BK/GMT-3/4A
BK/GMT-3/4A
    EATON(伊顿)
    报警指示器
    FUSE INDICATING 125VAC/60VDC
BK/GMT-3/4A 数据手册
Technical Data 5008 BUSSMANN Effective January 2020 Supersedes June 2016 SERIES Fast-acting indicating fuse 60 volts dc, 125 volts ac Features: Description: Bussmann® series fast-acting fuses for use in HLT, HLS and PCT fuse holders. • For telecommunications, computer, or control circuits • Visual spring indicating and alarm circuit indicating • Color coded flags designate ampere rating. • Fuses easily replaced without use of insulated tools • Fuses can be removed with wire hook when mounted on minimum centers Dimensions - in (mm): 0.127 Specifications: Contact and alarm spring 0.107 Ratings • Volts — 60 Vdc/125 Vac • Amps — up to 15 A 0.688 Max. Agency Information • UL® Recognized, Guide JFHR2, File E56412 • RoHS Compliant 0.585 0.118 0.810 Materials • Body: Thermosplastic, UL 94 V0 flammability rating • Terminals: Tin-plated beryllium copper Carton quantity and weight • Quantity: - 100 fuses per carton • Weight: - 0.33 lbs. (150g.) Fuse holders • Catalog Nos. HLT, HLS, and PCT Covers - in (mm) 0.20" (5.1mm) BUSS GMT-X 0.95" (24.0mm) 0.36" (9.0mm) 0.84" (21.3mm) GMT-X fuse cover Fuse covers • GMT-X • GMT-Y (with pull-tab) 0.95" (24.0mm) 0.20" (5.1mm) BUSS GMT-Y 0.7" (17.8mm) 0.84" (21.3mm) GMT-Y fuse cover Technical Data 5008 Fast-acting indicating fuse 60 volts dc, 125 volts ac Effective January 2020 Color code Catalog symbol Color code GMT-18/100 A Yellow GMT-3 1/2 A White/Blue GMT-1/4 A Violet GMT-4 A White/Brown GMT-3/8 A White/Gray GMT-5 A Green GMT-1/2 A Red GMT-7 1/2 A Black/White GMT-65/100 A Black GMT-10 A Red/White GMT-3/4 A Brown GMT-12 A Yellow/Green GMT-1 A Gray GMT-15 A Red/Blue GMT-1 1/3 A White GMT-Dummy Gray GMT-1 1/2 A White/Yellow GMT-A (alarm)* Yellow GMT-2 A Orange GMT-X (cover) Clear GMT-3 A Blue 300 3/8 A Catalog symbol 18/100 A 1/4 A 1/2 A Time-current characteristic curves-average melt 65/100A 3/4 A 1A 1 1/3 A 1.5 A 2A 3A 4A 5A 7.5 A 10 A 12 A 15 A Catalog symbol and color codes Amp Rating 100 10 Time in seconds *Designed specifically for use in Telpower® 15800 fused disconnect switch. 1 0.1 1000 100 10 1 0.01 0.01 Current in amps Test specifications Percent overload Opening time 100% 10 min. (minimum) 150% 5 min. (maximum) The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2020 Eaton All Rights Reserved Publication No. 5008 January 2020 Eaton, Bussmann and Telpower are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
BK/GMT-3/4A 价格&库存
很抱歉,暂时无法提供与“BK/GMT-3/4A”相匹配的价格&库存,您可以联系我们找货
