Technical Data ELX1021
Effective February 2021
HP
10 mm x 38 mm panel mount fuse holder
Agency information
Environmental compliance
Ordering part number
BK1-HPS-611E
Packaging prefix
Product features
For 10 mm x 38 mm fuse
Panel mount fuse holder
600 Vac rating and up to 30 A
Family name
Type
Packaging prefix
BK1- (1000 parts per case pack)
HP
Specifications
Voltage rating
(Vac)
Part number
BK1-HPS-611E
600
BK1-HPG-615E
Current rating
(A)
30
600
30
Body material
Contact/clip material
Agency
Bakelite, UL 94V-0, black
Clip: copper alloy, nickel plated
Terminals: brass, tin plated
Spring: steel
cURus
Spring: steel
cURus
Dimensions- mm
HPS-611E
HPG-615E
6.40±0.1
6.35±.10
6.40±0.1
44.7
6.35±0.1
33.00
68.0±1.0
After insert the fuse Max 75
4.50
68.0±1.0
0.80±0.05
33.00
0.80±0.05
28.5
22.5±0.1
0.80±0.05
22.2±0.3
Ø14.40
25.2
0.80±0.05
4.55±0.3 2X
Ø21.4
Ø28.5
Ø14.60
25.2
Punched mounting hole
21±0.1
Hexagonal Nut
Rubber Washer
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2021 Eaton
All Rights Reserved
Printed in USA
Publication No. ELX1021 BU-ELX21022
February 2021
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“BK1-HPS-611E”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+32652.41945
- 5+31999.36773
