CH141DU
CH141DU
    EATON(伊顿)
    保险丝 支座 50 A 700V 1 电路 盒 DIN 轨道
CH141DU 数据手册
DATASHEET - 1P 14X51 FUSE HOLDER Fuse-holder, low voltage, 50 A, AC 690 V, 14 x 51 mm, 1P, IEC General specifications Part no.      1P 14x51 Fuse Holder CH141DU       Product name     Eaton Bussmann series low voltage cylindrical fuse holder Part no.     1P 14x51 Fuse Holder EAN     5027590496667 Product Length/Depth     76 millimetre Product height     92 millimetre Product width     27 millimetre Product weight     86 gram Compliances     RoHS Compliant CE Marked Certifications     IEC 60269-2 EAC UL Listed File E14853 IEC 60269-1 Product Tradename     None Product Type     Low voltage cylindrical fuse holder Product Sub Type     None       Amperage Rating     50 A Voltage rating at AC     690 V a.c. (IEC) and 700 V a.c. (UL) Voltage rating at DC     750 V d.c. (IEC)       Mounting method     DIN rail 2 x M4 Panel mounting screws Optical defect indication     No Degree of protection     IP20 Built-in depth     51.5 mm Lockable     Yes Width in number of modular spacings     1.5 Application     Industrial and Commercial applications       Fuse size     14 x 51 mm Fuse type     C14G C14M Accessories       Accessories     JV-L Multipole connector kit, CH14-CTP IP20 Protection accessory, CH14-SPS Microswitch to work with CH141D(I)U Electrical data Product specifications Compatible fuse Technical data ETIM 9.0 Circuit breakers and fuses (EG000020) / Holder for cylindrical fuse (EC002705) Electric engineering, automation, process control engineering / Electrical installation, device / Safety fuse systems / Holder for cylindrical fuse (ecl@ss13-27-14-21-21 [ADI305012]) Nominal voltage   V 690 Mounting method     DIN rail For fuse size     14x51 mm Number of poles     1 Concurrently switching neutral conductor     No Lockable     Yes With optical defect indication     No Width in number of modular spacings     1.5 Built-in depth   mm 51.5 Degree of protection (IP)     IP20 05/08/2024 Eaton CH141DU ED2023 V1.0 EN 1/2 05/08/2024 Eaton Industries GmbH © 04/2023 by Eaton Industries GmbH Eaton CH141DU ED2023 V1.0 EN 2/2
CH141DU 价格&库存
很抱歉,暂时无法提供与“CH141DU”相匹配的价格&库存,您可以联系我们找货
CH141DU
  • 6+173.311326+22.48700
