C14G40
C14G40
    EATON(伊顿)
    Cartridge,Non-Standard
    FUSE CARTRIDGE 40A 500VAC
C14G40 数据手册
IEC and British Standard fuses Application data Contents Description Page CSA Type P and Type D fuses (CDS, CDN and PON) . . . . . . . . . . . . . . . . . . . . . . . . . . 7-3 Tron™ HRC Form II Class C fuses (CGL Form II Class C) . . . . . . . . . . . . . . . . . . . . . . . . . . 7-4 HRCI Industrial ceramic body fuses (CIF21 HRCI-CA and CIF06 HRCI-CB) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7-5 HRCI-J Fast-acting fuses (CJ HRCI-J) . . . . . . . . . . . . . . . 7-6 HRCI-Miscellaneous Type K fuses (CIH, CIK and CIL HRCI-MISC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7-7 HRC Form II current-limiting fuses . . . . . . . . . . . . . . . . . .7-8 BS 88 British Standard low voltage fuses (SSD, NSD, ESD and STD, NITD, AAO, BAO, OSD, CEO, DEO BS 88 Part 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . .7-9 BS 88 British Standard low voltage fuses (AC, AD, BC, BD, CD, DD, ED, EFS and EF, FF, FG, GF, GG, GH BS 88) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .7-10 DIN Style Type D (D16, D27, D33, D125 Type D) . . . . . .7-11 Neozed low voltage fuses (NZ01, NZ02 Type D0) . . . . . .7-11 NH HRC fuses . . . . . . . . . . . . . . . . . . . . . . . . . . 7-12 - 7-15 Class gG/gL IEC Industrial ferrule fuses (C08G, C08M, C10G, C10M, C14G, C14M, C22G, C22M) . . . . 7-16 - 7-17 Class aM IEC Industrial ferrule fuses (C08M, C10M, C14M, C22M) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .7-18 Class aM and gG/gL IEC Industrial ferrule fuses with striker (C14G_S, C22G_S, C14M_S, C22M_S) . . . . . . . . . . . . 7-19 Application data . . . . . . . . . . . . . . . . . . . . .7-1 - 7-2 CAMaster . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .7-20 SAFEloc . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .7-20 Red Spot . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7-20 HRC fuse holders 7 The standard range of fuses for low voltage industrial and general purpose applications meet the requirements of BS 88 and IEC 60269. By using advanced fuse technology, current ratings up to 400A have compact dimensions, but retain standard dimensional and performance requirements. These designs are for 315/240V systems. The standard range of fuses are available from 2-1250A in the following tag forms: Offset Blade - Offset Bolted - Center Bolted. Supplementary ranges cover applications up to 660Vac and 500Vdc including those with nonstandard tag fixings. Bussmann series fuses are manufactured under quality systems independently assessed to BS 5750 (ISO 9002) and appropriate ratings carry the ASTA 20 endorsement. Selecting fuses is relatively simple and effective. The following notes cover the majority of applications. For further information contact our Application Engineers toll free at: 855-287-7626 (855-BUSSMANN). Circuit loading The current rating of the fuse should not be less than the full load current of the circuit. The circuit should be so designed that small overloads of long duration will not be of frequent occurrence. Cable ratings and protection There is an increasing move away from 70°C PVC insulation to materials that are more environmentally friendly, for example 90°C XLPE. The ratings of fusegear, switches, accessories, etc. are generally based upon the equipment being connected to conductors intended to be operated at a temperature not exceeding 70°C in normal service. In view of the above, it is recommended that the practice of designs based upon conductor temperatures of 70°C be regarded as the norm. The equipment manufacturer should be consulted to ascertain the reduction of nominal current rating of the equipment if conductor temperatures exceeding 70°C are used. In addition, an overriding factor is often voltage drop. In motor circuits, the motor starter will provide the overload protection and the fuses will provide the short-circuit protection. The maximum fuse size that can be used depends upon the type of cable used and is determined using the appropriate K factor. The following table gives the maximum sizes of fuses that are recommended for two popular cables with copper conductors, 70°C PVC (K = 115) and 90°C thermosetting (K = 143). BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-1 IEC and British Standard fuses Fuses with gG characteristics protect associated cables against both overload and short-circuit current, provided that the current rating of the fuse 1N is equal or less than the current carrying capacity of the cable 1z. 7 Cable size (mm2) 1 1.5 2.5 4 6 10 16 25 35 50 70 95 120 IEC and British Standard fuses Application data for BS low voltage fuses Capacitor circuits Max. fuse rating (amps) K = 115 K = 143 16 16 20 25* 32* 32* 50* 50* 63* 63* 100* 125* 125* 160* 200* 250* 315* 355* 400* 500 560 630 710 800 800 1000 For power factor correction in capacitor circuits, the fuse should be chosen with a current rating greater than 1.5 times the rated capacitor current. This takes into account the high inrush current, circuit harmonics and capacitor tolerances. Motor circuits In motor circuits, the fuse has to withstand the motor's starting current and often requires a higher rating than the motor's full load current. Coordination recommendations are made by the manufacturers of motor starters in accordance with IEC 60947-4-1. To get Type 2 coordination with fuses, tests are performed with the latest gG or gM fuses to BS 88 or IEC 60269 that have pre-arcing I2t values towards the bottom of specified limits. This means that Bussmann series fuses are suitable to provide Type 2 coordination. * Extended Motor Circuit dual ratings can be used. Protection against electrical shock For a TN System, a disconnecting time not exceeding 5s is permitted for a distribution circuit. The maximum values of earth fault loop impedance (Zs) of 240V for Bussmann series gG fuses to BS 88: Parts 2 and 6 are: Extended dual ratings of motor circuit protection fuses with gM characteristics are available in most popular fuse sizes to extend the use of associated equipment with appropriate economies. In the majority of applications, gG fuses are used. It is not essential to use gM fuses for motor circuit protection, they simply extend the utilization of standard equipment. Rating (A) Zs (Ohms) Rating (A) Zs (Ohms) Rating (A) Zs (Ohms) 6 14 50 1.1 250 0.16 7.7 63 0.86 315 0.13 10 4.3 80 0.60 400 0.096 16 3.0 100 0.44 500 0.073 20 25 2.4 125 0.35 630 0.054 1.9 160 0.27 800 0.044 32 40 1.4 200 0.20 Below is a table of recommended fuses at 415V. In most applications, the run-up time is less than 5 seconds and duty is infrequent - no more than twice per hour. The next larger rating should be used for more demanding applications. Ambient temperature The derating, in terms of current, of 0.5% per °C above an ambient of 35°C is recommended. Interrupting rating The standardized interrupting rating values are 80kA for voltages of 415Vac and above, and 40kA for DC applications. The 240Vac designs have an interrupting rating of 50kA. Coordination ratio All fuses to BS 88 Parts 2 and 6 will give a coordination ratio of 2:1; and for most practical situations a ratio of 1.6:1 (two steps in the R10 series). Example: an upstream fuse rated at 160A will coordinate with a downstream fuse rated at 100A. Current and energy limitation The range of fuses have pre-arcing I2t values towards the bottom limits of BS 88 Parts 2 and 6. This ensures excellent current and energy limitation. They also have lower power losses at rated current. This assists in the appropriate interchangeability with other makes of fuses. Transformers When fuses are used on the primary side of transformers, the normal fuse current rating should be at least twice the nominal transformer primary current. Fluorescent lighting The normal fuse current rating should be at least twice the normal full load current of the maximum number of lights to be simultaneously switched. 7-2 BUSSMANN SERIES FULL LINE CATALOG kW 0.25 0.37 0.55 0.75 1.1 1.5 2.2 3.0 4.0 5.5 7.5 11.0 15.0 18.5 22.0 30.0 37.0 45.0 55.0 75.0 90.0 110.0 132.0 150.0 185.0 200.0 225.0 250.0 280.0 335.0 355.0 1007—July 2015 Rating motor A 0.8 1.1 1.5 2.0 30 3.6 5.0 6.5 8.4 11.0 15.0 20.0 27.0 33.0 38.0 54.0 66.0 79.0 98.0 135.0 155.0 185.0 220.0 250.0 310.0 335.0 375.0 415.0 460.0 562.0 596.0 Eaton.com/bussmannseries Direct on-line Standard Motor circuit (gG) (gM) A A 4 4 6 6 10 16 16 20 20 25 20M25 40 32M40 50 32M50 63 32M63 80 63M80 80 63M80 100 63M100 125 100M125 160 100M160 160 100M160 250 200M250 250 200M250 315 200M315 355 315M400 355 315M400 450 400M500 500 400M500 560 560 630 710 800 - Asst. start standard (gG) A 2 2 4 4 6 01 01 61 61 2 20 25 32 40 50 50 80 80 100 100 160 160 200 250 315 355 400 400 450 500 630 710 IEC and British Standard fuses 7 CSA Type P and Type D fuses CDS, CDN and PON Type P and D Specifications Description: CSA time-delay Type D and P fuses. Dimensions: See catalog numbers table and dimensions illustration. Ratings: Volts: — 250Vac (CDN and PON) — 600Vac (CDS) Amps: — 10-600A IR: — 10kA minimum Agency information: CE, CSA Certified to C22.2 No. 59.1. Features and benefits • Economical fuse in a variety of ratings for applications not requiring time-delay. Typical applications • Lighting, heating and other circuits not subject to temporary surges and where available short-circuit current are relatively low. Basic catalog numbers Time-Delay CSA Type “D” fuses Catalog numbers Volts CDN* 250Vac CDS** 600Vac Amp ratings 10, 12, 15, 20, 25, 30, 35, 40, 45, 50, 60, 70, 80, 90, 100, 110, 125, 150, 175, 200, 225, 250, 300, 350, 400, 450, 500, 600 10, 12, 15, 20, 25, 30, 35, 40, 45, 50, 60, 70, 80, 90, 100, 110, 125, 150,175, 200, 225, 250, 300, 350, 400, 450, 500, 600 * Below 10 amps, use FRN-R. ** Below 10 amps, use FRS-R. Volts 250Vac To order, specify basic catalog number and amp rating. Dimensions - in (mm) CDN/PON 250Vac CDS 600Vac Ferrule: 1 to 60A C A D F E Knifeblade: 70 to 600A A Overall 2.0 (50.8) 3.0 (76.2) 5.88 (149.4) 7.3 (185.4) 8.63 (219.2) 10.38 (263.7) 5.0 (127.0) 5.5 (139.7) 7.88 (200.2) 9.63 (244.6) 11.63 (295.4) 13.38 (339.9) B Max Diameter 0.56 (14.3) 0.81 (20.6) — — — — 0.81 (20.6) 1.06 (27.0) — — — — 2-pole Fuse 250V 600V 250V 600V 1-30A HM25030-1 HM60030-1 HM25030-2 HM60030-2 35-60A HM25060-1 HM60060-1 HM25060-2 HM60060-2 70-100 HM25100-1 HM60100-1 HM25100-2 HM60100-2 110-200 HM25200-1 HM60200-1 HM25200-2 HM60200-2 225-400 HM25400-1 HM60400-1 HM25400-2 HM60400-2 450-600 HM25600-1 HM60600-1 HM25600-2 HM60600-2 See data sheets 100289 (30-60A) and 3192 (70-600A) for terminal C Min Blade length — — 1.0 (25.4) 1.38 (34.9) 1.88 (47.6) 2.25 (57.2) — — 1.0 (25.4) 1.38 (34.9) 1.88 (47.6) 2.25 (57.2) D Min Barrel length — — — 4.13 (104.8) 4.63 (117.5) 5.19 (131.8) — — — 6.13 (115.6) 7.13 (118.1) 8.19 (208.0) E Blade thickness — — 0.13 (3.2) 0.19 (4.8) 0.25 (6.4) 0.25 (6.4) — — 0.13 (3.2) 0.19 (4.8) 0.25 (6.4) 0.25 (6.4) 3-pole 250V HM25030-3 HM25060-3 HM25100-3 HM25200-3 HM25400-3 HM25600-3 options. 600V HM60030-3 HM60060-3 HM60100-3 HM60200-3 HM60400-3 HM60600-3 F Blade width — — 0.75 (19.1) 1.13 (28.6) 1.63 (41.3) 2 (50.8) — — 0.75 (19.1) 1.13 (28.6) 1.63 (41.3) 2 (50.8) Data Sheet: 4126 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-3 IEC and British Standard fuses Example: CDN-30, CDS-110 or PON-40. Amp rating 1-30 35-60 70-100 110-200 225-400 450-600 1-30 35-60 70-100 110-200 225-400 450-600 B 1-pole Amp ratings 15, 20, 25, 30, 35, 40, 45, 50, 60 To Order Catalog symbol and volts A Recommended fuse blocks One-time CSA Type “P” fuses Catalog number PON D Dimensions IEC and British Standard fuses 7 Tron™ HRC Form II Class C fuses Dimensions - in (mm) CGL Form II Class C Specifications Description: Current-limiting HRCII-C fuses designed to withstand inrush currents on typical motor start-ups while offering high current limitation in the short-circuit region. Dimensions: See dimensions illustrations. Ratings: Volts: — 600Vac 250Vdc (1-30A) Amps: — 1-600A IR: — 200kA 40kA DC Agency information: CE, CSA Certified, C22.2 No. 106, Class 1422,File 53787. Features and benefits • Close sizing to loads allows using smaller and less costly switches • Provides a higher degree of short-circuit protection • Helps protect motors against burnout from overloads Typical applications • For use in circuits subject to surge currents such as those caused by motors, transformers and other inductive loads 0.22 0.81 0.22 (20.57) (5.56) (5.56) 2.0 0.06 (1.59) 0.34 (50.8) 2.80 0.94 (8.73) (71.04) (23.81) 3.31 (84.14) CGL 1-30 0.22 0.81 0.22 (20.64) (5.56) (5.56) 2.0 0.06 0.50 (50.8) 2.80 (1.59) 1.06 (12.7) (71.04) (26.92) 3.5 (88.9) CGL 35-60 1.34 0.343 0.343 (34.04) (8.71) (8.71) 2.39 (60.72) 3.64 0.09 (2.29) 0.75 1.375 (19.05) (34.93) (92.47) 4.31 (109.54) CGL 70-100 0.343 0.343 (8.71) (8.71) Catalog numbers (-amps) CGL-1 CGL-2 CGL-3 CGL-4 CGL-6 CGL-10 CGL-15 CGL-20 CGL-25 CGL-30 CGL-35 CGL-40 CGL-45 CGL-50 CGL-60 CGL-70 CGL-80 CGL-90 CGL-100 CGL-110 CGL-125 CGL-150 CGL-175 CGL-200 CGL-225 CGL-250 CGL-300 CGL-350 CGL-400 CGL-450 CGL-500 CGL-600 3.00 (38.1) 5.31 (134.87) CGL 110-200 0.19 0.38 1.0 (9.53) (4.76) (25.4) 1.0 Available Red Spot fuse holders 3.0 (25.4) 2.38 (76.2) (60.33) 5.25 (133.35) 8.19 (207.96) CGL 225-400 1.0 0.41 (25.4) (10.32) 1.0 (25.4) 3.0 (76.2) 5.25 (133.35) 8.19 (207.96) CGL 450-600 Data Sheet: 4125 BUSSMANN SERIES FULL LINE CATALOG (3.18) 1.50 (19.05) (109.22) Fuse amps Catalog symbol 1-32 RS32_ 35-60 RS63_ 70-100 RS100_ 110-200 RS200_ 225-400 RS400_ See Red Spot data sheet No. 10083 for details. 7-4 0.125 0.75 (76.2) 4.30 1007—July 2015 Eaton.com/bussmannseries 0.60 (15.24) 0.375 (9.53) 3.00 (76.2) IEC and British Standard fuses 7 HRCI industrial ceramic body fuses CIF21 HRCI-CA CIF06 HRCI-CB Specifications Description: The HRCI-CA fuse provides both overload and short-circuit protection to HRCI requirements. Offset blades for bolt-on mounting. CIF21 fuse fits the Bussmann series Rep Spot fuse holder (data sheet 10083) and CAMaster fuse holder (data sheet 4132). Dimensions: See dimensions illustration. Construction: Ceramic body. Ratings: Volts: — 600Vac 250Vdc Amps: — 1-30A IR: — 200kA RMS Sym. Agency information: CE, CSA C22.2, No. 106-M92. Mounting: Bolt-on. Specifications Description: A miniature industrial fuse that provides both short-circuit and overload protection and the CIF06 fits the 30A SAFEloc fuse holder (data sheet 4133). Dimensions: See dimensions illustration. Construction: Ground ceramic body with plated end caps. Ratings: Volts: — 600Vac 250Vdc Amps: — 1-30A IR: — 200kA RMS Sym. Agency information: CE, CSA C22.2 No. 106-M92 (3-30A only). Mounting: Clip-in offset blades. Catalog numbers Catalog number 1CIF21 3CIF21 6CIF21 10CIF21 15CIF21 20CIF21 25CIF21 30CIF21 Catalog numbers Catalog number 1CIF06 3CIF06 6CIF06 10CIF06 15CIF06 20CIF06 25CIF06 30CIF06 Amp rating 1 3 6 10 15 20 25 30 Features and benefits • Close sizing to loads allows using smaller and less costly switches • Provides a higher degree of short-circuit protection • Helps protect motors against burnout from overloads Typical applications • For use in circuits subject to surge currents such as those caused by motors, transformers and other inductive loads Amp rating 1 3 6 10 15 20 25 30 Features and benefits • Close sizing to loads allows using smaller and less costly switches • Provides a higher degree of short-circuit protection • Helps protect motors against burnout from overloads Typical applications • For use in circuits subject to surge currents such as those caused by motors, transformers and other inductive loads Dimensions - in (mm) 2.15 (54.5) 1.44 (35.5) 0.19 (4.7) 0.54 (13.8) 0.44 (11.1) 1.75 (44.5) Recommended fuse holders Red Spot P/N RS20_(1-20A) CAMaster P/N CM20CF (1-30A) Data Sheet: 4127 0.03 (0.81) IEC and British Standard fuses 2.38 (60.4) 1.44 (35.5) Dimensions - in (mm) 0.5 (12.7) 0.54 (13.8) 0.03 (3.5) 0.14 (3.5) Recommended fuse holders SAFEloc P/N C30_ Data Sheet: 4128 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-5 IEC and British Standard fuses 7 HRCI-J fast-acting fuses Dimensions CJ HRCI-J Specifications Description: HRCI-J fast-acting fuses are industrial duty fuses with the excellent current-limiting characteristics of fast-acting HRCI-J fuses to limit damage to equipment and installations by the thermal and magnetic energy associated with a large short-circuit fault current. Overload characteristics limit cable damage due to low overload currents. Dimensions: See catalog numbers table and dimensions illustrations. Construction: Ceramic body fuse. Ratings: Volts: — 600Vac (or less) 250Vdc Amps: — 1-600A IR: — 200kA Agency information: CSA C22.2 No. 106 M92; designed to BS 88:2, IEC 60269-2. C 70CJ to 600CJ A B 1CJ to 60CJ E C D B A K J F B H G Catalog numbers Catalog numbers Catalog number 1CJ 3CJ 6CJ 10CJ 15CJ 20CJ 25CJ 30CJ 35CJ 40CJ 45CJ 50CJ 60CJ 70CJ 80CJ 90CJ 100CJ 110CJ 125CJ 150CJ 175CJ 200CJ 225CJ 250CJ 300CJ 350CJ 400CJ 450CJ 500CJ 600CJ Amp rating 1 3 6 10 15 20 25 30 35 40 45 50 60 70 80 90 100 110 125 150 175 200 225 250 300 350 400 450 500 600 A B C D Dimensions - in (mm) E F G H J K 2.25 (57) 0.5 (12.7) 0.81 (20.6) — — — — — — — 2.38 (60) 0.63 (16) 1.06 (27) — — — — — — — 4.63 (117) 3.63 (92) 1.13 (28) 0.75 (19) 0.13 (3.2) 1 (25.4) 0.5 (12.7) 0.28 (7.1) 0.38 (9.5) 2.63 (67) 5.75 (146) 4.38 (111) 1.63 (41) 1.13 (28.6) 0.19 (4.8) 1.38 (35) 0.69 (17.5) 0.28 (7.1) 0.38 (9.5) 3 (76) 7.13 (181) 5.25 (133) 2.13 (54) 1.63 (41) 0.25 (6.3) 1.88 (47.6) 0.94 (24) 0.41 (10.3) 0.53 (13.5) 3.38 (86) 8 (203) 6 (152) 2.63 (66) 2 (51) 0.38 (9.5) 2.13 (54) 1 (25.4) 0.53 (13.5) 0.69 (17.5) 3.75 (96) Data Sheet: 4129 7-6 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries IEC and British Standard fuses 7 HRCI - miscellaneous Type K fuses CIH, CIK and CIL HRCI-MISC Specifications Description: HRI fuses provide both overload and short-circuit protection, featuring offset blades for bolt down mounting. Dimensions: See catalog numbers table and Dimensions illustration. Construction: Ceramic body. Ratings: Volts: — 600V Amps: — 1-100A IR: — 200kA@600V Agency information: CE, CSA C22.2 No. 106 M92. Dimensions K D F A L C G J E G H B (The CIL14 has a rejection hole, not a slot as shown above.) Catalog numbers A Max 2.25 (57) B Max 0.94 (24) C Max 3.38 (86) D Nom 0.38 (9.2) Dimensions - in (mm) E Nom F Nom G Nom 0.04 (1.0) 2.88 (73) 0.21 (5.2) 2.25 (57) 0.94 (24) 3.38 (86) 0.38 (9.2) 0.04 (1.0) 2.28 (58) 1.06 (27) 3.56 (91) 3.56 (91) 0.5 (12.7) 0.05 (1.2) 2.88 (73) 2.75 (70) 2.75 (70) 1.44 (37) 1.44 (37) 4.38 (111) 4.38 (111) 0.75 (19) 0.75 (19) 0.09 (2.5) 0.09 (2.5) 3.69 (94) 3.69 (94) 2.28 (58) 1.06 (27) 0.5 (12.7) 0.05 (1.2) H Nom 0.31 (8) J Max 1 (25.4) K Nom 0.10 (2.6) L Max 2.38 (60) 1 (25.4) 0.10 (2.6) 2.38 (60) 2.88 (73) 0.21 (5.2) 0.31 (8) 2.88 (73) 0.21 (5.2) 0.41 (10.5) 0.41 (10.5) 1.09 (28) 0.13 (3.2) 0.13 (3.2) 2.38 (61) 0.34 (8.7) 0.34 (8.7) 0.41 (10.5) 0.41 (10.5) 1.5 (38.5) 1.5 (38.5) — 2.91 (74) 2.91 (74) 0.21 (5.2) 1.09 (28) — 2.38 (61) Recommended fuse holders Fuse Red Spot holder 1-30A RS32_ 35-60A RS63_ 80-100 RS100_ See data sheets 10083 (Red Spot) and CAMaster holder CM30CF CM60CF — 4132 (CAMaster). Data Sheet: 4130 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-7 Standard fuses Catalog Amp numbers ratings 1CIH07 1 3CIH07 3 6CIH07 6 10CIH07 10 15CIH07 15 20CIH07 20 25CIH07 25 30CIH07 30 35CIK07 35 40CIK07 40 50CIK07 50 60CIK07 60 80CIL14 80 90CIL14 90 100CIL14 100 IEC and British Standard fuses 7 HRC Form II current-limiting fuses Dimensions HRC Form II F G Specifications Description: HRC Form II current-limiting fuses. Dimensions: See catalog numbers table and dimensions illustrations. Construction: Ceramic body. Ratings: Volts: — 600Vac (or less) — 250Vdc Amps: — 2-600A IR: — 200kA RMS Sym. Agency information: CE, CSA C22.2 No.106_M92; BS 88:2, IEC 60269:2. A H F H C D J B F K B D L09C/M09C/P09C (Center blades) E K F C K07C/K07CR/ L14C/M14C (Offset blades) B A G H07C (Offset blades) J E C A H G E C A G Typical applications • Used to protect motor control circuits, together with contactors and overload protection relays to provide Type 2 coordination - per IEC 60947-4. D B D H P11C/R11C (Center blades) E Catalog numbers Catalog Amp number rating 2H07C 2 4H07C 4 6H07C 6 10H07C 10 15H07C 15 20H07C 20 25H07C 25 30H07C 30 40K07C 40 50K07C 50 60K07C 60 80K07CR 80 100K07CR 100 80L14C 80 100L14C 100 125M14C* 125 150M14C* 150 200M14C* 200 80L09C* 80 100L09C* 100 125M09C 125 150M09C 150 200M09C 200 250P09C* 250 300P09C* 300 350P09C* 350 400P09C* 400 250P11C 250 300P11C 300 350P11C 350 400P11C 400 450R11C 450 500R11C 500 600R11C 600 A 1.38 (35) 1.38 (35) 2.19 (56) 2.19 (56) 2.19 (56) B 0.56 (14) 0.56 (14) 0.88 (22) 0.88 (22) 0.88 (22) C 3.38 (85) 3.38 (85) 0.38 (9) 3.44 (87) 3.44 (87) 0.5 (13) 4.38 (111) 0.56 (14.3) (14.3) 0.56 3.75 3.75(95) (95) 0.5 (13) 0.5 (13) 2.38 2.38 (60) (60) 0.88 (21.4) (21.4) 0.88 2.38 2.38 (60) (60) 0.88 (21.4) (21.4) 0.88 3.06 (178) 2.31 (59) 5.38 (136) 1 (25.4) 3.06 (178) 3.06 (178) 2.31 (59) 2.31 (59) 8.25 (210) 3.19 (81) 3.19 (81) 2.88 (73) 2.88 (73) 2.56 (65) 2.56 (65) 2.56 (65) 2.56 (65) 1.5 (38) 1.5 (38) 1.5 (38) 1.5 (38) Dimensions - in (mm) E F 0.06 (1.2) 2.88 (73) D 0.38 (9) 4.38 (111) 5 5(127) (127) 5.38 (136) 8.25 (210) 8.25 (210) 0.75 (19) 0.75 (19) 0.56 0.56 (14) (14) 0.75 (19) 0.75 (19) 0.06 (1.2) H 0.31 (8) 0.31 (8) 0.06 (1.2) 2.88 (73) 2.88 (73) 0.22 (5.6) 0.22 (5.6) 0.31 (8) 0.06 (1.2) 2.88 (73) 0.22 (5.6) 0.31 (8) 0.09 (2.4) 0.09 (2.4) 3.69 (94) 0.34 (8.7) 0.44 (11) 0.44 (11) 0.13 (3.2) (3.2) 0.13 0.13 (3.2) 0.13 0.13 (3.2) (3.2) 3.69 (94) 4.38 (111) 4.38 (111) 0.19 (4.8) 4.38 (111) 4.38 (111) 1 (25.4) 1 (25.4) 0.19 (5) 5.25 (133) 1 (25.4) 0.25 (6.3) 0.25 (6.3) 5.25 (133) 5.25 (133) * Not suitable for installation in Red Spot fuse holders. G 0.22 (5.6) 0.19 (4.8) 0.19 (5) 0.34 (8.7) 0.34 (8.7) 0.34 (8.7) 0.34 (8.7) 0.34 (8.7) 0.44 (11) 0.44 (11) 0.56 (14) 0.56 (14) J K 0.56 (14) — 0.56 (14) — HRCII-C 0.88 (22) — — 0.88 (22) 0.88 (22) — — HRCII-MISC HRCII-MISC — HRCII-MISC 11 (25.4) (25.4) — —— — 0.5 (13) — 0.41 (10) 0.63 (16) — 0.41 (10) 0.41 (10) 0.63 (16) 0.63 (16) — 0.5 (13) CSA category HRCII-C — — — — — — — — —— — — — — 1 (25) 1 (25) 1 (25) 1 (25) HRCII-C HRCII-C HRCII-C HRCII-MISC HRCII-MISC HRCII-C HRCII-C HRCII-MISC HRCII-MISC HRCII-C HRCII-C HRCII-C Recommended fuse holders: Red Spot up to 400A (data sheet 10083) and CAMaster up to 100A (data sheet 4132). Data Sheet: 4131 7-8 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries IEC and British Standard fuses 7 BS 88 British Standard low voltage fuses SSD, NSD, ESD BS 88 Part 1 STD, NITD, AAO, BAO, OSD, CEO, DEO BS 88 Part 1 Specifications Description: The NSD and ESD are low voltage fuses complying with general purpose gG characteristics. Construction: Ceramic body. Ratings: Volts: — 240-550Vac (see catalog numbers table) Amps: — 2-63A (see catalog numbers table) — 20M25-63M100A motor starter ratings (see catalog numbers table) IR: — 33kA (SSD) — 80kA (NSD, ESD) Agency information: CE, meets the requirements of BS 88 Part 1 and IEC 60269-1. Mounting: Offset blades. Specifications Description: The STD to DEO types are low voltage fuses complying with general purpose gG characteristics. Construction: Ceramic body. Ratings: Volts: — 240-550Vac (see catalog numbers table) Amps: — 2-200A (see catalog numbers table) — 20M25-200M315A motor starter ratings (see catalog numbers table) IR: — 33kA (STD) — 80kA (NITD, AAO, BAO, CEO, DEO, OSD) Agency information: CE, meets the requirements of BS 88 Part 1 and IEC 60269-1. Mounting: Offset bolted blades. Basic catalog numbers Basic catalog Amp numbers ratings SSD 2, 4, 6, 10, 16, 20, 25, 32 2, 4, 6, 10, 16, 20, 25, 32, NSD 20M25*, 20M32*, 20M36*, 32M36*, 32M40*, 32M50*, 32M63* 2, 4, 6, 10, 16, 20, 25, 32, 40, 50, 63, ESD 63M80, 63M100* *“M” indicates motor starter ratings. Max AC voltage ratings 240 550 BS 88 ref. E1 F1 550 415 F2 F2 415 To order F1 To order, specify basic catalog number and amp rating. Example: SSD-20 Basic catalog numbers Basic catalog numbers STD NITD AAO BAO Recommended fuse holders Basic fuse catalog number NSD ESD Typical applications • The STD type are used in 240V street lighting cut-outs • NITD to DEO types used for industrial and general purpose applications CEO Holder catalog numbers 32NNSF 63ENSF DEO OSD Amp ratings 2, 4, 6, 10, 16, 20, 25, 32 2, 4, 6, 10, 16, 20, 25, 32 20M25*, 20M32*, 32M40*, 32M50*, 32M63* 2, 4, 6, 10, 16, 20, 25, 32, 32M40*, 32M50*, 32M63* 40, 50, 63, 63M80*, 63M100* 32, 40, 50, 63, 80, 100 100M125*, 100M160*, 100M200* 125, 160, 200, 200M315* 80, 100 100M125*, 100M160* *“M” indicates motor starter ratings. Max AC voltage BS 88 ratings ref. 240 — 550 — 415 550 — 500 500 A3 550 A4 415 415 — 500 — 415 To order To order, specify basic catalog number and amp rating. Example: BAO-16 Data Sheets 4105 (SSD), 4100 (NSD) and 4101 (ESD) IEC and British Standard fuses Recommended fuse blocks and holders Basic fuse catalog numbers NITD AAO BAO OSD CEO Block/holder catalog numbers CM32FC, RS20_ CM32F, RS32_ CM63F, RS63_ CM100F, RS100_ BH-0111 Data Sheets 4123 (STD), 4106 (NITD), 4109 (AAO), 4112 (BAO), 4107 (OSD), 4115 (CEO) and 4117 (DEO) BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-9 IEC and British Standard fuses 7 BS 88 British Standard low voltage fuses AC, AD, BC, BD, CD, DD, ED, EFS BS 88 EF, FF, FG, GF, GG, GH BS 88 Specifications Description: Low voltage fuses that comply with general purpose gG characteristics and available up to 400A with two hole mount and up to 1250A with four hole mount. Construction: Ceramic body. Ratings: Volts: — 415/550Vac, 250Vdc (see catalog numbers table) Amps: — 2-400A (see catalog numbers table) — 63M80-400M500A motor starter ratings (see catalog numbers table) IR: — See catalog numbers table Agency information: CE, meets the requirements of BS 88 Parts 1 and 2 and IEC 60269-1. Mounting: Center bolted blades, two-hole mount. Specifications Description: Low voltage fuses complying with general purpose gG characteristics and available up to 400A with two hole mount and up to 1250A with four hole mount. Construction: Ceramic body. Ratings: Volts: — 415/690Vac, 250/400Vdc (see catalog numbers table for details) Amps: — 355-1250 IR: — see catalog numbers table Agency information: CE, meets the requirements of BS 88 Parts 1 and 2 and IEC269-1. Mounting: Center bolted blades, four-hole mount. Basic catalog numbers Basic catalog numbers Basic catalog numbers AC AD BC BD CD DD ED EFS Amp ratings 2, 4, 6, 10, 16, 20 25, 32 2, 4, 6, 10, 16, 20 25, 32 40, 50, 63 63M80*, 63M100* 40, 50, 63 80, 100, 100M125*, 100M160*, 100M200*, 100M200* 125, 160, 200, 200M250*, 200M315* 250, 315, 355, 400, 315M400* 400M500* 125, 160, 200, 250, 315 *“M” indicates motor starter ratings. Interrupting ratings (kA) AC DC 80 40 80 — 80 40 80 — 8 40 80 — 80 40 80 — 80 80 80 80 — — — Max voltage ratings BS 88 AC DC ref. 550 250 — 500 — 550 250 — 500 — 500 250 — 500 — 500 250 — 500 — B1 415 — 415 415 415 — Basic catalog numbers EF Interrupting Max voltage Amp ratings (kA) ratings BS 88 ratings AC DC AC DC ref. 355, 400 80 — 415 — C1 400M500* 80 — 550 — FF 450, 500, 560, 630 80 40 690 400 C2 FG 450, 500, 560, 630 80 40 550 400 — GF 710, 800 80 40 550 250 C3 GG 710, 800, 1000, 1250 80 — 550 — — GH 710, 800, 1000, 1250 80 — 550 — — *“M” indicates motor starter ratings.*“M” indicates motor starter ratings. To order To order, specify basic catalog number and amp rating. Example: FG-450 B2 — B4 — — To order To order, specify basic catalog number and amp rating. Example: BC-40 Recommended fuse blocks and holder Basic fuse catalog numbers AC AD BC BD CD DD ED Block/holder catalog numbers BH-0111 Modular fuse block BH-____ Modular fuse block BH-0111 Modular fuse block BH-____ Modular fuse block BH-____ Modular fuse block BH-____ Modular fuse block BH-1131 Modular fuse block Data Sheets 4110 (AC), 4111 (AD), 4113 (BC), 4114 (BD), 4116 (CD), 4118 (DD), 4119 (ED) and 4121 (EFS) 7-10 BUSSMANN SERIES FULL LINE CATALOG Data Sheets 4120 (EF), 4102 (FF), 4122 (FG), 4103 (GF), 4104 (GG) and 4108 (GH) 1007—July 2015 Eaton.com/bussmannseries IEC and British Standard fuses DIN Style Type D and Neozed low voltage fuses D16, D27, D33, D125 Type D NZ01, NZ02 Type D0 Specifications Description: DIN style Type D low voltage fuses. Dimensions: See catalog numbers table and dimensions illustrations. Construction: Ceramic body. Ratings: Volts: — 500Vac Amps: — 2-100A IR: — 50kA Agency information: CE, “D” type fuses complying with DIN 49360 Part 2 and DIN 49515, operating class gL. Catalog numbers Catalog numbers 2D16 4D16 6D16 10D16 16D16 20D16 25D16 2D27 4D27 6D27 10D27 16D27 20D27 25D27 35D33 50D33 63D33 80D125 100D125 Amp ratings 2 4 6 10 16 20 25 2 4 6 10 16 20 25 35 50 63 80 100 Dimension “D” (mm) 6 6 6 8 10 12 14 6 6 6 8 10 12 14 16 18 20 5 7 Color code Pink Brown Green Red Grey Blue Yellow Pink Brown Green Red Grey Blue Yellow Black White Copper Silver Red 7 Figure number 1 2 Specifications Description: Low voltage Neozed fuses suitable for use on 250Vdc systems. Dimensions: See catalog numbers table and dimensions illustration. Construction: Ceramic body. Ratings: Volts: — 400Vac Amps: — 2-63A IR: — 50kA Agency information: CE Catalog numbers Catalog numbers 2NZ01 4NZ01 6NZ01 10NZ01 16NZ01 20NZ02 25NZ02 35NZ02 50NZ02 63NZ02 Amp ratings 2 4 6 10 16 20 25 35 50 63 Dimension “D” (mm) 11 11 11 11 11 15 15 15 15 15 Color code Pink Brown Green Red Grey Blue Yellow Black White Copper Dimensions - mm D 3 4 36 Additional fuse links: Quick acting fuselinks in body sized D16, D27, D33 and D125 rated 2-100A. Reference number suffixed Q, i.e. 10D27Q. Voltage rating 500V. Gauge rings and keys can also be supplied. Dimensions - mm IEC and British Standard fuses Figure 1 Figure 2 Data Sheet: 4124 Figure 3 Figure 4 Data Sheet: 4124 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-11 IEC and British Standard fuses 7 NH HRC fuses Volts: — 500Vac — 690Vac Amps: — 2-1250A IR: — 120kA Frequency: — 50Hz Operating frequency: — 45-62Hz Agency information: IEC 60269, VDE 0636, DIN 43620 Part 1 to 4, VDE Mark and CE. Ratings: ___NHG___B Specifications Class: gG/gL Description: DIN square bodied, dual indication industrial fuses. Construction: Steatite insulator, corrosionproof (aluminum) metal parts with full-contact, silver-plated copper blades. Sizes: DIN 000 to 4. Selectivity ratio: 1:1.6 up to 500Vac. Fuse blocks SD00-D SD1-D SD2-D Size 000-00 1*, 1 02, 2, 03, 3 Dimensions - mm Fuse size 000 00 0 01 1 02 2 03 3 4 a1 78.5 ± 1.5 78.5 ± 1.5 125 ± 2.5 135 ± 2.5 135 ± 2.5 150 ± 2.5 150 ± 2.5 150 ± 3 150 ± 3 200 a2 (max) 54 54 68 75 75 75 75 75 75 84 45 45 62 62 62 62 62 62 62 80 a3 ± 1.5 ± 1.5 +3/-1.5 ± 2.5 ± 2.5 ± 2.5 ± 2.5 ± 2.5 ± 2.5 a4 49 ± 1.5 49 ± 1.5 68 +1.5/-3 68 ± 2.5 68 ± 2.5 68 ± 2.5 68 ± 2.5 68 ± 2.5 68 ± 2.5 90 b (nom) 15 15 15 15 20 20 25 25 32 50 c1 (± 8) 35 35 35 40 40 48 48 60 60 85 c2 (nom) 10 11 11 11 11 11 11 11 11 11 D (nom) 2 ± 0.5 7.0 ± 0.5 2.5 ± 0.5 2.5 ± 0.5 2.5 ± 0.5 2.5 ± 0.5 2.5 ± 0.5 2.5 ± 0.5 3.0 ± 0.5 3 e1 (max) 41 48 48 48 53 53 61 61 75 120 Data Sheet 10164 7-12 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries e2 (max) 21 30 30 30 52 52 60 60 70 87 e3 (max) 16 25 25 25 25 25 25 25 25 — e4 (nom) 6 6 6 6 6 6 6 6 6 8 f (max) 8 15 15 15 15 15 15 15 18 30 IEC and British Standard fuses 7 NH HRC fuses 500Vac Size 000 00 0 01 Rated current (amps) gG/gL dual indicator voltage conducting metal gripping lugs Carton quantity 2 4 6 10 16 20 25 32 35 40 50 63 80 100 50 63 80 100 125 160 6 10 16 20 25 32 35 40 50 63 80 100 125 160 6 10 16 20 25 32 35 40 50 63 80 100 125 160 2NHG000B 4NHG000B 6NHG000B 10NHG000B 16NHG000B 20NHG000B 25NHG000B 32NHG000B 35NHG000B 40NHG000B 50NHG000B 63NHG000B 80NHG000B 100NHG000B 50NHG00B 63NHG00B 80NHG00B 100NHG00B 125NHG00B 160NHG00B 6NHG0B 10NHG0B 16NHG0B 20NHG0B 25NHG0B 32NHG0B 35NHG0B 40NHG0B 50NHG0B 63NHG0B 80NHG0B 100NHG0B 125NHG0B 160NHG0B 6NHG01B 10NHG01B 16NHG01B 20NHG01B 25NHG01B 32NHG01B 35NHG01B 40NHG01B 50NHG01B 63NHG01B 80NHG01B 100NHG01B 125NHG01B 160NHG01B 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 500Vac Size Rated current (amps) gG/gL dual indicator voltage conducting metal gripping lugs 50 50NHG1B 63 63NHG1B 80 80NHG1B 100NHG1B 100 125 125NHG1B 1 160 160NHG1B 200NHG1B 200 224NHG1B 224 250 250NHG1B 315 315NHG1B 355 355NHG1B 35NHG02B 35 40 40NHG02B 50 50NHG02B 63 63NHG02B 80NHG02B 80 100 100NHG02B 02 125 125NHG02B 160NHG02B 160 200NHG02B 200 224NHG02B 224 250NHG02B 250 250 250NHG2B 300NHG2B 300 315 315NHG2B 355 355NHG2B 2 400NHG2B 400 425NHG2B 425 450 450NHG2B 500 500NHG2B 250 250NHG03B 315 315NHG03B 03 355 355NHG03B 400 400NHG03B 315 315NHG3B 355 355NHG3B 400 400NHG3B 425 425NHG3B 3 450 450NHG3B 500 500NHG3B 630 630NHG3B 800 800NHG3B 500 500NHG4G 630 630NHG4G 4* 800 800NHG4G 1000 1000NHG4G 1250 1250NHG4G * Size 4 is for a fuse with a single indicator link with slotted end tags. Carton quantity 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 1 1 1 1 1 IEC and British Standard fuses BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-13 IEC and British Standard fuses 7 NH HRC fuses 690Vac Size Rated current (amps) gG/gL dual indicator voltage conducting metal gripping lugs Carton quantity 2 2NHG000B-690 4 4NHG000B-690 6 6NHG000B-690 10 10NHG000B-690 000 16 16NHG000B-690 20 20NHG000B-690 25 25NHG000B-690 32 32NHG000B-690 35 35NHG000B-690 40 40NHG000B-690 50 50NHG000B-690 63 63NHG000B-690 50 50NHG00B-690 00 63 63NHG00B-690 80 80NHG00B-690 100 100NHG00B-690 125 125NHG00B-690 160* 160NHG00B-690 50 50NHG1B-690 63 63NHG1B-690 80 80NHG1B-690 1 100 100NHG1B-690 125 125NHG1B-690 160 160NHG1B-690 200 200NHG1B-690 224 224NHG1B-690 250 250NHG1B-690 200 200NHG2B-690 2 224 224NHG2B-690 250 250NHG2B-690 315 315NHG2B-690 250 250NHG3B-690 315 315NHG3B-690 3 355 355NHG3B-690 400 400NHG3B-690 425 425NHG3B-690 500 500NHG3B-690 4 630 630NHG4B-690 800 800NHG4B-690 * 160 amps rated at 660Vac. ** Size 4 is for a fuse with a single indicator link with slotted end tags. Data Sheet 720109 7-14 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 1 1 IEC and British Standard fuses 7 NH fuse bases Catalog numbers SD*-D, SD*-S Up to 690V / 160 - 1250A sizes 000 to 4 Size Description: NH fuse bases with thermoplastic bodies. DIN-Rail and screw mounting (size 4 screw fix). Range of protection accesories for live parts in order to obtain IP20 protection standard. • Volts: up to 690Vac • Amps: up to 1250A 1 1 1 2 Standards and approvals: IEC 60269, DIN 43620 SD00-D 3 TD00-D 1 SD1-D 3 250A 3 400A 3 1 630A 3 4 Applications: Protection of industrial circuits and electrical apparatus 160A 3 1 Carton Compatible quantity fuse siz e DIN screw 1 00 3 Ratings: Catalog numbers Current (amps ) Poles TD1-D 1 SD2-D 3 TD2-D 1 SD3-D 3 TD3-D 1 01 and 1 02 and 2 03 and 3 3 4 SD4-S (Screw 1250A 000 and 00 connection only) Neutral NH size Amps Catalog number Carton quantity 1 250 SDL-1 3 2 400 SDL-2 3 3 630 SDL-3 3 Fuse extraction handle Size Catalog number Carton quantity C00-3 FEH 1 Protection accessories Current (amps) 00* 0 1 2 3 160A 160A 250A 400A 630A Terminal cover 1 Catalog number CS00* CS0 CS1 CS2 CS3 Catalog numbers Kit description * For single pole only TD00-IP20 Ffor TD00-D fuse base Phase barrier kits TD1-IP20 For TD1-D fuse base TD2-IP20 For TD2-D fuse base TD3-IP20 For TD3-D fuse base SD12-SK For SD1 and SD2 fuse bases SD3-SK For SD3 fuse base Carton quantity 6 6 6 6 6 Catalog number For fuse base SD12-PB SD1 and SD2 SD3-PB SD3 Separator 3 Catalog number BC00* BC0 BC1-2 BC1-2 BC3 Carton quantity 2 2 2 2 2 IEC and British Standard fuses Shroud kits NH Size Kits include 2 phase barriers and 2 ganging links. Data Sheet 720136 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-15 IEC and British Standard fuses 7 Class gG IEC 60269 industrial ferrule fuses 8x31mm, Class gG, 400Vac, 0.5 to 20 A Catalog numbers Without indicator C08G0-5 C08G1 C08G2 C08G4 C08G6 C08G8 With indicator C08G2I C08G4I C08G6I C08G8I C08G10 C08G12 C08G16 C08G20 C08G10I C08G12I C08G16I C08G20I Rated voltage (Vac) 400 Amps 0.5 1 2 4 6 8 Interrupting rating at rated voltage (kA) 20 10 12 16 20 10x38mm, Class gG, 500 and 400Vac, 0.5 to 32 A Catalog numbers Without indicator C10G0-5 C10G1 C10G2 C10G4 C10G6 C10G8 C10G10 C10G12 C10G16 C10G20 C10G25 C10G32 C10G32 - With indicator C10G1I C10G2I C10G4I C10G6I C10G8I C10G10I C10G12I C10G16I C10G20I C10G25I C10G32I C10G321 C10G40I C10G50I Rated voltage (Vac) 500 400 400 500 500 400 Amps 0.5 1 2 4 6 8 10 12 16 20 25 32 32 32 40 50 Interrupting rating at rated voltage (kA) 120 Recommended fuse holder • CHM DIN-Rail* • BMM modular block * Not recommended for use with indicator version. 14x51mm, Class gG, 400, 500 and 690Vac, 1 to 50 A Catalog numbers Without indicator C14G1 C14G2 C14G4 - With indicator C14G1I C14G2I C14G4I - With striker C14G2S C14G4S C14G6 C14G8 C14G10 C14G12 C14G16 C14G20 C14G25 C14G32 C14G40 C14G50 C14G6I C14G8I C14G10I C14G12I C14G16I C14G20I C14G25I C14G32I C14G40I C14G50I C14G6S C14G8S C14G10S C14G12S C14G16S C14G20S C14G25S C14G32S C14G40S C14G50S Rated voltage (Vac) 690 500 690 500 690 500 690 500 690 500 690 500 690 500 690 500 690 500 400 Amps 1 2 4 6 8 10 12 16 20 25 32 40 50 Interrupting rating at rated voltage (kA) Recommended fuse holder 80 120 80 120 80 120 80 120 80 120 80 120 80 120 80 120 80 • CH14 DIN-Rail** 120 Data Sheet 720115 ** Not recommended for use with indicator version, use striker version to acutate optional, external microswitch. D 7-16 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries IEC and British Standard fuses Class gG IEC 60269 industrial ferrule fuses 7 22x58mm, Class gG, 400, 500 and 690Vac, 2 to 125 A Catalog numbers Without indicator C22G2 C22G4 C22G6 C22G8 C22G10 C22G12 C22G16 C22G20 C22G25 C22G32 C22G40 C22G50 C22G63 C22G80 C22G100 C22G125 With indicator C22G2I C22G4I C22G6I C22G8I C22G10I C22G12I C22G16I C22G20I C22G25I C22G32I C22G40I C22G50I C22G63I C22G80I C22G100I C22G125I With striker C22G4S C22G6S C22G8S C22G10S C22G12S C22G16S C22G20S C22G25S C22G32S C22G40S C22G50S C22G63S C22G80S C22G100S C22G125S Rated voltage (Vac) 690 500 400 Amps 2 4 6 8 10 12 16 20 25 32 40 50 63 80 100 125 Interrupting rating at rated voltage (kA) 80 Recommended holder/block • CH22 DIN-Rail* • JM70100 modular block 120 * Not recommended for use with indicator version, use striker version to acutate optional, external microswitch. Data Sheet 720115 Dimensions - mm C D ØA ØE B Catalog symbol C08M C10M C14M C22M ØA 8 10 14.3 22 B 31.5 38 51 58 C 6.3 10 13 16 Indicator/striker D ØE — — — — 8 4 8 4 IEC and British Standard fuses Data Sheet 720115 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-17 IEC and British Standard fuses 7 Class aM IEC 60269 industrial ferrule fuses 8x31mm, Class aM, 400Vac, 1 to 8 A, without indicator Rated voltage (Vac) Catalog numbers C08M1 C08M2 C08M4 C08M6 C08M8 400 Amps Interrupting rating at rated voltage (kA) 1 2 4 6 8 20 10x38mm, Class aM, 500 and 400Vac, 0.25 to 25 A Catalog numbers Without indicator With indicator C10M0-25 C10M0-5 C10M1 C10M2 C10M4 C10M6 C10M8 C10M10 C10M12 C10M16 C10M20 C10M25 C10M1I C10M2I C10M4I C10M6I C10M8I C10M10I C10M12I C10M16I C10M20I C10M25I Rated voltage (Vac) 500 400 Amps 0.25 0.5 1 2 4 6 8 10 12 16 20 25 Interrupting rating at rated voltage (kA) 120 Recommended fuse holder • CHM DIN-Rail* • BMM modular block * Not recommended for use with indicator version. 14x51mm, Class aM, 400, 500 and 690Vac, 0.25 to 50 A Catalog numbers Without indicator With indicator With striker C14M0-25 C14M0.5 C14M1 C14M2 C14M4 C14M6 C14M8 C14M10 C14M12 C14M16 C14M20 C14M25 C14M32 C14M40 C14M50 C14M1I C14M2I C14M4I C14M6I C14M8I C14M10I C14M12I C14M16I C14M20I C14M25I C14M32I C14M40I C14M50I C14M2S C14M4S C14M6S C14M8S C14M10S C14M12S C14M16S C14M20S C14M25S C14M32S C14M40S C14M50S Rated voltage (Vac) 690 500 690 500 690 500 690 500 690 500 690 500 690 500 690 500 690 500 400 Amps 0.25 0.5 1 2 4 6 8 10 12 16 20 25 32 40 50 Interrupting rating at rated voltage (kA) 120 80 80 120 80 120 80 120 80 120 80 120 80 120 80 120 80 120 80 120 ** Not recommended for use with indicator version, use striker version to acutate optional, external microswitch. D Data Sheet 720115 7-18 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Recommended fuse holder Eaton.com/bussmannseries • CH14 DIN-Rail** IEC and British Standard fuses Class aM IEC 60269 industrial ferrule fuses 7 22x58mm, Class aM, 400, 500 and 690Vac, 2 to 125 A Catalog numbers Without indicator With indicator With striker C22M2 C22M4 C22M6 C22M8 C22M10 C22M12 C22M16 C22M20 C22M25 C22M32 C22M40 C22M50 C22M63 C22M80 C22M100 C22M125 C22M2I C22M4I C22M6I C22M8I C22M10I C22M12I C22M16I C22M20I C22M25I C22M32I C22M40I C22M50I C22M63I C22M80I C22M100I C22M125I C22M12S C22M16S C22M20S C22M25S C22M32S C22M40S C22M50S C22M63S C22M80S C22M100S C22M125S Rated voltage (Vac) Amps Interrupting rating at rated voltage (kA) 2 4 6 8 10 12 16 20 25 32 40 50 63 80 100 125 690 500 400 80 Recommended holder/block • CH22 DIN-Rail* • JM70100 modular block 120 * Not recommended for use with indicator version, use striker version to acutate optional, external microswitch. Data Sheet 720115 Dimensions - mm C D ØA ØE B Catalog symbol C08M C10M C14M C22M ØA 8 10 14.3 22 B 31.5 38 51 58 C 6.3 10 13 16 Indicator/striker D ØE — — — — 8 4 8 4 IEC & British Fuses Data Sheet 720115 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries 7-19 IEC and British Standard fuses 7 HRC fuse holders CAMaster SAFEloc Specifications Catalog symbol: See table below. Description: The Bussmann series CAMaster HRC fuse holder features a unique cam-action for easy fuse removal while allowing significantly improved contact pressure between fuse carrier and base contact that enhances electrical performance. A range of lockable safety carriers for the fuse holder (catalog reference: LSC), are available. Ratings: Volts: — 690V Amps: — up to 100A (see catalog number table for details) Agency information: CE, CSA C22.2 No. 39; IEC 269 AND BS 88. Mounting: 35mm DIN-Rail or single screw mounting. Specifications catalog symbol: See table below. Description: The Bussmann series SAFEloc HRC fuse holders (for use with HRCI-CB fuses) provides a positive, stress-free fuse fitting and locks it in position to ensure safe insertion and withdrawal from the base. Base contacts are fully shrouded to help protect against electric shock. Shrouds utilize simple slide/snap action allowing access to the contact terminal screws. Ratings: Volts: — 600V Amps: — 30-60A (see catalog number table for details) Agency information: CE, designed to accommodate the compact range of offset blade fuse to CSA C22.2 No. 106, HRCI-CB. Mounting: 35mm DIN-Rail or single screw mounting. Catalog numbers Catalog numbers CM20CF CM30CF CM60CF CM100CF Amp ratings 30 30 60 100 Details for: HRCI-CA applications HRCII applications Fuse accepted _CIF21 _H07C _K07C _K07CR Accessory catalog numbers for CAMaster units Catalog numbers 20BS 32BS 60/100BS GLP 20LSC 32LSCC 63/100LSC Amp ratings 30 30 60/100 All 30 30 60/100A Details Back stud Ganging link kit Security carrier with clip Fuse holder accepted CM20CF CM30CF CM60/100CF 3-Pole CM20CF CM30CF CM60/100CF Catalog numbers* Catalog Amp numbers ratings Connection C30F Front C30BS 30 Back C30FBS Front-back C60F Front C60BS 60 Back C60FBS Front-back *For use with HRCI-CB fuses. Bussmann series Red Spot fuse holders These versatile CSA Certified and IP20 finger-safe fuse holders for BS88 HRC industrial fuses are available in ratings from 20 to 400 amps. Padlock inserts, warning carriers and fuse adapter accessories enhance safety and application flexibility. See data sheet 10083 for details. 7-20 BUSSMANN SERIES FULL LINE CATALOG 1007—July 2015 Eaton.com/bussmannseries Fuse accepted _CIF06 EK-Amp
C14G40 价格&库存
很抱歉,暂时无法提供与“C14G40”相匹配的价格&库存,您可以联系我们找货
C14G40
  • 1+27.956251+3.62730
  • 10+25.6047910+3.32220
  • 50+23.7758850+3.08490
库存:10
