BUSSMANN
SERIES
HALOGEN
Chip™ Fuses
HF
FREE
0603FA Series, Fast-Acting
Pb
Description
• Fast-acting 0603 surface mount fuse
• Excellent temperature and cycling characteristics
• Compatible with lead free solders and higher
temperature profiles
Electrical Characteristics
% of Amp Rating
Opening Time
100%
4 Hours Minimum
200%
60 Seconds Maximum
Agency Information
• UL Recognition Guide & File numbers:
JDYX2 &E19180
• CSA Component Acceptance: 053787 C 000 &
Class Number: 1422 30
Environmental Data
• Operating temparture: -55ºC to 125ºC with proper
derating
• Load humidity test: MIL-STD-202, Method 103B
• Moisture resistance test: MIL-STD-202, Method 106E
• Thermal shock test: MIL-STD-202, Method 107D
• High frequency vibration test: MIL-STD-202,
Method 204D
Surface Mount Device
Dimensions – mm/inches
Drawing Not to Scale
Recommended Pad Layout – mm/inches
1.25
(0.05)
Ordering
• Specify packaging and product code
(i.e., TR/0603FA250-R)
0.50
(0.02)
0.90
(0.035)
Soldering Method
• Wave solder: 260°C, 10 sec max.
• Solder reflow: 260°C, 30 sec max.
Specifications
Par t Number
0603FA250-R
0603FA375-R
0603FA500-R
0603FA750-R
0603FA1-R
0603FA1.25-R
0603FA1.5-R
0603FA2-R
0603FA2.5-R
0603FA3-R
0603FA3.5-R
0603FA4-R
0603FA5-R
Current
Rating
(amps)
250mA
375mA
500mA
750mA
1
1.25
1.5
2
2.5
3
3.5
4
5
Voltage
Rating
50Vdc
50Vdc
32Vac/50dc
32Vac/dc
32Vac/dc
32Vac/dc
32Vac/dc
32Vac/dc
32Vac/dc
32Vac/dc
32Vac/dc
32Vac/dc
32Vac/dc
Interrupting
Rating (amps) at
Rated Voltage*
50
50
50ac/35dc
50
50
35
35
35
35
35
35
35
35
DC Cold
Resistance** ( Ω)
Typical
3.100
1.250
1.025
0.450
0.150
0.108
0.086
0.051
0.037
0.028
0.022
0.017
0.011
Typical
Melting
I2t***
0.0004
0.0009
0.00193
0.0090
0.0025
0.0130
0.0319
0.0491
0.0625
0.0699
0.1200
0.2430
0.6950
Typical
Voltage
Drop†
0.921
0.605
0.600
0.440
0.211
0.151
0.138
0.116
0.113
0.110
0.103
0.097
0.090
Alpha
Code
Marking‡
D
E
F
G
H
J
K
N
O
P
R
S
T
* DC Interrupting rating (Measured at designated voltage, time constant of less than 50 microseconds, battery source)
** DC Cold resistance (Measured at ≤10% of rated current)
*** Typical melting I2t (Measured with a battery bank at rated DC voltage, 10x-rated current, not to exceed IR, time constant of calibrated circuit less than 50
microseconds) (0603FA4A and 5A measured at interrupting rating)
† Typical voltage drop (Measured at rated current after temperature stabilizes)
‡ Alpha code to be marked on the top of fuse body for all ratings
0210
BU-SB10140
Page 1 of 2
Data Sheet 4336
Time Current Cur ve
Packaging Code
Packaging Code Prefix
TR
Description
5,000 fuses on paper tape and reeled on a 178mm (7 inch) diameter reel per EIA Standard 481-1
The only controlled copy of this Data Sheet is the electronic read-only version located on the Eaton Network Drive. All other copies of this document are by definition uncontrolled. This bulletin
is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to
change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information
contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life
support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be
reasonably expected to result in significant injury to the user.
© 2017 Eaton
0210
BU-SB10140
Page 2 of 2
Data Sheet 4336
很抱歉,暂时无法提供与“0603FA250-R”相匹配的价格&库存,您可以联系我们找货
