BK/MDL-1-1/4-R
BK/MDL-1-1/4-R
    EATON(伊顿)
    3AB,3AG,1/4" x 1-1/4"
    FUSE GLASS 1.25A 250VAC 3AB 3AG
BK/MDL-1-1/4-R 数据手册
/4˝ x 1 1/4˝ Time-Delay, Glass Tube Fuses 1 MDL Series Description • Time-delay • Optional axial leads available • 1⁄4 x 1 1⁄4 (6.4 x 31.7mm) physical size • Glass tube, nickel-plated brass endcap construction • UL Listed product meets standard 248-14 Rated Current ⁄16 - 30A 1 1 ⁄16 - 3A 3-2⁄10 - 8A Electrical Characteristics % of Amp Rating Opening Time 100% None 135% 60 minutes maximum 200% 120 seconds maximum 200% 5 seconds minimum 200% 12 seconds minimum • For board washable, insert “B” between catalog series and amp rating. E.g., BK-MDL-B-5-R • For axial leads and board washable, insert “B” then “V” between catalog series and amp rating. E.g., BK-MDL-BV-5-R Agency Information • UL Listed Card: MDL 1/16 - 8A (Guide JDYX, File E19180) • UL Recognized Card: MDL 9 - 30A (Guide JDYX2, File E19180) • CSA Certification Card: MDL 1/16 - 8A (Class No. 1422-01) • CSA Component Acceptance: MDL 9-30A (Class No. 1422-30) • CE Environmental Data • Shock: 1A thru 30A – MIL-STD-202, Method 207, (HI Shock) • Vibration: 1/4A thru 30A – MIL-STD-202, Method 204, Test Condition C (Except 5g, 500HZ) Ordering Specify packaging code • Insert packaging code prefix before part number. E.g., BK (or BK1)-MDL-5-R Specify option codes if desired • For axial leads, insert “V” between catalog series and amp rating. E.g., BK-MDL-V-5-R Part Number MDL-1/16-R MDL-1/10-R MDL-1/8-R MDL-3/16-R MDL-2/10-R MDL-1/4-R MDL-3/10-R MDL-3/8-R MDL-1/2-R MDL-3/4-R MDL-1-R MDL-1-1/4-R MDL-1-1/2-R MDL-2-R MDL-2-1/4-R MDL-2-1/2-R MDL-3-R MDL-4-R MDL-5-R MDL-6-R MDL-6-1/4-R MDL-7-R MDL-8-R MDL-9-R MDL-10-R MDL-15-R MDL-20-R MDL-25†† MDL-30†† Voltage Rating Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 32 32 32 32 32 32 Dimensions - mm (in) Drawing Not to Scale DIA. OF LEADS 0.81 0–15 AMP: (0.032) 20–30 AMP: 1.02 (0.040) 31.75 (1.250) Specifications 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 10000 - 38.10 (1.500) 6.76 (0.266) AC Interrupting Rating* (amps)@ 250Vac 125Vac 32Vac 35 35 35 35 35 35 35 35 35 35 35 100 100 100 100 100 100 200 200 200 200 200 200 - 32.82 (1.292) 38.10 (1.500) 6.35 (0.250) Typical DC Cold Resistance** Ω) (Ω Typical Melting I2t† AC Typical Voltage Drop‡ 45.6 15.68 12.238 4.81 5.234 3.208 2.046 1.567 0.943 0.397 0.273 0.205 0.156 0.116 0.096 0.081 0.057 0.038 0.025 0.022 0.02 0.018 0.015 0.012 0.01 0.005 0.004 0.01225 0.0011 0.0046 0.0420 0.0422 0.116 0.314 0.447 0.412 0.982 1.656 4.343 11.498 86.2 22.7 62.3 49.6 63.1 67.5 19.3 32.0 37.4 38.7 42.7 47.8 51.5 64.4 354.0 2914.0 15221.0 15581.0 2.79 1.95 1.52 1.05 0.972 0.965 0.808 1.46 1.27 1.01 0.995 0.722 0.721 0.644 0.535 0.410 0.345 0.187 0.160 0.155 0.152 0.140 0.119 0.124 0.114 0.130 0.530 0.30 0.40 1000 1000 1000 1000 1000 1000 * Interrupting Ratings (Interrupting ratings were measured at 70% - 80% power factor on AC) ** DC Cold Resistance (Measured at ≤10% of rated current) † Typical Melting I2t (A2Sec) (I2t was measured at listed interrupting rating and rated voltage.) ‡ Typical Voltage Drop (Voltage drop was measured at 25°C±3°C ambient temperature at rated current) †† MDL-25 & MDL-30 not available in RoHS compliant construction. 0209 SB-BU08675 Page 1 of 2 Data Sheet 2004 Time-Current Curve Time in Seconds Time in Seconds Current in Amps Current in Amps Packaging Code Packaging Code BK BK1 BK8 Description 100 fuses packed into a cardboard carton 1,000 fuses packed into a cardboard carton 8,000 fuses packed into a cardboard carton Option Code Option Code B V Description Sealed to withstand aqueous cleaning (Board Washable) Axial leads - copper tinned wire with nickel plated brass overcaps The only controlled copy of this Data Sheet is the electronic read-only version located on the Cooper Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. © 2009 Cooper Bussmann St. Louis, MO 63178 www.cooperbussmann.com 0209 SB-BU08675 Page 2 of 2 Data Sheet 2004
BK/MDL-1-1/4-R 价格&库存
很抱歉,暂时无法提供与“BK/MDL-1-1/4-R”相匹配的价格&库存,您可以联系我们找货
