85102R106P50
85102R106P50
    EATON(伊顿)
    SOURIAU-SUNBANK / EATON - 85102R106P50 - Circular Connector, Souriau 851 Series, Wall Mount Receptac...
85102R106P50 数据手册
851 SERIES MIL-DTL-26482 Connectors Overview 851 Series | Introduction Typical applications............................................ 06 Features & Benefits ........................................... 07 Receptacle range overview ............................... 08 Plug range overview .......................................... 10 Ordering information......................................... 12 Layouts .............................................................. 14 General technical characteristics ....................... 16 Crimp contacts .................................................. 56 Caps / Ordering information.............................. 57 Plastic protective caps........................................ 59 Filler plugs.......................................................... 59 Dummy receptacle............................................. 60 Gasket................................................................ 60 Connector Technical Information Environmental connectors.................................. 20 Hermetic connectors.......................................... 43 PC Tail connectors.............................................. 45 Panel cut out...................................................... 46 Backshells / Ordering information...................... 47 Push-pull locking plug........................................ 49 8F51 filter connectors......................................... 51 SNC specific connectors..................................... 52 Tooling................................................................ 64 Stripping instruction........................................... 66 Crimping instruction........................................... 66 Crimp contact insertion...................................... 67 Crimp contact extraction.................................... 67 Cross reference list............................................. 68 Drilling pattern .................................................. 70 Discrimination / Keying methods....................... 76 Contacts & Accessories Contacts & Accessories Technical Information Overview Connector Contents 3 851 SERIES © 2016 SOURIAU - SOURIAU is a registered trademark 851 Series Overview Typical applications .......................................................................................................... 06 Features & Benefits .......................................................................................................... 07 Range overview ................................................................................................................ 08 Ordering information ....................................................................................................... 12 Layouts ............................................................................................................................. 14 General technical characteristics ...................................................................................... 16 5 851 Series | Overview Robotics - Machine Tools Aircraft © curraheeshutter / Shutterstock Water Measurement Oil & Gaz Industries 6 Telecom Military © dell / Fotolia © krungchingpixs / Fotolia Off-Road - Pavers © JPS / Fotolia © SOURIAU © Rainer Plendl / Fotolia Typical applications 851 Series | Overview Features & Benefits MIL-DTL-26482H Overview qualified Fully in accordance with the MIL spec requirements with solder type. 500 Mating Cycles ROBUSTNESS Equipped with a coupling ring made from high strength aluminum. The plug provides a minimum of 500 mating unmating cycles. The receptacle is equipped with rugged stainless steel bayonet pins. Salt Spray 500 Hours OUTDOOR USING Designed to withstand climate ingress and exposure to salt spray or corrosive atmospheres while still maintaining mechanical, electrical functionality and RoHS compliance. 1/3 Bayonet Coupling quick mating With only 1/3 twist of the bayonet coupling system, connectors are mated with audible "click" and tactile feel to confirm proper mating. These mating features eliminate uncertainty connection and reduce time and labor during installation. Arrangements from 2 to 61 contacts FLEXIBILITY Power supply and signal transmission can be combined in a unique interconnect solution to reduce system complexity and minimize component/installation costs. 7 851 Series | Overview Receptacle range Square flange receptacle type 00 Square flange receptacle with straight adaptor Square flange receptacle with straight cable clamp without grommet Front view 00A/RA 00AC Page 20 Page 20 Square flange receptacle with straight sealing gland backshell Square flange receptacle with straight sealing gland and cable clamp Square flange receptacle with removable straight backshell for heatshrink sleeving 00J 00JC 00M/RM Page 22 Page 22 Page 23 Cable in line receptacle with straight adaptor Cable in line receptacle with straight cable clamp without grommet 01A/RA 01AC Cable in line receptacle type 01 Front view Page 25 Page 25 Cable in line receptacle with straight sealing gland backshell Cable in line receptacle with straight sealing gland and cable clamp Cable in line receptacle with removable straight backshell for heatshrink sleeving 01J 01JC 01M/RM Page 27 Page 27 Page 28 Square flange receptacle type 02 Jam nut receptacle type 07 Jam nut receptacle not accepting backshell Front view Front view 07A/07H Square flange receptacle not accepting backshell Jam nut receptacle with removable straight backshell for screen termination and heatshrink sleeving Jam nut receptacle with straight backshell for potting 02E/02R/02H 07G/RG 07P/RP Page 32 Page 32 Pages 30, 43 & 45 H: Hermetic version 8 Pages 30, 43 & 45 851 Series | Overview Square flange receptacle with backnut Square flange receptacle with straight cable clamp Square flange receptacle with removable straight backshell for screen termination and heatshrink sleeving 00E/R 00EC/RC 00G/RG Page 21 Page 20 Page 21 Square flange receptacle with straight backshell for potting Square flange receptacle with straight backshell for heatshrink sleeving Square flange receptacle with removablebackshell and heatshrink sleeving 00P/RP 00T/RT 00T/RT..38/42 Page 23 Page 24 Page 24 Cable in line receptacle with backnut Cable in line receptacle with straight cable clamp Cable in line receptacle with removable straight backshell for screen termination and heatshrink sleeving 01E/R 01EC/RC 01G/RG Page 26 Page 25 Page 26 Cable in line receptacle with straight backshell for potting Cable in line receptacle with straight backshell for heatshrink sleeving Cable in line receptacle with removable backshell and heatshrink sleeving 01P/RP 01T/RT 01T/RT..38/42 Page 28 Page 29 Page 29 Jam nut receptacle with straight cable clamp without grommet Jam nut receptacle with backnut Jam nut receptacle with straight cable clamp Solder fixing receptacle for hermetic version type IH 07AC 07E/R 07EC/RC Front view Page 31 Page 31 Page 31 Jam nut receptacle with straight backshell for heatshrink sleeving Jam nut receptacle with removable backshell and heatshrink sleeving Solder fixing receptacle not accepting backshell 07T/RT 07T/RT..38/42 IH Page 33 Page 33 Overview overview Page 44 9 851 Series | Overview Plug range Plug type 06 Plug with straight adaptor Plug with straight cable clamp without grommet Front view 06A/RA 06AC Page 34 Page 34 Plug with straight sealing gland and cable clamp Plug with Long Metallic Adaptor and Plastic Cable Gland Plug with removable straight backshell for heatshrink sleeving 06JC 06L* 06M/RM Page 36 Page 37 Plug with Short Metallic Adaptor and Plastic Cable Gland Plug with straight backshell for heatshrink sleeving Plug with straight for electrical pitch access 06S* 06T/RT 06Z/RZ Page 39 Page 39 Page 40 Shielded plug with straight adaptor Shielded plug with removable straight backshell for screen termination and heatshrink sleeving Shielded plug with removable straight backshell for screen termination and heatshrink sleeving 36A/RA 36G/RG 36T/RT..38/42 Page 41 Page 42 Page 42 Page 36 * Available only from size 8 to 16 10 851 Series | Overview Plug with backnut Plug with straight cable clamp Plug with straight sealing gland backshell 06E/R 06EC/RC 06J Page 35 Page 34 Page 35 Plug with short metallic adaptor and plastic cable gland with spiral protector Plug with long metallic adaptor and plastic cable gland with spiral protector Plug with straight backshell for potting 06NS* 06NL* 06P/RP Page 37 Page 38 Page 38 Plug with elbow cable clamp backshell Plug with elbow backshell for potting 08EC/RC 08P/RP Page 40 Page 41 Overview overview Plug overmolded Consult us 11 851 Series | Overview Environmental connectors / Ordering information Basic Series 851 00 E 8 3A P - 50 Shell type: 00 square flange receptacle accepting backshells 01 in line receptacle 02 square flange receptacle not accepting backshells 07 jam nut receptacle accepting backshells 06 plug for use with straight backshells 08 plug for use with 90° backshells 36 shielded plug for use with straight backshells Backshell type: Solder Crimp A RA straight adaptor EC RC straight cable clamp for solder contacts EC RC 90° cable clamp AC straight cable clamp without grommet E R backnut G RG straight removable backshell for screen termination and heatshrink sleeving J straight backshell with sealing gland JC straight backshell with sealing gland and cable clamp L long metallic adaptor and plastic cable gland - Shell size 08 to 16 M RM square flange receptacle not accepting backshells NL long metallic adaptor and plastic cable gland with spiral protector - Shell size 08 to 16 NS short metallic adaptor and plastic cable gland with spiral protector - Shell size 08 to 16 P RP straight backshell for potting P RP 90° backshell for potting S short metallic adaptor and plastic cable gland - Shell size 08 to 16 T RT straight backshell for heatshrink sleeving U RU short backshell for screen termination and heatshrink sleeving Z RZ straight adaptor for electrical pich access Shell size: 8 - 10 - 12 - 14 - 16 - 18 - 20 - 22 - 24 Contacts layout: see pages 14 & 15 Contact type: P male S female Orientation: Normal (not included in part number). For others note: W, X, Y, Z - see table page 76 Obligatory suffix B crimp version without clip for layouts 8-2, 8-3, 8-4, & 12-14, gold plated all over the contact 50 Crimp type contact: Gold plated, all sizes Solder type contact: - Size 20, gold plated active area, tin plated termination area, except for layouts 8-2, 8-3, 8-4, & 12-14 gold plated all over the contact - Size 16 and mix layouts (size 20 &16), gold plated all over the contact. 51 solder type contact (only size 20, gold plated all over the contact) 54 black zinc nickel plating (contacts as per suffix 50) 57 black zinc nickel plating (contacts as per suffix 51) Specification (without specification: olive green cadmium plating) 29 black anodized plating (solder type contacts) 031 black anodized plating (crimp type contacts) 44 nickel plating 66 crimp version: delivered without backshell and conical ring solder version: delivered without backshell, conical ring and grommet 12 Cadmium plating without specification -- 851 Series | Overview Hermetic connectors / Ordering information Basic Series 851 02H 8 3A - P 50 Shell type: 02H square flange receptacle not accepting backshells 07H jam nut receptacle not accepting backshells IH solder fixing receptacle not accepting backshells Shell size: 8 - 10 - 12 - 14 - 16 - 18 - 20 - 22 - 24 Overview Contacts layout: see pages 14 & 15 Contact type: P male Orientation: Normal (not included in part number). For others note: W, X, Y, Z - see table page 76 Obligatory suffix 50 Gold plating for contacts #20 & #16 Specification (without specification: 02H and 07H yellow cadmium plating, IH nickel plating) 44 02H and 07H nickel plating PC Tail connectors / Ordering information Basic Series 851 02E 8 3A P - 5016 Shell type: 02E square flange receptacle not accepting backshells 07A jam nut receptacle not accepting backshells Shell size: 8 - 10 - 12 - 14 - 16 - 18 - 20 - 22 - 24 Contacts layout: see pages 14 & 15 Contact type: P male S female Orientation: Normal (not included in part number). For others note: W, X, Y, Z - see table page 76 Specification 5016 olive drab cadmium plating, shouldered PC tail type contact* 5116 olive drab cadmium plating, shouldered PC tail type contact (only size 20, gold plated all over the contact) 5416 black zinc nickel plating* 5716 black zinc nickel plating (only size 20, gold plated all over the contact) 5045 nickel plating, shouldered PC tail type contact* 5145 nickel plating, shouldered PC tail type contact (only size 20, gold plated all over the contact) 50F9 black anodized plating, shouldered PC tail type contact* 51F9 black anodized plating, shouldered PC tail type contact (only size 20, gold plated all over the contact) 50A7 olive drab cadmium plating, not shouldered PC tail type contact (gold plated all over the contact) 50G9 nickel plating, not shouldered PC tail type contact (gold plated all over the contact) *- Size 20, gold plated active area, tin plated termination area, except for layouts 8-2, 8-3, 8-4, & 12-14 gold plated all over the contact - Size 16, gold plated all over the contact, same for mix layouts (size 20 &16) 13 851 Series | Overview Layouts Shell size Contact #16 (Ø 1.6 mm) Contact #20 (Ø 1.0 mm) 8-2 2 contacts B ■ ▲ AB ● ♦ AB 8 8-3 8-3A/8-98 3xØ1.0 (#20) 3xØ1.0 (#20) 3 contacts 2xØ1.0 (#20) 8-33 B C A A B A C B A B A FC D BC E BB A FB B EC D 8-4 ■ A FB B ▲F G C A B C ●A D EC C B E ♦ D A D C C AA 4xØ1.0 (#20) A FBG B D A D D EC EC B C C FBG A C CCC A AAA C A B BBB B B AB C A 10 AC B A B B A AF B B B AA C B C A E C D B A F E A FB D EC 12-2 C B B A AA AA A A A B A E D B A C C A BA A BB BB B B A A H C E C A AJ A KB G L L B CC CC C H A DD DD DP CA P A E K 14 J H F D B C C K M B M S J S N R RP G H F D E G E E B B C CF B A A □ ♦ ● ♦ EEA C CD A B C B A D BC DC C C CC C BB BB B G C AG B A 12-10 C C AA BB D D 6 contacts A A 6xØ1.0 (#20) C BC BC ■ ♦ C B A▲ AAC BA EE FF BB B D DC C G A B E A A C A A G H F D B BC C F B E C D D A G H F B EC D A D A H H BG C K F HB GJ E A HB KC GJ FD E A KC B J FD E D A B C CA B A A D A C D E J N B B A C F H D E D L M K J K N R P F CA 12-14 10 contacts ■ ● ♦ A A EEFEE E C C CC CB D D DD D EA H BA ACG FB A A D H B GA K GGJ KFC JG C B 14 contacts ■ ● ♦ H F H B E A A C N E H H G G K J C FF FFF EE EE ED D DD D B B A 14-18 H L BM D E K JJ JJJ KK KK □ ♦ C M M MM M YYN YY Y SS SS S CCB CC R XX XX X YZZ ZZZ TT STTTDD DC LL LLLM D D VV VV V A XW P L T A A BA Z W W W W UU UU UEE EE ED KK KK K N A A GVGG G HH HH HG 15 contacts 8xØ1.0 (#20) 4xØ1.6 (#16) 19xØ1.0 (#20) ■ ● ♦ ▲ 16-26 14-15 12 contacts 19 contacts 18xØ1.0 (#20) 8 contacts C D RR RR R NN NN Naa Aaaa 14-12 14-19 18 contacts ■ ♦ PP PP P DD DD L D LA A K A LB R P MD M M HG G GG G EEKEE E B BB KK FF FFF S N N M N W X NW CX A G J E FJ S M JJ C NB CC Y VR a V P Ya P H DP L P A W R L C R Z H HHZ E D P DD G U RK RM U X FT SS V SG T K E D HH HH H B D P F A ▲ 16-8 ■ Solder contact layouts (QPL) □ Solder contact layouts + Solder contact layouts without grommet ▲ Crimp contact layouts ● Hermetic version contact layouts CC CC C JJ JJJ ♦ PC tail contact layouts S N CA J AL A L L F A 7xØ1.6 (#16) ■ D H K B A D C AA B B G FF G BB D D C C CA B DC A EEB 12-8 14-7 ● ♦ J ▲ B BBC C B D C 10-98 AC 7xØ1.0 (#20) B B A A CA B C 8 contacts 6 contacts +ground ▲ H G F A 8xØ1.6 (#16) C DE 16 GHH HH H FEE EE E B H F F BB ■ D C 14xØ1.0 (#20) 1xØ1.6 (#16) ■ ■ ● ♦ ▲ ▲ ● ♦ 16-23 D UT U UU UDDCDD S cc cccb D U VV VV V EE EE E c A XX XX X A B Y Y W WW W W LLMLL LY ZYY FF VFFF E A N N B B AA CB C AH C A JJ AJJJHHXH BRJ H J E DG R A JJK JJJ W A AA FFSU FFFb E RT S b T PT AA KL K KK K G G GG GS Fb T PP AA SB A T A S A Y W AA BB C S C C M M Y M YS Y SN B A U DR C BS R aG N a N U SD UR D BBH J N Ha G B NN BB B HH S b T AA CC J H F G G A U BB B B G U SS bb TT c c L RR d K K F CK T LR T C A P AL d P C CC MR cd SV V X L ZX X d Ce L L T Z D T T Ye D D a CC N M D Z U L LYY c A RB A RB A ANN RBaa A RB U A AL M A ASS H V E V E V Ec M Z M Z M Z U DDB UB U R B R H H K K K V V V c B B F C P D P D N D N D f f X XX X E GW D e W W cc FF CC cM CA C Me M M W K j U g E LU E K K Y WL Y LW UcF E Wj Z Fg TG D LLM XX T T D D Y WZ MF b P P P C C V Z Z LA L M E A L b B BK B V K K A Vh P MP B V E Ah A JHJ M AA X A G GE P X M S ZZXC P S XC VV S EE C P A J H H GJ F H J a Sa Sa S MW E D B XE E B J H J HF F N N VV g N Af S GJ Y A SN Jg WC fN SN E TTW AA bW G N U bCEE N XX DDC X KJ KNGK KJ N SS AAN N D D D L N N N D D FT W C X BBW X WaX N B G B UU SS EE W KK W F D D RR BB LL YY A a C W W A a S A F F G B b Z a GZ R F H P J H Z TbZ S b YT A BT b HH R bZ BB F F T UU J Y FY J C JL HH CGG YFF C M J M F M F RR J HH TY E S M EC Y G Y KKKL N ddW TT Y WCC KKTYJJW PP C D S N E GG ee V Y C XR U a ZY X a VV aC V JY a R RaZ AM C E H M M M E B E P J DH U Ddd V H P P BG M M E KP G H J H H K P HD c P GN cc L K LD K d c F CF G b UU ZDDb M ZY b R Z Y Y c d US Y b c Td U c G C X L T C PP NN Z ff J ee W DDZ XD H H L TG D cc a G Z W Z J N Z a FS V M Z CC U D D H D HD F L L aVV L a F V E H j j hh gg H M ZEE V G LL GE R L L L F U U R U RF V XG E cF E D C MM bb E E W V V U V U U X E D X X V X V V X U F F F L K T D W F Y Z bb L Y T SXX TEE S T S U E KE W gg ff W NNF WM Z W W V E L JJ JJJ AA AA G H F F D D A a a W W J H V E G E G K K G KX G K K G K G G aa G ZZ G SS SSSAA AAA J F J H TT TTTAA AA A EE D K G LL FF J K H W J H U J H F F YY FF F F M K YY G M E SS SS S BB BB B J HL YJ H J H W RR RR R BB E BEB B F ZZ XXJ H J ABB BB HH HH HH H KK JJ G B H K K J G G U U U U U H T A S A L L GG KK KK K J RR RR R e Seee C PP PP P dd ddd TT TTT CC CC C F K G VV VV V CC B CC dd ded d R B JJ HH H cc ccc B UU UU U C U K PP PP P R d eff f ff DD CDD D NN NN NP DD DD D V WW eed eee T W W cc ccc jj j jgjg ggg W G G GG G CC CC C LL LLL bb bbb c VV U VV V hh hhfh P N J C A M M MM M EE ED E E e W XEE ED G NN NN N bb cbbb E EA S j g XX XTX T A T A S A A S A g g g g g f f f f f L DD SDD FF FFF D aa abaa W W WW WV S B B R BB B R B aa aaaZZh ZZZS R X J MLL A LL L FF FFF E H M MN MM M YY YY YFF FFF E b BU EE EE ER JJ AA YYgYY Y U TC T A A d T C V C R P e dUP VT Sd C P f CS TT AA SS AA F e RK d eL V BC L d D H A AKK KKKZaZ ZZZ XX XXXGG GW R B KJJ aJJJHHdZHH G G F SS BB LL LKK LL KK G G cGY G G F c LU BB L H M B E U d AH Y c U AU WRR A L A W A B A A BB P P K D WB D P N Nf eR d W DC U HX R RR A B U R D TH B C KK R B V PP VC f f K e e D D KV e P W dd B RTT BJJ JJZJ NHH HH CC CC B G c C K V K G j cg j M VV J c H Gj g g dd ee L M cV M U C U Lh b b VM V X U h hPK P C C cX c P JM bH UU D N D B B f K j Y j Y M M E E E e W U X X X c Gb P N E EC N b N b P X ANGGS CA P ff X A W SW DD C ee a D A D SD N A PaN T T i NNA T B A T cc AS N g f Wg j Ef Jg N S N g NfAN N CC SD N Z i j j gg W T L NJ B B b V C C A Ja F a a W W a W D N D h i N D D X J Z a Z Z a LX k m Z A bb kN VV S A LE hhP T LN Y FA EB L sT B B P P MYM W B M Fg Y M ME Y F Y F M L Yb YF FS T X A T AM S A T M M M B B B S S S M M E E Z T Z T b b R b R R X X C C C b b f RJ P W T B R S S Sh Ba Y NN EET bb W U ZJ X S BLL Z P AA X a P C h D r r B g U ff a E U h S H HX Z J Z G URC KHF J H P A a FF DD Y K K G P W W J M Vgm V V E ML M E P HB L K H JL R L KBK T G tU S n A V Ga GRa d H F E CY ZZ E aa P LL T d rf A A E G DK R BB d R LL aad M MR YR dV e YP FV R C e D UL V K T WCLJ RL D RR AA S BBR dA B FFc D U Z CREE P C d Z FF C f R RR AA J R Yc L dM hM S acCc hSUb c CYY S YY D KK H JK H HW d BB ZbCW L C a Lh a RR g V R g H c X eq SZZnYe Xb X Fe g bq U c K N J q p Z M M H a H G M M G U D D k c P c RKK Pkf e W c U kf VGGW C f WPP R fD H L P Zc D F e K HHa GG B ge d T LL KK JJj T P ZD g Z NF G f J G E X W DX L Rj G g P Wc E R e KK L j BB gd Z j T F E aa c E U H XUU dp LJJ eCCf mP E G C C m gdV V F d UT PP XX SS PCC f j h cf W S S V g P P P L H H X X V b V G F F P V V S V S S h N N S S c N N W W i i i L T S C D bS DE JK J K K CM DT H NN h P NDD e L d W D X K V YEXX K Y K K YU DgG NN j DDPe c gj d KX f H gj W W E b E N GN Gf M E n Ne X K K GU D G UC GD g N E b N X F X ZF j Z TdT N gF bb F D g JJf W W YY b TN T Mb N Jb f eCC f J H e f Le F Z a l b d K Nlj J Md F D J H H W aa U T U L TJa U T F W a N Z hE L K h h J H hX M Y F a MNM RR F J PP E JE EY X L E F M M E X V V F X YY PPX V E M M E HH J Y DD Y VV Z Y ab M G a Y fY A LL LLL AA AA M ZZ a MN bb GY M GYY AAddAAA cc UUc EE a k c g H Z X J JW J WE F WE D E K GK J H AA AA L K Z a G L K AA aA A A GAA AA W W W W W LL LLL J A W W W W W B B B B B A AA AA A Z Z M M M a H H F H F F G L Z Z Z M Y F E R R RR R H H RR RR R BBGBB BEE V JG FF L BB BB Y LLVV VV H KK KK K B LB H L H H ABB BB L G G G J CC CC C VVLLVV V HBB BBBRR DDH F H F F Fb F H UU a Z bZ X M M MM M A BVV VV UC U CC M MM M A UU UU U CK X K L LM G G W XXWXX X A C JL KK J J KH G J AFF B XX X XX X PP PP P R TT A SS B CCGCC C LD G BB BB B R KK KK K jj Vj jj YY YY Y B W W YY YY Y DDC D D UU UU U Vjj j jj K B J PP PP PXX XX X SS SS SCC CC C G SS SS aa aG aa SEE KK G G K GDD TT TTT U KK DDG D K H H M NN NN N SS SS S N MNN NN FF FFF GB 12-4 ● ♦ A G C B A ■ C A FF A B ▲ B CD C E A R RR R N NN N LN L AR A A B L A KP PP AL FA A E CHD A H A MA A BA M A B CK AB A BB M B K JM P K N P B RF N PC A P A BA B KA F B F G G AA A A BB PN A G G H E BA B HH AA BB A G NK J NC B N M MA FAB B B B B C A C AN C C J PB B HF G B E E L N P C J T A T C U P A B BRE N AA ECL H L RH AA D D S HB R b NT CLSC RC RU DP E C b T SP b CT J J C L J J H H M M M C C C M M M M K M K Y Y Y P P S S S G KL J C F B C C B BB B B a UH a N N LF E EC C C B E G GK KKU JJV CCR D B E F DHE D HC F E D R R B H D Ea S K NU D V U R D D U D HFF S H D K D K K D C D C L Mc J c c F C HJ C J D D DC F AA X RLZF XF T LEZD X CDT Z D LL CF B FC B AA NC FF ND LR LE L AAV E C C Z B DJVBM B ETZ S BBG V F ETNHHD AA M J RH D C D CE V E Z KM EE F ECC G F F J EET DDS E G A A A V V D B E D E D M M F F B B K K P P P N N G G E E G A A H W B GG H A BBB E DE DE D R XH K BB DD FK X H F N W AXL YW U U E E K K UW EK A B A C L Y EE A BB FL CY MW F GWA F M G A B A C A BBH G G G EE H G JJ TT UU PP CC J PH F J J RR H H NN C JJ F J FH G JK FH J JH J K KG KG G CFGM F B F J H M PP J C B A CCH B LKL KKA C A RR DD D E HH SS HKK L DM E D D CC L M C B B F E C H H D D C B B F E D FF F C K E CCD CCE J F F D DD G G E E K FF FFF AA AA A J EE DD R LL D LLL G G FF EE R AA AA A N LL LLLAA AA A C B N B E HH HH HAA AA A M M MM MAA AA ABB BB B AA AA A ML MM MNN NN BB B KK KK KM P NBB F A D P KK KK K L B B BB B A G G G G G B B B B B A EE EE E B H A M M MM M A BB BB BB BB B EE EE E LL LLLNNMNN N PPAPP PCCBCC C JJ JJJTTKTTTUUMUU C UPPNPP PCCB CC RNN NN N BC K RR JJ JJJ GMM JJ JJJ RR M M M KK KK K B E B PP PM P P CC CC LL LLL B E RDDPDD S RRURR KK KK KUULUU UVVNVV VRRPRR RDDCDD D HHJ HH HSSTSS D C R N J DD DD D CC CC C J C K CC P DD DD HH HH H L F AF A F A FF FFF M L CC C L L A DL AA A L A LH A A DD DD D CCHCC C A H JJKJJJ TTUTTT SSVSS SEEREE E D G GHGG GFFSFFFEEREE E D D C A EE EE EDD DD D A FG FMFE FF A M AKM BM A N B B A B A G G EKE E MDB N B K NE HAGG F A F HH HH H FF FFFM A K KG B C B B K A B B P P BA L A A DG CG A B AAL BA LL J G E F G E FF E B GTGG G S H A M M LL AA F TE PANJUMC P A C B MAA A B A B B B N KC M N CB B RE ND R JN E E E J L N J L PT N CU PA P LF N P HH C TAG J U C H A JBJ C AA R N KC B M NN J KK M G B G B T A T A T A S A S A S A G J J C C J S T S T R KK BB b M KM K MP K E B PEE R G G BB R B MCBB S S B S Bb B RG B C P L LE L M M Y Y B S S M M L R D NB P C J T C U P R R R S S S K U K V U R V D R D K U V R HH H HUEE a N N Ua D H D B JN BKH D D BK JD R B U D C UB JJ TT UU H H C R RR NN K d P JJT d P R RC Ve C VU C P C T d C T C P J J C C H HF D DC C M L K H D d e d Ve d c c F C F F F C C M KK PP X L LGE XF R T D D KM LLE U HE S D CD C D C D Z A T Z c c U V cR U D J T J S T E S J T S F F G G E E U D C RR A A F S S H H V EG F ED E D E D M Z D G FF EG AEF ED F N eD D D CC f ZD eD Wf DL V W E A LD PA PPc H AAPj f FLcgH AMPW V LNAA H A NF e G G C CV H C j F cg j H C GAX E D E D HH DD FF DK C AV B A Jb T VCCMS E AL W F g WM G X hK E F N L KH W B KAA M b BB G U U b VM G h G E DD Lh Y CC A B A E GL D Y L B G G FF N CM G FEK E NN F FE A BW F M E E CBEE D K BB b NXB Eb J X H E D X HM G G G G FF EE G G H EAA bR N E B E J BBH G SS bb TT MN R g f gL fN g P f C JD H B D F B E J F B H A M K K G G G F F D F J T C U P a a W a W W C C A M M Y Y R N B S R Z Na Z Z J a E L P C J T L U UUP LDDC N J C J aSM J E L YF FN M HHE K YM C F Y F Y FN aa G B E P M Y YF B P L Z X Z X Z cc FF CC M L K R VG R H E HS DH BXK DGU HD HK K D C LL XX T S K R V R D JT L D D KE K G UK LZZ K J G J L G J G D C VV H DVV H M M ZZ F C F M K J EE H J J D C L D C J HT S HE J F XX F EEE G E D C AA AA A T S E W DDD D CLL YY G UU GKK F W EE E W W E FF E D F A A A A A G H F E PP PP PAA AA A F C AA AA A BB BB B H F GG JJ HH G JJ HH D C A FF KK GG G NN NN N BB BB B AA AA A C E D A TTT CC CC G G GG G BB BB B SS S S bTb Tb AbS B RRPRR R A b A 5xØ1.6 (#16) A A B 3 contacts +ground ● ♦ 14-5 14 C AA F CA B D D C AA 10-7 A A F E CB AF EB B F C C BB AA 7 contacts AC C AB 6xØ1.0 (#20)G A ■ □ ♦ 5 contacts E A A F G B F B A ACD A DD C CAA BC A B AE F D B BCC B BC BC E CB E A D C A D D C BC B B 3 contacts 2xØ1.6 (#16) BB BB B B A 12-3 2 contacts 12 A 10-6 AAAB C CCA C BBB CB A BAB 6 contacts A C B A BC B A A AA A A A AA A G G AB A FF FG F FGG B BB B G F F F F F B B B B B E E E E E FD DDD D B F A F AF A BL AL AL A G A G AB E E EE E C CCC C L A B H A B H L A A BL A ED H A H A A D B KN MB N B A H A C A K M KNC M DDD C D CFCC C B A A C A A C A A A A K KB KB B G G B EA C H H BF G B A A A F E E B E B B M M M B D C G C B G R K NJ RC N R N F B E F J E E K BJ J JU TPH JUC TP UC P T C JB JH G E E D D J J C J C C A A F B M KM KM P P P L LMA L M A AK AA L L A A R R R C B C B B B S S S H H H D D D K EC D CC E C D C D FE BF D B F G F B E F E D G F E D BE B K H D H D D J JFD CK F C BB D F F BBD FFC G BB F G GC AA H R RE E C CD CD A A H H B B N N F F F G G G E E F B E D AA G F E G F E G F E D BB EE FF AA BB AA C C AA E D E PD E D C D C D C CC P D D HH C E C FF EE C C EE C C G G KK JJ CC FF BB D 8xØ1.0 C A D 3xØ1.6 HH A D DC C (#16)A (#20) A 10xØ1.0 (#20) 14xØ1.0 (#20) DD EE D D A A LL M M G C C BB BB EE CC A F B F4xØ1.6 B (#16) FF EE DD A F B F G B K K JJ A DD R R F B E N N F B D E B F G B BB BB B F D G G GG G AA AA A E C E C P P A BB BB H H HH HAA AA B C AA AA A F B E AE D C C CDCC C AA AA AA AA AE D HH CHHH A C CC C B C D G D▲ C FF FFF E ▲ ▲ H A B C▲ E C A G G GG GKK KK K JJ JJJ C C CC C FF FFF BB BB B A C A CD H H HH H D C E E EE E F D D DD D H LL LL LM MM M M A A AA A FF FF F AB B BB B F B E E EE E C CCC C D D D D D B EA C A A DG G F F BF B B F D D E EC E C C D E B D C A AAA D DDD B BB C C BCC A D BC C CCCB A AAA BBB C B A ■ ●E ♦ ▲ AA BB B BBB A AAA B A ■ ▲ ●AD AD CD A BC A BC A B A B AC B AC B A B C♦ B C B C 4 contacts 3xØ1.0 (#20) A 3 contacts ■ A AC A C A C ▲ ♦ B B B C 3 contacts A Mixed power A B a N M M MM M ZZ ZZZ 26 contacts 23 contacts 26xØ1.0 (#20) ■ ● ♦ ▲ 22xØ1.0 (#20) 1xØ1.6 (#16) ■ ♦ ▲ Other layouts, please consult us ii i ii ZZ ZZZ C W WW W WXX XX J X HHZZ ZZZ NN NN N DD DD D ii i ii FF NN NN N P DDCDD D X kjk JkJkX k HHY B K Y TT TTT U ss sjkssk kJJkkm EEDEE E m mm m ZZ ZZZ abb bbb S TT TTT DE SS SS ShhT hhh rri r rr m W WW W WP YYXYY Y S TT TCTT D N JJ JJJ W C aaZaaa N maa ZaaaEE EE hh hhh i N D X Y CC CC k km mm M M MM M EE EE E VV VV V aa aaa YY YY A SS SS ST FF FE FFB PP PP P rr r rr tst t tt nn nm nn M M MM M E EE E A W Z TE A WWa AA L W B A B S E BW Wbb bbb YZZ ZZZR R TA AB R B A J YY YY Ydd ddd cbc cccR UU UV U UAW BV h B RC A RB A B Vm a B B r R R R R R g g g g g b b b b b F F F F F h C C C g g g g g b b b b b a V V V q q q q q nn nnn qqr qqqpp t ppp n ZZ ZZZ Y DD DP M aa aaa SR M UE U C C CW RR R R HH HH HV D D FF FP FFE A LL LLL L G GX GG GF W A B XA X AC LL B C AA LL M A d P cU U P b Z R LLL Y FF j FFFX R LL Y B UU UU U B R pp ppp cc cjcc jbU X K RR RR AA Yj C Y VjY X R Y F D Y BAA D BB D RR VV VV V UX a S XX XX X VV VV Va V PS X C S C CS ffg f ff qU cpc cjcc b G GG GU PPRPP Pff g f ff qT Ui n G a KK S BB aUUPUU D R S S W P DNX N i T PS i ZD D M Z CD eLeedLdLLddid HH HH A D A ee eee dd ddd i H PPR PA P P ee L H TT TTT SSZ S F W WW W WT L NM D AN B D A N B AK X D TD M i Z ZX Y Z C Z M M k G k T NN NN LK KK N f B Tp cH G GU GG G EEN EE ER X K K XN G G GG G Fk HH H KK KK K V N N G G GG GN THks G k msj k m E E U NN NN U Bf T B JJ JcsJJ U m j PP E Y P X S C N Z V Sb TaKK SE FF FT FF T SHH E B S S W B Y W H M MM M XX Z a SS DT CC JJ dJhJJr J A P M i a PPE eAKKLhKK M W bCYTXMP N TR B JJ JH JH J HW H H Z YN bZ T STb SS M T b DNN P C R BJJ JJJHHW SN H eKK PT M h h aW aT N hK M MM M K d a a k aa C r r m m m L L L L L K K i h N D C W k U U V a C C N JJ G K G K M M G P E B B r J Tt SXXT M E t rNNn t V E M Y SrH FS FE n SDD WNUS P n n NNs F m Md ZW cd YE dcE T E V M d V S bE F d cZ U U S H M b Z b Z b J J J J H Y Y U U Y ZZ R R C h M K A L R R g Rq g bR nF Af b F h W YYb aA m RTT p f JJq VC e C R LgK D g q C C gn p rbq W bFp m b a a L ha LYcW P SA C aAe hE c D S n X Vg D Cq W L L C q p Z R M a a t Wn V A a a S W L A Y Y r A A R B M E B VG R HL D F F F RRR L L M M P dVV k G B AA V EE q g R B Y kFZ M M VG dd f BWR f Y W L V L UP bHHc FPf LB D DR cF c U Acg PPk R KB BU p Lc P p g fc qc U b ZZ F e Z RV Ug Z j U M bc V XT gc X XAV Z a ZVA X f P pVf j f G bn e m G PN P E fR A A qYY p z U C BBm X r g dE T M M PP G C A h W h CW T SH E e DR d N WA eB L HLd Pj aXa HAYP eA D W NN BZ AA LZ W V Rd D CP e TT ePd UH Rj d eHH d ZZ i L d B L KK D KBS Y P P X iS FC FFj L F PDD E A FB D EC A B C D F G B BD E C D C F E F E 851 Series | Overview CC AB C A CC BB AA A AC Layouts C B B A A A B E B FF C C D G FF EE Shell size AA BB FC C DD A E D G E B B D F H F E D E A B B C F C J L M G M C C S H T Z V E W J H K B B R Y FX L A C D U G D E EE DD BB BB EE DD C R P G d c b F M AA GG BB HH FF X DZ H J 20 E Y F G LL KK C S J D H HH aP G BB B T Z E Y D S F XX WW J J HH CC TT ZZ VV DD L K P R J V D H E TT SS RR NN MM C D T cc jj bb AA UU dd ee A CC XX W 22 A w k L g z h K E f y i X J W D e x j C d KK B Y B c AA S Bb G A A P H F BB C C C T C AT P a N F DA H M A B B E J B H KK JJ a u b GG v c B d P D X C BB E C F G AA EE D D J E G F E B C C T G HS FAE E H F G B G J M K L BB EE GG T S AA R HH d D J A U e P BB BC C V D D A C C BB H HH AA RA B P D AA H H FF A C N A B G G EE B A H G BB K A K H H G G M M U BB K BF H M G N C P R J R R A E F ▲ 20-24 B K C AAL AA BB AA F CC D SS bb TT E aa D UU D A cc B VV EE MM ZZ XX R LL YCY WW FF J J HH KK GG GNN MM Z Y t a u GG v A b LL c B cc aa gg RR EE HH GG KK aa ZZ s XX HH ee GG SS dd WW EEC D D J N T B M M PP H L M H L M D E R R K PJ N K P R P K R P C C FF A JJ A KK N N H H LL M M B R R Mixed power A S b a N M L D U V X Y W E F 18-30 J K F C P TP c Z A E BB D D EE H G 30 contacts B 29xØ1.0 (#20) 1xØ1.6 (#16) N N R U U e N C e V b Mf W D j g g f B h a X Y E C TC RNACS b A LB Z X a U U KZ C Y F e P D Md D T J H H K V c V UJ N BE D G ELe f W b W V E F YM F g f X W G a G L F Y H Z X K G J H P B A d W d P D V c F C HW X E F G EH J ▲ D VA f FY Z K B G g a L ■ + ♦ C U e b M A T c N E G K C D 25xØ1.0 (#20) F N DD EE M h b X Z a NNE Y hh bb □ + ♦ b 20-27 XX ZZ aa FM M M EE YY HH G G L FF V g a f Y AZ bb M E M W VV gg aa F LL N A L K H J N LL KKA JJ TK X 27 contacts G ff YY ZZ N W W XX A 27xØ1.0 (#20) UU VV ff ZZ KK YY JJ C WW XX DD G G FF EE EE H Z U G FF T S F D H H Y X t TT G G FF SS R R D D ■ ▲ ● ♦ 20-41 EE FF 41 contacts ■ ● ♦ ▲ a L V EE K 22-32 b c GG v B J HK L a Y aa LLF G VV 32 contacts P JJ HH KK GG WW VV FF TT CC UU DD EE A ZZ AA S PP f f N C GG ee dd NN HH MP M LLKK JJ R D J GG H 22-36 G E F a u GG v b c B R AAP a AZ U T L K U UN M ff h EE w W W N Y L F Y Z a gg L 22-55 H T F A U B V BB CR R G 55 contacts C JJ MMP KK Z U T S F c R Y Z J nn cc pp G G ee dd H H M M LL KK JJ SS RR PP ee mm NN MM dd ll cc LL AA TT ff UU gg nn kk VV UU TT □ ▲N M ♦ CC hh WW DD jj XX YY bb aa ZZ KK JJ HH EE FF A P W L R mm zz yy ii MM h h xx gg LL D T kk jj NN C S U J PP B X V K GG SS RR E nn pp AA AA GG GG FF FF ww BB BB HH HH EE EE vv BB WW qq CC CC DD DD uu CC XX rr ss tt DD YY EE M ZZ aa bb cc HH dd ff JJ KK e e L GG FF Z K SS H m m ll bb KK U U gg nn kk D A U AA TT ff T BB VV jj aa ZZ JJ N H H S C C hh W W M XX R D D P EE N A YY R FF G GP X W M h C L Y T Z a V n ■ A ●b P R B a♦ h c S X j H f d e W G AA z BB GG HH FF x EE w g D f UU AA BB TT C VV SS nn W W m X RR pp X D m q qq Y kk AA AA rP zz BB BB P E CC CC CC Zj j GG GG y y s s HH HH NN F ai i FF FF DD DD DD xx t t EE EE u ww uuR bM M Ghh vvP gg c c H d dd a LL ff N J JJ K K ee B v K e Z E M T U V F E S C D R A T c N b i j h a M L D f W g X Y Z K C V e k P B U d J E F G H 61xØ1.0 (#20) A Z 24 Y X W V U T t s FF r a u b GG v NN PP c w HH JJ B C d x y D e f E EE MM F KK g LL DD z G CC AA h BB S H n i m j R J M k P K N L q ■ ▲ ● ♦ p 15 d X K G H Y L 61 contacts tt e L M W p F U J m y i B V K k j S b L E g f N G ▲N Y J F G AA VV P F 55xØ1.0 (#20) BB q R E W X ff N N D V f GPP H C U e g a c B J E b NNY a V A d L KT d D hh J n p e S M b K GC G g CC g c ee EE v h W PP D H d YY DD f n XX FFK e i Ji d d kk mm ZZj E TT N EX dE N N ss l YY G G SLS hh rArc t t knn aa Y cc FF M M MF ZZ M H H gg b qqbB ppa bZ K RR GG JJ L G LL W cc f fN X K H ee LL ddJ HH PP ii f NR P M t u P G G E s DD FF VV H H D ■R S Af A WW ▲ VV XX P e m UU♦ j j HH FF D D x W W JJ X r CC XX KK W X q BB GG yC C iV V ee W p AA z B H VJ m k B jB g h LF L AA TT aa bbBB YY BB SS cc CC CC UUvv XX C uu GG GG VV dd t RdR tt dd DD DD W W w W ww D eeHH HH HH s sse ee kk f f WW xx Px cc FF FF NN FF NN V VV JJ P JJ JJ EE EE E NN r rr f i PP iPP ff PP gg XXyy y bEE j j U EE MM MM F MM KKUUNN bEE KK KK FF FF gg q qq g DD LL LL DD DD hhLL z z z T TT MM YAA Y GaaCC GG GG CC AA CC AA p h pp hh BB BB ZZBB S SS LHL HH HHii n nn i Km K JJ jj m j m R J RR JJ M k M M kk P PP K KK N NN L LL X M f j b 34xØ1.0 (#20) S n VV JJ HH c N 34 contacts ■ + ▲ ♦ XX X V TW A KS BG J UH C V d e R 22-34 B 32xØ1.0 (#20) UU L G G JJ H H C b FF U U KK B A Z G C d UA J H A a u ZZ U U Z GG HH R E AA aa bb BB uu cc CC GG GGv v dd ww DD HH HH ee xx FF FF NN NN VV JJJJ EE rr ff PP PP yy UU EE EE MM MM FF KK KK gg qq DD LL LL DD z z TT GG CC CC AA AA pp hh BB BB SS H H nn ii mm jj RR JJ MM k k PP KK NN LL ss C D 41xØ1.0 (#20) YY XX E 37xØ1.0 (#20) 2xØ1.6 (#16) 24-61 WW B J 39 contacts A W A ▲ H ZZ A H G B 20-39 A ■ ♦ LL FF 22-21 Y RR BB cc ff B FF A b S ▲ 21xØ1.6 (#16) AA jj gg YY JJ FF hh A A D A P JJ C C D E AA C F 25 contacts 24xØ1.0 (#20) NN PKP 21 contacts d Z LL JK N N W A B A B V R B B R B C V M M U C M X X L A A P B A C CC B j Y BP j Y K R D UC R K B P X S C P X S CT a S a S T N KK U U VV RM R DDW N N i Z D HJH SSS RR DD N N C W M F A D i Z N D D X N P X k B E L K L A TT D s k m HH DD Z T H A P X S C Z a b b S E A A L L W Y T WN Y T h J MS N C aN JJJ TT S SS JAEE N C W aN K GG FF EE r C Y m D K B h A XA a Y GG FF A A A G B W W W L L L A A W R A A A A A A M E M E P t V EE a V P HHE RFF nB B MP E Er Bb R B B W V MY B V V BT B FZV H D K K d M cS U B B B b b Z Z R g R Y R Ed R cB U B B R A L Y J C J T U b F G G R R N M M J M Ma M U Ug UqX p X C b C E C n Z Z R A W jA X M P P M F Pq K C C A j BX JY VP Aa LB Y P RC P Ca H D B LHFB D K K j j Y Y M VG UY R B d L BG B E LK R K b L Z P X H SU CD C F R L P XP SX CS S U A a SV pa S c S R T DS P cZU DZ H N S V W NU N N N U N P Nf a iD Z D VT iFTf i X V W D C X G F M C C CMW J T BS S N D N N D D i RJ Z X a N D D X X X K S k k CH e kL d k H e W WF d P L H D D P B EG T T j F N sY G GT Z b C b T HS Ta E KJ G KU G hS G Z d CP TXUZ S bC K R T P CE TJ amiL E ha GXE F WK W Y D Y TG JS J NFY C CW W C h V rS N rh N mD GJa FHEES F FT E MD D J H J J H N S N a aV J aHY YC P k M r Km R R P J P W E M M E ET c H VD V S PY M P X E M M d LK E K bE DN H U D K r T G dc D b Z b bZ ZM S YYG Fd U Y Y UcZR Ug W TEc e J C hb b F R g R gq m q qn n Fr bg F Jq J H n a Y aP Z Z V a Ma RH E PZ D b JJ V R D H H D D F F F L L L M E H A A d c G G E R R R S F L L F M EE Z c U pU p Rp c g c YV F TU A TT AA U A SS AA U V V U U Lb V X X V G G q Gf n F F P f P fP f g f ZV T ST S R aX S BS SS BBT e L e e ed P B D RR BB a W W W W d d FG L G N N G E E G G E H EU G K K GN H f H p K T R G K K G K LG F H BB F LHH U UU KKY d dd TT V U N R C RR P CC X V VV F CC F M LM Z X JP d e F FV dd ee J H J HJ H J H J H T S J HC PP M WM L K J K L K J e d K G c G cc N EU UU K G K G P P D P D D N D N N D D f f f J e e e W W W F H M LK J c cc G G CC J H J H j jj gg g Eee bbF VV KK PP J D BC B BBA KK ■ + ♦ s NN G G ▲ SS EE MM bb E 20-25 24 contacts ● ♦ P JG ■ ● ♦ P N ▲ N R AA H H C E KK JJ 36xØ1.0 (#20) AAr R LL D CAA A B M M AA BB M M N B KK M N N BB M BB K P C LL N N PP C C J T TT C JJ C N U P U U PP LC C C R R R K S V R D KK U U VV R R D D H H H SS D D D U H H D D S A J T S E JJ TT SS EE F R BG G G FF EE E G G FF EE T PA S A H F H H FF d T C S B R B G G G c D J T (#20) 32xØ1.0 S E AA JJ KK LL ■ M S B B J C CF D D 36 contacts PP F M F K W GGD f C w D HH e x FF NN JJ E f PP y BB MM EE F KK g q LL DD z T RR WW G CCCC AA p h BB H XX S n i VV SSR DDm j J M k P K N L UU TT V NN MM F LG L t D P T Contact #20 (Ø 1.0 mm) U cC Z E A Z JJ L A CA K N ♦ TT GG FF D E K A A U KK G G G T B B B T J JJ P HH R B P M B A M H CA T M b S A T S R B A C A A N U AM b V U T C P P BN A B S P S B A B S n d V d V U U B P R M R N M B B SW X W R W R Cf A D C f Vb C V R C C G P DL B a a h c S h c S p U DR L C L C SRb T m R e e V k qd C Y M k Y fW W k c AAD f N Wa c R gA S g P Z T R P D Z T X U X j A A L C j e a h c S E e r e P E EP N A N NA A m z H C BB N N gN A Um A U A Ad h W D P T TC g T L B hB W D B d V S V S cj F i i D K D B k f CC c W Z GG K Y D b T T T DS L S X P A Z Z CgT CDj A d bT T j A g NBXX KS B B B P M M M g M XZ T y VTA M NbM b P nU R B b j P R BR n U M C E Y U E A N C s N U U V V HH A d F X d T P P P X F B A B FNS X S B B S eV j A N Ad B dl K VV j V U A TA Df W W L U T A WB A K h V E ES B AR f A e B Si aN SE S n n l W UD hW U U i DD R J R BE V V R R K W BM b B P DRd B E M RVC A gm X X V DV R W R Wf FF YS U D E R V EEbS VC jTt C L C L RLJW X WB R C a J hB c RYC Rf S cC YC S mp YC L G pF k X x FN UDe Mf U C a V V LEP C L ULa M ha X ach S C J D R R Rm G c eCH ke G W B c W f M U e C E Y Y J H X X X U T P C P CY J V Ug kAA q u bh kM Y k E U f f Fd W F j c WUj P j Y cPM kc YJ k DfR W AA j Y K D M h Gg w g H P X BSF C F k Hj F Z T HP X V Z Z T Z Z T W R D G P X S C X X X a S a S j j f L V L C C e e e L b R E E E c SH C T T bG HP rZ Z PWe m E z BB g dG g L d Z adD h H F gm h MvWh a BB a i g iF Z D W WcP D Yz a P E P z P m D N X GN DV S V ik ih W N N k Lm i Z JiE c k KD GS D S K DN K KV D DD J J k Dm Z Hg j j GG E L d f TW K CC ZG F j T i Gg T LGG K s Zj g kGX Z U HEDU j D Z T K XY ZS YK b Y T n E s n f n ee L mJ bT U D S W Y C T bN jab EKj aPg X H yH h h X r hFN hy H W KHH AAY L LLW dF F l Pj K Xj rf m X N dNa ld X h j N F N y D J sH ef m ea g N G b d V Sf l W JhF HA F Y U AT U U T TE De N Gi EKN E Ma t t En hD a A S F P W W AA DD LE i J i i FF A W FF r nh A J E EKKM J M b JY dZ K c E j g S XRR AAr X A V MLL Y d AA X c X U K E V V BB b Z R g AA BB M VxV BB t U E K B BB Y R J g J q W n W Yb ER F f E Me B a U RR k gF kV k dY Bl Y n xE Mapb Fab NYR b YG BG c Vx EE G X c c W J E g b q n Y q q p j Z M M M T aD M M C b N X XE u C wX R h M hw X FH L L P G Mh C PP R MG U F CCM F C FM UUh F H aH FJ F KF U F M EB M Z Z Z X V B B KK L j Y j j Y Y j G R U L F c c U p p L L L b b b H H H fH VH aS Y Za cZ C G N GU G V kT ii g Y v H N F W FJ P G F X WS c a aa Zf SS M g g v V U V f aG Gc T T D E PPJ P XX f SSeP CC NW S SS N NX ia Z D ZZ c D W W XXXP N T S CJJ C CW J eG L d D D DL dK N KJH e G d NG KNN J de D D LH X F G H d L Li L k k L G Mk G HG f kF ZT L NND HZZ P T N N G K E K K G H H G K G SS AA sf Lb TT G J Z J S Kh K H FT bb N TT N Y W W YYM F H H b aSS a Ehh Z rr K e m K CJJ C RR BB HMC J W H J H J H J H J m J aa EE h J r J Lm M K G K J K J L K MJ EE K a aa Y YYJ PP L K M G R R R M M E PP t V VV S P r M M ME EE dPd T PP H DT H H CC D D d c cc U b Z bb ZZ Y U YY dd U K H R g b R R F g g b b F F J g q qq YY FF HH GG JJ EF J N 18-32 B L EE ZZ N A b B P R B FF P G A J ▲ F H B B L K A B C 32 contacts JJ WW DD gg hh aa LL KK BB VV ff F C D L A A L A HB A M A B M A B M B K N FN A K B L A G B L A M H A L N P C LK NM PN C U P J C J TK U P B C J GR P N CB M K M B R K U V R JD H ES S R RN D DL KJ UT VU RP H D DC C J C L A A A M L KD P H D H L A L C A L LA F H AH A D T S K E LMK N M BA B J H TS SR E F G EE FM EA G M MBN AB B B J DC C K A K DK K B M B N G F E G G F E L A B G B B B H D H H F FF C L A M M H A D C MJ A B G GF E L F NLE P N CP M C B K TJ DUT LPU NC C B GJ C CN P PM RJ NR T CN UKC P E J J J R GN G C J B M MK KP P P M L L B RR D N S SH KR S UDJR VT UK VU RV DLR N D P C H H D RU DP C K J C B F P H C H H D JD C F C M DL K J TJ ST EKS U E V R D H SS E R A D F FG JEF TE G G E EC DE GD F E G F GE F E H H F H HF F D F F C C A C T S E GG G G J F E B AH E D G F E D E H F L M CA B A D G C A A A A B P E ■ E b EF C E C D D D E Fu Dc W C w X D AA N HH Aw T e AD A Z ZA GG EvU A HH s e T BZ B t x Bd x WT V JJ M A T HH w E T V A FF NN M MFF bNN P JJS R B S D E Z C Ar s a Cb eC U V r ba bB S B P B B S fU Y Y Ya f PP PP B V d V U U EE y USFF NN n JJ W x V U R KK dy X EE E u uR uv c c c WL R D D MM MM F C C C F X X v v KK f f V V L C C C R a h c S a h c S gC m X f a C Lq D GG GG GG r R b q e eRY g PP p B t t t LL DD LL Y k w d wuf d WTg c DD W w d WD W c z U gEE k MM AA KK q y T Pj c zWk T G f P T Z F C D v DE G XZ X j ee m e E r m z g d g d CC AA HH HH HH GG BB s s s A CC AA e e h h W W P P P g q Np d A D N AA p h i N N N V S hN A AA LL D itx T CC TT B E K D x x BB BB jDD z Z GG S S K Y D K D FF FF FF T NN NN NN V V V W H JJ JJ JJ j g j g H E E X n E w Pn G D U Yn PP M M bBB M i bb N eb i U X FB M SS CC AA y S bF R Rd BB N np s d f M HH s emR B M C HH r r rN X X F h f e f f f U PP PP PP m j j l l j j P P P U T N BB dE DD R E k J h R x J M k y U y M S i FF V N h yFF NN U UEE H aV R E EE X V V E MM R KK MM MM n R F k JJ F R D dd PX KK i AA J LL P KL a EEW Y K WqF R R x Y t EE j LLC g W C Cr LL KKcLY c C W ag G h c fA hh cc SS J E J N WM g L qE DD q M DDLL a NASLL L C aa Y m C kR PP A A LLG W W L L e DD A A A A J k M y w u b h zZ z MEE M F F RR F F BB RR z B U M P Z TB G T KK BB H W cc kk GP MM KK Zj LFT LCC Pg N cUU LVvkV K c f BB P T ZZ TTb bZG H agG Z G X H AA X CC H F H CC AAq AA jj MM a MM CC E gd gg dd p pX p h h h XX G G SSBBT D KBB DD BB S K BB KK j jd i H YY L LJ H LLH PP z aGa GKKSS D CC L Gf S K SK V n J D VV S D PP XX K D n n g ZZN i SS HCC i K CC i Y SS NN CC U YY DD U U KD WW XX NN J bb jj N TTb Ki i ej N X DDF JJ K JNNAAf H eh H DD m mN j m j kp Jj J kk ff ee R UN J J BB MT k U UR TTR M k M S Hbb h ZZ TTX A L n J E J J E E P P P S S EE i W W Y Y T T K K K X V X V V JJ CC m Ym aaM aa N L LN RL m M hh a r r M G YY PP W W RR J M MM EJJ EE MM N EE PP DD k j W J VV aa K HH cc UU EE H Fbb H FF ZZH P ZB YY K dd R R g g b b F FLL M L H N HL qq G G G nn F H H FF ZZ aa HH DD FF LL G K pp J cc KK GG EE RR LL G FF G UU B S A AF A L K M B E EE RFF N B J D A C C P A B S Z V NN N UU EE GG FF C PP N R Y X 16xØ1.6 (#16) C CC FF EE PDD R D X A JJ KK LLN BB SS B N C DD EE AA RR YY A CC LL FF M N X W G H U F AA KK GG M J RV E JJ K ■ ▲ ♦ eP K A L K B PP NN DD L D B T G AS A E FB J R B U d C V TC d c U P D H f e W D c N j g b h V M E X N E b g f W Z aa L F H M F YY Z H X K K J G L G J H G R D C W g h a D F F EEA D S C MM A P B V MM S CC B CC EE N f j L E L K A U K e N D A E A K H H B T B H C LF A H A K B G DB M E R N J J P M LC K AA J S B L M F E R K N 16 contacts AA CC J A R J A 20-16 F FF AA BB E B D S AC A FF C CH T S B R B A G F E EE D DJ BE d D BBT U C R C V AA d e CC c H B FF U D K P f e W D KK JJ CC FF c G C c G C j j g g HH E E D D L L b V J J J A A A h h L M M EM G T A T AT LA S N A b AS X X CC BB N E b C E S EE CC B S g S f B B R FF JSEE DD R R F D L B a KK F D a JJ W A H H aH Z Z D BD B B U U U FC P TC dA LR K K d T C E M YK F R d e YP F Pd E N dY eX V RR V eR VS B MBT ADC d N Z H H c c UK PP G ND c DU F K B J J L K L G HP G AA A K D P P D N N R C f f f P E e W W d W A B A BG e Ve cC c J cj H G C G C j g g j g L L L BC b V b b h h h AN A C P X MEX E M M S Rb T S b T fE X W D N E N N b b b c G C j gg f g fg C M S F F D D La a h W a a aY N N Da Z Za Z a U D U FD L L L M Y F M M FY F E E E NY E F Y X Y b c c Z X Z ZX X L T D F Z HJ H Z Ka K K G A AA E J D H G V E V L K L K LJ K M Z M Z G M AG Y F VX AA P PP AE AA J JH X A B J AA BB H W UW EF H KL Y K W F L Y JC N NN B BB L GAA A CC G B G G BB GH J H S b T SS bb TT R RR J K HJ F K G G C M CC M M Y YY S SS a N U D NN aa UU DD H H H c cc F C FF C C X L T TT DD D LL XX Z ZZ V EM VV EE M Z M ZZ LL AA VV V X XX E D EELL AAD D HH A AA L A UU EE W W U EK M K KK M M FAA LB M LW W W W FF K N N BB L Y LB YY KK LBB A JB H A A GG BB G G G JJL HH R R J H K B K JJ HH MM F FF B LPP CKC K KA G G G L L N N J J T T C C U U P P M BB A G H 11xØ1.6 (#16) G C C L A 11 contacts H AA CC P FF C R C M Y S NN a D U D G B R C M Y Sc X L T D Z VP E H V E M Z A A A A A V C A A A B B FB XT X L D W Z A U E K N NW F B A B B EA KC W W F L Y N AU C C A L Y G G B B S T S S T T P A V R R R G b b b A B J H J H E J HD G F J H F C CS M M Y Y GY S KM S W K G U E K Na C B a a N N N C U D U AD U D G B H H S b T R G c c c F FL J H A F C LC XA C Z S X L LXZ LA L T D ZT M DT Y D a N U D M K A M B NM BZ V E H M KN B K A M M Z M A ZXB XV E V E c A V V B V F C X E ED D WK W U L L G U E EUXY E Z KM W K WTFF D L NY L PY CW M F W B VB E Z FF L N P C L J J T T C U RP NC H U P V G G G J J H HJ H J X J HJ H F PJ E C D F K K G GY UG E K FKW W D F L R S K U H V S R RD D K H D G J CU V R D E C L H J H F H A FF AA FE D K LL AA G A L A M C 18-11 B P N D J AA N B D E D 18 BB H DD CC K C D A A C Contact #16 (Ø 1.6 mm) AA EE A A A A A B D D E B B B E FF GG BB DD EE CC A E F B BF G B E A AA A HG A FG B BA GF B E B E BF D JD M E C E E C CE C E E L KC C D C D D D D F A F FCAD C A F C H A D C A A A E D F G E B E E B B B A B B E E E J M K E B L CCAA BB AA DD E D C D DC C BCCA B GB G A H A B HD A DCB FC D C D A C A E D C H H F D G K JF C G K H J C F B B AA BB F F B C D B D C A A E BB AA E B A A Overview F G A 851 Series | Overview Environmental versions Technical features Materials • Shell: Environmental version : aluminium alloy - Plating : - olive green cadmium - black anodised - black zinc nickel - nickel • Backshells: Aluminum alloy • Cable glands: Thermoplastic • Coupling ring: Aluminum alloy • Spring washer: Spring stainless steel • Insert: Elastomeric soft neoprene • RoHS compliant & conforms to the Chinese standard SJ/T1166-2006 (Chinese RoHS equivalent) - At reduced pressure 10 mbar: connectors mated and unmated - 200 Vrms between size 20 contacts (service 1) - 300 Vrms between size 16 contacts (service 2) • Insulation resistance ≥ 5000 MΩ under 500 Vcc • Current rating per contact - Standard version: Size 20 = 7.5 A / Size 16 = 13 A - Hermetic version: Size 20 = 5 A / Size 16 = 10 A • Contact resistance - Environmental version: Size 20 ≤ 4 mΩ / Size 16 ≤ 3 mΩ - Hermetic version: Size 20 ≤ 30 mΩ / Size 16 ≤ 14 mΩ • Shielding effectiveness: 70 dB to 5 MHz - 40 dB to 100 MHz • Fluid resistance: - to MIL-DTL-26482G series 1 and NFC 93422 - HE 301 B code A - Hydraulic fluids - Lubricating oil Mechanical • Durability: 500 matings and unmatings per MIL-DTL-26482H COMPLIANT Electrical Environmental • Dielectric withstanding voltage: - At standard pressure: mated and unmated connectors - 1500 Vrms between size 20 contacts (service 1) - 2300 Vrms between size 16 contacts (service 2) - 1500 Vrms between mixed size 20 and 16 contacts (service 1) • Operating temperature: from -55°C to +125°C • Flammability rating: UL94 HB • Dynamic salt spray: per EIA-364-26 - 48 h nickel, zinc cobalt, zinc nickel - 500 h black anodized version - 500 h black zinc nickel version 16 • Sealing: - Globally IP65 (unmated conditions) - With J or JC backshell IP67 (mated conditions) - With cable gland IP68 (mated conditions) Under 10 meter of water during 48 hours - Crimp contact version, 1 bar differential pressure, leakage ≤ 8 cm3/hr - Solder contact version, 2 bar differential pressure, leakage ≤ 16 cm3/hr • Vibration resistance: 10-2000 Hz, acceleration 15 g test procedure per EIA-364-28 • Thermal shock: 5 cycles, 30 min. from -55°C to 125°C per EIA-364-32 • Mechanical shock: 50 g, 11 ms period per EIA-364-27 851 Series | Overview Overview Hermetic versions Technical features Materials Electrical Environmental • Shell: Steel • Max current rating per contact: • Operating temperature: -55°C to +125°C • Plating: Iridescent yellow cadmium Nickel • Contact: Gold plated ferrous alloy • Seal: Fluorocarbon elastomer Contact size 20 16 Rating (A) 5 10 • Dielectric withstanding voltage: Service I II Standard pressure 1 500 Vrms 2 300 Vrms • Contact resistance: Size 20 ≤ 30 mΩ Size 16 ≤ 14 mΩ 10 mbar pressure 200 Vrms 300 Vrms • Hermeticity: 1 bar differential pressure, leakage ≤ 2.8 mm3/hr • Salt spray: 48 hours min • Chemical resistance: To MIL-DTL-26482G Series I • Damp heat: 21 days • Shielding: 70 dB to 5 MHz 40 dB to 100 MHz 17 851 SERIES © 2016 SOURIAU - SOURIAU is a registered trademark 851 Series Connector Environmental connectors .................................................................................................20 Hermetic connectors .........................................................................................................43 PC Tail connectors .............................................................................................................45 Panel cut out .....................................................................................................................46 Backshells ..........................................................................................................................47 Push-pull locking plug .......................................................................................................49 8F51 filter connectors ........................................................................................................51 SNC specifique connectors ...............................................................................................52 19 851 Series | Connector Environmental connectors Square flange receptacle with straight adaptor E L F D HE 301 B 00 RA ØK 00 RA ØA HE 301 B 00 A ØG Cross reference 00 A ØJ Shell size Part numbers solder contacts 8 851 00 A 8.. 10 12 L max crimp contacts . 50.. 851 00 RA 8.. 851 00 A 10.. P S . 50.. 851 00 A 12.. P S . 50.. 14 851 00 A 14.. P S 16 851 00 A 16.. P S 18 20 solder crimp A B max C max D max F max G max J E K threading UNEF 2A . 50 .. 41.00 12.03 11.70 1.32 14.50 15.09 20.99 9.10 3.13 1/2 18 851 00 RA 10.. P S . 50.. 41.00 15.01 11.70 1.32 18.70 18.26 24.19 12.08 3.13 5/8 24 851 00 RA 12.. P S . 50.. 41.00 19.07 11.70 1.32 21.70 20.62 26.54 15.25 3.13 3/4 20 . 50.. 851 00 RA 14.. P S . 50.. 41.00 22.25 11.70 1.32 25.10 23.00 28.89 18.15 3.13 7/8 20 . 50.. 851 00 RA 16.. P S . 50.. 41.00 25.42 11.70 1.32 28.13 24.61 31.29 21.32 3.13 1-20 851 00 A 18.. P S . 50.. 851 00 RA 18.. P S . 50.. 41.00 28.60 11.70 1.32 31.38 26.97 33.69 24.32 3.13 1-3/16 18 851 00 A 20.. P S . 50.. 851 00 RA 20.. P S . 50.. 44.00 31.77 14.35 2.15 34.30 29.36 36.89 26.73 3.13 1-3/16 18 22 851 00 A 22.. P S . 50.. 851 00 RA 22.. P S . 50.. 44.00 34.95 14.35 2.15 37.60 31.75 39.99 30.67 3.13 1-7/16 18 24 851 00 A 24.. P S . 50.. 851 00 RA 24.. P S . 50.. 44.00 38.12 15.20 2.15 40.70 34.92 43.15 33.08 3.81 1-7/16 18 P S P S Square flange receptacle with straight cable clamp Cross reference HE 301 B 00 EC 00 EC HE 301 B 00 RC 00 RC F MS 3120 F VG 95328 B B Part numbers solder contacts 8 851 00 EC AC 8.. 10 851 00 EC AC 10.. P S 12 851 00 EC AC 12.. P S 14 851 00 EC AC 14.. P S 16 851 00 16.. P S 18 851 00 EC AC 18.. P S 20 851 00 20.. P S 22 851 00 EC AC 22.. P S 24 851 00 P S EC AC EC AC EC AC 24.. Note: all dimensions are in mm 20 D ØA HE 301 B 00 AC ØG MS 3110 F 00 AC Shell size E L P S ØJ C L max crimp contacts solder crimp A B max C max D max E F max J . 50.. 851 00 RC 8.. . 50 .. 48.00 47.30 12.03 11.70 1.32 13.50 15.09 20.99 3.13 . 50.. 851 00 RC 10.. P S . 50.. 48.00 47.30 15.01 11.70 1.32 16.70 18.26 24.19 3.13 . 50.. 851 00 RC 12.. P S . 50.. 48.00 47.30 19.07 11.70 1.32 19.90 20.62 26.54 3.13 . 50.. 851 00 RC 14.. P S . 50.. 48.00 47.30 22.25 11.70 1.32 23.40 23.00 28.89 3.13 . 50.. 851 00 RC 16.. P S . 50.. 51.00 50.50 25.42 11.70 1.32 26.60 24.61 31.29 3.13 . 50.. 851 00 RC 18.. P S . 50.. 51.00 50.50 28.60 11.70 1.32 29.50 26.97 33.69 3.13 . 50.. 851 00 RC 20.. P S . 50.. 53.00 51.50 31.77 14.35 2.15 32.70 29.36 36.89 3.13 . 50.. 851 00 RC 22.. P S . 50.. 53.00 51.50 34.95 14.35 2.15 36.00 31.75 39.99 3.13 851 00 RC 24.. P S . 50.. 53.00 51.50 38.12 15.20 2.15 39.10 34.92 43.15 3.81 . 50.. P S 851 Series | Connector Environmental connectors Square flange receptacle with backnut HE 301 B 00 E MS 3110 E ØA F HE 301 B 00 R 00 R D MS 3120 E VG 95328 A B Shell size Part numbers solder contacts 8 851 00 E 8.. 10 12 L max crimp contacts . 50.. P S ØJ C crimp A B max C max D max E F max J . 50.. 32.70 32.00 12.03 11.70 1.32 13.50 15.09 20.99 3.13 851 00 R 10.. P S . 50.. 32.70 32.00 15.01 11.70 1.32 16.70 18.26 24.19 3.13 851 00 R 12.. P S . 50.. 32.70 32.00 19.07 11.70 1.32 19.90 20.62 26.54 3.13 . 50.. 851 00 R 14.. P S . 50.. 32.70 32.00 22.25 11.70 1.32 23.40 23.00 28.89 3.13 . 50.. 851 00 R 16.. P S . 50.. 32.70 32.00 25.42 11.70 1.32 26.60 24.61 31.29 3.13 . 50.. 851 00 R 18.. P S . 50.. 32.70 32.00 28.60 11.70 1.32 29.50 26.97 33.69 3.13 . 50.. 851 00 R 20.. P S . 50.. 34.50 33.40 31.77 14.35 2.15 32.70 29.36 36.89 3.13 . 50.. 851 00 R 22.. P S . 50.. 34.50 33.40 34.95 14.35 2.15 36.00 31.75 39.99 3.13 . 50.. 851 00 R 24.. P S . 50.. 34.50 33.40 38.12 15.20 2.15 39.10 34.92 43.15 3.81 851 00 E 10.. P S . 50.. 851 00 E 12.. P S . 50.. 14 851 00 E 14.. P S 16 851 00 E 16.. P S 18 851 00 E 18.. P S 20 851 00 E 20.. P S 22 851 00 E 22.. P S 24 851 00 E 24.. P S 851 00 R 8.. solder P S Connector 00 E E L Cross reference Square flange receptacle with removable straight backshell for screen termination and heatshrink sleeving E L B Shell size Part numbers solder contacts 8 851 00 G 8.. 10 851 00 G 10.. 12 C L max crimp contacts solder crimp ØJ M A B max F VG 95328 R ØD 00 RG ØA 00 G ØG Cross reference C max D max E F max G max J M max .50.. 851 00 RG 8.. P S .50.. 851 00 RG 10.. P S 851 00 G 12.. P S .50.. 851 00 RG 12.. P S .50.. 54.00 19.07 11.70 1.32 22.30 20.62 26.54 13.20 3.13 3.60 14 851 00 G 14.. P S .50.. 851 00 RG 14.. P S .50.. 54.00 22.25 11.70 1.32 25.30 23.00 28.89 16.50 3.13 3.60 16 851 00 G 16.. P S .50.. 851 00 RG 16.. P S .50.. 54.00 25.42 11.70 1.32 28.30 24.61 31.29 19.35 3.13 3.60 18 851 00 G 18.. P S .50.. 851 00 RG 18.. P S .50.. 54.00 28.60 11.70 1.32 32.30 26.97 33.69 21.60 3.13 3.60 20 851 00 G 20.. P S .50.. 851 00 RG 20.. P S .50.. 59.30 31.77 14.35 2.15 34.30 29.36 36.89 24.80 3.13 3.60 22 851 00 G 22.. P S .50.. 851 00 RG 22.. P S .50.. 59.30 34.95 14.35 2.15 38.30 31.75 39.99 27.90 3.13 3.60 24 851 00 G 24.. P S .50.. 851 00 RG 24.. P S .50.. 59.30 38.12 15.20 2.15 41.30 34.92 43.15 31.00 3.81 3.60 P S P S .50 .. 54.00 12.03 11.70 1.32 16.30 15.09 20.99 7.45 3.13 3.60 .50.. 54.00 15.01 11.70 1.32 18.30 18.26 24.19 10.30 3.13 3.60 Note: all dimensions are in mm 21 851 Series | Connector Environmental connectors Square flange receptacle with straight sealing gland backshell E L B Part numbers Shell size solder contacts solder F ØJ C L max crimp contacts ØD ØA HE 301 B 00J ØG Cross reference 00 J crimp A B max C max D max E F max G max min max J 8 851 00 J 8.. 10 851 00 J 10.. 12 851 00 J 12.. P S . 50.. - 48.70 - 19.07 11.70 1.32 21.10 20.62 26.54 9.34 10.16 3.13 14 851 00 J 14.. P S . 50.. - 53.50 - 22.25 11.70 1.32 24.40 23.00 28.89 11.32 12.14 3.13 16 851 00 J 16.. P S . 50.. - 59.00 - 25.42 11.70 1.32 27.60 24.61 31.29 14.73 15.55 3.13 18 851 00 J 18.. P S . 50.. - 65.00 - 28.60 11.70 1.32 30.80 26.97 33.69 16.00 16.82 3.13 20 851 00 J 20.. P S . 50.. - 79.10 - 31.77 14.35 2.15 34.10 29.36 36.89 16.89 17.70 3.13 22 851 00 J 22.. P S . 50.. - 80.00 - 34.95 14.35 2.15 37.30 31.75 39.99 17.78 18.60 3.13 24 851 00 J 24.. P S . 50.. - 90.00 - 38.12 15.20 2.15 40.50 34.92 43.15 20.34 21.16 3.81 P S . 50.. - 47.60 - 12.03 11.70 1.32 14.40 15.09 20.99 5.02 5.84 3.13 . 50.. - 47.60 - 15.01 11.70 1.32 17.60 18.26 24.19 5.94 6.76 3.13 P S Square flange receptacle with straight sealing gland and cable clamp E L B Shell size Part numbers solder contacts 8 851 00 JC 8.. .50.. crimp contacts solder crimp - 57.68 - G max A B max C max D max E F max min max 12.03 11.70 1.32 19.90 15.09 20.99 5.02 5.84 J 3.13 10 851 00 JC 10.. .50.. - 57.68 - 15.01 11.70 1.32 21.50 18.26 24.19 5.94 6.76 3.13 12 851 00 JC 12.. PS .50.. - 61.24 - 19.07 11.70 1.32 25.00 20.62 26.54 9.34 10.16 3.13 14 851 00 JC 14.. PS .50.. - 66.01 - 22.25 11.70 1.32 27.80 23.00 28.89 11.32 12.14 3.13 16 851 00 JC 16.. PS .50.. - 74.75 - 25.42 11.70 1.32 29.40 24.61 31.29 14.73 15.55 3.13 18 851 00 JC 18.. PS .50.. - 80.57 - 28.60 11.70 1.32 35.30 26.97 33.69 16.00 16.82 3.13 P S 20 851 00 JC 20.. .50.. - 91.69 - 31.77 14.35 2.15 35.30 29.36 36.89 16.89 17.70 3.13 22 851 00 JC 22.. PS .50.. - 95.66 - 34.95 14.35 2.15 41.10 31.75 39.99 17.78 18.60 3.13 24 851 00 JC 24.. PS .50.. - 101.22 - 38.12 15.20 2.15 42.40 34.92 43.15 20.34 21.16 3.81 P S Note: all dimensions are in mm 22 P S ØJ C L max F MS 3110 J ØD ØA 00 JC ØG Cross reference 851 Series | Connector Environmental connectors Square flange receptacle with removable straight backshell for heatshrink sleeving E M Shell size Part numbers solder contacts 8 851 00 M 8.. P S L max crimp contacts . 50.. 851 00 RM 8.. ØJ C solder . 50 .. P S crimp 50.00 A B max C max D max E F max G max J M max 12.03 11.70 1.32 13.55 15.09 20.99 7.05 3.13 3.50 10 851 00 M 10.. P S . 50.. 851 00 RM 10.. P S 12 851 00 M 12.. P S . 50.. 851 00 RM 12.. P S 14 851 00 M 14.. P S . 50.. 851 00 RM 14.. P S . 50.. 50.00 22.25 11.70 1.32 21.30 23.00 28.89 15.90 3.13 3.50 16 851 00 M 16.. P S . 50.. 851 00 RM 16.. P S . 50.. 50.00 25.42 11.70 1.32 24.50 24.61 31.29 18.95 3.13 3.50 18 851 00 M 18.. P S . 50.. 851 00 RM 18.. P S . 50.. 50.00 28.60 11.70 1.32 26.45 26.97 33.69 20.90 3.13 3.50 20 851 00 M 20.. P S . 50.. 851 00 RM 20.. P S . 50.. 53.30 31.77 14.35 2.15 30.73 29.36 36.89 23.70 3.13 3.50 22 851 00 M 22.. P S . 50.. 851 00 RM 22.. P S . 50.. 53.30 34.95 14.35 2.15 34.24 31.75 39.99 26.60 3.13 3.50 24 851 00 M 24.. P S . 50.. 851 00 RM 24.. P S . 50.. 53.30 38.12 15.20 2.15 36.47 34.92 43.15 29.30 3.81 3.50 . 50.. 50.00 15.01 11.70 1.32 15.35 18.26 24.19 9.90 3.13 3.50 . 50.. 50.00 19.07 11.70 1.32 19.48 20.62 26.54 12.60 3.13 3.50 Connector B F ØD ØG ØA L Square flange receptacle with straight backshell for potting E L Cross reference 00 RP MS 3120 P B Shell size F HE 301 B 00 RP ØD MS 3110 P ØG HE 301 B 00 P ØA 00 P Part numbers solder contacts 8 851 00 P 8.. 10 851 00 P 10.. 12 L max crimp contacts solder ØJ C crimp A B max C max D max E F max G max J . 50.. 851 00 RP 8.. P S . 50.. 851 00 RP 10.. P S 851 00 P 12.. P S . 50.. 851 00 RP 12.. P S . 50.. 36.20 41.70 19.07 11.70 1.32 21.69 20.62 26.54 13.96 3.13 14 851 00 P 14.. P S . 50.. 851 00 RP 14.. P S . 50.. 36.20 41.70 22.25 11.70 1.32 23.90 23.00 28.89 17.42 3.13 16 851 00 P 16.. P S . 50.. 851 00 RP 16.. P S . 50.. 36.20 41.70 25.42 11.70 1.32 27.00 24.61 31.29 20.56 3.13 18 851 00 P 18.. P S . 50.. 851 00 RP 18.. P S . 50.. 36.91 44.46 28.60 11.70 1.32 30.50 26.97 33.69 23.66 3.13 20 851 00 P 20.. P S . 50.. 851 00 RP 20.. P S . 50.. 43.80 50.93 31.77 14.35 2.15 33.65 29.36 36.89 23.92 3.13 22 851 00 P 22.. P S . 50.. 851 00 RP 22.. P S . 50.. 43.80 50.93 34.95 14.35 2.15 37.10 31.75 39.99 25.52 3.13 24 851 00 P 24.. P S . 50.. 851 00 RP 24.. P S . 50.. 43.80 51.40 38.12 15.20 2.15 40.00 34.92 43.15 32.00 3.81 P S P S . 50 .. 36.20 41.70 12.03 11.70 1.32 15.34 15.09 20.99 10.46 3.13 . 50.. 36.20 41.70 15.01 11.70 1.32 17.70 18.26 24.19 13.55 3.13 Note: all dimensions are in mm 23 851 Series | Connector Environmental connectors Square flange receptacle with straight backshell for heatshrink sleeving E F ØD ØA ØG L M B Shell size Part numbers solder contacts 8 851 00 T 8.. 10 L max crimp contacts . 50.. ØJ C crimp C max D max G max F max E Solder Crimp M max . 50 .. 36.70 36.00 12.03 11.70 1.32 15.35 15.09 20.99 6.70 3.13 3.70 851 00 T 10.. . 50.. 851 00 RT 10.. P S . 50.. 36.70 36.00 15.01 11.70 1.32 18.15 18.26 24.19 10.20 9.40 3.13 3.70 12 851 00 T 12.. P S . 50.. 851 00 RT 12.. P S . 50.. 36.70 36.00 19.07 11.70 1.32 23.45 20.62 26.54 13.20 11.95 3.13 3.70 14 851 00 T 14.. P S . 50.. 851 00 RT 14.. P S . 50.. 36.70 36.00 22.25 11.70 1.32 24.25 23.00 28.89 16.10 15.15 3.13 3.70 16 851 00 T 16.. P S . 50.. 851 00 RT 16.. P S . 50.. 39.00 38.30 25.42 11.70 1.32 29.55 24.61 31.29 19.25 18.05 3.13 3.70 18 851 00 T 18.. P S . 50.. 851 00 RT 18.. P S . 50.. 39.00 38.30 28.60 11.70 1.32 31.75 26.97 33.69 21.30 19.95 3.13 3.70 20 851 00 T 20.. P S . 50.. 851 00 RT 20.. P S . 50.. 45.30 44.20 31.77 14.35 2.15 35.85 29.36 36.89 24.40 23.05 3.13 3.70 22 851 00 T 22.. P S . 50.. 851 00 RT 22.. P S . 50.. 45.30 44.20 34.95 14.35 2.15 38.20 31.75 39.99 27.50 25.55 3.13 3.70 24 851 00 T 24.. P S . 50.. 851 00 RT 24.. P S . 50.. 44.00 42.60 38.12 15.20 2.15 41.30 34.92 43.15 30.60 28.65 3.81 3.70 P S 7.20 J P S P S 851 00 RT 8.. solder B max A Square flange receptacle with removable backshell for screen termination and heatshrink sleeving (38 & 42 suffix) Shell size 8 851 00 T 8.. 10 851 00 T 10.. 12 38 . 50 42 P S . 50 38 42 851 00 T 12.. P S . 50 38 42 14 851 00 T 14.. P S . 50 38 42 16 851 00 T 16.. P S . 50 38 42 18 851 00 T 18.. P S . 50 38 42 20 851 00 T 20.. P S . 50 38 42 22 851 00 T 22.. P S . 50 38 42 24 851 00 T 24.. P S . 50 38 42 851 00 RT 8.. ØJ L max crimp contacts P S Note: all dimensions are in mm 24 M C Part numbers solder contacts P S F ØA B ØD E ØG L solder 38 . 50 42 38 crimp A B max C max D max E F max G max J M max 51.60 12.03 11.70 1.32 18.25 15.09 20.99 7.45 3.13 3.70 51.60 15.01 11.70 1.32 20.25 18.26 24.19 9.00 3.13 3.70 851 00 RT 10.. P S . 50 42 851 00 RT 12.. P S . 50 38 42 51.60 19.07 11.70 1.32 24.75 20.62 26.54 13.30 3.13 3.70 851 00 RT 14.. P S . 50 38 42 51.60 22.25 11.70 1.32 27.75 23.00 28.89 16.50 3.13 3.70 851 00 RT 16.. P S . 50 38 42 51.60 25.42 11.70 1.32 30.05 24.61 31.29 18.50 3.13 3.70 851 00 RT 18.. P S . 50 38 42 52.00 28.60 11.70 1.32 34.15 26.97 33.69 21.90 3.13 3.70 851 00 RT 20.. P S . 50 38 42 55.10 31.77 14.35 2.15 37.25 29.36 36.89 25.10 3.13 3.70 851 00 RT 22.. P S . 50 38 42 55.10 34.95 14.35 2.15 40.45 31.75 39.99 28.20 3.13 3.70 851 00 RT 24.. P S . 50 38 42 55.10 38.12 15.20 2.15 43.65 34.92 43.15 31.40 3.81 3.70 851 Series | Connector Environmental connectors Cable in line receptacle with straight adaptor L P Shell size Part numbers solder contacts 8 851 01 A 8.. P S L max crimp contacts . 50.. 851 01 RA 8.. solder . 50 .. P S ØD ØF C B max C max D max F max G max UNEF 2A P max 12.03 10.60 2.10 14.50 24.24 9.10 1/2 28 20.99 crimp 41.00 K A threading 10 851 01 A 10.. P S . 50.. 851 01 RA 10.. P S 12 851 01 A 12.. P S . 50.. 851 01 RA 12.. P S 14 851 01 A 14.. PS . 50.. 851 01 RA 14.. P S . 50.. 41.00 22.25 10.60 2.10 25.10 32.10 18.15 7/8 20 28.89 16 . 50.. 41.00 25.42 10.60 2.10 28.13 34.59 21.32 1-20 31.29 . 50.. 41.00 15.01 10.60 2.10 18.70 27.44 12.08 5/8 24 24.19 . 50.. 41.00 19.07 10.60 2.10 21.70 29.79 15.25 3/4 20 26.54 851 01 A 16.. P S . 50.. 851 01 RA 16.. P S 18 851 01 A 18.. P S . 50.. 851 01 RA 18.. P S . 50.. 41.00 28.60 10.60 2.10 31.38 36.94 24.32 1-3/16 18 33.69 20 851 01 A 20.. P S . 50.. 851 01 RA 20.. P S . 50.. 44.00 31.77 13.85 2.65 34.30 40.15 26.73 1-3/16 18 36.89 22 851 01 A 22.. P S . 50.. 851 01 RA 22.. P S . 50.. 44.00 34.95 13.85 2.65 37.60 42.24 30.67 1-7/16 18 40.00 24 851 01 A 24.. P S . 50.. 851 01 RA 24.. P S . 50.. 44.00 38.12 14.70 2.65 40.70 46.44 33.08 1-7/16 18 43.29 Connector B K HE 301 B 01 A HE 301 B 01 RA ØA 01 A 01 RA ØG Cross reference Cable in line receptacle with straight cable clamp L Cross reference HE 301 B 01 EC 01 EC HE 301 B 01 AC D ØA ØG MS 3111 F 01 AC HE 301 B 01 RC 01 RC Shell size P MS 3121 F B Part numbers solder contacts 8 851 01 EC AC 8.. 10 851 01 12 crimp contacts . 50.. 851 01 RC 8.. 10.. P S . 50.. 851 01 EC AC 12.. P S . 50.. 14 851 01 14.. P S 16 851 01 EC AC 16.. P S 18 EC AC EC AC P S L max solder crimp ØF C A B max C max D max F max G P max . 50 .. 48.00 47.30 12.03 10.60 2.10 19.90 24.24 3.50 20.99 851 01 RC 10.. P S . 50.. 48.00 47.30 15.01 10.60 2.10 21.50 27.44 5.00 24.19 851 01 RC 12.. P S . 50.. 48.00 47.30 19.07 10.60 2.10 25.00 29.79 8.20 26.54 . 50.. 851 01 RC 14.. P S . 50.. 48.00 47.30 22.25 10.60 2.10 27.80 32.10 10.00 28.89 . 50.. 851 01 RC 16.. P S . 50.. 51.00 50.50 25.42 10.60 2.10 29.40 34.59 13.00 31.29 P S 851 01 EC AC 18.. P S . 50.. 851 01 RC 18.. P S . 50.. 51.00 50.50 28.60 10.60 2.10 35.30 36.94 16.00 33.69 20 851 01 EC AC 20.. P S . 50.. 851 01 RC 20.. P S . 50.. 53.00 51.50 31.77 13.85 2.65 35.30 40.14 16.00 36.89 22 851 01 EC AC 22.. P S . 50.. 851 01 RC 22.. P S . 50.. 53.00 51.50 34.95 13.85 2.65 41.10 43.24 19.30 40.00 24 851 01 P S . 50.. 851 01 RC 24.. P S . 50.. 53.00 51.50 38.12 14.70 2.65 42.40 46.44 20.60 43.29 EC AC 24.. Note: all dimensions are in mm 25 851 Series | Connector Environmental connectors Cable in line receptacle with backnut L P Cross reference ØA MS 3111 E HE 301 B 01 R 01 R ØD HE 301 B 01 E 01 E MS 3121 E B Shell size Part numbers solder contacts 8 851 01 E 8.. 10 851 01 E 10.. 12 ØF C L max crimp contacts solder crimp A B max C max D max F max P max . 50.. 851 01 R 8.. P S . 50.. 851 01 R 10.. P S 851 01 E 12.. P S . 50.. 851 01 R 12.. P S . 50.. 32.70 32.00 19.07 10.60 2.10 19.90 29.79 26.54 14 851 01 E 14.. P S . 50.. 851 01 R 14.. P S . 50.. 32.70 32.00 22.25 10.60 2.10 23.40 32.10 28.89 16 851 01 E 16.. P S . 50.. 851 01 R 16.. P S . 50.. 32.70 32.00 25.42 10.60 2.10 26.60 34.59 31.29 18 851 01 E 18.. P S . 50.. 851 01 R 18.. P S . 50.. 32.70 32.00 28.60 10.60 2.10 29.50 36.94 33.69 20 851 01 E 20.. P S . 50.. 851 01 R 20.. P S . 50.. 34.50 33.40 31.77 13.85 2.65 32.70 40.14 36.89 22 851 01 E 22.. P S . 50.. 851 01 R 22.. P S . 50.. 34.50 33.40 34.95 13.85 2.65 36.00 43.24 40.00 24 851 01 E 24.. P S . 50.. 851 01 R 24.. P S . 50.. 34.50 33.40 38.12 14.70 2.65 39.10 46.44 43.29 P S P S . 50.. 32.70 32.00 12.03 10.60 2.10 13.50 24.24 20.99 . 50.. 32.70 32.00 15.01 10.60 2.10 16.70 27.44 24.19 Cable in line receptacle with removable straight backshell for screen termination and heatshrink sleeving L B Shell size 8 851 01 G 8.. 10 ØF L max crimp contacts solder crimp A B max C max D max F max G max M max P max . 50.. 851 01 RG 8.. . 50 .. 54.00 12.03 10.60 2.10 16.30 24.24 7.45 3.60 20.99 851 01 G 10.. P S . 50.. 851 01 RG 10.. PS . 50.. 54.00 15.01 10.60 2.10 18.30 27.44 10.30 3.60 24.19 12 851 01 G 12.. P S . 50.. 851 01 RG 12.. . 50.. 54.00 19.07 10.60 2.10 22.30 29.79 13.20 3.60 26.54 14 851 01 G 14.. P S . 50.. 851 01 RG 14.. PS . 50.. 54.00 22.25 10.60 2.10 25.30 32.10 16.50 3.60 28.89 16 851 01 G 16.. P S . 50.. 851 01 RG 16.. . 50.. 54.00 25.42 10.60 2.10 28.30 34.59 19.35 3.60 31.29 18 851 01 G 18.. P S . 50.. 851 01 RG 18.. PS . 50.. 54.00 28.60 10.60 2.10 32.30 36.94 21.60 3.60 33.69 20 851 01 G 20.. P S . 50.. 851 01 RG 20.. . 50.. 59.30 31.77 13.85 2.65 34.30 40.15 24.80 3.60 36.89 22 851 01 G 22.. P S . 50.. 851 01 RG 22.. PS . 50.. 59.30 34.95 13.85 2.65 38.30 42.24 27.90 3.60 40.00 24 851 01 G 24.. P S . 50.. 851 01 RG 24.. 59.30 38.12 14.70 2.65 41.30 46.44 31.00 3.60 43.29 Note: all dimensions are in mm 26 M C Part numbers solder contacts ØD ØA ØG P P S P S P S P S P S P S . 50.. 851 Series | Connector Environmental connectors Cable in line receptacle with straight sealing gland backshell L P ØA B Part numbers Shell size solder contacts 8 851 01 J 8.. 10 12 ØF C L max crimp contacts solder crimp G max A B max C max D max F max min max P max 5.84 20.99 . 50.. - 47.60 - 12.03 10.60 2.10 14.40 24.24 5.02 851 01 J 10.. P S . 50.. - 47.60 - 15.01 10.60 2.10 17.60 27.44 5.94 6.76 24.19 851 01 J 12.. P S . 50.. - 48.70 - 19.07 10.60 2.10 21.10 29.79 9.34 10.16 26.54 14 851 01 J 14.. P S . 50.. - 53.50 - 22.25 10.60 2.10 24.40 32.10 11.32 12.14 28.89 16 851 01 J 16.. P S . 50.. - 59.00 - 25.42 10.60 2.10 27.60 34.59 14.73 15.55 31.29 18 851 01 J 18.. P S . 50.. - 65.00 - 28.60 10.60 2.10 30.80 36.94 16.00 16.82 33.69 20 851 01 J 20.. P S . 50.. - 79.10 - 31.77 13.85 2.65 34.10 40.15 16.89 17.71 36.89 22 851 01 J 22.. P S . 50.. - 80.00 - 34.95 13.85 2.65 37.30 42.24 17.78 18.60 40.00 24 851 01 J 24.. P S . 50.. - 90.00 - 38.12 14.70 2.65 40.50 46.44 20.34 21.16 43.29 P S Connector HE 301 B 01 J ØD 01 J ØG Cross reference Cable in line receptacle with straight sealing gland and cable clamp backshell L P HE 301 B 01 J B Shell size Part numbers solder contacts ØD ØA 01 JC ØG Cross reference ØF C L max crimp contacts solder crimp G A B max C max D max F max min max P max 8 851 01 JC 8.. .50.. - 57.68 - 12.03 10.60 2.10 19.90 24.24 5.02 5.84 20.99 10 851 01 JC 10.. PS .50.. - 57.68 - 15.01 10.60 2.10 21.50 27.44 5.94 6.76 24.19 12 14 P S 851 01 JC 12.. P S .50.. - 61.24 - 19.07 10.60 2.10 25.00 29.79 9.34 10.16 26.54 851 01 JC 14.. P S .50.. - 66.01 - 22.25 10.60 2.10 27.80 32.10 11.32 12.14 28.89 16 851 01 JC 16.. .50.. - 74.75 - 25.42 10.60 2.10 29.40 34.59 14.73 15.50 31.29 18 851 01 JC 18.. PS .50.. - 80.57 - 28.60 10.60 2.10 35.30 36.94 16.00 16.82 33.69 20 851 01 JC 20.. .50.. - 91.69 - 31.77 13.85 2.65 35.30 40.15 16.89 17.71 36.89 22 851 01 JC 22.. PS .50.. - 95.66 - 34.95 13.85 2.65 41.10 42.24 17.78 18.60 40.00 24 851 01 JC 24.. .50.. - 101.22 - 38.12 14.70 2.65 42.40 46.44 20.34 21.16 43.29 P S P S P S Note: all dimensions are in mm 27 851 Series | Connector Environmental connectors Cable connecting receptacle with removable straight backshell for heatshrink sleeving P ØA ØG ØD L M B Shell size ØF C Part numbers solder contacts 8 851 01 M 8.. 10 12 L max crimp contacts .50.. 851 01 RM 8.. 851 01 M 10.. P S .50.. 851 01 M 12.. P S .50.. 14 851 01 M 14.. P S 16 851 01 M 16.. P S 18 20 solder crimp A B max C max D max F max G max P max M max 7.05 20.99 3.50 .50 .. 50.00 12.03 10.60 2.10 13.55 24.24 851 01 RM 10.. P S .50.. 50.00 15.01 10.60 2.10 15.35 27.44 9.90 24.19 3.50 851 01 RM 12.. P S .50.. 50.00 19.07 10.60 2.10 19.48 29.79 12.60 26.54 3.50 .50.. 851 01 RM 14.. P S .50.. 50.00 22.25 10.60 2.10 21.30 32.10 15.90 28.89 3.50 .50.. 851 01 RM 16.. P S .50.. 50.00 25.42 10.60 2.10 24.50 34.59 18.95 31.29 3.50 851 01 M 18.. P S .50.. 851 01 RM 18.. P S .50.. 50.00 28.60 10.60 2.10 26.45 36.94 20.90 33.69 3.50 851 01 M 20.. P S .50.. 851 01 RM 20.. P S .50.. 53.30 31.77 13.85 2.65 30.75 40.15 23.70 36.89 3.50 22 851 01 M 22.. P S .50.. 851 01 RM 22.. P S .50.. 53.30 34.95 13.85 2.65 34.24 42.24 26.60 40.00 3.50 24 851 01 M 24.. P S .50.. 851 01 RM 24.. P S .50.. 53.30 38.12 14.70 2.65 36.47 46.44 29.30 43.29 3.50 P S P S Cable connecting receptacle with straight backshell for potting P L Cross reference MS 3121 P B Part numbers solder contacts 8 851 01 P 8.. 10 851 01 P 10.. 12 14 L max crimp contacts ØF C solder crimp A B max C max D max F max G max P max . 50.. 851 01 RP 8.. . 50 .. 36.20 41.70 12.03 10.60 2.10 15.34 24.24 10.46 20.99 P S . 50.. 851 01 RP 10.. P S . 50.. 36.20 41.70 15.01 10.60 2.10 17.70 27.44 13.55 24.19 851 01 P 12.. P S . 50.. 851 01 RP 12.. P S . 50.. 36.20 41.70 19.07 10.60 2.10 21.69 29.79 13.96 26.54 851 01 P 14.. P S . 50.. 851 01 RP 14.. P S . 50.. 36.20 41.70 22.25 10.60 2.10 23.90 32.10 17.42 28.89 16 851 01 P 16.. P S . 50.. 851 01 RP 16.. P S . 50.. 36.20 41.70 25.42 10.60 2.10 27.00 34.59 20.56 31.29 18 851 01 P 18.. P S . 50.. 851 01 RP 18.. P S . 50.. 36.91 44.46 28.60 10.60 2.10 30.50 36.94 23.66 33.69 20 851 01 P 20.. P S . 50.. 851 01 RP 20.. P S . 50.. 43.80 50.93 31.77 13.85 2.65 33.65 40.15 23.92 36.89 22 851 01 P 22.. P S . 50.. 851 01 RP 22.. P S . 50.. 43.80 50.93 34.95 13.85 2.65 37.10 42.24 25.52 40.00 24 851 01 P 24.. P S . 50.. 851 01 RP 24.. P S . 50.. 43.80 50.93 38.12 14.70 2.65 40.00 46.44 32.00 43.29 Note: all dimensions are in mm 28 ØD HE 301 B 01 RP 01 RP Shell size ØA MS 3111 P ØG HE 301 B 01 P 01 P P S P S 851 Series | Connector Environmental connectors Cable in line receptacle with straight backshell for heatshrink sleeving L ØD ØA ØG P M Shell size ØF C Part numbers solder contacts 8 851 01 T 8.. crimp contacts .50.. P S L max 851 01 RT 8.. .50.. P S solder crimp 36.70 36.00 G max A B max C max D max F max solder crimp P max M max 12.03 10.60 2.10 15.35 24.24 7.20 6.70 20.99 3.70 24.19 3.70 10 851 01 T 10.. .50.. 851 01 RT 10.. .50.. 36.70 36.00 15.01 10.60 2.10 18.15 27.44 10.20 9.40 12 851 01 T 12.. PS .50.. 851 01 RT 12.. PS .50.. 36.70 36.00 19.07 10.60 2.10 23.45 29.70 13.20 11.95 26.54 3.70 14 851 01 T 14.. PS .50.. 851 01 RT 14.. PS .50.. 36.70 36.00 22.25 10.60 2.10 24.25 32.10 16.10 15.15 28.89 3.70 16 851 01 T 16.. PS .50.. 851 01 RT 16.. PS .50.. 39.00 38.30 25.42 10.60 2.10 29.55 34.59 19.25 18.05 31.29 3.70 18 851 01 T 18.. PS .50.. 851 01 RT 18.. PS .50.. 39.00 38.30 28.60 10.60 2.10 31.75 36.94 21.30 19.95 33.69 3.70 20 851 01 T 20.. PS .50.. 851 01 RT 20.. PS .50.. 45.30 44.20 31.77 13.85 2.65 35.85 40.15 24.40 23.05 36.89 3.70 22 851 01 T 22.. PS .50.. 851 01 RT 22.. PS .50.. 45.30 44.20 34.95 13.85 2.65 38.20 42.24 27.50 25.55 40.00 3.70 24 851 01 T 24.. PS .50.. 851 01 RT 24.. PS .50.. 44.00 42.60 38.12 14.70 2.65 41.30 46.44 30.60 28.65 43.29 3.70 P S P S Connector B Cable connecting receptacle with removable straight backshell for screen termination and heatshrink sleeving (38 & 42 suffix) L ØD ØA ØG P M B Shell size Part numbers solder contacts 8 851 01 T 8.. PS .50 10 851 01 T 10.. P S P S L max crimp contacts 38 42 ØF C 38 42 crimp A B max C max D max F max G max M max P max 51.60 12.03 10.60 2.10 18.25 24.24 7.45 3.70 20.99 .50 38 42 51.60 15.01 10.60 2.10 20.25 27.44 9.00 3.70 24.19 851 01 RT 12.. P S .50 38 42 51.60 19.07 10.60 2.10 24.75 29.79 13.30 3.70 26.54 851 01 RT 14.. P S .50 38 42 51.60 22.25 10.60 2.10 27.75 32.10 16.50 3.70 28.89 16 851 01 T 16.. 38 42 851 01 RT 16.. P S .50 38 42 51.60 25.42 10.60 2.10 30.05 34.59 18.50 3.70 31.29 18 851 01 T 18.. PS .50 38 42 851 01 RT 18.. P S .50 38 42 52.00 28.60 10.60 2.10 34.15 36.94 21.90 3.70 33.69 20 851 01 T 20.. 38 42 851 01 RT 20.. P S .50 38 42 55.10 31.77 13.85 2.65 37.25 40.15 25.10 3.70 36.89 22 851 01 T 22.. PS .50 38 42 851 01 RT 22.. P S .50 38 42 55.10 34.95 13.85 2.65 40.45 42.24 28.20 3.70 40.00 24 851 01 T 24.. 851 01 RT 24.. P S .50 38 42 55.10 38.12 14.70 2.65 43.65 46.44 31.40 3.70 43.29 .50 38 42 .50 851 01 RT 8.. PS .50 solder 851 01 RT 10.. P S 12 851 01 T 12.. 38 42 14 851 01 T 14.. PS .50 38 42 P S P S P S .50 .50 .50 38 42 Note: all dimensions are in mm 29 851 Series | Connector Environmental connectors Square flange receptacle not accepting backshell L Cross reference E HE 301 B 02 E 02 E F ØA VG 95328 H ØD MS 3112 E HE 301 B 02 R 02 R MS 3122 E B VG 95328 C Shell size Part numbers solder contacts 8 851 02 E 8.. 10 ØJ C L max crimp contacts solder crimp A B max C max D max E F max J . 50.. 851 02 R 8.. . 50 .. 25.18 32.35 12.03 11.70 1.32 10.84 15.09 20.99 3.13 851 02 E 10.. P S . 50.. 851 02 R 10.. P S . 50.. 25.10 32.35 15.01 11.70 1.32 13.99 18.26 24.19 3.13 12 851 02 E 12.. P S . 50.. 851 02 R 12.. P S . 50.. 25.10 32.35 19.07 11.70 1.32 17.37 20.62 26.54 3.13 14 851 02 E 14.. P S . 50.. 851 02 R 14.. P S . 50.. 25.10 32.35 22.25 11.70 1.32 20.57 23.00 28.89 3.13 16 851 02 E 16.. P S . 50.. 851 02 R 16.. P S . 50.. 25.10 32.35 25.42 11.70 1.32 23.72 24.61 31.29 3.13 18 851 02 E 18.. P S . 50.. 851 02 R 18.. P S . 50.. 25.10 32.35 28.60 11.70 1.32 26.69 26.97 33.69 3.13 20 851 02 E 20.. P S . 50.. 851 02 R 20.. P S . 50.. 26.67 33.95 31.77 14.35 2.15 29.89 29.36 36.89 3.13 22 851 02 E 22.. P S . 50.. 851 02 R 22.. P S . 50.. 26.67 33.95 34.95 14.35 2.15 33.04 31.75 39.99 3.13 24 851 02 E 24.. P S . 50.. 851 02 R 24.. P S . 50.. 26.67 33.95 38.12 15.20 2.15 36.24 34.92 43.15 3.81 P S P S Jam nut receptacle not accepting backshell L P HE 301 B 07 A S 07 A ØA Cross reference B Shell size Part numbers solder contacts 8 851 07 A 8.. . 50.. L max crimp contacts solder crimp - 25.18 - A B max C max F max P max S max 12.03 17.90 2.64 26.94 19.29 23.94 10 851 07 A 10.. P S 12 851 07 A 12.. P S 14 851 07 A 14.. P S . 50.. - 25.10 - 22.25 17.90 2.64 38.04 30.33 34.94 16 851 07 A 16.. P S . 50.. - 25.10 - 25.42 17.90 2.64 41.24 33.48 38.24 18 851 07 A 18.. P S . 50.. - 25.10 - 28.60 17.90 2.64 44.44 36.68 41.34 . 50.. - 25.10 - 15.01 17.90 2.64 30.14 22.38 26.94 . 50.. - 25.10 - 19.07 17.90 2.64 34.94 27.13 31.74 20 851 07 A 20.. P S . 50.. - 26.67 - 31.77 22.45 3.44 49.14 39.83 46.04 22 851 07 A 22.. P S . 50.. - 26.67 - 34.95 22.45 3.44 52.24 43.03 49.24 24 851 07 A 24.. P S . 50.. - 26.67 - 38.12 23.30 3.44 55.54 46.18 52.74 Note: all dimensions are in mm 30 P S ØF C 851 Series | Connector Environmental connectors Jam nut receptacle with straight cable clamp Cross reference L P HE 301 B 07 EC 07 EC S ØD ØA HE 301 B 07 AC ØG MS 3114 F 07 AC HE 301 B 07 RC MS 3124 F VG 95328 E Shell size B Part numbers solder contacts 8 851 07 EC AC 8.. 10 851 07 12 L max crimp contacts . 50.. 851 07 RC 8.. 10.. P S . 50.. 851 07 EC AC 12.. P S . 50.. EC AC P S solder crimp ØF C A B max C max D max F max G P max S max . 50 .. 49.31 49.10 12.03 17.90 2.64 19.90 26.94 3.50 19.29 23.94 851 07 RC 10.. P S . 50.. 49.31 49.10 15.01 17.90 2.64 21.50 30.14 5.00 22.38 26.94 851 07 RC 12.. P S . 50.. 49.17 49.10 19.07 17.90 2.64 25.00 34.94 8.20 27.13 31.74 P S 14 851 07 14.. P S . 50.. 851 07 RC 14.. P S . 50.. 49.17 49.10 22.25 17.90 2.64 27.80 38.04 10.00 30.33 34.94 16 851 07 EC AC 16.. P S . 50.. 851 07 RC 16.. P S . 50.. 52.34 52.20 25.42 17.90 2.64 29.40 41.24 13.00 33.48 38.24 EC AC 18 851 07 18.. P S . 50.. 851 07 RC 18.. P S . 50.. 53.22 53.10 28.60 17.90 2.64 35.30 44.44 16.00 36.68 41.34 20 851 07 EC AC 20.. P S . 50.. 851 07 RC 20.. P S . 50.. 58.10 58.00 31.77 22.45 3.44 35.30 49.14 16.00 39.83 46.04 . 50.. 851 07 RC 22.. P S . 50.. 58.10 58.00 34.95 22.45 3.44 41.10 52.24 19.30 43.03 49.24 . 50.. 851 07 RC 24.. P S . 50.. 58.10 58.00 38.12 23.30 3.44 42.40 55.54 20.60 46.18 52.74 EC AC EC AC 22 851 07 22.. P S 24 851 07 EC AC 24.. P S Connector 07 RC Jam nut receptacle with backnut L Cross reference HE 301 B 07 R 07 R MS 3124 E VG 95328 D Shell size S MS 3114 E ØD HE 301 B 07 E ØA 07 E P B Part numbers solder contacts L max crimp contacts solder crimp . 50 .. ØF C A B max C max D max F max P max S max 8 851 07 E 8.. 34.10 33.50 12.03 17.90 2.64 18.50 26.94 19.29 23.94 10 851 07 E 10.. P S . 50.. 851 07 R 10.. P S . 50.. 34.10 33.50 15.01 17.90 2.64 21.70 30.14 22.38 26.94 12 851 07 E 12.. P S . 50.. 851 07 R 12.. P S . 50.. 34.10 33.50 19.07 17.90 2.64 24.90 34.94 27.13 31.74 14 851 07 E 14.. P S . 50.. 851 07 R 14.. P S . 50.. 34.10 33.50 22.25 17.90 2.64 28.10 38.04 30.33 34.94 16 851 07 E 16.. P S . 50.. 851 07 R 16.. P S . 50.. 34.10 33.50 25.42 17.90 2.64 31.20 41.24 33.48 38.24 18 851 07 E 18.. P S . 50.. 851 07 R 18.. P S . 50.. 34.10 33.50 28.60 17.90 2.64 34.40 44.44 36.68 41.34 20 851 07 E 20.. P S . 50.. 851 07 R 20.. P S . 50.. 39.30 37.90 31.77 22.45 3.44 38.30 49.14 39.83 46.04 22 851 07 E 22.. P S . 50.. 851 07 R 22.. P S . 50.. 39.30 37.90 34.95 22.45 3.44 41.50 52.24 43.03 49.24 24 851 07 E 24.. P S . 50.. 851 07 R 24.. P S . 50.. 39.30 37.90 38.12 22.30 3.44 44.70 55.54 46.18 52.74 P S . 50.. 851 07 R 8.. P S Note: all dimensions are in mm 31 851 Series | Connector Environmental connectors Jam nut receptacle with removable straight backshell for screen termination and heatshrink sleeving L P B Shell size Part numbers solder contacts 8 851 07 G 8.. 10 C L max crimp contacts solder crimp S VG 95328 T ØD ØA 07 G 07 RG ØG Cross reference M ØF A B max C max D max F max G max M max P max S max . 50 851 07 RG 8.. . 50 62.20 12.03 17.90 2.64 16.30 26.94 7.45 3.60 19.29 23.94 851 07 G 10.. P S . 50 851 07 RG 10.. P S . 50 62.20 15.01 17.90 2.64 18.30 30.14 10.30 3.60 22.38 26.94 12 851 07 G 12.. P S . 50 851 07 RG 12.. P S . 50 62.20 19.07 17.90 2.64 22.30 34.94 13.20 3.60 27.13 31.74 14 851 07 G 14.. P S . 50 851 07 RG 14.. P S . 50 62.40 22.25 17.90 2.64 25.30 38.04 16.50 3.60 30.33 34.94 16 851 07 G 16.. P S . 50 851 07 RG 16.. P S . 50 62.40 25.42 17.90 2.64 28.30 41.24 19.35 3.60 33.48 38.24 18 851 07 G 18.. P S . 50 851 07 RG 18.. P S . 50 62.40 28.60 17.90 2.64 32.30 44.44 21.60 3.60 36.68 41.34 20 851 07 G 20.. P S . 50 851 07 RG 20.. P S . 50 67.50 31.77 22.45 3.44 34.30 49.14 24.80 3.60 39.83 46.04 22 851 07 G 22.. P S . 50 851 07 RG 22.. P S . 50 67.50 34.95 22.45 3.44 38.30 52.24 27.90 3.60 43.03 49.24 24 851 07 G 24.. P S . 50 851 07 RG 24.. P S . 50 67.50 38.12 23.30 3.44 41.30 55.54 31.00 3.60 46.18 52.74 P S P S Jam nut receptacle with straight backshell for potting L P Cross reference HE 301 B 07 RP 07 RP MS 3124 P B Shell size Part numbers solder contacts 8 851 07 P 8.. 10 851 07 P 10.. 12 L max crimp contacts solder crimp ØF C A B max C max D max F max G max P max S max . 50.. 851 07 RP 8.. P S . 50.. 851 07 RP 10.. P S 851 07 P 12.. P S . 50.. 851 07 RP 12.. P S . 50.. 34.30 39.80 19.07 17.90 2.64 21.69 34.94 13.96 27.13 31.74 14 851 07 P 14.. P S . 50.. 851 07 RP 14.. P S . 50.. 34.30 39.80 22.25 17.90 2.64 23.90 38.04 17.42 30.33 34.94 16 851 07 P 16.. P S . 50.. 851 07 RP 16.. P S . 50.. 34.30 39.80 25.42 17.90 2.64 27.00 41.24 20.56 33.48 38.24 18 851 07 P 18.. P S . 50.. 851 07 RP 18.. P S . 50.. 34.10 41.80 28.60 17.90 2.64 30.50 44.44 23.66 36.68 41.34 20 851 07 P 20.. P S . 50.. 851 07 RP 20.. P S . 50.. 42.25 49.92 31.77 22.45 3.44 33.65 49.14 23.92 39.83 46.04 22 851 07 P 22.. P S . 50.. 851 07 RP 22.. P S . 50.. 42.25 49.92 34.95 22.45 3.44 37.10 52.24 25.52 43.03 49.24 24 851 07 P 24.. P S . 50.. 851 07 RP 24.. P S . 50.. 43.26 51.30 38.12 23.30 3.44 40.00 55.54 32.00 46.18 52.74 Note: all dimensions are in mm 32 S MS 3114 P ØD ØA ØG HE 301 B 07 P 07 P P S P S . 50 .. 34.30 39.80 12.03 17.90 2.64 15.34 26.94 10.46 19.29 23.94 . 50.. 34.30 39.80 15.01 17.90 2.64 17.70 30.14 13.55 22.38 26.94 851 Series | Connector Environmental connectors Jam nut receptacle with straight backshell for heatshrink sleeving P L 07 RT VG 95328 S M Part numbers solder contacts 8 851 07 T 8.. P S L max crimp contacts . 50.. 851 07 RT 8.. . 50 .. P S solder crimp 42.60 41.50 ØF C B max A C max D max G max F max Solder Crimp 12.03 17.90 2.64 15.35 26.94 7.20 M max P max S max 6.70 3.70 19.29 23.94 41.50 15.01 17.90 2.64 18.15 30.14 10.20 9.40 3.70 22.38 26.94 41.50 19.07 17.90 2.64 23.45 34.94 13.20 11.95 3.70 27.13 31.74 10 851 07 T 10.. P S . 50.. 851 07 RT 10.. P S 12 851 07 T 12.. P S . 50.. 851 07 RT 12.. P S 14 851 07 T 14.. P S . 50.. 851 07 RT 14.. P S . 50.. 42.60 41.50 22.25 17.90 2.64 24.25 38.04 16.10 15.15 3.70 30.33 34.94 16 851 07 T 16.. P S . 50.. 851 07 RT 16.. P S . 50.. 44.40 43.80 25.42 17.90 2.64 29.55 41.24 19.25 18.05 3.70 33.48 38.24 18 851 07 T 18.. P S . 50.. 851 07 RT 18.. P S . 50.. 44.40 43.80 28.60 17.90 2.64 31.75 44.44 21.30 19.95 3.70 36.68 41.24 20 851 07 T 20.. P S . 50.. 851 07 RT 20.. P S . 50.. 50.90 49.80 31.77 22.45 3.44 35.85 49.14 24.40 23.05 3.70 39.83 46.04 22 851 07 T 22.. P S . 50.. 851 07 RT 22.. P S . 50.. 50.90 49.80 34.95 22.45 3.44 38.20 52.24 27.50 25.55 3.70 43.03 49.24 24 851 07 T 24.. P S . 50.. 851 07 RT 24.. P S . 50.. 49.90 48.50 38.12 23.30 3.44 41.30 55.54 30.60 28.65 3.70 46.18 52.74 . 50.. 42.60 . 50.. 42.60 Connector B Shell size S ØD ØA 07 T ØG Cross reference Jam nut receptacle with removable straight backshell for screen termination and heatshrink sleeving (38 & 42 suffix) P M B Shell size 851 07 T 8.. 10 851 07 T 10.. P S 12 14 . 50 42 P S L max crimp contacts 38 8 851 07 RT 8.. ØF C Part numbers solder contacts solder 38 crimp A B max C max D max F max G max M max P max S max 60.00 12.03 17.90 2.64 18.25 26.94 7.45 3.70 19.29 23.94 851 07 RT 10.. P S . 50 42 38 60.00 15.01 17.90 2.64 20.25 30.14 9.00 3.70 22.38 26.94 . 50 38 42 P S . 50 42 S ØD ØA ØG L . 50 38 42 851 07 T 12.. P S . 50 38 42 851 07 RT 12.. P S 60.00 19.07 17.90 2.64 24.75 34.94 13.30 3.70 27.13 31.74 851 07 T 14.. P S . 50 38 42 851 07 RT 14.. P S . 50 38 42 60.00 22.25 17.90 2.64 27.75 38.04 16.50 3.70 30.33 34.94 16 851 07 T 16.. P S . 50 38 42 851 07 RT 16.. P S . 50 38 42 60.00 25.42 17.90 2.64 30.05 41.24 18.50 3.70 33.48 38.24 18 851 07 T 18.. P S . 50 38 42 851 07 RT 18.. P S . 50 38 42 60.40 28.60 17.90 2.64 34.15 44.44 21.90 3.70 36.68 41.34 20 851 07 T 20.. P S . 50 38 42 851 07 RT 20.. P S . 50 38 42 63.40 31.77 22.45 3.44 37.25 49.14 25.10 3.70 39.83 46.04 22 851 07 T 22.. P S . 50 38 42 851 07 RT 22.. P S . 50 38 42 63.40 34.95 22.45 3.44 40.45 52.24 28.20 3.70 43.03 49.24 24 851 07 T 24.. P S . 50 851 07 RT 24.. P S . 50 63.40 38.12 23.30 3.44 43.65 55.54 31.40 3.70 46.18 52.74 38 42 38 42 Note: all dimensions are in mm 33 851 Series | Connector Environmental connectors Plug with straight adaptor L ØA Shell size Part numbers solder contacts 8 851 06 A 8 .. P S L max crimp contacts . 50.. 851 06 RA 8 .. . 50 .. P S solder crimp A max 41.00 41.00 19.05 D HE 301 B 06 A HE 301 B 06 RA ØK 06 A 06 RA ØG Cross reference D max G max F threading UNEF 2A 14.50 9.10 1/2 28 10 851 06 A 10 .. P S . 50.. 851 06 RA 10 .. P S 12 851 06 A 12 .. P S . 50.. 851 06 RA 12 .. P S 14 851 06 A 14 .. P S . 50.. 851 06 RA 14 .. P S . 50.. 41.00 41.00 29.35 25.10 18.15 7/8 20 16 851 06 A 16 .. P S . 50.. 851 06 RA 16 .. P S . 50.. 41.00 41.00 32.50 28.13 21.32 1-20 18 851 06 A 18 .. P S . 50.. 851 06 RA 18 .. P S . 50.. 41.00 41.00 35.30 31.38 24.32 1-3/16 18 20 851 06 A 20 .. P S . 50.. 851 06 RA 20 .. P S . 50.. 44.00 43.30 38.85 34.30 26.73 1-3/16 18 22 851 06 A 22 .. P S . 50.. 851 06 RA 22 .. P S . 50.. 44.00 43.30 42.05 37.60 30.67 1-7/16 18 24 851 06 A 24 .. P S . 50.. 851 06 RA 24 .. P S . 50.. 44.00 43.50 45.10 40.70 33.08 1-7/16 18 . 50.. 41.00 41.00 21.80 18.70 12.08 5/8 24 . 50.. 41.00 41.00 26.15 21.70 15.25 3/4 20 Plug with straight cable clamp Cross reference L HE 301 B 06 EC 06 EC ØA MS 3116 F 06 AC HE 301 B 06 AC 06 RC D ØG HE 301 B 06 RC MS 3126 F VG 95328 K Shell size Part numbers solder contacts 8 851 06 EC AC 8 .. 10 851 06 12 solder crimp A max D max G . 50.. 851 06 RC 8 .. P S . 50.. 851 06 RC 10 .. 851 06 EC AC 12 .. P S . 50.. 851 06 RC 12 .. P S . 50.. 48.00 47.30 26.15 25.00 8.20 14 851 06 14 .. P S . 50.. 851 06 RC 14 .. P S . 50.. 48.00 47.30 29.35 27.80 10.00 16 851 06 EC AC 16 .. P S . 50.. 851 06 RC 16 .. P S . 50.. 51.00 50.50 32.50 29.40 13.00 18 851 06 18 .. P S . 50.. 851 06 RC 18 .. P S . 50.. 51.00 50.50 35.30 35.30 16.00 20 851 06 EC AC 20 .. P S . 50.. 851 06 RC 20 .. P S . 50.. 52.00 50.20 38.85 35.30 16.00 22 851 06 22 .. P S . 50.. 851 06 RC 22 .. P S . 50.. 52.00 50.20 42.05 41.10 19.30 24 851 06 EC AC 24 .. P S . 50.. 851 06 RC 24 .. P S . 50.. 52.00 50.20 45.10 42.40 20.60 EC AC EC AC EC AC EC AC Note: all dimensions are in mm 34 L max crimp contacts 10 .. P S P S P S . 50 .. 48.00 47.30 19.05 19.90 3.50 . 50.. 48.00 47.30 21.80 21.50 5.00 851 Series | Connector Environmental connectors Plug with backnut L Cross reference Shell size MS 3116 E HE 301 B 06 R MS 3126 E Part numbers solder contacts 8 851 06 E 8 .. P S L max crimp contacts . 50.. 851 06 R 8 .. . 50 .. P S solder crimp A max D max 32.54 32.00 19.05 13.50 10 851 06 E 10 .. P S . 50.. 851 06 R 10 .. P S 12 851 06 E 12 .. P S . 50.. 851 06 R 12 .. P S 14 851 06 E 14 .. P S . 50.. 851 06 R 14 .. P S . 50.. 32.54 32.00 29.35 23.40 16 851 06 E 16 .. P S . 50.. 851 06 R 16 .. P S . 50.. 32.54 32.00 32.50 26.60 18 851 06 E 18 .. P S . 50.. 851 06 R 18 .. P S . 50.. 32.54 32.00 35.30 29.60 20 851 06 E 20 .. P S . 50.. 851 06 R 20 .. P S . 50.. 33.30 32.10 38.85 32.70 22 851 06 E 22 .. P S . 50.. 851 06 R 22 .. P S . 50.. 33.30 32.10 42.05 36.00 24 851 06 E 24 .. P S . 50.. 851 06 R 24 .. P S . 50.. 33.30 32.10 45.10 39.10 . 50.. 32.54 32.00 21.80 16.70 . 50.. 32.54 32.00 26.15 19.90 Connector 06 R HE 301 B 06 E D 06 E ØA Plug with straight sealing gland backshell L ØA Shell size ØG HE 301 B 06 J Part numbers solder contacts L max crimp contacts ØD Cross reference 06 J G max solder crimp A max D max min max 8 851 06 J 8 .. . 50.. - 47.60 - 19.05 14.40 5.02 5.84 10 851 06 J 10 .. P S . 50.. - 47.60 - 21.80 17.60 5.94 6.76 12 851 06 J 12 .. P S . 50.. - 49.20 - 26.15 21.10 9.34 10.16 14 851 06 J 14 .. PS . 50.. - 54.00 - 29.35 24.40 11.32 12.14 16 18 P S 851 06 J 16 .. P S . 50.. - 59.60 - 32.50 27.60 14.73 15.55 851 06 J 18 .. P S . 50.. - 65.60 - 35.30 30.80 16.00 16.80 20 851 06 J 20 .. P S . 50.. - 78.00 - 38.85 34.10 16.89 17.71 22 851 06 J 22 .. P S . 50.. - 79.50 - 42.05 37.30 17.78 18.60 24 851 06 J 24 .. P S . 50.. - 90.00 - 45.10 40.50 20.34 21.16 Note: all dimensions are in mm 35 851 Series | Connector Environmental connectors Plug with straight sealing gland and cable clamp backshells L ØA 06 JC Shell size ØG MS 3116 J Part numbers L max ØD Cross reference crimp contacts solder crimp min max 8 851 06 JC 8 .. . 50.. - 57.68 - 19.05 19.90 5.02 5.84 10 851 06 JC 10 .. PS . 50.. - 57.68 - 21.80 21.50 5.94 6.76 12 851 06 JC 12 .. PS . 50.. - 61.24 - 26.15 25.00 9.34 10.16 14 851 06 JC 14 .. PS . 50.. - 66.01 - 29.35 27.80 11.32 12.14 16 851 06 JC 16 .. PS . 50.. - 74.75 - 32.50 29.40 14.73 15.50 18 851 06 JC 18 .. . 50.. - 80.57 - 35.30 35.30 16.00 16.82 20 851 06 JC 20 .. PS . 50.. - 91.69 - 38.85 35.30 16.89 17.71 22 851 06 JC 22 .. . 50.. - 95.66 - 42.05 41.10 17.78 18.60 24 851 06 JC 24 .. PS . 50.. - 101.22 - 45.10 42.40 20.34 21.16 solder contacts P S P S P S D max G max A max Plug with long metallic adaptor and plastic cable gland E D ØG ØC Shell size Part numbers solder contacts * E maxi ØC maxi mini maxi 8 851 06L 8 57.00 81.00 19.30 4.00 5.00 10 851 06L 10 P S * 57.00 84.00 22.00 4.00 6.00 12 851 06L 12 P S * 57.00 86.00 26.30 4.00 7.00 14 851 06L 14 P S * 57.00 87.00 29.50 4.00 9.00 16 851 06L 16 P S * 57.00 90.00 32.70 6.00 12.00 P S Black anodized* See page 12 "obligatory specification". Example: 85106L123P54 Note: all dimensions are in mm 36 ØG D maxi 851 Series | Connector Environmental connectors Plug with removable straight backshell for heatshrink sleeving ØA ØD ØG L Shell size Part numbers solder contacts 8 851 06 M 8 .. P S L max crimp contacts . 50.. 851 06 RM 8 .. . 50 .. P S solder crimp 50.00 A max D max G max M max 19.05 13.55 7.05 3.50 10 851 06 M 10 .. P S . 50.. 851 06 RM 10 .. P S 12 851 06 M 12 .. P S . 50.. 851 06 RM 12 .. P S 14 851 06 M 14 .. P S . 50.. 851 06 RM 14 .. P S . 50.. 50.00 29.35 21.30 15.90 3.50 16 851 06 M 16 .. P S . 50.. 851 06 RM 16 .. P S . 50.. 50.00 32.50 24.50 18.95 3.50 18 851 06 M 18 .. P S . 50.. 851 06 RM 18 .. P S . 50.. 50.00 35.30 26.45 20.90 3.50 20 851 06 M 20 .. P S . 50.. 851 06 RM 20 .. P S . 50.. 52.00 38.85 30.73 23.70 3.50 22 851 06 M 22 .. P S . 50.. 851 06 RM 22 .. P S . 50.. 52.00 42.05 34.24 26.60 3.50 24 851 06 M 24 .. P S . 50.. 851 06 RM 24 .. P S . 50.. 52.00 45.10 36.47 29.30 3.50 . 50.. 50.00 21.80 15.35 9.90 3.50 . 50.. 50.00 26.15 19.48 12.60 3.50 Connector M Plug with short metallic adaptor and plastic cable gland with spiral protector B ØC ØG A Shell size Part numbers solder contacts 8 851 06NS 8 10 12 P S A maxi * B maxi ØC maxi ØG mini maxi 37.00 91.00 19.30 4.00 6.50 * 37.00 101.00 22.00 4.00 7.00 * 37.00 114.00 26.30 4.00 7.00 851 06NS 10 P S 851 06NS 12 P S 14 851 06NS 14 P S * 37.00 125.00 29.50 4.00 7.00 16 851 06NS 16 P S * 42.00 144.00 32.70 6.00 11.0 Black anodized* See page 12 "obligatory specification". Example: 85106NS123P54 Note: all dimensions are in mm 37 851 Series | Connector Environmental connectors Plug with long metallic adaptor and plastic cable gland with spiral protector B ØC ØG A Shell size Part numbers solder contacts D maxi * E maxi ØC maxi ØG mini maxi 8 851 06NL 8 10 851 06NL 10 P S 12 851 06NL 12 P S * 57.00 134.00 26.30 4.00 7.00 14 851 06NL 14 P S * 57.00 145.00 29.50 4.00 7.00 16 851 06NL 16 P S * 57.00 159.00 32.70 6.00 11.0 P S * 57.00 111.00 19.30 4.00 6.50 57.00 121.00 22.00 4.00 7.00 Black anodized* See page 12 "obligatory specification". Example: 85106NL123P54 Plug with straight backshell for potting L Cross reference HE 301 B 06 RP 06 RP MS 3126 P Part numbers solder contacts L max crimp contacts solder crimp A max D max G 8 851 06 P 8 .. . 50 .. 36.20 42.10 19.05 15.34 10.46 10 851 06 P 10 .. P S . 50.. 851 06 RP 10 .. P S . 50.. 36.20 42.10 21.80 17.70 13.55 12 851 06 P 12 .. P S . 50.. 851 06 RP 12 .. P S . 50.. 36.20 42.10 26.15 21.69 13.96 14 851 06 P 14 .. PS . 50.. 851 06 RP 14 .. P S . 50.. 36.20 42.10 29.35 23.90 17.42 16 18 P S . 50.. 851 06 RP 8 .. P S 851 06 P 16 .. P S . 50.. 851 06 RP 16 .. P S . 50.. 36.20 42.10 32.50 27.00 20.56 851 06 P 18 .. P S . 50.. 851 06 RP 18 .. P S . 50.. 37.70 45.40 35.30 30.50 23.66 20 851 06 P 20 .. P S . 50.. 851 06 RP 20 .. P S . 50.. 42.40 50.00 38.85 33.65 23.92 22 851 06 P 22 .. P S . 50.. 851 06 RP 22 .. P S . 50.. 42.40 50.00 42.05 37.10 25.52 24 851 06 P 24 .. P S . 50.. 851 06 RP 24 .. P S . 50.. 42.85 50.00 45.10 40.00 32.00 Note: all dimensions are in mm 38 ØG MS 3116 P ØD HE 301 B 06 P 06 P Shell size ØA 851 Series | Connector Environmental connectors Plug with short metallic adaptor and plastic cable gland B A ØG ØC Part numbers solder contacts 8 851 06S 8 10 12 * P S ØG A maxi B maxi ØC maxi mini maxi 37.00 61.00 19.30 4.00 5.00 851 06S 10 P S * 37.00 64.00 22.00 4.00 6.00 851 06S 12 P S * 37.00 66.00 26.30 4.00 7.00 14 851 06S 14 P S * 37.00 67.00 29.50 4.00 9.00 16 851 06S 16 P S * 42.00 75.00 32.70 6.00 12.00 Connector Shell size Black anodized* See page 12 "obligatory specification". Example: 85106S123P54 Plug with straight backshell for heatshrink sleeving L ØA ØG 06 T 06 RT VG 95328 J D Cross reference M Shell size Part numbers solder contacts 8 851 06 T 8.. 10 851 06 T 10.. 12 14 L max crimp contacts solder crimp A max D max G max Solder Crimp M max . 50.. 851 06 RT 8.. . 50 .. 36.70 36.00 19.05 15.35 7.20 6.70 3.70 P S . 50.. 851 06 RT 10.. P S . 50.. 36.70 36.00 21.80 18.15 10.20 9.40 3.70 851 06 T 12.. P S . 50.. 851 06 RT 12.. P S . 50.. 36.70 36.00 26.15 23.45 13.20 11.95 3.70 851 06 T 14.. P S . 50.. 851 06 RT 14.. P S . 50.. 36.70 36.00 29.35 24.25 16.10 15.15 3.70 16 851 06 T 16.. P S . 50.. 851 06 RT 16.. P S . 50.. 39.00 38.30 32.50 29.55 19.25 18.05 3.70 18 851 06 T 18.. P S . 50.. 851 06 RT 18.. P S . 50.. 39.00 38.30 35.30 31.75 21.30 19.95 3.70 20 851 06 T 20.. P S . 50.. 851 06 RT 20.. P S . 50.. 44.00 42.90 38.85 35.85 24.40 23.05 3.70 22 851 06 T 22.. P S . 50.. 851 06 RT 22.. P S . 50.. 44.00 42.90 42.05 38.20 27.50 25.55 3.70 24 851 06 T 24.. P S . 50.. 851 06 RT 24.. P S . 50.. 42.70 41.60 45.10 41.30 30.60 28.65 3.70 P S P S Note: all dimensions are in mm 39 851 Series | Connector Environmental connectors Plug with straight adaptor for electrical pitch access ØA D The Z type special adaptor which equips crimp plug 851 06 RZ fits following accessories. - Packing gland collet backshell - Backshell for polyflex sleeving - Backshell for C.N.O.M.O. tube ØC L B Part numbers L max Shell size solder contacts crimp contacts 8 - - 10 - 12 851 06 Z 12 .. 14 solder crimp - - B max C max D threading PE - - - - - - - - - 43.00 26.15 9.10 24.80 11 P S . 50.. 851 06 RZ 12 .. 851 06 Z14 .. P S . 50.. 851 06 RZ 14 .. P S . 50.. 45.00 29.35 11.00 28.80 16 16 851 06 Z 16 .. P S . 50.. 851 06 RZ 16 .. P S . 50.. 45.00 32.50 11.00 30.80 16 18 851 06 Z 18 .. P S . 50.. 851 06 RZ 18 .. P S . 50.. 46.00 35.30 12.00 40.80 21 20 851 06 Z 20 .. P S . 50.. 851 06 RZ 20 .. P S . 50.. 46.50 38.85 12.00 40.80 21 22 851 06 Z 22 .. P S . 50.. 851 06 RZ 22 .. P S . 50.. 46.50 42.05 12.00 40.80 21 24 851 06 Z24 .. P S . 50.. 851 06 RZ 24 .. P S . 50.. 65.50 45.10 31.40 45.00 29 P S . 50.. A max Plug with elbow cable clamp backshell L ØA 08 EC HE 301 B 08 EC 08 RC HE 301 B 08 RC R Cross reference ØG Shell size Part numbers solder contacts 8 851 08 EC 8 .. 10 851 08 EC 10 .. 12 14 solder crimp A max D max G R max . 50.. 851 08 RC 8 .. . 50.. 50.10 19.05 19.70 3.50 16.00 P S . 50.. 851 08 RC 10 .. P S . 50.. 52.60 21.80 21.20 5.00 18.00 851 08 EC 12 .. P S . 50.. 851 08 RC 12 .. P S . 50.. 54.90 26.15 24.20 8.20 19.50 851 08 EC 14 .. P S . 50.. 851 08 RC 14 .. P S . 50.. 58.50 29.35 27.50 10.00 22.00 . 50.. 60.80 32.50 29.10 13.00 23.50 . 50.. 65.00 35.30 35.70 16.00 25.00 P S P S 16 851 08 EC 16 .. P S . 50.. 851 08 RC 16 .. P S 18 851 08 EC 18 .. P S . 50.. 851 08 RC 18 .. P S 20 851 08 EC 20 .. P S . 50.. 851 08 RC 20 .. P S . 50.. 69.10 38.85 35.70 16.00 26.50 22 851 08 EC 22 .. P S . 50.. 851 08 RC 22 .. P S . 50.. 71.00 42.05 39.70 19.30 28.00 24 851 08 EC 24 .. P S . 50.. 851 08 EC 24 .. P S . 50.. 75.50 45.10 43.50 20.60 31.00 Note: all dimensions are in mm 40 L max crimp contacts D 851 Series | Connector Environmental connectors Plug with elbow backshell for potting L ØA HE 301 B 08 P HE 301 B 08 RP S G Shell size Part numbers solder contacts 8 851 08 P 8 .. P S L max crimp contacts . 50.. 851 08 RP 8 .. solder . 50.. P S A max G max R max S max 19.05 8.10 11.70 11.30 crimp 40.70 10 851 08 P 10 .. P S . 50.. 851 08 RP 10 .. P S 12 851 08 P 12 .. P S . 50.. 851 08 RP 12 .. P S . 50.. 49.20 29.35 16.10 16.30 20.10 . 50.. 50.60 32.50 16.90 19.30 22.80 . 50.. 44.90 21.80 11.30 14.35 14.50 . 50.. 46.90 26.15 13.30 15.90 17.70 14 851 08 P 14 .. P S . 50.. 851 08 RP 14 .. P S 16 851 08 P 16 .. P S . 50.. 851 08 RP 16 .. P S . 50.. 51.80 35.30 18.10 20.60 25.60 . 50.. 53.70 38.85 19.70 21.90 28.80 18 851 08 P 18 .. P S . 50.. 851 08 RP 18 .. P S 20 851 08 P 20 .. P S . 50.. 851 08 RP 20 .. P S 22 851 08 P 22 .. P S . 50.. 851 08 RP 22 .. P S . 50.. 54.80 42.05 20.80 23.50 31.60 24 851 08 P 24 .. P S . 50.. 851 08 RP 24 .. P S . 50.. 58.20 45.10 24.20 30.15 35.20 Connector 08 P 08 RP R Cross reference Shielded plug with straight adaptor L ØA Cross reference Shell size Part numbers solder contacts L max crimp contacts solder crimp D VG 95328 N ØK 36 RA ØG 36 A A max D max G max F threading UNEF 2A 8 851 36 A 8 .. . 50.. 851 36 RA 8 .. 10 851 36 A 10 .. P S . 50.. 851 36 RA 10 .. P S 12 851 36 A 12 .. P S . 50.. 851 36 RA 12 .. P S . 50.. 41.00 26.15 21.70 15.25 3/4 20 14 851 36 A 14 .. P S . 50.. 851 36 RA 14 .. P S . 50.. 41.00 29.35 25.10 18.15 7/8 20 16 851 36 A 16 .. P S . 50.. 851 36 RA 16 .. P S . 50.. 41.00 32.50 28.13 21.32 1-20 18 851 36 A 18 .. P S . 50.. 851 36 RA 18 .. P S . 50.. 41.00 35.30 31.38 24.32 1-3/16 18 20 851 36 A 20 .. P S . 50.. 851 36 RA 20 .. P S . 50.. 43.30 38.85 34.30 26.73 1-3/16 18 22 851 36 A 22 .. P S . 50.. 851 36 RA 22 .. P S . 50.. 43.30 42.05 37.60 30.67 1-7/16 18 24 851 36 A 24 .. P S . 50.. 851 36 RA 24 .. P S . 50.. 43.50 45.10 40.70 33.08 1-7/16 18 P S P S . 50.. 41.00 19.05 14.50 9.10 1/2 28 . 50.. 41.00 21.80 18.70 12.08 5/8 24 Note: all dimensions are in mm 41 851 Series | Connector Environmental connectors Shielded plug with removable straight backshell for screen termination and heatshrink sleeving L ØA ØG 36 G 36 RG VG 95328 M ØD Cross reference M Shell size Part numbers solder contacts 8 851 36 G 8 .. P S L max crimp contacts . 50.. 851 36 RG 8 .. PS . 50.. solder A max D max G max M max 19.05 16.30 7.45 3.60 crimp 54.00 10 851 36 G10 .. P S . 50.. 851 36 RG 10 .. P S 12 851 36 G 12 .. P S . 50.. 851 36 RG 12 .. P S 14 851 36 G 14 .. P S . 50.. 851 36 RG 14 .. P S . 50.. 54.00 29.35 25.30 16.50 3.60 16 851 36 G 16 .. P S . 50.. 851 36 RG 16 .. P S . 50.. 54.00 32.50 28.30 19.35 3.60 18 851 36 G 18 .. P S . 50.. 851 36 RG 18 .. P S . 50.. 54.00 35.30 32.30 21.60 3.60 20 851 36 G 20 .. P S . 50.. 851 36 RG 20 .. P S . 50.. 58.00 38.85 34.30 24.80 3.60 22 851 36 G 22 .. P S . 50.. 851 36 RG 22 .. P S . 50.. 58.00 42.05 38.30 27.90 3.60 24 851 36 G 24 .. P S . 50.. 851 36 RG 24 .. P S . 50.. 58.00 45.10 41.30 31.00 3.60 . 50.. 54.00 21.80 18.30 10.30 3.60 . 50.. 54.00 26.15 22.30 13.20 3.60 Shielded plug with removable straight backshell for screen termination and heatshrink sleeving (38 & 42 suffix) ØA ØD ØG L M Shell size Part numbers solder contacts 8 851 36 T 8 .. 10 851 36 T 10 .. 12 . 50.. 38 42 851 36 RT 8 .. P S solder crimp A max D max G max M max . 50.. 51.60 19.05 18.25 7.45 3.70 . 50.. 51.60 21.80 20.25 9.00 3.70 . 50.. 38 42 851 36 RT 10 .. P S . 50.. 38 42 851 36 RT 12 .. P S . 50.. 51.60 26.15 24.75 13.30 3.70 851 36 T 14 .. P S . 50.. 38 42 851 36 RT 14 .. P S . 50.. 51.60 29.35 27.75 16.50 3.70 16 851 36 T 16 .. P S . 50.. 38 42 851 36 RT 16 .. P S . 50.. 51.60 32.50 30.05 18.50 3.70 18 851 36 T 18 .. P S . 50.. 38 42 851 36 RT 18 .. P S . 50.. 52.00 35.30 34.15 21.90 3.70 20 851 36 T 20 .. P S . 50.. 38 42 851 36 RT 20 .. P S . 50.. 53.90 38.85 37.25 25.10 3.70 22 851 36 T 22 .. P S . 50.. 38 42 851 36 RT 22 .. P S . 50.. 53.90 42.05 40.45 28.20 3.70 24 851 36 T 24 .. P S . 50.. 38 42 851 36 RT 24 .. P S . 50.. 53.90 45.10 43.65 31.40 3.70 P S 851 36 T 12 .. 14 Note: all dimensions are in mm 42 P S L max crimp contacts P S 851 Series | Connector Hermetic connectors Square flange receptacle B F J C Cross reference ØE H ØL D Shell size Part numbers A max B C D E F max H max J L 8 851 02 H 8 .. PS . 50.. 12.03 13.84 11.24 1.55 14.27 7.5 21.03 15.09 3.15 10 851 02 H 10 .. . 50.. 15.01 13.84 11.24 1.55 17.07 7.5 24.23 18.26 3.15 12 851 02 H 12 .. PS . 50.. 19.07 13.84 11.24 1.55 19.84 7.5 26.59 20.62 3.15 14 851 02 H 14 .. . 50.. 22.25 13.84 11.24 1.55 23.01 7.5 28.98 23.00 3.15 16 851 02 H 16 .. PS . 50.. 25.42 13.84 11.24 1.55 26.19 7.5 31.34 24.61 3.15 18 851 02 H 18 .. . 50.. 28.60 13.84 11.24 1.55 29.36 7.5 33.73 26.97 3.15 20 851 02 H 20 .. PS . 50.. 31.77 15.42 12.00 2.36 31.75 7.5 36.91 29.36 3.15 22 8851 02 H 22 .. . 50.. 34.95 16.23 12.00 2.36 34.92 7.5 40.10 31.75 3.15 24 851 02 H 24 .. PS . 50.. 38.12 17.04 12.81 2.36 38.10 6.7 43.27 34.92 3.82 P S P S P S P S Connector HE 301 B 02 H ØA 02 H Jam nut receptacle B E Cross reference F MS 3114 H ØA 07 H ØG HE 301 B 07 H VG 95328 F ØD C Shell size Part numbers A max B max C D max E max F G max 8 851 07 H 8 .. PS . 50.. 12.03 20.60 17.93 27.37 24.07 13.33 14.26 10 851 07 H 10 .. PS . 50.. 15.01 20.60 17.93 30.57 27.22 16.51 17.43 12 851 07 H 12 .. . 50.. 19.07 20.60 17.93 35.32 32.00 20.63 22.19 14 851 07 H 14 .. PS . 50.. 22.25 20.60 17.93 38.50 35.17 23.78 25.36 16 851 07 H 16 .. . 50.. 25.42 20.60 17.93 41.67 38.35 26.93 28.54 18 851 07 H 18 .. PS . 50.. 28.60 20.60 17.93 44.85 41.52 30.10 31.71 20 851 07 H 20 .. . 50.. 31.77 26.15 22.70 49.62 46.27 33.28 34.89 22 8851 07 H 22 ..PS . 50.. 34.95 26.15 22.70 52.77 49.47 36.45 38.06 24 851 07 H 24 .. . 50.. 38.12 26.98 23.54 55.97 52.62 39.63 41.24 P S P S P S P S Note: all dimensions are in mm 43 851 Series | Connector Hermetic connectors Solder fixing receptacle B ØG C Cross reference MS 3113 H ØE ØA HE 301 B 1H IH VG 95328 G D Shell size Part numbers A max B C D E F max G max 8 851 IH 8 .. PS . 50.. 12.03 13.84 10.70 0.80 14.27 8.60 16.40 10 851 IH 10 .. . 50.. 15.01 13.84 10.70 0.80 17.07 8.60 19.40 12 851 IH 12 .. PS . 50.. 19.07 13.84 10.70 0.80 19.84 8.60 21.80 14 851 IH 14 .. . 50.. 22.25 13.84 10.70 0.80 23.01 8.60 25.00 16 851 IH 16 .. PS . 50.. 25.42 13.84 10.70 0.80 26.19 8.60 28.10 18 851 IH 18 .. . 50.. 28.60 13.84 10.70 0.80 29.36 8.60 31.30 20 851 IH 20 .. PS . 50.. 31.77 15.42 12.70 0.80 31.75 8.60 33.70 22 8851 IH 22 .. . 50.. 34.95 16.23 12.70 0.80 34.92 8.60 36.90 24 851 IH 24 .. PS . 50.. 38.12 17.04 13.10 0.80 38.10 7.80 40.10 P S P S P S P S Note: all dimensions are in mm 44 851 Series | Connector PC Tail connectors Square flange receptacle L A B max C max ØD max E F max J L max T +1.25 0 851 02 E 8.. P S .50.. 16 40 12.03 11.70 1.32 10.84 15.09 20.99 3.13 20.50 9.46 10 851 02 E 10.. .50.. 16 40 15.01 11.70 1.32 13.99 18.26 24.19 3.13 20.50 9.46 12 851 02 E 12.. PS .50.. 16 40 19.07 11.70 1.32 17.37 20.62 26.54 3.13 20.50 9.46 14 851 02 E 14.. PS .50.. 16 40 22.25 11.70 1.32 20.57 23.00 28.89 3.13 20.50 9.46 16 851 02 E 16.. PS .50.. 16 40 25.42 11.70 1.32 23.62 24.61 31.29 3.13 20.50 9.46 18 851 02 E 18.. PS .50.. 16 40 28.60 11.70 1.32 26.69 26.97 33.69 3.13 20.50 9.46 20 851 02 E 20.. PS .50.. 16 40 31.77 14.35 2.15 29.89 29.36 36.89 3.13 23.80 7.76 22 851 02 E 22.. PS .50.. 16 40 34.95 14.35 2.15 33.04 31.75 39.99 3.13 23.80 7.76 24 851 02 E 24.. PS .50.. 16 40 38.12 15.20 2.15 36.24 34.92 43.15 3.81 23.80 7.76 P S Connector C Part numbers 8 F ØD ØA B Shell size E T Jam nut receptacle L P S ØA T B Shell size Part numbers ØF C A B max C max F max L max P max S max T +1.25 0 8 851 07 A 8.. 16 40 12.03 17.90 2.64 26.94 20.64 19.29 23.94 9.46 10 851 07 A 10.. PS .50.. 16 40 15.01 17.90 2.64 30.14 20.64 22.38 26.95 9.46 12 851 07 A 12.. PS .50.. 16 40 19.07 17.90 2.64 34.94 20.64 27.13 31.74 9.46 14 851 07 A 14.. PS .50.. 16 40 22.25 17.90 2.64 38.04 20.64 30.33 34.94 9.46 16 851 07 A 16.. PS .50.. 16 40 25.42 17.90 2.64 41.26 20.64 33.48 38.24 9.46 18 851 07 A 18.. PS .50.. 16 40 28.60 17.90 2.64 44.44 20.64 36.68 41.34 9.46 20 851 07 A 20.. PS .50.. 16 40 31.77 22.45 3.44 49.14 25.99 39.83 46.04 8.49 22 851 07 A 22.. PS .50.. 16 40 34.95 22.45 3.44 52.24 25.99 43.03 49.24 8.49 24 851 07 A 24.. PS .50.. 16 40 38.12 23.30 3.44 55.54 26.84 46.18 52.74 7.79 P S .50.. Note: all dimensions are in mm 45 851 Series | Connector Panel cut out Receptacle Square flange receptacle Shell size A±0.1 B±0.1 C±0.1 E±0.15 J±0.15 8 15.55 14.60 14.70 15.10 10 18.80 17.75 17.50 12 22.15 22.50 14 25.30 25.70 16 28.45 18 31.65 20 22 24 N P±0.1 X min 3.17 13.75 2.90 1.57 3.17 16.95 2.90 3.15 1.57 3.17 21.50 2.90 3.15 1.57 3.17 24.20 2.90 24.60 3.15 1.57 3.17 27.35 2.90 26.97 3.15 1.57 3.17 30.55 2.90 32.10 29.36 3.15 1.57 6.35 33.70 5.50 35.30 31.75 3.15 1.57 6.35 36.90 5.50 38.40 34.92 3.82 1.57 6.35 40.05 5.50 min max 3.15 1.57 18.26 3.15 20.20 20.62 23.40 23.00 28.85 26.60 32.05 29.80 34.80 35.20 38.00 38.40 41.20 41.55 Note: all dimensions are in mm 46 Solder fixing receptacle Jam nut receptacle 851 Series | Connector Backshell / Ordering information Shell size Backnut Straight cable clamp Straight backshell for potting (nut+potting) Straight adaptor Straight backshell for heatshrink sleeving Removable straight backshell for heatshrink sleeving Removable straight backshell for screen termination & heatshrink sleeving Straight sealing gland backshell Straight sealing gland & cable clamp backshell Short backshell for screen termination & heatshrink sleeving Straight adaptor for electrical pitch access E R EC or AC RC Plating* Std 29 31 44 Std 29 31 44 8 10 12 14 16 18 20 22 24 8500-5882 LP 8500-5883 LP 8500-5884 LP 8500-5885 LP 8500-5886 LP 8500-5887 LP 8500-5888 LP 8500-5889 LP 8500-5890 LP 8500-5882 110 8500-5883 110 8500-5884 110 8500-5885 110 8500-5886 110 8500-5887 110 8500-5888 110 8500-5889 110 8500-5890 110 8500-5882 202 8500-5883 202 8500-5884 202 8500-5885 202 8500-5886 202 8500-5887 202 8500-5888 202 8500-5889 202 8500-5890 202 8500-2469 900 8500-2470 900 8500-2471 900 8500-2472 900 8500-2473 900 8500-2474 900 8500-2475 900 8500-2476 900 8500-2477 900 8500-2469 902 8500-2470 902 8500-2471 902 8500-2472 902 8500-2473 902 8500-2474 902 8500-2475 902 8500-2476 902 8500-2477 902 8500-2469 903 8500-2470 903 8500-2471 903 8500-2472 903 8500-2473 903 8500-2474 903 8500-2475 903 8500-2476 903 8500-2477 903 Nut P RP Std 8500-1559 LP 8500-1560 LP 8500-1561 LP 8500-1562 LP 8500-1563 LP 8500-1564 LP 8500-1565 LP 8500-1566 LP 8500-1567 LP P - RP - 8500-466 8500-467 8500-468 8500-469 8500-470 8500-471 8500-472 8500-473 8500-474 8500-682 8500-683 8500-684 8500-685 8500-686 8500-687 8500-688 8500-689 8500-690 A RA Std 8500-448 LP 8500-449 LP 8500-450 LP 8500-451 LP 8500-452 LP 8500-453 LP 8500-3185 LP 8500-3186 LP 8500-456 LP Std 8500-4021 LP 8500-4022 LP 8500-4023 LP 8500-4024 LP 8500-4025 LP 8500-4026 LP 8500-4027 LP 8500-4028 LP 8500-4029 LP T RT 29 31 8500-4021 110 8500-4022 110 8500-4023 110 8500-4024 110 8500-4025 110 8500-4026 110 8500-4027 110 8500-4028 110 8500-4029 110 Std 8500-4045 900 8500-4046 900 8500-4047 900 8500-4048 900 8500-4049 900 8500-4050 900 8500-4051 900 8500-4052 900 8500-4053 900 Std 8501-0188 900 8500-8977 900 8501-0189 900 8500-8978 900 8501-0190 900 8500-8979 900 8500-8980 900 8500-8981 900 8500-8982 900 44 8501-0188 903 8500-8977 903 8501-0189 903 8500-8978 903 8501-0190 903 8500-8979 903 8500-8980 903 8500-8981 903 8500-8982 903 38 851 T 08-38 851 T 10-38 851 T 12-38 851 T 14-38 851 T 16-38 851 T 18-38 851 T 20-38 851 T 22-38 851 T 24-38 42 851 T 08-42 851 T 10-42 851 T 12-42 851 T 14-42 851 T 16-42 851 T 18-42 851 T 20-42 851 T 22-42 851 T 24-42 Sealing gland - 8500-5873 8500-5874 8500-5875 8500-5876 8500-5877 8500-5878 8500-5879 8500-5880 8500-5881 Nut Std 8500-5900 LP 8500-5901 LP 8500-5902 LP 8500-5903 LP 8500-5904 LP 8500-5905 LP 8500-5906 LP 8500-5907 LP 8500-5908 LP Sealing gland - 8500-5873 8500-5874 8500-5875 8500-5876 8500-5877 8500-5878 8500-5879 8500-5880 8500-5881 Nut Std 8500-5989 900 8500-5990 900 8500-5991 900 8500-5992 900 8500-5993 900 8500-5994 900 8500-5995 900 8500-5996 900 8500-5997 900 Potting M RM G RG T RT U RU Std - - 8500-8474 900 8500-8475 900 8500-8476 900 - - - - Z RZ Std - - 8500-8185 LP 8500-8186 LP 8500-8187 LP 8500-8188 LP 8500-8189 LP 8500-8190 LP 8500-8191A LP 47 Connector Designation Contact type Solder Crimp 851 Series | Connector Straight backshells for Receptacle 07 / Ordering information Shell size Designation Contact type Solder Crimp 8 10 12 14 16 18 20 22 24 Std 29 31 44 8500-8347 LP 8500-374 LP 8500-375 LP 8500-376 LP 8500-377 LP 8500-378 LP 8500-379 LP 8500-380 LP 8500-381 LP 8500-8347 110 8500-374 110 8500-375 110 8500-376 110 8500-377 110 8500-378 110 8500-379 110 8500-380 110 8500-381 110 8500-8347 202 8500-374 202 8500-375 202 8500-376 202 8500-377 202 8500-378 202 8500-379 202 8500-380 202 8500-381 202 Backnut E Straight cable clamp EC or AC RC Std 8500-8351 900 8500-1790 900 8500-1791 900 8500-1792 900 8500-1793 900 8500-1794 900 8500-1795 900 8500-1796 900 8500-1797 900 P - - 8500-466 8500-467 8500-468 8500-469 8500-470 8500-471 8500-472 8500-473 8500-474 - RP - 8500-682 8500-683 8500-684 8500-685 8500-686 8500-687 8500-688 8500-689 8500-690 Std 8500-4776 LP 8500-4777 LP 8500-4778 LP 8500-4779 LP 8500-4780 LP 8500-4781 LP 8500-4782 LP 8500-4783 LP 8500-4784 LP T RT 29 31 8500-4776 110 8500-4777 110 8500-4778 110 8500-4779 110 8500-4780 110 8500-4781 110 8500-4782 110 8500-4783 110 8500-4784 110 Straight backshell for potting Straight backshell for heatshrink sleeving R Plating* Elbow backshells / Ordering information Shell size Designation Elbow cable clamp backshell Contact type Solder Crimp EC RC Plating* 8 10 12 14 16 18 20 22 24 Std 8500-791 900 8500-792 900 8500-793 900 8500-794 900 8500-795 900 8500-796 900 8500-3224 900 8500-3225 900 8500-799 900 29 31 8500-791 902 8500-792 902 8500-793 902 8500-794 902 8500-794 902 8500-795 902 8500-796 902 8500-3224 902 8500-799 902 *Plating: Std olive green cadmium plating 29 black anodised (solder version) 031 black anodised (crimp version) 44 nickel plating 38 nickel plating for backshell for screen termination 42 olive green cadmium plating 48 851 Series | Connector Push-pull locking plug General characteristics • Locking: by pushing on the coupling nut • Unlocking: by pulling a lanyard • Mounted: on all 851 receptacles • Layouts and crimp solder contacts: (see pages 14 & 15) • cable gainé noir longueur déroulée 106 mm (for other length, consult us) • Other characteristics: (see page 16) Ordering information Basic Series 856 00 E 8 3A P - 50 -- Shell type: 06 plug for use with straight backshell 08 plug for use with 90° backshell Connector Backshell type: Solder Crimp E R backnut EC RC straight cable clamp A RA straight adaptor P RP straight backshell for potting T RT straight backshell for heatshrink sleeving M RM straight removable backshell for heatshrink sleeving EC RC 90° cable clamp Shell size: 8 - 10 - 12 - 14 - 16 - 18 - 20 - 22 - 24 Contacts layout: see pages 14 & 15 Contact type: P male S female Orientation: Normal (not included in part number). For others note: W, X, Y, Z - see table page 76 Obligatory suffix 50 Specification 07 olive-green cadmium plating (solder version) 08 olive green cadmium plating (crimp version) 09 white cadmium plating (crimp and solder version) 49 851 Series | Connector Push-pull locking plug Shell size Backshell type Dimension 8 10 12 14 16 18 20 22 24 All A 19.50 22.80 27.30 30.80 34.00 37.00 41.00 44.50 49.20 All B 24.95 28.25 32.55 36.05 39.05 42.05 45.80 49.20 53.45 06 R E 32.00 32.00 32.00 32.00 32.00 32.00 31.80 31.80 31.80 06 RC E 47.30 47.30 47.30 47.30 50.50 50.50 49.90 49.90 49.90 06 RP E 42.10 42.10 42.10 42.10 42.10 45.40 49.80 49.80 49.80 06 RA E 41.00 41.00 41.00 41.00 41.00 41.00 43.00 43.00 43.20 06 RM E 50.00 50.00 50.00 50.00 50.00 50.00 51.70 51.70 51.70 06 RT spécifications 38 or 42 E 50.00 50.00 50.00 50.00 50.00 50.00 51.70 51.70 51.70 E 50.10 52.60 54.90 58.50 60.80 65.00 68.80 71.20 76.20 D max 16.00 18.00 19.50 22.00 23.50 25.00 26.50 28.00 31.00 08RC Note : For backshells dimensioning, refer to values given in preceding pages Note: all dimensions are in mm 50 851 Series | Connector 8F51 filter connectors General information They are intermountable and intermateable with standard connectors. Different types of filters may be fitted in these connectors to eliminate RFI/EMI in different frequency ranges. Using built-in High Performance EMI filters offers the following advantages : • Efficient filtering on interferences at electronic equipment input or output, • Case screen-shielding efficiency is maintained, • Cost and volume saving as compared with the use of discrete filters wired down the line, • 4 types of standard filters are available Please consult us for other capacitance and filter types, • Combinations of mixed filter in the same layout: filtered, non-filtered and grounded contacts available. • Max. current rating per contact: 7.5 A (#20), 13 A (#16) • Max. operating voltage: 200 Vdc, 120 Vac • Standard filter types: C, Pi • Capacitance range: typically 500 pF - 200 nF • Filter performance: up to -60dB / -80dB For this product, consult our FILTER CONNECTOR department. An adaptor version is also a simple technique to equip existing systems which do not incorporate filters. Connector These connectors are derived from standard specifications MIL-DTL-26482 G series 1 - NFC 93422 (HE 301 B) - VG 95328. Electrical characteristics 51 851 Series | Connector SNC specific connectors and connection accessories General information These connectors are derived from standard specifications MIL-DTL-26482 G series 1 - NFC 93422 (HE 301 B) - VG 95328. They are intermountable and intermateable with standard connectors. Different types of filters may be fitted in these connectors to eliminate RFI/EMI in different frequency ranges. Using built-in High Performance EMI filters offers the following advantages : • Efficient filtering on interferences at electronic equipment input or output Electrical characteristics • Case screen-shielding efficiency is maintained • Cost and volume saving as compared with the use of discrete filters wired down the line • 4 types of standard filters are available. Please consult us for other capacitance and filter types • Combinations of mixed filter in the same layout: filtered, non-filtered and grounded contacts available. • Max. current rating per contact: 7.5 A (#20),13 A (#16) • Max. operating voltage: 200 Vdc, 120 Vac • Standard filter types: C, Pi • Capacitance range: typically 500 pF - 200 nF • Filter performance: up to -60dB / -80dB An adaptor version is also a simple technique to equip existing systems which do not incorporate filters. For this product, consult our FILTER CONNECTOR department. Designations Part numbers Square flange through bulkhead, pins, sockets Shell sizes 8 to 24: layouts 8.03 / 10.06 / 12.10 / 14.19 / 16.26 / 18.32 / 20.41 / 22.55 / 24.61 Insert rotations: N & W Plating: 085 green cadmium / 112 black anodized EC 52 B Short profile 90° backshell with cable clamp for 08 RC plug Shell sizes 12, 14, 16, 18 and 22 SN 556 Plug and receptacle connector Shell size 24 : contact layout = 3 contacts # 16, 7 contacts # 20, 1 coaxial contact 50 Ω (for KX15 cable) SN 775 P SN 775 S Shunt plug SN 901 Straight two-piece backshell with sealing gland and cable strap Shell sizes 8, 10 and 16 SN 946 Plug with flanged coupling nut Shell sizes 20, 22 and 24 SN 1167 Cable in line receptacle test connector, pins, sockets Shell sizes 8 to 24, arrangements with size contacts # 20 SN 1206 Ring with lugs with cone-pointed grub screws fitting 851 plug Shell sizes 8 to 24 SN 1277 Elbow backshell with closing sleeve for shield termination by magnaforming Shell sizes 8 to 24 SN 1533 Jam nut receptacle with front release straight PC tails Layouts: 14.19 (N) / 16.26 (N) / 18.32 (N, X) / 20.41 (N, W, X, Y) / 22.55 (N, W, X, Y, Z) / 24.61 (N) Plating: passivated green cadmium SN 0378 Other layouts, please consult us 52 851 Series | Connector Connector Notes 53 851 SERIES © 2016 SOURIAU - SOURIAU is a registered trademark 851 Series Contacts & Accessories Crimp contacts ................................................................................................................. 56 Caps / Ordering information ............................................................................................ 57 Plastic protective caps ...................................................................................................... 59 Filler plugs ........................................................................................................................ 59 Dummy receptacle ........................................................................................................... 60 Gaskets ............................................................................................................................. 60 55 851 Series | Contacts & Accessories Crimp contacts Standard version Contact size #20 Ø1 mm Wire size Specification AWG mm² For layouts 8-2, 8-3, 8-4 & 12-14 24-18 0.21-0.93 For further contact layout 24-18 0.21-0.93 Reducing sleeve 30-24 0.06-0.21 - 18-14 0.93-1.91 Reducing sleeve 20 0.60 Part number insulator Ø Male Female 8500-9573* 8500-9213 900* 8500-697 8500-1758A 900 8500-781 B1 8500-1300 #16 Ø1.6 mm 8500-9331 900 8500-1985 B1 min. max. 1.20 2.11 1.20 2.11 - - 1.60 2.80 - - Thermocouple version Contact size Wire size Specification AWG mm² Chromel 24-18 0.21-0.93 Alumel 24-18 0.21-0.93 Chromel 18-14 0.93-1.91 Alumel 20 0.60 #20 Ø1 mm #16 Ø1.6 mm Note: all dimensions are in mm 56 Part number insulator Ø Male Female 8500-809 A 8500-2054 900 8500-812 A 8500-2055 900 8500-1053 8500-1054 900 8500-812 A 8500-1059 900 min. max. 1.20 2.11 1.20 2.11 1.60 2.80 1.60 2.80 851 Series | Contacts & Accessories Caps / Ordering information Basic Series Shell type: Part numbers for receptacle Part numbers for plug 8 02 10 10 03 11 12 04 12 14 05 13 16 27 28 18 06 14 8500 05 22 08 16 24 09 17 20 07 15 -- Specifications: For cap & plating, see table below Type and plating Plug cap Olive White Black green cadmium anodised cadmium Cap type Nickel Olive White Black green cadmium anodised cadmium Nickel Cap with chain and ring D 02 D 29 D 44 D D 02 D 29 D 44 D Cap with nylon cord and ring B 02 B 29 B 44 B B 02 B 29 B 44 B Cap with nylon cord and washer (shell 10, 12 , 14, 16 & 18) - - - - E - - - Cap with nylon cord and washer H - - 44 H - - - - Cap with chain and washer J - - - - - - - JQ7 - - - - - - - M - - - M - - - Cap 500hr salt spray Cap without chain Contacts & Accessories Receptacle cap Caps for plugs D B&M E Shell size ØA max B max C+60 D+20 E ØF 8 16.80 19.84 132 128 consult us consult us 10 19.80 19.84 132 128 132 14.00 12 23.90 19.84 148 140 148 17.60 14 27.00 19.84 148 140 148 20.80 16 30.20 19.84 148 140 148 25.60 18 33.40 19.84 148 140 148 28.70 20 36.50 21.44 168 153 consult us consult us 22 39.80 21.44 168 153 consult us consult us 24 42.90 22.22 168 153 consult us consult us Note: all dimensions are in mm 57 851 Series | Contacts & Accessories Caps Caps for receptacles D B&M J & JQ7 H Shell size ØA max B max C+60 D+20 J max H+20 K+60 8 19.00 21.44 84 77 14.80 80 84 10 21.80 21.44 84 77 17.90 80 84 12 26.10 21.44 100 89 22.70 90 100 14 29.30 21.44 100 89 25.90 90 100 16 32.50 21.44 100 89 29.00 90 100 18 35.30 21.44 100 89 32.20 90 100 20 38.80 21.44 116 102 35.40 110 116 22 42.00 21.44 116 102 38.60 110 116 24 45.10 22.22 116 102 41.70 110 116 Note: all dimensions are in mm 58 851 Series | Contacts & Accessories Accessories Shell size Caps for receptacles Caps for plugs 8 8500-5585 A 8500-5594 10 8500-5586 A 8500-5595 12 8500-5587 A 8500-5596 14 8500-5588 A 8500-5597 16 8500-5589 A 8500-5598 18 8500-5590 A 8500-5599 20 8500-5591 A 8500-5600 22 8500-5592 A 8500-5601 24 8500-5593 A 8500-5602 Contacts & Accessories Plastic protective caps for receptacles and plugs Filler plugs Contact size Part number 8500-4144 #20 Ø1 mm Color grey 8500-4144 A (MS 3187 A 20) red 8500-479 #16 Ø1.6 mm 8500-4267 (MS 3187-16) blue Note: all dimensions are in mm 59 851 Series | Contacts & Accessories Accessories Dummy receptacles F ØA E M ØJ N Shell size Part numbers A C max E J M max N max 8 8500-18 12.03 20.99 15.09 3.13 11.70 1.32 10 8500-19 15.01 24.19 18.26 3.13 11.70 1.32 12 8500-20 19.07 26.54 20.62 3.13 11.70 1.32 14 8500-21 22.25 28.89 23.00 3.13 11.70 1.32 16 8500-26 25.42 31.29 24.61 3.13 11.70 1.32 18 8500-22 28.60 33.69 26.97 3.13 11.70 1.32 20 8500-23 31.77 36.89 29.36 3.13 14.35 2.15 22 8500-24 34.95 39.99 31.75 3.13 14.35 2.15 24 8500-25 38.12 43.15 34.92 3.81 15.20 2.15 Gaskets Shell size Fairprène Gaskets for jam nut receptacle Néoprène Vitton 8 8500-275 8500-4164 3330102 3330675 10 8500-276 8500-4165 3330103 3330670 12 8500-277 8500-4166 3330104 3330671 14 8500-278 8500-4167 3330105 3330672 16 8500-283 8500-4168 3330106 3331048 18 8500-279 8500-4169 3330107 3331049 20 8500-280 8500-4170 3330108 3331050 22 8500-281 8500-4171 3330109 3331051 24 8500-282 8500-4172 3330110 3331052 Note: all dimensions are in mm 60 Gaskets for square flange receptacle Néoprène 851 Series | Contacts & Accessories Contacts & Accessories Notes 61 851 SERIES © 2016 SOURIAU - SOURIAU is a registered trademark 851 Series Technical Information Tooling .............................................................................................................................. 64 Stripping instruction ......................................................................................................... 66 Crimping instruction ......................................................................................................... 66 Crimp contact insertion .................................................................................................... 67 Crimp contact extraction .................................................................................................. 67 Cross reference list ........................................................................................................... 68 Drilling pattern ................................................................................................................. 70 Discrimination / Keying methods ..................................................................................... 76 63 851 Series | Technical Information Tooling Crimp tooling - Contact #20 & 16 Locator - Contact #20 & 16 Part number Part number 8365 (M 22520/1-01) 8365-02 (M 22520/1-02) Crimp tooling - Contact #20 Locator - Contact #20 Part number Part number 8476-01 (M 22520/2-01) 8476-02 (M 22520/2-02) Insertion tools - Crimp contact Part number 8500-29B* * Except 8-2, 8-3, 8-4, 12-14 contact layouts : insertion tool 8500-93B 64 851 Series | Technical Information Tooling Strap backshell Part number #20 Part number #16 Part number 8500-38A 8500-36A 8490-04 Technical Information Extraction tools - Crimp contact 65 851 Series | Technical Information Stripping instructions • This operation should be carried out with great care. Use stripping pliers which are in good condition and which are designed for use with the size of wire being stripped. • In order to maintain the connector’s excellent sealing characteristics and, at the same time, meet the highest cabling standards the wires should have the following external sheath dimensions : Ø over sheath Contacts size min. max. 20 1.20 2.11 16 1.60 2.80 • Recommended loading: - 050 % with max. diam. wires - 050 % with min. diam. wires - 100 % with medium size wires. • Size 20 contacts for cables: - when Ø over insulation ≤ 2 mm strip to a 4.5 mm length - when Ø over insulation > 2 mm strip to a 7 mm length. • Size 16 contacts, strip the cable to a length of 6 mm. 4.5 mm 7 mm 6 mm Cable-contact assembly • Insert the wire into the crimp barrel and ensure that it has penetrated correctly by checking that it may be seen through the lateral hole in the barrel. Reducing sleeve • If a wire with a cross sectional area of less than 0.21 mm2 is used with a size 20 contact, it will be necessary to use a reducing sleeve: ref. 8500-781. • Wires of cross sectional area of 0.6 mm2 may be used with size 16 contacts by using a reducing sleeve, ref. 8500-1985. contact sleeve cable Crimping instructions • With crimping pliers MS 22520/1-01 Souriau part number 8365 and turret MS 22520/1-02 8365-02: - «red» position for size 20 contacts - «blue» position for size 16 contacts. • With crimping pliers MS 22520/2-01 Souriau part number 8476-01 and locator MS 22520/2-02 8476-02: - for size 20 contacts only. Note : not be used with reducing sleeve. Squeeze pliers firmly until a click is heard, the pliers should spring open when the ratched mechanism is released. • Hold indentor side up-insert the wire-contact assembly or mire-reducing sleeve-contact assembly between the four indentors, ensuring that the contact bottoms in the locator. • Fully close the jaws, once the contact is crimped the pliers must spring open remove wire + crimped contact, check crimp aspect. 66 851 Series | Technical Information Crimp contact insertion First disassemble and slide connector rear accessory over cables. Insertion tools • Pliers 8500-29B. • Except 8-2, 8-3, 8-4, 12-14 contact layouts: tool 8500-93B Use of insertion tools Manually insert the contact into the desired insert cavity. • Insert the wire between the pliers jaws, the tip of the jaws butting the contact shoulder. Introduce contacts one by one in insert cavities pushing straight in until the contact snaps into position and the clip ensures contact retention. Filler plugs Where certain contacts are unwired and where it is necessary to fully maintain the connector’s sealing characteristics, a filler plug must be used. Note that the contact must be inserted before the filler plug. Crimp contact extraction 8500-36A All contacts for use in insulators with clips are extracted using a semi-automatic tool: • size 20 contacts: tool type 8500-36A • size 16 contacts: tool type 8500-38A. 8500-38A First dissassemble and slide connector rear accessory over cables. • Do not operate the tool slide button. • Bring the tool tip over the male or female contact to be removed from connector front (mating face) as far as the first mark for male contacts and the second mark for female contacts. Technical Information First mark Second mark • This operation, should be carried out delicately in a direction parallel to the contact centre line with a light turning action. • Extract contact pushing the slide button fully forward, carefully remove tool and pull wire to release the wire-contact assembly. Note : tools have an adjustable spring system (rear knurled knob) also for automatic contact disengagement. 67 851 Series | Technical Information Cross reference list 851 version with crimp contacts (olive green cadmium plating) Connector with backshells SOURIAU NCF 93422 (modèle HE 301B) MIL-DTL-26482G série 1 VG 95328 851 00 R .. .. .. 50 .. HE 301 B 00 R .. .. .. 1A * MS 3120 E .. .. .. VG 95328 A .. .. .. VG 95328 B .. .. .. 851 00 RC .. .. .. 50 .. HE 301 B 00 RC .. .. .. 1A * MS 3120 F .. .. .. 851 00 RP .. .. .. 50 .. HE 301 B 00 RP .. .. .. 1A * MS 3120 P .. .. .. 851 00 RG .. .. .. 50 .. - - 851 00 RA .. .. .. 50 .. HE 301 B 00 RA .. .. .. 1A - - 851 01 R .. .. .. 50 .. HE 301 B 01 R .. .. .. 1A * MS 3121 E .. .. .. - 851 01 RC .. .. .. 50 .. HE 301 B 01 RC .. .. .. 1A * MS 3121 F .. .. .. - 851 01 RP .. .. .. 50 .. HE 301 B 01 RP .. .. .. 1A * MS 3121 P .. .. .. - 851 01 RA .. .. .. 50 .. HE 301 B 01 RA .. .. .. 1A - - 851 02 R .. .. .. 50 .. HE 301 B 02 R .. .. .. 1A * MS 3122 E .. .. .. VG 95328 C .. .. .. VG 95328 R .. .. .. 851 06 R .. .. .. 50 .. HE 301 B 06 R .. .. .. 1A * MS 3126 E .. .. .. - 851 06 RC .. .. .. 50 .. HE 301 B 06 RC .. .. .. 1A * MS 3126 F .. .. .. VG 95328 K .. .. .. 851 06 RP .. .. .. 50 .. HE 301 B 06 RP .. .. .. 1A * MS 3126 P .. .. .. - 851 06 RT .. .. .. 50 .. - - VG 95328 J .. .. .. 851 06 RA .. .. .. 50 .. HE 301 B 06 RA .. .. .. 1A - - 851 36 RG .. .. .. 50 .. - - VG 95328 M .. .. .. 851 36 RA .. .. .. 50 .. - - - 851 07 R .. .. .. 50 .. HE 301 B 07 R .. .. .. 1A * MS 3124 E .. .. .. VG 95328 D .. .. .. 851 07 RC .. .. .. 50 .. HE 301 B 07 RC .. .. .. 1A * MS 3124 F .. .. .. VG 95328 E .. .. .. 851 07 RP .. .. .. 50 .. HE 301 B 07 RP .. .. .. 1A * MS 3124 P .. .. .. - 851 07 RT .. .. .. 50 .. - - VG 95328 S .. .. .. 851 07 RG .. .. .. 50 .. - - VG 95328 T .. .. .. 851 08 RC .. .. .. 50 .. HE 301 B 08 RC .. .. .. 1A - - * Not QPL 851 version with crimp contacts (other plating) SOURIAU Plating 68 NFC 93422 (modèle HE 301B) Solder version Crimp version Black anodised 851 .. .. .. .. 5029 851 .. .. .. .. .. 50031 HE 301B .. .. .. .. .. 4A Nickel 851 .. .. .. .. 5044 851 .. .. .. .. .. 5044 HE 301B .. .. .. .. .. 5A 851 Series | Technical Information Cross reference list 851 version with solder contacts (olive green cadmium plating) SOURIAU NCF 93422 (modèle HE 301B) MIL-DTL-26482G série 1 VG 95328 851 00 E .. .. .. 50 .. HE 301 B 00 E .. .. .. 1A MS 3110 E .. .. .. - 851 00 EC .. .. .. 50 .. HE 301 B 00 EC .. .. .. 1A MS 3110 F .. .. .. - 851 00 AC .. .. .. 50 .. HE 301 B 00 AC .. .. .. 1A - - 851 00 P .. .. .. 50 .. HE 301 B 00 P .. .. .. 1A MS 3110 P .. .. .. - 851 00 A .. .. .. 50 .. HE 301 B 00 A .. .. .. 1A - - 851 00 J .. .. .. 50 .. HE 301 B 00 J .. .. .. 1A - - 851 00 JC .. .. .. 50 .. - MS 3110 J .. .. .. 851 01 E .. .. .. 50 .. HE 301 B 01 E .. .. .. 1A MS 3111 E .. .. .. - 851 01 EC .. .. .. 50 .. HE 301 B 01 EC .. .. .. 1A MS 3111 F .. .. .. - 851 01 AC .. .. .. 50 .. HE 301 B 01 AC .. .. .. 1A - - 851 01 P .. .. .. 50 .. HE 301 B 01 P .. .. .. 1A MS 3111 P .. .. .. - 851 01 A .. .. .. 50 .. HE 301 B 01 A .. .. .. 1A - - 851 01 J .. .. .. 50 .. HE 301 B 01 J .. .. .. 1A - - 851 01 JC .. .. .. 50 .. - MS 3111 J .. .. .. - 851 02 E .. .. .. 50 .. HE 301 B 02 E .. .. .. 1A MS 3112 E .. .. .. VG 95328 H .. .. .. 851 06 E .. .. .. 50 .. HE 301 B 06 E .. .. .. 1A MS 3116 E .. .. .. - 851 06 EC .. .. .. 50 .. HE 301 B 06 EC .. .. .. 1A MS 3116 F .. .. .. - 851 06 AC .. .. .. 50 .. HE 301 B 06 AC .. .. .. 1A - - 851 06 P .. .. .. 50 .. HE 301 B 06 P .. .. .. 1A MS 3116 P .. .. .. - 851 06 A .. .. .. 50 .. HE 301 B 06 A .. .. .. 1A - - 851 06 J .. .. .. 50 .. HE 301 B 06 J .. .. .. 1A - - 851 06 JC .. .. .. 50 .. - MS 3116 J .. .. .. - 851 08 EC .. .. .. 50 .. HE 301 B 08 EC .. .. .. 1A - - 851 08 P .. .. .. 50 .. HE 301 B 08 P .. .. .. 1A - - 851 07 E .. .. .. 50 .. HE 301 B 07 E .. .. .. 1A MS 3114 E .. .. .. - 851 07 EC .. .. .. 50 .. HE 301 B 07 EC .. .. .. 1A MS 3114 F .. .. .. - 851 07 AC .. .. .. 50 .. HE 301 B 07 AC .. .. .. 1A - - 851 07 P .. .. .. 50 .. HE 301 B 07 P .. .. .. 1A MS 3114 P .. .. .. - Technical Information Connector with backshells 851 Hermetic version SOURIAU NFC 93422 (modèle HE 301B) 851 02 H .. .. P.50 HE 301 B 02 H .. .. P.3A 851 07 H .. .. P.50 851 I H .. .. P.50 MIL-DTL-26482G série 1 VG 95328 HE 301 B 07 H .. .. P.3A * MS 3114 H .. .. P. VG 95328 F .. .. .. HE 301 B 1 H .. .. P.3A * MS 3113 H .. .. P. VG 95328 G .. .. . * Not QPL 69 851 Series | Technical Information Drilling pattern - Male rear face Shell Size Dimension (mm) 8-2 2 contacts 2xØ1.0 (#20) 8-3 8-3A/8-98 3xØ1.0 (#20) 3xØ1.0 (#20) 3 contacts 8-33 3 contacts 8-4 3 contacts 4 contacts 3xØ1.0 (#20) 4xØ1.0 (#20) 8 10-6 10-98 6 contacts 10-7 6 contacts 6xØ1.0 (#20) 7 contacts 6xØ1.0 (#20) 7xØ1.0 (#20) 10 12-2 12-3 2 contacts 3 contacts 2xØ1.6 (#16) 12 3xØ1.6 (#16) 12-10 10 contacts 10xØ1.0 (#20) 70 12-4 3 contacts +ground 12 4 4xØ1.6 (#16) 12-14 14 contacts 14xØ1.0 (#20) 12-8 8 contacts 8xØ1.0 (#20) 851 Series | Technical Information Drilling pattern - Male rear face Dimension (mm) 14-5 12 4 14 5 contacts 5xØ1.6 (#16) 14-15 15 contacts 14xØ1.0 (#20) 1xØ1.6 (#16) 14-7 6 contacts +ground 147 7xØ1.6 (#16) 14-18 18 contacts 18xØ1.0 (#20) 16-8 14-12 12 contacts 8xØ1.0 (#20) 4xØ1.6 (#16) 14-19 19 contacts 19xØ1.0 (#20) 16-23 8 contacts 23 contacts 8xØ1.6 (#16) 22xØ1.0 (#20) 1xØ1.6 (#16) Technical Information Shell Size 16-26 26 contacts 26xØ1.0 (#20) 16 71 851 Series | Technical Information Drilling pattern - Male rear face Shell Size Dimension (mm) 18-11 18-30 11 contacts 30 contacts 11xØ1.6 (#16) 29xØ1.0 (#20) 1xØ1.6 (#16) 18-32 32 contacts 32xØ1.6 (#16) 18 20-16 16 contacts 16xØ1.6 (#16) 20 72 20-24 24 contacts 24xØ1.0 (#20) 851 Series | Technical Information Drilling pattern - Male rear face Dimension (mm) 20-25 25 contacts 25xØ1.0 (#20) 20 20-39 39 contacts 37xØ1.0 (#20) 2xØ1.6 (#16) 20-27 27 contacts 27xØ1.0 (#20) 20-41 41 contacts 41xØ1.0 (#20) Technical Information Shell Size 22-21 21 contacts 21xØ1.6 (#16) 22 73 851 Series | Technical Information Drilling pattern - Male rear face Shell Size Dimension (mm) 22-32 32 contacts 32xØ1.0 (#20) 22-34 34 contacts 34xØ1.0 (#20) 22 22-36 36 contacts 36xØ1.0 (#20) 74 22-55 55 contacts 55xØ1.0 (#20) 851 Series | Technical Information Drilling pattern - Male rear face Shell Size Dimension (mm) 24-61 61 contacts 61xØ1.0 (#20) Technical Information 24 75 851 Series | Technical Information Discrimination / Keying methods Insulator rotated inside metal bod Viewed from front face of male insulator (receptacle or plug) Shells Angle in degrees Layouts W 8 10 X Y NFC 93422 HE 301B Z Solder Crimp MIL-DTL-26482G serie 1 Solder Crimp Service1 1500 Vrms 2 58 122 - - • X 3 60 210 - - • X 3A (98)* 60 210 - - • 4 45 - - - • 33 90 - - - 6 90 - - - 7* 90 - - - 98 90 180 240 270 3 - - 180 - • • Service 2 2300 Vrms X X • • • X • • • X • • • X X • • • X • • X • • • • X 4 12 8 90 112 203 292 10 60 155 270 295 - - - 2 - 14* 45 X 5 40 92 184 273 • • • • 43 90 - - • • • • 15 17 110 155 234 • • 18 15 90 180 270 • X X 7 14 16 18 20 22 24 12 • • X • • X X 19 30 165 315 - • • • • 8 54 152 180 331 • • • • 23 158 270 - - • • • • X X X 26 60 - 275 338 • • • • 11 62 119 241 340 • • • • 32 85 138 222 265 • • • • X • X 30 180 193 285 350 16 238 318 333 347 • • • • 39 63 144 252 333 • • • • • • 41 45 126 225 - 24 70 145 215 290 25 72 144 216 288 27 72 144 216 288 21 16 135 175 349 36 72 144 216 288 • X X X • • X • • X X • • • • • • • X X 55 30 142 226 314 72 145 215 288 • X 34 62 142 218 298 • X 61 90 180 270 324 • X • • X • 32 * 8-98 layout, W and X non standard ortientations 10-7 & 12-14 layouts, W non standard orientation 76 X • • • • X 851 Series | Technical Information Technical Information Notes 77 851 Series | Technical Information Notes 78 Our contribution to environmental protection: This catalog is printed on PEFC certified paper Advancement of sustainable wood cultivation. www.pefc.org contactindustry@souriau.com (Europe - Asia - Africa) technicalsupport@souriau.com (North America) www.souriau-industrial.com CA851WUSEN01 © Copyright SOURIAU 2016 - SOURIAU is a registered trademark Your local contact All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. Reliable People, Reliable Solutions
85102R106P50 价格&库存
很抱歉,暂时无法提供与“85102R106P50”相匹配的价格&库存,您可以联系我们找货
