000 69500 105000 11000 15500 21500 28000 41000 60500 86000 125000 180000 11500 21000 42000 59000 91500 120000 170000 230000 350000 465000 725000 74000 105000 145000 190000 275000 405000 575000 840000 1250000 45 55 58 60 65 70 72 75 80 85 95 65 70 75 80 90 95 105 110 115 170M4308 170M4309 170M4310 170M4311 170M4312 170M4313 170M4314 170M4315 170M4316 170M4317 170M4318 170M5308 170M5309 170M5310 170M5311 170M5312 170M5313 170M5314 170M5315 170M5316 170M4358 170M4359 170M4360 170M4361 170M4362 170M4363 170M4364 170M4365 170M4366 170M4367 170M4368 170M5358 170M5359 170M5360 170M5361 170M5362 170M5363 170M5364 170M5365 170M5366 500 550 630 700 800 900 1000 1100 1250 1400 1500 14000 19500 31000 44500 69500 100000 140000 190000 290000 370000 460000 95000 135000 210000 300000 465000 670000 945000 1300000 1950000 2450000 3100000 95 100 105 110 115 120 125 130 140 155 160 170M6308 170M6309 170M6310 170M6311 170M6312 170M6313 170M6314 170M6315 170M6316 170M6317 170M6318 170M6358 170M6359 170M6360 170M6361 170M6362 170M6363 170M6364 170M6365 170M6366 170M6367 170M6368 Watts Loss 䡲 Interrupting rating 300kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 Microswitch indicator ordered separately. See accessories on pages 58-59. Curves Carton Qty. Carton Weight (kg) See Page or (BIF #) 1 0.300 page 61 (17056314) 1 0.470 page 61 (17056316) 1 0.620 page 62 (17056318) 1 0.930 page 62 (17056320) 1 kg = 2.2 lbs. BIF document: 720022 52 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® Square Body – French Style 660V/700V (IEC/U.L.) 40-1500A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.4 1.2 103 9 8 7 6 1.0 Kp 0.8 K 1.0 0.5 0.4 UL 0.6 0.5 0.4 0.3 5 0.3 0.2 4 0.2 Eg Eg 3 200 100 200 300 400 500 600 660 300 400 500 Ib 0.1 600 660 30 40 50 60 70 80 90 100% Dimensions French Style: Type -E/-, -EK/Size A B C D E H I J 1* 1 2 3 50 50 50 51 102 111 126 126 76 86 91 91 59 69 77 92 45 53 61 76 18 25 30 36 9 11 13 13 13 11 12 13 C Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm A H I D J B E 6 E BIF document: 720022 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 53 Bussmann® Square Body – US Style 660V/700V (IEC) 40-2000A Electrical Characteristics Rated Current Size RMS-Amps 40 50 63 80 100 125 160 200 250 315 350 400 450 500 550 630 200 250 315 350 400 450 500 550 630 700 800 ‡900 400 450 500 550 630 700 800 900 1000 1100 1250 500 550 630 700 800 900 1000 1100 1250 1400 1500 1600 †1800 ‡2000 1* 1 2 3 䡲 䡲 䡲 䡲 I2t Ordering Information Watts Loss -FU/Without Indicator -FKE/Type K Indicator for Micro 9 11 14 18 21 26 30 35 40 50 55 60 65 70 75 80 45 55 58 60 65 70 72 75 80 85 95 100 65 70 75 80 90 95 105 110 115 120 130 95 100 105 110 115 120 125 130 140 155 160 160 165 175 170M3608 170M3609 170M3610 170M3611 170M3612 170M3613 170M3614 170M3615 170M3616 170M3617 170M3618 170M3619 170M3620 170M3621 170M3622 170M3623 170M4608 170M4609 170M4610 170M4611 170M4612 170M4613 170M4614 170M4615 170M4616 170M4617 170M4618 170M4619 170M5608 170M5609 170M5610 170M5611 170M5612 170M5613 170M5614 170M5615 170M5616 170M5617 170M5618 170M6608 170M6609 170M6610 170M6611 170M6612 170M6613 170M6614 170M6615 170M6616 170M6617 170M6618 170M6619 170M6620 170M6621 170M3658 170M3659 170M3660 170M3661 170M3662 170M3663 170M3664 170M3665 170M3666 170M3667 170M3668 170M3669 170M3670 170M3671 170M3672 170M3673 170M4658 170M4659 170M4660 170M4661 170M4662 170M4663 170M4664 170M4665 170M4666 170M4667 170M4668 170M4669 170M5658 170M5659 170M5660 170M5661 170M5662 170M5663 170M5664 170M5665 170M5666 170M5667 170M5668 170M6658 170M6659 170M6660 170M6661 170M6662 170M6663 170M6664 170M6665 170M6666 170M6667 170M6668 170M6669 170M6670 170M6671 (A2S) Pre-arc Clearing at 660V 40 77 115 185 360 550 1100 2200 4200 7000 10000 15000 21000 27000 34000 48500 1650 3100 6200 8500 13500 17000 25000 34000 52000 69500 105000 155000 11000 15500 21500 28000 41000 60500 86000 125000 180000 245000 365000 14000 19500 31000 44500 69500 100000 140000 190000 290000 370000 460000 580000 880000 1150000 270 515 770 1250 2450 3700 7500 15000 28500 46500 68500 105000 140000 180000 230000 325000 11500 21000 42000 59000 91500 120000 170000 230000 350000 465000 725000 ‡850000 74000 105000 145000 190000 275000 405000 575000 840000 1250000 1600000 2400000 95000 135000 210000 300000 465000 670000 945000 1300000 1950000 2450000 3100000 3900000 †5250000 ‡6350000 ® Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Rated voltage (IEC) †600V ‡550V (Consult Bussmann for U.L. Recognition status.) Microswitch indicator ordered separately. See accessories on pages 58-59. -FU/115 Without Indicator -FKE/115 Type K Indicator for Micro 170M3708 170M3709 170M3710 170M3711 170M3712 170M3713 170M3714 170M3715 170M3716 170M3717 170M3718 170M3719 170M3720 170M3721 170M3722 170M3723 170M4708 170M4709 170M4710 170M4711 170M4712 170M4713 170M4714 170M4715 170M4716 170M4717 170M4718 170M4719 170M5708 170M5709 170M5710 170M5711 170M5712 170M5713 170M5714 170M5715 170M5716 170M5717 170M5718 170M6708 170M6709 170M6710 170M6711 170M6712 170M6713 170M6714 170M6715 170M6716 170M6717 170M6718 170M6719 170M6720 170M6721 170M3758 170M3759 170M3760 170M3761 170M3762 170M3763 170M3764 170M3765 170M3766 170M3767 170M3768 170M3769 170M3770 170M3771 170M3772 170M3773 170M4758 170M4759 170M4760 170M4761 170M4762 170M4763 170M4764 170M4765 170M4766 170M4767 170M4768 170M4769 170M5758 170M5759 170M5760 170M5761 170M5762 170M5763 170M5764 170M5765 170M5766 170M5767 170M5768 170M6758 170M6759 170M6760 170M6761 170M6762 170M6763 170M6764 170M6765 170M6766 170M6767 170M6768 170M6769 170M6770 170M6771 Curves Carton Qty. Carton Weight (kg) See Page or (BIF #) 1 0.340 page 61 (17056314) 1 0.500 page 61 (17056316) 1 0.630 page 62 (17056318) 1 0.950 page 62 (17056320) 1 kg = 2.2 lbs. BIF document: 720023 54 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® Square Body – US Style 660V/700V (IEC) 40-2000A Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 1.0 Kp 0.8 0.5 0.4 1.4 1.2 103 9 8 7 6 0.3 5 0.2 4 K 2) 1) 1.0 UL 0.6 0.5 0.4 0.3 0.2 Eg Eg 3 100 200 300 400 500 600 660 200 300 400 500 600 660 Ib 0.1 30 40 50 60 70 80 90 100% 1) Rated voltage 600V 2) Rated voltage 550V Dimensions US Style: Type -FU/-, -FKE/-, FU/115-, -FKE/115 B§ Size A B 1* 1 2 3 50 50 50 51 110 136 135 135 C1 C1§ C2 C2§ D E H I 148 85 157 104 159 105 155 106 123 126 125 125 72 78 78 77 110 100 99 97 59 69 77 92 45 53 61 76 20 25 25 36 10 14 14 16 § Valid for fuses type -FU/115 & -FKE/115 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm B 6 A D C1 E C2 E I H BIF document: 720023 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 55 Bussmann® Square Body – US Style 1250V/1300V (IEC/U.L.) 50-1400A Electrical Characteristics Size 50 63 80 100 125 160 200 250 315 350 160 200 250 315 350 400 450 †500 †550 ‡630 250 280 315 350 400 450 500 550 630 †700 †800 ‡900 ‡1000 315 350 400 450 500 550 630 700 800 900 ¥1000 ¥1100 ¥1250 ¥1400 1* 1 2 3 䡲 䡲 䡲 䡲 ¥ Rated Current RMS-Amps Pre-arc I2t (A2S) Clearing at 1000V 135 215 420 750 1450 2600 5150 9200 18500 27000 1900 3800 7750 15000 20000 29500 42000 69500 95000 130000 6500 9350 13000 16500 23000 34000 48000 62000 115000 160000 245000 360000 480000 9500 13500 19500 31000 39000 55000 83500 115000 205000 305000 450000 575000 810000 1250000 815 1300 2500 4450 9000 16000 31000 54500 115000 165000 11500 22500 46000 90000 125000 175000 250000 340000 465000 660000 38500 55500 77500 97500 140000 205000 285000 370000 575000 795000 1200000 1750000 2350000 58000 81500 120000 185000 235000 325000 495000 705000 995000 1500000 2150000 2800000 3950000 6000000 ® Ordering Information Clearing at 1250V Watts Loss -FU/115 Visual Indicator -FKE/115 Type K Indicator for Micro 1100 1750 3350 5950 11500 21000 41000 73000 150000 220000 15500 30000 61500 120000 165000 235000 335000 15 20 25 30 35 40 45 55 60 65 45 50 60 65 70 75 80 85 95 100 65 70 75 80 85 90 95 100 110 115 120 125 135 185 90 95 100 105 110 115 120 125 130 135 140 145 150 170M3688 170M3689 170M3690 170M3691 170M3692 170M3693 170M3694 170M3695 170M3696 170M3697 170M4688 170M4689 170M4690 170M4691 170M4692 170M4693 170M4694 170M4695 170M4696 170M4697 170M5688 170M5689 170M5690 170M5691 170M5692 170M5693 170M5694 170M5695 170M5696 170M5697 170M5698 170M5699 170M5700 170M6688 170M6689 170M6690 170M6691 170M6692 170M6693 170M6694 170M6695 170M6696 170M6697 †170M6698 †170M6699 ‡170M6700 ‡170M6701 170M3738 170M3739 170M3740 170M3741 170M3742 170M3743 170M3744 170M3745 170M3746 170M3747 170M4738 170M4739 170M4740 170M4741 170M4742 170M4743 170M4744 170M4745 170M4746 170M4747 170M5738 170M5739 170M5740 170M5741 170M5742 170M5743 170M5744 170M5745 170M5746 170M5747 170M5748 170M5749 170M5750 170M6738 170M6739 170M6740 170M6741 170M6742 170M6743 170M6744 170M6745 170M6746 170M6747 †170M6748 †170M6749 ‡170M6750 ‡170M6751 51500 74500 105000 135000 180000 270000 380000 495000 730000 77500 110000 160000 245000 310000 435000 665000 940000 1300000 1900000 Interrupting rating 300kA RMS Symmetrical. Watts loss provided at rated current. Rated voltage (IEC) †1100 ‡1000V (Consult Bussmann for U.L. Recognition status.) Microswitch indicator ordered separately. See accessories on pages 58-59. U.L. Recognition at 1000V. Carton Qty. Curves Carton Weight (kg) 1 0.425 page 63 (17056630) 1 0.675 page 64 (17056632) 1 0.740 page 64 (17056634) 1 1.250 page 65 (17056636) 1 kg = 2.2 lbs. 1 lb = 0.45 kg BIF document: 720032 56 See Page or (BIF #) For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Square Body – US Style 1250V/1300V (IEC/U.L.) 50-1400A Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.5 K 1.25 1.0 3 2.5 1.0 Kp 0.8 UL 0.6 0.5 1.8 1.4 0.4 0.5 0.4 103 8 0.3 0.3 6 5 0.2 0.2 4 Eg 400 600 800 Eg 3 400 1000 1200 1400 600 800 1000 1200 1400 Ib 0.1 30 40 50 60 70 80 90 100% -----Dashed lines apply to the following amperages: Size Amp 1* 400 1 500-630 2 630-1000 3 800-1400 Dimensions US Style: Type -FU/115, -FKE/115 Size 1* 1 2 3 B C1 C2 D E H I 156 160 160 159 130 127 127 128 101 102 102 101 59 69 77 92 45 53 61 76 20 25 25 36 10 14 14 16 B Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm 6 74 D C1 E C2 E I H BIF document: 720032 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 57 Bussmann® Square Body – Accessories Indicator System ® Indicators Typower ZILOX fuses are available with three different indicator systems. Visual Indicator The indicator situated in one cover plate is clearly visible as soon as the fuse has operated. The minimum voltage for operating the indicator is 20V. Type T Indicator The indicator is situated on one cover plate with a cover plate tag to accommodate an auxiliary switch. The minimum voltage for operating the indicator is 20V. A special low voltage indicator (1.5V) is available on request. Type K Indicator This indicator is situated on the fuse body. It is covered by an adaptor for snap-on mounting of an auxiliary switch. The operating voltage of the indicator is 1.5V. As a matter of safety, the factory mounted adaptor must not be removed from the fuse. Microswitch The Typower ZILOX fuses with either type T indicator or type K indicator can be equipped with a microswitch for remote electrical indication of fuse operations. All microswitches have one normally open and one normally closed contact. Ratings are 2A, 250 Vac. Microswitch 170H0235 170H0236 170H0237 170H0238 170H0069 6.3 x 0.8 mm Lugs ≈ ≈ ≈ ≈ 000 00 1* 1 2 3 Indicator Type T T T T K ≈ DIN 43 653 Size 2.8 x 0.5 mm Lugs Type T 170H0236 170H0238 170H0235 170H0237 170H0235 170H0237 170H0235 170H0237 170H0235 170H0237 170H0235 170H0237 4 23 24 Type K DIN 43 620 Type T 170H0236 170H0238 Type K French Style Type T Type K Flush End Type T Type K 170H0069 170H0069 170H0069 170H0069 170H0069 170H0069 170H0069 170H0069 170H0069 170H0069 170H0069 170H0069 170H0235 170H0237 170H0069 170H0235 170H0237 170H0069 170H0069 170H0069 170H0235 170H0237 170H0236 170H0238 170H0236 170H0238 170H0236 170H0238 170H0236 170H0238 170H0236 170H0238 170H0069 170H0069 170H0069 BIF document: 720034 58 US Style Type K For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Square Body – Accessories Fuse Bases (Blocks) ® DIN 43 653 Fuse Bases For the Typower ZILOX fuses according to DIN 43 653, the following fuse bases are available: Part Number 170H3003 170H3004 170H3005 170H3006 Max. Voltage 1000V 1000V 1400V 1400V Rated Current 630A 1250A 630A 1250A DIN 43 653 Center Distance 80mm 80mm 110mm 110mm The fuse bases rated 1250A can also be used for the fuses with higher rated current if the maximum load current is derated according to the table below: Fuse Rating 1400A 1500A 1600A 1800A 2000A Max. Load Current In Fuse Base 1325A 1400A 1500A 1650A 1800A Fixed Center Base Style Max. Voltage 170H1007 1000V 170H1013 660V U.L. Recognized to U.L. 512. Max. Fuse Current Rating 400A 200A Universal Fuse Size 00, 000 0000,000 Universal Fuse Bases For the Typower ZILOX fuses according to DIN 43 653, French style and North American style, the following fuse bases are available: Modular Base Style 1BS101 1BS102 1BS103 1BS104 BH-0 BH-1 BH-2 BH-3 Max. Voltage 600V 600V 600V 600V 700V 2500V 5000V 1250V Max. Fuse Current Rating 100A 400A 400A 600A 100A 400A 400A 700A BIF Document 1206 1207 1208 1209 1200 1201 1202 1203 DIN 43 620 Modular fuse bases are U.L. Recognized to U.L. 512 and meet the spacing requirements of U.L. 347. Contact Bussmann sales representative for more complete ordering information. DIN 43 620 Fuse Bases For fuse bases used with Typower ZILOX fuses according to DIN 43 620, please contact your local Bussmann sales representative. BIF document: 720036 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 59 Bussmann® Square Body Curves 25A 32A 40A 50A 63A 80A 100A 125A 160A 200A 250A 315A 350A 400A 80A 100A 125A 160A 200A 250A 315A 32A 40A 50A 63A Time-Current Curve 16A 20A 25A Size 00: 660V (25-400)A Time-Current Curve 10A Size 000: 660V (10-315)A 104 104 103 103 102 102 Virtual Pre-Arcing Time In Seconds A A 101 100 10–1 10–1 10–3 10–3 1x101 102 103 Prospective Current In Amperes RMS 104 Peak Let-Through Curve 1x10–4 315A B 103 250A 200A 160A 125A 100A 80A 63A 50A 40A 32A 25A 20A 16A 10A 104 400A 350A 315A 250A 200A 160A 125A 100A 80A 63A 50A 40A 32A 25A 104 B 103 A A 1 2x10 1x101 102 103 104 Prospective Short-Circuit Current Symmetrical RMS BIF document: 17056310 60 102 103 Prospective Current in Amperes RMS 102 102 2x10 1x101 Peak Let-Through Curve 104 Peak Let-Through Current 100 10–2 1x10–4 A 101 10–2 Peak Let-Through Current Virtual Pre-Arcing Time In Seconds A 105 1 1x101 102 103 104 Prospective Short-Circuit Current Symmetrical RMS BIF document: 17056312 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 105 Bussmann® Square Body Curves Time-Current Curve 200A 250A 40A 50A 63A 80A 100A 125A 160A 200A 250A 315A 315A 350A 400A 450A 500A 550A 630A 700A 800A 900A Size 1: 660V (200-900)A Time-Current Curve 350A 400A 450A 500A 550A 630A Size 1*: 660V (40-630)A 104 104 103 103 102 102 A A A 101 Virtual Pre-Arcing Time In Seconds Virtual Pre-Arcing Time In Seconds A 100 10–1 10–2 101 100 10–1 10–3 10–2 1x10–4 3x101 102 103 Prospective Current In Amperes RMS 104 105 10–3 1x10–4 1x102 103 104 105 Prospective Current In Amperes RMS Peak Let-Through Curve Peak Let-Through Curve 105 105 B 630A 550A 500A 450A 400A 350A 315A 250A 200A 160A 125A 100A 80A 63A 50A 40A 104 900A 700A 550A 450A 350A Peak Let-Through Current Peak Let-Through Current B 250A 200A 104 103 103 A A 2x102 800A 630A 500A 400A 315A 2x102 1x102 103 104 105 Prospective Short-Circuit Current Symmetrical RMS 106 1x102 103 104 105 106 Prospective Short-Circuit Current Symmetrical RMS 900 amp fuse is derated to 550V (IEC). BIF document: 17056314 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 BIF document: 17056316 61 Bussmann® Square Body Curves Size 3: 660V (500-2000)A Time-Current Curve Time-Current Curve 104 104 103 103 102 102 A A Virtual Pre-Arcing Time In Seconds Virtual Pre-Arcing Time In Seconds A 101 100 10–1 100 10–1 10–2 10–3 10–3 1x102 103 104 105 1x10–4 1x102 Prospective Current In Amperes RMS Peak Let-Through Curve 103 104 Prospective Current In Amperes RMS 106 B 1250A 1000A 800A 630A 500A 400A 105 1100A 900A 700A 550A 450A Peak Let-Through Current B 1800A 1500A 1250A 1000A 800A 630A 500A 105 104 104 A A 2x103 2x103 1x103 104 105 106 Prospective Short-Circuit Current Symmetrical RMS 107 1x103 104 105 106 Prospective Short-Circuit Current Symmetrical RMS 1800 amp fuse is derated to 600V (IEC). 2000 amp fuse is derated to 550V (IEC). BIF document: 17056318 62 105 Peak Let-Through Curve 106 Peak Let-Through Current A 101 10–2 1x10–4 500A 550A 630A 700A 800A 900A 1000A 1100A 1250A 1400A 1500A 1600A 1800A 2000A 400A 450A 500A 550A 630A 700A 800A 900A 1000A 1100A 1250A Size 2: 660V (400-1250)A BIF document: 17056320 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 107 2000A 1600A 1400A 1100A 900A 700A 550A Bussmann® Square Body Curves Size 1*: 1250V (50-400)A Time-Current Curve Time-Current Curve 50A 63A 80A 100A 125A 160A 200A 250A 315A 350A 400A 1000A 1250A 1400A 1600A 2000A 2200A 2500A 3000A 3500A 4000A Size 4: 660V (1000-4000)A 104 104 103 103 102 102 Virtual Pre-Arcing Time In Seconds A Virtual Pre-Arcing Time In Seconds A A 101 10 0 A 101 100 10–1 10–1 10–2 10–2 10–3 10–3 1x10–4 1x10–4 1x103 104 105 Prospective Current in Amperes RMS 5x101 102 103 104 Prospective Current In Amperes RMS 105 106 Peak Let-Through Curve Peak Let-Through Curve 105 106 B 10 4000A 3500A 3000A 2500A 2200A 2000A 1600A 1400A 1250A 1000A 5 Peak Let-Through Current Peak Let-Through Current B 400A 350A 315A 250A 200A 160A 125A 100A 80A 63A 50A 104 103 104 A A 2x10 2x103 2 1x102 1x103 104 105 106 107 103 104 105 Prospective Short-Circuit Current Symmetrical RMS 106 Prospective Short-Circuit Current Symmetrical RMS 4000 amp fuse is derated to 500V (IEC). BIF document: 17056328 BIF document: 17056630 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 63 Bussmann® Square Body Curves Size 2: 1250V (250-1000)A Time-Current Curve Time-Current Curve 160A 200A 250A 315A 350A 400A 450A 500A 550A 630A 250A 280A 315A 350A 400A 450A 500A 550A 630A 700A 800A 900A 1000A Size 1: 1250V (160-630)A 104 104 103 103 102 102 A A 101 Virtual Pre-Arcing Time In Seconds Virtual Pre-Arcing Time In Seconds A 100 10–1 A 101 100 10–1 10–2 10–2 10–3 10–3 1x10–4 1x102 103 104 Prospective Current In Amperes RMS 105 Peak Let-Through Curve 1x10–4 103 104 Prospective Current In Amperes RMS 105 B 104 103 B Peak Let-Through Current 630A 550A 500A 450A 400A 350A 315A 250A 200A 160A 1000A 900A 800A 700A 630A 550A 500A 450A 400A 315A 350A 280A 250A 104 103 A A 2x102 2x102 1x102 103 104 105 Prospective Short-Circuit Current Symmetrical RMS 106 1x102 103 104 105 Prospective Short-Circuit Current Symmetrical RMS 630 amp fuse is derated to 1100V (IEC). 900-1000 amp fuses are derated to 1100V (IEC). BIF document: 17056632 BIF document: 17056634 64 105 Peak Let-Through Curve 105 Peak Let-Through In Amperes 1x102 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 106 Bussmann® Square Body Curves Size 3: 1250V (315-1400)A 315A 350A 400A 450A 500A 550A 630A 700A 800A 900A 1000A 1100A 1250A 1400A Time-Current Curve 104 103 Virtual Pre-Arcing Time In Seconds 102 A A 101 100 10–1 10–2 10–3 1x10–4 1x102 103 104 Prospective Current In Amperes RMS 105 Peak Let-Through Curve 1400A 105 Peak Let-Through Current B 1250A 1100A 1000A 900A 800A 700A 630A 550A 500A 450A 400A 350A 315A 104 103 A 2x102 1x102 103 104 105 Prospective Short-Circuit Current Symmetrical RMS 106 1250-1400 amp fuses are derated to 1100V (IEC). BIF document: 17056636 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 65 Bussmann® British Style BS 88 Introduction Table of Contents Fuse Style Ampere Range Page 240V 690V 6-900A 6-700A 68-69 70-71 Accessories Indicator System & Fuse Bases 72 Curves Time-Current & Peak Let-Through 73-77 General Information Designed and tested to: • BS 88: Part 4 • IEC 269: Part 4 • U.L. Recognized Bussmann offers the industry’s widest range of British style semiconductor fuses and accessories. Bussmann British style products use innovative arc quenching techniques and high grade materials to provide: British style fuses are typically found in equipment manufactured in the United Kingdom or British Commonwealth countries. However, North American manufacturers have begun to specify British style fuses — particularly in UPS applications at 240 volts or less — to take advantage of their size, performance and cost benefits. Voltage Rating All Bussmann British style fuses are tested to IEC 269: Part 4. This standard requires a test voltage which is 5% higher than the rated voltage. In North America, fuses are required to clear only their rated voltage. Accessories Trip-indicator fuses are available for use in parallel with the main fuse. Indicator fuses can be attached to the associated fuselink, or mounted separately in panel-mounted fuseclips. In addition, a push-on adaptor and microswitch attachment are available, to provide remote indication. Fuseblocks are also available for most applications. Voltage 240 150 690 450 AC X — X — DC — X — X Ampere Range 6-900 6-900 6-700 6-700 • Minimal energy let-through (I2t) • Excellent DC performance • Good surge withstand profile For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 67 Bussmann® British Style BS 88 240V Type Rated Current RMS-Amps LCT LET LMT LMMT 䡲 䡲 䡲 䡲 䡲 6-900A ® Electrical Characteristics I2t (A2S) Clearing Clearing Pre-arc at 120V at 240V 6 10 12 16 20 25 32 35 50 63 80 100 125 160 180 160 200 250 315 355 400 450 400 500 630 710 800 900 2 3.8 7 20 25 18 32 50 100 180 300 600 600 1100 1600 1100 1500 3200 6000 8000 14000 18000 6000 14000 24000 32000 52000 75000 6 12 22 50 80 120 200 320 500 1100 1900 3800 3800 7000 12000 7000 10000 20000 35000 50000 70000 100000 35000 80000 150000 200000 300000 400000 9 22 32 100 160 250 450 600 1400 2200 3800 7500 7500 16000 29000 16000 20000 40000 75000 100000 160000 220000 80000 170000 300000 460000 600000 800000 Ordering Information Watts Loss Part Number 1.0 2.5 2.5 2.5 4.0 4.0 5.0 5.0 7.0 9.0 10.0 10.0 16.0 20.0 21.0 17.0 28.0 28.0 35.0 35.0 40.0 42.0 60.0 64.0 75.0 77.0 82.0 97.0 6LCT 10LCT 12LCT 16LCT 20LCT 25LET 32LET 35LET 50LET 63LET 80LET 100LET 125LET 160LET 180LET 160LMT 200LMT 250LMT 315LMT 355LMT 400LMT 450LMT 400LMMT 500LMMT 630LMMT 710LMMT 800LMMT 900LMMT Dimensions Curves Carton Qty. Carton Weight (kg) Figure Number See Page or (BIF #) 20 0.110 Fig. 1 page 73 (35785296) 10 0.310 Fig. 2 page 73 (35785293) 1 0.180 Fig. 3 page 74 (35785294) 1 0.370 Fig. 4 page 74 (35785295) Interrupting rating 200kA RMS Symmetrical. 䡲 150 Vdc rating Watts loss provided at rated current. Note: 7LET, 10LET, 12LET and 16LET are available for replacement purposes on existing equipment. All fuses above have been tested at 318 Vac. See accessories on page 72. 1 kg = 2.2 lbs Dimensions Fig. 1: LCT Fig. 2: LET 4 7.1 28 38 47 26.2 41.8 56 5.5 9.7 12.7 6.4 8.4 8.7 1mm = 0.0394∑ 17.7 19.1 1∑ = 25.4mm BIF document: 720004 68 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® British Style BS 88 240V 6-900A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.6 750 1.0 Kp 0.8 K 1.4 UL 0.6 0.5 1) 1.2 500 1.0 0.4 2) 0.8 0.6 1) 2) 50 0.2 250 0.4 0.2 0.3 Eg Eg 100 150 200 250 100 1) LCT 2) LET, LMT, LMMT 200 Ib 0.1 30 40 50 300 60 70 80 90 100% 1) LCT 2) LET, LMT, LMMT Dimensions Fig. 3: LMT Fig. 4: LMMT 25.4 25.4 31 59 84 31 59 84 13.5 13.5 10.3 10.3 41 83 38.1 Indicator (Optional) 1mm = 0.0394∑ 38 1∑ = 25.4mm BIF document: 720004 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 69 Bussmann® British Style BS 88 690V Type CT ET FE EET FEE FM FMM MT† MMT† 6-700A Rated Current RMS-Amps ® Electrical Characteristics I2t (A2S) Clearing Clearing Pre-arc at 415V at 660V 6 10 12 16 20 25 32 35 40 45 56 63 80 35 40 45 50 63 71 80 90 100 90 110 140 160 100 120 140 160 180 200 180 200 225 250 280 315 350 400 450 500 550 630 700 160 180 200 250 280 315 355 180 200 225 280 315 355 400 450 500 560 630 710 1.8 7 10 16 32 25 32 52 103 103 135 171 360 33 52 76 103 135 210 250 360 470 490 600 1050 1500 400 540 850 1000 1400 1900 1400 2600 3700 5200 7000 10000 15000 10000 15000 20000 30000 45000 60000 2400 3800 6000 11500 16500 19000 22000 1650 2200 3700 6600 8600 13500 21000 30000 42000 60000 68500 78000 8.5 30 40 66 150 150 190 310 600 680 950 1200 2500 130 180 270 380 480 600 900 1300 1800 3000 4000 7000 10000 1600 1900 2500 3700 5300 7100 7500 10500 14500 20500 30500 40000 60000 40000 60000 82000 120000 180000 245000 15000 25000 40000 80000 100000 125000 160000 12000 16000 26000 47000 62000 97000 150000 220000 300000 430000 500000 600000 12 48 65 110 220 250 350 500 900 1100 1500 2000 4000 200 300 450 600 750 950 1500 2100 2800 4500 6500 12000 17000 2400 3100 3800 5700 8400 11400 13500 18500 26500 37500 55000 77000 105000 72500 105000 150000 215000 310000 420000 25000 38000 58000 110000 150000 180000 200000 18000 23000 40000 70000 91000 140000 220000 320000 450000 640000 720000 850000 Ordering Information Watts Loss 2 3 3 7 7 7 11 11 9 11 14 16 18 9 9 11 11 12 17 20 20 23 19 27 35 39 24 32 36 46 46 52 40 40 44 48 48 55 55 85 90 100 100 100 120 26 26 27 32 35 42 51 42 42 42 47 51 54 60 57 64 64 86 105 Part Number 6CT 10CT 12CT 16CT 20CT 25ET 32ET 35ET 40ET 45ET 56ET 63ET 80ET 35FE 40FE 45FE 50FE 63FE 71FE 80FE 90FE 100FE 90EET 110EET 140EET 160EET 100FEE 120FEE 140FEE 160FEE 180FEE 200FEE 180FM 200FM 225FM 250FM 280FM 315FM 350FM 400FMM 450FMM 500FMM 550FMM 630FMM 700FMM 160MT 180MT 200MT 250MT 280MT 315MT 355MT 180MMT 200MMT 225MMT 280MMT 315MMT 355MMT 400MMT 450MMT 500MMT 560MMT 630MMT 710MMT Dimensions Curves Carton Weight (kg) Figure Number See Page or (BIF #) 20 0.160 Fig. 1 page 75 (35785312) 10 0.420 Fig. 2 page 75 (35785312) 10 0.420 Fig. 2 page 76 (35785314) 5 0.450 Fig. 3 page 75 (35785313) 5 0.450 Fig. 3 page 77 (35785292) 1 0.240 Fig. 4 page 76 (35785314) 1 0.450 Fig. 5 page 77 (35785292) 1 0.260 Fig. 4 page 75 (35785313) 1 .0470 Fig. 5 page 76 (35785311) Carton Qty. 䡲 Interrupting rating 200kA RMS Symmetrical. 䡲 450 Vdc rating 䡲 Watts loss provided at rated current. 䡲 Note: FC, 8ET, 12ET, 15ET, 20ET, 65EET and 75EET are available for replacement purposes on existing equipment. 䡲 See accessories on page 72. †350 Vdc (IEC) rating. Consult Bussmann for U.L. Recognition status. 1 kg = 2.2 lbs BIF document: 720024 70 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® British Style BS 88 690V 6-700A ® Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). 1.6 Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. K 1500 1.4 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.0 Kp 0.8 UL 0.6 0.5 1) 1.2 1.0 0.4 1000 2) 0.8 0.3 0.6 0.2 500 0.4 1) 0.2 2) Eg Eg 200 300 400 500 200 600 660 1) CT, FE, EET, FEE 2) ET, FM, FMM 400 Ib 0.1 30 40 50 600 660 60 70 80 90 100% 1) CT 2) ET, FE, EET, FEE, FM, FMM Dimensions Fig. 1: CT Fig. 2: ET, FE 4 Fig. 3: EET, FEE 8.7 7.1 5.5 54.8 64.3 74.6 46 70 94 48 63.5 77 11.9 9.7 8.7 31.8 12.7 17.1 6.4 8.7 19.1 Fig. 4: FM, MT 37 19 Fig. 5: FMM, MMT 25.4 25.4 50 50 A A 113 14 113 Type FM FMM MT MMT “A” Dimension 80-85 80-85 85 85 10.3 13.5 10.3 83 41 38.1 38 Dimensions in mm. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720024 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 71 Bussmann® British Style BS 88 – Accessories Indicator System and Fuse Bases (Blocks) Microswitch and Adaptor Type MAI Current Rating: AC 50/60Hz resistive load @ 250 VRMS AC 50/60Hz resistive load @ 127 VRMS Trip Indicator 4A 6A DC, resistive load @ 110 Vdc DC, resistive load @ 30 Vdc 0.7 2 Maximum Working Voltage: Contact-to-contact (RMS) Contact-to-contact (RMS) 2.8 2.4 1000V 1500V 3.6 5.2 5.2 Trip-indicator fuselinks are available for use in parallel with the main fuselinks. They can either be attached to the associated fuselink or mounted separately in panel mounted fuse clips, Part No. CL1. A push-on adaptor and microswitch attachment is available for use with the trip indicator to give the facility of remote indication, reference MAI or MBI. 9.5 NO NC NC 21 21 NO 3.6 44 36 44 36 MAI or MBI Universal and Stud Fuseblocks Fuse ratings of 20A and below cannot usually accommodate a trip fuselink in parallel. Where trip indicator fuselinks are to be attached to the main fuselink, an accessory pack comprising a pair of mounting clips and an appropriate trip indicator fuselink will be required. The ordering code references for these packs are listed below: Fuse Type ET EET FE FEE LET Order Ref. EC-600 EC-600 EC-600 EC-600 EC-250 Fuse Type FM FMM LMT LMMT A 0.8 Order Ref. MC-600 MC-600 MC-250 MC-250 Dimensions in mm. 1mm = 0.0394∑ 1∑ = 25.4mm Stud Fuseblocks Part No. C5268-1 C5268-2 C5268-3 C5268-4 C5268-5 Trip-indicator Fuselink Data Dim. ‘A’ Voltage Type Max. Rating TI250 37.6 250 TI500 47.5 500 TI600 55.7 600 TI700 61.8 700 Universal Fuseblocks Modular Max. Base Voltage 1BS101 600V 1BS102 600V 1BS103 600V 1BS104 600V 6 21 6.35 6 Type TI1100 TI1500 TI2000 TI2500 Dim. ‘A’ Max. 98.4 120.8 147.5 198.3 Voltage Rating 1100 1500 2000 2500 Stud Height 1.00∑ 1.75∑ 0.75∑ 1.00∑ 1.75∑ Stud Dia. & Threads fiΩ¡§-18 fiΩ¡§-18 fiΩ¡§-18 ⁄Ω¢-20 ⁄Ω¢-20 Max. Fuse Current Rating 100A 400A 400A 600A BIF document: 720037 72 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 BIF Document 1206 1207 1208 1209 Bussmann® British Style BS 88 Curves LCT 6-20: 240V LET 25-180: 240V Time-Current Curve Time-Current Curve 104 6 4 104 6 4 2 2 103 103 6 4 6 4 2 6LCT 10LCT 12LCT 16LCT 20LCT 102 6 4 2 102 6 4 Virtual Pre-Arcing Time In Seconds Virtual Pre-Arcing Time In Seconds 2 101 2 100 6 4 2 10 80LET 100LET 125LET 160LET 180LET 6 4 2 –1 6 4 101 6 4 25LET 32LET 35LET 50LET 63LET 2 100 6 4 2 10–1 6 4 2 10–2 6 4 2 10–2 2 6 4 10–3 6 4 2 10–3 2 10–4 2 4 6 8 2 4 6 8 2 101 102 Prospective Current In Amperes RMS 4 6 8 6 4 103 2 10–4 2 101 4 6 8 102 2 4 6 8 103 Prospective Current In Amperes RMS Peak Let-Through Curve Peak Let-Through Curve 2 2 102 6 4 2 101 4 2 101 2 100 6 4 4 2 100 6 4 63LET 50LET 35LET 32LET 25LET 2 –1 10 4 2 10–1 2 4 6 10–1 2 4 20LCT 16LCT 12LCT 10LCT 6LCT 6 4 2 SYMMETRICAL FAULT FULLY ASYMMETRICAL FAULT 10–2 63LET 50LET 35LET 32LET 25LET 2 20LCT 16LCT 12LCT 10LCT 6LCT 6 10–2 180LET 200LMT 160LET & LMT 125 & 100LET 80LET 6 Peak Let-Through Current 4 900LMMT 800LMMT 710LMMT 630LMMT 450LMT 400 & 500LMMT 355LMT 315LMT 250LMT 6 180LET 200LMT 160LET & LMT 125 & 100LET 80LET 6 Peak Let-Through Current 102 900LMMT 800LMMT 710LMMT 630LMMT 450LMT 400 & 500LMMT 355LMT 315LMT 250LMT 6 100 2 4 6 101 2 4 6 SYMMETRICAL FAULT FULLY ASYMMETRICAL FAULT 10–2 102 –2 10 2 4 6 10–1 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785296 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 2 4 6 100 2 4 6 101 2 4 6 102 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785293 73 Bussmann® British Style BS 88 Curves LMT 160-450: 240V LMMT 400-900: 240V Time-Current Curve Time-Current Curve 104 104 6 4 6 4 2 2 103 103 6 4 6 4 2 101 6 4 400LMMT 500LMMT 630LMMT 710LMMT 800LMMT 900LMMT 102 6 4 2 Virtual Pre-Arcing Time In Seconds 2 Virtual Pre-Arcing Time In Seconds 2 160LMT 200LMT 250LMT 315LMT 355LMT 400LMT 450LMT 102 6 4 2 100 6 4 2 10–1 6 4 101 6 4 2 100 6 4 2 10–1 6 4 2 2 10–2 6 4 10–2 6 4 2 2 10–3 10–3 6 4 6 4 2 2 10–4 2 102 4 6 8 103 2 4 6 10–4 8 104 2 102 4 Prospective Current In Amperes RMS Peak Let-Through Curve 102 900LMMT 800LMMT 710LMMT 630LMMT 450LMT 400 & 500LMMT 355LMT 315LMT 250LMT 4 2 101 4 6 8 104 4 2 101 180LET 200LMT 160LET & LMT 125 & 100LET 80LET 6 Peak Let-Through Current 4 900LMMT 800LMMT 710LMMT 630LMMT 450LMT 400 & 500LMMT 355LMT 315LMT 250LMT 6 180LET 200LMT 160LET & LMT 125 & 100LET 80LET 6 Peak Let-Through Current 2 2 6 2 100 6 4 2 100 6 4 4 63LET 50LET 35LET 32LET 25LET 2 10–1 4 2 10 2 4 6 10–1 2 4 –1 20LCT 16LCT 12LCT 10LCT 6LCT 6 4 2 SYMMETRICAL FAULT FULLY ASYMMETRICAL FAULT 10–2 63LET 50LET 35LET 32LET 25LET 2 20LCT 16LCT 12LCT 10LCT 6LCT 6 6 100 2 4 6 101 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785294 74 8 103 Peak Let-Through Curve 2 102 10–2 6 Prospective Current In Amperes RMS 2 4 6 SYMMETRICAL FAULT FULLY ASYMMETRICAL FAULT 10–2 102 10–2 2 4 6 10–1 2 4 6 100 2 4 6 101 2 4 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785295 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 6 102 Bussmann® British Style BS 88 Curves CT 6-20, ET 25-80: 690V EET 90-160, MT 160-355: 690V Time-Current Curve Time-Current Curve 104 6 4 104 6 4 2 2 103 6 4 103 Virtual Pre-Arcing Time In Seconds 2 101 6 4 2 102 6 4 Virtual Pre-Arcing Time In Seconds 2 102 6 4 6CT 10CT 12CT 16CT 20CT 2 100 6 4 160MT 180MT 200MT 250MT 280MT 315MT 355MT 6 4 25ET 32ET 35ET 40ET 45ET 56ET 63ET 80ET 2 10–1 2 101 6 4 90EET 110EET 140EET 160EET 2 100 6 4 2 10–1 6 4 6 4 2 2 10–2 6 4 10–2 6 4 2 2 10–3 10–3 6 4 6 4 2 10–4 2 2 4 6 8 101 2 4 6 8 102 2 4 6 8 103 10–4 2 4 6 8 102 Prospective Current In Amperes RMS 2 4 6 8 103 2 4 6 8 104 Prospective Current In Amperes RMS Peak Let-Through Curve Peak Let-Through Curve 6 6 4 2 315MT 355MT 280MT 250MT 105 6 180MT 160MT 4 710MMT 630MMT 560MMT 500MMT 450MMT 400MMT 355MMT 315MMT 280MMT 200MT 225MMT 200MMT 180MMT 4 2 6 2 2 Peak Let-Through Current Peak Let-Through Current 180MT 160MT 4 104 6 4 2 103 6 104 6 4 2 103 6 160EET 140EET 110EET 90EET 4 80ET 63ET 56ET 45ET 40ET 35ET 32ET 25ET 2 20CT 16CT 12CT 10CT 6CT 102 6 160EET 140EET 110EET 90EET 4 80ET 63ET 56ET 45ET 40ET 35ET 32ET 25ET 2 20CT 16CT 12CT 10CT 6CT 102 6 4 4 2 2 101 10 315MT 355MT 280MT 250MT 105 710MMT 630MMT 560MMT 500MMT 450MMT 400MMT 355MMT 315MMT 280MMT 200MT 225MMT 200MMT 180MMT 1 2 4 6 10 2 2 4 6 10 3 2 4 6 10 4 2 4 6 10 5 2 Prospective Short-Circuit Current Symmetrical RMS 101 101 2 4 6 102 2 4 6 103 2 4 6 104 2 4 6 105 2 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785312 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 BIF document: 35785313 75 Bussmann® British Style BS 88 Curves MMT 180-710: 690V FE 35-100 & FM 180-350: 690V Time-Current Curve Time-Current Curve 104 104 6 4 6 4 2 2 400MMT 450MMT 500MMT 560MMT 630MMT 710MMT 103 6 4 2 103 6 4 2 102 Virtual Pre-Arcing Time In Seconds Virtual Pre-Arcing Time In Seconds 6 4 180MMT 200MMT 225MMT 280MMT 315MMT 355MMT 2 101 6 4 180FM 200FM 220FM 250FM 280FM 315FM 350FM 102 6 4 2 100 6 4 2 101 6 4 2 35FE 40FE 45FE 50FE 63FE 71FE 80FE 90FE 100FE 100 6 4 2 10–1 6 4 2 10–1 2 6 4 10–2 6 4 2 2 10–2 10–3 6 4 6 4 2 2 10–3 10–4 6 4 2 4 6 8 102 2 4 6 8 103 2 4 6 8 104 Prospective Current In Amperes RMS 2 10–4 2 102 4 6 8 2 4 6 103 Prospective Current In Amperes RMS 8 104 Peak Let-Through Curve Peak Let-Through Curve 105 6 4 2 315MT 355MT 280MT 250MT 105 6 180MT 160MT 4 2 6 4 Peak Let-Through Current 2 10 4 6 4 2 10 350FM 315FM 280FM 250FM 225FM 200FM 180FM 104 Peak Let-Through Current 4 6 710MMT 630MMT 560MMT 500MMT 450MMT 400MMT 355MMT 315MMT 280MMT 200MT 225MMT 200MMT 180MMT 2 103 6 4 2 3 160EET 140EET 110EET 90EET 4 80ET 63ET 56ET 45ET 40ET 35ET 32ET 25ET 2 20CT 16CT 12CT 10CT 6CT 102 6 4 2 101 2 4 6 102 2 4 6 103 2 4 6 104 2 4 6 Prospective Short-Circuit Current Symmetrical RMS 2 101 6 101 4 101 100FE 90FE 80FE 71FE 63FE 50FE 45FE 40FE 35FE 102 6 2 4 6 102 2 4 6 103 2 4 6 104 2 4 6 105 2 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785311 76 BIF document: 35785314 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 105 2 Bussmann® British Style BS 88 Curves FEE 100-200 & FMM 400-700: 690V Time-Current Curve 104 6 4 2 103 6 4 2 400FMM 450FMM 500FMM 550FMM 630FMM 700FMM Virtual Pre-Arcing Time In Seconds 102 6 4 2 101 6 100FEE 4 120FEE 140FEE 2 160FEE 180FEE 100 200FEE 6 4 2 10–1 6 4 2 10–2 6 4 2 10–3 6 4 2 10–4 2 102 4 6 8 2 4 6 103 Prospective Current In Amperes RMS 8 104 Peak Let-Through Curve 700FMM 8 630FMM 6 550FMM 500FMM 450FMM 4 400FMM Peak Let-Through Current 2 104 8 6 4 2 103 200FEE 8 180FEE 6 160FEE 140FEE 4 120FEE 100FEE 2 102 2 4 6 103 2 4 6 104 2 4 6 105 2 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785292 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 77 Bussmann® Ferrule Introduction Table of Contents Catalog Symbol General Information Ampere Range Page FWA 150V 5-60A 80 FWX 250V 1-30A 81 FWH 500V 0.25-30A 82-83 FWC 600V 6-32A 84 FWP 660V/700V 1-100A 85-86 FWK 750V 5-60A 87 FWJ 1000V 20-30A 88 FWL/FWS 1250V/1500V 2-30A 89 Accessories Fuseholders 90 Curves Time-Current & Peak Let-Through Voltage 150 250 500 600 700 700 750 800 1000 1000 1250 1500 91-96 AC X X X X X — — — X — X X DC — X X — — X X X — X — — Ampere Range 5-60 1-30 0.25-30 6-32 1-100 1-30 5-60 20-30 20-30 2-30 20-30 2-15 Select fuses designed and tested to: • IEC 269: Part 4 • U.L. Recognized Bussmann offers a full line of ferrule style (cylindrical and clip-mounted) fuses, designed and tested to meet standards and requirements in various locations around the world. Their unique design and construction provide: • Superior cycling capability • Low energy let-through (I2t) Ferrule fuses provide an excellent solution for small UPS, small AC drives and other low power applications where space is at a premium. Voltage Rating All Bussmann ferrule fuses — except 660 volt — have been tested at their rated voltage. The 660 volt ferrule fuse has been tested to the IEC 269 standard, which requires clearing at the rated voltage +10%. Accessories Ferrule fuses may be mounted in fuseclips, fuseholders, fuseblocks or fused switches. A variety of products are available to suit most end-use requirements. For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 79 Bussmann® Ferrule FWA 150V 5-60A ® Electrical Characteristics I2t (A2S) Clearing Pre-arc at 150V Ordering Information Rated Current RMS-Amps Size 5 1.6 10 3.6 10 ≈ 38mm 15 14 (⁄‹Ω£™∑) 20 33 25 58 30 100 35 75 40 100 21 ≈ 51mm 45 130 (⁄‹Ω¡§∑) 50 170 60 250 䡲 Interrupting rating 100kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 Consult Bussmann for DC ratings. 䡲 See accessories on page 90. Watts Loss Part Number 1 2.7 3.3 3.8 4.9 4.9 4.5 5.1 6 7.3 8.0 FWA-5A10F FWA-10A10F FWA-15A10F FWA-20A10F FWA-25A10F FWA-30A10F FWA-35A21F FWA-40A21F FWA-45A21F FWA-50A21F FWA-60A21F 8 16 55 130 220 400 800 1000 1300 1600 2400 Dimensions Curves Carton Qty. Carton Weight (kg) Figure Number See Page or (BIF #) 10 0.100 Fig. 1 page 91 (35785317) 10 0.600 Fig. 1 page 91 (35785305) 1 kg = 2.2 lbs. 1 lb = 0.45 kg Dimensions Fig. 1: 5-60 Amp Range A C Part Number FWA 5A10F-30A10F FWA 35A21F-60A21F A 38.1 50.8 Metric B C 9.5 10.3 15.9 20.6 A 1.5 2.0 Inches B C 0.375 0.406 0.625 0.811 Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm B Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 1.5 K 1.0 Kp 0.8 UL 1.0 0.6 0.5 300 1) 0.5 0.4 200 0.3 0.2 0.3 0.2 2) 100 Eg Eg 0.15 22 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current . The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 70 102 150 50 100 150 0.1 30 40 50 Ib 60 70 80 90 100% 1) 5-30 Amp Range 2) 35-60 Amp Range BIF document: 720003 80 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Ferrule FWX 250V (U.L.) Size 1-30A Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 250V ® Ordering Information Watts Loss Part Number Carton Qty. 1 — — — FWX-1A14F 2 — — — FWX-2A14F 3 — — — FWX-3A14F 4 — — — FWX-4A14F 14 ≈ 51mm 5 1.6 13 1.3 FWX-5A14F 10 (·Ω¡§∑) 10 3.6 24 3.4 FWX-10A14F 15 14 83 3.8 FWX-15A14F 20 33 200 4.6 FWX-20A14F 25 58 300 5.3 FWX-25A14F 30 100 500 5.9 FWX-30A14F 䡲 Interrupting rating 200kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 250 Vdc U.L. Recognition on 5 through 30 amperes only. Consult Bussmann for additional ratings. 䡲 See accessories on page 90. Dimensions Curves Carton Weight (kg) Figure Number See Page or (BIF #) 0.225 Fig. 1 page 92 (35785302) 1 kg = 2.2 lbs. 1 lb = 0.45 kg Dimensions Fig. 1: 1-30 Amp Range 50.8 (2.000") 14.3 (0.563") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm 15.5 (0.610") Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 1.4 1.2 1.5 K 1.0 Kp 0.8 UL 103 1.0 0.6 0.5 800 0.4 600 500 0.5 0.3 400 0.3 0.2 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 0.2 300 Eg 0.15 75 125 200 250 300 Eg 200 50 100 150 200 250VRMS 0.1 30 40 50 Ib 60 70 80 90 100% BIF document: 720006 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 81 Bussmann® Ferrule FWH 500V Size 䡲 䡲 䡲 䡲 0.25-30A Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 500V ® Ordering Information Watts Loss 0.25 0.01 0.05 2.7 0.5 0.05 0.25 1.2 1 0.4 2 1.7 2 1.3 3.5 3.2 3.15 3.1 7.7 2.9 5 15 40 2.1 6.3 36 90 2.3 6 ≈ 32mm 7 50 125 2.5 (⁄Ω¢∑ ≈ 1⁄Ω¢∑) 10 — — — 12.5 20 — 3.53 15 44 146 3.08 16 48 177 4.48 20 75 259 4.26 25 — — — 30 — — — 0.25-7A 300% minimum opening current at rated voltage. 10-30A 200% minimum opening current at rated voltage. Interrupting rating: 0.25-20A 50kA at ≥ 20% pf 25-30A 20kA at Consult Bussmann for DC ratings. See accessories on page 90. Blow Times Current Ratings 150% 0.25-7A > 30 min. 10-30A < 30 min. 200% < 30 min. < 30 min. Part Number FWH-.250A6F FWH-.500A6F FWH-001A6F FWH-002A6F FWH-3.15A6F FWH-005A6F FWH-6.30A6F FWH-007A6F FWH-010A6F FWH-12.5A6F FWH-015A6F FWH-016A6F FWH-020A6F FWH-025A6F FWH-030A6F Carton Qty. Carton Weight (kg) Dimensions Curves Figure Number See Page or (BIF #) page 92 (35785256) 10 0.03 Fig. 1 page 93 (50955) 1 kg = 2.2 lbs. ≥ 20% pf. 300% ≤ 10 sec. ≤ 10 sec. Dimensions Fig. 1: 0.25-30 Amp Range 31.8 (1.25") 6.4 (0.25") 3.2 (0.125") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720038 82 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 1 lb = 0.45 kg Bussmann® Ferrule FWH 500V Size 1-30A ® Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 500V Ordering Information Watts Loss Part Number Carton Qty. 1 — — — FWH-1A14F 2 — — — FWH-2A14F 3 — — 2.3 FWH-3A14F 4 — — — FWH-4A14F 5 1.6 6.4 1.5 FWH-5A14F 14 ≈ 51mm 6 1.6 6.4 1.5 FWH-6A14F 10 (·Ω¡§∑) 10 3.6 13 4 FWH-10A14F 12 — — — FWH-12A14F 15 10 40 5.5 FWH-15A14F 20 26 96 6 FWH-20A14F 25 49 191 7 FWH-25A14F 30 58 232 9 FWH-30A14F 䡲 Interrupting rating 200kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 500 Vdc U.L. Recognition on 5 through 30 amperes only. Consult Bussmann for additional ratings. 䡲 See accessories on page 90. Dimensions Curves Carton Weight (kg) Figure Number See Page or (BIF #) 0.250 Fig. 1 page 93 (35785298) 1 kg = 2.2 lbs. 1 lb = 0.45 kg Dimensions Fig. 1: 1-30 Amp Range 50.8 (2.000") 14.3 (0.563") 15.5 (0.610") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). 1.5 Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 2.0 K 1.6 1.0 1.0 Kp 0.8 UL 0.6 0.5 1.2 103 0.5 0.4 800 0.3 600 500 0.3 0.2 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 0.2 400 0.15 100 Eg 250 400 500 300 100 Eg 200 300 400 500 0.1 30 40 50 Ib 60 70 80 90 100% BIF document: 720008 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 83 Bussmann® Ferrule FWC 600V Size 6-32A ® Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 600V 6 4 8 6 10 9 10 ≈ 38mm 12 15 (⁄‹Ω£™∑) 16 25 20 34 25 60 32 95 䡲 Interrupting rating 200kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 Consult Bussmann for DC ratings. 䡲 See accessories on page 90. Ordering Information Watts Loss Part Number 1.5 2.0 2.5 3.0 3.5 4.8 6.0 7.5 FWC-6A10F FWC-8A10F FWC-10A10F FWC-12A10F FWC-16A10F FWC-20A10F FWC-25A10F FWC-32A10F 30 50 70 120 150 260 390 600 Carton Qty. 10 Dimensions Curves Carton Weight (kg) Figure Number See Page or (BIF #) 0.100 Fig. 1 page 94 (35785306) 1 kg = 2.2 lbs. 1 lb = 0.45 kg Dimensions Fig. 1: 6-32 Amp Range 38.1 (1.500") 10.3 (0.406") 9.5 (0.375") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 2.0 1.5 K 1.6 1.0 0.5 0.3 0.2 0.15 100 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current . The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.0 Kp 0.8 UL 1.2 0.6 0.5 103 0.4 800 0.3 600 500 0.2 400 Eg 250 400 500 600 300 200 Eg 300 400 500 600 0.1 30 40 50 Ib 60 70 80 90 100% BIF document: 720011 84 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Ferrule FWP 660V/700V (IEC/U.L.) Size Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 660V 1-50A ® Ordering Information Watts Loss 1 — — — 2 — — — 3 — — — 4 — — — 5 1.6 11 1.5 6 — — — 14 ≈ 51mm 10 3.6 22 4 (·Ω¡§∑) 15 10 75 5.5 20 26 180 6 25 44 320 7 30 58 450 9 32 68 600 7.6 40 84 750 8 50 200 1800 9 䡲 Interrupting rating 200kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 700 Vdc ratings for 5 through 30 amperes only. Consult Bussmann for 䡲 See accessories on page 90. Part Number Carton Qty. Carton Weight (kg) FWP-1A14F FWP-2A14F FWP-3A14F FWP-4A14F FWP-5A14F FWP-6A14F FWP-10A14F FWP-15A14F FWP-20A14F FWP-25A14F FWP-30A14F FWP-32A14F FWP-40A14F FWP-50A14F 10 0.225 Dimensions Curves Figure Number See Page or (BIF #) Fig. 1 page 94 (35785307) 1 kg = 2.2 lbs. 1 lb = 0.45 kg other ratings. Dimensions Fig. 1: 1-50 Amp Range 50.8 (2.000") 14.3 (0.563") 15.5 (0.610") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). 1.4 1.2 1.0 0.9 0.8 0.7 0.6 0.5 0.4 1.4 1.2 103 9 8 7 6 K Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1.0 Kp 0.8 UL 0.6 0.5 0.4 0.3 5 1) 0.2 4 2) 0.3 200 Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. Eg Eg 3 300 400 500 600 700 200 300 400 500 600 700 1) 5-30 Amp Range 2) 32-50 Amp Range For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 0.1 30 40 50 Ib 60 70 80 90 100% BIF document: 720025 85 Bussmann® Ferrule FWP 660V/700V (IEC/U.L.) Size Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 660V 20 23 25 37 32 55 22 ≈ 58mm 40 68 (‡Ω•∑) 50 155 63 280 80 600 100 1100 䡲 Interrupting rating 200kA RMS Symmetrical. 䡲 Watts loss provided at rated current. 䡲 Consult Bussmann for DC ratings. 䡲 See accessories on page 90. 20-100A ® Ordering Information 260 410 605 750 1600 3080 6600 12500 Watts Loss Part Number Carton Qty. Carton Weight (kg) 4.6 5.6 7.0 8.5 9.5 11 13.5 16 FWP-20A22F FWP-25A22F FWP-32A22F FWP-40A22F FWP-50A22F FWP-63A22F FWP-80A22F FWP-100A22F 10 0.450 Dimensions Curves Figure Number See Page or (BIF #) page 95 (35785291) Fig. 1 1 kg = 2.2 lbs. 1 lb = 0.45 kg Dimensions Fig. 1: 20-100 Amp Range 58.0 (2.283") 22.2 (0.875") 15.0 (0.591") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). 1.4 1.2 1.0 0.9 0.8 0.7 0.6 Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 1.4 1.2 103 9 8 7 6 K 0.5 5 0.4 4 0.3 200 300 400 500 600 1.0 Kp 0.8 UL 0.6 0.5 0.4 0.3 0.2 Eg Eg 3 700 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current . The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 200 300 400 500 600 700 0.1 30 40 50 Ib 60 70 80 90 100% BIF document: 720026 86 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Ferrule FWK 750V Size 5-60A Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 750 Vdc Ordering Information Watts Loss Part Number Dimensions Curves Figure Number See Page or (BIF #) Carton Qty. Carton Weight (kg) 10 0.95 Fig. 1 page 95 (35785031) 10 1.65 Fig. 2 page 95 (35785031) 5 8.5 16 — FWK-5A20F 8 50 100 — FWK-8A20F 10 95 200 — FWK-10A20F 20 ≈ 127mm 15 100 240 — FWK-15A20F (⁄‹Ω¡§∑) 20 125 315 — FWK-20A20F 25 400 1100 — FWK-25A20F 30 800 2600 — FWK-30A20F 35 1300 4300 — FWK-35A25F 25 ≈ 146mm 40 1600 5300 — FWK-40A25F (1∑) 50 3100 12000 — FWK-50A25F 60 5900 24000 — FWK-60A25F 䡲 Interrupting rating 45kA RMS symmetrical. 䡲 750 Vdc rating for 5 through 60 amperes (Time constant = 10-15 mS). 1 kg = 2.2 lbs. 1 lb = 0.45 kg Dimensions Fig. 1: 5-30 Amp Range 127.0 (5.000") 20.5 (0.807") 16.0 (0.630") Fig. 2: 35-60 Amp Range 146.05 (5.75") 25.4 (1") 20.64 (0.813") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720039 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 87 Bussmann® Ferrule FWJ 1000V 20-30A Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 1000V Size 20 25 25 33 30 52 Interrupting rating 200kA RMS Symmetrical. Watts loss provided at rated current. 800 Vdc U.L. Recognized. See accessories on page 90. 14 ≈ 67mm (·Ω¡§∑) 䡲 䡲 䡲 䡲 ® Ordering Information Watts Loss Part Number Carton Qty. Carton Weight (kg) 9 11 14 FWJ-20A14F FWJ-25A14F FWJ-30A14F 10 0.300 220 350 450 Dimensions Curves Figure Number See Page or (BIF #) Fig. 1 page 96 (35785315) 1 kg = 2.2 lbs. 1 lb = 0.45 kg Dimensions Fig. 1: 20-30 Amp Range 66.7 (2.626") 14.5 (0.571") 15.9 (0.625") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm Electrical Characteristics Total Clearing I2t The total clearing I2t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, E g , (RMS). Arc Voltage This curve gives the peak arc voltage, U L , which may appear across the fuse during its operation as a function of the applied working voltage, E g , (RMS) at a power factor of 15%. 1.5 2000 K 1.0 Kp 0.8 UL 1.0 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current . The correction factor, K p , is given as a function of the RMS load current, Ib , in % of the rated current . 1600 0.6 0.5 1200 0.4 0.5 0.3 800 0.3 0.2 0.2 400 Eg Eg 0.15 680 800 1000 200 600 1000 1400 1800 0.1 30 40 50 Ib 60 70 80 90 100% BIF document: 720028 88 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Ferrule FWL/FWS 1250V/1500V Size Electrical Characteristics I2t (A2S) Rated Current Clearing RMS-Amps Pre-arc at 1000 Vdc †2 0.8 †6 27 20 ≈ 127mm †15 300 (·Ω¡§∑) ‡20 675 ‡30 1850 䡲 Interrupting rating 45kA RMS Symmetrical. 䡲 Rated voltage (IEC) †1500V ‡1250V 䡲 1000 Vdc rating. 䡲 See accessories on page 90. 2.4 81 700 1550 4300 2-30A Ordering Information Watts Loss Part Number Carton Qty. Carton Weight (kg) 4.4 6.7 5 5.9 7.5 FWS-2A20F FWS-6A20F FWS-15A20F FWL-20A20F FWL-30A20F 10 1.00 Dimensions Curves Figure Number See Page or (BIF #) Fig. 1 page 96 (35785109) 1 kg = 2.2 lbs. 1 lb = 0.45 kg Dimensions Fig. 1: 2-30 Amp Range 127.0 (5.000") 20.5 (0.807") 16.0 (0.630") Dimension in mm. 1mm = 0.0394∑ 1∑ = 25.4mm BIF document: 720040 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 89 Bussmann® Ferrule – Accessories Fuseholders ® Catalog Symbol: CH Series Features: • 10 ≈ 38 Dovetail design provides maximum flexibility in assembling multiple poles • Touchsafe design - No exposed contacts • DIN rail mount (35mm) • Optional open fuse indication lights • Excellent for switchboard panel, control consoles, small motors, transformers, and similar applications • Handle/fusepuller to install and remove fuses easily • Available in single and multi-pole configurations • Circuit marking system (P/N CH10CL and CH10CM) • Wire ready: Saves time as terminals are ready to accept wires. • CE marking Standards: North American 10 ≈ 38 Class CC Listed U.L. 512, Guide IZLT, File E14853 Certified CSA Std. C22.2 No. 39, Class 6225 01, File 47235 North American 10 ≈ 38 Midget Recognized U.L. 512, Guide IZLT2, File E14853 Certified CSA Std. C22.2 No. 39, Class 6225 01, File 47235 European 10 ≈ 38 IEC 269-2-1 14 ≈ 51 IEC 269-2 22 ≈ 58 IEC 269-2 Recommended Buss® Fuse Types: 10 ≈ 38 North American Class CC Fuses - LP-CC, FNQ-R, KTK-R 10 ≈ 38 North American Midget Fuses - FNQ, KTK, AGU, BAF, BAN, FNM, FWA, & FWC 14 ≈ 51 Fuses - FWX, FWH, FWP & NON 22 ≈ 58 Fuses - FWP BIF document: 1151 Catalog Symbol: J70100 Ampere Rating: 100 Amperes Voltage Rating: 700 Volts AC Agency Approvals: UL Recognized, Guide IZLT2, File E14853 Withstand Rating: 200,000 RMS Sym. Amps For use with 22 ≈ 58mm fuses (FWP-40A22F, FWP-100A22F, etc.) Materials: Thermoplastic UL Flammability: 94 VO Amps 100 Poles 1 2 3 Catalog Numbers Box Lug w/ Retaining Clip J70100-1CR J70100-2CR J70100-3CR Max. Wire Size #2 #2 #2 BIF document: 1211 90 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 Bussmann® Ferrule Curves FWA 150V 5-30A (10 ≈ 38mm) FWA 150V 35-60A (21 ≈ 51mm) Time-Current Curve Time-Current Curve 104 104 6 4 6 4 2 2 6 4 103 6 4 103 2 2 6 4 102 6 4 Virtual Pre-Arcing Time In Seconds 102 Virtual Pre-Arcing Time In Seconds 2 101 FWA-5A10F FWA-10A10F FWA-15A10F FWA-20A10F FWA-25A10F FWA-30A10F 6 4 2 100 6 4 2 10–1 2 101 6 4 2 100 6 4 2 10–1 6 4 6 4 2 2 10–2 10–2 6 4 6 4 2 2 10–3 10–3 6 4 6 4 2 10–4 FWA-35A21F FWA-40A21F FWA-45A21F FWA-50A21F FWA-60A21F 2 2 4 6 8 2 101 4 6 8 2 102 4 6 8 103 10–4 Prospective Current In Amperes RMS 2 101 4 6 8 2 102 4 6 8 103 Prospective Current In Amperes RMS Peak Let-Through Curve Peak Let-Through Curve 104 104 6 6 4 4 FWA-30A10F FWA-25A10F FWA-20A10F FWA-15A10F 10 2 103 Peak Let-Through Current Peak Let-Through Current 2 3 FWA-60A21F FWA-50A21F FWA-45A21F FWA-40A21F FWA-35A21F 6 4 2 FWA-12A10F FWA-10A10F FWA-5A10F 102 6 4 2 102 6 6 4 4 2 2 101 101 101 2 4 6 102 2 4 6 103 2 4 6 104 2 4 6 105 2 101 2 4 6 102 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785317 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 2 4 6 103 2 4 6 104 2 4 6 105 2 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785305 91 Bussmann® Ferrule Curves FWX 250V 1-30A (14 ≈ 51mm) FWH 500V 0.25-7A (6 ≈ 32mm) Time-Current Curve Time-Current Curve 104 104 6 4 6 4 FWH-3.15A6F FWH-005A6F 3 FWH-6.30A6F 10 103 6 4 FWH-007A6F 6 4 2 2 102 102 6 4 Virtual Pre-Arcing Time In Seconds 6 4 Virtual Pre-Arcing Time In Seconds FWH-002A6F 2 2 2 101 6 4 FWX-5A14F FWX-10A14F FWX-15A14F FWX-20A14F FWX-25A14F FWX-30A14F 2 100 6 4 2 101 6 4 2 100 6 4 2 2 10–1 6 FWH-.250A6F 4 FWH-.500A6F FWH-001A6F 2 10–1 6 4 2 10–2 10–2 4x10–3 .2 6 4 .4 .6 .8 100 2 4 6 8 101 2 4 Prospective Current In Amperes RMS 2 10–3 6 4 2 10–4 2 4 6 8 2 101 4 6 8 102 2 4 6 8 103 Prospective Current In Amperes RMS Peak Let-Through Curve 104 6 4 FWX-30A14F FWX-25A14F FWX-20A14F FWX-15A14F FWX-10A14F FWX-5A14F Peak Let-Through Current 2 103 6 4 2 102 6 4 2 101 101 2 4 6 102 2 4 6 103 2 4 6 104 4 6 105 2 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785302 92 BIF document: 35785256 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 6 8 102 2 Bussmann® Ferrule Curves FWH 500V 10-30A (6 ≈ 32mm) FWH 500V 1-30A (14 ≈ 51mm) Time-Current Curve Time-Current Curve 104 104 6 4 2 10 103 6 4 3 2 102 6 4 Virtual Pre-Arcing Time In Seconds FWH-12.5A6F FWH-016A6F FWH-020A6F FWH-025A6F 101 100 FWH-5A14F FWH-10A14F FWH-15A14F FWH-20A14F FWH-25A14F FWH-30A14F 2 101 6 4 2 100 6 4 2 10–1 6 4 2 10–1 10–2 6 4 2 10–2 10–3 6 4 2 10–3 1 10 10–4 102 103 104 2 105 4 6 8 2 101 4 6 8 2 102 4 6 105 2 8 103 Prospective Current In Amperes RMS Prospective Current In Amperes RMS Peak Let-Through Curve 104 6 4 2 FWH-30A14F FWH-25A14F 103 Peak Let-Through Current Virtual Pre-Arcing Time In Seconds 102 6 4 2 FWH-20A14F FWH-15A14F FWH-10A14F FWH-5A14F 102 6 4 2 101 101 2 4 6 102 2 4 6 103 2 4 6 104 2 4 6 Prospective Short-Circuit Current Symmetrical RMS BIF document: 50955 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 BIF document: 35785298 93 Bussmann® Ferrule Curves FWC 600V 6-32A (10 ≈ 38mm) FWP 660V/700V 1-50A (14 ≈ 51mm) Time-Current Curve Time-Current Curve 4 104 10 6 4 6 4 2 2 103 103 10 6 4 2 FWP-25A14F FWP-30A14F FWP-32A14F FWP-40A14F FWP-50A14F 102 6 4 Virtual Pre-Arcing Time In Seconds 2 2 Virtual Pre-Arcing Time In Seconds 6 4 FWC-6A10F FWC-8A10F FWC-10A10F FWC-12A10F FWC-16A10F FWC-20A10F FWC-25A10F FWC-30A10F & FWC-32A10F 6 4 2 101 6 4 2 100 6 4 2 101 6 4 2 100 6 4 FWP-5A14F FWP-10A14F FWP-15A14F FWP-20A14F 2 10–1 2 6 4 10–1 2 6 4 10–2 6 4 2 –2 10 2 6 4 10–3 6 4 2 2 10–3 10–4 6 4 2 4 6 8 2 101 4 6 8 102 2 4 6 6 105 8 103 Prospective Current In Amperes RMS 2 10–4 2 102 4 6 8 103 2 4 6 8 104 Prospective Current In Amperes RMS Peak Let-Through Curve Peak Let-Through Curve 104 104 6 4 4 2 2 103 Peak Let-Through Current Peak Let-Through Current FWP-50A14F FWP-40A14F FWP-32A14F FWP-30A14F FWP-25A14F 6 FWC-30A10F & FWC-32A10F FWC-25A10F FWC-20A10F FWC-16A10F 6 4 2 FWC-12A10F FWC-10A10F FWC-8A10F FWC-6A10F 102 103 6 4 2 6 6 4 4 2 FWP-20A14F FWP-15A14F FWP-10A14F FWP-5A14F 102 2 101 101 101 2 4 6 102 2 4 6 103 2 4 6 104 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785306 94 4 6 105 2 101 2 4 6 102 2 4 6 103 2 4 6 104 2 4 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785307 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 2 Bussmann® Ferrule Curves FWP 660V/700V 20-100A (22 ≈ 58mm) Time-Current Curve FWK 750V 5-30A (20 ≈ 127mm) FWK 750V 35-60A (25 ≈ 146mm) Time-Current Curve 104 104 6 4 6 4 2 FWK-15A20F 2 FWK-20A20F 3 103 10 6 FWK-30A20F 4 FWK-40A25F 2 2 6 4 102 6 Virtual Pre-Arcing Time In Seconds 10 2 101 6 4 2 100 6 4 FWK-50A25F FWK-60A25F FWP-50A22F FWP-63A22F FWP-80A22F FWP-100A22F 2 Virtual Pre-Arcing Time In Seconds FWK-25A20F 6 4 FWP-20A22F FWP-25A22F FWP-32A22F FWP-40A22F 4 2 101 6 4 2 100 6 4 FWK-5A20F FWK-8A20F 2 2 FWK-10A20F —1 10 10–1 6 4 6 4 2 2 —2 10 –2 10 6 4 —3 4x10 2 4 6 8 101 2 4 6 8 102 2 4 6 8 103 Prospective Current In Amperes RMS 2 10–3 6 4 2 10–4 2 101 4 6 8 2 102 4 6 8 103 Prospective Current In Amperes RMS Peak Let-Through Curve 104 FWP-100A22F FWP-80A22F 6 FWP-63A22F Peak Let-Through Current 4 FWP-50A22F 2 103 6 FWP-40A22F FWP-32A22F 4 FWP-25A22F FWP-20A22F 2 102 102 2 4 6 103 2 4 6 104 2 4 6 105 2 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785291 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 BIF document: 35785031 95 Bussmann® Ferrule Curves FWJ 1000V 20-30A (14 ≈ 67mm) Time-Current Curve FWL/FWS 1250V/1500V 2-30A (20 ≈ 127mm) Time-Current Curve 104 104 6 4 FWS-15A20F 6 4 FWL-20A20F FWL-30A20F 2 2 103 103 6 4 6 4 2 2 102 Virtual Pre-Arcing Time In Seconds 102 6 4 Virtual Pre-Arcing Time In Seconds 2 101 6 4 FWJ-20A14F FWJ-25A14F FWJ-30A14F 2 100 6 4 2 101 6 4 2 100 6 4 2 6 4 10–1 6 4 2 FWS-2A20F FWS-6A20F 10–1 2 6 4 10–2 4x10–3 2 100 10–2 2 4 6 8 101 2 4 6 8 102 Prospective Current In Amperes RMS 6 4 2 10–3 6 4 2 10–4 2 101 4 6 8 102 2 4 6 8 103 Prospective Current In Amperes RMS Peak Let-Through Curve 104 6 4 FWJ-30A14F FWJ-25A14F FWJ-20A14F Peak Let-Through Current 2 103 6 4 2 102 6 4 2 101 101 2 4 6 102 2 4 6 103 2 4 6 104 2 4 6 105 2 Prospective Short-Circuit Current Symmetrical RMS BIF document: 35785315 96 BIF document: 35785109 For complete specification data, visit our Web site at www.bussmann.com or call Bussmann Information Fax ~ 314.527.1450 2 4 6 8 103 Bussmann ® Worldwide Circuit Protection Solutions Bussmann North America’s leading supplier of fuses and fusible protection systems, Bussmann continues its 80-year history of blazing new trails of innovative technologies. Maker of the industry’s first truly global product line, each item is backed by an efficient worldwide network of distribution, customer service and technical support. Bussmann products include the most extensive circuit protection solutions that are built and tested to a variety of major standards: U.L., CSA, IEC, ISO. . . Additionally, both European (DIN, British Standard) and North American styled fuses are used for a wide range of applications: industrial motor protection, power conversion, medium voltage power distribution, telecommunications network equipment, electronics, and automotive. Manufacturing operations in the U.S., Denmark, and the United Kingdom have earned ISO 9000 certification, assuring Bussmann customers only the utmost quality across every product line. Knowledgeable. Responsive. Customer focused. Bussmann continues to set the standard for circuit protection solutions in the global marketplace. Bussmann—The Source For Global Solutions In Semiconductor Protection Today’s power electronics market knows no international boundaries – so neither should the high speed fuses that are used to protect semiconductor devices. Only one fuse maker – Bussmann – has the resources required to meet all of the power conversion industry’s principle needs: • Knowledgeable technical support • Cutting-edge application design • Global sourcing & manufacturing (certified to ISO 9000 standards) Bussmann offers a comprehensive range of high speed fuselinks, specifically designed for semiconductor device protection. These products use advanced materials and technology to deliver unsurpassed performance. All high speed fuses carry the quality assurance of the Bussmann name – the recognized world leader in circuit protection. Headquarters Cooper Industries Bussmann Division P.O. Box 14460 St. Louis, Missouri 63178-4460, USA Telephone: 314-394-2877 Facsimile: 800-544-2570 Bussmann Circuit Components 7300 West Wilson Avenue Chicago, IL 60656-4793, USA Telephone: 708-867-4600 Facsimile: 708-867-2211 European Headquarters Bussmann Division Cooper (UK) Limited Burton-on-the-Wolds Leicestershire LE12 5th, England Telephone: 44 1509 882737 Facsimile: 44 1509 882786 Bussmann Asia Pacific 331 North Bridge Road #03-02 Odeon Towers Singapore 188720 Republic of Singapore Telephone: 65 336 3610 Facsimile: 65 336 4810 Bussmann Australia Block X 391 Park Road P.O. Box 257 Regents Park, Sydney NSW 2143, Australia Telephone: 61 2 9743 8333 Facsimile: 61 2 9743 8070 Bussmann Brasil Bussmann do Brasil Ltda. Rodovia Santos Dumont, Km 23 13 300-000 Cruz das Almas Caixa Postal 95-Itu Sao Paulo-Brasil Telephone: 55 11 7824 1722 Facsimile: 55 11 7824 1721 Bussmann Denmark 5 Literbuen DK-2740 Skovlunde Copenhagen, Denmark Telephone: 45 4485 0900 Facsimile: 45 4485 0901 Bussmann India 2nd Floor, Unit #5 White House 23-29, St. Marks Road Bangalore – 560-001 India Telephone: 91-80-227-0893 Facsimile: 91-80-224-0124 Bussmann Mexico Arrow-Hart S.A. de C.V. Poniente 148, No. 933 02300 Mexico, D.F. Mexico Telephone: 52 5 587 0211 Facsimile: 52 5 567 4049 This brochure summarizes the features and benefits of the following high speed fuses that Bussmann manufactures for the power electronics market: • North American • British • European (DIN) • Ferrule This catalog is intended to present product data and provide technical information that will help the end user with design application. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this catalog. Once a product has been selected, it should be tested by the user in all possible applications. ©1998 Cooper Industries, Bussmann Division Printed in the U.S.A. http://www.bussmann.com
FWP-40A22F 价格&库存
很抱歉,暂时无法提供与“FWP-40A22F”相匹配的价格&库存,您可以联系我们找货
