DH364FRK
DH364FRK
    EATON(伊顿)
DH364FRK 数据手册
Welcome to the Retail Catalog The residential construction market has experienced unprecedented growth over the last several years. As new home construction and remodeling projects continue to rise, homebuilders, electrical contractors and do-it-yourselfers demand more in service and products. You can rely on Eaton’s electrical business to give you the best in products and services. In the following pages, you will find the standard products you have come to know and trust, as well as innovative products that can boost your value to your customers. From loadcenters and breakers to generators and surge protection devices, this catalog will help you choose the right product for your consumers’ next project. UNDERSTANDING YOUR PURCHASING NEEDS As you strive to provide the best for your customers, our experienced sales team can help you select specific products for your geography and customers: ✓ Products to help lower installation costs ✓ Enhance the homeowner’s safety, as well as the home’s contents ✓ Meet code and environmental requirements ✓ Reduce the number of shelf SKUs ✓ Increase your overall profitability WHY EATON? Eaton is a premier provider of electrical products for the retail industry. We understand our customers and what they need to stay competitive. Put our expertise to work for you! Circuit Breakers Loadcenters Meter Breakers Metering Power Outlet Panels Disconnects Pressure Switches Surge Protection Emergency Power Solutions Structured Wiring Terms & Conditions Index EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — ©Copyright 2005 Retail Customer Service TOLL FREE: 1-877-932-9322 ✓ Please have your vista customer number ✓ Option 1: Order Services, Order Changes, Expediting ✓ Option 2: Order Returns ✓ Option 3: Product Selection and Technical Support ✓ Option 4: Retail Store Pricing and Sales Support WEBSITE: WWW.EATONELECTRICAL.COM This is a source for company information, news and events, technical documents, product information, and more. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Effective August 2005 Features, Functions and Benefits 1-2 1-4 1-4 1-8 1-10 1-12 1-15 1-15 1-16 1-16 1-19 1-23 1-24 ✓ Unique sandlewood handles are marked with ON✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ OFF indication and ampere rating of the breaker. Type CH: – 10 to 150 amperes – 1-, 2- and 3-pole – 1- and 2-pole 120/240 V – 3-pole 240 V – 10 kAIC Installation flexibility. Solid and stranded wire can be used together. 15 – 60 ampere breakers marked for heating, air conditioning and refrigeration equipment application. Lifetime warranty. Meet UL姞 489, CSA姞, NEMA姞 standards, Federal Spec Classification W-C 375 b/GEN. 3/4-inch (19.1 mm) wide (per pole). Trips to off. Circuit Breakers CH 3/4” Circuit Breakers Circuit Breaker Accessories. . . . . . . . . . . . . . Twin Circuit Breakers . . . . . . . . . . . . . . . . . . . Circuit Breaker Cross-Reference . . . . . . . . . . BR 1” Circuit Breakers Circuit Breaker Accessories. . . . . . . . . . . . . . Duplex and Quadplex Circuit Breakers . . . . . Circuit Breaker Cross-Reference . . . . . . . . . . Arc Fault Circuit Breakers BR 1” . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . CH 3/4” . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Ground Fault Circuit Breakers BR 1” . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . CH 3/4” . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Classified Circuit Breakers . . . . . . . . . . . . . . . . . Circuit Breaker Applications . . . . . . . . . . . . . . . . Main Breakers . . . . . . . . . . . . . . . . . . . . . . . . . . . Catalog Numbering System Type CH Circuit Breakers TABLE 1-1. CATALOG NUMBERING SYSTEM CH 1 20 CS Type Packaging CH Poles Amperes 1 = 1-Pole 2 = 2-Pole 3 = 3-Pole 10 = 10 15 = 15 20 = 20 25 = 25 30 = 30 35 = 35 40 = 40 45 = 45 50 = 50 60 = 60 70 = 70 80 = 80 90 = 90 100 = 100 110 = 110 125 = 125 150 = 150 NEED Type CH Circuit Breakers Installed Type CH Circuit Breakers Product Description The primary function of a circuit breaker is to protect the wire from overheating (referred to as an overload) and fault currents (referred to as short circuits). Circuit breakers replaced fuses because they can be reset. CS = Clamshell Note: For arc fault and ground fault breakers, please see appropriate section. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-1 Data Tables TABLE 1-2. TYPE CH BREAKERS, 3/4-INCH (19.1 MM) PER POLE 120, 120/240 OR 240 VAC, 10 kAIC Circuit Breakers Wire Size Ampere Range Cu/Al Rating 60ºC or 75°C 1-Pole 120/240 Vac Requires One 3/4-Inch (19.1 mm) Space 2-Pole 120/240 Vac Common Trip Requires Two 3/4-Inch (19.1 mm) Spaces 3-Pole 240 Vac Common Trip Requires Three 3/4-Inch (19.1 mm) Spaces 10 per Shelf Carton 5 per Shelf Carton 5 per Shelf Carton 10 kAIC Catalog Number UPC Code 10 kAIC 10 kAIC Catalog Number UPC Code Catalog Number UPC Code CH210 CH215 CH220 CH225 CH230 782113906751 782113101729 782113101767 782113121451 782113101804 CH310 CH315 CH320 CH325 CH330 782113906768 782113101996 782113102023 782113121482 782113102054 10 15 20 25 30 (1) #14 – 8 (2) #14 – 10 (1) #14 – 6 CH110 CH115 CH120 CH125 CH130 782113906744 782113101620 782113101644 782113121420 782113101668 35 #14 – 2 #14 – 6 CH135 782113316987 CH235 782113312248 CH335 782113316994 #10 – 1/0 #14 – 2 #3/0 CH140 CH145 CH150 CH160 CH170 — — — — — — 782113101675 782113510811 782113101682 782113871141 782113871158 — — — — — — 782113101835 782113317014 782113101859 782113101873 782113101897 782113312293 782113101910 782113102375 782113317038 782113298788 782113298795 782113102078 782113356266 782113102092 782113102115 782113102139 782113146768 782113102399 782113102405 — — — 40 45 50 60 70 80 90 100 110 125 150 CH240 CH245 CH250 CH260 CH270 CH280 CH290 CH2100 CH2110 CH2125 CH2150 For 1- and 2-pole breakers. Solid and stranded wire can be used together. For 3-pole breakers. 1-pole 60 – 70 amperes, 2-pole 80 – 125 amperes, 3-pole 40 – 100 amperes. 1-pole 40 – 50 amperes, 2-pole 40 – 70 amperes. CH340 CH345 CH350 CH360 CH370 CH3080 CH3090 CH3100 — — — 2-pole 150 amperes. Switching duty rated. HACR rated. CH2150 requires 4-pole spaces and is not suitable for use on 3-phase panels. Not CSA certified. TABLE 1-3. TYPE CH BREAKERS, 3/4-INCH (19.1 MM) PER POLE 120, 120/240 OR 240 VAC, 10 kAIC — CLAMSHELLS 2-Pole 120/240 Vac Common Trip Requires Two 3/4-Inch (19.1 mm) Spaces 6 per Shelf Carton 3 per Shelf Carton Ampere Rating Wire Size Range Cu/Al 60ºC or 75°C 10 kAIC 15 20 30 40 50 60 10 kAIC Catalog Number UPC Code Catalog Number UPC Code (1) #14 – 8  (2) #14 – 10  (1) #14 – 6  CH115CS  CH120CS  CH130CS  782114752500 782114752517 782114752524 CH215CS  CH220CS  CH230CS  782114752531 782114752548 782114752555 #10 – 1/0  #14 – 2  #3/0 CH140CS CH150CS — 782116630585 782116630592 — CH240CS  CH250CS  CH260CS  782114752562 782114752579 782114752593 70 80 90 — — — — — — CH270CS CH280CS CH290CS 782116630608 782116630615 782116630622 100 110 125 — — — — — — CH2100CS CH2110CS CH2125CS 782116630776 782116630783 782116630790     1-2 1-Pole 120/240 Vac Requires One 3/4-Inch (19.1 mm) Space For 1- and 2-pole breakers. Solid and stranded wire can be used together. For 3-pole breakers. 1-pole 60 – 70 amperes, 2-pole 80 – 125 amperes, 3-pole 40 – 100 amperes.    1-pole 40 – 50 amperes, 2-pole 40 – 70 amperes. Switching duty rated. HACR rated. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Accessories Minimum Order Quantity Catalog Number UPC Code Handle tie bar for physically joining the handles of two adjacent 1-pole Type CH Circuit Breakers. (Molded Plastic Handle Cover) CHHT 782113099071 25 Handle tie bar for physically joining the handles of two adjacent 1-pole Type CH Circuit Breakers. (Clamshell) CHHTCS 782114793220 1 Padlockable device for locking the handle of 1-, 2- or 3-pole Type CH Circuit Breakers. (Escutcheon Mounted) CHPL 782113099118 1 Padlockable device for locking the handle of 1-, 2- or 3-pole Type CH Circuit Breakers. (Clamshell) CHPLCS 782114793251 1 Padlockable device for locking the handle of a 1-, 2- or 3-pole Type CHGFI Circuit Breaker. (Escutcheon Mounted) CHPLGF 782114213629 1 Padlockable device for locking the handle of main circuit breaker Types CC and CCH into the ON or OFF position. (Screw Mounted) CCPL 782113099415 1 Padlockable device for locking the handle of main breaker Types BW and CSR into the ON or OFF position. (Escutcheon Mounted) MCBPL 782113099309 1 Device used to secure handle in ON or OFF position for 1-pole Type CH Circuit Breakers. (Handle Mounted) CHLO 782113099088 10 Device used to secure handle in ON or OFF position for 1-pole Type CH Circuit Breakers. (Clamshell) CHLOCS 782114793237 1 Description Handle Ties Handle Lockoffs Circuit Breakers TABLE 1-4. FIELD INSTALLATION KITS AND PARTS Handle Lockdogs Hold-Down Kits Hold-down retainer kit for 1-, 2-, 3-pole Type CH Circuit Breakers. For 6 – 24 circuit 125 ampere CH125RB single- and 3-phase, 12 – 42 circuit 225 ampere single-phase and 24 – 42 circuit 3-phase 225 ampere MLO Type CH Loadcenters. 782113099125 1 Hold-down retainer kit for 1-, 2-, 3-pole Type CH Circuit Breakers. For 6 – 24 circuit 125 ampere CH125RBCS single- and 3-phase, 12 – 42 circuit 225 ampere single-phase and 24 – 42 circuit 3-phase 225 ampere MLO Type CH Loadcenters. (Clamshell) 782114793183 1 Hold-down retainer kit for 1-, 2-, 3-pole Type CH Circuit Breakers for 2 – 4 circuit MLO CH Loadcenters. CH125RB24 782114344446 1 Hold-down retainer kit for 1-, 2-, 3-pole Type CH Circuit Breakers for 2 – 4 circuit MLO CH Loadcenters. (Clamshell) CH125RB24CS 782114793190 1 Mounting Bases Mounting base for 2-pole Type CH Circuit Breaker — 70 ampere maximum. CH9MB270 782113418926 1 CHML CHMLCS CHSACS CHSF2125CS 782114262849 782114793244 782114753408 782114793268 CCL300 MCBL300 782113099354 1 782113099316 1 Mechanical Interlock Type CH for 2-, 3- and 4-pole breakers Type CH for 2-, 3- and 4-pole breakers (Clamshell) Type CH 2-pole plug-in surge arrester (Clamshell) Type CH sub-feed block 125 ampere, 2-pole (Clamshell) 10 1 1 1 Main Breaker Replacement Lug Kits CC/CCH Main Breaker Lug Kit 1 – 300 kcmil Replacement Lug Kit for CSR/BW/BWH Main Breaker (CH Version) Handle Ties: Typically used to join two similar independent single-pole breakers to form a 2-pole noncommon trip breaker. Handle Lockoffs: Devices that use a padlock to lock the circuit breaker’s handle in the ON or OFF position. Requires one additional pole space. Escutcheon Mounted: Device mounted semipermanently to the face of the circuit breaker and secured by the loadcenter deadfront. Screw Mounted: Device permanently mounted to the face of the circuit breaker by the use of a non-removable screw. Handle Lockdogs: Devices that are used to secure a circuit breaker’s handle in the ON or OFF position. Handle Lockdogs are not padlockable devices. Handle Mounted: Device mounted above or below handle using spring pressure. Hold-Down Kits: Devices used to secure the circuit breaker to the loadcenter for back-feed main application. See NEC姞 Article 384-16(g). EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-3 Circuit Breakers Related Products Cross-Reference CTL PLUG-ON CIRCUIT BREAKERS, TYPE CHT TWIN 10,000 AMPERES INTERRUPTING CAPACITY 120/240 VAC TABLE 1-8. CIRCUIT BREAKERS TABLE 1-5. TYPE CHT TWIN (CTL) 3/4-INCH (19.1 MM) PER POLE 120 VAC CLASS CTL 10 kAIC All circuit breakers have rejection feature. Use only with loadcenters marked for use with CHT breakers. 1-Pole 120/240 Vac 120/240 Vac Requires One 3/4-Inch (19.1 mm) Space Ampere Rating 15 – 15 15 – 20 20 – 20 Square D姞 — QO CH115 CH120 CH130 QO115 QO120 QO130 CH210 CH2100 CH2125 QO210 QO2100 QO2125 CH215 CH220 CH225 QO215 QO220 QO225 QO230 QO240 QO250 10 per Shelf Carton Catalog Number UPC Code CH230 CH240 CH250 #14 – 8 CHT1515 CHT1520 CHT2020 782113631530 782113631554 782113631547 CH260 CH270 CH280 QO260 QO270 QO280 CH3100 CH320 CH330 QO3100 QO320 QO330 CH340 CH350 CH360 QO340 QO350 QO360 CHNT1515 CHNT2020 — — CHQ120 CHQ230 QO120 QO230 CHT1515 CHT1520 CHT2020 QOT1515 — QOT2020 CHQ120 CHQ230 QO120 QO230 10 kAIC TABLE 1-6. TYPE CHT TWIN (CTL) 3/4-INCH (19.1 MM) PER POLE 120 VAC CLASS CTL 10 kAIC (CLAMSHELLS) 1-Pole 120/240 Vac 120/240 Vac Requires One 3/4-Inch (19.1 mm) Space 15 – 15 15 – 20 20 – 20 CH Breakers Wire Size Range Cu/Al 60ºC or 75°C Switching duty rated. HACR rated. Ampere Rating 3/4-Inch Breakers (19.1 mm) Wire Size Range Cu/Al 60ºC or 75°C 10 per Shelf Carton Catalog Number UPC Code #14 – 8 CHT1515CS CHT1520CS CHT2020CS 782116630745 782116630769 782116630752 10 kAIC Switching duty rated. HACR rated. NON-CTL PLUG-ON REPLACEMENT CIRCUIT BREAKERS, TYPE CHNT 10,000 AMPERES INTERRUPTING CAPACITY 120/240 VAC Note: These products are by no means equivalent but functionally similar. This is a cross-reference tool not an interchangeability chart. TABLE 1-7. TYPE CHNT 3/4-INCH (19.1 MM) PER POLE 120 VAC, NON-CTL 10 kAIC For use as replacement in loadcenters built prior to 1968 and within the current style 2 – 8 circuit loadcenters as indicated in the loadcenter section. 1-Pole 120/240 Vac 120/240 Vac Requires One 3/4-Inch (19.1 mm) Space Ampere Rating 15 – 15 15 – 20 20 – 20 Wire Size Range Cu/Al 60ºC or 75°C 10 per Shelf Carton Catalog Number UPC Code #14 – 8 CHNT1515 CHNT1520 CHNT2020 782114220849 782114220870 782114220863 10 kAIC Switching duty rated. HACR rated. 1-4 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Type BR Circuit Breakers Features, Functions and Benefits NEED ✓ ✓ Product Description The primary function of a circuit breaker is to protect the wire from overheating (referred to as an overload) and fault currents (referred to as short circuits). Circuit breakers replaced fuses because they can be reset. ✓ ✓ ✓ circuit breakers have an internal common trip mechanism. Handle position provides visual trip position. Type BR: – 10 to 150 amperes – 1-, 2- and 3-pole – 1- and 2-pole 120/240 V – 3-pole 240 V – 10, 22 and 42 kAIC (2 poles only) Type BR breakers carry listing for HCAR application. Meet UL 489, CSA, NEMA standards, Federal Spec Classification W-C 375 b/GEN. 1-inch (25.4 mm) wide (per pole). Circuit Breakers ✓ Operated by toggle-type handle and multi-pole Catalog Numbering System TABLE 1-9. CATALOG NUMBERING SYSTEM BR 1 20 CS Type Packaging BR Poles Amperes 1 = 1-Pole 2 = 2-Pole 3 = 3-Pole 10 = 10 15 = 15 20 = 20 25 = 25 30 = 30 35 = 35 40 = 40 45 = 45 50 = 50 60 = 60 70 = 70 80 = 80 90 = 90 100 = 100 110 = 110 125 = 125 150 = 150 CS = Clamshell Note: For arc fault and ground fault breakers, please see applicable sections. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-5 Data Tables Wire Size Range Cu/Al 60°C or 75°C Circuit Breakers Ampere Rating TABLE 1-10. TYPE BR BREAKERS, 1-INCH (25.4 MM) PER POLE 120/240, 10, 22 AND 42 kAIC 1-Pole 120/240 Vac Requires One 1-Inch (25.4 mm) Space 2-Pole 120/240 Vac Common Trip Requires Two 1-Inch (25.4 mm) Spaces 10 per Shelf Carton 5 per Shelf Carton 10 kAIC 22 kAIC 10 kAIC 22 kAIC 42 kAIC Catalog Number UPC Code Catalog Number UPC Code Catalog Number UPC Code Catalog Number UPC Code Catalog Number UPC Code 10 #14 – 4 15 20 25 30 BR110 BR115 BR120 BR125 BR130 786676362009 786676362054 786676362108 786676362153 786676362207 — BRH115 BRH120 BRH125 BRH130 — 786676373050 786676373104 786676373159 786676373203 BR210 BR215 BR220 BR225 BR230 786676362757 786676362801 786676362856 786676362900 786676362955 — BRH215 BRH220 BRH225 BRH230 — 786676373456 786676373500 786676373555 786676373609 — — — — — — — — — — 35 #14 – 4 40 45 50 BR135 BR140 — BR150 782114372081 786676362252 — 786676362306 BRH135 BRH140 BRH145 BRH150 782114372128 786676373258 782114372135 786676373302 BR235 BR240 BR245 BR250 786676374354 786676363006 786676374453 786676363051 BRH235 BRH240 BRH245 BRH250 782114372159 786676373654 782114372166 786676373708 — — — — — — — — 55 #14 – 3 BR150 786676362306 BRH155 782114372142 BR255 782114372111 BRH255 782114372173 — — 60 #4 – 1/0 70 80 90 100 110 BR160 BR170 — — — — 786676362351 786676362405 — — — — BRH160 BRH170 — — — — 786676373357 786676373401 — — — — BR260 BR270 BR280 BR290 BR2100 BR2110 786676363105 786676363150 786676363174 786676363204 786676363259 786676384278 BRH260 BRH270 BRH280 BRH290 BRH2100 BRH2110 786676373753 786676373807 782114372180 786676373852 786676373906 786676374248 — — — — — — 786676367059 BRH2125 786676373951 BRHH2125 786676377003 BR2125 — — BR2150 786676101950 — — 125 #4 – 2/0 — 150 — BRHH260 BRHH270 BRHH280 BRHH290 BRHH2100 BRHH2110 786676382601 786676382700 786676382809 786676382908 786676376952 786676002950 1-pole, 1-inch (25.4 mm) per pole circuit breakers are available with high magnetic setting for switching large tungsten lamp loads. Add Suffix H to catalog number. Switching duty rated. For use as a branch circuit breaker in 400 and 600 ampere panels only. Note: All Type BR 1-, 2- and 3-pole circuit breakers carry listing for HACR application. Wire Size Range Cu/Al 60°C or 75°C Ampere Rating TABLE 1-11. TYPE BR BREAKERS, 1-INCH (25.4 MM) PER POLE 120/240, 10, 22 AND 42 kAIC — CLAMSHELLS 1-Pole 120/240 Vac Requires One 1-Inch (25.4 mm) Space 2-Pole 120/240 Vac Common Trip Requires Two 1-Inch (25.4 mm) Spaces 6 per Shelf Carton 3 per Shelf Carton 10 kAIC 10 kAIC 22 kAIC 42 kAIC Catalog Number UPC Code Catalog UPC Number Code Catalog Number UPC Code Catalog Number UPC Catalog UPC Code Number Code BR115CS BR120CS BR130CS BR140CS 782114752708 782114752715 782114752722 782116630370 — — — — — — — — BR215CS BR220CS BR230CS BR240CS 782116630486 782114752746 782114752753 782114752760 — — — — — — — — — — — — — — — — 782116630387 782116630394 782116630400 — — — — — — — — — BR250CS BR260CS BR270CS BR280CS 782114752777 782114752784 782116630493 782116630509 — — — — — — — — — — — — — — — — — 782116630417 — — — — — — — — — — BR290CS BR2100CS BR2110CS BR2125CS 782116630516 782116630523 782116630530 782116630547 — — — — — — — — — — — — — — — — — — — — — — BR2135CS BR2150CS 782116630554 782116630561 — — — — — — — — 15 20 30 40 #14 – 4 50 60 70 80 #4 – 1/0 BR150CS BR160CS BR170CS — 90 #4 – 1/0 100 110 125 22 kAIC — BR1100CS — — 135 #4 – 1/0 — 150 — 1-pole, 1-inch (25.4 mm) per pole circuit breakers are available with high magnetic setting for switching large tungsten lamp loads. Add Suffix H to catalog number. Switching duty rated. Note: All Type BR 1-, 2- and 3-pole circuit breakers carry listing for HACR application. 1-6 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Data Tables 3-Pole 240 Vac Common Trip Requires Three 1-Inch (25.4 mm) Spaces 5 per Shelf Carton Ampere Rating Wire Size Range Cu/Al 60°C or 75°C 10 15 20 25 30 10 kAIC 22 kAIC Catalog Number UPC Code Catalog Number UPC Code #14 – 4 BR310 BR315 BR320 BR325 BR330 786676092050 786676367707 786676367752 786676000093 786676367806 — BRH315 BRH320 BRH325 BRH330 — 786676372503 786676372558 786676002707 786676372602 35 40 45 50 #14 – 4 BR335 BR340 BR345 BR350 786676000109 786676367851 786676000116 786676367905 BRH335 BRH340 BRH345 BRH350 786676002714 786676372657 786676002721 786676372701 55 #14 – 3 BR355 782114375167 BRH355 786676002738 60 70 80 90 100 #4 – 1/0 BR360 BR370 BR380 BR390 BR3100 786676367950 786676368001 782114103098 786676368056 786676368094 BRH360 BRH370 BRH380 BRH390 BRH3100 786676372756 786676372800 786676002745 786676372855 786676372909 Circuit Breakers TABLE 1-12. TYPE BR BREAKERS, 1-INCH (25.4 MM) PER POLE 240 VAC, 10,000 AND 22,000 kAIC One pole, 1-inch (25.4 mm) per pole circuit breakers are available with high magnetic setting for switching large tungsten lamp loads. Add suffix H to catalog number. Note: All Type BR 1-, 2- and 3-pole circuit breakers carry listing for HACR application. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-7 Accessories TABLE 1-13. FIELD INSTALLATION KITS AND PARTS Circuit Breakers Catalog Number Description UPC Code Minimum Order Quantity Handle Ties Handle tie bar for physically joining the handles of two adjacent 1-pole Type BR Circuit Breakers. BHT (Metal Cylinder Pin Type) 786676375207 10 Handle tie bar for physically joining the handles of two adjacent 1-pole Type BR Circuit Breakers. BHTCS (Metal Cylinder Pin Type w/ Clamshell) 782114793107 1 Handle tie bar for joining two independent outside poles of Types BQ and BQC Quadplex and outside poles of two Type BD Duplex Circuit Breakers. THOW 786676092036 10 Handle tie bar for joining two independent outside poles of Types BQ and BQC Quadplex and outside poles of two Type BD Duplex Circuit Breakers (w/ Clamshell). THOWCS 782114793435 1 Handle tie bar for joining two adjacent outside poles of Types BQ and BQC Quadplex and outside THS1 poles of two Type BD Duplex Circuit Breakers. 786676092043 10 Handle tie bar for joining two adjacent outside poles of Types BQ and BQC Quadplex and outside THS1CS poles of two Type BD Duplex Circuit Breakers (w/ Clamshell). 782114793442 1 Handle Lockoffs Padlockable device for locking the handle of 1-, 2- or 3-pole Type BR Circuit Breakers and 1-pole of a Type BD Duplex or one independent outside pole of a Type BQ or BQC Quadplex Circuit Breakers. (Escutcheon Mounted) or one independent outside pole of a Type BQ or BQC Quadplex Circuit Breakers. (Escutcheon Mounted w/ Clamshell) BRLW BRLWCS 786676000499 10 782114793138 1 Padlockable device for locking the handle of a 1-pole Type BR Circuit Breaker. (Handle Mounted) BRLW1 786676376228 10 Padlockable device for locking the handle of a 1-pole Type BR Circuit Breaker. (Handle Mounted w/ Clamshell) BRLW1CS 782114793145 1 Padlockable device for locking the handle of a 2- and 3-pole Type BR Circuit Breaker. (Handle Mounted) BRLW2 Padlockable device for locking the handle of a 2- and 3-pole Type BR Circuit Breaker. (Handle Mounted w/ Clamshell) BRLW2CS 782114793152 1 Padlockable device for locking the handle of a 1-pole Type BD Duplex, BQ or BQC Quadplex Breaker. (Handle Mounted) BRDL1 786676376129 10 Padlockable device for locking the handle of the two center poles and the two outer poles of a 2-pole Types BQ and BQC Quadplex Circuit Breakers. (Escutcheon Mounted) BRQLW 786676376303 10 Padlockable device for locking the handle of main circuit breaker Types CC and CHH into the ON or OFF position. (Screw Mounted) CCPL 782113099415 1 Padlockable device for locking the handle of main breaker Types BW and BWH into the ON or OFF MCBPL position. (Escutcheon Mounted) 786676376259 10 782113099309 1 Handle Ties: Typically used to join two similar independent single-pole breakers to form a 2-pole noncommon trip breaker. Handle Lockoffs: Devices that use a padlock to lock the circuit breaker’s handle in the ON or OFF position. Escutcheon Mounted: Device mounted semipermanently to the face of the circuit breaker and secured by the loadcenter deadfront. Handle Mounted: Device mounted directly to the handle by the use of a set screw. Screw Mounted: Device permanently mounted to the face of the circuit breaker by the use of a non-removable screw. 1-8 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Accessories Minimum Order Quantity Catalog Number UPC Code Device used to secure handle in ON or OFF position for 1-, 2-, or 3-pole Type BR Circuit Breakers and 1-pole of Type BD Duplex and one independent outside pole of Type BQ or BQC Quadplex Circuit Breakers. (Escutcheon Mounted) BHLW 786676000482 10 Device used to secure handle in ON or OFF position for 1-pole Type BR Circuit Breakers. (Handle Mounted) BHLW1 786676375658 10 Device used to secure handle in ON or OFF position for 2- and 3-pole Type BR Circuit Breakers. BHLW2 (Handle Mounted) 786676375689 10 Device used to secure handle in ON or OFF position for 1-pole Type GFCB Ground Fault Circuit Breakers. (Handle Mounted) 782114797358 10 Description Handle Lockdogs BHGW Device used to secure handle in ON or OFF position for one independent outside pole of Types HLW1 BQ and BQC Quadplex or 1-pole Type BD Duplex Circuit Breakers. (Handle Mounted) Circuit Breakers TABLE 1-13. FIELD INSTALLATION KITS AND PARTS (CONTINUED) 786676375450 10 Hold-Down Kits Hold-down retainer kit for 3-pole Type BR Circuit Breakers in S3100 and 3100R Loadcenters only. BRHDB 786676376402 1 Hold-down screw kit for 2-pole Type BR Circuit Breakers in single-phase MLO Loadcenters through 125 amperes. BREQS125 786676449557 1 Hold-down screw kit for 2-pole Type BR Circuit Breakers in MLO Loadcenters 150 through 225 amperes (single-phase only). BRHDK125 786676449502 1 Hold-down screw kit for 2-pole Types BJ and BJH Circuit Breakers in MLO Loadcenters 125 through 225 amperes. BJHDS 786676376709 1 Hold-down screw kit for 3-pole Types BJ and BJH Circuit Breakers in MLO Loadcenters 125 through 225 amperes. BJHDS3P 786676376754 1 BRML BRMLCS 782114383926 10 782114793169 1 BRSF125 BRSF125CS 786676001762 1 782114793176 1 Mechanical Interlocks Types BR for 2-, 3- and 4-pole breakers Types BR for 2-, 3- and 4-pole breakers (w/ Clamshell) Sub-Feed Blocks 125 A 2-pole sub-feed block #6 – 2/0 wire size 125 A 2-pole sub-feed block #6 – 2/0 wire size (w/ clamshell) Surge Breaker Plug-on surge protector Plug-on surge protector (w/ clamshell) BRSURGE 786676449403 1 BRSURGECS 782114753415 1 Handle Lockdogs: Devices that are used to secure a circuit breaker’s handle in the ON or OFF position. Handle Lockdogs are not padlockable devices. Escutcheon Mounted: Device mounted semipermanently to the face of the circuit breaker and secured by the loadcenter deadfront. Handle Mounted: Device mounted directly to the handle by the use of a set screw. Hold-Down Kits: Devices used to secure the circuit breaker to the loadcenter for back-feed main application. See NEC Article 384-16(g). EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-9 Related Products DUPLEX AND INDEPENDENT TRIP QUADPLEX BREAKERS Type BD Duplex (UL Type BRD) Type BQ Quadplex Independent Trip (UL Type BRD) Type BQ Quadplex Independent Trip (UL Type BRD) 2-Pole and 1-Pole 2-Pole Requires One 1-Inch (25.4 mm) Space Requires Two 1-Inch (25.4 mm) Spaces Requires Two 1-Inch (25.4 mm) Spaces 10 per Shelf Carton 5 per Shelf Carton 5 per Shelf Carton 10 kAIC 10 kAIC 10 kAIC 120 Vac 120 Vac 120/240 Vac 1-Pole 120/240 Vac 120/240 120 Vac Vac BD1010 BD1515 BD1515CS BD1520 BD1530 BD2015 BD2020 BD2020CS BD2030 BD2525 BD3015 BD3020 BD3030 BD3040 BD3050 BD5030 BD5050 786676009010 #14 – 4 786676369053 782116630462 786676369107 786676369152 786676369206 786676369251 782116630479 786676369305 786676369350 786676369404 786676369459 786676369503 786676369534 786676369558 786676369602 786676004282 15 20 15 20 15 20 15 20 — — — — — — — — — Center 2-Poles Independent Trip UPC Code Outer Left 1-Pole Catalog Number 20 20 30 30 40 40 50 50 — — — — — — — — — Ampere Rating Outer Right 1-Pole 10 – 10 15 – 15 15 – 15 15 – 20 15 – 30 20 – 15 20 – 20 20 – 20 20 – 30 25 – 25 30 – 15 30 – 20 30 – 30 30 – 40 30 – 50 50 – 30 50 – 50 Wire Size Range Cu/Al 65°C or 75°C Ampere Rating Ampere Rating Vac Catalog Number UPC Code 15 20 15 20 15 20 15 20 — — — — — — — — — BQ2202115 BQ2202120 BQ2302115 BQ2302120 BQ2402115 BQ2402120 BQ2502115 BQ2502120 — — — — — — — — — 786676371353 786676371308 786676371506 786676371551 786676371605 786676371650 786676371704 786676371759 — — — — — — — — — 15 15 15 15 15 20 20 20 20 25 30 30 30 40 40 50 — Center 2-Poles Independent Trip 120/240 Vac 120/240 Vac Outer 2-Poles Independent Trip Circuit Breakers TABLE 1-14. CLASS CTL, 1-INCH (25.4 MM) PER POLE 10 kAIC — ALL CIRCUIT BREAKERS HAVE REJECTION TAB FEATURE Catalog Number UPC Code 15 20 30 40 50 20 30 40 50 25 30 40 50 40 50 50 — BQ215215 BQ215220 BQ215230 BQ215240 BQ215250 BQ220220 BQ220230 BQ220240 BQ220250 BQ225225 BQ230230 BQ230240 BQ230250 BQ240240 BQ240250 BQ250250 — 786676370707 786676004381 786676004404 786676004411 786676004435 786676370752 786676370806 786676370851 786676370905 786676370950 786676371001 786676371056 786676371100 786676371155 786676371209 786676371254 — All Type BD Duplex and BQ Quadplex circuit breakers carry listing for HACR applications. All 15 and 20 ampere single poles are switch-duty rated. Note: Type BD Duplex, BQ and BQC Quadplex (CTL) circuit breakers conform to Section 384-15 of the latest National Electrical Code. Install breaker only in panel positions that have notched bus stabs. Notched Bus Stab Unnotched Bus Stab Type BR or Type BD Duplex, (CTL), Type BQ and BQC Quadplex CTL Circuit Limiting Feature Type BD Duplex Rejection Tab Type BR Notched Stab Non-CTL Non-Circuit Limiting Type BR FIGURE 1-1. CTL AND NON-CTL BREAKERS 1-10 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Data Tables Type Brand BRD Quadplex Independent Trip Type BR Duplex 120/240 Vac 120/240 Vac 120/240 Vac 1-Pole Type BRD Quadplex Common Trip center and Outer Poles 2-Pole Vac 120/240 Vac 2-Pole Vac 3 per Shelf Carton 10 kAIC 10 kAIC 10 kAIC 120 Vac 120/240 120/240 Vac Vac 120/240 Vac Ampere Rating Ampere Rating Ampere Catalog Rating Number UPC Code 15 – 15 15 – 15 15 – 20 20 – 15 20 – 20 20 – 20 30 – 30 786676370059 #14 – 4 782114752791 786676370103 786676370202 786676370257 782114752807 786676370301 BR1515 BR1515CS BR1520 BR2015 BR2020 BR2020CS BR3030 15 15 20 30 20 20 30 15 15 20 30 30 30 40 Catalog Number UPC Code BR415 BR420 BR430 BRD220230 BRD230240 BRD230250 — 786676372107 786676372152 786676372206 786676372213 786676372251 786676372305 — 15 30 30 30 — — — Center 2-Poles Common Trip 3 per Shelf Carton Outer 2-Poles Common Trip 10 per Shelf Carton Center 2-Poles Independent Trip Requires Two 1-Inch (25.4 mm) Spaces Outer 2-Poles Independent Trip Requires Two 1-Inch (25.4 mm) Spaces Wire Size Range Cu/Al 65°C or 75°C Requires One 1-Inch (25.4 mm) Space 15 30 40 50 — — — Catalog Number UPC Code BRDC215215 BRDC230230 BRDC230240 BRDC230250 — — — 786676372312 786676372329 786676372336 786676372343 — — — Circuit Breakers TABLE 1-15. CLASS NON-CTL, 1-INCH (25.4 MM) PER POLE 10 kAIC — BREAKERS DO NOT HAVE REJECTION TAB FEATURE Non-CTL 10 kAIC for replacement purposes only. For replacement in enclosures manufactured prior to 1968 with unnotched stabs. Circuit breakers do not have rejection tab. Clamshell. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-11 Cross-Reference TABLE 1-16. CIRCUIT BREAKERS 1-Inch Breakers (25.4 mm) Circuit Breakers Cutler-Hammer姞 BR Breakers Siemens姞 GE姞 Square D — HOMELINE姞 BR115 BR120 BR130 Q115 Q120 Q130 THQL1115 THQL1120 THQL1130 HOM115 HOM120 — — BR2100 BR2125 — Q2100 Q2125 — THQL21110 THQL21125 — HOM2100 HOM2125 BR215 BR220 BR225 Q215 Q220 Q225 THQL2115 THQL2120 THQL2125 HOM215 HOM220 HOM225 BR230 BR240 BR250 Q230 Q240 Q250 THQL2130 THQL2140 THQL2150 HOM230 HOM240 HOM250 BR260 BR270 BR280 Q260 Q270 Q280 THQL2160 THQL2170 THQL2180 HOM260 HOM270 — BR3100 BR320 BR330 Q3100 Q320 Q330 THQL32100 THQL32020 THQL32030 — — — BR340 BR350 BR360 Q340 Q350 Q360 THQL32040 THQL32050 THQL32060 — — — BR1515 BR2020 — — — — — — BD1515 BD1520 BD2020 Q1515 Q1520 Q2020 — — — HOMT1515 HOMT1520 HOMT2020 — — BQ230240 Q120 Q230 — TQ1120 TQ2130 — — — — BQ220230 BD3020 Q23020 Q2030 — — — — Note: These products are by no means equivalent but functionally similar. This is a cross-reference tool not an interchangeability chart. 1-12 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Circuit Breakers Arc Fault Circuit Interrupters (AFCIs) AFCI Breakers Product Description FIRE-GUARD姠 Arc Fault Circuit Interrupter (AFCI) is a circuit breaker that provides protection from fires caused by arcing faults. Arcing faults can occur when insulation around cords, wires or cables is damaged or deteriorated. AFCIs are required in bedroom circuits for new construction per the 2005 National Electrical Code. Features, Functions and Benefits ✓ Reduces the risk of electrical fires started by arcing faults. ✓ Meets UL 489 (standard for molded case circuit breakers), UL 1699 (standard for arc fault circuit interrupters) and either UL 1053 (standard for ground fault relaying and sensing at 30 mA) or UL 943 (ground fault circuit interrupters at 5 mA). ✓ Meets 1999, 2002 and 2005 National Electrical Code requirements for AFCIs. Catalog Numbering System TABLE 1-17. CATALOG NUMBERING SYSTEM BR 1 15 AF CS Type BR = 1-Inch (25.4 mm) CH = 3/4-Inch (19.1 mm) CL = Classified breaker for GE, Siemens, T&B and Square D HOMELINE CHQ = Classified breaker for Square D QO Breaker Type Poles 1 = 1-Pole 2 = 2-Pole Amperes AF = Arc Fault Packaging CS = Clamshell 15 = 15 20 = 20 FIGURE 1-2. APPLICATION DIAGRAM EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-13 APPLICATION DIAGRAMS Circuit Breakers 120/240 Vac Source N A B 120/240 Vac Source N A B Line B Line B 2 Pole 1 Pole Line A Neutral 120 V Duplex Receptacle Neutral Neutral Equipment Ground Equipment Ground FIGURE 1-3. 1-POLE SINGLE 120 VOLT LOAD APPLICATION SOURCED BY 120/240 VAC 120/240 Vac Source N A B 240 V Duplex Receptacle FIGURE 1-5. 2-POLE 240 VOLT LOAD APPLICATION SOURCED BY 120/240 VAC 120/240 Vac Source N A B Line B Line B Line A 2 Pole Neutral Neutral 2 Pole 2-120 V Duplex Receptacles Neutral Neutral 120 V Duplex Receptacle (With Line Side Jumper Removed) Equipment Ground Line A Equipment Ground FIGURE 1-4. 1-POLE SHARED NEUTRAL WITH MULTI-DUPLEX RECEPTACLE APPLICATION 1-14 FIGURE 1-6. 2-POLE SHARED NEUTRAL WITH DUPLEX RECEPTACLE APPLICATION EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Related Products TYPE BR LOADCENTER BREAKERS AFCI TESTER AND CIRCUIT ANALYZER Ampere Rating Wire Size Range Cu/Al 60°C or 75°C TABLE 1-18. TYPE BR 1-INCH (25.4 MM), 10 kAIC 15 15 15 15 15 15 20 20 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 1-Pole Requires One 1-Inch (25.4 mm) Space 2-Pole Requires One 1-Inch (25.4 mm) Space 1 per Shelf Carton 1 per Shelf Carton Catalog Number UPC Code Catalog Number UPC Code BR115AF BR115AFGF — — — — BR120AF BR120AFGF 782114231494 782114409671 — — — — 782114231500 782114409688 BR215AF BR215AFIT BR215AFGF BR220AF BR220AFIT BR220AFGF — — 782114409695 782114415566 782114409725 782114409701 782114415573 782114409732 — — ✓ Catalog Number AFGFTESTER. ✓ UL listed tester for use with AFCI, GFCI (5 mA) and GFI (30 mA) devices. ✓ Verifies proper wiring in a circuit. ✓ Only tester with GFI function and Line-Neutral test feature. ✓ Comes with carrying case, lighting adapter, 2-prong adapter and alligator clips for hardwired circuits. Circuit Breakers Data Tables Wire Size Range Cu/Al 60°C or 75°C Ampere Rating TABLE 1-19. TYPE BR 1-INCH (25.4 MM) — CLAMSHELLS 1-Pole Requires One 1-Inch (25.4 mm) Space 2-Pole Requires One 1-Inch (25.4 mm) Space 1 per Shelf Carton 1 per Shelf Carton Catalog Number Catalog Number UPC Code 15 #14 – 4 BR115AFCS 782114351123 — 20 #14 – 4 BR120AFCS 782114351130 — UPC Code — — TYPE CH LOADCENTER BREAKERS Ampere Rating Wire Size Range Cu/Al 60°C or 75°C TABLE 1-20. TYPE CH 3/4-INCH (19.1 MM) 15 15 15 15 15 15 20 20 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 1-Pole Requires One 3/4-Inch (19.1 mm) Space 2-Pole Requires One 3/4-Inch (19.1 mm) Space 1 per Shelf Carton 1 per Shelf Carton Catalog Number UPC Code Catalog Number UPC Code CH115AF CH115AFGF — — — — CH120AF CH120AFGF 782114231470 782114409749 — — — — 782114231487 782114409756 CH215AF CH215AFIT CH215AFGF CH220AF CH220AFIT CH220AFGF — — 782114409763 782114415580 782114409787 782114409770 782114415597 782114409794 — — Wire Size Range Cu/Al 60°C or 75°C Ampere Rating TABLE 1-21. TYPE CH 3/4-INCH (19.1 MM) — CLAMSHELLS 1-Pole Requires One 3/4-Inch (19.1 mm) Space 2-Pole Requires One 3/4-Inch (19.1 mm) Space 1 per Shelf Carton 3 per Shelf Carton Catalog Number Catalog Number UPC Code 15 #14 – 4 CH115AFCS 782114351109 — 20 #14 – 4 CH120AFCS 782114351116 — UPC Code — — EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-15 breakers) and UL 943 (ground fault circuit interrupters at 5 mA). Catalog Numbering System TABLE 1-22. CATALOG NUMBERING SYSTEM GFCB 1 15 GF CS Packaging GFCB = 1-Inch (25.4 mm) CH = 3/4-Inch (19.1 mm) CL = Classified breaker for GE, Siemens, T&B and Square D HOMELINE CHQ = Classified breaker for Square D QO Poles 1 = 1-Pole 2 = 2-Pole CS = Clamshell 15 = 15 20 = 20 30 = 30 40 = 40 50 = 50 1-Pole Requires One 1-Inch (25.4 mm) Space 2-Pole Requires One 1-Inch (25.4 mm) Space 1 per Shelf Carton 1 per Shelf Carton Catalog Number UPC Code Catalog Number UPC Code GFCB115 GFCB120 GFCB125 GFCB130 GFCB140 — 786676368704 786679371206 786676368766 786676368797 786676008532 — GFCB215 GFCB220 GFCB225 GFCB230 GFCB240 GFCB250 786676368933 786676368957 786676368971 786676368995 786676335461 786676332507 TABLE 1-24. TYPE BR 1-INCH (25.4 MM), 10 KAIC — CLAMSHELLS 15 20 30 40 50 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 1-Pole Requires One 1-Inch (25.4 mm) Space 2-Pole Requires One 1-Inch (25.4 mm) Space 1 per Shelf Carton 1 per Shelf Carton Catalog Number UPC Code Catalog Number UPC Code GFCB115CS GFCB120CS GFCB130CS GFCB140CS GFCB150CS 782114753255 782114753262 782114753279 782116630721 782116630738 GFCB215CS GFCB220CS GFCB230CS GFCB240CS GFCB250CS 782113759005 782114753286 782114753293 782114752869 782114752876 Breaker Type GF = Ground Fault Amperes #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 #14 – 4 TABLE 1-25. TYPE CH 3/4-INCH (19.1 MM), 10 KAIC All except GFCB Type, 5 mA protection. Note: GFCB for use in 1-inch Type BR loadcenters. Wire Size Range Cu/Al 60°C or 75°C Type Wire Size Range Cu/Al 60°C or 75°C ✓ Reduces the risk of shock and electrocution. ✓ Meets UL 489 (standard for molded case circuit 15 20 25 30 40 50 Wire Size Range Cu/Al 60°C or 75°C Features, Functions and Benefits Ampere Rating Ground Fault Circuit Interrupter (GFCI) breakers provide protection for people from hazards of electrical shock in areas where electricity may come into contact with water. GFCIs are required in any application near water such as kitchen countertops, bathrooms, swimming pools, hot tubs, outdoor receptacles, etc. TABLE 1-23. TYPE BR 1-INCH (25.4 MM), 10 KAIC Ampere Rating Circuit Breakers Product Description Data Tables Ampere Rating Ground Fault Circuit Interrupters (GFCIs) 15 20 25 30 40 45 50 #14 – 6 #14 – 6 #14 – 4 #14 – 6 #14 – 4 #14 – 4 #14 – 6 1-Pole Requires One 3/4-Inch (19.1 mm) Space 2-Pole Requires One 3/4-Inch (19.1 mm) Space 1 per Shelf Carton 1 per Shelf Carton Catalog Number UPC Code Catalog Number UPC Code CH115GF CH120GF CH125GF CH130GF — — — 782113261218 782113261768 782114022962 782113263878 — — — CH215GF CH220GF CH225GF CH230GF CH240GF CH245GF CH250GF 782113296142 782113296159 782113444833 782113444727 782113912882 782113924915 782113912899 15 20 30 40 50 60 1-16 Wire Size Range Cu/Al 60°C or 75°C Ampere Rating TABLE 1-26. TYPE CH 3/4-INCH (19.1 MM), 10 KAIC — CLAMSHELLS #14 – 6 #14 – 6 #14 – 6 #14 – 6 1-Pole Requires One 3/4-Inch (19.1 mm) Space 2-Pole Requires One 3/4-Inch (19.1 mm) Space 6 per Shelf Carton 3 per Shelf Carton Catalog Number UPC Code Catalog Number UPC Code CH115GFCS CH120GFCS CH130GFCS — — — 782114752609 782114752616 782114752623 — — — CH215GFCS CH220GFCS CH230GFCS CH240GFCS CH250GFCS CH260GFCS 782116630639 782116630646 782116630653 782116630660 782114752661 782116630677 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 FIGURE 1-7. 1-POLE 120 VOLT DUPLEX RECEPTACLE APPLICATION FIGURE 1-9. 2-POLE 120 VOLT DUPLEX RECEPTACLE APPLICATION FIGURE 1-8. 2-POLE 120 VOLT MULTI-DUPLEX RECEPTACLE APPLICATION FIGURE 1-10. 2-POLE 240 VOLT DUPLEX RECEPTACLE APPLICATION Related Products Did You Know? AFCI TESTER AND CIRCUIT ANALYZER In homes built to comply with the National Electrical Code (the Code), GFCI protection is required for most outdoor receptacles (since 1973), bathroom receptacle circuits (since 1975), garage wall outlets (since 1978), kitchen receptacles (since 1987), and all receptacles in crawl spaces and unfinished basements (since 1990). ✓ Catalog Number AFGFTESTER. ✓ UL listed tester for use with AFCI, GFCI (5 mA) and GFI (30 mA) devices. ✓ Verifies proper wiring in a circuit. ✓ Only tester with GFI function and Line-Neutral test feature. ✓ Comes with carrying case, lighting adapter, 2-prong adapter and alligator clips for hardwired circuits. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 Circuit Breakers APPLICATION DIAGRAMS 1-17 Arc Fault/Ground Fault Analyzer Circuit Analyzer Features, Functions and Benefits ✓ All-in-one tester for ground fault, arc fault and faulty Circuit Breakers ✓ ✓ ✓ ✓ wiring conditions. Neutral Isolation Test Button is a patented feature that allows the contractor to determine whether they have a grounded neutral or have other neutrals connected before leaving the job. Additional test button for AFCI and two that test GFCI devices (40 mA and 8 mA). Only product available from an AFCI manufacturer. Three standard accessories enhance the usefulness of the Circuit Analyzer: – An alligator clip attachment to test hardwired circuits, such as smoke detectors, that lack a receptacle. The clip simply is attached to the smoke alarm’s terminals – An adapter (3-prong to 2-prong) for testing in older homes that lack 3-prong receptacles – Light socket adapter for AFCI testing when no receptacle is available. Examples are ceiling fans that contain sockets and recessed lighting – Additionally, the Circuit Analyzer comes with a black carrying case Circuit Analyzer Product Description Eaton’s Cutler-Hammer Circuit Analyzer provides accurate testing of AFCI and GFCI devices while also testing for faulty wiring conditions. There are other testing devices on the market but this will be the only one available from an AFCI manufacturer. Eaton has more than 100 years of electrical control and power distribution experience, and a thorough understanding of what arc faults are all about. This experience with AFCI breakers led to developing a patented feature of the analyzer that will save contractors time and aggravation. It allows contractors to verify whether they have a grounded neutral simply by depressing the red Neutral Isolation test button. In this way, they will be able to determine whether they have a grounded neutral or have other neutrals connected before they leave the job site. Additionally, the Circuit Analyzer has a button that tests AFCI and two that test GFCI devices (both 40 mA and 8 mA). Application Description Technical Data and Specifications HOW IT WORKS 1. Plug the tester (or one of the accessories) into the receptacle, light fixture or hardwired terminals to be tested. 2. Check the wiring LEDs on the Circuit Analyzer to determine if the circuit is wired correctly. 3. If the circuit is wired correctly, then proceed to test for Neutral Isolation, Arc Fault or Ground Fault conditions, depending on the breaker or receptacle type that is on the circuit. 4. To perform these tests, press the corresponding button on the Circuit Analyzer and review the results. TABLE 1-27. PRODUCT SELECTION Description Catalog Number UPC Code Circuit Analyzer AFGFTESTER 782116141913 The Circuit Analyzer serves as a handy troubleshooting tool for contractors and electrical inspectors. It’s a circuit analyzer that provides accurate testing of AFCI and GFCI devices while also testing for faulty wiring conditions. 1-18 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Classified Circuit Breakers Product Description are considered suitable, by Underwriters Laboratories, for use in another manufacturers’ panelboard. ✓ Tested extensively in numerous GE, Square D, Siemens, Murray姞, Thomas and Betts姞 and Crouse-Hinds姞 panels. ✓ Retailers can streamline inventory by carrying one manufacturer’s circuit breakers vs. multiple manufacturers. Classified Circuit Breakers Features, Functions and Benefits ✓ Available in both 3/4-inch Type CHQ and 1-inch Type CL, 1- and 2-pole ✓ ✓ ✓ ✓ ✓ Circuit Breakers ✓ Classified Replacement Circuit Breakers configurations. 120/240 Vac. Classified as direct replacements by Underwriters Laboratories. 15-year warranty. Available in clamshell packaging. Classified arc fault and ground fault breakers available. Catalog Numbering System TABLE 1-28. CATALOG NUMBERING SYSTEM CHQ 1 20 GF CS Type Poles CHQ = 3/4-Inch (19.1 mm) — Square D CL = 1-Inch (25.4 mm) 1 = 1-Pole 2 = 2-Pole CHQ — Classified breakers for use in Square D QO Loadcenters. CL — Classified breakers for use in Square D Homeline, GE, Siemens, Murray, Thomas & Betts, and Crouse-Hinds Loadcenters. Packaging CS = Clamshell Amperes 15 = 15 20 = 20 25 = 25 30 = 30 35 = 35 40 = 40 45 = 45 50 = 50 60 = 60 Breaker Type GF = Ground Fault AF = Arc Fault All except GFCB Type, 5 mA protection. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-19 Data Tables TABLE 1-29. TYPE CHQ CLASSIFIED BREAKERS 3/4-INCH (19.1 MM) PER POLE 120 OR 120/240 VAC, 10 kAIC TABLE 1-32. TYPE CL BREAKERS, 1-INCH (25.4 MM) PER POLE — CLAMSHELLS 2-Pole 120/240 V Common Trip Requires One Requires Two 1-Inch (25.4 mm) Space 1-Inch (25.4 mm) Spaces 10 per Shelf Carton 5 per Shelf Carton Wire Size 10 kAIC Range Cu/Al 60ºC Catalog UPC Number Code or 75°C 15 (1) #14 – 8 20 (2) #14 – 10 25 30 35 40 45 50 60 CHQ115 CHQ120 CHQ125 CHQ130 CHQ135 CHQ140 CHQ145 CHQ150 — 10 kAIC Catalog UPC Number Code 782113010816 782113010823 782113010830 782113010847 782113010854 782113010861 782113010878 782113010885 — CHQ215 CHQ220 CHQ225 CHQ230 CHQ235 CHQ240 CHQ245 CHQ250 CHQ260 782113010892 782113010908 782113010915 782113010922 782113010939 782113010946 782113010953 782113010960 782113010977 Ampere Rating 2-Pole 120/240 Vac Common Trip Requires One 3/4-Inch Requires Two 3/4-Inch (19.1 mm) Space (19.1 mm) Spaces Ampere Rating Circuit Breakers 1-Pole 120/240 V 1-Pole 120/240 Vac Wire Size Range Cu/Al 60°C or 75°C 15 #14 – 4 20 30 40 50 6 per Shelf Carton 3 per Shelf Carton Wire Size 10 kAIC Range Cu/Al 60ºC Catalog Number or 75°C 15 (1) #14 – 8 20 (2) #14 – 10 30 40 50 60 10 kAIC CHQ115CS CHQ120CS CHQ130CS CHQ140CS CHQ150CS — UPC Code Catalog Number UPC Code 782114752906 782114752913 782114752920 782116630684 782116630691 — CHQ215CS CHQ220CS CHQ230CS CHQ240CS CHQ250CS CHQ260CS 782114752937 782114752944 782114752951 782114752968 782114752975 782114752982 TABLE 1-31. TYPE CL BREAKERS, 1-INCH (25.4 MM) PER POLE 2-Pole 120/240 V Common Trip Requires One Requires Two 1-Inch (25.4 mm) Space 1-Inch (25.4 mm) Spaces Ampere Rating 1-Pole 120/240 V Wire Size Range Cu/Al 60°C or 75°C 15 #14 – 4 20 25 30 35 40 45 50 1-20 10 per Shelf Carton 5 per Shelf Carton 10 kAIC 10 kAIC Catalog UPC Number Code Catalog Number UPC Code CL215 CL220 CL225 CL230 CL235 CL240 CL245 CL250 786676011624 786676011631 786676011648 786676011655 786676011662 786676011679 786676011686 786676011693 CL115 CL120 CL125 CL130 CL135 CL140 CL145 CL150 786676011549 786676011556 786676011563 786676011570 786676011587 786676011594 786676011600 786676011617 10 kAIC 10 kAIC Catalog UPC Number Code Catalog UPC Number Code CL115CS CL120CS CL130CS CL140CS CL150CS CL215CS CL220CS CL230CS CL240CS CL250CS 782114753026 782114753033 782114753040 782116630431 782116630448 1-Pole 120/240 V Ampere Rating Ampere Rating Requires One 3/4-Inch (19.1 mm) Space 2-Pole 120/240 Vac Common Trip Requires Two 3/4-Inch (19.1 mm) Spaces 3 per Shelf Carton 782114753057 782114753064 782114753071 782114753088 782114753095 TABLE 1-33. TYPE CL CLASSIFIED LATCHING REMOTE CONTROL SMART BREAKERS姠, 1-INCH (25.4 MM) PER POLE TABLE 1-30. TYPE CHQ CLASSIFIED BREAKERS 3/4-INCH (19.1 MM) PER POLE 120 OR 120/240 VAC, 10 kAIC — CLAMSHELLS 1-Pole 120/240 Vac 6 per Shelf Carton Wire Size Range Cu/Al 60°C or 75°C 15 #14 – 4 20 25 30 Requires One 1-Inch (25.4 mm) Space 2-Pole 120/240 V Common Trip Requires Two 1-Inch (25.4 mm) Spaces 10 per Shelf Carton 5 per Shelf Carton 10 kAIC 10 kAIC Catalog UPC Number Code Catalog UPC Number Code CLRP115 CLRP120 CLRP125 CLRP130 782116062454 782116062461 782116062478 782116062485 CLRP215 CLRP220 CLRP225 CLRP230 782116062492 782116062508 782116062415 782116062422 ACCESSORIES TABLE 1-34. TYPE CHQ FIELD INSTALLATION KITS AND PARTS Description Type CHQ 2-Pole Plug-in Surge Arrester (Clamshell) Catalog Number UPC Code CHQSACS 782114753422 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Data Tables Catalog Number UPC Code 782114982150 782114982167 786676011570 — — — — — — #14 – 4 CL115GF #14 – 4 CL120GF #14 – 4 CL130GF 15 20 30 Wire Size Range Cu/Al 60°C or 75°C Ampere Rating TABLE 1-36. TYPE CLASSIFIED 1-INCH (25.4 MM), 10 KAIC, GROUND FAULT — CLAMSHELLS 1-Pole Requires One 1-Inch (25.4 mm) Space 2-Pole Requires One 1-Inch (25.4 mm) Space 6 per Shelf Carton 3 per Shelf Carton Catalog Number Catalog Number UPC Code #14 – 4 CL115GFCS 782114753149 — #14 – 4 CL120GFCS 782114753156 — #14 – 4 CL130GFCS 782114982174 — UPC Code — — — 15 20 1 per Shelf Carton Catalog Number UPC Code Catalog Number UPC Code CHQ115GF CHQ120GF CHQ130GF — 782114086032 782114086049 782114086063 — — — — CHQ250GF — — — 782114086186 Wire Size Range Cu/Al 60°C or 75°C Ampere Rating TABLE 1-38. TYPE CLASSIFIED 3/4-INCH (19.1 MM), 10 KAIC, GROUND FAULT — CLAMSHELLS 1-Pole Requires One 3/4-Inch (19.1 mm) Space 2-Pole Requires One 3/4-Inch (19.1 mm) Space 6 per Shelf Carton 3 per Shelf Carton Catalog Number Catalog Number UPC Code UPC Code 1 per Shelf Carton Catalog Number UPC Code Catalog Number UPC Code 782113982588 782113982618 — — — — #14 – 4 CL115AF #14 – 4 CL120AF 1-Pole Requires One 1-Inch (25.4 mm) Space 2-Pole Requires One 1-Inch (25.4 mm) Space 6 per Shelf Carton 1 per Shelf Carton Catalog Number Catalog Number UPC Code UPC Code — — TABLE 1-41. TYPE CLASSIFIED 3/4-INCH (19.1 MM), 10 kAIC, ARC FAULT Ampere Rating Wire Size Range Cu/Al 60°C or 75°C #14 – 8 #14 – 10 #14 – 10 #14 – 10 1 per Shelf Carton 1 per Shelf Carton 15 #14 – 4 CL115AFCS 782114753217 — 20 #14 – 4 CL120AFCS 782114753224 — 1-Pole Requires One 3/4-Inch (19.1 mm) Space 2-Pole Requires One 3/4-Inch (19.1 mm) Space 1 per Shelf Carton 1 per Shelf Carton Catalog Number Catalog Number UPC Code 15 #14 – 4 CHQ115AF 782116010622 — 20 #14 – 4 CHQ120AF 782116010639 — UPC Code — — TABLE 1-42. TYPE CLASSIFIED 3/4-INCH (19.1 MM) 10 kAIC, ARC FAULT — CLAMSHELLS Ampere Rating Ampere Rating 15 20 30 50 2-Pole Requires One 3/4-Inch (19.1 mm) Space 2-Pole Requires One 1-Inch (25.4 mm) Space TABLE 1-40. TYPE CLASSIFIED 1-INCH (25.4 MM), ARC FAULT — CLAMSHELLS TABLE 1-37. TYPE CLASSIFIED 3/4-INCH (19.1 MM), 10 KAIC, GROUND FAULT 1-Pole Requires One 3/4-Inch (19.1 mm) Space 1-Pole Requires One 1-Inch (25.4 mm) Space Circuit Breakers UPC Code Wire Size Range Cu/Al 60°C or 75°C Catalog Number Wire Size Range Cu/Al 60°C or 75°C 1 per Shelf Carton Wire Size Range Cu/Al 60°C or 75°C 1 per Shelf Carton Wire Size Range Cu/Al 60°C or 75°C 2-Pole Requires One 1-Inch (25.4 mm) Space Ampere Rating 1-Pole Requires One 1-Inch (25.4 mm) Space TABLE 1-39. TYPE CLASSIFIED 1-INCH (25.4 MM), 10 kAIC, ARC FAULT Ampere Rating 15 20 30 Wire Size Range Cu/Al 60°C or 75°C Ampere Rating TABLE 1-35. TYPE CLASSIFIED 1-INCH (25.4 MM), 10 KAIC, GROUND FAULT 1-Pole Requires One 3/4-Inch (19.1 mm) Space 2-Pole Requires One 3/4-Inch (19.1 mm) Space 6 per Shelf Carton 6 per Shelf Carton Catalog Number Catalog Number UPC Code 15 #14 – 4 CHQ115AFCS 782116010592 — 20 #14 – 4 CHQ120AFCS 782116010608 — UPC Code — — 15 #14 – 8 CHQ115GFCS 782114752999 CHQ215GFCS 782116630806 20 #14 – 10 CHQ120GFCS 782114753002 CHQ220GFCS 782116630813 30 #14 – 10 CHQ130GFCS 782114753019 CHQ230GFCS 782116630820 40 #14 – 8 — 50 #14 – 10 — 60 #14 – 10 — — — — CHQ240GFCS 782116630837 CHQ250GFCS 782116630844 CHQ260GFCS 782116630851 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-21 Related Products TABLE 1-43. CIRCUIT BREAKERS 3/4-Inch Breakers (19.1 mm) 1-Inch Breakers (25.4 mm) Circuit Breakers CH Breakers Square D — QO BR Breakers Siemens GE Square D — HOMELINE CH115 CH120 CH130 QO115 QO120 QO130 BR115 BR120 BR130 Q115 Q120 Q130 THQL1115 THQL1120 THQL1130 HOM115 HOM120 — CH210 CH2100 CH2125 QO210 QO2100 QO2125 — BR2100 BR2125 — Q2100 Q2125 — THQL21110 THQL21125 — HOM2100 HOM2125 CH215 CH220 CH225 QO215 QO220 QO225 BR215 BR220 BR225 Q215 Q220 Q225 THQL2115 THQL2120 THQL2125 HOM215 HOM220 HOM225 CH230 CH240 CH250 QO230 QO240 QO250 BR230 BR240 BR250 Q230 Q240 Q250 THQL2130 THQL2140 THQL2150 HOM230 HOM240 HOM250 CH260 CH270 CH280 QO260 QO270 QO280 BR260 BR270 BR280 Q260 Q270 Q280 THQL2160 THQL2170 THQL2180 HOM260 HOM270 — CH3100 CH320 CH330 QO3100 QO320 QO330 BR3100 BR320 BR330 Q3100 Q320 Q330 THQL32100 THQL32020 THQL32030 — — — CH340 CH350 CH360 QO340 QO350 QO360 BR340 BR350 BR360 Q340 Q350 Q360 THQL32040 THQL32050 THQL32060 — — — CHNT1515 CHNT2020 — — BR1515 BR2020 — — — — — — CHQ120 CHQ230 QO120 QO230 — — — — — — — — CHT1515 CHT1520 CHT2020 QOT1515 — QOT2020 BD1515 BD1520 BD2020 Q1515 Q1520 Q2020 — — — HOMT1515 HOMT1520 HOMT2020 CHQ120 CHQ230 — QO120 QO230 — — — BQ230240 Q120 Q230 — TQ1120 TQ2130 — — — — — — — — BQ220230 BD3020 Q23020 Q2030 — — — — Note: These products are by no means equivalent but functionally similar. This is a cross-reference tool not an interchangeability chart. TABLE 1-44. GROUND FAULT BREAKERS 1-22 3/4-Inch Breakers (19.1 mm) 1-Inch Breakers (25.4 mm) CH Breakers Square D — QO BR Breakers Siemens GE Square D — HOMELINE CH115GF CH120GF CH220GF QO115GFI QO120GFI QO220GFI GFCB115 GFCB120 GFCB220 QF115 QF120 QF220 THQL1115GF THQL1120GF THQL2120GF1 HOM115GFI HOM120GFI HOM220GFI CH230GF CH240GF CH250GF CH260GF QO230GFI QO240GFI QO250GFI QO260GFI GFCB230 GFCB240 GFCB250 — QF230 QF240 QF250 QF260 THQL2130GF1 THQL2140GF1 THQL2150GF1 — HOM230GFI HOM240GFI HOM250GFI — EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Breaker Application Chart Circuit Breaker Amperes Gauge No. Wires w/ Ground Cutler-Hammer 1-Inch Cutler-Hammer 3/4-Inch GE/Siemens Square D Homeline Square D QO 120/240 50 6/3 BR250 CH250 CL250 CHQ250 12,000 120/240 50 6/3 BR250 CH250 CL250 CHQ250 Built-in Oven 4,500 120/240 30 10/3 BR230 CH230 CL230 CHQ230 Range Top 6,000 3,300 120/240 120/240 30 20 10/3 12/3 BR230 BR220 CH230 CH220 CL230 CL220 CHQ230 CHQ220 Clothes Dryer 5,000 120/240 30 10/3 BR230 CH230 CL230 CHQ230 Water Heater 4,500 120/240 30 10/3 BR230 CH230 CL230 CHQ230 Appliance Central Air/Heat Pump Range Typical Watts Voltage 6,000 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 Circuit Breakers TABLE 1-45. CH BREAKERS TO USE IN CUTLER-HAMMER, GE/SIEMENS/SQUARE D HOMELINE AND SQUARE D QO LOADCENTERS — 2-POLE CIRCUIT BREAKER APPLICATIONS 1-23 CH Main Breakers Product Description Circuit Breakers The main circuit breaker protects the entire loadcenter. It can also be used as a service disconnect. The main breaker delivers electricity to the branch circuit breakers within the loadcenter. It is either factory installed or sold separately depending on the model and application. Features, Functions and Benefits ✓ Full range from 100 to 225 amperes, CH Main Breaker ✓ ✓ ✓ ✓ ✓ 120/240 volts. 25 kAIC, 42 kAIC and 100 kAIC available. Approved for service entrance. Include line lugs only as standard. 15-year warranty. Meet UL 489, CSA, NEMA standards, Federal Spec Classification W-C 375 b/ GEN. Catalog Numbering System TABLE 1-46. CATALOG NUMBERING SYSTEM CSR 2 125 N Type Poles CSR 2 = 2-Pole Amperes 100 = 100 125 = 125 150 = 150 175 = 175 200 = 200 225 = 225 CH Main Breaker Loadcenter 1-24 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 TABLE 1-50. TYPE CC CIRCUIT BREAKERS 240 VAC — 10 kAIC FOR USE IN TYPE ECC UNIT ENCLOSURES Wire Size Range Cu/Al 60°C or 75°C Ampere for Line Rating Terminals Number of Poles Catalog Number UPC Code CSR2100 CSR2125N CSR2150N CSR2175N CSR2200N CSR2225N 782116061112 782114019733 782113098449 782113098456 782113098463 782114106242 25 kAIC 100 125 150 175 200 225 #2 – 300 kcmil 2 Accessories Description Volts Catalog Number Suffix Adder 12 24 120 SR12 SR24 SR01 Shunt Trip CSR CSR CSR — — AL1 AL2 Ampere Rating CC2100 CC2125 CC2150 782113386546 CC2100HM 782113828589 782113266565 CC2125HM 782113828596 782113266572 CC2150HM 782113828602 175 #2/0 – 300 CC2175 200 kcmil CC2200 225 CC2225 782113266589 CC2175HM 782113828619 782113266596 CC2200HM 782113828626 782113266602 CC2225HM 782113828633 100 #4 – 4/0 125 150 CC3100 CC3125 CC3150 782113386553 CC3100HM 782113828640 782113266619 CC3125HM 782113828657 782113266626 CC3150HM 782113828664 175 #2/0 – 300 CC3175 200 kcmil CC3200 225 CC3225 782113266633 CC3175HM 782113828671 782113266640 CC3200HM 782113828688 782113266657 CC3225HM 782113828695 — CR1 Wire Size Range Cu/Al 60°C or 75°C for Line Terminals Volts Catalog Number Suffix Adder 12 dc 24 dc 120 ac 208 ac 240 ac SR12 SR24 SR01 SR08 SR02 — AL1 — CR1 Shunt Trip TABLE 1-49. CSR LUG TREE KIT FOR REPLACEMENT PURPOSES ONLY FOR USE IN TYPE ECB UNIT ENCLOSURES 225 100 #4 – 4/0 125 150 Type Add suffix indicated to end of breaker catalog number. Description UPC Code 2-Pole Description Alarm Contact CSR Type CC UPC 10 kAIC Code TABLE 1-51. SHUNT TRIPS, AUXILIARY AND ALARM CONTACTS Auxiliary Contact CSR (1) NO and (1) NC CSR (2) NO and (2) NC Type CC Hi Mag 10 kAIC 3-Pole TABLE 1-48. SHUNT TRIPS, AUXILIARY, ALARM CONTACTS Type Catalog Number Circuit Breakers TABLE 1-47. TYPE CSR CIRCUIT BREAKERS 120/240 VAC — 25 kAIC FOR USE IN TYPE ECB UNIT ENCLOSURES Wire Size Range Cu/Al 60°C or 75°C for Line Terminals Related Products Ampere Rating Data Tables CC CC CC CC CC Auxiliary Contact CC (1) NO and (1) NC Catalog Number UPC Code For use on 125, #2 – 300 kcmil MCBK225 782114110591 150, 175, 200 and 225 Ampere CSR Breakers Alarm Contact CSR Add suffix indicated to end of breaker catalog number. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-25 BR Main Breakers Data Tables TABLE 1-53. TYPES BW AND BWH CIRCUIT BREAKERS 120/240 VAC — 25 kAIC FOR USE IN TYPE ECB UNIT ENCLOSURES Circuit Breakers Wire Size Range Ampere Number Cu/Al 60°C or 75°C Catalog Rating of Poles for Line Terminals Number UPC Code 10,000 AIC 100 125 150 175 200 225 BR Main Breaker 2 #2 – 300 kcmil BW2100 BW2125 BW2150 BW2175 BW2200 BW2225 782116061099 786676460361 786676460408 786676460507 786676460552 786679122556 2 #2 – 300 kcmil BWH2100 BWH2125 BWH2150 BWH2175 BWH2200 BWH2225 782116061105 786676460439 786676460453 786676449700 786676460606 786679122563 25,000 AIC 100 125 150 175 200 225 Accessories TABLE 1-54. SHUNT TRIPS, AUXILIARY AND ALARM CONTACTS Catalog Number Suffix Adder Description BR Main Breaker Loadcenter 12 Volts 24 Volts 120 Volts The main circuit breaker protects the entire loadcenter. It can also be used as a service disconnect. The main breaker delivers electricity to the branch circuit breakers within the loadcenter. It is either factory installed or sold separately depending on the model and application. Features, Functions and Benefits Full range from 125 to 225 amperes, 120/240 volts. 10 kAIC and 25 kAIC available. Approved for service entrance. Five-year warranty. Meet UL 489, CSA, NEMA standards, Federal Spec Classification W-C 375 b/GEN. Catalog Numbering System TABLE 1-52. CATALOG NUMBERING SYSTEM Type BW = 10 kAIC BWH = 22 kAIC (1) NO and (1) NC (2) NO and (2) NC Poles Amperes 2 = 2-Pole 100 = 100 125 = 125 150 = 150 175 = 175 200 = 200 225 = 225 AL1 AL2 Alarm Contacts for Types BW/BWH Types BW/BWH CR1 Alarm Contacts for Type GFCB (1-Pole) Alarm Contact for GFCB (1-Pole) (1) NO and (1) NC W1 W2 Add suffix indicated to end of breaker catalog number. TABLE 1-55. BW/BWH LUG TREE KIT FOR REPLACEMENT PURPOSES ONLY FOR USE IN TYPE ECB UNIT ENCLOSURES 225 BW 2 125 SR12 SR24 SR01 Auxiliary Contact for Types BW/BWH Ampere Rating Product Description ✓ ✓ ✓ ✓ ✓ Shunt Trip for Types BW/BWH Description Wire Size Range Cu/Al 60°C or 75°C for Line Terminals Catalog Number UPC Code For use on 125, #2 – 300 kcmil MCBK225 782114110591 150, 175, 200 and 225 Ampere BW and BWH Breakers Note: All packaged quantities or single units. 1-26 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 Features, Functions and Benefits ✓ Protects the entire main panel. ✓ Also can be used as a service disconnect. ✓ For use in single-phase and 3-phase loadcenters, ✓ ✓ ✓ ✓ ✓ 100 amperes and up. Full range from 100 to 225 amperes, 120/240 volts or 240 volts, 2- and 3-poles. 10 kAIC and 22 kAIC available. Five-year warranty. Meet UL 489, CSA, NEMA standards, Federal Spec Classification W-C 375 b/GEN. Plug-on circuit breaker. Catalog Numbering System Circuit Breakers BJ & BJH Main Breakers TABLE 1-56. CATALOG NUMBERING SYSTEM BJ & BJH Main Breakers BJ 2 125 Product Description Type BJ breakers are replacement main circuit breakers in some older Westinghouse姞 and Bryant loadcenters. They are more commonly used as branch circuit breakers in current style Type BR loadcenters. Amperes Poles BJ= 10 kAIC BJH= 22 kAIC 100 = 100 125 = 125 150 = 150 175 = 175 200 = 200 225 = 225 2 = 2-Pole 3 = 3-Pole Data Tables TABLE 1-57. TYPES BJ AND BJH BREAKERS, 1-INCH (25.4 MM) PER POLE, 120/240 OR 240 VAC, 10 AND 22 kAIC 2-Pole 120/240 Vac Common Trip Requires Four 1-Inch (25.4 mm) Spaces 3-Pole 240 Vac Common Trip Requires Six 1-Inch (25.4 mm) Spaces 10 per Shelf Carton 5 per Shelf Carton 10 kAIC 22 kAIC Ampere Rating Catalog Number UPC Code Catalog Number UPC Code 100 125 150 175 200 225 BJ2100 BJ2125 BJ2150 BJ2175 BJ2200 BJ2225 782116484294 786676367004 786676367103 786676367158 786676367202 786676367257 — BJH2125 BJH2150 BJH2175 BJH2200 BJH2225 — 786676367028 786676367127 786676367172 786676367226 786676367271 Wire Size Range Cu/Al 60°C or 75°C #2 – 300 kcmil 10 kAIC 22 kAIC Catalog Number UPC Code Catalog Number UPC Code — BJ3125 BJ3150 BJ3175 BJ3200 BJ3225 — 786676368308 786676368353 786676368407 786676368452 786676368506 — BJH3125 BJH3150 BJH3175 BJH3200 BJH3225 — 786676367455 786676367509 786676367554 786676367608 786676367653 Breaker uses two 1-inch (25.4 mm) pole spaces on left side and two 1-inch (25.4 mm) pole spaces on right side of loadcenter. Breaker uses three 1-inch (25.4 mm) pole spaces on left side and three 1-inch (25.4 mm) pole spaces on right side of loadcenter. Westinghouse is a registered trademark of Westinghouse Electric Company LLC. UL is a federally registered trademark of Underwriters Laboratories Inc. CSA is a registered trademark of the Canadian Standards Association. NEMA is the registered trademark and service mark of the National Electrical Manufacturers Association. National Electrical Code and NEC are registered trademarks of the National Fire Protection Association, Quincy, Mass. Square D is a federally registered trademark of Schneider Electric. Cutler-Hammer is a federally registered trademark of Eaton Corporation. Siemens is a federally registered trademark of Siemens AG. General Electric is a federally registered trademark of General Electric Company. Homeline is a registered trademark of Schneider Electric. Murray is a federally registered trademark of Siemens Energy & Automation, Inc. Thomas & Betts is a federally registered trademark of Thomas & Betts Corporation. Crouse-Hinds is a federally registered trademark of Cooper Industries. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — ©Copyright 2005 1-27 Circuit Breakers 1-28 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Circuit Breakers — Effective August 2005 CH 3/4” Single-Phase Main Breaker Loadcenters High Interrupting . . . . . . . . . . . . . . . . . . . . . . 2-4 Main Lug Only . . . . . . . . . . . . . . . . . . . . . . . . 2-6 CH 3/4” Three-Phase Loadcenters Main Breaker . . . . . . . . . . . . . . . . . . . . . . . . . 2-8 Main Lug Only . . . . . . . . . . . . . . . . . . . . . . . . 2-9 CH 3/4” Single-Phase Convertible Loadcenters Indoor. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-10 Outdoor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-11 CH Single-Phase Main Breaker Value Packs . . . . 2-12 Enclosed Circuit Breakers and Main Breakers . . . . 2-13 CH 3/4” Loadcenter Accessories . . . . . . . . . . . . 2-15 CH 3/4” Mechanical Interlock Covers. . . . . . . . . 2-17 CH 3/4” Technical Data and Specifications . . . . . 2-18 BR 1” Single-Phase Loadcenters Main Breaker . . . . . . . . . . . . . . . . . . . . . . . . 2-23 Main Lug Only . . . . . . . . . . . . . . . . . . . . . . . . 2-25 Main Lug Only — Non-Metallic . . . . . . . . . . . 2-27 Copper Bus . . . . . . . . . . . . . . . . . . . . . . . . . . 2-27 BR 1” Three-Phase Loadcenters Main Breaker . . . . . . . . . . . . . . . . . . . . . . . . 2-28 Main Lug Only . . . . . . . . . . . . . . . . . . . . . . . . 2-29 BR 1” Convertible Loadcenters Copper Bus . . . . . . . . . . . . . . . . . . . . . . . . . . 2-30 BR 1” New York City Approved Loadcenters . . . 2-34 BR 1” Single-Phase Value Packs. . . . . . . . . . . . . 2-35 Enclosed Circuit Breakers and Main Breakers . . . . 2-37 BR 1” Loadcenter Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . 2-39 Technical Data and Specifications . . . . . . . . . 2-41 CH 3/4” Surge Loadcenters . . . . . . . . . . . . . . . . 2-44 Loadcenters CH Loadcenters CH Loadcenters Product Description A loadcenter is called a breaker box, electrical box or even a fuse box. The main function is to take electricity supplied by the utility and distribute it throughout the home to feed lights and receptacles. Not only does the loadcenter distribute power, it also provides protection. Warranty ✓ Lifetime warranty on all CH loadcenters. ✓ Lifetime warranty on branch breakers. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-1 Loadcenters Cutler-Hammer Type CH Breaker Family Single-Phase Main Circuit Breaker Indoor Enclosure Cutler-Hammer Type CH Convertible Main Breaker or Main Lug Only Family Three-Phase Main Circuit Breaker Outdoor Enclosure Separately Packaged Covers Single-Phase Main Circuit Breaker Bottom Feed — Indoor Enclosure 2-2 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Features, Benefits and Functions Extra 1.5-inch (38.1 mm) Knockout for Bundling Provides for easier installation, less installation time. Single Keyhole Mounting ■ Straight-in wiring saves labor and material. ■ Only one panel for either application — no modifications necessary. Unique Sandalwood Finish Immediately recognizable, aesthetically appealing, scratch resistant powder coating. Separately Packaged Covers ■ Full line of “true” surface and combination covers. ■ Built-in flush leveling feature. ■ Choice of circuit identification by breaker labels or circuit directory. Commercial Grade Main Breaker ■ 25 kAIC series rated main breaker in 150 and 200 ampere loadcenters. ■ 42 and 100 kAIC series ratings available. Loadcenters Just one keyhole at top and bottom for easier mounting and leveling. Top or Bottom Feed Drywall Marking on Enclosure Indicates proper mounting depth for flush applications. Neutral Design (For styles as indicated) ■ Bonding strap is easily removable for sub-panel applications providing a ground and neutral. ■ Factory bonded for service entrance applications providing a split neutral. ■ Ample additional 2/0 lugs provided; no kits necessary. ■ 200% size neutral. Single-Piece Silver Flash-Plated Copper Bus Provides superior conductivity throughout the entire product line. Steel Backpan ■ Provides positive, reliable breaker mounting. ■ Single-piece designed for stability. Convertible Styles Available Improved Endwall Knockouts ■ Uses field-installable main breaker or main lug kits. ■ Flexible inventory — same breaker is used in loadcenter and circuit breaker enclosures. Larger KOs are balanced to enhance installed appearance and to ease use of existing wiring. Type CH Loadcenter EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-3 Catalog Numbering System TABLE 2-1. LOADCENTERS 100 – 225 AMPERES AND 12 – 42 CIRCUITS CATALOG NUMBERING SYSTEM CH 42 B Loadcenter Type Loadcenters Type CH 3/4-inch (19.1 mm) Branch Circuit Breakers CH 8 K F 200 K P Number of Circuits Bus Amperes Selection Circuits 40 70 100 125 150 200 225 2 4 8 12 14 16 18 20 22 24 28 30 32 42 TABLE 2-2. INDOOR COVERS ORDERED SEPARATELY Box Sizes B C D E G J K L R = Outdoor (No Cover) Type CH Packaged for Retail. Includes Cover. Mounting Loadcenter Cover Series F = Combination Flush/Surface S = Surface Box Size Indicated in Loadcenter Catalog Number For catalog numbers not ending with a “P”. Phases Note: All combinations are not valid, refer to the catalog section. Blank = Single-Phase 3 = Three-Phase Main Device L = Main Lug Only B = Main Breaker N = Convertible H = High AIC Main Breaker Data Tables SINGLE-PHASE — MAIN CIRCUIT BREAKER LOADCENTERS — 10,000/22,000/25,000 AMPERES INTERRUPTING CAPACITY CH 10 kAIC Maximum Number 3/4-Inch (19.1 mm) Encl. Space Poles Type Box Size Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Main Breaker Type Main Ampere Rating TABLE 2-3. SINGLE-PHASE 3-WIRE — 120/240 VAC — FACTORY BONDED SPLIT NEUTRAL Loadcenter Catalog Number Loadcenter Cover UPC Code Combination Surface Catalog UPC Number Code Catalog UPC Number Code 100 22 22 Indoor C #6 – 1/0 CH22B100CP 782114007648 Included — 125 22 22 Indoor C CSR 150 25 kAIC 200 32 32 32 42 32 42 Indoor J #2 – 300 CH32B150JP 782114007655 Included — kcmil Indoor J CH32B200JP 782114007662 Included — Indoor K CH42B200KP 782114007679 Included — CH22B125C 782113097633 CH8CF — 782113098876 CH8CS — 782113098869 — — — — — — All main circuit breaker loadcenters are listed for use as service entrance equipment. Loadcenters are factory bonded for service entrance applications. Remove bonding strap for separate neutral and ground bars for sub-feed applications. Combination style covers may be used in surface or flush applications. Indoor loadcenters can be top or bottom fed by rotating the enclosure and trim – 180 degrees. 25 kAIC series combination rating is obtained when Types CH, CHT and CHP branch breakers are used with CSR main. P Suffix = Specifically packaged for retail sales. Dimensions for boxes on Pages 2-18 – 2-19. 2-4 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 SINGLE-PHASE — MAIN CIRCUIT BREAKER LOADCENTERS — 10,000/22,000/25,000 AMPERES INTERRUPTING CAPACITY TABLE 2-4. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL 100 14 14 18 18 22 30 30 14 14 18 18 22 30 30 Indoor Outdoor Indoor Outdoor Outdoor Indoor Outdoor B B C C C D D #6 – 1/0 CH14B100BP CH14B100R CH18B100C CH18B100R CH22B100R CH30B100D CH30B100R 125 22 30 30 22 30 30 Outdoor C Indoor D Outdoor D #6 – 1/0 CH22B125R CH30B125D CH30B125R 782113097640 — 782113097831 CH8DF 782113317069 — — — 782113098890 CH8DS — — — 782113098883 — 150 8 24 24 32 8 24 24 32 Outdoor Indoor Outdoor Outdoor E E E J #2 – 300 CH8B150RF  kcmil CH24B150E CH24B150R CH32B150R 782113098425 782113097756 782113097763 782113098098 — CH8EF — — — 782113098913 — — — CH8ES — — — 782113098906 — — 200 8 24 24 32 42 8 24 24 32 42 Outdoor Indoor Outdoor Outdoor Outdoor E E E J K #2 – 300 CH8B200RFP  kcmil CH24B200E CH24B200R CH32B200R CH42B200R 782114007686 782113097770 782113097787 782113098135 782113098227 Included CH8EF — — — — 782113098913 — — — — CH8ES — — — — 782113098906 — — — 225 32 32 42 42 32 32 32 32 Indoor Outdoor Indoor Outdoor J J K K #2 – 300 CH32B225J kcmil CH32B225R CH42B225K CH42B225R 782114262856 782113098159 782114227473 782113098395 CH8JF — CH8KF — 782113098951 — 782113098975 — CH8JS — CH8KS — 782113098944 — 782113098968 — Catalog Number Combination Surface UPC Code Catalog UPC Number Code Catalog UPC Number Code 782114007631 782113097435 782113097565 782113097558 782113097626 782113097794 782113097824 Included — CH8CF — — CH8DF — — — 782113098876 — — 782113098890 — Included — CH8CS — — CH8DS — — — 782113098869 — — 782113098883 — Loadcenters Wire Size Range Cu/Al 60°C or 75°C for Main Breaker CSR 25 kAIC Loadcenter Cover Box Size CH 10 kAIC Loadcenter Encl. Space Poles Type Main Ampere Rating Main Breaker Type Maximum Number 3/4-Inch (19.1 mm) All main circuit breaker loadcenters are listed for use as service entrance equipment. Combination style covers may be used in surface or flush applications. Indoor loadcenters can be top or bottom fed by rotating the enclosure and trim – 180 degrees. Rainproof panels are furnished with hub closure plates.  Panel includes #4 – 300 kcmil feed-through lugs. 25 kAIC series combination rating is obtained when Types CH, CHT and CHP branch breakers are used with CSR main. P Suffix = Specifically packaged for retail sales. LD 10 kAIC Encl. Space Poles Type Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Maximum Number 3/4-Inch (19.1 mm) Box Size Main Breaker Type Main Ampere Rating TABLE 2-4. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL (CONTINUED) Commercial Loadcenter Loadcenter Cover Flush Catalog Number UPC Code Catalog Number Surface UPC Code Catalog UPC Number Code 300 42 42 Indoor PM (2) 400 – CH42PM300 782113218113 CH7PMF 782113218588 CH7PMS 782113218571 500 kcmil 400 42 42 Indoor PM (2) 400 – CH42PM400 782113218304 CH7PMF 782113218588 CH7PMS 782113218571 500 kcmil All main circuit breaker loadcenters are listed for use as service entrance equipment. This cover is for flush applications only (not combination). P Suffix = Specifically packaged for retail sales and comes with a combination cover that can be used for surface or flush mount applications. Dimensions for boxes on Pages 2-18 – 2-19. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-5 SINGLE-PHASE — MAIN CIRCUIT BREAKER LOADCENTERS 42,000/100,000 AMPERES INTERRUPTING CAPACITY Encl. Space Poles Type 100 20 20 28 28 20 20 28 28 Indoor Outdoor Indoor Outdoor C C D D 125 28 28 28 28 CHH 150 100 kAIC 32 32 200 225 Main Breaker Type CHB4 42 kAIC Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Maximum Number 3/4-Inch (19.1 mm) Box Size Loadcenters Main Ampere Rating TABLE 2-5. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Loadcenter Loadcenter Cover Combination Surface Catalog UPC Number Code Catalog Number UPC Code Catalog UPC Number Code #6 – 1/0 CH20H100C CH20H100R CH28H100D CH28H100R 782113097589 782113097596 782113097800 782113097817 CH8CF — CH8DF — Indoor D Outdoor D #6 – 1/0 32 32 32 32 42 42 42 42 CH8CS — CH8DS — 782113098869 — 782113098883 — CH28H125D 782113097848 CH8DF CH28H125R 782113097855 — 782113098890 CH8DS — — 782113098883 — Indoor L Outdoor L #2/0 – 300 CH32H150L 782113098067 CH8LF kcmil CH32H150R 782113098074 — 782113098999 CH8LS — — 782113098982 — 32 32 42 42 Indoor Outdoor Indoor Outdoor #2/0 – 300 CH32H200L kcmil CH32H200R CH42H200L CH42H200R 782113098999 — 782113098999 — CH8LS — CH8LS — 782113098982 — 782113098982 — 42 42 Indoor L Outdoor L 782113098999 CH8LS — — 782113098982 — L L L L 782113098104 782113098111 782113098197 782113098203 CH8LF — CH8LF — #2/0 – 300 CH42H225L 782113098364 CH8LF kcmil CH42H225R 782113098371 — 782113098876 — 782113098890 — All main circuit breaker loadcenters are listed for use as service entrance equipment. Combination style covers may be used in surface or flush applications. Series rated for 42 kAIC with all CH, CHT and CHP breakers. Indoor loadcenters can be top or bottom fed by rotating the enclosure and trim – 180 degrees. Rainproof panels are furnished with hub closure plates. Series rated for 100 kAIC with all CH, CHT and CHP breakers. SINGLE-PHASE — MAIN LUG LOADCENTERS TABLE 2-6. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Main Ampere Rating Maximum Number 3/4-Inch (19.1 mm) Space Poles Enclosure Type Type of Trim (Included) Box Size Wire Size Range Cu/Al 60°C or 75°C for Main Lugs Loadcenter Catalog Number UPC Code 40 2 2 2 4 4 4 Indoor Outdoor Indoor Surface no Door — Flush no Door 5 5R 5 #14 – 6 CH2L40SP CH2L40RP CH2L40FP 782114190418 782114190425 782114190401 70 2 2 2 4 4 4 Indoor Outdoor Indoor Surface no Door — Flush no Door 5 5R 5 #14 – 2 CH2L70SP CH2L70RP CH2L70FP 782114190449 782114190456 782114190432 125 2 2 2 4 4 4 Indoor Outdoor Indoor Surface no Door — Flush no Door 6 6R 6 #14 – 1/0 CH2L125SP CH2L125RP CH2L125FP 782114190470 782114190487 782114294444 4 4 4 8 8 8 Indoor Outdoor Indoor Surface no Door — Flush no Door 7 7R 7 #14 – 1/0 CH4L125SP  CH4L125RP  CH4L125FP  782114190500 782114190517 782114190494 8 8 8 16 16 16 Indoor Outdoor Indoor Surface no Door — Flush no Door 7 7R 7 #6 – 1/0 CH8L125SP  CH8L125RP  CH8L125FP  782114190531 782114190548 782114190524 Requires the use of CHNT breakers. Suitable for use as service equipment when not more than two service disconnecting mains are provided or when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC姞). Rainproof panels are furnished with hub closure plates.  Suitable for use as service equipment when not more than two service disconnecting mains are provided or when not more than six service disconnecting mains are provided and when not used as a lighting and appliance panelboard (see Article 408.34 of the NEC).  Suitable for use as service equipment when a main breaker is used or when not more than six service disconnecting mains are provided and when not used as a lighting and appliance panelboard (see Article 408.34 of the NEC). P Suffix = Specifically packaged for retail sales. Dimensions for boxes on Pages 2-18 – 2-19. 2-6 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 SINGLE-PHASE — MAIN LUG LOADCENTERS 42,000/100,000 AMPERES INTERRUPTING CAPACITY Encl. Poles Type 125 12 12 16 16 20 20 24 24 12 12 16 16 20 20 24 24 Indoor Outdoor Indoor Outdoor Indoor Outdoor Indoor Outdoor B B B B C C C C 150 24 24 32 32 24 24 32 32 Indoor Outdoor Indoor Outdoor 200 12 12 16 16 12 12 16 16 225 24 24 32 32 42 42 400 42 Loadcenter Loadcenter Cover Combination Surface Catalog Number UPC Code Catalog Number UPC Code Catalog UPC Number Code #6 – 2/0 CH12L125BP CH12L125RP  CH16L125B CH16L125R  CH20L125C CH20L125R  CH24L125CP CH24L125RP  782114007822 782114007839 782113097473 782113097480 782113097572 782113097602 782114007860 782114007877 Included Included CH8BF — CH8CF — Included — — — 782113098852 — 782113098876 — — — — — CH8BS — CH8CS — — — — — 782113098845 — 782113098869 — — — D D D D #4 – 300 kcmil CH24L150D CH24L150R  CH32L150D CH32L150R  782113097718 782113097725 782113098029 782113098050 CH8DF — CH8DF — 782113098890 — 782113098890 — CH8DS — CH8DS — 782113098883 — 782113098883 — Indoor Outdoor Indoor Outdoor D D D D #4 – 300 kcmil CH12L200D CH12L200R  CH16L200D CH16L200R  782113097398 782113097404 782113097497 782113097503 CH8DF — CH8DF — 782113098890 — 782113098890 — CH8DS — CH8DS — 782113098883 — 782113098883 — 24 24 32 32 42 42 Indoor Outdoor Indoor Outdoor Indoor Outdoor D D D D G G #4 – 300 kcmil CH24L225D CH24L225R  CH32L225DP CH32L225R  CH42L225GP CH42L225RP  782113097732 782113097749 782114107768 782113098043 782114007945 782114007952 CH8DF — Included — Included — 782113098890 — — — — — CH8DS — — — — — 782113098883 — — — — — 42 Indoor P (2) 1/0 – CH42PL400 300 kcmil (1) 750 kcmil 782113342948 CH7PF 782113218564 CH7PS 782113218557 Loadcenters Space Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Maximum Number 3/4-Inch (19.1 mm) Box Size Main Ampere Rating TABLE 2-7. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Includes factory-installed ground bar. Requires the use of CHT breakers. Ground bar GBK14 is installed. Suitable for use as service equipment when a circuit breaker is used as a main breaker. The main breaker is backfed and requires hold-down bracket kit catalog number CH125RB. Suitable for use as service equipment when not more than six disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408.34 of the NEC).  Rainproof panels are furnished with hub closure plates. Suitable for use as service equipment when a circuit breaker is used as a main breaker. The main breaker is backfed and requires hold-down bracket kit catalog number CH125RB. Ground bar GBK21 is installed. Suitable for use as service equipment when a circuit breaker is used as a main breaker. The main breaker is backfed and must be a Type CHB. The breaker cannot be a Type CH. This cover is for flush application only (not combination). P Suffix = Specifically packaged for retail sales and comes with a combination cover that can be used for surface or flush mount applications. Dimensions for boxes on Pages 2-18 – 2-19. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-7 3-PHASE — MAIN CIRCUIT BREAKER LOADCENTERS 10,000/100,000 AMPERES INTERRUPTING CAPACITY CC 10 kAIC Encl. Type Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Box Size Poles Maximum Number 3/4-Inch (19.1 mm) Space Loadcenters Main Breaker Type Main Ampere Rating TABLE 2-8. 3-PHASE 4-WIRE — 208Y/120 VAC OR 240 VAC INSULATED/BONDABLE NEUTRAL Loadcenter Catalog Number Loadcenter Cover UPC Code Combination Surface Catalog Number Catalog UPC Number Code 150 30 30 30 30 Indoor L Outdoor L #1 – 4/0 200 30 30 42 42 30 30 42 42 Indoor Outdoor Indoor Outdoor L L L L #2/0 – CH30B3200L 300 kcmil CH30B3200R CH42B3200L CH42B3200R 782113097961 782113097992 782113098265 782113098296 225 30 30 42 42 30 30 42 42 Indoor Outdoor Indoor Outdoor L L L L CH30B3225L CH30B3225R CH42B3225L CH42B3225R 782113098005 782113098012 782113098302 782113098333 300 42 42 Indoor PM (2) 3/0 – CH424PM300 350 kcmil 782113218311 CH7PMF 782113218588 CH7PMS 782113218571 400 42 42 Indoor PM (2) 3/0 – CH424PM400 350 kcmil 782113218328 CH7PMF 782113218588 CH7PMS 782113218571 CHH 200 100 kAIC 30 30 42 42 30 30 42 42 Indoor Outdoor Indoor Outdoor L L L L 42 42 42 42 Indoor L Outdoor L LD 10 kAIC 225 CH30B3150L 782113097947 CH8LF CH30B3150R 782113097954 — UPC Code #2/0 – CH30H3200L 300 kcmil CH30H3200R CH42H3200L CH42H3200R 782113097978 782113097985 782113098272 782113098289 782113098999 CH8LS — — 782113098982 — CH8LF — CH8LF — 782113098999 — 782113098999 — CH8LS — CH8LS — 782113098982 — 782113098982 — CH8LF — CH8LF — 782113098999 — 782113098999 — CH8LS — CH8LS — 782113098982 — 782113098982 — CH8LF — CH8LF — CH42H3225L 782113098319 CH8LF CH42H3225R 782113098326 — 782113098999 — 782113098999 — CH8LS — CH8LS — 782113098982 — 782113098982 — 782113098999 CH8LS — — 782113098982 — All main circuit breaker loadcenters are listed for use as service entrance equipment. Rainproof loadcenters are furnished with hub closure plates. This cover for flush application only (not combination). 100 kAIC series combination rating is obtained when Types CH and CHP branch breakers are used with CHH main. Dimensions for boxes on Pages 2-18 – 2-19. 2-8 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 3-PHASE — MAIN LUG LOADCENTERS Loadcenter Catalog Number Loadcenter Cover UPC Code Combination Surface Catalog UPC Number Code Catalog UPC Number Code 125 6 6 6 12 Indoor 7 Surface #14 – 1/0 CH6L3125SP 12 Outdoor 7R — CH6L3125RP 12 Indoor 7 Flush CH6L3125FP 782114229231 — 782114229255 — 782114229248 — — — — — — — — — — 125 12 12 18 18 24 24 12 12 18 18 24 24 Indoor Outdoor Indoor Outdoor Indoor Outdoor B B C C C C — — — — — — #14 – 1/0 CH12L3125B CH12L3125R CH18L3125C CH18L3125R CH24L3125C CH24L3125R 782113097350 782113097367 782113097534 782113097541 782113097657 782113097664 782113098852 — 782113098876 — 782113098876 — CH8BS — CH8CS — CH8CS — 782113098845 — 782113098869 — 782113098869 — 150 30 30 30 30 Indoor D Outdoor D — — #4 – 300 kcmil CH30L3150D 782113097909 CH8DF CH30L3150R 782113097916 — 782113098890 CH8DS — — 782113098883 — 225 24 24 30 30 42 42 24 24 30 30 42 42 Indoor Outdoor Indoor Outdoor Indoor Outdoor D D D D G G — — — — — — #4 – 300 kcmil CH24L3225D CH24L3225R CH30L3225D CH30L3225R CH42L3225G CH42L3225R 782113098890 — 782113098890 — 782113098937 — CH8DS — CH8DS — CH8GS — 782113098883 — 782113098883 — 782113098920 — 400 42 42 Indoor P — (2) 1/0 – CH424PL400 300 kcmil (1) 750 kcmil 782113342955 CH7PF  782113218564 CH7PS 782113218557 782113097671 782113097688 782113097923 782113097930 782113098241 782113098258 CH8BF — CH8CF — CH8CF — CH8DF — CH8DF — CH8GF — Loadcenters Type of Trim Included Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Poles Encl. Type Box Size Maximum Number 3/4-Inch (19.1 mm) Space Main Ampere Rating TABLE 2-9. 3-PHASE 4-WIRE — 208Y/120 VAC OR 240 VAC INSULATED/BONDABLE NEUTRAL Requires the use of CHNT breakers. No door. Suitable for use as service equipment when not more than two service disconnecting means are provided or when not more than six service disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Ground bar GBK14 is installed. Suitable for use as service equipment when a circuit breaker is used as a main breaker. The main breaker is backfed and requires hold-down bracket kit catalog number CH125RB. Suitable for use as service equipment when not more than six service disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Rainproof panels are furnished with hub closure plates. Suitable for use as service equipment when a circuit breaker is used as a main breaker. The main breaker is backfed and requires hold-down kit catalog number CH125RB. Ground bar GBK21 is installed. Suitable for use as service equipment when a circuit breaker is used as a main breaker. The main breaker is backfed and must be a type CHB. The breaker cannot be a Type CH.  This cover is for flush application only (not combination). P Suffix = Specifically packaged for retail sales. Dimensions for boxes on Pages 2-18 – 2-19. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-9 CONVERTIBLE LOADCENTERS MAIN BREAKER OR MAIN LUG CENTER — BASE UNITS AND MAIN DEVICES 10,000/25,000 AMPERES INTERRUPTING CAPACITY — COMPLETE ASSEMBLY CONSISTS OF: LOADCENTER, COVER, AND EITHER MAIN BREAKER KIT OR MAIN LUG KIT Note: Interrupting rating depends on main circuit breaker selected. TABLE 2-10. INDOOR — SINGLE-PHASE 3-WIRE — 120/240 V — FACTORY BONDED SPLIT NEUTRAL — TOP OR BOTTOM FEED Loadcenter Cover Loadcenters Max. Main Ampere Rating Max. Number of Single Poles Box Size Loadcenter Box and Panel 125 22 C CH22N125C 782113098494 #10 – 1/0 CH8CF 782113098876 CH8CS 782113098869 10 200 32 J CH32N200J 782113098500 #4 – 300 kcmil CH8JF 782113098951 CH8JS 782113098944 25 225 42 K CH42N225K 782113098517 #4 – 300 kcmil CH8KF 782113098975 CH8KS 782113098968 25 Catalog UPC Number Code Combination Catalog UPC Wire Size Range Cu/Al 60°C or 75°C Number Code Surface Catalog UPC Number Code kAIC Rating Panel does not include main. Order main breaker or main lug kit separately. Loadcenters are factory bonded for service entrance applications. Remove bonding strap for separate neutral and ground bars for sub-feed applications. TABLE 2-11. MAIN LUG/MAIN BREAKER KIT Max. Main Ampere Rating Main Lug Kit Max. Number UPC of Single Catalog Number Code Poles Main Breaker Kit Wire Size Range Catalog Cu/Al 60°C or 75°C Number UPC Code kAIC Rating 125 22 CHL125N 782113098579 #10 –1/0 CH2100N CH2125N 782113098555 782113098562 10 200 32 CHL225N 782113098555 #2 – 300 kcmil CSR2125N CSR2150N CSR2175N CSR2200N 782114019733 782113098449 782113098456 782113098463 25 225 42 CHL225N 782114019733 #2 – 300 kcmil CSR2125N CSR2150N CSR2175N CSR2200N CSR2225N 782114019733 782113098449 782113098456 782113098463 782114106242 25 25 kAIC series combination rating is obtained when Types CH, CHT and CHP branch breakers are used with CSR main. CSR breakers include line lugs only as standard. Dimensions for boxes on Pages 2-18 – 2-19. 2-10 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 CONVERTIBLE LOADCENTERS MAIN BREAKER OR MAIN LUG CENTER — BASE UNITS AND MAIN DEVICES 10,000/25,000 AMPERES INTERRUPTING CAPACITY — COMPLETE ASSEMBLY CONSISTS OF: LOADCENTER, COVER, AND EITHER MAIN BREAKER KIT OR MAIN LUG KIT UPC Code CHL225N 782113098487 #2 – 300 kcmil Catalog Number UPC Code CSR2125N CSR2150N CSR2175N CSR2200N 782114019733 25 782113098449 782113098456 782113098463 200 8 E CH8N200RF 782113098418 #4 – 300 kcmil 125 22 C CH22N125R 782113098524 #10 – 1/0 CHL125N 782113098579 #10 – 1/0 CH2100N CH2125N 782113098555 10 782113098562 200 32 J CH32N200R 782113098531 #4 – 300 kcmil CHL225N 782113098487 #2 – 300 kcmil CSR2125N  CSR2150N  CSR2175N  CSR2200N  782114019733 25 782113098449 782113098456 782113098463 225 42 K CH42N225R 782113098548 #4 – 300 kcmil CHL225N 782113098487 #2 – 300 kcmil CSR2125N  CSR2150N  CSR2175N  CSR2200N  CSR2225N  782114019733 25 782113098449 782113098456 782113098463 782114106242 Loadcenters Catalog Number kAIC Rating UPC Code Main Breaker Kit Wire Size Range Cu/Al 60°C or 75°C Catalog Number Main Lug Kit Wire Size Range Cu/Al 60°C or 75°C Loadcenter Box and Panel Box Size Maximum Number of Single Poles Maximum Main Ampere Rating TABLE 2-12. OUTDOOR — SINGLE-PHASE 3-WIRE — 120/240 V — INSULATED/BONDABLE NEUTRAL Panel does not include main. Order main breaker or main lug kit separately. Rainproof panels are furnished with hub closure plates. Includes feed-through lugs for both phase and neutral conductors. 25 kAIC series combination rating is obtained when Types CH, CHT and CHP branch breakers are used with CSR main.  SR breakers include line lugs only as standard. Dimensions for boxes on Pages 2-18 – 2-19. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-11 VALUE PACKS TABLE 2-13. VALUE PACKS — SINGLE-PHASE — INDOOR — MAIN CIRCUIT BREAKER LOADCENTERS — COMBINATION COVER AND BREAKERS INCLUDED SINGLE-PHASE 3-WIRE — 120/240 VAC — FACTORY BONDED SPLIT NEUTRAL Loadcenters Main Breaker Type Maximum Main Ampere Rating Maximum Number 3/4-Inch (19.1 mm) Single Poles Wire Box Range Size Size Breakers Included Catalog Number UPC Code CH 10 kAIC 100 22 C #6 – 1/0 5-CH120 & 1-CH230 CH22B100V 782114290255 CSR 25 kAIC 200 200 32 42 J K #2 – 300 kcmil CH32B200V CH42B200V 782114290262 782114810880 Loadcenter Dimensions for boxes on Pages 2-18 – 2-19. 2-12 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Circuit Breaker Unit Enclosures CSR2200 Circuit Breaker TABLE 2-14. CIRCUIT BREAKER UNIT ENCLOSURES Unit Enclosure Main Circuit Ampere Breaker Rating Type Wire Size Range Cu/Al Encl. 60°C or 75°C Type Unit Enclosure Flush Cover Surface Cover Catalog Number Catalog Number UPC Code UPC Code Rainproof NEMA Type 3R Encl. Type Catalog Number Loadcenters CIRCUIT BREAKER UNIT ENCLOSURES 10,000/25,000 AMPERES INTERRUPTING CAPACITY UPC Code Type ECB Circuit Breaker Unit Enclosures — Order Type CSR Circuit Breaker Separately (Unit Enclosure Includes Lug Tree Kit) Single-Phase 3-Wire — 240 Vac Maximum 225 CSR 25 kAIC Indoor ECB225F 782113098753 ECB225S 782113098746 Outdoor ECB225R 782113098760 Type ECB Circuit Breaker Unit Enclosures — Includes Factory Installed CSR Circuit Breaker Single-Phase 3-Wire — 240 Vac Maximum 150 200 CSR2150N 25 kAIC — — — — — Outdoor ECB150RB 782114225240 CSR2200N 25 kAIC — — — — — Outdoor ECB200RB 782114225257 Type ECC Circuit Breaker Unit Enclosures — Order Type CC Circuit Breakers Separately Single-Phase 3-Wire/3-Phase 4-Wire — 240 Vac Maximum 225 CC 10 kAIC Indoor ECC225F 782114225196 ECC225S 782114225202 Outdoor ECC225R 782114225219 Wire size is determined by the circuit breaker installed in enclosure. Maximum wire size and ampere rating is determined by table below. Order circuit breaker separately. One ground lug accepting (1) #14 – #2 is factory installed. Also, there are pre-drilled holes to accept a GBK5 ground bar. Rainproof panels are furnished with hub closures plates. CSR2150N factory-installed circuit breaker. CSR2200N factory-installed circuit breaker. Maximum Ampere Rating Wire/Application Maximum Wire Size 200 Aluminum – Standard 250 kcmil 225 Aluminum – Service Entrance 250 kcmil 225 Copper – Standard and Service Entrance 250 kcmil EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-13 CIRCUIT BREAKER UNIT ENCLOSURES 10,000/25,000 AMPERES INTERRUPTING CAPACITY TABLE 2-15. TYPE CSR CIRCUIT BREAKERS 120/240 VAC — 25 kAIC FOR USE IN TYPE ECB UNIT ENCLOSURES 2-Pole Breakers 25 kAIC Loadcenters Ampere Rating Wire Size Range Cu/Al 60°C or 75°C for Line Terminals Catalog Number UPC Code 125 150 175 200 225 #2 – 300 kcmil CSR2125N CSR2150N CSR2175N CSR2200N CSR2225N 782114019733 782113098449 782113098456 782113098463 782114106242 TABLE 2-16. CSR LUG TREE KIT FOR REPLACEMENT PURPOSES ONLY — FOR USE IN TYPE ECB UNIT ENCLOSURES Ampere Rating 225 Description Wire Size Range Cu/Al 60°C or 75°C for Line Terminals Catalog Number UPC Code For use on 125,150, 175, 200 and 225 Ampere CSR Breakers #2 – 300 kcmil MCBK225 782114110591 TABLE 2-17. TYPE CC CIRCUIT BREAKERS 240 VAC — 10 kAIC FOR USE IN TYPE ECC UNIT ENCLOSURES Type CC 10 kAIC Ampere Rating Wire Size Range Cu/Al Catalog 60°C or 75°C for Line Terminals Number Type CC Hi-Mag 10 kAIC UPC Code Catalog Number UPC Code 2-Pole 100 125 150 #4 – 4/0 CC2100 CC2125 CC2150 782113386546 782113266565 782113266572 CC2100HM CC2125HM CC2150HM 782113828589 782113828596 782113828602 175 200 225 #2/0 – 300 kcmil CC2175 CC2200 CC2225 782113266589 782113266596 782113266602 CC2175HM CC2200HM CC2225HM 782113828619 782113828626 782113828633 100 125 150 #4 – 4/0 CC3100 CC3125 CC3150 782113386553 782113266619 782113266626 CC3100HM CC3125HM CC3150HM 782113828640 782113828657 782113828664 175 200 225 #2/0 – 300 kcmil CC3175 CC3200 CC3225 782113266633 782113266640 782113266657 CC3175HM CC3200HM CC3225HM 782113828671 782113828688 782113828695 3-Pole TABLE 2-18. MAIN BREAKER KITS 2-14 Ampere Rating Catalog Number UPC Code 225 200 150 100 CSH2225N CSH2200N CSH2150N CSH2100N 782113099774 782113099767 782113099743 782116318889 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Accessories LOADCENTER ACCESSORIES TABLE 2-19. FIELD INSTALLATION KITS AND PARTS Number Ampere No. of 1-Inch (25.4 mm) Wire Size Range of Poles Rating Spaces Needed Cu/Al 60°C or 75°C Ordering Catalog Qty. Number UPC Code 2 3 125 125 2 3 Neutral/Ground Lug Add-on Neutral or Ground Lug #1/0 Maximum #1/0 Maximum 1 CHSF2125 782113099132 CHSF3125 782113099149 #2/0 Maximum 1 #3/0 Maximum 300 kcmil Maximum NL20 NL30 NL300 782113099156 782113099163 782113099170 Filler Plates — 3/4-Inch (19.1 mm) Circuit Breaker Space (comes in a bag of 5 filler plates) 5 CHFPP 786676000437 Door Lock — 12 through 42 Circuits, and 100 through 225 A 1 TDL 782113099040 Sandlewood Spray Paint 1 SPCSW 782113098784 ANSI-61 Light Gray Touchup Paint for Outdoor Loadcenters 1 SPC61 782113098777 Isolated Neutral Assembly (Computer Circuits) 1 BINA 782113099439 Circuit Directory — Adhesive Backed 10 TCD 782113099019 Cover Screws 25 LCCS 782113099583 Cover Replacement Latch 14.31 Inch (363.6 mm) Wide Loadcenters Only 1 CHRLS 782113099255 Circuit Marking Strip (next to breakers) 10 CHMS 782113099729 Circuit Identification Label (preprinted breaker labels) 25 CHBL 782113099712 Series Rated Caution Label 25 SRL 782113099002 Branch Circuit Numbering Strip 20 CHNS 782114090091 TDL CHRLS Loadcenters Sub-Feed Lug Blocks CHFPP Must be purchased in multiples of ordering quantities indicated. TABLE 2-20. FIELD INSTALLATION RAINPROOF CONDUIT HUBS Conduit Size Inches (mm) Catalog Number UPC Code Group 1 — For use with 70, 100 and 125 Ampere MLO and MCB Loadcenters and Circuit Breaker Enclosures .75 (19.1) 1.00 (25.4) 1.25 (31.8) 1.50 (38.1) 2.00 (50.8) DS075H1P DS100H1P DS125H1P DS150H1P DS200H1P 786676805001 786676805056 786676805100 786676805155 786676805209 Group 2 — For use with 150, 200 and 225 Ampere MLO and MCB Loadcenters and Circuit Breaker Enclosure 2.00 (50.8) 2.50 (63.5) 3.00 (76.2) DS200H2P DS250H2P DS300H2P 786676462068 786676000505 786676000529 Adapter Kit — Allows Installing a Group 1 Hub on Devices Arranged for Group 2 Hubs Group 1 — Small Blank Hub Closure Plate Group 2 — Large Blank Hub Closure Plate — — — DS900AP CS900CP1 CS900CP2 782113099422 782114014394 782114014400 Description CHSF2125 Ordering quantity for all catalog numbers is one. Must be purchased in multiples. TABLE 2-21. CLAMSHELL ACCESSORIES Description Catalog Number UPC Code CHSF2125CS CHFPCS LCCSCS CHBLCS 782114793268 782114793213 782114793428 782114793206 DS075H1CS DS100H1CS DS125H1CS DS150H1CS DS200H2CS 782114793275 782114793282 782114793299 782114793305 782114793312 CHSF3125 Field Installation Kits and Parts Main or Sub-Feed Lug Block Filler Plates Cover Screws Circuit Identification Labels Rainproof Conduit Hubs Type 1 Hub Type 1 Hub Type 1 Hub Type 1 Hub Type 2 Hub EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-15 LOADCENTER ACCESSORIES TABLE 2-22. GROUND BAR KITS Description (See Legend) 䊋 䊉 䊋 䊋 䊋 䊑 䊋 䊉 䊋 䊑 䊋 䊋 䊋 䊉䊊䊊䊊䊊䊉䊊 䊉䊊䊊䊊䊊䊉䊊䊏 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊏 Loadcenters 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊏 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊏 䊔䊋䊔䊉䊔䊋䊔䊔䊔䊋䊔䊉䊔䊋䊔䊔䊔䊋䊔 䊊䊊䊊䊊䊊 Length Inches (mm) Ordering Quantity Catalog Number UPC Code 2.54 (64.5) 3.59 (91.2) 4.29 (109.0) 5.34 (135.6) 4.61 (117.1) 5.69 (144.5) 6.74 (171.2) 8.14 (206.8) 9.19 (233.4) 5.78 (146.8) 1.84 (46.7) 1 1 1 1 1 1 1 1 1 1 1 GBK5P GBK520 GBK10P GBK1020 GBK13 GBK14P GBK1420 GBK21P GBK2120 BRGBK39512 GB4NMP 786676460804 782114014356 782114462058 782114014554 782114220610 786676461153 782113099576 786676461252 782113099552 786676449359 786676378031 GBK14 BRGBK39512 Distance between mounting holes is 1.75 inches (44.5 mm). For single- and 3-phase 400 and 600 ampere applications. Distance between mounting holes is 2.34 inches (59.5 mm). For non-metallic enclosures. Snaps into molded base. Ground Bar Legend 䊋 䊑 䊊 䊏 䊔 䊋 䊉 (3) #14 – #10 Cu/Al or (1) #14 – #4 Cu/Al (1) #6 – 2/0 Cu/Al (1) #14 – #6 Cu/Al or (2) #14 – #12 Cu/Al (1) 1/8 – 14 or (3) #10 – 12 Cu/Al (1) #14 – 1/0 Cu/Al or (3) #14 – #10 Cu/Al (1) #6 – 14 Cu/Al or (2) #1/0 – 14 Cu/Al Mounting Hole TABLE 2-23. CLAMSHELL ACCESSORIES 2-16 Description Catalog Number UPC Code Ground Bar Kit Ground Bar Kit Ground Bar Kit Ground Bar Kit Ground Bar Kit Ground Bar Kit Ground Bar Kit GBK5CS GBK520CS GBK10CS GBK1020CS GBK13CS GBK14CS GBK21CS 782114793411 782114793404 782114793343 782114793336 782114793350 782114793374 782114793398 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Related Products MECHANICAL INTERLOCK COVERS DECORATOR COVERS Now you don‘t! Now you see it... NOW YOU SEE IT...NOW YOU DON‘T! CH8BRM Type A CH8EFM Type B Loadcenters Covers mechanically interlock two breakers designed for use with a portable generator. Type A covers interlock two CH breakers mounted across from one another. Type B covers interlock a main Type CSR Breaker with a Type CH. ✓ For easy use with CH Loadcenters mounted in living space. ✓ Easily wallpapered or painted to match any decor. ✓ Patented Loadcenter accessory — exclusively from Eaton. TABLE 2-24. MECHANICAL INTERLOCKS Mechanical Interlock Panel Cover Flush Surface Fits Loadcenter Type Catalog Numbers Catalog Number UPC Code Catalog Number UPC Code A CH12L125B, CH16L125B, CH12L3125B, CH14B100B CH8BFM 782113099590 CH8BSM 782113099606 CH20L125C, CH24L125C, CH18L3125C, CH24L3125C, CH22B100C, CH22N100C CH8CFM 782113099613 CH8CSM 782113099620 CH24L150D, CH32L150D, CH24L3225D, CH30L3150D CH8DFM 782113099644 CH8DSM 782113099637 CH42L225G, CH42L3225G CH8GFM 782113099675 CH8GSM 782113099682 Inner Cover of Box B Raintight Inner Cover of Box C Raintight — — — — CH8BRM CH8CRM 782113099651 782113099668 CH24B150E, CH24B200E CH8EFM 782114799390 CH8ESM 782114799406 CH32B150J, CH32B200J, CH3242B200J, CH32N200J, CH32B225J CH8JFM 782114799413 CH8JSM 782114799420 CH42B200K, CH42N200K, CH42B225K CH8KFM 782114799437 CH8KSM 782114799444 CHPC32B150L, CHPC32B200L, CHPC32N200L CHPC8B32LFM 782114799451 — — CHPC42B150L, CHPC42B200L, CHPC42N200L CHPC8B42LFM 782114799468 — — B TABLE 2-25. COVERS For Use with CH Loadcenter Cover Decorator Cover Catalog Number UPC Code Catalog Number UPC Code CH8KDNB CH8KDNC CH8KDND CH8KDNJ CH8KDNK 782114155424 782114155417 782114155431 782114155400 782114155394 CH8BF CH8CF CH8DF/EF CH8GF/JF CH8KF 782113098852 782113098876 782113098890/ 782113098913 782113098937/ 782113098951 782113098975 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-17 Technical Data and Specifications RESIDENTIAL/COMMERCIAL/ UNIT ENCLOSURE — BOX SIZES RESIDENTIAL LOADCENTER KNOCKOUT DIMENSIONS IN INCHES (MM) TABLE 2-26. RESIDENTIAL LOADCENTERS Residential NEMA Type 1 Indoor and NEMA Type 3R Outdoor Enclosures. Box Size Dimensions in Inches Height Width Dimensions in mm Depth Height Width Depth TABLE 2-29. KNOCKOUTS FOR BOX SIZES 5, 6, 7, 5R, 6R, 7R Loadcenters Code Diameter in Inches NEMA Type 1 Indoor 5 6 7 B C D E G J K L 9.50 11.38 13.00 16.75 21.00 29.13 29.13 34.13 34.13 37.00 39.00 4.50 6.88 11.00 14.31 14.31 14.31 14.31 14.31 14.31 14.31 14.31 3.13 3.39 3.69 3.88 3.88 3.88 3.88 3.88 3.88 3.88 3.88 241.3 288.9 330.2 425.5 533.4 739.8 739.8 866.8 866.8 939.8 990.6 114.3 174.6 279.4 363.5 363.5 363.5 363.5 363.5 363.5 363.5 363.5 79.4 86.1 93.7 98.4 98.4 98.4 98.4 98.4 98.4 98.4 98.4 3.13 4.50 3.69 5.19 5.19 5.19 5.19 5.19 5.19 5.19 5.19 241.3 298.5 330.2 425.5 533.4 739.8 739.8 866.8 866.8 939.8 990.6 114.3 165.1 279.4 363.5 363.5 363.5 363.5 363.5 363.5 363.5 363.5 79.4 114.3 93.7 131.8 131.8 131.8 131.8 131.8 131.8 131.8 131.8 Diameter in mm A B C .50 .50 .50 — .75 .75 — — 1.00 — — — 12.7 12.7 12.7 — 19.1 19.1 — — 25.4 — — — D E F .50 .75 .75 .75 1.00 1.00 1.00 1.25 1.25 1.25 — 1.50 12.7 19.1 19.1 19.1 25.4 25.4 25.4 31.8 31.8 31.8 — 38.1 G H I 1.00 1.00 1.25 1.25 1.25 1.50 1.50 1.50 2.00 — 2.00 — 25.4 25.4 31.8 31.8 31.8 38.1 38.1 38.1 50.8 — 50.8 — NEMA Type 3R Outdoor 5R 6R 7R B C D E G J K L 9.50 11.75 13.00 16.75 21.00 29.13 29.13 34.13 34.13 37.00 39.00 4.50 6.50 11.00 14.31 14.31 14.31 14.31 14.31 14.31 14.31 14.31 A F A D A D D Height Width Width F Depth NEMA Type 1 Indoor P PM 54.38 62.63 A 21.00 21.00 6.00 6.00 1381.1 1590.7 533.4 533.4 152.4 152.4 B Hub A C F F B F C A A D F A H B A Box 5R B F D A F H A Height D Box 5 Dimensions in mm Depth D A B Dimensions in Inches D A F TABLE 2-27. COMMERCIAL LOADCENTERS Box Size Hub A F B B H B Box 6 D B Box 6R TABLE 2-28. TYPES ECB AND ECC UNIT ENCLOSURES Dimensions in Inches Height Width Dimensions in mm Depth Height Width B C Depth G NEMA Type 1 Indoor A A A A G B B B B G B A 23.25 8.88 4.50 590.6 225.4 114.3 9.31 C G NEMA Type 3R Outdoor 23.69 Hub A A A B C C F A A A 5.44 601.7 236.5 Note: Box sizes do not include covers/fronts. 138.1 B C G C G A A A A B B Box 7 G F C A A A B C G G A A A A B B Box 7R FIGURE 2-1. KNOCKOUT POSITIONS 2-18 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 RESIDENTIAL AND COMMERCIAL LOADCENTER KNOCKOUT DIMENSIONS IN INCHES (MM) Residential NEMA Type 1 Indoor and NEMA Type 3R Outdoor Enclosures. TABLE 2-30. KNOCKOUTS FOR BOX SIZES 8, 8R, P, PM, B, C, D, E, G, J, K, L AND OUTDOOR BOXES 12-42 CKT Diameter in Inches Diameter in mm a b c d .75 .50 .50 1.00 — .75 — 1.25 — — — 1.50 — — — 2.00 — — — 2.50 19.1 12.7 12.7 25.4 — 19.1 — 31.8 — — — 38.1 — — — 50.8 — — — 63.5 e f g h 1.25 .75 .50 1.50 1.50 1.25 .75 2.00 2.00 1.50 1.00 2.50 2.50 2.00 — — — — — — 31.8 19.1 12.7 38.1 38.1 31.8 19.1 50.8 50.8 38.1 25.4 63.5 63.5 50.8 — — — — — — i j k m .50 1.00 1.25 .75 .75 1.25 1.50 1.00 1.00 1.50 2.00 1.25 1.25 — — 1.50 1.50 — — 2.00 12.7 25.4 31.8 19.1 19.1 31.8 38.1 25.4 25.4 38.1 50.8 31.8 31.8 — — 38.1 38.1 — — 50.8 n p .75 2.00 1.00 2.50 1.25 — 1.50 — — — 19.1 50.8 25.4 63.5 31.8 — 38.1 — — — .450 Dia. b c i h .450 Dia. c b b c c d c c b c c c g g e e c c .450 Dia. b c b i g b e e e .450 Dia. c c d c c Loadcenters Code c c c g g c e b b c g e e g g g c c c b b b b b b g e e e .450 Dia. b b g c .450 Dia. d i e e .450 Dia. 3/4 b b b g Outdoor Boxes 12-42 CKT 225A Maximum c c c g e Flush Trim e c c d c c b b b b b b b b c c c c e e .450 Dia. b .450 Dia. b b c c g c c c e c c c d c b i c c b Box C, D, E, G, J, K, L Box B Box P, PM c c g e b i c c g e .450 Dia. b c c c g c c c c FIGURE 2-2. KNOCKOUT DIAGRAM TABLE 2-31. TYPE ECB AND ECC UNIT ENCLOSURE KNOCKOUT Code Diameter in Inches Diameter in mm NEMA Type 1 Indoor (Flush and Surface Trims) A .50 — — — — 12.7 — — — — B 1.25 1.50 1.75 2.00 2.50 31.8 38.1 44.5 50.8 63.5 NEMA Type 3R Outdoor A .50 — — — — 12.7 — — — — B 1.25 1.50 1.75 2.00 2.50 31.8 38.1 44.5 50.8 63.5 A HUB B B B B B B B B B B A B A Outdoor Indoor FIGURE 2-3. NEMA TYPE 1 B FIGURE 2-4. NEMA TYPE 3R EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-19 BR Loadcenters Product Description Loadcenters A loadcenter is called a breaker box, electrical box or even a fuse box. The main function is to take electricity supplied by the utility and distribute it throughout the home to feed lights and receptacles. Not only does the loadcenter distribute power, it also provides protection. Warranty ✓ Ten years on loadcenters. ✓ Ten years on branch circuit breakers. Single-Phase Main Circuit Breaker — Top or Bottom Feed Single-Phase — Main Lugs Three-Phase Main Circuit Breaker — Commercial Convertible Main Breaker or Main Lug Only Three-Phase Main Circuit Breaker Circuit Breaker Unit Enclosures Outdoor Single-Phase — Main Lugs 2-20 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Features, Functions and Benefits Uses 1-inch (25.4 mm) BR breakers. Tangential main knockout. Standard 14-3/8 inches (365.1 mm) wide enclosures fit snugly between wall studs. Drywall marking on enclosure. Loadcenter can be mounted for top or bottom feed. Same size Allen wrench can be used for phase and neutral lugs. Loadcenters Extra 1-1/2-inch (38.1 mm) knockout for bundling of wires. Commercial grade main breaker designed for straight-in wiring that allows for top or bottom feed. Twin neutral design for easier wiring and balancing of the load, located in wireway, away from circuit breakers. Factory pre-attached neutral bonding strap. Maximum wiring gutter space for ease of wiring in compliance with NEC requirements. Predrilled mounting holes for ease of installing ground bar kits. One piece roll formed metal backpan with circuit breaker alignment notches ensures accurately aligned breaker and bus stabs. Maximum variety of concentric knockouts, at rear and sides. Combination trim has sliding latch and adjustable deadfront for neat, clean appearance. Six mounting holes (three top, three bottom) for ease of installation. BR2040B200 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-21 Catalog Numbering System TABLE 2-32. SINGLE- AND THREE-PHASE THROUGH 225 AMPERES CATALOG NUMBERING SYSTEM 3 BR 30 42 B C 200 Phase Amperes Loadcenters Blank = 1-Phase 3 = 3-Phase Number of 1-Inch (25.4 mm) Spaces Eaton’s Cutler-Hammer Type BR Loadcenter B L N H = = = = 50 = 70 = 100 = 125 = 150 = 200 = 225 = Maximum Number of Circuits Main Breaker Main Lug Convertible Main Main Breaker High AIC 50 70 100 125 150 200 225 Bus Blank = Aluminum Bus C = Copper Bus Blank = No Feed-Thru Lugs F = Feed Thru Lugs G = Ground Bar P = Current Design NY = NY City Gutter Space Enclosure R = NEMA姞 Type 3R Rainproof S = NEMA Type 1 Indoor with Surface Trim F = NEMA Type 1 Indoor with Flush Trim Blank = NEMA Type 1 Indoor with Combination Trim RIS = Riser Panel PGFI = Spa Panel No character space used. TABLE 2-33. SINGLE- AND THREE-PHASE 400 AMPERES THROUGH 600 AMPERES CATALOG NUMBERING SYSTEM 3 B 30 42 D F N N= Current Design Phase Blank = 1-Phase 3 = 3-Phase Main Enclosure Blank = Main Lug B = Main Breaker Number of 1-Inch (25.4 mm) Spaces F = NEMA Type 1 Indoor with Combination Trim S = NEMA Type 1 Indoor with Surface Trim R1 = NEMA Type 3R Rainproof Amperes Maximum Number of Circuits No character space used. D = 400 Amperes E = 600 Amperes Example No. 1: BR1224L125G Single-Phase CutlerHammer Type BR Loadcenter Rated at 125 Amperes with Main Lugs, 12 Spaces Allowing 24 Poles, Indoor Combination Enclosure, Aluminum Bus and Ground Bar. Example No. 2: BR24L70RP Single-Phase Cutler-Hammer Type BR Loadcenter Rated at 70 Amperes with Main Lugs, 2 Spaces Allowing 4 Poles, Rainproof Enclosure with Aluminum Bus. Example No. 3: 3B4242EFN 3-Phase Cutler-Hammer Type BR Loadcenter Rated at 600 Amperes with Main Breaker, 42 Spaces Allowing 42 Poles, Indoor Combination Enclosure. 2-22 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Data Tables SINGLE-PHASE — MAIN CIRCUIT BREAKER LOADCENTERS 10,000/22,000 AMPERES INTERRUPTING CAPACITY TABLE 2-34. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Main Ampere Rating BR 10 kAIC BW 10 kAIC Maximum Number 1-Inch (25.4 mm) Spaces Poles Enclosure Type Box Size 100 8 10 10 10 12 12 16 16 16 20 20 16 20 20 20 20 24 20 24 24 20 24 Indoor Surface Flush Outdoor Indoor Outdoor Indoor Indoor Outdoor Indoor Outdoor B1 A1 A1 B2R B2 B2R C1 C1 C1R C2 C3R 125 16 20 20 24 24 24 Indoor Indoor Outdoor 150 8 16 20 20 20 20 24 30 30 30 16 30 30 30 40 40 30 30 30 40 200 4 8 16 20 20 24 30 30 40 40 225 42 42 Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Loadcenter with Combination or NEMA Type 3R Cover Catalog Number UPC Code #4 – 1/0 BR816B100 BR1020B100S11 BR1020B100F11 BR1020B100RFP BR1220B100 BR1224B100R BR1620B100 BR1624B100 BR1624B100R BR2020B100 BR2024B100R 786676443456 782114993514 782116125494 786676443708 786676443753 786676443951 786676444002 786676444057 786676444101 786676444156 786676444354 C1 C1 C3R #4 – 2/0 BR1624B125 BR2024B125 BR2024B125R 786676444408 786676444453 786676444507 Outdoor Indoor Indoor Outdoor Indoor Outdoor Indoor Indoor Outdoor Indoor C3R C4 C4 D1R D1 D1R G1 G1 G1R G1 #2 – 300 kcmil BR816B150RF BR1630B150 BR2030B150 BR2030B150R BR2040B150 BR2040B150R BR2430B150 BR3030B150 BR3030B150R BR3040B150 786676444552 786676444705 786676444903 786676444958 786676001038 786676483209 786676445009 786676445054 786676445108 786676445979 8 16 32 40 40 40 40 40 40 40 Outdoor Outdoor Indoor Indoor Outdoor Indoor Indoor Outdoor Indoor Outdoor 8R C3R C4 D1 D1R G1 G1 G1R L1 L1R #2 – 300 kcmil BR48B200RFP BR816B200RF BR1632B200 BR2040B200 BR2040B200R BR2440B200 BR3040B200 BR3040B200R BR4040B200 BR4040B200R 786676000512 786676445153 786676445351 786676445559 786676445757 786676445856 786676445955 786676446051 786676446150 786676446303 42 42 Indoor Outdoor L2 L2R #1 – 250 kcmil BR4242B225 BR4242B225R 786676446402 786676446457 Loadcenters Main Breaker Type Combination style covers may be used in surface or flush applications. All main circuit breaker loadcenters are listed for use as service entrance equipment and are shipped with a neutral bonding strap preattached. The maximum rating of the panel is the main circuit breaker rating when used as service entrance equipment. Wire range size for BR1020B100SP is #6 – 1 Al/Cu. Available in flush. Loadcenters are 11.75 inches (293.8 mm) wide and 13.00 inches (330.2 mm) high for retrofit applications. Includes through-feed lugs for both phase and neutral conductors. Rainproof panels are furnished with hub closure plates. DS200H1 hub is included with loadcenter. Neutral is bonded – suitable for service entrance only – can not be converted for sub-feed application. P Suffix = Specifically packaged for retail sales. Dimensions for boxes on Pages 2-41 – 2-43. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-23 SINGLE-PHASE — MAIN CIRCUIT BREAKER LOADCENTERS 10,000/22,000 AMPERES INTERRUPTING CAPACITY TABLE 2-35. SINGLE-PHASE, 3-WIRE — 120/240 VAC Commercial Loadcenter Maximum Number 1-Inch (25.4 mm) Loadcenters Main Breaker Type Main Ampere Rating Spaces Poles Enclosure Type DK  300 42 42 400 42 42 42 LA  600 With Flush or NEMA Type 3R Cover Box Size Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Catalog Number UPC Code Indoor 24 (2) #3/0 – 250 kcmil BR304242F 786676001076 42 42 Indoor Outdoor 24 47 (2) #3/0 – 250 kcmil B4242DFN B4242DR1N 42 Indoor 24 (2) #3/0 – 500 kcmil  B4242EFN 786676316026 786676316071 786676316170 The maximum rating of the panel is the main circuit breaker rating when used as service entrance equipment. Door lock and key included with loadcenter.  Type DK main circuit breaker is rated 65 kAIC at 240 Vac and allows a 22 kAIC series rating on the panel when Types BR, BD and BJ branch circuit breakers are used.  Type LA main circuit breaker is rated 42 kAIC at 240 Vac. Type LA circuit breaker is not series rated with Types BR, BD and BJ branch circuit breakers.  Rainproof panels are furnished with hub closure plates. P Suffix = Specifically packaged for retail sales. SINGLE-PHASE — MAIN CIRCUIT BREAKER LOADCENTERS 22,000/25,000 AMPERES INTERRUPTING CAPACITY TABLE 2-36. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Main Breaker Type Main Ampere Rating BRH 22 kAIC BWH 25 kAIC Maximum Number 1-Inch (25.4 mm) Box Size Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Loadcenter with Combination Cover Spaces Poles Enclosure Type Catalog Number UPC Code 100 20 24 Indoor C2 #2/0 – 300 kcmil BR2024H100 786676444309 150 20 30 Indoor C4 #2/0 – 300 kcmil BR2030H150 786676444859 200 20 30 40 40 40 40 Indoor Indoor Indoor D1 G1 L1 #2/0 – 300 kcmil BR2040H200 BR3040H200 BR4040H200 786676445504 786676445900 786676446105 All main circuit breaker loadcenters are listed for use as service entrance equipment and are shipped with neutral bonding strap preattached. The maximum rating of the panel is the main circuit breaker rating when used as service entrance equipment. 22 kAIC series combination rating is obtained when Types BD, BR, BQ, BQC and GFCB 10 kAIC branch breakers are used in series with Type BRH main breaker. 25 kAIC series combination rating is obtained when Types BD, BR, BQ, BQC and GFCB 10 kAIC branch circuit breakers are used in series with Type BWH main breaker. Dimensions for boxes on Pages 2-41 – 2-43. 2-24 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 SINGLE-PHASE — MAIN LUG LOADCENTERS TABLE 2-37. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Enclosure Type of Trim Type Wire Size Range Box Cu/Al 60°C or 75°C Size for Main Lugs Loadcenter Catalog Number UPC Code 70 2 2 2 2 2 4 4 4 4 4 Indoor Indoor Outdoor Indoor Indoor Surface no Door Surface no Door — Flush no Door Flush no Door 5 5 5R 5 5 #8 – #2 BR24L70SP BR24L70SGP BR24L70RP BR24L70FP BR24L70FGP 786676001670 786676001946 786676001618 786676001847 786676001939 125 2 2 2 4 4 4 Indoor Outdoor Indoor Surface no Door — Flush no Door 6 6R 6 #14 – 1/0 BR24L125SP BR24L125RP BR24L125FP 786676002271 786676001502 786676002264 4 4 4 4 4 4 8 8 8 8 8 8 Indoor Indoor Outdoor Indoor Indoor Indoor Surface no Door Surface no Door — Flush no Door Flush with Door Flush with Door 7 7 7R 7 7 7 #14 – 1/0 BR48L125SP BR48L125SGP BR48L125RP BR48L125FP BR48L125FDP BR48L125FGP 786676001236 786676001991 786676001205 786676001717 786676002288 786676001984 6 6 6 6 6 6 6 6 6 12 12 12 12 12 12 12 12 12 Indoor Indoor Indoor Indoor Outdoor Indoor Indoor Indoor Indoor Surface no Door Surface no Door Surface with Door Surface with Door — Flush no Door Flush no Door Flush with Door Flush with Door 7 7 7 7 7R 7 7 7 7 #14 – #1 BR612L125SP BR612L125SGP BR612L125SDP BR612L125SDGP BR612L125RP BR612L125FP BR612L125FGP BR612L125FDP BR612L125FDGP 786676002035 786676002059 786676001304 786676002097 786676001359 786676002028 786676002042 786676001311 786676002080 8 8 8 8 8 8 8 8 8 8 8 16 16 16 16 16 16 16 16 16 16 16 Indoor Indoor Indoor Indoor Indoor Outdoor Indoor Indoor Indoor Indoor Indoor Surface no Door Surface no Door Surface with Door Surface with Door Surface with Door — Flush no Door Flush no Door Flush with Door Flush with Door Flush with Door 7 7 7 7 7 7R 7 7 7 7 7 #14 – #1 BR816L125SP BR816L125SGP BR816L125SDP BR816LC125SDP BR816L125SDGP BR816L125RP BR816L125FP BR816L125FGP BR816L125FDP BR816LC125FDP BR816L125FDGP 786676002127 786676002141 786676001427 786676002301 786676002189 786676001472 786676002110 786676002134 786676001434 786676002295 786676002172 Loadcenters Maximum Number Main 1-Inch (25.4 mm) Ampere Poles Spaces Rating Suitable for use as service equipment when not more than two service disconnecting mains are provided or when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Ground bar GBK5 is installed. Rainproof panels are furnished with hub closure plates. Suitable for use as service equipment when not more than two service disconnecting mains are provided or when not more than six service disconnecting mains are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Suitable for use as service equipment when a main breaker is used or when not more than six service disconnecting mains are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Ground bar GBK10 is installed. CSA and UL approved. Ground bar GBK14 is installed. Copper bus is included. P Suffix = Specifically packaged for retail sales. Dimensions for boxes on Pages 2-41 – 2-43. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-25 SINGLE-PHASE — MAIN LUG LOADCENTERS, CONTINUED TABLE 2-38. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE Maximum Number 1-Inch (25.4 mm) Main Ampere Rating Poles 125 12 12 12 12 12 16 16 16 20 20 20 24 24 12 24 24 24 24 24 24 24 24 24 24 24 24 Indoor Indoor Indoor Indoor Outdoor Indoor Indoor Outdoor Indoor Indoor Outdoor Indoor Indoor B1 B1 B1 B1 B1R B2 B2 B2R C1 C1 C1R C2 C2 150 16 20 30 30 Indoor Indoor 200 8 12 12 20 20 24 30 30 40 40 16 24 24 40 40 40 40 40 40 40 225 42 42 42 42 Loadcenters Spaces Enclosure Type Box Size Wire Size Range Cu/Al 60°C or 75°C for Main Lugs Loadcenter with Combination or NEMA Type 3R Cover Catalog Number UPC Code #6 – 2/0 BR1212L125 BR1224L125 BR1224L125G BR1224L125DG BR1224L125R BR1624L125 BR1624L125G BR1624L125R BR2024L125 BR2024L125G BR2024L125R BR2424L125 BR2424L125G 786676446501 786676446556 786676446600 786676000628 786676446709 786676446754 786676446808 786676446853 786676446907 786676446952 786676447058 786676447102 786676001199 C2 C2 #1 – 300 kcmil BR1630L150  BR2030L150  786676447157 786676447201 Outdoor Indoor Outdoor Indoor Outdoor Indoor Indoor Outdoor Indoor Outdoor B2R B2 B2R C2 C3R C4 D1 D1R G1 G1R #1 – 300 kcmil BR816L200RF  BR1224L200  BR1224L200R  BR2040L200 BR2040L200R  BR2440L200  BR3040L200  BR3040L200R  BR4040L200  BR4040L200R  786676447256 786676447300 786676447355 786676447454 786676447553 786676447607 786676447652 786676447706 786676447751 786676447805 Indoor Outdoor L1 L1R #1 – 300 kcmil BR4242L225 BR4242L225R 786676447850 786676447904 Has notch for BREQS125 hold-down kit. Single, movable neutral is provided. Combination cover style. Suitable for use as service equipment when not more than six main disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Ground bar GBK8 installed. Ground bars GBK5 and GBK520 installed. Rainproof panels are furnished with hub closure plates. Ground bar GBK10 installed Ground bar GBK1220 installed.  Has notch for BRHDK125 hold-down kit.  Includes through-feed lugs for both phase and neutral conductors. P Suffix = Specifically packaged for retail sales. TABLE 2-39. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE Maximum Number 1-Inch (25.4 mm) Main Ampere Rating Spaces Commercial Loadcenter  Poles Wire Size Range Enclosure Box Cu/Al 60°C or 75°C Type Size for Main Lugs With Flush or NEMA Type 3R Cover With Surface Cover Catalog Number UPC Code Catalog Number UPC Code 400 12 12 24 42 42 24 24 42 42 42 Indoor Outdoor Indoor Indoor Outdoor 19 42 20 22 46 (1) #4/0 – 750 kcmil or (2) #3/0 – 400 kcmil — 1224DRIN  — 4242DFN 4242DRIN  — 786676310581 — 786676305983 786676310680 1224DSN  — 2442DSN 4242DSN — 786676305006 — 786676305563 786676306003 — 600 42 42 Indoor 22 (2) #2 – 500 kcmil — — 4242ESN 786676306041  Has notch for BRHDK125 hold-down kit.  Ground bar GBK8 installed.  Suitable for use as service equipment when not more than six main disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC).  Rainproof panels are furnished with hub closure plates. P Suffix = Specifically packaged for retail sales. Dimensions for boxes on Pages 2-41 – 2-43. 2-26 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 SINGLE-PHASE — MAIN LUG LOADCENTERS, NON-METALLIC TABLE 2-40. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Maximum Number 1-Inch (25.4 mm) Wire Size Range Box Cu/Al 60°C or 75°C Size for Main Lugs Spaces Poles Enclosure Type Type of Trim 40 Indoor Flush No Door 2 2 60 2 2 2 2 2 4 4 4 4 4 Indoor Indoor Indoor Indoor Outdoor Flush No Door Surface No Door Flush No Door Surface No Door — 2 2 2 2 2R Loadcenter Catalog Number UPC Code TT120FLGNM TT120SLGNM 786676369855 786676369886 #14 – 2 2460FNM 2460SNM 2460FGNM 2460SGNM 2460RNM 786676369701 786676369763 786676369732 786676369794 786676369824 Suitable for use as service equipment when not more than six main disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). This device has no main lugs. A Type BR or BD breaker is required to be backfed to supply power to branch breakers. This device is single-phase 120 Vac only. With the use of three Type BR breakers, there are two branch circuits available. With the use of three Type BD breakers, there are five branch circuits available. Includes GB4NM ground bar. P Suffix = Specifically packaged for retail sales. Loadcenters Main Ampere Rating Dimensions for boxes on Pages 2-41 – 2-43. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-27 3-PHASE — MAIN CIRCUIT BREAKER LOADCENTERS 10,000/22,000/100,000 AMPERES INTERRUPTING CAPACITY Maximum Number 1-Inch (25.4 mm) Spaces Poles Encl. Type Box Size Main Breaker Type Main Ampere Rating TABLE 2-41. 3-PHASE 4-WIRE — 208Y/120 VAC OR 240 VAC INSULATED/BONDABLE NEUTRAL Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Loadcenter With Combination or NEMA Type 3R Cover With Surface Cover Catalog Number Catalog Number UPC Code UPC Code Loadcenters BR 10 kAIC 100 12 12 24 24 Indoor C1 #4 – 1/0 Outdoor C1R 3BR1224B100 786676440103 3BR1224B100S 3BR1224B100R 786676440158 — 786676443951 — CC 10 kAIC 125 30 42 Indoor 3BR3042B125 786676440257 3BR3042B125S 786676440301 150 30 30 42 42 Indoor L1 #1 – 3/0 Outdoor L1R 3BR3042B150 786676440455 3BR3042B150S 3BR3042B150R 786676440509 — 786676440554 — 200 30 30 42 42 42 42 42 42 Indoor Outdoor Indoor Outdoor 3BR3042B200 3BR3042B200R 3BR4242B200 3BR4242B200R 3BR3042B200S — 3BR4242B200S — 786676440806 — 786676441100 — 225 42 42 42 42 Indoor L2 #1 – 300 kcmil 3BR4242B225 786676441254 3BR4242B225S Outdoor L2R 3BR4242B225R 786676441308 — 786676441353 — DK 22 kAIC 400 42 42 42 42 Indoor 24 Outdoor 47 (2) #3/0 – 250 kcmil 3B4242DFN 786676317191 3B4242DSN 3B4242DR1N 786676317221 — 786676317214 — LD 600 42 42 Indoor 24 (2) #3/0 – 500 kcmil 3B4242EFN 786676317238 3B4242ESN 786676317245 BRH 22 kAIC 100 12 24 Indoor C1 #4 – 1/0 3BR1224H100 786676440004 3BR1224H100S 786676440059 CHH 150 100 kAIC 30 42 Indoor L1 #1 – 250 kcmil 3BR3042H150 786676440356 3BR3042H150S 786676440400 CHH 200 100 kAIC 30 42 42 42 Indoor Indoor L1 L2 #1 – 250 kcmil 3BR3042H200 3BR4242H200 786676440608 3BR3042H200S 786676440905 3BR4242H200S 786676440653 786676440950 L1 #1 – 2/0 L1 #1 – 250 kcmil L1R L2 L2R 786676440707 786676440752 786676441001 786676441056 All main circuit breaker loadcenters are listed for use as service entrance equipment and are shipped with a neutral bonding strap pre-attached (commercial loadcenters do not have a pre-attached bonding strip). The maximum main rating of the panel is the main circuit breaker rating when used as service entrance equipment. Door lock and key included with loadcenter. Type DK main circuit breaker is rated 65 kAIC at 240 Vac and allows a 22 kAIC series rating on the loadcenter when Types BR, BD and BJ branch circuit breakers are used. Commercial loadcenter. The LD main circuit breaker is rated 65 kAIC at 240 Vac. Type LD circuit breaker is not series rated with Types BR, BD and BJ branch circuit breakers. 22 kAIC series combination rating is obtained when Types BD, BR, BQ, BQC and GFCB branch breakers are used with BRH main. Loadcenter with combination cover only. 100 kAIC series combination rating is obtained when Types BD, BR, BQ, BQC and GFCB branch breakers are used with CHH main. Dimensions for boxes on Pages 2-41 – 2-43. 2-28 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 3-PHASE — MAIN LUG LOADCENTERS Loadcenter Maximum Number 1-Inch (25.4 mm) Spaces Poles Encl. Type Wire Size Range Cu/Al Box 60°C or 75°C Size for Main Lugs Indoor 9 Outdoor 9R #14 – 1/0 With Combination or NEMA Type 3R Cover With Surface Cover Catalog Number UPC Code Catalog Number — 3BR3L100R — 3BR3L100S 786849164805 — UPC Code 100 3 3 3 3 786849164799 — 125 12 12 24 24 Indoor C1 #6 – 2/0 Outdoor C1R 150 18 18 24 24 36 36 42 42 Indoor Outdoor Indoor Outdoor D1 #1 – 300 kcmil D1R D1 D1R 3BR1836L150 3BR1836L150R 3BR2442L150 3BR2442L150R 786676441551 786676441605 786676441704 786676441759 3BR1836L150S — 3BR2442L150S — 786676441650 — 786676441803 — 200 12 12 18 18 24 30 30 42 42 24 24 36 36 42 42 42 42 42 Indoor Outdoor Indoor Outdoor Indoor Indoor Outdoor Indoor Outdoor C4 #1 – 300 kcmil C3R C4 C3R G1 G1 G1R L1 L1R 3BR1224L200 3BR1224L200R 3BR1836L200 3BR1836L200R 3BR2442L200 3BR3042L200 3BR3042L200R 3BR4242L200 3BR4242L200R 786676441858 786676441902 786676442053 786676442107 786676442206 786676442305 786676442350 786676442503 786676442558 3BR1224L200S — 3BR1836L200S — 3BR2442L200S 3BR3042L200S — 3BR4242L200S — 786676442008 — 786676442152 — 786676442251 786676442404 — 786676442602 — 225 42 42 42 42 Indoor L1 #1 – 300 kcmil Outdoor L1R 3BR4242L225 3BR4242L225R 786676442756 3BR4242L225S 786676442800 — 786676442855 — 400 18 18 24 42 42 36 36 42 42 42 Indoor Outdoor Indoor Indoor Outdoor 19 43 38 22 46 (1) #4/0 – 750 kcmil 31836DFN 31836DR1N or (2) #3/0 – 400 kcmil — 34242DFN 34242DR1N 786676306782 786676311335 — 786676308526 786676311533 786676306805 — 786676308274 786676308571 — 600 42 42 Indoor 22 (2) #2 – 500 kcmil 786676308625 34242ESN 3BR1224L125 786676441407 3BR1224L125S 786676441506 3BR1224L125R 786676441452 — — 34242EFN 31836DSN — 32442DSN 34242DSN — Loadcenters Main Ampere Rating TABLE 2-42. 3-PHASE 4-WIRE — 208Y/120 VAC OR 240 VAC INSULATED/BONDABLE NEUTRAL 786676308670 Rainproof loadcenters are furnished with hub closure plates. Has notch for BREQS125 hold-down kit. Suitable for use as service equipment when not more than six main disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Door lock and key included with loadcenter. Commercial loadcenter. With Flush or NEMA Type 3R cover. Not combination. Dimensions for boxes on Pages 2-41 – 2-43. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-29 CONVERTIBLE LOADCENTERS MAIN BREAKER OR MAIN LUG CENTER — BASE UNITS AND MAIN DEVICES 10,000/22,000/25,000 AMPERES INTERRUPTING CAPACITY ➀ — COMPLETE ASSEMBLY CONSISTS OF: LOADCENTER AND EITHER MAIN BREAKER KIT OR MAIN LUG KIT Base Units TABLE 2-43. SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Loadcenters Main Ampere Rating Maximum Number 1-Inch (25.4 mm) Box Size Spaces Poles Enclosure Type 125 12 12 16 16 20 20 24 24 24 24 24 24 Indoor Outdoor Indoor Outdoor Indoor Outdoor B2 B2R C1 C1R C2 C3R 200 8 12 12 16 20 20 24 30 30 40 40 16 24 24 32 40 40 40 40 40 40 40 Outdoor Indoor Outdoor Indoor Indoor Outdoor Indoor Indoor Outdoor Indoor Outdoor C3R C4 C3R C4 D1 D1R G1 G1 G1R L1 L1R Loadcenter with Combination or NEMA Type 3R Cover Wire Size Range Cu/Al 60°C or 75°C for Main See main breaker and main lug kit tables. Catalog Number UPC Code BR1224N125 BR1224N125R BR1624N125 BR1624N125R BR2024N125 BR2024N125R 786676447959 786676448000 786676448154 786676448208 786676448253 786676448307 BR816N200RF BR1224N200 BR1224N200R BR1632N200 BR2040N200 BR2040N200R BR2440N200 BR3040N200 BR3040N200R BR4040N200 BR4040N200R 786676448451 786676448505 786676448550 786676448604 786676448659 786676448703 786676008822 786676448857 786676448901 786676449007 786676449052 Interrupting rating depends on main circuit breaker selected. The maximum rating of the loadcenter is the main circuit breaker rating when used as service entrance equipment. 100, 125 and 200 ampere Convertible base unit catalog numbers include interior, box and cover only. Main devices and accessories must be ordered separately for field installation. All Convertible base units are listed as suitable for use as service entrance equipment when used per Article 384 of the NEC. BREQS125 hold-down screw comes with loadcenter for back-fed Types BR and BRH main circuit breakers. Convertible to maximum of 100 ampere main circuit breaker and 125 ampere main lug. Rainproof loadcenters are furnished with hub closure plates. Suitable for use as service equipment when not more than six main disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Includes feed-through lugs for both phase and neutral conductors. No hold-down provisions for back-fed Types BR and BRH main circuit breakers. Main Ampere Rating  TABLE 2-44. 3-PHASE 4-WIRE — 208Y/120 VAC OR 240 VAC INSULATED/BONDABLE NEUTRAL Maximum Number 1-Inch (25.4 mm) Loadcenter  100 30 30 Indoor D1 125 12 24 Indoor C1 Encl. Spaces Poles Type Box Size Wire Size Range Cu/Al 60°C or 75°C for Main With Combination or NEMA Type 3R Cover With Surface Cover Catalog Number Catalog Number UPC Code UPC Code See main breaker 3BR3030N100  786676442909 3BR3030N100S  786676443005 and main lug kit tables 3BR1224N125  786676443159 3BR1224N125S  786676443258 (Page 2-31).  The maximum rating of the loadcenter is the main circuit breaker rating when used as service entrance equipment.  100, 125 and 200 ampere Convertible base unit catalog numbers include interior, box and cover only. Main devices and accessories must be ordered separately for field installation. All Convertible base units are listed as suitable for use as service entrance equipment when used per Article 384 of the NEC.  BREQS125 hold-down screw comes with loadcenter for back-fed Types BR and BRH main circuit breakers.  Convertible to maximum of 100 ampere main circuit breaker and 125 ampere main lug.  Suitable for use as service equipment when not more than six main disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Dimensions for boxes on Pages 2-41 – 2-43. 2-30 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 MAIN DEVICES Main Circuit Breaker with Accessory TABLE 2-45. 2- AND 3-POLE MAIN CIRCUIT BREAKERS; 120/240 VAC OR 208Y/120 VAC OR 240 VAC Wire Size Range Cu/Al 60°C or 75°C for Main Breaker 10 kAIC Catalog Number UPC Code Catalog Number UPC Code 100 #4 – 1/0 BR2100 786676363259 BRH2100 786676373906 110 #4 – 1/0 BR2110 786676384278 BRH2110 786676374248 125 #4 – 2/0 BR2125 786676367059 BRH2125 786676373951 125 #2 – 300 kcmil BW2125 786676460361 BWH2125 786676460439 150 #2 – 300 kcmil BW2150 786676460408 BWH2150 786676460453 175 #2 – 300 kcmil BW2175 786676460507 BWH2175 786676449700 200 #2 – 300 kcmil BW2200 786676460552 BWH2200 786676460606 #1 BR3100 786676368094 BRH3100 786676372909 Ampere Rating 22/25 kAIC Example: BW22005R01 (Put description with catalog number on order.) 3-Pole 100 Loadcenters 2-Pole Series combination rating with Types BD, BR, BQ, BQC and GFCB is 22 kAIC with BRH main and 25 kAIC with BWH main. TABLE 2-46. 2- AND 3-POLE MAIN LUG KITS 120/240 VAC OR 208Y/120 VAC OR 240 VAC Wire Size Range Cu/Al 60°C or 75°C for Main Lugs Catalog Number UPC Code 125 #6 – 2/0 BRSF125 786676001762 150 #1 – 300 kcmil BRL200 786676460101 175 #1 – 300 kcmil BRL200 786676460101 200 #1 – 300 kcmil BRL200 786676460101 #6 – 3/0 3BRSF150 786676001786 Ampere Rating 2-Pole 3-Pole 150 Accessory clamshell number BRF125CS clamshell available. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-31 MAIN CIRCUIT BREAKER/MAIN LUG/CONVERTIBLE LOADCENTERS — WITH COPPER BUS 10,000/22,000/25,000 AMPERES INTERRUPTING CAPACITY TABLE 2-47. MAIN CIRCUIT BREAKER — SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Loadcenters Main Breaker Type Main Ampere Rating BR 10 kAIC Maximum Number 1-Inch (25.4 mm) Box Size Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Loadcenter with Combination Cover Spaces Poles Enclosure Type Catalog Number UPC Code 100 100 20 30 20 30 Indoor Indoor C2 D1 #4 – 1/0 BR2020BC100 BR3030BC100 782114867044 786676001175 BW 10 kAIC 150 200 200 200 30 20 30 40 30 40 40 40 Indoor Indoor Indoor Indoor G1 D1 G1 L1 #2 – 300 kcmil #2 – 300 kcmil BR3030BC150 BR2040BC200 BR3040BC200 BR4040BC200 782114867051 782114867037 782114867020 782114867013 BRH 22 kAIC 100 30 30 Indoor D1 #4 – 1/0 BR3030HC100 786676001182 All main circuit breaker loadcenters are listed for use as service entrance equipment and are shipped with a neutral bonding strap preattached. The maximum main rating of the loadcenter is the main breaker rating when used as service entrance equipment. Note: All main circuit breaker loadcenters are listed for use as service entrance equipment. Loadcenters are factory bonded for service entrance applications. Remove bonding strap for separate neutral and ground bars for sub-feed applications. TABLE 2-48. MAIN LUG — SINGLE-PHASE 3-WIRE — 120/240 VAC — SINGLE NEUTRAL Main Ampere Rating 125 Maximum Number 1-Inch (25.4 mm) Spaces Poles Enclosure Type 8 8 16 16 Indoor Indoor Type of Trim Box Size Surface w/door Flush w/door 7 7 Wire Size Range Cu/Al 60°C or 75°C for Main Lugs #14 – 1 Loadcenter Catalog Number UPC Code BR816LC125SDP BR816LC125FDP 786676002301 786676002295 TABLE 2-49. MAIN CIRCUIT BREAKER — 3-PHASE 4-WIRE — 208Y/120 VAC OR 240 VAC — INSULATED/BONDABLE NEUTRAL Main Breaker Type Main Ampere Rating BW 10 kAIC 200 Maximum Number 1-Inch (25.4 mm) Spaces Poles Enclosure Type Box Size 30 42 42 42 42 42 Indoor Indoor Outdoor L1 L2 L2R Wire Size Range Cu/Al 60°C or 75°C for Main Breaker #1/0 – 250 kcmil Loadcenter with Combination or NEMA Type 3R Cover Catalog Number UPC Code 3BR3042BC200 3BR4242BC200 3BR4242BC200R 786676440851 786676441155 786676441209 All main circuit breaker loadcenters are listed for use as service entrance equipment and are shipped with a neutral bonding strap preattached. The maximum main rating of the loadcenter is the main breaker rating when used as service entrance equipment. Rainproof loadcenters are furnished with hub closure plates. TABLE 2-50. MAIN LUG — 3-PHASE 4-WIRE — 208Y/120 VAC OR 240 VAC — INSULATED/BONDABLE NEUTRAL Main Ampere Rating 200 Maximum Number 1-Inch (25.4 mm) Spaces Poles Enclosure Type 30 42 42 42 42 42 Indoor Indoor Outdoor Box Size G1 L1 L1R Wire Size Range Cu/Al 60°C or 75°C for Main Lugs #1/0 – 300 kcmil Loadcenter with Combination or NEMA Type 3R Cover Catalog Number UPC Code 3BR3042LC200 3BR4242LC200 3BR4242LC200R 786676442459 786676442657 786676442701 Rainproof loadcenters are furnished with hub closure plates. Dimensions for boxes on Pages 2-41 – 2-43. 2-32 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 MAIN CIRCUIT BREAKER/MAIN LUG/CONVERTIBLE LOADCENTERS — WITH COPPER BUS 10,000/22,000/25,000 AMPERES INTERRUPTING CAPACITY TABLE 2-51. CONVERTIBLE — SINGLE-PHASE 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL Maximum Number 1-Inch (25.4 mm) Box Size Spaces Poles Enclosure Type 125 10/22 kAIC 12 12 20 20 24 24 24 24 Indoor Outdoor Indoor Outdoor B2 B2R C2 C3R 200 10/25 kAIC 20 20 30 30 40 40 40 40 40 40 40 40 Indoor Outdoor Indoor Outdoor Indoor Outdoor D1 D1R G1 G1R L1 L1R Wire Size Range Cu/Al 60°C or 75°C for Main See main breaker and main lug kit tables (Page 2-31). Loadcenter with Combination or NEMA Type 3R Cover Catalog Number UPC Code BR1224NC125 BR1224NC125R BR2024NC125 BR2024NC125R 786676448055 786676448109 786676448352 786676448406 BR2040NC200 BR2040NC200R BR3040NC200 BR3040NC200R BR4040NC200 BR4040NC200R 786676448758 786676448802 786676448956 786676001090 786676449106 786676449151 All main circuit breaker loadcenters are listed for use as service entrance equipment and are shipped with a neutral bonding strap preattached. The maximum main rating of the loadcenter is the main breaker rating when used as service entrance equipment. 100, 125 and 200 ampere Convertible base unit catalog numbers include interior, box and cover only. Accessories must also be ordered separately for field installation. All Convertible base units are listed as suitable for use as service entrance equipment when used per Article 384 of the NEC. Interrupting rating depends on main circuit breaker selected. Hold-down screw BREQS125 comes with loadcenter for back-fed Types BR and BRH main circuit breakers. Suitable for use as service equipment when not more than six main disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Rainproof loadcenters are furnished with hub closure plates. Loadcenters Main Ampere Rating TABLE 2-52. CONVERTIBLE — 3-PHASE 4-WIRE — 208Y/120 VAC OR 240 VAC — INSULATED/BONDABLE NEUTRAL Maximum Number 1-Inch (25.4 mm) Main Ampere Rating Spaces 100 10/22 kAIC 125 10/22 kAIC Poles Enclosure Type Box Size 30 30 30 30 Indoor Outdoor D1 D1R 12 12 24 24 Indoor Outdoor C1 C1R Wire Size Range Cu/Al 60°C or 75°C for Main See main breaker and main lug kit tables (Page 2-31). Loadcenter with Combination or NEMA Type 3R Cover Catalog Number UPC Code 3BR3030NC100  3BR3030NC100R  786676443050 786676443104 3BR1224NC125  3BR1224NC125R  786676443302 786676443357 All main circuit breaker loadcenters are listed for use as service entrance equipment and are shipped with a neutral bonding strap preattached. The maximum main rating of the loadcenter is the main breaker rating when used as service entrance equipment. 100, 125 and 200 ampere Convertible base unit catalog numbers include interior, box and cover only. Accessories must also be ordered separately for field installation. All Convertible base units are listed as suitable for use as service entrance equipment when used per Article 384 of the NEC. Interrupting rating depends on main circuit breaker selected.  Hold-down screw BREQS125 comes with loadcenter for back-fed Types BR and BRH main circuit breakers.  Rainproof loadcenters are furnished with hub closure plates.  Convertible to maximum of 100 ampere main breaker and 125 ampere main lug.  Suitable for use as service equipment when not more than six main disconnecting means are provided and when not used as a lighting and appliance panelboard (see Article 408-34 of the NEC). Dimensions for boxes on Pages 2-41 – 2-43. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-33 COMMERCIAL LOADCENTERS — INDOOR ENCLOSURES MAIN CIRCUIT BREAKER, MAIN LUG AND CONVERTIBLE, SINGLE-PHASE AND THREE-PHASE Wire Size Range Cu/Al 60°C or 75°C for Main Breaker Encl. Type Box Size Circuits Spaces Maximum Number 1-Inch (25.4 mm) Loadcenter Catalog Number UPC Code Flush Loadcenter Cover Surface Loadcenter Cover Catalog Number Catalog Number UPC Code UPC Code Single-Phase 3-Wire — 120/240 Vac Insulated/Bondable Neutral CC 200 42 10 kAIC 42 Indoor A #1 – 300 kcmil BR4242B200NY 782114885734 3BR42FTNY 782114801222 3BR42STNY 782114801239 Approved for 150 ampere and up for residential services in New York City. Encl. Type Box Size Main Lug Ampere Rating Circuits Maximum Number 1-Inch (25.4 mm) Wire Size Range Cu/Al 60°C or 75°C for Main Breaker TABLE 2-54. SINGLE-PHASE MAIN LUGS — FACTORY INSTALLED Spaces Loadcenters Main Breaker Type Main Ampere Rating TABLE 2-53. SINGLE-PHASE MAIN CIRCUIT BREAKER — FACTORY INSTALLED Loadcenter Catalog Number UPC Code Flush Loadcenter Cover Surface Loadcenter Cover Catalog Number Catalog Number UPC Code UPC Code Single-Phase 3-Wire — 120/240 Vac Insulated/Bondable Neutral 225 42 42 Indoor A #1 – 300 BR4242L225NY 782114826546 3BR42FTNY 782114801222 3BR42STNY 782114801239 kcmil Approved for 150 ampere and up for residential services in New York City. Encl. Type Box Size Circuits Main Ampere Rating Spaces Maximum Number 1-Inch (25.4 mm) Wire Size Range Cu/Al 60°C or 75°C for Main Breaker TABLE 2-55. THREE-PHASE CONVERTIBLE LOADCENTERS Loadcenter Catalog Number UPC Code Flush Loadcenter Cover Surface Loadcenter Cover Catalog Number Catalog Number UPC Code UPC Code 3-Phase 4-Wire — 120/240 Vac Insulated/Bondable Neutral 225 42 42 Indoor B #1 – 300 3BR4242N225NY 782114790243 3BR42FTNY 782114801222 3BR42STNY 782114801239 kcmil Approved for 150 ampere and up for residential services in New York City. Order main device from Table 2-56 and Table 2-57 below. TABLE 2-56. THREE-PHASE MAIN BREAKER KITS TABLE 2-57. THREE-PHASE MAIN LUGS KIT Ampere Wire Size Range Main Breaker Kit UPC Rating Cu/Al 60°C or 75°C 10 kAIC Code 150 175 200 225 #4 – 4/0 #2/0 – 300 kcmil CC3150N CC3175N CC3200N CC3225N 782114652060 782114652077 782114652084 782114652091 Ampere Rating Wire Size Range Cu/Al 60°C or 75°C Main Lugs Kit UPC Code 225 #2/0 – 300 kcmil 3BRL225 782114790250 Dimensions for boxes on Pages 2-41 – 2-43. 2-34 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 BR Renovation Loadcenter Value Packs Product Description ✓ Available in 10, 20, 30 and 40 circuit main ✓ ✓ ✓ Features, Functions & Benefits ✓ Factory-installed terminal block(s) allows installer ✓ ✓ ✓ ✓ BR Renovation Loadcenters to terminate existing short wires without using wire nuts or junction boxes. Twin-stacked neutrals are mounted up high in the loadcenter, which allows for all neutral and ground wires to be terminated in the top half of the loadcenter. Specifically designed for the service contractor — this is the ONLY renovation line in the industry. Single-pole and two-pole breakers included. 10-year warranty on loadcenter and breakers. Loadcenters ✓ breaker styles. Designed to replace existing loadcenters and fuse boxes. Type BR loadcenter packaged with circuit breakers. Factory-installed 5-circuit terminal block(s). Twin-stacked neutral design. TABLE 2-58. PRODUCT SELECTION Main Breaker Type Description Wire Size Range BR 10 kAIC #6 – 1/0 0 (2) BR115 (1) BR230 BR1020B100S11RN 782116417070 0 (2) BR115 (1) BR230 BR1020B100F11RN 782116417087 Single-Phase 100 Ampere #2 – 300 1 10 kAIC Main Breaker 20/20 Circuit kcmil (5) BR120 (1) BR230 BR2020B100RN 782116417094 Single-Phase 200 Ampere 10 kAIC Main Breaker 30/40 Circuit 2 (5) BR115 (5) BR120 (1) BR230 BR3040B200RN (1) BR250 782116417100 Single-Phase 200 Ampere 10 kAIC Main Breaker 40/40 Circuit 2 (6) BR115 (6) BR120 (1) BR230 BR4040B200RN (1) BR250 782116417117 Single-Phase 100 Ampere 10 k Main Breaker 10/20 Circuit Surface-Mount Box is 11.75" Wide x 13" Tall Single-Phase 100 Ampere 10 k Main Breaker 10/20 Circuit Flush-Mount Box is 11.75" Wide x 13" Tall BW 10 kAIC Number of Single-Pole Two-Pole Catalog 5-Circuit Breakers Number Terminal Blocks Breakers UPC Code Note: Indoor enclosure type. Cutler-Hammer Quick-Pro SM All you need to know to save time and make more money. Specified on certain Cutler-Hammer products, the Quick-Pro symbol allows for immediate recognition of products that are designed for straightforward installation. When you see Quick-Pro, you know you can install quickly — sometimes up to 50% less than the usual installation time — and move onto your next job. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-35 Data Tables TABLE 2-59. VALUE PACKS — SINGLE-PHASE — INDOOR — MAIN CIRCUIT BREAKER LOADCENTERS — COMBINATION COVER AND BREAKERS INCLUDED SINGLE-PHASE, 3-WIRE — 120/240 VAC — FACTORY BONDED SPLIT NEUTRAL — ALUMINUM BUS Loadcenter Loadcenters Maximum Number Main Maximum 1-Inch (25.4 mm) Wire Size Breaker Main Ampere Spaces Circuits Range Type Rating Breakers Included BR 10 kAIC 100 20 20 #6 – 1/0 5-BR120 & 1 BR230 BR2020B100V 6-BR120, 6-BR115, 1-BR230 & 1-BR250 BR2020B100V4 BW 10 kAIC 150 30 30 #1 – 300 kcmil 10-BR120 & 1-BR230 BR3030B150V2 782114894446 200 20 40 — — 5-BR120 & 1-BR230 5-BD2020 & 1-BR230 BR2040B200V BR2040B200V3 786676445702 782114894453 30 40 — — — BR3040B200V 5-BR120 & 1 BR230 BR3040B200V2 10-BR120 & 1-BR230 6-BR120, 6-BR115, 1-BR230 & 1-BR250 BR3040B200V4 786676001106 782114894460 782113491653 40 40 — — 5-BR120 & 1 BR230 10-BR120 & 1-BR230 786676446204 782114894484 Catalog Number BR4040B200V BR4040B200V2 UPC Code 786676444255 782113491646 TABLE 2-60. VALUE PACKS — SINGLE-PHASE — INDOOR — MAIN CIRCUIT BREAKER LOADCENTERS — COMBINATION COVER AND BREAKERS INCLUDED — SINGLE-PHASE, 3-WIRE — 120/240 VAC — FACTORY BONDED SPLIT NEUTRAL — COPPER BUS Maximum Number Main Wire Maximum 1-Inch (25.4 mm) Breaker Main Ampere Range Spaces Circuits Size Type Rating Loadcenter Breakers Included Catalog Number UPC Code 5-BR120 & 1-BR230 BR2020BC100V BR3030BC100V 782113491639 782113491639 782116103690 782116103706 BR 10 kAIC 100 20 30 20 30 #6 – 1/0 BW 10 kAIC 200 30 40 40 40 #1 – 300 kcmil 5-BR120, 1-BR230 & 2-BR120AF 5-BR120, 1-BR230 & 2-BR120AF BR3040BC200VA BR4040BC200VA BW 10 kAIC 200 30 30 40 40 #1 – 300 kcmil 10-BR120, 1-BR230 5-BR120, 1-BR230 & 2-BR115AF BR3040BC200V2 782116484379 BR3040BC200VA15 782116123285 BW 10 kAIC 200 40 40 40 40 #1 – 300 kcmil 5-BR120, 1-BR230 & 2-BR115AF 10-BR120 & 1-BR230 BR4040BC200VA15 782116123292 BR4040BC200V2 782116484386 TABLE 2-61. VALUE PACKS — SINGLE-PHASE — OUTDOOR — MAIN CIRCUIT BREAKER LOADCENTERS — BREAKERS INCLUDED — SINGLE-PHASE, 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL — ALUMINUM BUS Maximum Number Main Wire Maximum 1-Inch (25.4 mm) Breaker Main Ampere Range Spaces Circuits Size Type Rating Loadcenter Breakers Included Catalog Number UPC Code BR 10 kAIC 100 20 24 #6 – 1/0 5-BR120 & 1 BR230 BR2024B100RV 786676002219 BW 10 kAIC 200 30 40 #1 – 300 kcmil 5-BR120 & 1 BR230 BR3040B200RV 786676002226 TABLE 2-62. VALUE PACKS — SINGLE-PHASE — INDOOR — MAIN LUG LOADCENTERS — BREAKERS INCLUDED — SINGLE-PHASE, 3-WIRE — 120/240 VAC — INSULATED/BONDABLE NEUTRAL — ALUMINUM BUS Maximum Number Main Wire Maximum 1-Inch (25.4 mm) Breaker Main Ampere Range Spaces Circuits Size Type Rating BW 10 kAIC 2-36 200 30 40 Loadcenter Breakers Included #1 – 300 kcmil 10-BR120 & 1-BR230 Catalog Number UPC Code BR3040L200V2 782114894477 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Circuit Breaker Unit Enclosures BW2200 Circuit Breaker TABLE 2-63. CIRCUIT BREAKER UNIT ENCLOSURES — UNIT ENCLOSURE INCLUDES LUG TREE KIT Unit Enclosure Catalog Number Circuit Wire Size Main Breaker Range Cu/Al Ampere Encl. Type 60°C or 75°C Rating Type Unit Enclosure Catalog Number Flush Cover Surface Cover Catalog Number Catalog Number UPC Code Encl. Type — — Outdoor BR2100BRP 786676001687 RCC150SEBP 782114105344 RCC200SEBP 782114105337 UPC Code Rainproof NEMA Type 3R Catalog Number UPC Code Loadcenters SINGLE-PHASE AND 3-PHASE — CIRCUIT BREAKER UNIT ENCLOSURES — 10,000/25,000 AMPERES INTERRUPTING CAPACITY Type ECB Circuit Breaker Unit Enclosures — Factory-Installed Main Breaker BW/BR 10 kAIC 100 150 200 — — — Type ECB Circuit Breaker Unit Enclosures — Order Types BW and BWH Circuit Breakers Separately Single-Phase 3-Wire — 240 Vac Maximum BW 10 kAIC 225 Indoor ECB225F 782113098753 ECB225S 782113098746 Outdoor ECB225R 782113098760 BWH 25 kAIC Type ECC Circuit Breaker Unit Enclosures — Order Type CC Circuit Breakers Separately Single-Phase 3-Wire/3-Phase 4-Wire — 240 Vac Maximum CC 10 kAIC 225 Indoor ECC225F 782114225196 ECC225S 782114225202 Outdoor ECC225R 782114225219 Wire size is determined by the circuit breaker installed in enclosure. See table below. Order circuit breaker separately. One ground lug accepting (1) #14 – #2 is factory installed. Also, there are pre-drilled holes to accept a GBK5 ground bar. Rainproof enclosures are furnished with hub closure plates. TABLE 2-64. MAXIMUM WIRE SIZE Maximum Ampere Rating Wire/Application Maximum Wire Size 200 Aluminum – Standard 250 kcmil 225 Aluminum – Service Entrance 250 kcmil 225 Copper – Standard and Service Entrance 250 kcmil EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-37 SINGLE-PHASE AND 3-PHASE — CIRCUIT BREAKER UNIT ENCLOSURES — 10,000/25,000 AMPERES INTERRUPTING CAPACITY TABLE 2-65. TYPES BW AND BWH CIRCUIT BREAKERS — 120/240 VAC — 10 AND 25 kAIC FOR USE IN TYPE ECB UNIT ENCLOSURES 2-Pole Breakers Ampere Rating Loadcenters 125 150 175 200 225 Wire Size Range Cu/Al 60°C or 75°C for Line Terminals #2 – 300 kcmil 10 kAIC 25 kAIC Catalog Number UPC Code Catalog Number UPC Code BW2125 BW2150 BW2175 BW2200 BW2225 786676460408 786676460507 786676460552 786679122556 786679122556 BWH2125 BWH2150 BWH2175 BWH2200 BWH2225 786676460439 786676460453 786676449700 786676460606 786679122563 TABLE 2-66. BW/BWH LUG TREE KIT — FOR REPLACEMENT PURPOSES ONLY FOR USE IN TYPE CCM UNIT ENCLOSURES Ampere Rating Wire Size Range Cu/Al 60°C or 75°C for Line Terminals 225 #2 – 300 kcmil Catalog Number Description For use on 125, 150, 175, 200 and 225 Ampere BW and BWH Breakers UPC Code MCBK225 782114110591 TABLE 2-67. TYPE CC CIRCUIT BREAKERS — 240 VAC —10 kAIC FOR USE IN TYPE ECC UNIT ENCLOSURES Ampere Rating Wire Size Range Cu/Al 60°C or 75°C for Line Terminals Type CC 10 kAIC Type CC Hi-Mag 10 kAIC Catalog Number UPC Code Catalog Number UPC Code 2-Pole 100 125 150 #4 – 4/0 CC2100 CC2125 CC2150 782113386546 782113266565 782113266572 CC2100HM CC2125HM CC2150HM 782113828589 782113828596 782113828602 175 200 225 #2/0 – 300 kcmil CC2175 CC2200 CC2225 782113266589 782113266596 782113266602 CC2175HM CC2200HM CC2225HM 782113828619 782113828626 782113828633 100 125 150 #4 – 4/0 CC3100 CC3125 CC3150 782113386553 782113266619 782113266626 CC3100HM CC3125HM CC3150HM 782113828640 782113828657 782113828664 175 200 225 #2/0 – 300 kcmil CC3175 CC3200 CC3225 782113266633 782113266640 782113266657 CC3175HM CC3200HM CC3225HM 782113828671 782113828688 782113828695 3-Pole 2-38 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Loadcenter Options and Accessories TABLE 2-68. FIELD INSTALLATION KITS AND PARTS Number of Poles Ampere Rating No. of 1-Inch (25.4 mm) Spaces Needed Wire Size Range Cu/Al 60°C or 75°C Ordering Qty. Catalog Number UPC Code 786676001762 786676001779 786676461405 Main and Sub-Feed Lug Blocks 125 150 225 4 4 4 #8 – 2/0 #8 – 2/0 #2 – 300 kcmil 1 1 1 BRSF125 BRSF150 BRS225 3 150 225 6 6 #8 – 2/0 #2 – 300 kcmil 1 1 3BRSF150 786676001786 3BRS225 786676461504 #1 – 300 kcmil 1 BRL200 786676460101 #2/0 Maximum #3/0 Maximum 300 kcmil Maximum 1 1 1 NL20 NL30 NL300 782113099156 782113099163 782113099170 25 1 BRFP BWFP 786676461603 782114127384 Door Lock —12 through 42 Circuits, and 100 through 225 Amperes 1 TDL 782113099040 Door Lock — 4 through 8 Circuits, 125 Amperes 1 CH9FL 782113101224 ANSI-61 Light Gray Touchup Paint for Current Loadcenters 1 SPC61 782113098777 Isolated Neutral Assembly (Computer Circuits) 1 BINA 782113099439 Circuit Directory — Adhesive Backed 10 TCD 782113099019 Cover Screws 25 LCCS 782113099583 Cover Replacement Latch (Gray) 14.31 (363.5 mm) Wide — Loadcenters Only 1 BRRL 786676461757 Circuit Marking Strip (Next to Breaker) 10 BRMS 786676101509 Circuit Identification Label (Preprinted Breaker Labels) 25 CHBL 782113099712 Series Rated Caution Label 25 SRL 782113099002 Bonding Strip with Screw 1 BSSUSE 782114127339 Main Lugs — 2-Pole, 200 Ampere Stud Mounted (Includes Deadfront Filler Plate) Neutral/Ground Lug Add-On Neutral or Ground Lug Filler Plates: 1-Inch (25.4 mm) Circuit Breaker Space BW Main Circuit Breaker Space (with Hardware) BRSF125 3BRS225 Loadcenters 2 BRL200 Must be purchased in multiples of ordering quantities indicated. TDL TABLE 2-69. FIELD INSTALLATION RAINPROOF CONDUIT HUBS Conduit Size Inches (mm) Catalog Number UPC Code Group 1 — For use with 70, 100 and 125 Ampere MLO and MCB Loadcenters and Circuit Breaker Enclosures and the following 150 and 200 Ampere Panels: BR816B150RF, BR816B200RF 0.75 (19.1) 1.00 (25.4) 1.25 (31.8) 1.50 (38.1) 2.00 (50.8) DS075H1P DS100H1P DS125H1P DS150H1P DS200H1P 786676805001 786676805056 786676805100 786676805155 786676805209 Group 2 — For use with 150, 200 and 225 Ampere MLO and MCB Loadcenters and Circuit Breaker Enclosures except for the following 200 Ampere Loadcenters: BR48B200RF 2.00 (50.8) 2.50 (63.5) 3.00 (76.2) DS200H2P 786676462068 DS250H2P 786676000505 DS300H2P 786676000529 Type R1H Conduit Hubs for 400 and 600 Ampere Loadcenters and New York City Loadcenters 2.00 (50.8) 2.50 (63.5) 3.00 (76.2) R1H200 R1H250 R1H300 786676201254 786676201261 786676201278 Type H Conduit Hubs for Loadcenters PL0724R and S3100RN 0.75 (19.1) 1.00 (25.4) 1.25 (31.8) 1.50 (38.1) 2.00 (50.8) RH75P RH100P RH125P RH150P RH200P 786676213257 786676213356 786676213455 786676213554 786676213653 — — — DS900AP 782113099422 DS900CP1 782114014394 DS900CP2 782114014400 Description Adapter Kit — Allows Installing a Group 1 Hub on Devices Arranged for Group 2 Hubs Group 1 Small Blank Hub Plate with Bump Group 2 Large Blank Hub Plate with Bump DS300H2 Ordering quantity [for all catalog numbers is one. Must be purchased in multiples. TABLE 2-70. CLAMSHELL ACCESSORIES Description Catalog Number UPC Code Field Installation Kits and Parts Main or Sub-Feed Lug Block Filler Plates Cover Screws Circuit Identification Labels — Description Catalog Number UPC Code Rainproof Conduit Hubs BRSF125CS BRFPCS LCCSCS CHBLCS — 782114793176 782114793121 782114793428 782114793206 — Type 1 Hub Type 1 Hub Type 1 Hub Type 1 Hub Type 2 Hub DS075H1CS DS100H1CS DS125H1CS DS150H1CS DS200H2CS 782114793275 782114793282 782114793299 782114793305 782114793312 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-39 Loadcenter Options and Accessories TABLE 2-71. GROUND BAR KITS Description (See Legend) 䊋 䊉 䊋 䊋 䊋 䊑 䊋 䊉 䊋 䊑 䊋 䊋 䊋 䊉䊊䊊䊊䊊䊉䊊 䊉䊊䊊䊊䊊䊉䊊䊏 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊏 Loadcenters 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊏 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊 䊉䊊䊊䊊䊊䊉䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊊䊏 䊔䊋䊔䊉䊔䊋䊔䊔䊔䊋䊔䊉䊔䊋䊔䊔䊔䊋䊔 䊊䊊䊊䊊䊊 Length Inches (mm) Ordering Quantity Catalog Number UPC Code 2.54 (64.5) 3.59 (91.2) 4.29 (109.0) 5.34 (135.6) 4.61 (117.1) 5.69 (144.5) 6.74 (171.2) 8.14 (206.8) 9.19 (233.4) 5.78 (146.8) 1.84 (46.7) 1 1 1 1 1 1 1 1 1 1 1 GBK5P GBK520 GBK10P GBK1020 GBK13 GBK14P GBK1420 GBK21P GBK2120 BRGBK39512 GB4NMP 786676460804 782114014356 782114462058 782114014554 782114220610 786676461153 782113099576 786676461252 782113099552 786676449359 786676378031 GBK14 BRGBK39512 Distance between mounting holes is 1.75 inches (44.5 mm). For 1- and 3-phase 400 and 600 ampere applications. Distance between mounting holes is 2.34 inches (59.5 mm). For non-metallic enclosures. Snaps into molded base. Ground Bar Legend 䊋 䊑 䊊 䊏 䊔 䊋 䊉 (3) #14 – #10 Cu/Al or (1) #14 – #4 Cu/Al (1) #6 – 2/0 Cu/Al (1) #14 – #6 Cu/Al or (2) #14 – #12 Cu/Al (1) 1/8 – 14 or (3) #10 – 12 Cu/Al (1) #14 – 1/0 Cu/Al or (3) #14 – #10 Cu/Al (1) #6 – 14 Cu/Al or (2) #1/0 – 14 Cu/Al Mounting Hole TABLE 2-72. CLAMSHELL ACCESSORIES 2-40 Description Catalog Number UPC Code Ground Bar Kit Ground Bar Kit Ground Bar Kit Ground Bar Kit Ground Bar Kit Ground Bar Kit Ground Bar Kit GBK5CS GBK520CS GBK10CS GBK1020CS GBK13CS GBK14CS GBK21CS 782114793411 782114793404 782114793343 782114793336 782114793350 782114793374 782114793398 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Technical Data and Specifications RESIDENTIAL/COMMERCIAL/ NEW YORK CITY LOADCENTERS, UNIT ENCLOSURES — BOX SIZES TABLE 2-75. COMMERCIAL LOADCENTERS — NEMA TYPE 1 INDOOR Note: Box sizes do not include covers/fronts. TABLE 2-73. RESIDENTIAL LOADCENTERS — NEMA TYPE 1 INDOOR Dimensions in Inches Box Depth Size Height Width Dimensions in mm Height Width Depth A1 B1 B2 C1 C2 C4 D1 G1 L1 L2 2 3 4 5 6 7 9 381.0 425.5 476.3 533.4 584.2 685.8 739.8 866.8 990.6 1143.0 219.1 239.7 330.2 239.7 304.8 330.2 368.3 285.8 363.5 363.5 363.5 363.5 363.5 363.5 363.5 363.5 363.5 127.0 114.3 279.4 114.3 174.6 279.4 165.1 95.3 98.4 98.4 98.4 98.4 98.4 98.4 98.4 98.4 98.4 88.9 76.2 90.5 76.2 114.3 90.5 88.9 15.00 16.75 18.75 21.00 23.00 27.00 29.13 34.13 39.00 45.00 8.63 9.44 13.00 9.44 12.00 13.00 14.50 11.25 14.31 14.31 14.31 14.31 14.31 14.31 14.31 14.31 14.31 5.00 4.50 11.00 4.50 6.88 11.00 6.50 3.75 3.88 3.88 3.88 3.88 3.88 3.88 3.88 3.88 3.88 3.50 3.00 3.56 3.00 4.50 3.56 3.50 TABLE 2-74. RESIDENTIAL LOADCENTERS — NEMA TYPE 3R OUTDOOR 19 20 22 24 Dimensions in mm Dimensions in Inches Height Width Depth Height Width Depth 44.00 44.00 54.00 66.50 16.16 16.16 16.22 16.22 6.25 6.25 6.31 6.31 1117.6 1117.6 1371.6 1689.1 410.4 410.4 412.0 412.0 158.8 158.8 160.3 160.3 TABLE 2-76. COMMERCIAL LOADCENTERS — NEMA TYPE 3R OUTDOOR Box Size 42 43 46 47 Dimensions in mm Dimensions in Inches Height Width Depth Height Width Depth 38.00 44.00 54.00 66.56 16.31 16.31 16.31 16.31 6.38 6.38 6.38 6.38 965.2 1117.6 1371.6 1690.7 414.3 414.3 414.3 414.3 161.9 161.9 161.9 161.9 TABLE 2-77. NEW YORK CITY LOADCENTERS — NEMA TYPE 1 INDOOR Box Size A B C Dimensions in mm Dimensions in Inches Height Width Depth Height Width Depth 38.00 44.00 66.50 18.13 18.13 18.13 5.00 5.00 6.25 965.2 1117.6 1689.1 460.4 460.4 460.4 127.0 127.0 158.8 TABLE 2-78. TYPES ECB AND ECC UNIT ENCLOSURES — NEMA TYPE 1 INDOOR Dimensions in Inches Box Size Height Width Depth Dimensions in mm Height Width Depth Height Width Depth Height Width Depth B1R B2R C3R D1R G1R L1R L2R 2R 3R 4R 5R 6R 7R 8R 9R C1R 425.5 476.3 635.0 739.8 866.8 990.6 1143.0 219.1 239.7 330.2 239.7 298.5 330.2 685.8 362.0 533.4 363.5 363.5 363.5 363.5 363.5 363.5 363.5 127.0 114.3 279.4 114.3 165.1 279.4 266.7 165.1 363.5 131.8 131.8 131.8 131.8 131.8 131.8 131.8 88.9 76.2 90.5 76.2 114.3 90.5 120.7 101.6 131.8 23.25 8.88 4.50 590.6 225.4 114.3 16.75 18.75 25.00 29.13 34.13 39.00 45.00 8.63 9.44 13.00 9.44 11.75 13.00 27.00 14.25 21.00 14.31 14.31 14.31 14.31 14.31 14.31 14.31 5.00 4.50 11.00 4.50 6.50 11.00 10.50 6.50 14.31 5.19 5.19 5.19 5.19 5.19 5.19 5.19 3.50 3.00 3.56 3.00 4.50 3.56 4.75 4.00 5.19 Loadcenters Box Size Dimensions in Inches Dimensions in mm TABLE 2-79. TYPES ECB AND ECC UNIT ENCLOSURES — NEMA TYPE 3R OUTDOOR Dimensions in Inches Dimensions in mm Height Width Depth Height Width Depth 23.68 9.31 5.44 601.7 236.5 138.1 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-41 RESIDENTIAL LOADCENTER KNOCKOUTS — DIMENSIONS IN INCHES (MM) Knockouts for Box Sizes A1, B1, B2, C1, C2, C4, D1, G1, L1, L2, B1R, B2R, C1R C3R, D1R, G1R, L1R, L2R Code A Diameter in Inches .50 .75 Diameter in mm Code Diameter in Inches Diameter in mm A .50 .50 — — — 12.7 19.1 — — — B — — — 12.7 — — — .75 — — 12.7 19.1 — — Loadcenters .50 — — — — 12.7 — — — — C .50 .75 1.00 — .50 1.25 1.50 2.00 2.50 12.7 31.8 38.1 50.8 63.5 D .50 .75 1.00 1.25 12.7 19.1 25.4 31.8 D 1.25 1.25 2.00 2.50 — 31.8 38.1 50.8 63.5 — E .75 1.00 1.25 — E .50 .75 1.00 — — 12.7 19.1 25.4 — — F .75 1.00 1.25 1.50 19.1 25.4 31.8 38.1 F .50 .75 1.00 1.50 2.00 12.7 19.1 25.4 38.1 50.8 G 1.00 1.25 1.50 — G 1.25 1.50 2.00 — — 31.8 38.1 50.8 — — H 1.00 1.25 1.50 2.00 25.4 31.8 38.1 50.8 I 1.25 1.50 2.00 — .50 .75 1.00 1.25 1.50 12.7 19.1 25.4 31.8 38.1 1.00 1.25 1.50 2.00 2.50 25.4 31.8 38.1 50.8 63.5 J 1.00 1.25 1.50 — — 25.4 31.8 38.1 — — .50–.75 (12.7–19.1) 2.38 (60.3) .31 (7.9) B I –1.25 KO –31.8) KO R 6.38 3 (161.9) 1 Box 2, 2R C H Mounting Hole for 5/16 (7.9) Screw Knockouts for Box Sizes 3, 4, 5, 6, 7, 9, 2R, 3R, 4R, 5R, 6R, 7R, 8R, 9R 12.7 19.1 25.4 — .50– (12.7– .50– – (12.7 19.1 25.4) – – 19.1 25.4 31.8 — A F 25.4 31.8 38.1 — A A E A A Box 3 31.8 38.1 50.8 — C C A F 2.06 (52.3) Dia. (125A A Max.) 3.06 (77.7) Dia. (225A A Max.) D B A A G Outdoor Boxes B1R, B2R, C1R C3R, D1R, G1R, L1R, L2R Hub A A A B B G B A D D D E A B B B B B B B B B B B H B B I B J B J J A A A A G G A A A A A A D A A A G B D B B A A B B A B Box 3R B Box 4 Box 4R B A B Hub A F B H A A D B A C F F B B A B B B B B A J J B B J E B B B A A J D D B B H A D D F A Box 5 B B B I B B D A F B .45 (11.4) Dia. KO A B B B E E D A F F A A A B C A H Box 5R F B Box 6 E B C A A A A D D B A B Hub D B E J B G B B Hub A A A D E A B B A B G G B A F A D A A A F A E A B D A G D D .45 (11.4) Dia. KO A G E B B G A B A B A B A B A E D D D D D .45 (11.4) Dia. KO B A B E I B B H B F A B B B B B D D B E A E B A B G B A B A E A B B A E A D D B B I B B B B B B A H B B B Hub G A G G B B C I C I C I B B B B G G G A B A A A A G G G D .45 (11.4) Dia. KO E G B C Box 7R A C E A B B A A A A A B B A G F C D D E D G Box 7 Hub E G A I B C A A A G B C Box 6R B H F A A A B H C G A .45 (11.4) Dia. KO A D B B C C E A Indoor Boxes C1, C2, C4, D1, G1, L1, L2 B B A G A A A Indoor Boxes B1, B2 A Hub Hub Indoor Boxes A1 E A A A A A A C B B C Box 8R B A C G A Box 9 G A C B A Box 9R FIGURE 2-5. RESIDENTIAL NEMA TYPE 1 INDOOR AND NEMA TYPE 3R OUTDOOR ENCLOSURES 2-42 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 COMMERCIAL LOADCENTER KNOCKOUTS A TABLE 2-80. NEMA TYPE 1 INDOOR COMMERCIAL ENCLOSURES KNOCKOUTS FOR BOX SIZES 19, 20, 22, 24 A .50 B .50 C — A C H E C Diameter in mm — — 12.7 — — — .75 — — 12.7 19.1 — — .75 1.00 1.50 — 19.1 25.4 38.1 — D 1.50 2.00 2.50 3.00 38.1 50.8 63.5 76.2 E 2.00 2.50 3.00 — 50.8 63.5 76.2 — F 2.50 3.00 3.50 — 63.5 76.2 88.9 — D D A C D B B B F D E E A E C Box 19, 20 E B B B F E Loadcenters Code Diameter in Inches H E E Box 22, 24 FIGURE 2-6. INDOOR COMMERCIAL ENCLOSURES TABLE 2-81. NEMA TYPE 3R OUTDOOR COMMERCIAL ENCLOSURES KNOCKOUTS FOR BOX SIZES 42, 43, 46, 47 Code Diameter in Inches A .50 B .50 C — Diameter in mm — — 12.7 — — — .75 — — 12.7 19.1 — — .75 1.00 1.25 — 19.1 25.4 31.8 — D 1.50 2.00 2.50 — 38.1 50.8 63.5 — E 2.00 2.50 3.00 — 50.8 63.5 76.2 — F 2.50 3.00 3.50 — 63.5 76.2 88.9 — G 1.25 1.50 2.00 2.50 31.8 38.1 50.8 63.5 H 3.25 Sq. — — — 82.6 Sq. — — — HUB E D HUB E HUB E D D C B B B F HUB F F D C B B B B G B F A F G A Box 42 Box 43, 46, 47 FIGURE 2-7. OUTDOOR COMMERCIAL ENCLOSURES TABLE 2-82. UNIT ENCLOSURE KNOCKOUTS, TYPES ECB AND ECC KNOCKOUTS Code Diameter in Inches A Diameter in mm NEMA Type 1 Indoor (Flush and Surface Trims) A B .50 — — — — 12.7 — — — B HUB B B B B B B — 1.25 1.50 1.75 2.00 2.50 31.8 38.1 44.5 50.8 63.5 NEMA Type 3R Outdoor A B .50 — — — — 12.7 — — — — 1.25 1.50 1.75 2.00 2.50 31.8 38.1 44.5 50.8 63.5 B B B A NEMA Type 1 — Indoor B B A NEMA Type 3R — Outdoor FIGURE 2-8. UNIT ENCLOSURE KNOCKOUTS EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-43 Surge Loadcenters Product Description The Type CH Surge Loadcenter includes a factorymounted and wired surge suppressor device. There is a knockout in the cover which allows the user to view the status indication lights on the surge suppressor. The CH Surge Loadcenter reduces the force of power line surges to an acceptable level for surge strips to handle. Loadcenters Features, Functions and Benefits LOADCENTER ✓ 35 kAIC main breaker, main lug only, and convertible main breaker/main lug. ✓ Factory installed or provision for field installed surge suppressor. ✓ Top or bottom feed. SURGE SUPPRESSOR (CHSPULTRA) CHSPULTRA New Surge Loadcenter ✓ ✓ ✓ ✓ ✓ Total joules: 3,500 joules. Maximum surge current: 175,000 amperes . Per phase (L-N/L-G) Surge Current: 75,000 amperes. Warranty: Lifetime. Connected equipment warranty: $5,000. Cutler-Hammer Quick-Pro SM All you need to know to save time and make more money. Specified on certain Cutler-Hammer products, the Quick-Pro symbol allows for immediate recognition of products that are designed for straightforward installation. When you see Quick-Pro, you know you can install quickly — sometimes up to 50% less than the usual installation time — and move onto your next job. 2-44 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 Data Tables TABLE 2-83. SINGLE-PHASE MAIN CIRCUIT BREAKER LOADCENTERS WITH FACTORY INSTALLED SURGE SUPPRESSION — INDOOR SINGLE-PHASE 3-WIRE — 120/240 VAC — FACTORY BONDED SPLIT NEUTRAL 24 32 E K #6 – 4/0 150 200 200 32 32 42 K K L #2 – 300 kcmil CHSUR32B150K 782116200085 CHSUR8KF 782116200238 CHSUR8KS 782116200276 CHSUR32B200K 782116200108 CHSUR8KF 782116200238 CHSUR8KS 782116200276 CHSUR42B200L2 782116320196 CHSUR8LF 782116200245 CHSUR8LS 782116200283 Combination Surface Catalog Number Catalog Number Catalog Number CHSUR24B100E 782116200054 CHSUR8EF 782116200221 CHSUR8ES 782116200269 CHSUR32B100K 782116200078 CHSUR8KF 782116200238 CHSUR8KS 782116200276 UPC Code UPC Code UPC Code Combination style covers may be used for surface or flush mount applications. See Page 2-18 for dimensions. Maximum Main Ampere Rating Maximum Number 3/4-Inch (19.1 mm) Single Poles TABLE 2-84. SINGLE-PHASE MAIN LUG LOADCENTERS WITH FACTORY INSTALLED SURGE SUPPRESSION — INDOOR SINGLE-PHASE 3-WIRE — 120/240 VAC — TWIN NEUTRAL — FACTORY INSTALLED GROUND BAR Loadcenter Loadcenters 100 Maximum Main Ampere Rating Maximum Number 3/4-Inch (19.1 mm) Single Poles Loadcenter Cover Box Wire Size Range Size Main Breaker Type CSH 35 kAIC Loadcenter Loadcenter Cover Combination Surface Box Wire Size Range Size Catalog Number UPC Code Catalog Number UPC Code Catalog Number UPC Code 125 24 E #6 – 2/0 CHSUR24L125E 782116200061 CHSUR8EF 782116200221 CHSUR8ES 782116200269 225 32 42 K L #2 – 300 kcmil CHSUR32L225K CHSUR42L225L2 782116200092 782116320202 CHSUR8KF CHSUR8LF 782116200238 782116200245 CHSUR8KS CHSUR8LS 782116200276 782116200283 Combination style covers may be used for surface or flush mount applications. See Page 2-18 for dimensions. Maximum Main Ampere Rating Maximum Number 3/4-Inch (19.1 mm) Single Poles TABLE 2-85. SINGLE-PHASE CONVERTIBLE LOADCENTERS WITH FACTORY INSTALLED SURGE SUPPRESSION — INDOOR SINGLE-PHASE 3-WIRE — 120/240 VAC — TWIN NEUTRAL — FACTORY INSTALLED GROUND BAR 225 32 42 Loadcenter Loadcenter Cover Combination Surface Box Wire Size Range Size Catalog Number UPC Code Catalog Number UPC Code Catalog Number UPC Code K L CHSUR32N225K CHSUR42N225L 782116200115 782116320004 CHSUR8KF CHSUR8LF 782116200238 782116200245 CHSUR8KS CHSUR8LS 782116200276 782116200283 #2 – 300 kcmil Combination style covers may be used for surface or flush mount applications. See Page 2-18 for dimensions. TABLE 2-86. SINGLE-PHASE MAIN CIRCUIT BREAKER LOADCENTERS WITH FIELD INSTALLATION PROVISION FOR SURGE SUPPRESSION — INDOOR SINGLE-PHASE 3-WIRE — 120/240 VAC — FACTORY BONDED SPLIT NEUTRAL Maximum Number 3/4-Inch (19.1 mm) Single Poles CSH 35 kAIC Loadcenter Cover Box Wire Size Range Size 100 24 32 E K #6 – 4/0 150 200 200 32 32 42 K K L #2 – 300 kcmil CHEC32B150K 782116200160 CHSUR8KF 782116200238 CHSUR8KS 782116200276 CHEC32B200K 782116200252 CHSUR8KF 782116200238 CHSUR8KS 782116200276 CHEC42B200L 782116200184 CHSUR8LF 782116200245 CHSUR8LS 782116200283 Maximum Main Ampere Rating Main Breaker Type Loadcenter Combination Surface Catalog Number Catalog Number Catalog Number CHEC24B100E 782116200139 CHSUR8EF 782116200221 CHSUR8ES 782116200269 CHEC32B100K 782116200153 CHSUR8KF 782116200238 CHSUR8KS 782116200276 UPC Code UPC Code UPC Code Combination style covers may be used for surface or flush mount applications. See Page 2-18 for dimensions. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — ©Copyright 2005 2-45 Data Tables Maximum Number 3/4-Inch (19.1 mm) Single Poles Loadcenter Loadcenter Cover Combination Surface Box Wire Size Range Size Catalog Number UPC Code Catalog Number UPC Code Catalog Number UPC Code 125 24 E #6 – 2/0 CHEC24L125E 782116200146 CHSUR8EF 782116200221 CHSUR8ES 782116200269 225 32 42 K L #2 – 300 kcmil CHEC32L225K CHEC42L225L 782116200177 782116200191 CHSUR8KF CHSUR8LF 782116200238 782116200245 CHSUR8KS CHSUR8LS 782116200276 782116200283 Combination style covers may be used for surface or flush mount applications. See Page 2-18 for dimensions. 225 Maximum Number 3/4-Inch (19.1 mm) Single Poles TABLE 2-88. SINGLE-PHASE CONVERTIBLE LOADCENTERS WITH FIELD INSTALLATION PROVISION FOR SURGE SUPPRESSION — INDOOR SINGLE-PHASE 3-WIRE — 120/240 VAC — TWIN NEUTRAL — FACTORY INSTALLED GROUND BAR Maximum Main Ampere Rating Loadcenters Maximum Main Ampere Rating TABLE 2-87. SINGLE-PHASE MAIN LUG LOADCENTERS WITH FIELD INSTALLATION PROVISION FOR SURGE SUPPRESSION — INDOOR SINGLE-PHASE 3-WIRE — 120/240 VAC — TWIN NEUTRAL — FACTORY INSTALLED GROUND BAR 32 42 Loadcenter Loadcenter Cover Combination Surface Box Wire Size Range Size Catalog Number UPC Code Catalog Number UPC Code Catalog Number UPC Code K L CHEC32N225K CHEC42N225L 782116200207 782116200214 CHSUR8KF CHSUR8LF 782116200238 782116200245 CHSUR8KS CHSUR8LS 782116200276 782116200283 #2 – 300 kcmil Combination style covers may be used for surface or flush mount applications. See Page 2-18 for dimensions. Cutler-Hammer is a federally registered trademark of Eaton Corporation. National Electrical Code and NEC are registered trademarks of the National Fire Protection Association, Quincy, Mass. NEMA is the registered trademark and service mark of the National Electrical Manufacturers Association. 2-46 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Loadcenters — Effective August 2005 3-3 3-3 3-5 3-5 3-6 3-9 3-10 Residential Meter Breakers and Non-EUSERC Panel Product Description A meter breaker combines two products into one: a single meter socket and a loadcenter, a.k.a. the circuit breaker box. Sometimes these units are called all-in-ones or combo units. Certain utilities will specify a meter breaker instead of a meter socket and loadcenter. The meter breaker is used where electricity enters a home or dwelling. The utility attaches a meter in the socket to measure power consumption. The loadcenter portion is used to distribute the power throughout the home using various circuits. Meter Breakers CH and BR Meter Mains — Non-EUSERC . . . . . CH and BR Meter Breaker — Non-EUSERC . . . . CH and BR Meter Breaker — EUSERC. . . . . . . . BR EUSERC - All-In-One – 7” Deep . . . . . . . . . . 300 and 400 Ampere House Panels . . . . . . . . . . Meter Breaker Accessories . . . . . . . . . . . . . . . . Meter Breaker Technical Data and Dimensions . . . Features, Functions and Benefits ✓ Variety of designs to meet local utility ✓ ✓ ✓ ✓ ✓ ✓ ✓ specifications. Meets NEC姞 wire bending space requirements. Commercial grade main breaker. Overhead or underground service. Raised interior with built-in wireway for easier installation. 100 – 225 amperes. Warranty: – CH style — 20-year warranty – BR style — 10-year warranty UL姞 listed. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-1 Catalog Numbering System TABLE 3-1. CATALOG NUMBERING SYSTEM (APPLIES TO NEW DESIGNS ONLY) MBE 20 40 B 200 B S Meter Breaker Type MB = MBE = CMB = CMBE = MBEO = 1-Inch (25.4 mm) BR Type 1-Inch (25.4 mm) BR Type — EUSERC 3/4-Inch (19.1 mm) CH Type 3/4-Inch (19.1 mm) CH Type — EUSERC 1-Inch (25.4 mm) BR Type 7-Inch (177.8) Deep Enclosure Spacing Accessories/Modifications Number of Spaces D = 5th Jaw and Horn Bypass CU = Copper C = Single Cover Compact Design CR = 2 Cover Compact Design Poles Maximum Number of Poles Mounting Main Meter Breakers B = Main Breaker Included P = Provision for Main L = Main Lug Amperes Amperage of Unit Breaker Feed BT = Bottom and Top B = Bottom Only T = Top Only TABLE 3-2. CATALOG NUMBERING SYSTEM (APPLIES TO NEW DESIGNS ONLY) MB 20 40 B 200 BT S Meter Breaker Type MB = MBE = CMB = CMBE = MBT = 1-Inch (25.4 mm) BR Type 1-Inch (25.4 mm) BR Type — EUSERC 3/4-Inch (19.1 mm) CH Type 3/4-Inch (19.1 mm) CH Type — EUSERC 1-Inch (25.4 mm) BR Type Mobile Home Panel Spacing Accessories/Modifications Number of Spaces D = 5th Jaw and Horn Bypass CU = Copper C = Single Cover Compact Design CR = 2 Cover Compact Design Poles Maximum Number of Poles Mounting Main B = Main Breaker Included P = Provision for Main L = Main Lug Amperes Amperage of Unit 3-2 S = Surface F = Flush/Stucco S = Surface F = Flush/Stucco Breaker Feed BT = Bottom and Top B = Bottom Only T = Top Only EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 Product Selection TABLE 3-3. COMBINATION SERVICE ENTRANCE DEVICES — NON-EUSERC Ampere Rating Bypass Service kAIC Jaws Distribution Main Branch Breaker Type Catalog Number UPC Code 100 150 150 None None None OH OH/UG OH/UG 200 200 200 None None None OH/UG OH/UG OH/UG 10 10 22 22 4 4 4 None None None Provision CSR2150 CSR2150 None None None WMB102RN MBB150BTSCR CMBB150BTS 786676258272 782114860137 782113601809 4 4 4 None None None CSR2200 Provision CSR2200 None None None MBB200BTSCR CMBP200BTS CMBB200BTS 782114860144 782114987889 782114872505 Ringless Meter Mains (no distribution section included) 150 200 200 None None None OH/UG OH/UG OH/UG 10 10 10 4 4 4 None None None CSR2150 CSR2200 CSR2200 None None None MBB150BTSC MBB200BTS MBB200BTSC 782114860175 782114860199 782114860182 150 200 200 200 None None Horn Horn OH/UG OH/UG OH/UG OH/UG 10 4 4 5 5 None None None None CSR2125 Provision Provision Provision None None None None MBB150BTS MBP200BTS MBP200SD MBP200BTSD 782116073252 782114860151 782114668887 782114887707 100 150 200 Horn Horn Horn OH/UG OH/UG OH/UG 10 10 10 5 5 5 None None None Provision BWH2150 BWH2200 None None None CHMMB100BTS CHMMB150BTS CHMMB200BTS 782113682006 782113682013 782113682020 10 10 10 10 4 4 4 4 None None None None BR2100 BR2100 BR2100 BR2100 None None None None SMB12OG  SMB12OAL  SMB12UOG  SMB12UOAL  782114375846 782114375815 782114375853 782114375808 Meter Breakers Ring Style Meter Mains (no distribution section included) Puerto Rican Meter Breaker Units 100 100 100 100 None None None None OH OH OH/UG OH/UG Per installed main breaker rating. Provision for main is provided. WMB style devices accept Main Breaker style BR, 2-Pole. All panels are dual labeled to accept Types BW or CSR Main Breakers. MCBK225 lug kit is needed for load side cable connection for Meter Mains. Please order separately. When a provision for main is provided, order one of the main breakers listed in this table. All panels are dual labeled to accept Types BW, BWH and CSR Main Breakers. Panels are specifically designed for the Georgia Power Service Territory, but may be used in any service territory that has the same design requirements. Copper bus. One-piece cover on utility side, Florida approved. Single cover design.  Galvanized steel enclosure.  Aluminum enclosure. Wiring diagrams and dimensional information on Pages 3-10 – 3-26. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-3 Product Selection TABLE 3-3. COMBINATION SERVICE ENTRANCE DEVICES — NON-EUSERC (CONTINUED) Ampere Rating Bypass Service kAIC Jaws Distribution Main Branch Breaker Type Catalog Number UPC Code BR CH WMB1224SCN CMB24L125BTS 786676258456 782114872512 Ring Style All-in-Ones (includes distribution section) Meter Breakers 125 125 None None OH/UG OH/UG 4 4 2/4 None — Refer to Distribution 150 150 None None OH/UG UG 22 22 4 4 8 32/42 CSR2150 CSR2150 CH CH CMB88B150BTS CMB3242B150BS 782114872482 782114872536 200 200 200 None None None OH/UG OH/UG UG 10 22 22 4 4 4 4/8 8 32/42 BW2200 CSR2200 CSR2200 BR CH CH MB48B200BTS CMB88B200BTS CMB3242B200BS 782114872499 782114872475 782114872529 200 200 200 None None None OH/UG OH/UG OH/UG 22 10 22 — 4 4 42/42 4/8 8/8 — BW2200 CSR2200N CH BR CH CMB4242B200BTS MBER48B200BTS CMBER88B200BTS 782114872543 782116077373 782116077380 150 150 None None OH/UG OH/UG 10 22 4 4 4/8 8/8 BW2150 CSR2150N BR CH MBER48B150BTS CMBER88B150BTS 782116197682 782116197699 Ringless All-in-Ones (includes distribution section) 200 200 200 None None None OH/UG OH/UG OH/UG 10 10 10 4 4 4 8/16 8/16 8/16 BW2200 BW2200 BW2200 BR BR BR MB816B200BTS MB816B200BTSV MB816B200BTSCU 782114858615 782116094851 782114858622 200 200 200 None None Horn OH/UG OH/UG OH/UG 4 4 5 8/16 8/16 8/16 Provision Provision Provision BR BR BR MB816P200BTS MB816P200BTSCU MB816P200STD 782114860076 782114860083 782114668894 200 200 200 Horn None None OH/UG OH/UG OH/UG 5 4 4 8/16 12/12 6 – 2 Pole Provision CSR2000 Main Lugs BR CH CH MB816P200BTSD CMB1212B200BTS CMB1212L200BTS 782114887714 782114858561 782114848753 200 200 200 None Horn None OH/UG OH/UG OH/UG 4 5 4 12/12 12/12 6 – 2 Pole Provision Provision Main Lugs CH CH BR CMB1212P200BTS CMB1212P200BTSD MB1212L200BTS 782114858554 782114858592 782114849019 200 200 200 None None None OH/UG OH/UG OH/UG 22 10 4 4 4 24/24 20/40 20/40 CSR2200 BW2200 Provision CH BR BR CMB2424B200BTS MB2040B200BTS MB2040P200BTS 782114987896 782114858639 782114860090 200 200 150 Horn Horn Horn OH/UG OH/UG OH/UG 10 10 5 5 5 20/40 20/40 20/40 Provision BW2200 BW2150 BR BR BR MB2040P200SD MB2040B200SD MB2040B150SD 782114668900 782116287727 782116199631 200 200 200 Lever Lever Lever OH/UG OH/UG OH/UG 10 10 10 5 5 5 None 12/12 32/42 CSR2200 CSR2200 CSR2200 None CH CH CMBXB200BTS CMBX1212B200BTS CMBX3242B200BTS 782116142347 782116142354 782116142361 200 200 200 Lever Lever Lever OH/UG OH/UG OH/UG 10 10 10 5 5 5 None 12/12 32/42 Provision Provision Provision None CH CH CMBXP200BTS CMBX1212P200BTS CMBX3242P200BTS 782116128884 782116128891 782116128907 200 200 None None OH/UG OH/UG 4 4 4/8 4/8 Provision BWH2200 BR BR MBT48P200BTS MBT48B200BTS 782116484324 782116157372 10 22 Per installed main breaker rating. Will accept maximum four 1-pole, two 2-pole, or two quad breakers. All panels are dual labeled to accept Types BW or CSR Main Breakers. Copper bus. One-piece cover on utility side, Florida approved. Units come with feed-through lugs. Value pack includes breakers 5-BR115 and 1-BR230. TABLE 3-4. MAIN BREAKER SELECTION CHART Maximum Ampere Rating 100 125 150 200 2-Pole Breaker Catalog Numbers 10 kAIC 22 kAIC 22 kAIC BW2100 BW2125 BW2150 BW2200 BWH2100 BWH2125 BWH2150 BWH2200 CSR2125N CSR2150N CSR2200N — Load Side Lug Kit for BW and CSR Breakers Wiring diagrams and dimensional information on Pages 3-10 – 3-26. 3-4 MCBK225 When a provision for main is provided, order one of the main breakers listed in this table. All panels are dual labeled to accept Types BW, BWH and CSR Main Breakers. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 Product Selection Distribution Main Branch Breaker Type Jaws Bypass Service kAIC Ampere Rating TABLE 3-5. COMBINATION SERVICE ENTRANCE DEVICES (EUSERC) Catalog Number Catalog Number Surface UPC Code Flush MBE24L125BTS CMBE24L125BTS 782114849156 MBE24L125BTF 782114848845 — 782114849149 — UPC Code 125 125 None None OH/UG OH/UG 4 4 2/4 2/4 MLO MLO BR CH 150 200 200 None None None OH/UG OH/UG OH/UG 22 10 22 4 4 4 None None None CSR2150N None CMBEB150BTS BW2200 None MBEB200BTS CSR2200N None CMBEB200BTS 782114849286 — 782114849279 MBEB200BTF 782114849002 — — 782114849262 — 200 200 None None OH/UG OH/UG 4 4 2/4 2/4 MLO MLO BR CH MBE24L200BTS CMBE24L200BTS 782114849170 MBE24L200BTF 782114848852 — 782114849163 — Ring Style All-in-Ones (includes distribution section) 100 100 100 None None None OH/UG UG OH 10 10 10 4 4 4 12/24 14/28 12/24 BR2100 BR2100 BR2100 BR BR BR MBE1224B100BTS MBE1428B100BS MBE1224B100TS 782114890790 MBE1224B100BTF 782114849064 MBE1428B100BF 782114872574 — 782114890806 782114849057 — 125 125 125 None None None OH/UG OH UG 10 10 10 4 4 4 12/24 12/24 18/36 BR2125 BR2125 BR2125 BR BR BR MBE1224B125BTS MBE1224B125TS — 782114890813 MBE1224B125BTF 782114872550 — — MBE1836B125BF 782114890820 — 782114849095 150 150 150 None None None OH/UG UG UG 22 22 10 4 4 4 8 32/42 20/40 CSR2150N CH CSR2150N CH BW2150 BR CMBE88B150BTS CMBE3242B150BS — 782114848968 CMBE88B150BTF 782114848951 782114848883 — — — MBE2040B150BF 782114865293 150 150 None None OH/UG OH/UG 22 10 4 4 20/40 4/8 BW2150 BW2150 MBE2040B150BTS MBE48B150BTS 782116015849 — 782114865262 — 200 200 200 None None None OH/UG OH/UG OH/UG 10 22 10 4 4 4 4/8 8 8 BW2200 BR CSR2200N CH BW2200 BR MBE48B200BTS CMBE88B200BTS MBE88B200BTS 782114849217 MBE48B200BTF 782114849200 782114848982 CMBE88B200BTF 782114848975 782114849255 — — 200 200 200 None None None OH UG OH/UG 4 4 4 8/16 Provision 6 – 2 Pole Main Lug 6 – 2 Pole Main Lug MBE816P200TS CMBE1212L200BS MBE1212L200BTS 782114849231 — 782114848777 MBE1212L200BTF 782113493749 — — 782113493756 — 200 200 200 None None None OH UG OH/UG 10 10 22 4 4 4 20/40 20/40 20/40 BW2200 BR BW2200 BR BWH2200 BR MBE2040B200TS MBE2040B200BS MBE2040BH200BTS 782114887684 MBE2040B200TF 782114849118 MBE2040B200BF 782116073924 — 782114887691 782114849101 — 200 200 200 None None None OH/UG UG UG 22 22 22 4 4 4 20/40 30/42 32/42 BWH2200 BR BW2200 BR CSR2200N CH MBE2040BH200BTF — CMBE3242B200BS 782116073931 — — MBE3042B200BF 782114848906 CMBE3242B200BF — 782113554686 782114848890 200 200 200 None None None UG OH/UG OH/UG 22 22 22 4 4 4 40 40 42 BWH2200 BR BWH2200 BR CSR2200N CH MBE4040B200BSH MBE4040B200BTS CMBE4242B200BTS 782114867068 — 782114849194 MBE4040B200BTF 782114869222 — — 782114881767 — 200 200 200 None None None OH/UG OH/UG OH/UG 10 10 10 4 4 4 20/40 20/40 4/8 BW2200 BW2200 BW2200 BR BR BR MBE2040B200BTS 782114883594 MBE2040B200BTF MBE2040B200BTSV 782116094844 — MBER48B200BTS 782116077373 — 782114883587 — — 200 225 225 225 None None None None OH/UG OH/UG UG UG 22 10 22 22 4 4 4 4 8/8 20/40 30/42 32/42 CSR2200N BW2225 BW2225 CSR2225N CH BR BR CH CMBER88B200BTS MBE2040B225BTS — CMBE3242B225BS — 782114883600 782113554891 782114848913 BR BR BR CH BR Interrupting rating is dependent on the main breaker that is installed. Unit has copper bus. Units come with feed-through lugs. All panels are dual labeled to accept Types BW or CSR Main Breakers. Please use RH-Type hubs on top end wall for overhead feed. Includes factory mounted 2.50 inch hub on bottom endwall. UG feed only. Semi-flush flange, not full stucco flange. Value pack includes breakers 2-BD115, 2-BR115 and 1-BR230. Ranch panel includes provision for second main up to 70 A wired in parallel. — — — MBE2040B225BTF MBE3042B225BF CMBE3242B225BF TABLE 3-6. MAIN BREAKER SELECTION CHART Maximum Ampere Rating 125 150 200 2-Pole Breaker Catalog Numbers 10 kAIC 22 kAIC 22 kAIC BW2125 BW2150 BW2200 BWH2125 BWH2150 BWH2200 CSR2125N CSR2150N CSR2200N Load Side Lug Kit for BW and CSR Breakers   Wiring diagrams and dimensional information on Pages 3-10 – 3-26. 782116077380 782114883617 — 782114848920 Meter Breakers Ring Style Meter Mains (no distribution section included) MCBK225 When a provision for main is provided, order one of the main breakers listed in this table. All panels are dual labeled to accept Types BW, BWH and CSR Main Breakers. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-5 House Panels Product Description Meter Breakers A recently redesigned Cutler-Hammer姞 House Panel by Eaton Corporation offers a faster, easier and safer installation. These 400 ampere units are ideal for larger homes in North America that require meter breakers. Coming in both CH and BR styles, these service entrance devices consist of a meter socket and a distribution section. In response to contractor feedback, these panels have been redesigned with a focus on flexibility, simplified wiring, and an overall ease of installation. All units come standard with a 22 kAIC main breaker. Previously, the panels were designed as bottomexit only. Now the load conductors can exit the top, bottom, side or back for greater application and installation flexibility. Additionally, Cutler-Hammer House Panels can be used for apartments, condominiums, clubhouses or common areas. Features, Benefits and Functions House Panel ✓ ✓ ✓ ✓ ✓ Ring style units meet EUSERC requirements. NEMA 3R rainproof. Rated for service entrance equipment. UL listed. Lever bypass socket available on certain catalog numbers. ✓ Pin type door hinges. ✓ Socket to distribution section is connected via insulated cable for safety. ✓ Second main space can accept 100 to 200 amperes BW, BWH or CSR breakers, or accept a plug-on kit for breakers less than 100 amperes. NEW ACCESSORIES House Panel Interior ✓ Top-feed gutter kit to ease top-fed installation. ✓ Re-engineered, adjustable flush mount kit for a cleaner installation. ✓ 100 ampere second main breaker kit. ✓ New 750 kcmil box type lug kit. 3-6 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 West Coast All-in-One Design FEATURES, BENEFITS AND FUNCTIONS ✓ ✓ ✓ ✓ ✓ ✓ ✓ stucco homes. Endwall knockouts are easily accessible for future wiring without damaging stucco. Prevent water and moisture penetration by gasketing and chanting of hood. Knockout in back of case for mounting car-charging receptacle in garage (meets future electric car requirements). Outboard split neutral for easy wiring. Raised interior with built-in wireway for easier wiring. Commercial grade main breaker. Value-added kits available: – Surge kit — for adding integral surge to the panel – Receptacle kit — add 20 A duplex GFI – 30 ampere TT-30 receptacle – 50 ampere 14-50R receptacle – Hub adapter plate Meter Breakers ✓ Semi-flush mounting. 7-inch design ideal for MBED3042B200BF PRODUCT SELECTION Dimensions in Inches (mm) Catalog Number Height Width Depth Flush 38.00 (965.2) 38.00 (965.2) 38.00 (965.2) 14.19 (360.4) 7.00 (177.8) MBED1836B100BF 14.19 (360.4) 7.00 (177.8) MBED1836B125BF 14.19 (360.4) 7.00 (177.8) MBED2040B200BF 38.00 (965.2) 42.50 (1079.5) 42.50 (1079.5) 42.50 (1079.5) 14.19 (360.4) 14.19 (360.4) 14.19 (360.4) 14.19 (360.4) Factory Installed Kits Main Branch Breaker Type Distribution Jaws kAIC Service Bypass Ampere Rating TABLE 3-7. 7-INCH DEEP METER BREAKER UPC Code — — — 782116149735 782116149742 782116137374 — — — — 782116137381 782116149711 782116347834 782116149728 Standard Design 100 125 200 None UG 10 4 None UG 10 4 None UG 10 4 18/36 BW2100 BR 18/36 BW2125 BR 20/40 BW2200 BR 225 200 200 225 None None None None 20/40 30/42 20/40 30/42 UG UG UG UG 10 10 10 10 4 4 4 4 BW2225 BW2200 BW2200 BW2225 BR BR BR BR 7.00 (177.8) 7.00 (177.8) 7.00 (177.8) 7.00 (177.8) MBED2040B225BF MBED3042B200BF MBED2040B200BFN MBED3042B225BF Main Breaker Bus connected to 20/40 distribution. Main and Disconnect in same compartment. ACCESSORIES TABLE 3-8. ACCESSORIES Description Catalog Number UPC Code Field-Mounted Surge Kit Hub Adapter Plate MBEDSURGE MBEDADPT 782116151141 782116167937 Field-Mounted 20 A GFI Receptacle Kit for 125 Ampere All-in-One Field-Mounted 30 A TT-30 Receptacle Kit for 125 Ampere All-in-One Field-Mounted 50 A 14-50R Receptacle Kit for 125 Ampere All-in-One MBED125RCK20GFI MBED125RCK30A MBED125RCK50A 782116151189 782116151196 782116151202 Field-Mounted 20 A GFI Receptacle Kit for 200 Ampere All-in-One Field-Mounted 30 A TT-30 Receptacle Kit for 200 Ampere All-in-One Field-Mounted 50 A 14-50R Receptacle Kit for 200 Ampere All-in-One MBED200RCK20GFI MBED200RCK30A MBED200RCK50A 782116151158 782116151165 782116151172 Wiring diagrams and dimensional information on Pages 3-10 – 3-26. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-7 Data Tables 400 Ring 400 Ring CSR2200N CSR CSR2200N CSR Manual BWH2200 BW/BWH Manual BWH2200 BW/BWH Meter Breakers Line Side Main Lugs and Neutral UPC Code Surface Catalog Number UPC Code — — — — CG403242SH CG1212P400BS 782114231814 782114895085 UG 22 None UG 22 40/40 — — — — HP40SHA HP404040SHA 782116060108 782113533766 — — — — HP402440B HP402440SBH 786676883122 786676092005 — — — HP404040SHF — — — — 782116341269 — HP40 HP40SH HP402442 HP404040SH HP816P400BS 786676883306 782114212882 786676000567 782114868713 782114895078 — — — — — — — — — — CG1212P400BSL CG4042SHL HP40SHL HP404040SHL HP816P400BSL 782116110414 782114105825 782114105856 782114105863 782116080250 UG 22 32/42 UG 22 12/12 kAIC Semi-Flush Catalog Number Dist. 400 Ringless None 400 Ringless None DK2400 None BWH2200 BW/BWH UG 22 24/40 UG 22 24/40 400 400 400 400 400 Ring Ring Ring Ring Ring None None None None None DK2400 BWH2200 DK2400 BWH2200 BWH2200 None BW/BWH None BW/BWH BW/BWH UG UG UG UG UG 22 22 22 22 22 None None 24/42 40/40 8/16 400 400 400 400 400 Ringless Ringless Ringless Ringless Ringless Lever Lever Lever Lever Lever CSR2200N CSR2200N BWH2200 BWH2200 BWH2200 CSR CSR BW/BWH BW/BWH BW/BWH UG UG UG UG UG 22 22 22 22 22 12/12 42/42 None 40/40 8/16 Lug landings for compression lugs 400 Ringless None 400 Ring None Service Type Security Bypass Main Breaker Optional Secondary Main Breaker (Not Included) Ampere Rating TABLE 3-9. 400 AMPERE HOUSE PANELS Confirm security type for individual EUSERC utility requirements. Included in all of the following devices. If unit needs to be semi-flush, order accessory item catalog number HPPR to convert all surface mounting devices to semi-flush mounting. Secondary sub-main installed in panel. Feed-through lugs included. Includes manual bypass and additional ground lug to meet Nevada Power requirements. Bolt-on meter socket. TABLE 3-10. HOUSE PANEL ACCESSORIES Description Catalog Number UPC Code Top Feed Kit 750 kcmil Lug Kit Manual Bypass Kit Flush Mount Kit HP40TFKIT HPBLK750 HPBPK HPPR 782113959412 782113683317 782114413241 782114231821 100 Ampere 2nd Main Kit (Type BR Branch) HP2NDMNKIT 782116049356 100 Ampere 2nd Main Kit (Type CH Branch) CH2NDMNKIT 782116049363 HPBLK750 HP2NDMNKIT HPBPK HP40TFKIT Wiring diagrams and dimensional information on Pages 3-10 – 3-26. 3-8 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 Accessories TABLE 3-11. METER BREAKER PARTS Description Catalog Number UPC Code 5th Jaw Kits Compact and Standard Styles MB5JAWKIT (MB & CMB) WMB Style WMB5J 782116347803 786676258173 Manual Bypass Kits Ring Style Units Only (MB) 1MMBPM200 782114380314 Ringless Style Units Only (MB & MBHBPKIT CMB) 782116347797 TABLE 3-12. DS HUB SELECTION CHART Hub Size Dimensions in Inches (mm) Catalog Number UPC Code 1.00 (25.4) 1.25 (31.8) 1.50 (38.1) DS100H2 DS125H2 DS150H2 782114987858 782114987865 782114987872 2.00 (50.8) 2.00 (50.8) 2.50 (63.5) 3.00 (76.2) DS200H2 DS200H2CS DS250H2 DS300H2 782113109961 782114793312 782113109978 782113342276 0.75 (19.1) 1.00 (25.4) 1.25 (31.8) RH75P RH100P RH125P 786676213257 786676213356 786676213455 1.50 (38.1) 2.00 (50.8) RH150P RH200P 786676213554 786676213653 Type DS Meter Breakers Horn Bypass Kits Type RH Clamshell packaged hub. RH Type hubs to be used with the MBE2040 units only. Wiring diagrams and dimensional information on Pages 3-10 – 3-26. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-9 Typical Wiring Diagrams (Residential Meter Breakers) Bonded Neutral 1 2 3 4 5 6 7 8 9 10 11 12 13 14 23 24 25 26 27 28 29 30 31 32 15 35 16 36 17 37 18 38 19 39 20 40 2 4 6 8 10 1 3 5 7 9 11 13 15 17 19 14 16 18 20 22 33 34 41 22 42 Wiring Diagram Key #14-4 AWG #6-2/0 AWG B A Line N A N B Line Wiring Diagram Key #14-2 AWG #14-4 AWG #6-2/0 AWG #6-250 AWG FIGURE 3-1. CATALOG NUMBERS — CMB3242B200BS, CMBE3242B150BS, CMBE3242B200BS, CMBE3242B200BF, CMBE3242B225BS, CMBE3242B225BF AND CMB3242B150BS FIGURE 3-2. CATALOG NUMBERS — Bonded Neutral Service Disconnect Type CSR #6-250 AWG 1 3 2 4 7 8 11 12 B A N Bonded Neutral Meter Breakers 21 Bonded Neutral Line Wiring Diagram Key #14-4 AWG #6-1/0 AWG #6-250 AWG FIGURE 3-3. CATALOG NUMBER — CMBE1212L200BS 3-10 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 TYPICAL WIRING DIAGRAMS (RESIDENTIAL METER BREAKERS) Install 200 Ampere Maximum Service Disconnect Type CSR ➀ A B A B 1 A Line N B Line N A Line N 34 Bonded Neutral B Bonded Neutral Wiring Diagram Key #14-1/0 AWG #14-6 AWG #14-1/0 AWG #6-250 AWG #14-2/0 AWG #14-2 AWG #6-250 AWG FIGURE 3-4. CATALOG NUMBERS — CMBP200BTS, CMBB150BTS, CMBB200BTS, CMBEB150BTS AND CMBEB200BTS Factory installed MCBK225 Kit for C/B load lugs. FIGURE 3-6. CATALOG NUMBERS — CMBE24L125BTS AND CMB24L125BTS Service Disconnect Type CSR 200 Ampere Maximum Line N FIGURE 3-8. CATALOG NUMBER — CMBE24L200BTS 1 2 3 4 5 6 7 8 Wiring Diagram Key #14-1/0 AWG #14-6 AWG #6-2/0 AWG #6-250 AWG #4-300 AWG FIGURE 3-5. CATALOG NUMBERS — CMBE88B200BTS, CMBE88B200BTF, CMB88B200BTS, CMB88B150BTS, CMBE88B150BTS AND CMBE88B150BTF A Bonded Neutral B 2 4 6 1 3 5 9 11 13 15 17 19 Main Bonded Neutral B Wiring Diagram Key #14-6 AWG #14-1/0 AWG #6-250 AWG 1 2 3 4 B A 1 Bonded Neutral B Wiring Diagram Key A 34 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 Wiring Diagram Key #14-6 AWG #14-1/0 AWG #14-2/0 AWG #6-250 AWG FIGURE 3-7. CATALOG NUMBERS — MBE1224B100BTS, MBE1224B100BTF, MBE1224B125BTS AND MBE1224B125BTF Meter Breakers A B A 31 33 32 34 37 39 38 40 Disconnect Type BW, BWH or CSR A B Line N Wiring Diagram Key #14-4 AWG #6-2/0 AWG #6-250 AWG FIGURE 3-9. CATALOG NUMBERS — MBE2040B150BF, MBE2040B200BS AND MBE2040B200BF EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-11 23 25 27 29 31 2 6 8 10 12 35 36 1 2 3 5 4 6 7 8 9 11 10 12 13 14 16 15 17 19 21 23 25 27 29 31 33 35 37 39 41 18 20 22 24 26 28 30 32 34 36 38 40 42 Bonded Neutral 9 11 13 15 17 19 1 3 5 7 9 11 Bonded Neutral 1 3 5 Bonded Neutral Bonded Neutral TYPICAL WIRING DIAGRAMS (RESIDENTIAL METER BREAKERS) Service Disconnect B Line N #6-250 AWG FIGURE 3-10. CATALOG NUMBER — MBE1836B125BF 9 11 13 15 17 19 21 23 FIGURE 3-12. CATALOG NUMBERS — B N Line Wiring Diagram Key B #14-4 AWG #6-2/0 AWG N #6-250 AWG FIGURE 3-11. CATALOG NUMBERS — MBE1428B100BS AND MBE1428B100BF 3-12 Bonded Neutral Wiring Diagram Key #14-6 AWG #14-1/0 AWG #6-250 AWG N A 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 FIGURE 3-13. CATALOG NUMBERS — MBE2040B200BTS, MBE2040B150BTS, MBE2040BH200BTS AND MBE2040B200BTF LINE B Wiring Diagram Key #14-4 AWG #6-2/0 AWG #6-250 AWG FIGURE 3-14. CATALOG NUMBER — MBE3042B200BF 200 A Max. Service Disconnect B A A A Wiring Diagram Key #14-6 AWG #6-1/0 AWG #6-250 AWG 1 2 3 5 4 6 7 8 9 11 13 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 15 17 19 21 23 25 27 29 31 33 35 37 39 41 Bonded Neutral Bonded Neutral 1 3 5 Line N Bonded Neutral A Bonded Neutral Meter Breakers B A Wiring Diagram Key #14-4 AWG #6-2/0 AWG Service Disconnect Type BW, BWH or CSR Service Disconnect Type BW, BWH or CSR N A LINE B Wiring Diagram Key #14-4 AWG #6-2/0 AWG #6-250 AWG FIGURE 3-15. CATALOG NUMBER — MBE3042B225BF EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 TYPICAL WIRING DIAGRAMS (RESIDENTIAL METER BREAKERS) A B 200 Ampere Maximum Service Disconnect Type BW, BWH or CSR 200 Ampere Maximum Service Disconnect Type BW, BWH or CSR A B A B 1 2 34 56 Line N B Neutral MCBK225 Kit for C/B Load Lugs A Line N B Wiring Diagram Key #14-1/0 AWG #14-6 AWG #14-2/0 AWG #6-250 AWG FIGURE 3-16. CATALOG NUMBERS — MBE24L125BTS AND MBE24L125BTF A L1 L2 Bonded Neutral A Line N Wiring Diagram Key #14-1/0 AWG #14-6 AWG #6-2/0 AWG #6-250 AWG FIGURE 3-18. CATALOG NUMBERS — MBE48B150BTS, MBE48B200BTS, MBE48B200BTF AND MB48B200BTS A Bonded Neutral Wiring Diagram Key #14-2/0 AWG #6-2/0 AWG #6-250 AWG FIGURE 3-20. CATALOG NUMBERS — MBEB200BTS AND MBEB200BTF 200 Ampere Maximum Service Disconnect Type BW, BWH or CSR B B Meter Breakers A B 1 2 34 56 A Line N B Neutral A Wiring Diagram Key #14-1/0 AWG #14-6 AWG #14-2/0 AWG #6-250 AWG FIGURE 3-17. CATALOG NUMBERS — MBE24L200BTS AND MBE24L200BTF Line N B 6 7 8 Wiring Diagram Key #14-1/0 AWG #14-6 AWG #6-2/0 AWG #6-250 AWG FIGURE 3-19. CATALOG NUMBER — MBE88B200BTS EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-13 TYPICAL WIRING DIAGRAMS (RESIDENTIAL METER BREAKERS) A B A B A N B Bonded Neutral Line N Bonded Neutral N 200 Ampere Maximum Service Disconnect Type BW, Bonded Neutral 1 2 3 4 1 2 5 6 3 4 7 8 5 6 9 10 7 8 11 12 9 10 11 12 Meter Breakers Wiring Diagram Key #14-4 AWG #6-350 kcmil #6-2/0 AWG #6-300 kcmil #6-300 kcmil FIGURE 3-21. CATALOG NUMBERS — MBE816P200TS AND MBE816P200TSCU A Wiring Diagram Key #14-4 AWG #6-350 kcmil #6-2/0 AWG #6-300 kcmil FIGURE 3-23. CATALOG NUMBER — MBE1212L200BTS Wiring Diagram Key #14-4 AWG #6-350 kcmil #6-2/0 AWG #6-300 kcmil FIGURE 3-25. CATALOG NUMBER — B A B Line N Bonded Neutral Bonded Neutral 1 2 1 3 2 4 200 Ampere Maximum Service Disconnect Type BW, A LINE N B 4 5 8 #14-4 AWG #6-350 kcmil #6-2/0 AWG FIGURE 3-22. CATALOG NUMBERS — MBE2040B200TS AND MBE2040B200TF 3-14 Wiring Diagram Key #14-4 AWG #6-350 kcmil #6-2/0 AWG FIGURE 3-24. CATALOG NUMBER — MBE1212L200BTS EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 TYPICAL WIRING DIAGRAMS (RESIDENTIAL METER BREAKERS) Bonded Neutral 5TH Jaw Factory Installed on CMB1212B200BTSD and CMB1212P200BTSD Only A B Bonded Neutral A B 5th Jaw Factory Installed on CMB1212L200BTSD Only N A Line N B N Bonded Neutral 200 Ampere Maximum Service Disconnect Type CSR 1 2 3 4 5 6 7 8 9 10 11 12 2 3 4 5 6 7 8 9 10 11 12 Wiring Diagram Key #14-4 AWG #6-350 kcmil #6-2/0 AWG #4-300 kcmil #6-300 kcmil FIGURE 3-26. CATALOG NUMBERS — CMB1212P200BTSD AND CMB1212P200BTS Wiring Diagram Key FIGURE 3-28. CATALOG NUMBER — MB1212L200BTS A 2 3 4 5 6 7 8 9 10 11 12 Wiring Diagram Key #14-4 AWG #6-350 kcmil #6-2/0 AWG #6-300 kcmil FIGURE 3-30. CATALOG NUMBER — CMB1212L200BTS Line N B Bonded Neutral Line N B 1 #14-2/0 AWG #6-350 kcmil #6-300 kcmil 5th Jaw Factory Installed on CMB1212B200BTSD and CMB1212P200BTSD Only A 1 Meter Breakers Ground Bar Bonded Neutral 200 Ampere Maximum Service Disconnect Type CSR 1 2 3 4 5 6 7 8 9 10 11 12 Wiring Diagram Key #14-4 AWG #6-350 kcmil #6-2/0 AWG #4-300 kcmil #6-300 kcmil FIGURE 3-27. CATALOG NUMBER — CMB1212B200BTS 200 Ampere Maximum Service Disconnect Type CSR 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 Wiring Diagram Key #14-4 AWG #6-350 kcmil #6-2/0 AWG #4-300 kcmil FIGURE 3-29. CATALOG NUMBER — CMB2424B200BTS EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-15 TYPICAL WIRING DIAGRAMS (RESIDENTIAL METER BREAKERS) Factory Installed Service Disconnect Type BW Factory Installed Service Disconnect Type CSR A Meter Breakers A B B Bonded Neutral N Wiring Diagram Key #14-6 AWG #14-1/0 AWG #6 AWG-250 kcmil 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 FIGURE 3-31. CATALOG NUMBER — CMBE4242B200BTS 3-16 A B A B Bonded Neutral N Wiring Diagram Key #14-6 AWG #14-1/0 AWG #6 AWG-250 kcmil 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 FIGURE 3-32. CATALOG NUMBERS — MBE4040B200BTS AND MBE4040B200BSH EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 TYPICAL WIRING DIAGRAMS (NON-EUSERC METER BREAKER DESIGN) A B B A B Line N Included in MBB150BTSCR 2 4 Wiring Diagram Key #14-4 AWG #6-350 kcmil #6-2/0 AWG #6-300 kcmil #6-300 kcmil Wiring Diagram Key #6-2/0 AWG #6-350 kcmil #6-250 kcmil #1-300 kcmil A Disconnect 16 15 FIGURE 3-33. CATALOG NUMBERS — MBB150BTSC, MBB150BTSCR, MBB200BTSCR AND MBB200BTSC FIGURE 3-35. CATALOG NUMBERS — MB816P200STD, MB816B200BTS, MB816B200BTSCU, MB816P200BTS, MB816P200BTSCU AND MB816P200BTSD B A 1 3 5 7 9 11 13 15 17 19 21 23 2 4 6 8 10 12 14 16 18 20 22 24 Equipment Ground Wiring Diagram Key #14-4 AWG #14-1/0 AWG #6-350 kcmil FIGURE 3-37. CATALOG NUMBERS — MBE1224B125TS AND MBE1224B100TS B Line N Line N Bonded Neutral Bonded Neutral 200 Ampere Maximum Service Disconnect Type BW, BWH or CSR ➀ 125 Ampere Maximum Service Disconnect Type BR, or BRH 200 Ampere Maximum 1 3 Bonded Neutral Bonded Neutral Bonded Neutral 200 Ampere Maximum Service Disconnect Type CSR Line N Line N Meter Breakers A 1 3 2 4 200 Ampere Maximum Service Disconnect Type BW, BWH or CSR 8 10 12 14 16 18 20 22 Wiring Diagram Key #6-2/0 AWG #6-350 kcmil #1-300 kcmil #6-300 kcmil FIGURE 3-34. CATALOG NUMBERS — MBB150BTS, MBP200SD, MBB200BTS, MBP200BTS AND MBP200BTSD Use MCBK225 for C/B Load Lugs. 26 28 30 32 34 36 38 40 Wiring #14-4 AWG #6-350 kcmil #6-2/0 AWG FIGURE 3-36. CATALOG NUMBERS — MB2040P200SD, MB2040B200BTS, MB2040P200BTS, MB2040B150SD AND MB2040B200SD EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-17 DIMENSIONS AND KNOCKOUTS (RESIDENTIAL METER BREAKERS) — DIMENSIONS IN INCHES (MM) Keyhole Knockouts on Sides for Stucco Units Only. 3.50 (88.9) 5.31 (134.9) Top Surface Top Stucco Meter Breakers 4.94 (125.4) 4.94 (125.4) Bottom Bottom FIGURE 3-38. KNOCKOUTS FOR STUCCO AND SURFACE UNITS CATALOG NUMBERS — CMBE3242B200BF, CMBE3242B225BF, MBE2040B200BF, MBE2040B150BF, MBE1428B100BF, MBE1212L200BTF, MBE1836B125BF AND MBE1212L200BTS TABLE 3-13. TOP ENDWALL (SURFACE) FIGURE 3-39. KNOCKOUTS FOR STUCCO AND SURFACE UNITS CATALOG NUMBERS — CMBE3242B150BS, CMBE3242B200BS, CMBE3242B225BS, CMBE1212L200BS, MBE2040B200BS, MBE1428B100BS, MBE1212L200BTS, CMB3242B150BS AND CMB3242B200BS TABLE 3-15. BOTTOM ENDWALL Hub Provision Catalog Number UPC Code DS100H2 DS125H2 DS150H2 782114987858 782114987865 782114987872 DS200H2 DS250H2 DS300H2 DS900AP (Adapter Plate if using DS___H1 hubs only) 782113109961 782113109978 782113342276 782113099422 Knockout Size Dimensions in Inches (mm) Quantity .50 (12.7) .50, .75 (12.7, 19.1) .50, .75, 1.00 (12.7, 19.1, 25.4) 7 4 1 1.00, 1.25, 1.50, 2.00 (25.4, 31.8, 38.1, 50.8) 1.25, 1.50, 2.00, 2.50, 3.00 (31.8, 38.1, 50.8, 63.5, 76.2) 1 1 Use when DS H1 Type 1, 1.25 and 1.50-inch hubs are needed. TABLE 3-14. TOP ENDWALL (STUCCO) 3-18 Knockout Size Dimensions in Inches (mm) Quantity 1.25, 1.50, 2.00, 2.50 (31.8, 38.1, 50.8, 63.5) 1.00, 1.25, 1.50 (25.4, 31.8, 38.1) .50, .75, 1.00 (12.7, 19.1, 25.4) 1 1 1 .50, .75 (12.7, 19.1) .50 (12.7) 5 7 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 DIMENSIONS AND KNOCKOUTS (RESIDENTIAL METER BREAKERS) — DIMENSIONS IN INCHES (MM) Keyhole Knockouts on Sides for Stucco Units Only. 3.50 (88.9) 5.31 (134.9) Top Stucco 4.94 (125.4) 4.94 (125.4) Bottom Bottom FIGURE 3-40. KNOCKOUTS FOR STUCCO AND SURFACE UNITS CATALOG NUMBERS — CMBE88B150BTF, CMBE88B200BTF, MBE24L125BTF, MBE24L200BTF, MBE48B200BTF, MBEB200BTF, MBE1224B100BTF AND MBE1224B125BTF TABLE 3-16. TOP ENDWALL (SURFACE) Hub Provision Catalog Number UPC Code DS100H2 DS125H2 DS150H2 782114987858 782114987865 782114987872 DS200H2 DS250H2 DS300H2 DS900AP 782113109961 782113109978 782113342276 782113099422 (Adapter Plate) Use when DS H1 Type 1, 1.25 and 1.50-inch hubs are needed. FIGURE 3-41. KNOCKOUTS FOR STUCCO AND SURFACE UNITS CATALOG NUMBERS — CMBB150BTS, CMBB200BTS, CMBP200BTS, CMBE24L125BTS, CMB24L125BTS, CMBE24L200BTS, CMBEB200BTS, CMBEB150BTS, CMBE88B150BTS, CMBP200BTS, CMBE88B200BTS, MBE24L125BTS, MBE24L200BTS, MBE48B150BTS, MBE48B200BTS, MBE88B200BTS, MBEB200BTS, MBE1224B100BTS, MBE1224B125BTS, CMB88B150BTS, CMB88B200BTS AND MB48B200BTS Meter Breakers Top Surface TABLE 3-18. BOTTOM ENDWALL Knockout Size Dimensions in Inches (mm) Quantity .50 (12.7) .50, .75 (12.7, 19.1) .50, .75, 1.00 (12.7, 19.1, 25.4) 7 4 1 1.00, 1.25, 1.50, 2.00 (25.4, 31.8, 38.1, 50.8) 1.25, 1.50, 2.00, 2.50, 3.00 (31.8, 38.1, 50.8, 63.5, 76.2) 1 1 TABLE 3-17. TOP ENDWALL (STUCCO) Knockout Size Dimensions in Inches (mm) Quantity 1.25, 1.50, 2.00, 2.50 (31.8, 38.1, 50.8, 63.5) 1.00, 1.25, 1.50 (25.4, 31.8, 38.1) .50, .75, 1.00 (12.7, 19.1, 25.4) 1 1 1 .50, .75 (12.7, 19.1) .50 (12.7) 3 3 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-19 DIMENSIONS AND KNOCKOUTS (RESIDENTIAL METER BREAKERS) — DIMENSIONS IN INCHES (MM) Keyhole Knockouts on Sides for Stucco Units Only. 3.50 (88.9) 5.31 (134.9) Top Surface Top Stucco Meter Breakers 4.94 (125.4) 4.94 (125.4) Bottom Bottom FIGURE 3-42. KNOCKOUTS FOR STUCCO AND SURFACE UNITS CATALOG NUMBER — MBE2040B200TF TABLE 3-19. TOP ENDWALL (SURFACE) Hub Provision Catalog Number UPC Code DS100H2 DS125H2 DS150H2 782114987858 782114987865 782114987872 DS200H2 DS250H2 DS300H2 DS900AP (Adapter Plate) 782113109961 782113109978 782113342276 782113099422 FIGURE 3-43. KNOCKOUTS FOR STUCCO AND SURFACE UNITS CATALOG NUMBERS — MBE1224B100TS, MBE1224B125TS, MBE816P200TS, MBE816P200TSCU, MBE2040B200TS, CMB1212P200BTS, CMB1212P200BTSD, CMB1212B200BTS, MB1212L200BTS AND CMB1212L200BTS TABLE 3-21. BOTTOM ENDWALL Knockout Size Dimensions in Inches (mm) Quantity .50 (12.7) .50, .75 (12.7, 19.1) .50, .75, 1.00 (12.7, 19.1, 25.4) 7 4 1 1.00, 1.25, 1.50, 2.00 (25.4, 31.8, 38.1, 50.8) 1.25, 1.50, 2.00, 2.50, 3.00 (31.8, 38.1, 50.8, 63.5, 76.2) 1 1 Use when DS H1 Type 1, 1.25 and 1.50-inch hubs are needed. TABLE 3-20. TOP ENDWALL (STUCCO) 3-20 Knockout Size Dimensions in Inches (mm) Quantity 1.25, 1.50, 2.00, 2.50 (31.8, 38.1, 50.8, 63.5) 1.00, 1.25, 1.50 (25.4, 31.8, 38.1) .50, .75, 1.00 (12.7, 19.1, 25.4) 1 1 1 .50, .75 (12.7, 19.1) .50 (12.7) 3 3 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 DIMENSIONS AND KNOCKOUTS (RESIDENTIAL METER BREAKERS) — DIMENSIONS IN INCHES (MM) 3.44 (87.3) Top Flush MBE4040B200BTF 5.31 (134.9) Top Surface Meter Breakers 5.31 (134.9) Top Surface 2-1/2-inch Hub 4.94 (125.4) 4.94 (125.4) Bottom Bottom CMBE4242B200BTS MBE4040B200BTS MBE4040B200BSH FIGURE 3-44. KNOCKOUTS FOR STUCCO AND SURFACE UNITS TABLE 3-22. TOP ENDWALL (SURFACE) TABLE 3-24. BOTTOM ENDWALL Hub Provision Catalog Number UPC Code Knockout Size Dimensions in Inches (mm) Quantity DS100H2 DS125H2 DS150H2 782114987858 782114987865 782114987872 DS200H2 DS250H2 DS300H2 DS900AP (Adapter Plate) 782113109961 782113109978 782113342276 782113099422 .50, .75 (12.7, 19.1) .50, .75, 1, 1.25 (12.7, 19.1, 25.4, 31.8) 1.00, 1.25, 1.50, 2.00, 2.50 (25.4, 31.8, 38.1, 50.8, 63.5) 1.00, 1.25, 1.50, 2.00, 2.50, 3.00 (25.4, 31.8, 38.1, 50.8, 63.5, 76.2) 6 2 1 1 Use when DS H1 Type 1, 1.25 and 1.50-inch hubs are needed. TABLE 3-23. TOP ENDWALL (STUCCO) Knockout Size Dimensions in Inches (mm) Quantity 1.25, 1.50, 2.00, 2.50 (31.8, 38.1, 50.8, 63.5) .50, .75 (12.7, 19.1) 2 3 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-21 DIMENSIONS AND KNOCKOUTS (NON-EUSERC METER BREAKER DESIGN) — DIMENSIONS IN INCHES (MM) 5.31 (134.9) 5.31 (134.9) Top Surface (Catalog Numbers with SC and SCR Suffix Only) Top Surface Meter Breakers 4.94 (125.4) 4.94 (125.4) Bottom Bottom FIGURE 3-45. KNOCKOUTS FOR NON-EUSERC UNITS CATALOG NUMBERS — MBB150BTS, MBB200BTS, MBP200BTS, MB816P200BTS, MB816P200BTSCU, MB816P200BTSD, MB816B200BTS, MB816B200BTSCU, MB2040P200BTS, MB2040B200BTS, MBP200BTSD, MBP200SD, MB816P200STD, MB2040B150SD, MB2040B200SD AND MB2040P200SD TABLE 3-25. TOP ENDWALL (SURFACE) Hub Provision Catalog Number UPC Code DS100H2 DS125H2 DS150H2 782114987858 782114987865 782114987872 DS200H2 DS250H2 DS300H2 DS900AP (Adapter Plate) 782113109961 782113109978 782113342276 782113099422 FIGURE 3-46. KNOCKOUTS FOR NON-EUSERC UNITS CATALOG NUMBERS — CMB2424B200BTS, MBB150BTSCR, MBB200BTSCR, MBB150BTSC AND MBB200BTSC TABLE 3-26. BOTTOM ENDWALL Knockout Size Dimensions in Inches (mm) Quantity .31 (7.9) .50 (12.7) .50, .75 (12.7, 19.1) .75, 1.00 (12.7, 25.4) 1.25, 1.50, 2.00, 2.50 (19.1, 38.1, 50.8, 63.5) 1.50, 2.00, 2.50, 3.00 (38.1, 50.8, 63.5, 76.2) 3 3 2 1 2 1 Use when DS H1 Type 1, 1.25 and 1.50-inch hubs are needed. 4.94 (125.4) 4.94 (125.4) Bottom Bottom FIGURE 3-47. KNOCKOUTS FOR NON-EUSERC UNITS CATALOG NUMBER — CHMMB100BTS FIGURE 3-48. KNOCKOUTS FOR NON-EUSERC UNITS CATALOG NUMBERS — CHMMB150BTS AND CHMMB200BTS TABLE 3-27. BOTTOM ENDWALL TABLE 3-28. BOTTOM ENDWALL Knockout Size Dimensions in Inches (mm) .31 (7.9) .50 (12.7) .50, .75, 1.00, 1.25, 1.50, 2.00, 2.50 (12.7, 19.1, 25.4, 31.8, 38.1, 50.8, 63.5) 1,00, 1.25, 1.50, 2.00, 2.50 (25.4, 31.8, 38.1, 50.8, 63.5) 3-22 Quantity 1 1 2 1 Knockout Size Dimensions in Inches (mm) .31 (7.9) .50 (12.7) .50, .75, 1.00, 1.25, 1.50, 2.00, 2.50 (12.7, 19.1, 25.4, 31.8, 38.1, 50.8, 63.5) 1.00, 1.25, 1.50, 2.00, 2.50, 3.00 (25.4, 31.8, 38.1, 50.8, 63.5, 76.2) Quantity 1 1 2 1 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 Technical Data and Specifications — House Panels TYPICAL WIRING DIAGRAMS (TYPE CH STYLE HOUSE PANELS) (OPTIONAL) FACTORY INSTALLED 200 A SERVICE DISCONNECT A N B LINE 400 AMPERES (320 AMPERES CONTINUOUS) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 18 20 21 22 24 26 28 30 32 34 36 38 40 42 17 19 23 25 27 29 31 33 35 37 39 41 FACTORY/FIELD INSTALLED 100 A MAXIMUM SERVICE DISCONNECT TYPE CH OPTIONAL 200 A MAX. SERVICE DISCONNECT TYPE CSR 100 A MAX. SERVICE DISCONNECT TYPE CH OPTIONAL 200 A MAXIMUM SERVICE DISCONNECT TYPE BW, BWH OR CSR AMPERES (CONTINUOUS) EQUIPMENT GROUNDING TERMINALS A N B LINE 1 2 3 4 5 6 7 8 9 10 11 12 BONDED NEUTRAL BONDED NEUTRAL FIGURE 3-49. TYPE CH WIRING DIAGRAM 1 — CATALOG NUMBER CG403242SH FIGURE 3-51. TYPE CH WIRING DIAGRAM 3 — CATALOG NUMBER CG1212P400BS (OPTIONAL) FACTORY/FIELD INSTALLED 200 A MAXIMUM SERVICE DISCONNECT FACTORY INSTALLED 200 A SERVICE DISCONNECT TYPE CSR FACTORY/FIELD INSTALLED 100 A MAXIMUM SERVICE DISCONNECT TYPE CH 400 AMPERES (320 AMPERES CONTINUOUS) A N LINE B 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 17 16 18 19 20 21 22 23 24 25 26 27 29 28 31 32 EQUIPMENT GROUNDING TERMINALS A N LINE BONDED NEUTRAL OPTIONAL 200 A MAX. SERVICE DISCONNECT TYPE CSR OPTIONAL 200 A MAXIMUM SERVICE DISCONNECT TYPE BW, BWH OR CSR 400 AMPERES (320 AMPERES CONTINUOUS) B 1 3 5 7 9 11 Meter Breakers FACTORY/FIELD INSTALLED 200 A MAXIMUM SERVICE DISCONNECT TYPE CSR 100 A MAX. SERVICE DISCONNECT TYPE CH 2 4 6 8 10 12 BONDED NEUTRAL 30 33 34 35 36 37 38 39 40 41 42 FIGURE 3-50. TYPE CH WIRING DIAGRAM 2 — CATALOG NUMBER CG4042SHL FIGURE 3-52. TYPE CH WIRING DIAGRAM 4 — CATALOG NUMBER CG1212P400BSL #14-6 AWG #14-1/0 AWG 1/0 – 300 kcmil #4 AWG – 300 kcmil FIGURE 3-53. TYPE CH WIRING DIAGRAM KEY EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-23 DIMENSIONS AND KNOCKOUTS (TYPE CH STYLE HOUSE PANELS) — DIMENSIONS IN INCHES Meter Breakers FIGURE 3-54. HOUSE PANEL DIMENSIONS AND KNOCKOUTS 3-24 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 TYPICAL WIRING DIAGRAMS (TYPE BR STYLE HOUSE PANELS) A N 9 LINE 400 AMPERES (320 AMPERES CONTINUOUS) A N B BONDED NEUTRAL FIGURE 3-55. TYPE BR WIRING DIAGRAM 1 — CATALOG NUMBER HP40 4 1 2 6 EQUIPMENT 8 GROUNDING TERMINALS 10 3 4 5 6 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 11 12 13 14 15 16 17 18 19 20 21 22 25 24 26 27 28 29 30 31 32 23 LINE 100 A MAX. SERVICE DISCONNECT TYPE BRH OR BR 400 AMPS (320 AMPS CONTINUOUS) 2 7 B FACTORY INSTALLED 200 A SERVICE DISCONNECT TYPE BWH 100 A MAXIMUM SERVICE DISCONNECT TYPE BRH OR BR 400 AMPERES 1 (320 AMPERES 3 CONTINUOUS) 5 FACTORY/FIELD INSTALLED 200 A MAX. SERVICE DISCONNECT TYPE BWH OR BW 33 34 35 36 37 39 38 A N B LINE BONDED NEUTRAL 40 FIGURE 3-57. TYPE BR WIRING DIAGRAM 3 — CATALOG NUMBER HP404040SH FIGURE 3-59. TYPE BR WIRING DIAGRAM 5 — CATALOG NUMBER HP402440SBH #14-6 AWG FACTORY INSTALLED 400 A SERVICE DISCONNECT TYPE DK 400 AMPS (320 AMPS CONTINUOUS) A N LINE B 1 2 3 4 5 6 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 A N LINE B #14-1/0 AWG (OPTIONAL) 200 A MAX. SERVICE DISCONNECT TYPE BW OR BWH FACTORY INSTALLED 200 A MAX. SERVICE DISCONNECT TYPE BWH 400 AMPS (320 AMPS CONTINUOUS) BONDED NEUTRAL #6 AWG – 250 kcmil 100 A MAX. SERVICE DISCONNECT 1 3 5 7 9 11 13 15 #1 AWG – 300 kcmil 2 4 6 8 10 EQUIPMENT 12 GROUNDING 14 TERMINALS 16 1/0 – 300 kcmil Meter Breakers FACTORY INSTALLED 200 A SERVICE DISCONNECT TYPE BWH F ACTOR Y INSTALLED 400 A SER VICE DISCONNECT TYPE DK (OPTIONAL) (OPTIONAL) FACTORY/FIELD INSTALLED 200 A MAXIMUM SERVICE DISCONNECT TYPE BWH OR BW #4 AWG – 300 kcmil #6 AWG – 300 kcmil BONDED NEUTRAL FIGURE 3-60. TYPE BR WIRING DIAGRAM KEY BONDED NEUTRAL FIGURE 3-56. TYPE BR WIRING DIAGRAM 2 — CATALOG NUMBER HP402440B FIGURE 3-58. TYPE BR WIRING DIAGRAM 4 — CATALOG NUMBER HP816P400BS EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — ©Copyright 2005 3-25 TYPICAL WIRING DIAGRAMS (TYPE BR STYLE HOUSE PANELS) 400 AMPS (320 AMPS CONTINUOUS) FACTORY INSTALLED 400 A SERVICE DISCONNECT TYPE DK 400 AMPERES (320 AMPERES CONTINUOUS) A N B LINE (OPTIONAL) (OPTIONAL) Meter Breakers 1 2 3 4 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 FACTORY/FIELD INSTALLED 200A MAX. SERVICE DISCONNECT TYPE BWH OR BW 100A MAX. SERVICE DISCONNECT TYPE BRH OR BR FACTORY INSTALLED 200 A SERVICE DISCONNECT TYPE BWH 400 AMPS (320 AMPS CONTINUOUS) BONDED NEUTRAL A N FACTORY INSTALLED BY-PASS. A 2 3 4 5 6 N B LINE LINE GROUNDING LUG 100 A MAX. SERVICE DISCONNECT TYPE BRH OR BR EQUIPMENT 8 GROUNDING 10 TERMINALS 9 B FIGURE 3-63. TYPE BR WIRING DIAGRAM 8 — CATALOG NUMBER HP40SH 1 7 BONDED NEUTRAL FIGURE 3-61. TYPE BR WIRING DIAGRAM 6 — CATALOG NUMBER HP402442 FACTORY/FIELD INSTALLED 200 A MAX. SERVICE DISCONNECT TYPE BWH OR BW FACTORY INSTALLED 200 A SERVICE DISCONNECT TYPE BWH 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 33 32 34 35 37 36 38 39 40 FIGURE 3-65. TYPE BR WIRING DIAGRAM 10 — CATALOG NUMBER HP404040SHA (OPTIONAL) FACTORY INSTALLED 200 A SERVICE DISCONNECT TYPE BWH 400 AMPS (320 AMPS CONTINUOUS) B A LINE N 1 2 3 BONDED NEUTRAL 5 7 4 9 10 11 OPTIONAL FACTORY INSTALLED 200 A SERVICE DISCONNECT TYPE BWH 8 400 AMPS (320 AMPS CONTINUOUS) 12 14 15 17 16 18 19 20 21 22 23 24 25 26 27 28 200 A MAX. SERVICE DISCONNECT TYPE BWH FACTORY INSTALLED 200 A MAX. SERVICE DISCONNECT 6 13 29 FACTORY/FIELD INSTALLED 200 A MAX. SERVICE DISCONNECT TYPE BW OR BWH 100 A MAX. SERVICE DISCONNECT TYPE BR OR BHR (OPTIONAL) FACTORY/FIELD INSTALLED 200 A MAX. SERVICE DISCONNECT TYPE BW OR BWH 400 AMPS (320 AMPS CONTINUOUS) A N LINE B 100 A MAX. SERVICE DISCONNECT 1 3 5 7 9 11 13 15 2 4 6 8 10 12 14 16 EQUIPMENT GROUNDING TERMINALS 100 A MAX. SERVICE DISCONNECT TYPE BR OR BRH BONDED NEUTRAL BONDED NEUTRAL A LINE B N 30 31 32 33 34 35 36 37 38 39 40 FIGURE 3-62. TYPE BR WIRING DIAGRAM 7 — CATALOG NUMBER HP404040SHL FIGURE 3-64. TYPE BR WIRING DIAGRAM 9 — CATALOG NUMBER HP40SHL FIGURE 3-66. TYPE BR WIRING DIAGRAM 11 — CATALOG NUMBER HP816P400BSL #14-6 AWG #14-1/0 AWG #6 AWG – 250 kcmil #1 AWG – 300 kcmil 1/0 – 300 kcmil 1/3 – 300 kcmil #4 AWG – 300 kcmil #6 AWG – 300 kcmil FIGURE 3-67. TYPE BR WIRING DIAGRAM KEY National Electrical Code and NEC are registered trademarks of the National Fire Protection Association, Quincy, Mass. UL is a federally registered trademark of Underwriters Laboratories Inc. Cutler-Hammer is a federally registered trademark of Eaton Corporation. 3-26 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Meter Breakers — Effective August 2005 Meter Sockets NEED 4-5 4-6 4-7 4-10 4-12 4-13 4-14 4-15 4-16 4-16 Metering Meter Sockets Single Position (Ring, Ringless and Lever Bypass). . . . . . . . Multiple Position — Without Tenant Main Breakers . . . . . . . . . . Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . Meter Packs — (All-in-Ones) Aluminum Bus . . . Metering Mains Main Terminal Box . . . . . . . . . . . . . . . . . . . . . Main Circuit Breaker . . . . . . . . . . . . . . . . . . . Main Circuit Breaker — EUSERC Approved. . . Main Fusible Switch . . . . . . . . . . . . . . . . . . . Underground Pull Box . . . . . . . . . . . . . . . . . . Bolted Pressure Switch . . . . . . . . . . . . . . . . . Residential Meter Stacks — Single- and Three-Phase 800 A — Ring, Ringless, and Ringless with Horn Bypass — Aluminum Bus . . . . . 800 A — Ring, Ringless, and Ringless with Horn Bypass — Copper Bus . . . . . . . . 1200 A — Ring, Ringless, and Ringless with Horn Bypass — Copper Bus . . . . . . . . Commercial Meter Stacks Three-Phase In — Single-Phase Out . . . . . . . Three-Phase In — Three-Phase Out . . . . . . . EUSERC Approved . . . . . . . . . . . . . . . . . . . . Tenant Main Breakers . . . . . . . . . . . . . . . . . . . . . Metering Accessories . . . . . . . . . . . . . . . . . . . . . Meter Sockets Product Description 4-17 4-18 A meter socket is used where the electricity enters a home. The electric utility meter fits in the socket to measure power consumption. 4-19 Features, Functions and Benefits ✓ Variety of designs to meet local utility 4-20 4-21 4-22 4-23 4-24 specifications. ✓ Interchangeable hubs. ✓ Notched wire saddle — grips for good wire connectivity. ✓ Anti-pry rivets on cover for security. ✓ Limited 1-year warranty. ✓ UL姞 listed. Also available are regional-specific meter socket catalogs identifying products approved by local utilities in each of these markets. These can be found on www.EatonElectrical.com. TABLE 4-1. REGIONAL-SPECIFIC METER SOCKET CATALOGS Region Publication Number North & South Carolina Chicago Florida TD00505007E TD00505001E TD00505002E Iowa, Kansas, Missouri & Oklahoma New York City Ohio TD00505003E TD00505004E TD00505005E Pennsylvania Texas Upstate New York Wisconsin & Minnesota TD00505006E TD00505012E TD00505008E TD00505013E EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-1 Catalog Numbering System TABLE 4-2. “RS” GROUP CATALOG NUMBERING SYSTEM UT RS 2 0 2 B CH Standard Prefix (See Prefix Guide) Cutler-Hammer姞 Standard Suffixes See Product Group Designators Ampere Rating 1 = 100 Amperes 2 = 200 Amperes 5 = 150 Amperes Service Design 0 = Overhead 1 = Combination Overhead/Underground 2 = Underground, Side Wired 3 = Combination, Overhead/ Underground, Side Wired Maximum Conductor (Line & Load) Metering 0= 1= 2= 3= 3/8" Stud Connectors #2/0 Connectors #250 kcmil Connectors #350 kcmil Connectors A= B= C= L= M= N= P= T= U= V= Q= R= S= Z= Solid Top Small Hub Opening Small Hub Closure Plate 1-1/4" Hub 1-1/2" Hub 2" Hub 2-1/2" Hub Large Hub Opening Large Hub Cover Plate 2-1/2" Large Hub 3" Large Hub 3-1/2" Large Hub 4" Large Hub Large to Small Hub Adapter Mounted “RS” Group = Residential Service, Single Position. Note: Some sockets that are built for specific utilities have their own unique catalog numbers. These can be found on the utility selection pages. Meter Socket “Prefix” Guide A B F G H I M N R S T TT U Z Aluminum enclosure Barrel lock provision, for an exposed INNER-TITE姞 or Brooks barrel lock; unit includes an internal lock receiver bracket. Barrel lock with guard provision, for a lock guard INNER-TITE or Brooks barrel lock; unit includes an internal lock receiver bracket. Grounded fifth terminal (9 o’clock position) Horn bypass Inhibitor installed in wire connectors Temporary meter cover (waxed cardboard) No sealing ring (applies only to ring style sockets) Ring style socket Aluminum screw type sealing ring (applies only to ring style sockets) Grounding connector (#14 – #2 Cu) for Tri-Plex ground Two (2) grounding connectors (#14 – #2 Cu) for Quad-Plex ground UL (Underwriters Laboratories) labeled 5/16” Hex head connector screw in place of slotted (100 amperes only) Note: The “U” prefix is always used first, followed by other prefixes required in alphabetical order. 4-2 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Catalog Numbering System TABLE 4-3. “2R-6R” AND “2H-6H” GROUP CATALOG NUMBERING SYSTEM UT 2R 1 1 21 B CH Standard Prefix (See Prefix Guide on Page 4-2) Cutler-Hammer姞 Ampere Rating 1 = 100 Amperes 2 = 200 Amperes Service Design 0 = Overhead 1 = Combination Overhead/Underground 2 = Underground, Side Wired 3 = Combination, Overhead/ Underground, Side Wired 4 = Endfeed Maximum Conductor (Line & Load) 0= 1= 2= 3= 5= 6= 7= 8= 9= 3/8" Stud Connectors #2/0 Connectors #250 kcmil Connectors #350 kcmil Connectors #500 kcmil Connectors #600 kcmil Connectors #750 kcmil Connectors Dual #250 kcmil Connectors Dual #500 kcmil Connectors A= B= C= L= M= N= P= T= U= V= Q= R= S= Z= Solid Top Small Hub Opening Small Hub Closure Plate 1-1/4" Hub 1-1/2" Hub 2" Hub 2-1/2" Hub Large Hub Opening Large Hub Cover Plate 2-1/2" Large Hub 3" Large Hub 3-1/2" Large Hub 4" Large Hub Large to Small Hub Adapter Mounted “2R-6R” Group = Residential Service, Multiple Position. “2H-6H” Group = Commercial or Residential Service, Multiple Position (lever bypass). Metering Standard Suffixes See Product Group Designators TABLE 4-4. “H” GROUP CATALOG NUMBERING SYSTEM UT H 4 2 0 3 B CH Cutler-Hammer Standard Prefix (See Prefix Guide on Page 4-2) Standard Suffixes See Product Group Designators Jaw Quantity 4 = 4 Terminal 5 = 5 Terminal 7 = 7 Terminal Ampere Rating 2 = 200 Amperes 3 = 320 Amperes Service Design 0 = Overhead 1 = Combination Overhead/Underground 2 = Underground, Side Wired 3 = Combination, Overhead/ Underground, Side Wired Maximum Conductor (Line & Load) 0= 1= 2= 3= 5= 6= 7= 8= 9= 3/8" Stud Connectors #2/0 Connectors #250 kcmil Connectors #350 kcmil Connectors #500 kcmil Connectors #600 kcmil Connectors #750 kcmil Connectors Dual #250 kcmil Connectors Dual #500 kcmil Connectors A= B= C= L= M= N= P= T= U= V= Q= R= S= Z= Solid Top Small Hub Opening Small Hub Closure Plate 1-1/4" Hub 1-1/2" Hub 2" Hub 2-1/2" Hub Large Hub Opening Large Hub Cover Plate 2-1/2" Large Hub 3" Large Hub 3-1/2" Large Hub 4" Large Hub Large to Small Hub Adapter Mounted “H” Group = Commercial or Residential Service, Single Position (lever bypass). EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-3 Knockout Drawings 2 1 4 3 4 UTRS101BCH 1 4 3 2 4 UTH5213B or TCH 2 Metering 1 1 3 2 UTRS202BCH 4 3 4 UTH4330TCH 2 1 3 4 1 1 1 4 4 2 UTRS223ACH 4 3 UT3R1121BCH 1 4 3 1 1 4 4 2 UT3R2332TCH Drawings not to scale. FIGURE 4-1. KNOCKOUT DRAWINGS Dimensions for boxes on Pages 4-29. 4-4 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Data Tables RESIDENTIAL METER SOCKETS — RINGLESS TYPE COVER Load Depth Service Bypass Line Width Connections Height Positions Jaws Ampere Rating TABLE 4-5. SINGLE METER SOCKETS — DIMENSIONS IN INCHES 10.88 10.88 10.88 10.88 8.00 8.00 8.00 8.00 3.50 3.50 3.50 3.50 Opening, Hub Catalog or Closure Plate Number UPC Code Hub Opening 1 1/4" Hub Hub Opening Hub Opening UTRS101BCH UTRS101LCH UHTRS101BCH UGHTRS101BCH 782113685168 782116016242 782114007556 782113890623 125 125 125 125 4 4 4 5 — — — — — — Horn Horn #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 150 150 4 4 — OH/UG — OH/UG — — #8 – 250 kcmil #8 – 250 kcmil 14.00 #8 – 250 kcmil #8 – 250 kcmil 14.00 8.00 4.38 Hub Opening 8.00 4.38 Closure Plate UTRS502BCH UTRS502CCH 782113684024 782113729732 200 200 200 4 4 4 — OH — OH — OH — Horn — #8 – 250 kcmil #8 – 250 kcmil 14.00 #8 – 250 kcmil #8 – 250 kcmil 14.00 #8 – 250 kcmil #8 – 250 kcmil 14.00 8.00 4.38 Hub Opening 8.00 4.38 Hub Opening 8.00 4.38 2" Hub UTRS202BCH UHTRS202BCH UTRS202NCH 782113685144 782114582626 782114110607 200 200 200 200 4 4 4 4 — — — — OH/UG OH/UG OH/UG OH/UG — — Horn Horn #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil UTRS213BCH UTRS213CCH UHTRS213BCH UHTRS213CCH 782113685182 782114631058 782116016389 782114007563 200 200 5 5 — OH/UG — OH/UG Horn Horn #6 – 350 kcmil #6 – 350 kcmil 15.00 11.00 4.38 Hub Opening #6 – 350 kcmil #6 – 350 kcmil 15.00 11.00 4.38 Closure Plate UGHTRS213BCH UGHTRS213CCH 782113890616 782116016433 200 200 200 200 4 4 5 4 — — — — — Horn Horn Horn #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil 13.00 13.00 13.00 20.00 UTRS223ACH UHTRS223ACH UGHTRS223ACH UHTRS233CCH 782114103524 782114113905 782113890647 782116168613 URTRS101BCH URTRS111BCH UNRRS101BEUSCH UNRRS111BEUSCH 782114114346 782116136520 782113683928 782113683935 URTRS202BCH URTRS202NEUSCH UNRRS202BEUSCH URTRS213BCH URTRS213CEUSCH URTRS213NEUSCH UNRRS213AEUSCH UNRRS213BEUSCH UNRRS213CEUSCH 782114114339 782116103324 782113683959 782114114322 782116124329 782116103317 782113928630 782113928647 782113683966 OH/UG OH/UG OH/UG OH/UG UG UG UG OH/UG #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil 15.00 15.00 15.00 15.00 11.00 11.00 11.00 11.00 13.00 13.00 13.00 13.00 4.38 4.38 4.38 4.38 4.94 4.94 4.94 4.94 Hub Opening Closure Plate Hub Opening Closure Plate Solid Top Solid Top Solid Top Closure Plate Metering Residential Ringless Type Cover Residential Ring Type Cover 125 125 125 125 4 4 4 4 — — — — OH/UG OH/UG OH/UG OH/UG — — — — #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 10.88 8.00 3.50 Hub Opening 14.00 11.00 4.38 Hub Opening 10.88 8.00 3.50 Hub Opening 14.00 11.00 4.38 Hub Opening 200 200 200 200 200 200 200 200 200 4 4 4 4 4 4 4 4 4 — — — — — — — — — OH OH OH OH/UG OH/UG OH/UG UG OH/UG OH/UG — — — — — — — — — #8 – 250 kcmil #8 – 250 kcmil #8 – 250 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #8 – 250 kcmil #8 – 250 kcmil #8 – 250 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil 14.00 14.00 14.00 15.00 15.00 15.00 15.00 15.00 15.00 8.00 8.00 8.00 11.00 11.00 11.00 11.00 11.00 11.00 4.38 4.38 4.38 4.38 4.38 4.38 4.38 4.38 4.38 Hub Opening 2" Hub Hub Opening Hub Opening Closure Plate 2" Hub Hub Opening Hub Opening Closure Plate Residential/Commercial Lever Bypass 200 200 200 4 5 5 — OH — OH — OH Lever Lever Lever #6 – 350 kcmil #6 – 350 kcmil 19.00 10.50 4.94 Hub Opening #6 – 350 kcmil #6 – 350 kcmil 19.00 10.50 4.94 Hub Opening #6 – 350 kcmil #6 – 350 kcmil 19.00 10.50 4.94 Hub Opening UTH4203BCH UTH5203BCH UTH7203TCH 782114840313 782116109449 782116109470 200 200 200 4 5 7 — OH/UG — OH/UG — OH/UG Lever Lever Lever #6 –350 kcmil #6 – 350 kcmil 19.00 13.00 4.94 Closure Plate #6 – 350 kcmil #6 – 350 kcmil 19.00 13.00 4.94 Closure Plate #6 – 350 kcmil #6 – 350 kcmil 19.00 13.00 4.94 Closure Plate UTH4213CCH UTH5213CCH UTH7213UCH 782113685038 782116106660 782116016600 320 320 320 4 5 7 — OH — OH — OH Lever Lever Lever 3/8" Studs 3/8" Studs 3/8" Studs 3/8" Studs 3/8" Studs 3/8" Studs 19.00 10.50 4.94 Hub Opening 19.00 10.50 4.94 Hub Opening 19.00 10.50 4.94 Hub Opening UTH4300TCH UTH5300TCH UTH7300TCH 782113715445 782116144679 782116094875 320 320 320 4 5 7 — OH/UG — OH/UG — OH/UG Lever Lever Lever 3/8" Studs 3/8" Studs 3/8" Studs 3/8" Studs 3/8" Studs 3/8" Studs 19.00 13.00 4.94 Closure Plate 19.00 13.00 4.94 Closure Plate 19.00 13.00 4.94 Closure Plate UTH4330UCH UTH5330UCH UTH7330UCH 782116003778 782116096381 782116016686 Does not include the ring. Ring to be provided by local utility. Note: This is only a sample of products available. Meter sockets are specified by local utilities. See Table 4-1 Regionalspecific Meter Socket Catalogs. Check with the department manager for catalog numbers specific to your area or visit www.EatonElectrical.com for more information. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-5 RESIDENTIAL METER SOCKETS — RINGLESS TYPE COVER Depth Opening, Hub Catalog or Closure Plate Number 100 100 100 100 100 4 4 4 4 4 2 3 4 5 6 OH/UG OH/UG OH/UG OH/UG OH/UG — — — — — #6 – 250 kcmil #6 – 250 kcmil #6 – 250 kcmil #6 – 250 kcmil #6 – 350 kcmil #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 14.13 14.13 14.13 14.13 14.13 24.31 32.47 40.63 48.78 56.94 4.50 4.50 4.50 4.50 4.50 Hub Opening Hub Opening Hub Opening Hub Opening Hub Opening UT2R1121BCH UT3R1121BCH UT4R1121BCH UT5R1121BCH UT6R1131BCH 782116016532 782116094615 782116094639 782116094646 782116094653 100 100 100 100 100 4 4 4 4 4 2 3 4 5 6 OH/UG OH/UG OH/UG OH/UG OH/UG Horn Horn Horn Horn Horn #6 – 250 kcmil #6 – 250 kcmil #6 – 250 kcmil #6 – 250 kcmil #6 – 350 kcmil #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 #8 – 2/0 14.13 14.13 14.13 14.13 14.13 24.31 32.47 40.63 48.78 56.94 4.50 4.50 4.50 4.50 4.50 Hub Opening Hub Opening Hub Opening Hub Opening Hub Opening UHT2R1121BCH UHT3R1121BCH UHT4R1121BCH UHT5R1121BCH UHT6R1131BCH 782116007769 782116007783 782116007806 782116007820 782116007844 200 200 200 200 200 4 4 4 4 4 2 3 4 5 6 OH/UG OH/UG OH/UG OH/UG OH/UG — — — — — #6 – 350 kcmil #6 – 350 kcmil 1/0 – 500 kcmil 1/0 – 500 kcmil 1/0 – 500 kcmil #8 – 250 kcmil #8 – 250 kcmil #8 – 250 kcmil #8 – 250 kcmil #8 – 250 kcmil 14.13 14.13 14.13 14.13 14.13 24.31 32.47 40.63 54.78 62.94 5.38 5.38 5.38 5.38 5.38 Hub Opening Hub Opening Hub Opening Hub Opening Hub Opening UT2R2332TCH UT3R2332TCH UT4R2352TCH UT5R2392TTCH UT6R2392TTCH 782116064083 782116036011 782116016693 782116104642 782116104659 200 200 200 200 200 4 4 4 4 4 2 3 4 5 6 OH/UG OH/UG OH/UG OH/UG OH/UG Horn Horn Horn Horn Horn #6 – 350 kcmil #6 – 350 kcmil 1/0 – 500 kcmil 1/0 – 500 kcmil 1/0 – 500 kcmil #8 – 250 kcmil #8 – 250 kcmil #8 – 250 kcmil #8 – 250 kcmil #8 – 250 kcmil 14.13 14.13 14.13 14.13 14.13 24.31 32.47 40.63 54.78 62.94 5.38 5.38 5.38 5.38 5.38 Hub Opening Hub Opening Hub Opening Hub Opening Hub Opening UHT2R2332TCH UHT3R2332TCH UHT4R2352TCH UHT5R2392TTCH UHT6R2392TTCH 782113922621 782113923093 782116007813 782116073979 782116073986 200 200 200 200 200 5 5 5 5 5 2 3 4 5 6 OH/UG OH/UG OH/UG OH/UG OH/UG Lever Lever Lever Lever Lever 1/0 – 500 kcmil 1/0 – 500 kcmil 1/0 – 500 kcmil 1/0 – 500 kcmil 1/0 – 500 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil #6 – 350 kcmil 23.56 23.56 23.56 23.56 23.56 32.78 43.91 61.03 72.16 83.28 6.00 6.00 6.00 6.00 6.00 Hub Opening Hub Opening Hub Opening Hub Opening Hub Opening UT2H52353TCH UT3H52353TCH UT4H52393TTCH UT5H52393TTCH UT6H52393TTCH 782116143986 782116143993 782116144006 782116144013 782116144020 Jaws Width Connections Height Positions Ampere Rating TABLE 4-5. SINGLE METER SOCKETS — DIMENSIONS IN INCHES (CONTINUED) Service Bypass Line Load UPC Code Horizontal Design — Multi-Position Ringless Metering Note: This is only a sample of products available. Meter sockets are specified by local utilities. Check with the department manager for catalog numbers specific to your area or visit www.EatonElectrical.com for more information. 4-6 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Related Products TABLE 4-6. CUTLER-HAMMER METER SOCKET ACCESSORIES Description Cutler-Hammer Catalog Number UPC Code 1.00-Inch Hub 1.25-Inch Hub 1.50-Inch Hub 2.00-Inch Hub — Small Opening 2.50-Inch Hub — Small Opening ARP00003CH1 ARP00004CH12 ARP00005CH15 ARP00006CH2 ARP00007CH25 782114004081 782114004098 782114004104 782114004111 782114004128 2.00-Inch Hub — Large Opening 2.50-Inch Hub — Large Opening 3.00-Inch Hub — Large Opening 4.00-Inch Hub — Large Opening Small Hub Closure Plate ARP00017CH2 ARP00018CH25 ARP00019CH3 ARP00021CH4 ARP00002CHB 782113950822 782116029754 782114117255 782114117262 782114004074 Small Hub Closure Plate — Aluminum Large Hub Closure Plate Hub Adapter Plate — Large to Small Replacement — Plug-in Fifth Terminal (R and RS Models Only) Replacement Block Assembly for 100 A Sockets — 2/0 Maximum ARP00008CH ARP00016CHB ARP00015CHAP ARP00035CHJ ARP00039CH 782116029891 782114117279 782113945552 782114004135 782116036868 Replacement Block Assembly for 200 A Sockets — 350 Maximum Replacement Block Assembly for 150 A Sockets — 250 Maximum #4 – 600 kcmil Lug #6 – 350 kcmil Dual Lug #6 – 350 kcmil Lug ARP00048CH ARP00354CH ARP00129CH ARP00427CH ARP00119CH 782116036851 782116036875 782116015931 782116044955 782116072354 Description Cutler-Hammer Catalog Number UPC Code Small Hub Closure Plate 1.00-Inch Hub 1.25-Inch Hub 1.50-Inch Hub 2.00-Inch Hub — Small Opening 2.50-Inch Hub — Small Opening ARP00002CHBCS ARP00003CH1CS ARP00004CH12CS ARP00005CH15CS ARP00006CH2CS ARP00007CH25CS 782116036363 782116036387 782116036394 782116036400 782116036417 782116036370 TABLE 4-7. CLAMSHELL ACCESSORIES EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 ✓ Loadcenters ✓ Surge Protection ✓ Circuit Breakers Metering Accessories 4-7 Group Metering NEED Metering Group Metering Product Description Group metering, also known as multiple metering, is used where electric utility power enters a commercial building or multi-family residence. The product consists of some type of main device along with multiple meter sockets in one unit or in several connected units. The multiple meters allow the utility to measure power consumption for each tenant of the building. This type of metering equipment is commonly used at apartment complexes and strip malls. 4-8 Features, Functions and Benefits ✓ Available as main breaker, fusible ✓ ✓ ✓ ✓ ✓ ✓ switches or terminal boxes. Ring or ringless. Clip-tight姠 socket. One piece vertical bus bar. Easy installation. Limited 1-year warranty. UL listed. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Catalog Numbering System TABLE 4-8. METER PACK CATALOG NUMBERING SYSTEM 1 M P 4 12 4 R C 1-Phase Type of Metering Bus Material MP = Meter Pack C = Copper Bus Blank = Aluminum Bus Number of Meters Security or Accessory Code 2, 3, 4, 5 or 6 Blank = Accessory R = Ring RRL = Ringless RRLB = Ringless with Horn Bypass LK = Lug Kit (Accessory) SC = Crimp Lug Landing Pad Kit (Accessory) Ampere Rating 12 = 125 Amperes 20 = 200 Amperes Blank = Accessory Bus Ampere Rating Metering 2 = 200 Amperes 4 = 400 Amperes 6 = 600 Amperes Blank = Accessory TABLE 4-9. MAIN SERVICE MODULES CATALOG NUMBERING SYSTEM 3 MTB 400 R C Bus Material Phase C = Copper Bus Blank = Aluminum Bus 1 = 1-Phase 3 = 3-Phase Type of Metering MTB = MCB = BPS = MFS = UGPB = Accessories and Additional Options Main Terminal Box Main Circuit Breaker Bolted Pressure Switch Main Fusible Switch Underground Pull Box BLK CLK B T UG Blank = = = = = = Box Lug Kit (Accessory) Compression Lug (Accessory) Bottom Feed Top Feed Pull Box No Options Ampere Rating 400 Amperes 600 Amperes 800 Amperes 1000 Amperes 1200 Amperes 1400 Amperes 1600 Amperes 2000 Amperes Enclosure R = NEMA姞 3R TABLE 4-10. RESIDENTIAL METER STACKS CATALOG NUMBERING SYSTEM 1 MM 4 12 R Phases 1 = 1-Phase 3 = 3-Phase Type of Metering MM = Multiple Metering RLB C Options Number of Meters 2, 3, 4, 5 or 6 Blank = Accessory Ampere Rating 12 = 125 Amperes 20 = 200 Amperes Blank = Accessory Enclosure R = Outdoor Blank = Indoor Blank = Ring RL = Ringless RLB = Ringless with Horn Bypass WB = Wall Bracket (Accessory) BSK = Bussed Spacer (Accessory) EB12 = 12-Inch (304.8 mm) Elbow (Accessory) EB16 = 16-Inch (406.4 mm) Elbow (Accessory) Bus Type Blank = Aluminum C = Copper Bus Amperes 12 = 1200 Ampere Horizontal Bus (3MM units only) Blank = Standard 800 Ampere Bus EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-9 Data Tables TABLE 4-11. METER PACKS — ALUMINUM BUS Socket Ampere Rating Number of Meter Sockets Bus Ampacity Main Tenant Breaker Type Catalog Number UPC Code Semi-flush Flange Kit Catalog Number UPC Code Ring Style Meter Socket Covers 125 2 3 4 5 6 200 400 400 600 600 Plug-on Type BR_ BRH_ BRHH_ — 1MP2122R 1MP3124R 1MP4124R 1MP5126R 1MP6126R 786849052379 786849052386 786849052393 786849052409 786849052416 1MPSFK1 1MPSFK2 1MPSFK2 1MPSFK3 1MPSFK3 786849054069 786849054076 786849054076 786849054083 786849054083 200 2 3 4 5 6 400 600 600 600 600 Bolt-on Type CC2_X CHH2_H2X CHH2_H4X CHH_X 1MP2204R 1MP3206R 1MP4206R 1MP5206R 1MP6206R 786849052423 786849052430 786849052447 786849052454 786849052461 1MPSFK4 1MPSFK5 1MPSFK5 1MPSFK6 1MPSFK6 786849054090 786849054106 786849054106 786849054113 786849054113 Ringless Style Meter Socket Covers Metering 125 2 3 4 5 6 200 400 400 600 600 Plug-on Type BR_ BRH_ BRHH_ — 1MP2122RRL 1MP3124RRL 1MP4124RRL 1MP5126RRL 1MP6126RRL 786849052478 786849052485 786849052492 786849052508 786849052515 1MPSFK1 1MPSFK2 1MPSFK2 1MPSFK3 1MPSFK3 786849054069 786849054076 786849054076 786849054083 786849054083 200 2 3 4 5 6 400 600 600 600 600 Bolt-on Type CC2_X CHH2_H2X CHH2_H4X CHH_X 1MP2204RRL 1MP3206RRL 1MP4206RRL 1MP5206RRL 1MP6206RRL 786849052522 786849052539 786849052546 786849052553 786849052560 1MPSFK4 1MPSFK5 1MPSFK5 1MPSFK6 1MPSFK6 786849054090 786849054106 786849054106 786849054113 786849054113 Ringless Style Covers with Horn Bypass 125 2 3 4 5 6 200 400 400 600 600 Plug-on Type BR_ BRH_ BRHH_ — 1MP2122RRLB 1MP3124RRLB 1MP4124RRLB 1MP5126RRLB 1MP6126RRLB 786849052577 786849052584 786849052591 786849052607 786849052720 1MPSFK1 1MPSFK2 1MPSFK2 1MPSFK3 1MPSFK3 786849054069 786849054076 786849054076 786849054083 786849054083 200 2 3 4 5 6 400 600 600 600 600 Bolt-on Type CC2_X CHH2_H2X CHH2_H4X CHH_X 1MP2204RRLB 1MP3206RRLB 1MP4206RRLB 1MP5206RRLB 1MP6206RRLB 786849052737 786849052744 786849052751 786849052768 786849052775 1MPSFK4 1MPSFK5 1MPSFK5 1MPSFK6 1MPSFK6 786849054090 786849054106 786849054106 786849054113 786849054113 Ring Style Meter Packs do not come with fifth jaw. Order 1MM5KJ if needed. To change in field from ring to ringless — order 1MMRC125. To change in field from ring to ringless — order 1MMRC200. To change from ring to ringless covers, the top socket only in 2, 5 and 6 socket designs — order 1MMRC125T. Top socket only — other sockets see . Main lugs included. #6 – 300 kcmil. (Optional lugs are not available.) Bottom feed only. Fifth jaw factory installed at 9 o’clock position. 4-10 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Data Tables TABLE 4-12. METER PACKS — COPPER BUS Socket Ampere Rating Number of Meter Sockets Bus Ampacity Main Tenant Breaker Type Catalog Number UPC Code Semi-flush Flange Kit Catalog Number UPC Code Ring Style Meter Socket Covers 125 2 3 4 5 6 200 400 400 600 600 Plug-on Type Plug-on Type BR_ BRH_ BRHH_ 1MP2122RC 1MP3124RC 1MP4124RC 1MP5126RC 1MP6126RC 782116008902 782114990087 782114990162 782114990247 782114990308 1MPSFK1 1MPSFK2 1MPSFK2 1MPSFK3 1MPSFK3 786849054069 786849054076 786849054076 786849054083 786849054083 200 2 3 4 5 6 400 600 600 600 600 Bolt-on Type CC2_X CHH2_H2X CHH2_H4X CHH_X 1MP2204RC 1MP3206RC 1MP4206RC 1MP5206RC 1MP6206RC 782114990056 782114990131 782114990209 782114990278 782114990346 1MPSFK4 1MPSFK5 1MPSFK5 1MPSFK6 1MPSFK6 786849054090 786849054106 786849054106 786849054113 786849054113 125 2 3 4 5 6 200 400 400 600 600 Plug-on Type Plug-on Type BR_ BRH_ BRHH_ 1MP2122RRLC 1MP3124RRLC 1MP4124RRLC 1MP5126RRLC 1MP6126RRLC 782116008919 782114990117 782114990193 782114990261 782114990322 1MPSFK1 1MPSFK2 1MPSFK2 1MPSFK3 1MPSFK3 786849054069 786849054076 786849054076 786849054083 786849054083 200 2 3 4 5 6 400 600 600 600 600 Bolt-on Type CC2_X CHH2_H2X CHH2_H4X CHH_X 1MP2204RRLC 1MP3206RRLC 1MP4206RRLC 1MP5206RRLC 1MP6206RRLC 782114990070 782114990155 782114990230 782114990292 782114990360 1MPSFK4 1MPSFK5 1MPSFK5 1MPSFK6 1MPSFK6 786849054090 786849054106 786849054106 786849054113 786849054113 Metering Ringless Style Meter Socket Covers Ringless Style Covers with Horn Bypass 125 2 3 4 5 6 200 400 400 600 600 Plug-on Type Plug-on Type BR_ BRH_ BRHH_ 1MP2122RRLBC 1MP3124RRLBC 1MP4124RRLBC 1MP5126RRLBC 1MP6126RRLBC 782116010301 782114990094 782114990186 782114990254 782114990315 1MPSFK1 1MPSFK2 1MPSFK2 1MPSFK3 1MPSFK3 786849054069 786849054076 786849054076 786849054083 786849054083 200 2 3 4 5 6 400 600 600 600 600 Bolt-on Type CC2_X CHH2_H2X CHH2_H4X CHH_X 1MP2204RRLBC 1MP3206RRLBC 1MP4206RRLBC 1MP5206RRLBC 1MP6206RRLBC 782114990063 782114990148 782114990223 782114990285 782114990353 1MPSFK4 1MPSFK5 1MPSFK5 1MPSFK6 1MPSFK6 786849054090 786849054106 786849054106 786849054113 786849054113 Ring Style Meter Packs do not come with fifth jaw. Order 1MM5KJ if needed. To change in field from ring to ringless — order 1MMRC125. To change in field from ring to ringless — order 1MMRC200. To change in field from ring to ringless covers, the top socket only in 5 to 6 socket design — order 1MMRC125T. Top socket only — other sockets see . Fifth jaw factory installed at 9 o’clock position. TABLE 4-13. MAIN LUG KIT SELECTION — FIELD INSTALLED KITS FOR EITHER 400 OR 600 AMPERE MAIN BUS Line Lug and Wire Sizes Order Separately and Field Install Line Lug Kit Catalog Number Each Kit Comes With 3 Lugs, Two Lines and a Neutral UPC Code (1) #6 – 600 kcmil or (2) 2/0 – 250 kcmil (2) 250 – 500 kcmil (3) #4 – 300 kcmil (1) 750 kcmil Crimp lug landing pad 250 – 750 kcmil 1MPLK1 1MPLK3 1MPLK4 1MPLK2 1MPSC1 786849054120 786849054137 786849054144 786849054151 786849054168 This kit comes with three pads for two lines and neutral. Each pad will accept one or two crimp lugs. Cannot be used on 1MP2122R, RL and RLB EUSERC underground termination. This lug is not UL listed. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 1MPLK3 4-11 Data Tables TABLE 4-14. MAIN TERMINAL BOX System Voltage Ampere Rating 120/240 Vac 1-Phase, 3-Wire 120/208 Vac 3-Phase, 4-Wire Catalog Number UPC Code Catalog Number UPC Code (1) #6 – 600 or (2) 1/0 – 250 kcmil (2) 250 – 500 kcmil (4) 250 – 500 kcmil (4) 250 – 500 kcmil (6) 500 kcmil — — 786849053055 786849053062 782114733677 3MTB400R 3MTB600R 3MTB800R 3MTB1200R 3MTB1600RC 786849053086 786849053093 786849053109 782116007899 782114733684 (1) #6 – 600 or (2) 1/0 – 250 kcmil (2) 250 – 500 kcmil (4) 250 – 500 kcmil (4) 250 – 500 kcmil (6) 500 kcmil — — 782114990384 782114990377 782114733677 3MTB400RC 3MTB600RC 3MTB800RC 3MTB1200RC 3MTB1600RC 782114556139 782114556146 782114556153 782114632178 782114733684 Line Side Lug and Wire Sizes — Included Aluminum Bus 400 600 800 1200 1600 1MTB800R 1MTB1200R 1MTB1600RC Copper Bus Metering 4-12 400 600 800 1200 1600 1MTB800RC 1MTB1200RC 1MTB1600RC 120 ampere main devices must be center fed when installing 800 ampere residential meter stacks. 1600 ampere main devices must be center fed when installing 800 – 1200 ampere residential and commercial meter stacks. For compression lug landing kits for 600 ampere units, order 3MTB600CLK. Kit includes lug landings for 3-phases and neutral. For 800 ampere units, to obtain (4) 1/0 – 300 kcmil or (2) 1/0 – 750 kcmil cables per phase — order catalog number 3MTB800BLK, one lug kit per main terminal box ordered. For 1200 ampere units, to obtain (6) 1/0 – 300 kcmil or (3) 750 kcmil cables per phase — order catalog number 3MTB1200BLK, one lug kit per main terminal box ordered. For 800 ampere and 1200 ampere units, for compression lug landing kits, order 3MTB1200CLK. Kit includes lug landings for 3-phases and neutral. For 1600 ampere units, to obtain (4) 750 kcmil cables per phase — order catalog number 3MTB1600BLK, one lug kit per main terminal box ordered. For a 1600 ampere compression lug landing kit, order catalog number 3MTB1600CLK. Use 3-phase. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Data Tables TABLE 4-15. MAIN CIRCUIT BREAKER Main Main Circuit Ampere Breaker Feed Rating Type System Voltage Line Side Lug and Wire Sizes. kAIC Lugs Included with Main Breaker 120/240 Vac 1-Phase, 3-Wire 120/208 Vac 3-Phase, 4-Wire Catalog Number Catalog Number UPC Code UPC Code 250 KD HKD Bottom 65 Bottom 100 (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MCB250R (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MHCB250R 786849000929 3MCB250R 786849000943 3MHCB250R 786849000936 786849000950 300 KD HKD Bottom 65 Bottom 100 (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MCB300R (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MHCB300R 786849000967 3MCB300R 786849000981 3MHCB300R 786849000974 786849000998 350 KD HKD Bottom 65 Bottom 100 (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MCB350R (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MHCB350R 786849020002 3MCB350R 786849020026 3MHCB350R 786849020019 786849020033 400 KD HKD Bottom 65 Bottom 100 (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MCB400R (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MHCB400R 786849053192 3MCB400R 782116008063 3MHCB400R 786849053246 782116008247 500 LD HLD Bottom 65 Bottom 100 (2) 400 – 500 kcmil (2) 400 – 500 kcmil 1MCB500R 1MHCB500R 786849020040 3MCB500R 786849020064 3MHCB500R 786849020057 786849020071 600 LD HLD Bottom 65 Bottom 100 (2) 400 – 500 kcmil (2) 400 – 500 kcmil 1MCB600R 1MHCB600R 786849053208 3MCB600R 782116008070 3MHCB600R 786849053253 782116008254 700 MDL HMDL Bottom 65 Bottom 100 (3) 3/0 – 400 kcmil (3) 3/0 – 400 kcmil 1MCB700R 1MHCB700R 786849020088 3MCB700R 786849020101 3MHCB700R 786849020095 786849020118 800 MDL HMDL Bottom 65 Bottom 100 (3) 3/0 – 400 kcmil (3) 3/0 – 400 kcmil 1MCB800R 1MHCB800R 786849053215 3MCB800R 782116008087 3MHCB800R 786849053260 782116008261 900 ND HND Bottom 65 Bottom 100 (4) 4/0 – 500 kcmil (4) 4/0 – 500 kcmil 1MCB900R 1MHCB900R 786849020125 3MCB900R 786849020149 3MHCB900R 786849020132 786849020156 1000 ND HND Bottom 65 Bottom 100 (4) 4/0 – 500 kcmil (4) 4/0 – 500 kcmil 1MCB1000R 786849083229 3MCB1000R 782116008278 1MHCB1000R 782116008094 3MHCB1000R 782116008285 1200 ND HND Bottom 65 Bottom 100 (4) 4/0 – 500 kcmil (4) 4/0 – 500 kcmil 1MCB1200R 786849053239 3MCB1200R 782116008292 1MHCB1200R 782116008100 3MHCB1200R 782116008308 1400 RD RD Bottom 100 Top 100 (4) 500 – 1000 kcmil (4) 500 – 1000 kcmil 1MCB1400RBC 782114989630 3MCB1400RBC 782114990445 1MCB1400RT 782116006298 3MCB1400RT 782116008421 1600 RD RD Bottom 100 Top 100 (4) 500 – 1000 kcmil (4) 500 – 1000 kcmil 1MCB1600RBC 782114989647 3MCB1600RBC 782114890929 782116006250 3MCB1600RT 782116008445 1MCB1600RT 2000 RD RD Bottom 100 Top 100 (6) #2 – 600 kcmil (6) #2 – 600 kcmil 1MCB2000RBC 782114989784 3MCB2000RBC 782114990452 782116006274 3MCB2000RT 782116008469 1MCB2000RT 400 400 KD HKD Bottom 65 Bottom 100 (2) 3/0 – 250 kcmil or (1) 2/0-500 kcmil 2/0–500 kcmil 1MCB400RC 1MHCB400RC 782114989678 3MCB400RC 782114838815 3MHCB400RC 782114990469 782114838860 600 600 LD HLD Bottom 65 Bottom 100 (2) 300 – 500 kcmil (2) 300 – 500 kcmil 1MCB600RC 1MHCB600RC 782114989685 3MCB600RC 782114838822 3MHCB600RC 782114990483 782114838877 800 800 MDL HMDL Bottom 65 Bottom 100 (3) 3/0 – 400 kcmil (3) 3/0 – 400 kcmil 1MCB800RC 1MHCB800RC 782114989692 3MCB800RC 782114838839 3MHCB800RC 782114990506 782114838884 1000 1000 ND ND Bottom 65 Bottom 100 (4) 4/0 – 500 kcmil (4) 4/0 – 500 kcmil 1MCB1000RC 782114989616 3MCB1000RC 782114990421 1MHCB1000RC 782114838846 3MHCB1000RC 782114838891 1200 1200 ND HND Bottom 65 Bottom 100 (4) 4/0 – 500 kcmil (4) 4/0 – 500 kcmil 1MCB1200RC 782114989623 3MCB1200RC 782114990438 1MHCB1200RC 782114838853 3MHCB1200RC 782114838907 Metering Aluminum Bus Copper Bus If additional neutral lugs are needed, order 1MCB1200NLK [(3) 1/0 – 750 kcmil or (6) 1/0 – 300 kcmil]. Add CL to end of catalog number for compression lug pads (includes lug pads for lines and neutral). If (3) 500 – 750 kcmil are needed, order TA1201NB1. Order one kit per pole. Main devices with a rating greater than 800 ampere can be used with 800 ampere residential modular stacks but only as a center fed main. If (6) #2 – 600 kcmil lugs are needed, order TA2000RD. Catalog number includes terminals and hardware for 3 poles. If neutral is needed, order TA2000N. Copper bus. Main devices with a rating greater than 1200 amperes can be used with residential and commercial modular metering stacks but only as a center fed main. Only to be used in center feed applications with 1200 ampere meter stacks. Not to be used with 800 ampere stacks. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-13 Data Tables TABLE 4-16. MAIN CIRCUIT BREAKER — ALUMINUM BUS (EUSERC APPROVED) System Voltage Main Main Circuit Ampere Breaker Feed Rating Type 120/240 Vac Single-Phase, 3-Wire Line Side Lug and Wire Sizes Catalog kAIC Lugs Included with Main Breaker Number UPC Code 120/208 Vac 3-Phase, 4-Wire Catalog Number UPC Code 400 KD HKD Bottom 65 Bottom 100 (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MCBE400R (2) 3/0 – 250 kcmil or (1) 2/0 – 500 kcmil 1MHCBE400R 782116136599 3MCBE400R 782116136674 3MHCBE400R 782116136605 782116136681 600 LD HLD Bottom 65 Bottom 100 (2) 400 – 500 kcmil (2) 400 – 500 kcmil 1MCBE600R 1MHCBE600R 782116136612 3MCBE600R 782116136698 3MHCBE600R 782116136629 782116136704 800 MDL HMDL Bottom 65 Bottom 100 (3) 3/0 – 400 kcmil (3) 3/0 – 400 kcmil 1MCBE800R 1MHCBE800R 782116136636 3MCBE800R 782116136711 3MHCBE800R 782116136643 782116136728 ND HND Bottom 65 Bottom 100 (4) 4/0 – 500 kcmil (4) 4/0 – 500 kcmil 1MCBE1200R 782116136650 3MCBE1200R 782116136667 1MHCBE1200R 782116136735 3MHCBE1200R 782116136742 1200 If additional neutral lugs are needed, order 1MCB1200NLK [(3) 1/0 – 750 kcmil or (6) 1/0 – 300 kcmil]. Metering 4-14 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Data Tables TABLE 4-17. MAIN FUSIBLE SWITCHES Ampere Rating Feed System Voltage Class Fuse Clips 120/240 Vac 1-Phase, 3-Wire (Fuses Not Line Side Box Lugs and Wire Sizes Catalog Number UPC Code Included) (Included with Switch) 120/208 Vac 3-Phase, 4-Wire Catalog Number UPC Code Aluminum Bus 400 Bottom T T Top (2) 1/0 – 300 kcmil or (1) 750 kcmil 1MFS400RB (2) 1/0 – 300 kcmil or (1) 750 kcmil 1MFS400RT 786849053604 3MFS400RB 786849053666 3MFS400RT 786849053635 782116007950 600 Bottom T T Top (2) #2 – 600 kcmil (2) #2 – 600 kcmil 1MFS600RB 1MFS600RT 786849053611 3MFS600RB 786849053673 3MFS600RT 786849053642 782116007967 800 Bottom T T Top (4) 3/0 – 750 kcmil (4) 3/0 – 750 kcmil 1MFS800RB 1MFS800RT 786849053628 3MFS800RB 782116007943 3MFS800RT 786849053659 782116007974 1200 Bottom T (4) #2 – 600 kcmil 1MFS1200RB 782114396100 3MFS1200RB 782114396117 400 Bottom T T Top (2) 1/0 – 300 kcmil or (1) 750 kcmil 1MFS400RBC (2) 1/0 – 300 kcmil or (1) 750 kcmil 1MFS400RTC 782114989739 3MFS400RBC 782114989746 3MFS400RTC 782114990544 782114990551 600 Bottom T T Top (2) #2 – 600 kcmil (2) #2 – 600 kcmil 1MFS600RBC 1MFS600RTC 782114989760 3MFS600RBC 782114989777 3MFS600RTC 782114990575 782114990582 800 Bottom T T Top (4) 3/0 – 750 kcmil (4) 3/0 – 750 kcmil 1MFS800RBC 1MFS800RTC 782114989807 3MFS800RBC 782114989814 3MFS800RTC 782114990605 782114990612 1200 Bottom T (4) #2 – 600 kcmil 1MFS1200RBC 782114989715 3MFS1200RBC 782114990520 Metering Copper Bus If Class H fuse clips are needed, use catalog number WCG3HK400 (order one per phase). If Class R fuse clips are needed, order catalog number DS56FK in addition to WCG3HK400. In order to go from T to R, the device must first be converted to H. All kits are field installable and each DS56FK kit will convert 3 poles. If Class H fuse clips are needed, use catalog number WCG3HK600 (order one per phase). If Class R fuse clips are needed, order catalog number DS66FK in addition to WCG3HK600. In order to go from T to R, the device must first be converted to H. All kits are field installable and each DS66FK kit will convert 3 poles. Class T fuse clips provided are field convertible to Class L by repositioning. No kit is needed. If compression lugs are being used, order 3MFS800CLK. This compression lug kit includes four pads (3 poles and neutral). If compression lugs are being used, order 3MFS800CLKT. This compression lug kit includes four pads (3 poles and neutral). TABLE 4-18. MAIN FUSIBLE SWITCH WITH PULL BOX System Voltage Class Fuse Clips 120/240 Vac 1-Phase, 3-Wire (Fuses Not Line Side Box Lugs and Wire Sizes Catalog Number UPC Code Included) (Included with Switch) Catalog Number UPC Code Bottom Bottom Bottom Bottom T T T T (2) 1/0 – 300 or (1) 750 kcmil (2) #2 – 600 kcmil (4) 3/0 – 750 kcmil (4) #2 – 600 kcmil 1MFS400RUG 1MFS600RUG 1MFS800RUG 1MFS1200RUG 786849053727 786849053734 786849053741 782114396124 3MFS400RUG 3MFS600RUG 3MFS800RUG 3MFS1200RUG 786849053758 786849053765 782116008001 782114396131 Bottom Bottom Bottom Bottom T T T T (2) 1/0 – 300 or (1) 750 kcmil (2) #2 – 600 kcmil (4) 3/0 – 750 kcmil (4) #2 – 600 kcmil 1MFS400RUGC 1MFS600RUGC 1MFS800RUGC 1MFS1200RUGC 782114989753 782114989791 782114989821 782114989722 3MFS400RUGC 3MFS600RUGC 3MFS800RUGC 3MFS1200RUGC 782114990568 782114990599 782114990629 782114990537 Ampere Rating Feed 120/208 Vac 3-Phase, 4-Wire Aluminum Bus 400 600 800 1200 Copper Bus 400 600 800 1200 Class T fuse clips are provided. Class L is not available on MFS with pull box units. Pull box section includes landing studs for line side compression lugs. Wire sizes refer to fusible switch line side connection. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-15 Data Tables TABLE 4-19. PULL BOX System Voltage Ampere Rating Feed Line Side Lug Information Load Side Lug Information for Cable Connection to Main Disconnect 120/240 Vac 1-Phase, 3-Wire 120/208 Vac 3-Phase, 4-Wire Catalog Number Catalog Number UPC Code UPC Code Aluminum Bus 400 800 1200 Bottom Pull box section includes 1/0 – 750 kcmil or (2) 1/0 – 300 kcmil 1UGPB400R Bottom landing studs for line (2) 1/0 – 750 kcmil or (4) 1/0 – 300 kcmil 1UGPB800R Bottom side compression lugs. (4) #2 – 600 kcmil 1UGPB1200R 782116008018 3UGPB400R 782116008025 3UGPB800R 786849053154 3UGPB1200R 782116008032 782116008049 782116008056 Copper Bus 400 800 1200 Bottom Pull box section includes 1/0 – 750 kcmil or (2) 1/0–300 kcmil 1UGPB400RC 782114990407 3UGPB400RC 782114990919 Bottom landing studs for line (2) 1/0 – 750 kcmil or (4) 1/0 – 300 kcmil 1UGPB800RC 782114990414 3UGPB800RC 782114990933 Bottom side compression lugs. (4) #2 – 600 kcmil 1UGPB1200RC 782114990391 3UGPB1200RC 782114990902 Metering TABLE 4-20. MAIN BOLTED PRESSURE CONTACT SWITCHES System Voltage 120/240 Vac 1-Phase, 3-Wire 120/208 Vac 3-Phase, 4-Wire Catalog Number UPC Code Catalog Number UPC Code Feed Class Fuse Clips (Fuses Not Included) Line Side Box Lugs and Wire Sizes (Order Separately) 1200 Bottom Top L L (4) #4 – 600 kcmil (4) #4 – 600 kcmil 1BPS1200RB 1BPS1200RT 782114350836 782114350843 3BPS1200RB 3BPS1200RT 782114350867 782114350874 1600 Bottom Top L L (4) #4 – 600 kcmil (4) #4 – 600 kcmil — — 3BPS1600RB 3BPS1600RT 782114350881 782114350898 2000 Bottom Top L L (6) #4 – 600 kcmil (4) #4 – 600 kcmil — — 3BPS2000RB 3BPS2000RT 782114350904 782114350911 Ampere Rating 1200 ampere lug kit — WCG3BL6012. 2000 ampere lug kit — WCG3BL6020. Use 3-phase. 4-16 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Data Tables RESIDENTIAL METER STACKS TABLE 4-21. 800 AMPERE ALUMINUM BUS Amperes Number Per Meter of Meter Bus Enclosure Socket Sockets Ampacity Type Main Tenant Breaker Type 1-Phase Horizontal Bus (3 Horizontal Bus Bars — A, B, and Neutral) 3-Phase Horizontal Bus (4 Horizontal Bus Bars — A, B, C and Neutral) Catalog Number UPC Code Catalog Number UPC Code 125 200 2 3 4 5 6 800 800 800 800 800 Indoor/Outdoor Indoor/Outdoor Indoor/Outdoor Indoor/Outdoor Indoor/Outdoor Plug-on Type BR_ BRH_ BRHH_ — 1MM312R 1MM412R 1MM512R 1MM612R — 786849051891 786849051907 786849051914 782116007271 3MM212R 3MM312R 3MM412R 3MM512R 3MM612R 786849051969 786849051976 786849051983 786849051990 786849052331 2 3 4 800 800 800 Outdoor Outdoor Outdoor Bolt-on Type CC2_X, CHH2_H2X 1MM320R CHH2_H4X, CHH2_X 1MM420R — 786849051945 786849051952 3MM220R 3MM320R 3MM420R 786849052010 786849052027 786849052034 Ringless Style Meter Socket Covers 125 200 2 3 4 5 6 800 800 800 800 800 Outdoor Outdoor Outdoor Outdoor Outdoor Plug-on Type BR_ BRH_ BRHH_ — 1MM312RRL 1MM412RRL 1MM512RRL 1MM612RRL — 786849052065 786849052072 786849052089 782116007288 3MM212RRL 3MM312RRL 3MM412RRL 3MM512RRL 3MM612RRL 786849052133 786849052140 786849052157 786849052164 786849052171 2 3 4 800 800 800 Outdoor Outdoor Outdoor Bolt-on Type CC2_X, CHH2_H2X 1MM320RRL CHH2_H4X, CHH2_X 1MM420RRL — 786849052119 786849052126 3MM220RRL 3MM320RRL 3MM420RRL 786849052188 786849052195 786849052201 Metering Ring Style Meter Socket Covers Ringless Style Covers with Horn Bypass 125 200 2 3 4 5 6 800 800 800 800 800 Outdoor Outdoor Outdoor Outdoor Outdoor Plug-on Type BR_ BRH_ BRHH_ — 1MM312RRLB 1MM412RRLB 1MM512RRLB 1MM612RRLB — 786849052225 786849052232 786849052249 782116007295 3MM212RRLB 3MM312RRLB 3MM412RRLB 3MM512RRLB 3MM612RRLB 786849052294 786849052300 786849052317 786849052324 786849996468 2 3 4 800 800 800 Outdoor Outdoor Outdoor Bolt-on Type CC2_X, CHH2_H2X 1MM320RRLB CHH2_H4X, CHH2_X 1MM420RRLB — 786849052270 786849052287 3MM220RRLB 3MM320RRLB 3MM420RRLB 786849052348 786849052256 786849052362 For indoor applications where a top endwall with knockouts is needed, order (1) of part number MM12N1WLK for each 125 ampere stack or MM20N1WLK for each 200 ampere stack. 1MM units do not come with 5th jaw. To change in field from ring to ringless — order 1MMRC125. To change in field from ring to ringless, the top socket in 125 ampere, 2- and 3-high stacks use 1MMRC125T. Top socket only — other sockets see . To change in field from ring to ringless — order 1MMRC200. Use 3-phase. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-17 Data Tables RESIDENTIAL METER STACKS TABLE 4-22. 800 AMPERE COPPER BUS Amperes Number Enclosure Per Meter of Meter Bus Socket Sockets Ampacity Type Main Tenant Breaker Type 1-Phase Horizontal Bus (3 Horizontal Bus Bars — A, B and Neutral) 3-Phase Horizontal Bus (4 Horizontal Bus Bars — A, B, C and Neutral) Catalog Number UPC Code Catalog Number UPC Code Ring Style Meter Socket Covers 125 200 2 3 4 5 6 800 800 800 800 800 Outdoor Outdoor Outdoor Outdoor Outdoor Plug-on Type BR_ BRH_ BRHH_ — Metering 3MM212RC 3MM312RC 3MM412RC 3MM512RC 3MM612RC 782114990667 782114990728 782114990780 782114990841 782114990872 2 3 4 800 800 800 Outdoor Outdoor Outdoor Bolt-on Type CC2_X, CHH2_H2X 1MM320RC H4X, CHH2_X 1MM420RC — 3MM220RC 782114989890 3MM320RC 782114989951 3MM420RC 782114990698 782114990759 782114990810 — 782114989883 782114989944 782114990018 782114990049 3MM212RRLC 3MM312RRLC 3MM412RRLC 3MM512RRLC 3MM612RRLC 782114990681 782114990742 782114990803 782114990865 782114990896 1MM312RC 1MM412RC 1MM512RC 1MM612RC — 782114989869 782114989920 782114989982 782114990025 Ringless Style Meter Socket Covers 125 200 2 3 4 5 6 800 800 800 800 800 Outdoor Outdoor Outdoor Outdoor Outdoor Plug-on Type BR_ BRH_ BRHH_ — 2 3 4 800 800 800 Outdoor Outdoor Outdoor Bolt-on Type CC2_X, CHH2_H2X 1MM320RRLC 1MM420RRLC H4X, CHH2_X — 3MM220RRLC 782114989913 3MM320RRLC 782114989975 3MM420RRLC 782114990711 782114990773 782114990834 — 782114989876 782114989937 782114990001 782114990032 3MM212RRLBC 3MM312RRLBC 3MM412RRLBC 3MM512RRLBC 3MM612RRLBC 782114990674 782114990735 782114990797 782114990858 782114990889 — 3MM220RRLBC 782114989906 3MM320RRLBC 782114989968 3MM420RRLBC 782114990704 782114990766 782114990827 1MM312RRLC 1MM412RRLC 1MM512RRLC 1MM612RRLC Ringless Style Covers with Horn Bypass 125 200 2 3 4 5 6 800 800 800 800 800 Outdoor Outdoor Outdoor Outdoor Outdoor Plug-on Type BR_ BRH_ BRHH_ — 2 3 4 800 800 800 Outdoor Outdoor Outdoor Bolt-on Type CC2_X, CHH2_H2X 1MM320RRLBC 1MM420RRLBC H4X, CHH2_X 1MM312RRLBC 1MM412RRLBC 1MM512RRLBC 1MM612RRLBC For indoor applications where a top endwall with knockouts is needed, order (1) of part number MM12N1WLK for each 125 ampere stack or MM20N1WLK for each 200 ampere stack. 1MM units do not come with 5th jaw. To change in field from ring to ringless — order 1MMRC125. To change in field from ring to ringless, the top socket in 125 ampere, 2- and 3-high stacks use 1MMRC125T. Top socket only — other sockets see . To change in field from ring to ringless — order 1MMRC200. Use 3-phase. 4-18 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Data Tables RESIDENTIAL METER STACKS TABLE 4-23. 1200 AMPERE HORIZONTAL BUS — COPPER Amperes Per Meter Socket Number of Meter Sockets Bus Ampacity Enclosure Type Main Tenant Breaker Type 3-Phase Horizontal Bus (4 Horizontal Bus Bars — A, B, C and Neutral) Catalog Number UPC Code Ring Style Meter Socket Covers 125 2 3 4 5 6 1200 1200 1200 1200 1200 Indoor/Outdoor Indoor/Outdoor Indoor/Outdoor Indoor/Outdoor Indoor/Outdoor Plug-on Type BR_ BRH_ BRHH_ — 3MM212R12 3MM312R12 3MM412R12 3MM512R12 3MM612R12 782114733714 782114733721 782114733738 782114733745 782114733752 200 2 3 4 1200 1200 1200 Outdoor Outdoor Outdoor Bolt-on Type CC2_X, CHH2_H2X CHH2_H4X, CHH2_X 3MM220R12 3MM320R12 3MM420R12 782114733769 782114733776 782114733783 125 2 3 4 5 6 1200 1200 1200 1200 1200 Outdoor Outdoor Outdoor Outdoor Outdoor Plug-on Type BR_ BRH_ BRHH_ — 3MM212R12RL 3MM312R12RL 3MM412R12RL 3MM512R12RL 3MM612R12RL 782114786215 782114786222 782114786239 782114786246 782114786253 200 2 3 4 1200 1200 1200 Outdoor Outdoor Outdoor Bolt-on Type CC2_X, CHH2_H2X CHH2_H4X, CHH2_X 3MM220R12RL 3MM320R12RL 3MM420R12RL 782114786260 782114786277 782114786284 Metering Ringless Style Meter Socket Covers (5th Jaw at 9 o’clock Standard — Field Adjustable to 3 or 6 o’clock) Ringless Style Covers with Horn Bypass (5th Jaw at 9 o’clock Standard — Field Adjustable to 3 or 6 o’clock) 125 2 3 4 5 6 1200 1200 1200 1200 1200 Outdoor Outdoor Outdoor Outdoor Outdoor Plug-on Type BR_ BRH_ BRHH_ — 3MM212R12RLB 3MM312R12RLB 3MM412R12RLB 3MM512R12RLB 3MM612R12RLB 782114786291 782114786307 782114786314 782114786321 782114786338 200 2 3 4 1200 1200 1200 Outdoor Outdoor Outdoor Bolt-on Type CC2_X, CHH2_H2X CHH2_H4X, CHH2_X 3MM220R12RLB 3MM320R12RLB 3MM420R12RLB 782114786345 782114786352 782114786369 For indoor applications where a top endwall with knockouts is needed, order (1) of part number MM12N1WLK for each 125 ampere stack or MM20N1WLK for each 200 ampere stack. To change in field from ring to ringless — order 1MMRC125. To change in field from ring to ringless, the top socket in 125 ampere, 2- and 3-high stacks use 1MMRC125T. Top socket only — other sockets see . To change in field from ring to ringless — order 1MMRC200. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-19 35MM, SINGLE-PHASE COMMERCIAL METER STACK MODULES ✓ Each socket is a 5 terminal block with lever bypass ✓ ✓ ✓ ✓ and jaw release. Ringless covers. Provision for 2-pole main tenant breakers (circuit breakers not included). Phase balancing kits are included with three high and four high modules. Each individual socket can be phase balanced in the field to the desired lines (A-B, B-C, or A-C). Comes from factory as A-B. Indoor/outdoor construction. ✓ Main tenant feeders can exit top, bottom, or back. ✓ If being used in outdoor application and exiting the top, mount Myer type hubs on rainproof cap. ✓ Short circuit ratings up to 100 ampere rms symmetrical depending upon the kAIC rating of installed main tenant circuit breakers and main device. ✓ Copper horizontal bus supplied as standard. ✓ Non-EUSERC areas. TABLE 4-24. 35MM — SINGLE-PHASE COMMERCIAL METER STACK MODULES System Voltage Metering 120/240 volt, Single-phase, 3-wire systems and 208Y/120 volt network metering (Not suitable for use on 3-phase, 4-wire Delta systems) Ampere Rating Per Meter Socket Number Number of of Meter Bus Jaws Per Sockets Ampacity Meter Socket 225 1 2 3 4 1200 1200 1200 1200 400 1 400 Main Tenant Breaker Type) Catalog Number UPC Code 5 5 5 5 Bolt-on Type EHD2_ CC2_X CHH2_H2X CHH2_H4X CHH2_X 35MM120R12 35MM220R12 35MM320R12 35MM420R12 786849052959 786849052966 786849052973 786849052980 1200 5 400 Ampere K-Frame Included 35MM140R1240 35MM140HR1240 782114754467 782113935362 2 1200 5 400 Ampere K-Frame Included 35MM240R1240 782116107858 400 Continuous 1 1200 5 400 Ampere L-Frame Included 35MM140R1240K 782116303823 400 Continuous 1 1200 5 400 Ampere L-Frame Included 35MM140HR1240K 782116303830 Add NJ suffix for New Jersey “NJUA” approved units. EHD main tenant breakers require one 37MMCBK kit per breaker. Unit is bottom exit only. Rated at 100 kAIC. Rated at 25 kAIC. Rated at 35 kAIC. 4-20 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 37MM, THREE-PHASE COMMERCIAL METER STACK MODULES ✓ Each socket is a 7 terminal block with lever bypass ✓ ✓ ✓ ✓ and jaw release. Ringless covers. Provision for 3-pole main tenant breakers (circuit breakers not included). Indoor/outdoor construction. Main tenant breakers can exit top, bottom, or back. ✓ If being used in outdoor application and exiting the top, mount Myer type hubs on rainproof cap. ✓ Short circuit ratings up to 100 ampere rms symmetrical depending upon the kAIC rating of installed main tenant circuit breakers and main device. ✓ Copper horizontal bus supplied as standard. ✓ Non-EUSERC areas. System Voltage 208Y/120 volt, 3-phase, 4-wire 240/120 volt, 3-phase, 4-wire Delta (B-Phase is high leg) Number Number of Ampere Rating Main Tenant of Meter Bus Jaws Per Per Meter Socket Sockets Ampacity Meter Socket Breaker Type Catalog Number UPC Code 37MM120R12 37MM220R12 37MM320R12 37MM420R12 37MM140R12 786849052881 786849052898 786849052904 786849052911 786849052928 225 1 2 3 4 1200 1200 1200 1200 7 7 7 7 400 1 1200 7 400 1 1200 7 400 Ampere 37MM140R1240 K-Frame Included 37MM140HR1240 782114754450 782113935379 400 2 1200 7 400 Ampere 37MM240R1240 K-Frame Included 782116107865 400 Continuous 1 1200 7 400 Ampere 37MM140R1240K L-Frame Included 782116303847 400 Continuous 1 1200 7 400 Ampere 37MM140HR1240K 782116303854 L-Frame Included Bolt-on Type EHD3_ CC3_X CHH3_H2X CHH3_H4X CHH3_ Metering TABLE 4-25. 37MM — THREE-PHASE COMMERCIAL METER STACK MODULES If a socket in a 37MM meter stack module needs to be single-phase, order 37MM1CK. This will convert the 3-phase socket to single-phase. EHD main tenant breakers require one 37MMCBK kit per breaker. Add NJ suffix for New Jersey “NJUA” approved units. 320 ampere continuous rated socket with provisions for two main tenant breakers. Unit is bottom exit only. Rated at 100 kAIC. Rated at 25 kAIC. Rated at 35 kAIC. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-21 35SS, SINGLE-PHASE COMMERCIAL METER STACK MODULES ✓ Sockets include EUSERC required test- ✓ Indoor/outdoor construction. ✓ Main tenant breakers can exit top, bottom or back. bypass-disconnect feature. ✓ Ring type covers. ✓ Single-phase units have provisions for 2-pole main tenant breakers. ✓ When applying 35SS (single-phase) stacks on 208Y/120 volt, 3-phase, 4-wire and 240/120 volt, 3-phase, 4-wire delta systems, refer to suffixes for proper phase balancing. Each meter stack module is phase balanced at the plant (A-B, B-C, or A-C) and cannot be field modified. Removable blank plates are supplied for customer punched service cable exits. If being used in outdoor application and exiting the top, mount Myer type hubs on rainproof cap. ✓ Short circuit ratings up to 100A rms symmetrical depending upon the kAIC rating of installed main tenant circuit breakers and main device. ✓ Copper horizontal bus supplied as standard. TABLE 4-26. 35SS — SINGLE-PHASE COMMERCIAL METER STACK MODULES System Voltage Metering 120/240 volt, Single-phase, 3-wire systems and 208Y/120 volt network metering (Not suitable for use on 3-phase, 4-wire Delta systems) Number Ampere Rating of Meter Per Meter Socket Sockets 225 Bus Ampacity Number of Jaws Per Meter Socket 1 1200 5 2 1200 5 3 1200 5 Main Tenant Breaker Type Catalog Number UPC Code Bolt-on Type EHD2_ CC2_X CHH2_H2X CHH2_H4X CHH2_X 35SS120RAB 35SS120RAC 35SS120RBC 786849053000 786849053017 786849053024 35SS220RAB 35SS220RAC 35SS220RBC 782114055045 782114055052 782114055069 35SS320RAB 35SS320RAC 35SS320RBC 782114055076 782114055083 782114055090 EHD main tenant breakers require one 37MMCBK kit per breaker. Last 2 digits of catalog number indicate phase balancing (AB indicates all sockets in this stack are connected to phases A and B only). 37SS, THREE-PHASE COMMERCIAL METER STACK MODULES ✓ Sockets include EUSERC required test- ✓ Three-phase units have provisions for 3-pole bypass-disconnect feature. ✓ Ring type covers. main tenant breaker. ✓ Copper horizontal bus supplied as standard. TABLE 4-27. 37SS — THREE-PHASE COMMERCIAL METER STACK MODULES System Voltage 208Y/120 volt, 3-phase, 4-wire 240/120 volt, 3-phase, 4-wire Delta (B-Phase is high leg) Number Ampere Rating of Meter Per Meter Socket Sockets 225 Bus Ampacity Number of Jaws Per Meter Socket 1 1200 7 2 1200 7 3 1200 7 Main Tenant Breaker Type Catalog Number UPC Code Bolt-on Type EHD3_ CC3_X CHH3_H2X CHH3_H4X CHH3_ 37SS120R 786849052997 37SS220R 782114055106 37SS320R 782114055113 EHD main tenant breakers require one 37MMCBK kit per breaker. 4-22 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Accessories Main Tenant Circuit Breaker Ampere Rating Number of Poles TABLE 4-28. 1MP, 1MM AND 3MM MAIN TENANT CIRCUIT BREAKERS Catalog Number 10 kAIC UPC Code 22 kAIC UPC Code 25 kAIC UPC Code 42 kAIC UPC Code 100 kAIC UPC Code Plug-on type circuit breakers used with 1MP, 1MM and 3MM 125 ampere modular metering stacks. 2 2 2 60 70 80 BR260 BR270 BR280 786676363105 BRH260 786676373753 — 786676363150 BRH270 786676373807 — 786676363174 BRH280 782114372180 — — — — BRHH260 BRHH270 BRHH280 786676382601 — 786676382700 — 786676382809 — — — — 2 2 2 2 90 100 110 125 BR290 BR2100 BR2110 BR2125 786676363204 786676363259 786676384278 786676367059 — — — — BRHH290 BRHH2100 BRHH2110 BRHH2125 786676382908 786676376952 786676002950 786676377003 — — — — BRH290 BRH2100 BRH2110 BRH2125 786676373852 786676373906 786676374248 786676373951 — — — — — — — — 2 2 2 60 70 80 — — — — — — CHH2060H2X 782113032719 CHH2060H4X 782113032634 CHH2060X 782113032559 CHH2070H2X 782113032726 CHH2070H4X 782113032641 CHH2070X 782113032566 CHH2080H2X 782113032733 CHH2080H4X 782113032658 CHH2080X 782113032573 2 2 2 90 100 125 — — — CC2100X 782113031897 — CC2125X 782113031903 — — — — CHH2090H2X 782113032740 CHH2090H4X 782113032665 CHH2090X 782113032580 CHH2100H2X 782113032016 CHH2100H4X 782113032139 CHH2100X 782113032252 CHH2125H2X 782113032023 CHH2125H4X 782113032146 CHH2125X 782113032269 2 2 2 150 175 200 CC2150X 782113031910 — CC2175X 782113031927 — CC2200X 782113031934 — — — — CHH2150H2X 782113032030 CHH2150H4X 782113032153 CHH2150X 782113032276 CHH2175H2X 782113032047 CHH2175H4X 782113032160 CHH2175X 782113032283 CHH2200H2X 782113032092 CHH2200H4X 782113032177 CHH2200X 782113032290 — — — — — — EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 Metering Bolt-on type circuit breakers used with 1MP, 1MM and 3MM 200 ampere modular metering stacks. 4-23 Accessories TABLE 4-29. ACCESSORIES FOR 1MP, 1MM AND 3MM MODULAR METERING STACKS Catalog Number UPC Code Bolted onto neutral in the 3, 6 or 9 o’clock position. Typically used on network metering systems (3-phase in/ single-phase out) or when specified by utility company. 1MM5JK 782114380284 Isolated Fifth Jaw Kit Connects to the neutral with an insolated wire. 1MM5JKOP 782116007882 Manual Bypass Kit (Ring Style Socket Only) For use with 125 ampere sockets only. (Not top socket.) 1MMBPM125 782114380307 For use with 200 ampere sockets only. (Not top socket.) 1MMBPM200 782114380314 Description Application Fifth Jaw Kit This kit only to be used for top position of 2- and 3-high 125 1MMBPM125T 782114380321 ampere 1MM and 3MM stacks and of 2-, 3-, 5- and 6-position 125 ampere 1MP packs. Metering Top 200 ampere socket. 1MMBPM200T 782114631713 Horn Bypass Used only on ringless cover stacks, kits can be installed on 125 ampere or 200 ampere sockets. Note: For 1MP2122RRL use: 1MMBPH WCG8HB 782114380338 782113031828 Meter Bypass Jumper Installed on 125 ampere or 200 ampere sockets. Jumpers 1MMBPJ are plugged into jaws. Order Lexan姞 cover plate with bypass jumpers to prevent access to meter socket once energized. (Not UL listed.) 786849054441 Lexan Blank Cover Circular cover mounted on ring or ringless devices preventing access to meter socket while meter is not in place. Includes 4 plastic tabs which plug into each jaw. 1MMPCP 786849055059 Same as 1MMPCP minus the tabs located in the back to plug 1MMACP into jaws. This device to be used while meter bypass jumpers are in place (1MMBPJ). 782116006373 Used for 125 ampere stacks. Fits bottom socket only. Kit replaces 1MMBC125B existing meter cover preventing access to meter socket. Includes hasp for seal. 786849054427 Used on 200 ampere stacks. Fits bottom socket only. Kit replaces 1MMBC200B existing meter cover preventing access to meter socket. Includes hasp for seal. 786849054434 Rails are 4 feet (1219.2 mm) in length. Bolted on wall for stacks, packs and mains to be hung. 1MMWB 786849054243 Bussed Spacer Bussed spacer 1200 ampere 4-inch (101.6 mm). Required when stacks are mounted on right-hand side in EUSERC areas. (Copper) 3MMBSK 786849054052 Bus Duct Riser/ Available in 400, 600, 800 ampere Main Fusible units only. Contact Product Line for details. Meter Center Connection — — Blank Meter Socket Cover Wall Mounting Rail Manual Bypass Kit Horn Bypass Kit Lexan Blank Cover Wall Mounting Rail Indoor Corner 12-inch (304.8 mm) indoor corner elbow, 1200 ampere, 3MMEB12 Elbow (Copper) 3-phase, 4-wire for use with 1MM and 3MM only. Do not use with 35MM, 37MM, 35SS or 37SS stacks. 786849054038 Indoor Corner 16-inch (406.4 mm) indoor corner elbow, 1200 ampere, Elbow (Copper) 3-phase, 4-wire for use with 1MM, 3MM, 35MM, 37MM, 35SS and 37SS. 3MMEB16 786849054045 Barrier Barrier for individual sockets. 1MMBK 786849054311 Meter Jumper and Cover Combination meter jumper and cover (200 ampere maximum). 1MMJCK Used to jumper line and load jaws as well as cover meter socket preventing exposure to current carrying parts. 786849054366 Lug Block 125 ampere 2-pole lug block assembly. BRSF125 786676001762 Sealing Ring Standard (included with packs and stacks). 1MMSR2 786849054557 Stainless steel screw type. 1MMSR1 786849054540 Stainless steel snap type. 1MMSR4 786849054571 Aluminum screw type with locking provisions. 1MMSR5 786849054588 125 ampere, NEMA 1 top end wall with knockouts for 1MM and 3MM meter stacks. MM12N1WLK 782114794319 200 ampere, NEMA 1 top end wall for 1MM, 3MM meter stacks. MM20N1WLK 782114801253 Top Endwall Fifth Jaw Kit Bussed Spacer Indoor Corner Elbow Standard Sealing Ring Aluminum snap type. 4-24 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Accessories TABLE 4-30. 1MP, 1MM AND 3MM REPLACEMENT PARTS Application Catalog Number UPC Code Ringless Cover (Can install this to go from ring to ringless) Installed on 125 ampere socket for ringless security. 1MMRC125 786849054496 Installed on 200 ampere socket for ringless security. 1MMRC200 786849054502 For use with top position of 125 ampere, 2 and 3 position, 1MM and 3MM stacks and 2, 5 and 6 position 1MP packs. 1MMRC125T 786849054519 Ring Cover Installed on 125 ampere socket for ring security. 1MMCP1 786849054373 Installed on 200 ampere socket for ring security. 1MMCP2 786849054380 Top socket ring cover 125 amperes. 1MMCP1T 782114858943 Top socket ring cover 200 amperes. 1MMCP2T 782114858950 Tenant Breaker Hinged Cover 125 ampere cover. 1MMBC1 786849054298 200 ampere cover. 1MMBC2 786849054304 Meter Socket 125 and 200 amperes. 1MMMS 782116008513 Ringless Cover Ring Cover Meter Packs 1MP2122RRL and 1MP2122RRLB use different meter sockets, see Renewal Parts listing RP.32A.01A.T.E for details. Note: See RP.32A.01A.T.E for a complete Renewal Parts listing. Tenant Breaker Cover Metering Description Meter Socket EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-25 Accessories TABLE 4-31. ACCESSORIES FOR 35MM AND 37MM MODULAR METERING STACKS Description Application Catalog Number UPC Code Wall Mounting Rail Rails are 4 feet (1219.2 mm) in length. Bolted on wall for stacks, packs, and mains to be hung. 1MMWB 786849054243 Indoor Corner Elbow 16-inch (406.4 mm) indoor corner elbow, 1200 ampere, 3MMEB16 (Copper) 3-phase, 4-wire for use with 1MM, 3MM, 35MM, 37MM, 35SS and 37SS. Handle Insulator Each meter block includes a lever bypass. This kit 37MMHC includes the sleeve which slides onto the lever handle. Barrel Lock Bracket Kit Needed when using barrel lock security. 786849054045 786849054212 Metering 37MMBLK 786849054182 Totalizing Jumper Kit Used if one socket is to meter two tenant feeds. When 37MMTJK ordering jumper kit, should also order a plastic cover plate (1MMPCP) preventing access to live parts on unused socket. 786849054267 EHD Breaker Mounting Kit Bolt-on breaker provisions are set up to accept CC/ 37MMCBK CHH breaker styles. If an EHD breaker is needed, each breaker requires one mounting kit. 786849054274 Blank Cover Kit Kit replaces meter cover preventing access to socket. 37MMCK 786849054175 37MMCKA Barrel Lock Bracket Kit Totalizing Jumper Kit EHD Breaker Mounting Kit 782116058051 Barrier Barrier for individual sockets. 37MMBK 786849054199 3-Phase to Single-Phase Conversion Kit This kit will convert one 3-phase meter socket (37MM devices) to a single-phase socket. Only needed if phasing A-C or C-B. If single-phase socket is to be phased A-B, kit is not required for field conversion. (Must use 3-phase breaker.) 37MM1CK 786849054229 — — Catalog Number UPC Code Bus Duct Riser/Meter Available in 400, 600, 800 ampere Main Fusible units Center Connection and 400, 600, 800, 1000, 1200 main circuit breaker. Contact product line for details. Blank Cover Kit 3-Phase to Single-Phase Conversion Kit For all units made 10/2002 and earlier. For all units made after 11/2002. TABLE 4-32. REPLACEMENT PARTS Description Application 35MM Replacement Meter Socket To replace meter socket with lever bypass and jaw release. MSLMSA1 782114633823 37MM Replacement Meter Socket To replace meter socket with lever bypass and jaw release. MSLMSA2 782114633830 35SS Replacement Meter Socket To replace meter socket with test bypass disconnect feature. MSTMSA1 782114633915 37SS Replacement Meter Socket To replace meter socket with test bypass disconnect feature. MSTMSA2 782114633922 Meter Cover Assembly To replace ringless cover over the meter. MSTMCVR1 782114633557 Meter Cover Assembly with NJ Latch To replace ringless cover over the meter. Includes New Jersey latch requirement. 37MMSKNJ 786849054250 Tenant Breaker Hinged Cover To replace cover over tenant breakers. 1MMBC2 786849054304 35MM Replacement Meter Socket 35SS Replacement Meter Socket Note: See RP.32A.01.T.E for a complete Renewal Parts listing. Related Products ✓ Main Circuit Breakers. Meter Cover Assembly 4-26 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Group Metering MAIN SERVICE MODULES — DIMENSIONS IN INCHES (MM) C A A E B B F F 17.00 (431.8) Bottom Feed Switch and Combination Switch/Pullbox D C D Main CB, Terminal Box and Pullboxes FIGURE 4-2. MAIN CIRCUIT BREAKERS, TERMINAL BOXES AND PULL BOXES C A E FIGURE 4-4. BOTTOM FEED FUSIBLE SWITCH AND COMBINATION FUSIBLE SWITCH WITH PULL BOX A B E C Metering E B F F 17.00 (431.8) Top Feed Switch (No Knockouts) D FIGURE 4-3. TOP FEED FUSIBLE SWITCH D 25.00 (635.0) FIGURE 4-5. BOLTED PRESSURE SWITCH EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-27 MAIN SERVICE MODULES — DIMENSIONS IN INCHES (MM) .625 ±.010 .080 ±.020 2-1/2”, 3”, 3-1/2”, 4” KO 1 Knockout Required .310 ±.030 Diameter 2.500 Paint Hole ±.020 1/2”Knockout 1 Required Per 50-1827-1 2.880 ±.030 3.010 ±.010 KO (1) 6.500 Outside ±.010 2.880 ±.010 .800 ±.030 6.000 ±.020 5.000 ±.020 .080 ±.020 3.250 ±.020 .150 ±.020 Typ. 6.120 ±.020 3.500 ±.010 Stamped ID Mark 6.850 ±.020 KO (10) KO (10) KO (44) 5.375 ±.010 .150 ±.020 Typ. 7.000 +.000 -.030 3.000 ±.020 CL .875 ±.020 12.375 ±.010 .438 ±.010 .175 ±.010 +.003 .169 -.000 Diameter 5 Hole FIGURE 4-6. KNOCKOUT 1 3.75 Metering 4.250 .150 ±.020 ±.020 Typ. .45 .61 10.38 1.93 FIGURE 4-10. KNOCKOUT 5 2.50 .220 Dia. .250 Paint Ref. Hole 3.25 1.75 2.50 2 Knockouts for 1/2”, 3/4” or 1” Conduit .16 10.120 ±.020 4.000 ±.020 8.00 A .200 ±.020 Typ. .780 ±.020 Typ. 4 Knockouts for 2-1/2”, 3”, 3-1/2” or 4” Conduit 19.40 11.000 +.000 -.030 10.850 ±.020 KO (10) .281 Diameter Knockout 1 Required 8.00 4.00 .150 ±.020 Typ. KO (10) KO (10) 4.25 11.19 6.000 ±.020 6.000 ±.020 6.000 ±.020 .250 Ref. 22.54 11.62 .200 ±.020 Typ. .780 ±.020 Typ. FIGURE 4-11. KNOCKOUT 6 FIGURE 4-7. KNOCKOUT 2 4.000 ±.020 .380 ±.020 2.125 ±.020 3/4”, 1”, 1-1/4”, 1-1/2” Knockout Per A50-26319 1 Knockout Required 6.000 ±.010 6.000 ±.010 32.120 ±.020 6.000 ±.010 .150 ±.020 Typ. .350 Ref. 6.000 ±.010 1.440 ±.020 6.000 ±.010 2.125 ±.020 2.750 7.500 ±.010 ±.020 2.750 ±.010 .220 Dia. Paint Hole 7.250 ±.020 7.250 ±.020 7.250 ±.020 .150 ±.020 Typ. .350 Ref. KO (11) KO (11) KO (11) .130 ±.030 6.000 ±.010 6.000 ±.010 3”, 3-1/2”, 4”, 5” Knockout Per A50-26327 5 Knockouts Required 6.000 ±.010 6.000 ±.010 .169 ±.002 Diameter 5 Holes Required at ”X” .125 ±.030 10.140 ±.020 10.850 ±.020 KO (11) 11.000 +.000 -.030 4.000 ±.020 2.750 ±.010 1.500 ±.020 4.250 ±.020 5.125 ±.020 .685 ±.020 Typ. .120 ±.020 Typ. FIGURE 4-12. KNOCKOUT 7 4.440 ±.020 FIGURE 4-8. KNOCKOUT 3 22.54 11.62 3.75 1.93 .45 .61 10.38 2.50 3.25 1.75 2.50 4.25 11.19 2 Knockouts for 1/2”, 3/4” or 1” Conduit .16 8.00 4.00 8.00 19.40 .281 Diameter Knockout 1 Required 4 Knockouts for 2-1/2”, 3”, 3-1/2” or 4” Conduit B FIGURE 4-9. KNOCKOUT 4 4-28 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 MAIN FUSIBLE SWITCHES — DIMENSIONS IN INCHES (MM) A C B D 7.00 — 13.50 48.75 (342.9) (1238.3) (177.8) E Knockouts in Bottom Endwalls Except No KOs for Top Feed Switch or Bolted Pressure Switch Conduit Diameter F Inches mm (1) 2.50, 3.00, 3.50, 4.00 (1) .50 (1) 63.5, 76.2, 88.9, 101.6 (1) 12.7 1 2 30.63 54.00 (1371.6) (777.9) 800 and 1200 Ampere 30.63 11.75 12.00 51.50 20.00 47.63 (508.0) (1209.8) (298.5) (304.8) (1308.1) (777.9) (2) .50, .75, 1.00 (4) 2.00, 2.50, 3.00, 3.50, 4.00 (2) 12.1, 19.1, 25.4 (4) 50.8, 63.5, 76.2, 88.9, 101.6 1600 Ampere 31.63 11.75 16.00 56.25 32.88 52.13 (835.2) (1324.1) (298.5) (406.4) (1428.8) (803.4) (1) .75, 1.00, 1.25, 1.50 (5) 3.00, 3.50, 4.00, 5.00 (1) 19.1, 25.4, 31.8, 38.1 3 (5) 76.2, 88.9, 101.6, 127.0 Main Circuit Breaker with Box Lugs 400 – 1200 Ampere 11.75 12.00 51.50 30.63 20.00 47.63 (508.0) (1209.8) (298.5) (304.8) (1308.1) (777.9) (2) .50, .75, 1.00 (4) 2.00, 2.50, 3.00, 3.50, 4.00 (2) 12.7, 19.1, 25.4 (4) 50.8, 63.5, 76.2, 88.9, 101.6 2 Main Circuit Breaker with Box Lugs 1400 – 2000 Ampere 14.88 16.00 57.13 44.00 24.88 57.13 (632.0) (1451.0) (378.0) (406.4) (1451.0) (1117.6) — — — Main Circuit Breaker 11.75 12.00 65.00 44.00 20.00 61.00 with Compression Lugs (508.0) (1549.4) (298.5) (304.8) (1651.0) (1117.6) 400 – 1200 Ampere (2) .50, .75, 1.00 (4) 2.00, 2.50, 3.00, 3.50, 4.00 (2) 12.7, 19.1, 25.4 (4) 50.8, 63.5, 76.2, 88.9, 101.60 2 Main Fusible Switch — Bottom Feed 20.00 47.63 11.75 12.00 51.50 30.63 (508.0) (1209.8) (298.5) (304.8) (1308.1) (777.9) (2) .50, .75, 1.00 (2) 12.7, 19.1, 25.4 (4) 2.00, 2.50, 3.00, 3.50, 4.00 (4) 50.8, 63.5, 76.2, 88.9, 101.6 2 Main Fusible Switch — Top Feed 20.00 47.63 11.75 12.00 51.50 18.13 (508.0) (1209.8) (298.5) (304.8) (1308.1) (460.4) (2) .50, .75, 1.00 (2) 12.7, 19.1, 25.4 (4) 2.00, 2.50, 3.00, 3.50, 4.00 (4) 50.8, 63.5, 76.2, 88.9, 101.6 2 Main Fusible Switch — 1200 Ampere 33.50 52.75 11.88 16.00 56.25 30.75 (850.9) (1339.9) (301.8) (406.4) (1428.8) (781.1) (5) 3.50, 4.00, 5.00 (1) .75, 1.00, 1.25, 1.50 (5) 88.9, 101.6, 127.0 4 (1) 19.1, 25.4, 31.8, 38.1 Bolted Pressure Switch 36.50 66.50 19.50 28.00 60.00 30.63 (927.1) (1689.1) (495.3) (711.2) (1524.0) (777.9) — — — 44.00 20.00 61.00 11.75 12.00 65.00 (508.0) (1549.4) (298.5) (304.8) (1651.0) (1117.6) (2) .50, .75, 1.00 (4) 2.00, 2.50, 3.00, 3.50, 4.00 (2) 12.7, 19.1, 25.4 (4) 50.8, 63.5, 76.2, 88.9, 101.6 2 600 and 800 Ampere (Single-Phase) 44.00 20.00 61.00 11.75 12.00 65.00 (508.0) (1549.4) (298.5) (304.8) (1651.0) (1117.6) (2) .50, .75, 1.00 (4) 2.00, 2.50, 3.00, 3.50, 4.00 (2) 12.7, 19.1, 25.4 (4) 50.8, 63.5, 76.2, 88.9, 101.6 2 600 and 800 Ampere (3-Phase) 44.00 25.00 61.00 11.75 12.00 65.00 (635.0) (1549.4) (298.5) (304.8) (1651.0) (1117.6) (2) .50, .75, 1.00 (4) 2.00, 2.50, 3.00, 3.50, 4.00 (2) 12.7, 19.1, 25.4 (4) 50.8, 63.5, 76.2, 88.9, 101.6 5 48.00 33.50 61.50 11.88 16.00 65.25 (850.9) (1562.1) (301.8) (406.4) (1657.4) (1219.2) (5) 3.50, 4.00, 5.00 (1) .75, 1.00, 1.25, 1.50 (5) 88.9, 101.6, 127.0 4 (1) 19.1, 25.4, 31.8, 38.1 Main Fusible Switch with Pull Box 400 Ampere 1200 Ampere EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 Metering Terminal Box 400 and 600 Ampere Depth Mounting Center Line of Wall Mounting Bracket Main Device Width Height Knockout Drawing TABLE 4-33. APPROXIMATE DIMENSIONS (NOT TO BE USED FOR CONSTRUCTION PURPOSES) 4-29 MAIN FUSIBLE SWITCHES — DIMENSIONS IN INCHES (MM) Center Line of Wall Mounting Bracket Knockouts in Bottom Endwalls Except No KOs for Top Feed Switch or Bolted Pressure Switch Conduit Diameter F Inches mm Knockout Drawing Table 4-33. APPROXIMATE DIMENSIONS (NOT TO BE USED FOR CONSTRUCTION PURPOSES) — CONTINUED 39.75 20.01 60.44 11.14 12.00 65.11 (508.2) (1535.2) (283.0) (304.8) (1653.8) (1009.6) (4) 2.50, 3.00, 3.50, 4.00 (4) 63.5, 76.2, 88.9, 101.6 2 39.81 24.88 60.94 11.14 17.00 64.88 (632.0) (1547.9) (283.0) (431.8) (1648.0) (1011.2) (4) 2.50, 3.00, 3.50, 4.00 (4) 63.5, 76.2, 88.9, 101.6 2 33.00 61.14 11.32 16.00 (838.2) (1553.0) (287.5) (46.4) (4) 2.50, 3.00, 3.50, 4.00 (4) 63.5, 76.2, 88.9, 101.6 4 28.63 16.38 44.88 8.00 45.75 7.88 (416.1) (1140.0) (200.2) (203.2) (1162.1) (727.2) (2) 4.00 101.6 6 800 Ampere 32.25 24.38 46.88 11.88 12.00 47.75 (619.3) (1190.8) (301.8) (304.8) (1212.9) (819.2) (3) 4.00 101.6 7 1200 Ampere 42.25 32.50 56.88 12.00 17.75 57.75 (825.5) (1444.8) (304.8) (450.9) (1466.9) (1073.2) (4) 5.00 127.0 8 EUSERC Bussed Pull Section 400 and 800 Ampere (Single-Phase) 11.25 12.00 64.88 44.00 20.13 61 (511.3) (1549.4) (285.8) (304.8) (1648.0) (1117.6) (4) 2.50, 3.00, 3.50, 4.00 (4) 63.5, 76.2, 88.9, 101.6 5 400 and 800 Ampere (3-Phase) 11.88 17.0 64.88 44.00 25.13 61 (638.3) (1549.4) (301.8) (431.8) (1648.0) (1117.6) (4) 2.50, 3.00, 3.50, 4.00 (4) 63.5, 76.2, 88.9, 101.6 6 Main Device Main Circuit Breaker with Pull Box 400 Ampere 800 Ampere 1200 Ampere Metering 4-30 Pull Box 400 Ampere Width Height Depth Mounting A C B D E 43.56 65.25 (1657.4) (1106.4) EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Residential Meter Stacks DIMENSIONS AND KNOCKOUTS (IN INCHES) — MODULAR METERING STACKS — ALUMINUM AND COPPER Note: Dimensions Apply to 800 and 1200 Ampere Horizontal Bus. .125 12.130 2.830 2.830 2.330 2.830 "Z" = CL OF 1-1/2" RING "Y" = C L OF 1-1/4" RING "X" = CL OF 3/4" & 1" RING 2.830 6.065 TANGENTIAL K.O.'S 3/4, 1, 1-1/4, 1-1/2 Metering 2.830 6.625 "X" "Z" 2.830 "Y" TOP END & BOTTOM END VIEW FOR NEMA 1; BOTTOM END VIEW FOR NEMA 3R FIGURE 4-13. 1MM, 3MM, 125 AMPERES EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-31 DIMENSIONS AND KNOCKOUTS (IN INCHES) — MODULAR METERING STACKS — ALUMINUM AND COPPER Note: Dimensions Apply to 800 and 1200 Ampere Horizontal Bus. 13.380 .125 3.210 6.620 "X" "W" 1.320 "Y" 3.210 1.790 "Z" 3.210 TANGENTIAL K.O.'S 1, 1-1/4, 1-1/2, 2 Metering "Z" = CL OF 1" RING "Y" = C L OF 1-1/4" RING "X" = CL OF 1-1/2" RING "W" = CL OF 2" RING TOP END & BOTTOM END VIEW FOR NEMA 1; BOTTOM END VIEW FOR NEMA 3R FIGURE 4-14. 1MM, 3MM, 125 AMPERES 4-32 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 COMMERCIAL STACKS (35MM, 37MM, 35SS AND 37SS) — DIMENSIONS IN INCHES (MM) 35MM140R1240 37MM140R1240 same as below except eliminate top socket. 14.00 (355.6) Typ. 25.38 (644.5) 52.63 (1336.7) 66.63 (1692.3) 8.75 (222.3) 8.75 (222.3) 18.25 (463.6) 18.25 (463.6) 8.75 (222.3) 8.75 (222.3) (489.0) (463.6) Metering 52.63 (1336.7) FIGURE 4-15. 35MM AND 37MM 21.38 (542.9) 12.00 (304.8) 21.38 (542.9) 12.00 (304.8) 29.38 (746.1) 21.38 (542.9) 12.00 (304.8) 9.50 (241.3) 13.50 (342.9) 19.50 (495.3) 17.75 (450.9) Centerline 19.50 (495.3) of Wall Mounting Screws 62.44 (1585.9) 6.50 (165.1) 6.50 (165.1) 6.50 (165.1) 25.00 (635.0) 9.56 (242.9) 0.41 Dia. 9.56 (10.3) (242.9) 4-Holes 68.88 (1749.4) 2.00 (50.8), 2.50 (63.5) 43.00 (1092.2) KO 1.50 (38.1) 19.50 (495.3) 31.50 (800.1) 47.38 (1203.3) 31.50 (800.1) Wire Seal Slot and Sealing Screw Ribbon Seal or Barrel Lock Hasp 8.75 Bottom (Typ.) 13.56 (222.3) (344.5) Inside 3 KOs 1.50 (38.1), 2.00 (50.8), 2.50 (63.5) FIGURE 4-16. 35SS AND 37SS EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-33 GENERAL LAYOUT — DIMENSIONS IN INCHES (MM) Minimum and maximum height of Single-phase and 3-phase meter sockets above typical ground level. 1MM/3MM 200 A 1MM/3MM 125 A 35MM/37MM 225 A Maximum 35MM/37MM 225 A Maximum 35MM/37MM 225 A Maximum 37MM 400 A 35MM/37MM 13.50 (342.9) 12.25 (311.2) 19.25 (488.8) 18.25 (463.6) 18.25 (463.6) 18.25 (463.6) 18.25 (463.6) 30.00 (762.0) 44.00 (1117.6) Wall Hanger Screws C L Metering 34.25 (870.0) Main Device  Typical Height Above Ground or Floor Level 13.38 (339.7) 31.88 (809.6) 26.00 (660.4) 68.25 (1733.6) 30.00 (762.0) 71.00 (1803.4) 72.00 (1828.8) 58.00 (1473.2) 44.00 (1117.6) 44.00 (1117.6) 58.00 (1473.2) 31.00 (787.4) FIGURE 4-17. GENERAL LAYOUT Not a constant value. Dimension changes depending on main device chosen. See Pages 4-29 and 4-30 for specific dimensions. MOUNTING FEATURES APPLICATION DESCRIPTION When main tenant breakers are installed in Eaton’s Cutler-Hammer modular metering stack per Table 4-34, the branch breakers installed in Cutler-Hammer downstream panel rated 10,000 AIC or greater are protected to the listed series AIC rating. Refer to the downstream panel marking for the proper series combination short circuit ratings. Replacement or additional breakers shall be of the same manufacture and type and shall have an interrupting rating equal to or greater than the interrupting rating of any main tenant breaker installed. Mounting Features The Watt-Hour Meter is not Included in the Short Circuit Current Rating (Per UL 67). Downstream Panel (Type CH or BR) A standard mounting rail and factory-installed swing away feet, speed up and simplify installation. Main Tenant Breaker Main Modular Service Metering Module Stack Load Side Breakers FIGURE 4-18. SERIES COMBINATION SHORT CIRCUIT RATINGS UL is a federally registered trademark of Underwriters Laboratories Inc. Cutler-Hammer is a federally registered trademark of Eaton Corporation. NEMA is the registered trademark and service mark of the National Electrical Manufacturers Association. Lexan is a registered trademark of General Electric Co., USA. INNER-TITE is a registered trademark of Inner-Tite Corp. 4-34 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 None None — BD, BR, BRD, BQ, BQC, GFCB, CH, CHT, CH3, CH-GFCI 10,000 Without Main Disconnect. BR_, CC_, BW_ Cable Tap Box BRH_ Type 1MTB_, 3MTB_ BWH_, CHH_H2 10,000 10,000 22,000 22,000 25,000 25,000 BRHH_, CHH_H4 42,000 42,000 CHH 100,000 100,000 Main Switch Module Type 1MFS_, 3MFS_ with Class T Fuse, 400 Ampere Maximum BRH 22,000 CH, CHT, CH3, CH-GFCI Main Switch Module Type 1MFS_, 3MFS_ with Class T Fuse, 600 Ampere Maximum BRH_ 22,000 BD, BR, BRD, BQ, BQC, GFCB BRHH 42,000 CH, CHT, CH3, CH-GFCI 42,000 Main Switch Module Type 1MFS_, 3MFS_ with Class T Fuse, 800 Ampere Maximum BR_, CC_, BW_ 10,000 BD, BR, BRD, BQ, BQC, GFCB, CH, CHT, CH3, CH-GFCI 10,000 BRH_ 22,000 BRH_ 22,000 BD, BR, BRD, BQ, BQC, GFCB BWH_, CHH_H2 25,000 BD, BR, BRD, BQ, BQC, GFCB, CH, CHT, CH3, CH-GFCI BRHH_, CHH_H4 42,000 BRHH_, CHH_H4 42,000 42,000 100,000 22,000 100,000 25,000 42,000 BD, BR, BRD, BQ, BQC, GFCB 100,000 CHH_ 100,000 BD, BR, BRD, BQ, BQC, GFCB, CH, CHT, CH3, CH-GFCI 100,000 Main Switch Module Type 1MFS_, 3MFS_ with Class T Fuse, 1200 Ampere Maximum BRHH 42,000 BD, BR, BRD, BQ, BQC, GFCB, CH, CHT, CH3, CH-GFCI 100,000 Main Switch Module Type 1BPS_, 3BPS_ with Class L Fuse, 1200 – 1600 Amperes BR_, CC_, BW_ 10,000 BD, BR, BRD, BQ, BQC, GFCB, CH, CHT, CH3, CH-GFCI BRH_ 22,000 22,000 BWH_, CHH_H2 25,000 25,000 BRHH_, CHH_H4 42,000 42,000 100,000 100,000 CHH_ BD, BR, BRD, BQ, BQC, GFCB, CH, CHT, CH3, CH-GFCI 10,000 Main Breaker Module Type 1MCB_, 3MCB_ with LC, LD, LSE (600 Ampere Maximum) MC, MA, MDL (800 Ampere Maximum) BR_, CC_, BW_ 10,000 BRH_ 22,000 22,000 BWH_, CHH_H2 25,000 25,000 BRHH_, CHH_H4 42,000 42,000 Main Breaker Module Type 1MCB_, 3MCB_ with ND 1200 Ampere Maximum CHH_ 100,000 BD, BR, BRD, BQ, BQC, GFCB, CH, CHT, CH3, CH-GFCI 100,000 BRHH_ 42,000 BD, BR, BRD, BQ, BQC, GFCB 65,000 Main Breaker Module Type 1MCB_, 3MCB_ with LHE, HLD, LDC (600 Ampere Maximum) HMDL (800 Ampere Maximum) NBY, HND, NDC (1200 Ampere Maximum) BR_, CC_, BW_ 10,000 BD, BR, BRD, BQ, BQC, GFCB, CH, CHT, CH3, CH-GFCI 10,000 BRH_ 22,000 22,000 BWH_, CHH_H2 25,000 25,000 BWH_, CHH_H4 42,000 42,000 100,000 100,000 CHH_ Metering Main Module Overcurrent Device Breaker Type or Class Fuse Meter Module Tenant Feeder Breaker Type 1MM, 3MM, Tenant Feeder 35MM, 37MM, 35SS, Breaker Short Loadcenter Branch Breaker 37SS or Loadcenter Circuit Rating (1-, 2- or 3-Pole) Main Breaker System AIC Rating 120/240 Vac Maximum TABLE 4-34. SERIES COMBINATION SHORT CIRCUIT RATINGS — 240 VAC 10,000 100,000 with Class T fuse, 600 ampere maximum. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — ©Copyright 2005 4-35 Metering 4-36 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Metering — Effective August 2005 Product Description Eaton’s Cutler-Hammer姞 Power Outlet Panel (POP) is a device designed for outdoor service to meet temporary power requirements at construction sites and recreational vehicle parks. Construction sites and RV parks need to provide a safe and reliable means for users to access electricity. POPs provide the outlets for electrical access. Features, Functions and Benefits Surface Mount Un-metered, Metered Ring Style, Metered Ringless, Metered Ring Style Bottom Fed . . . . Metered Ringless Bottom Fed . . . . . . . . . . . Pedestal Mount — Un-metered, Metered Ring Style, Metered Ringless. . . . . . . . Back-to-Back Pedestal Mount — Un-metered, Metered Ring Style and Metered Ringless. . . . . Mobile Home Pedestals — Ring and Ringless . . . . Power Outlet Panel Accessories . . . . . . . . . . . . Power Outlet Panel Dimensions . . . . . . . . . . . . . ✓ 5-6 5-7 5-7 5-8 5-8 5-9 5-11 ✓ ✓ ✓ ✓ ✓ ✓ ✓ UL姞 231 and ready to install. Available in three mounting styles: surface, pedestal and back-to-back. Available in three metering styles: unmetered, metered ring type and metered ringless type. Padlockable doors with or without plugs connected, preventing power theft, vandalism or unauthorized breaker operation. Exclusive time-saving design features: Removable upper deadfront cover, providing easy connection of incoming wire to the lugs; lower deadfront cover rotates 90 degrees for easy routing of incoming wire. Rugged, heavy-duty 100% galvanized-steel enclosure with special coating that provides extra durability and longer life. Door swings open and stays open for easy interior access and convenience during installation. Suitable for service entrance applications. Variety of accessories available. Cutler-Hammer Quick-Pro SM All you need to know to save time and make more money. Specified on certain Cutler-Hammer products, the Quick-Pro symbol allows for immediate recognition of products that are designed for straightforward installation. When you see Quick-Pro, you know you can install quickly — sometimes up to 50% less than the usual installation time — and move onto your next job. Power Outlet Panels ✓ Unit arrives assembled, prewired, factory tested to Power Outlet Panels EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — ©Copyright 2005 5-1 SURFACE UNITS NEMA姞 3R construction for rainproof installation. 100 percent galvanized steel with baked-on polyester powder coating. Utility grade metering available for construction site RV park applications. Three-point mounting. Removable upper deadfront cover for easy incoming wire connections to breaker terminals. One-piece case back for metered and unmetered panels. Lighted option for site location and nighttime panel operations. GFI circuit breakers available through 50 amperes. Unique steel barrier prevents unauthorized operation of breakers when door is closed and padlocked. Metered units available (with meter on top or bottom). PEDESTAL UNITS Door swings up and pushes in to lock into open position. Pull out and push down to close door. Lower deadfront cover rotates 90 degrees or can be removed for easy routing of incoming wires or receptacle changeouts. Padlock provisions to prevent unauthorized entry. Units are factory wired and assembled. NEMA 3R construction for rainproof installation. Power Outlet Panels 100 percent galvanized steel with baked-on polyester powder coating. Utility grade metering available for construction site RV park applications. Door swings up and pushes in to lock into open position. Pull out and push down to close door. GFI circuit breakers (1- and 2-pole) available through 50 amperes. Removable upper deadfront cover for easy incoming wire connections to breaker terminals. One-piece case back for metered and unmetered panels. Unique steel barrier prevents unauthorized operation of breakers when door is closed and padlocked. Lower deadfront cover rotates 90 degrees or can be removed for easy routing of incoming wires or receptacle changeouts. Loop feed lug assembly with 350 kcmil lugs as standard. Padlock provisions to prevent unauthorized entry. Pedestal extension available for underground services. Pad-mounted bracket option also available. Units are factory wired and assembled. 5-2 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — Effective August 2005 SURFACE UNITS Unmetered Type Metered Ring or Ringless Power Outlet Panels PEDESTAL UNITS Unmetered Type Metered Ringless Type EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — ©Copyright 2005 Metered Ring Type 5-3 Application Photos Power Outlet Panels 5-4 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — Effective August 2005 Catalog Numbering System TABLE 5-1. CATALOG NUMBERING SYSTEM CH M 1 N 7 N 4 N P X L TZ U Feed Cutler-Hammer U = Bottom Fed Blank = Top Fed Metering Type Receptacle Type Center Position 1 = NEMA 14-50R 2 = NEMA 10-50R 3 = NEMA 14-30R 4 = NEMA TT-30R 5 = NEMA 6-20R2 6 = NEMA 5-20R2 7 = NEMA 5-20R2GFI Receptacle Type Left Position 1 = NEMA 14-50R 2 = NEMA 10-50R 3 = NEMA 14-30R 4 = NEMA TT-30R 5 = NEMA 6-20R2 6 = NEMA 5-20R2 7 = NEMA 5-20R2GFI Circuit Breaker Type Position 1 N = Non-Ground Fault G = Ground Fault Blank = No Breaker TZ = Factory-Installed Pedestal Extension with Lay-in Ground Lug Receptacle Type Right Position 1 = NEMA 14-50R 2 = NEMA 10-50R 3 = NEMA 14-30R 4 = NEMA TT-30R 5 = NEMA 6-20R2 6 = NEMA 5-20R2 7 = NEMA 5-20R2GFI L = Lighted Interior X = Six Circuit Blank = Standard Four Circuit Circuit Breaker Type Position 2 Mounting N = Non-Ground Fault G = Ground Fault Blank = No Breaker S = Surface P = Pedestal B = Back-to-Back Pedestal Circuit Breaker Type Position 3 N = Non-Ground Fault G = Ground Fault Blank = No Breaker For receptacle configurations, see Table 5-2 below. Twist lock receptacles are not listed in Table 5-2, as not all receptacle combinations are valid even though one can create a catalog number above. Contact Eaton for a quote on twist lock receptacles and custom breaker/receptacle configurations. Only available with metered surface mount units. TABLE 5-2. RECEPTACLE CONFIGURATION 50 ampere, 125/250 volt 3-pole, 4-wire, NEMA 14-50R 1 2-pole 50 ampere breaker 20 ampere, 250 volt, 2-pole, 3-wire, NEMA 6-20R2 5 50 ampere, 125/250 volt 2-pole, 3-wire, NEMA 10-50R 2 2-pole 50 ampere breaker 20 ampere, 125 volt, 2-pole, 3-wire, NEMA 5-20R2 6 30 ampere, 125/250 volt 3-pole, 4-wire, NEMA 14-30R 3 2-pole 30 ampere breaker 2-pole 20 ampere breaker Power Outlet Panels U = Unmetered M = Metered-Ring R = Metered-Ringless 1-pole 20 ampere breaker 20 ampere, 125 volt, 2-pole, 3-wire, NEMA 5-20R2GFI 7 1-pole 20 ampere breaker 30 ampere, 125 volt 2-pole, 3-wire, NEMA TT-30R 4 1-pole 30 ampere breaker EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — ©Copyright 2005 5-5 Data Tables TABLE 5-3. SURFACE TYPE Receptacle Description Ampere Series Breaker Description Position UPC Code Left Center Right 1st 2nd 3rd Catalog Number 20/20/20 20/20/20 20/20/20 5-20R2 5-20R2GFI 5-20R2GFI 5-20R2 5-20R2GFI 5-20R2GFI 6-20R2 6-20R2 6-20R2 GFI Non-GFI Non-GFI GFI Non-GFI Non-GFI GFI Non-GFI GFI CHU6G6G5GS CHU7N7N5NS CHU7N7N5GS 782114203927 782114203941 782114215753 50/20/30 50/20/30 30/20 14-50R 14-50R TT-30R 5-20R2GFI 5-20R2GFI 5-20R2GFI TT-30R 5-20R2GFI — Non-GFI GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI — CHU1N7N4NS CHU1G7N7NS CHU4N7NS 782114203828 782114215722 782114203743 20/20 50/20 50/20 5-20R2GFI 14-50R 14-50R 5-20R2GFI 5-20R2GFI 5-20R2GFI — — — Non-GFI GFI Non-GFI Non-GFI Non-GFI Non-GFI — — — CHU7N7NS CHU1G7NS CHU1N7NS 782114203774 782114215685 782114203705 50/20/50 50 50/20 14-50R 14-50R 10-50R 5-20R2GFI — 5-20R2GFI 14-50R — — Non-GFI Non-GFI GFI Non-GFI — Non-GFI Non-GFI — — CHU1N7N1NSX CHU1NS CHU2G7NS 782114203811 782114203668 782114215692 30/30/20 50/20 30 TT-30R 10-50R TT-30R 5-20R2GFI 5-20R2GFI — TT-30R — — Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI — Non-GFI — — CHU4N7N4NS CHU2N7NS CHU4NS 782114203903 782114203729 782114203675 Unmetered Power Outlet Panels Metered — Ring 50/20/20 20/20 20/20/20 14-50R 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI — 6-20R2 GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI — GFI CHM1G7N7NS CHM7N7NS CHM7N7N5GS 782114215586 782114202838 782114215616 20/20/20 50/30/20 50/20 20/20 5-20R2GFI 14-50R 14-50R 6-20R2 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI 6-20R2 TT-30R — — Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI — — CHM7N7N5NS CHM1N7N4NS CHM1N7NS CHM5N7NS 782114203002 782114202883 782114202777 782114215630 Metered — Ringless 50/20 20/20 50/20/20 14-50R 5-20R2GFI 14-50R 5-20R2GFI 5-20R2GFI 5-20R2GFI — — 5-20R2GFI GFI Non-GFI GFI Non-GFI Non-GFI Non-GFI — — Non-GFI CHR1G7NS CHR7N7NS CHR1G7N7NS 782114219072 782114203293 782114239834 50/20 50/20 20/20/20 10-50R 14-50R 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI — — 5-20R2GFI GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI — — Non-GFI CHR2G7NS CHR1N7NS CHR7N7N7NS 782114239827 782114203248 782114203477 30/20/20 50/30/20 14-30R 14-50R 5-20R2GFI 5-20R2GFI 5-20R2GFI TT-30R Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI CHR3N7N7NS CHR1N7N4NS 782114203415 782114203347 — 6-20R2 5-20R2GFI Non-GFI Non-GFI GFI Non-GFI Non-GFI Non-GFI — GFI Non-GFI CHM7N7NSU CHM7N7N5GSU CHM1G7N7NSU 782116153275 782116153305 782116153299 Metered — Ring — Bottom Fed 20/20 20/20/20 50/20/20 5-20R2GFI 5-20R2GFI 14-50R 5-20R2GFI 5-20R2GFI 5-20R2GFI The “X” suffix indicates that a six circuit interior is provided, instead of the standard four circuit interior. Note: For receptacle and circuit breaker configurations, please contact your local Eaton salesperson. Note: Contact your local Eaton sales office for configurations not listed. 5-6 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — Effective August 2005 Data Tables TABLE 5-3. SURFACE TYPE (CONTINUED) Receptacle Description Ampere Series Breaker Description Position Left Center Right 1st 2nd 3rd Catalog Number UPC Code Metered — Ringless — Bottom Fed 20/20 50/20 50/20 5-20R2GFI 14-50R 10-50R 5-20R2GFI 5-20R2GFI 5-20R2GFI — — — Non-GFI GFI GFI Non-GFI Non-GFI Non-GFI — — — CHR7N7NSU CHR1G7NSU CHR2G7NSU 782116153268 782116153282 782116153381 20/20/20 20/20/20 20/20/20 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI 6-20R2 6-20R2 5-20R2GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI GFI Non-GFI Non-GFI CHR7N7N5GSU CHR7N7N5NSU CHR7N7N7NSU 782116153312 782116153329 782116153374 30/20/20 30/20/20 50/20/20 50/20/30 14-30R 14-30R 14-50R 14-50R 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI 5-20R2GFI TT-30R Non-GFI GFI GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI CHR3N7N7NSU CHR3G7N7NSU CHR1G7N7NSU CHR1N7N4NSU 782116153336 782116153343 782116153367 782116153350 Note: For receptacle and circuit breaker configurations, please contact your local Eaton salesperson. Note: Contact your local Eaton sales office for configurations not listed. TABLE 5-4. PEDESTAL TYPE Ampere Series Breaker Description Position Left Center Right 1st 2nd 3rd Catalog Number UPC Code 50/30/20 30/20 14-50R TT-30R 5-20R2GFI 5-20R2GFI TT-30R — Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI — CHU1N7N4NP CHU4N7NP 782114203194 782114203170 50/30/20 30/30/20 14-50R TT-30R 5-20R2GFI 5-20R2GFI TT-30R TT-30R Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI CHU1N7N4NPTZ CHU4N7N4NP 782114342886 782114203217 5-20R2GFI 5-20R2GFI TT-30R — Non-GFI Non-GFI Non-GFI Non-GFI Non-GFI — CHM1N7N4NP CHM1N7NP 782114203040 782114223154 5-20R2GFI TT-30R Non-GFI Non-GFI Non-GFI CHR1N7N4NP 782114203101 Unmetered Metered — Ring 50/30/20 50/20 14-50R 14-50R Metered — Ringless 50/30/20 14-50R Power Outlet Panels Receptacle Description Note: For receptacle and circuit breaker configurations, please contact your local Eaton salesperson. Note: Contact your local Eaton sales office for configurations not listed. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — ©Copyright 2005 5-7 Data Tables TABLE 5-5. BACK-TO-BACK PEDESTAL TYPE Receptacle Description Ampere Series Breaker Description Position UPC Code Left Center Right 1st 2nd 3rd Catalog Number TT-30R 5-20R2GFI TT-30R Non-GFI Non-GFI Non-GFI CHU4N7N4NB 782114203644 5-20R2GFI 5-20R2GFI — TT-30R Non-GFI Non-GFI Non-GFI Non-GFI — Non-GFI CHM4N7NB CHM1N7N4NB 782114203484 782114203507 5-20R2GFI TT-30R Non-GFI Non-GFI Non-GFI CHR1N7N4NBTZ 782114332498 Unmetered 30/30/20 Metered — Ring 30/20 50/30/20 TT-30R 14-50R Metered — Ringless 50/30/20 14-50R Consult Power Outlet Estimator on Eaton intranet for additional combinations. Contact your local Eaton salesperson. The pedestal back-to-back units have receptacles and circuit breakers as shown for each panel and share one common pedestal with loop feed lugs. Note: For receptacle and circuit breaker configurations, please contact your local Eaton salesperson. Note: Contact your local Eaton sales office for configurations not listed. TABLE 5-6. MOBILE HOME PANELS Power Outlet Panels 5-8 Amperes Security Interior Main Branch Breakers Mounting Receptacles Catalog Number UPC Code 100 100 100 100 Ring Ring Ringless Ringless 4/8 4/8 4/8 4/8 BR2100 BR2100 BR2100 BR2100 BR BR BR BR Pedestal Back-to-Back Pedestal Back-to-Back None None None None MHM100P MHM100B MHR100P MHR100B 782114981689 782114981696 782114981702 782114981719 150 150 150 150 Ring Ring Ringless Ringless 8/16 8/16 8/16 8/16 BWH2150 BWH2150 BWH2150 BWH2150 BR BR BR BR Pedestal Back-to-Back Pedestal Back-to-Back None None None None MHM150P MHM150B MHR150P MHR150B 782116175352 782116175345 782116164752 782116164745 200 200 200 200 Ring Ring Ringless Ringless 8/16 8/16 8/16 8/16 BWH2200 BWH2200 BWH2200 BWH2200 BR BR BR BR Pedestal Back-to-Back Pedestal Back-to-Back None None None None MHM200P MHM200B MHR200P MHR200B 782114981726 782114981733 782114981740 782114981757 200 Ringless 8/16 BWH2200 BR Pedestal Qty 1 14-50R Qty 2 TT-30R MHM200P1N4N4N 782114981764 Pedestal Extension included with Mobile Home Panels. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — Effective August 2005 Accessories TABLE 5-7. ACCESSORIES AND REPLACEMENT PARTS Description Catalog Number UPC Code CHPEDEXT CHPEDEXTSS CHPADEXT 782114202739 782114221303 782114202746 Pad-Mount Bracket Accessories Cable TV and Telephone Bracket CHTELTV 782114202753 Rainproof Conduit Hub 0.75 Inch (19.1 mm) Rainproof Conduit Hub 1.00 Inch (25.4 mm) Rainproof Conduit Hub 1.25 Inch (31.8 mm) Rainproof Conduit Hub 1.50 Inch (38.1 mm) DS075H1 DS100H1 DS125H1 DS150H1 782113109916 782113109923 782113109930 782113109947 Fluorescent Light Kit — Converts Power Outlet Panel to Lighted Unit, must also order CHOUTCVRL. CHFLGTKIT 782114634240 Replacement Parts Replacement Meter Socket Replacement Meter Socket Replacement Meter Socket — 1 Block Assembly Per Kit CHPOPMS CHPOPMSN ARP00039CH 782114819999 782116127283 782116036868 5th Jaw Kit 5th Jaw Kit Bonding Strap and Mounting Hardware 1MM5JKOP ARP00035CHJ CHBONDST 782116007882 782114004135 782114219263 Horn Bypass — 1 Lug Cap Per Kit; 4 Kits Required Per Device Horn Bypass — 1 Kit Required Per Device ARP00777CH 1MMBPH 782114612840 782114380338 Inner Lens for Lighted Power Outlet Panels Loop Feed Lug Assembly for Single Pedestal Loop Feed Lug Assembly for Back-to-Back Pedestal CHINLENS CHLOOPFDP CHLOOPFDB 782114219270 782114219287 782114219294 Blank Lower Deadfront Cover Lower Deadfront Cover with Duplex Receptacle Opening Lower Deadfront Cover with Duplex, Duplex Receptacle Opening CHLDFCVR CHLDFCVR1 CHLDFCVR2 782114219300 782114219317 782114219324 Lower Deadfront Cover with Duplex, Duplex, Duplex Receptacle Opening Lower Deadfront Cover with Rectangle Receptacle Opening Lower Deadfront Cover with Rectangle, Rectangle Receptacle Opening CHLDFCVR3 CHLDFCVR4 CHLDFCVR5 782114219331 782114219348 782114219355 Lower Deadfront Cover with Rectangle, Rectangle, Rectangle Receptacle Opening CHLDFCVR6 CHLDFCVR7 Lower Deadfront Cover with Duplex, Rectangle Receptacle Opening CHLDFCVR8 Lower Deadfront Cover with Duplex, Rectangle, Duplex Receptacle Opening 782114219362 782114219379 782114219386 Lower Deadfront Cover with Rectangle, Rectangle, Duplex Receptacle Opening Lower Deadfront Cover with Round Receptacle Opening Lower Deadfront Cover with Round, Round Receptacle Opening CHLDFCVR9 CHLDFCVR10 CHLDFCVR11 782114219393 782114219409 782114221280 Lower Deadfront Cover with Round, Duplex Receptacle Opening Lower Deadfront Cover with Round, Duplex, Duplex Receptacle Opening Lower Deadfront Cover with Round, Duplex, Round Receptacle Opening CHLDFCVR12 CHLDFCVR13 CHLDFCVR14 782114221297 782114219423 782114219430 Lower Deadfront Cover with Round, Rectangle Receptacle Opening Lower Deadfront Cover with Round, Rectangle, Rectangle Receptacle Opening Lower Deadfront Cover with Round, Rectangle, Round Receptacle Opening CHLDFCVR15 CHLDFCVR16 CHLDFCVR17 782114219447 782114219454 782114219461 Lower Deadfront Cover with Round, Rectangle, Duplex Receptacle Opening Upper Deadfront Cover with Six Breaker Twistouts Upper Deadfront Cover with Provisions for Lighted Option CHLDFCVR18 CHUDFCVR CHUDFCVRL 782114220795 782114219478 782114219485 Power Head Outer Cover Power Head Outer Cover with Lens CHOUTCVR CHOUTCVRL 782114219492 782114219508 6-Hole Neutral Assembly with 2/0 Lug 7-Hole Neutral Assembly with 2/0 Lug 5-Hole Ground Bar Kit 10-Hole Ground Bar Kit CHNEUT CHNEUT1 GBK5 GBK10 782114219515 782114221808 782113099064 782114014561 Replacement Meter Cover — Ring Type Replacement Meter Cover — Ringless Replacement Meter Cover — Ringless Replacement Meter Cover — Ringless CHPOPRMC CHPOPRLMC CHPOPRLMCN CHPOPRLMCN2 782114838471 782114838488 782116127290 782116641914 CS Hub Underground Pedestal Extension Inner Lens Cable TV/ Telephone Bracket Power Head Outer Cover with Lens Neutral Assemblies Power Head Outer Cover Loop Feed Lug Assembly Meter Socket Lower Deadfront Cover Circuit Breaker (BR/GFCB) Power Outlet Panels Underground Pedestal Extension Stainless Steel Underground Pedestal Extension Pad-Mount Bracket Upper Deadfront Cover Bonding Strap and Mounting Hardware For power outlet panels manufactured before 12/1/02. For power outlet panels manufactured after 12/1/02. For power outlet panels with a date code ending in L. For power outlet panels with a date code not ending in L. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — ©Copyright 2005 5-9 Mobile Home Panel Deadfronts Power Outlet Panels FIGURE 5-1. AVAILABLE RECEPTACLE DEADFRONT KITS — RECEPTACLES AND BREAKERS NOT INCLUDED 5-10 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — Effective August 2005 DIMENSIONAL DRAWINGS Ringless U.G. Feed Pedestal-Mount B/B 18.02 (457.7) 8.25 33.00 (838.2) 33.00 (838.2) Power Outlet Panels Hit Exit Hole B/B Only FIGURE 5-2. 100 AMPERES BACK-TO-BACK EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — ©Copyright 2005 5-11 DIMENSIONAL DRAWINGS Ringless U.G. Feed Pedestal-Mount. .79 (20.1) 0.24 260.0) 10.78 (273.7) Gasket .92 (23.4) 4.00 Hit Exit Hole B/B Only Power Outlet Panels 6.10 (154.9) 18.02 wer Barrier 33.00 (838.2) 33.00 (838.2) FIGURE 5-3. 100 AMPERE PEDESTAL 5-12 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — Effective August 2005 DIMENSIONAL DRAWINGS Ringless Socket Rated 200 A Continuous 5.31 Sealin 5/16 (7.9) Diameter KO Opposite Side Only 1, 1-1/4, 1-1/2, 2 (25.4, 31.8, 38.1, 50.8) Knockout 57.81 (1468.3) 200A 50.08 (1272.1) Optional Direct Feed Kit Shown Installed (Cover Not Shown) 27.87 (708.0) 28.01 (711.5) 43.20 (1097.4) 28.70 (729.0) 24.65 (626.1) 2.00 (50.8) 1, 1-1/4, 1-1/2, 2 (25.4, 31.8, 38.1, 50.8) KO 1/2, 3/4,1 (12.7, 19.1, 25.4) KO (2 Required) 23.69 (601.8) 1/2, 3/4, 1, 1-1/4, 1-1/2 (12.7, 19.1, 25.4, 31.8, 38.1) KO Sealing Provision 1.21 Grade Level FIGURE 5-4. MOBILE HOME PANEL — RINGLESS SECURITY — PEDESTAL MOUNTING Front View Back View 12.09 (307.2) Ringless Socket Rated 200 A Continuous 10 14.45 1-1/4, 1-1/2, 2, 2-1/2 (31.8, 38.1, 50.8, 63.5) KO (2) Required Sealing Provision Side Only 1,1-1/4, 1-1/2, 2 1/2 (12.7) KO (3) Required 57.81 (1468.3) Door Not Shown 5/16 (7.9) Diameter Door Not Shown 1-1/4, 1-1/2, Diameter KO (31.8, 38.1, 50.8, 63.5) Knockout Side Only Power Outlet Panels 1-1/4, 1-1/2, 2, 2-1/2 (31.8, 38.1, 50.8, 63.5) Knockout 3/4, 1 (19.1, 25.4) KO KO (3) Required 200A Main KO (2) Required 1-1/2, 2, 2-1/2, 3 (38.1, 50.8, 63.5, 76.2) KO Bottom Endwall Back Unit 50.08 (1272.1) (1097.4) 27.87 (708.0) 22.01 (711.5) Feed Kit Shown Installed (Cover Not Shown) 25.00 (635.0) 18.69 (474.6) 2.00 1/2, 3/4, 1 (12.7, 19.1, 25.4) KO (2) Required 28.70 (729.0) 23.69 (601.8) 1.21 Sealing Provision 1, 1-1/4, 1-1/2, 2 (25.4, 31.8, 38.1, 50.8) KO 1/2, 3/4, 1, 1-1/4, 1-1/2 (12.7, 19.1, 25.4, 31.8, 38.1) KO Bottom Endwall Direct Feed Kit Grade Level FIGURE 5-5. MOBILE HOME PANEL — RINGLESS SECURITY — BACK-TO-BACK MOUNTING EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — ©Copyright 2005 5-13 DIMENSIONAL DRAWINGS 5.31 (134.8) 14.45 Ring Type Socket Rated 200 A Continuous 5/16 (7.9) Diameter KO Opposite Side Only 200A Main Breaker 1-1/4, 1-1/2, 2, 2-1/2 (31.8, 38.1, 1, 1-1/4, 1-1/2, 2 (25.4, Knockout 50.8) KO ON Door Not Shown OFF 5.56 (141.3) 57.81 (1468.3) 50.08 (1272.1) 43.20 (1097.4) Optional Direct Feed Kit Shown Installed (Cover Not Shown) 1/2, 3/4, 1 (12.7, 19.1, 25.4) KO (2 Required) 1, 1-1/4, 1-1/2, 2 (25.4, 31.8, 38.1, 50.8) KO 1/2, 3/4, 1, 1-1/4, 1-1/2 (12.7, 19.1, 25.4, 31.8, 38.1) KO 28.70 (729.0) 28.01 (711.5) 27.87 (708.0) 24.64 (626.0) 23.69 (601.8) Direct Feed Kit Power Outlet Panels Sealing Provision 2.00 (50.8) 1.21 (30.7) Grade Level FIGURE 5-6. MOBILE HOME PANEL — RING SECURITY — PEDESTAL MOUNTING Front View Back View 11.25 (285.8) 10 75 14.45 (367.0) 200A Main Breaker 5/16 (7.9) Diameter KO 1-1/4, 1-1/2, 2, 2-1/2 (31.8, 38.1, 50.8, 63.5) Knockout Ring Type Socket Rated 200 A Continuous 57.81 (1468.3) Door Not Shown 1-1/4, 1-1/2, 2, 2-1/2 KO (2) Required 3/4, 1 (19.1, 25.4) KO 1/2 (12.7) KO (3) Required 5/16 (7.9) Diameter 50.0 (1272 43.20 (1097.4) 27.87 (708.0) 22.01 (711.5) Feed Kit Shown Installed (Cover Not Shown) Bottom Endwall Back Unit 28.70 (729.0) 25.00 (635.0) 23.69 (601.8) 18.69 (474.6) , 2, 2-1/2, 3 (38.1, 50.8, 63.5, 76.2) KO KO (2) Required 1/2, 3/4, 1 19.1, 25.4) K (2) Required 1, 1-1/4, 1-1/2, 2 (25.4, 31.8, 38.1, 50.8) KO 1/2, 3/4, 1, 1-1/4, 1-1/2 (12.7, 19.1, 25.4, 31.8, 38.1) KO Grade Level Sealing Provision Direct Feed Kit FIGURE 5-7. MOBILE HOME PANEL — RING SECURITY — BACK-TO-BACK MOUNTING 5-14 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — Effective August 2005 DIMENSIONS IN INCHES (MM) — METERED UNITS (RING AND RINGLESS) 4.50 (114.3) 4.30 9.50 .07 30.00 (762.0) 22.50 (571.5) Sealing Provision (170.1) FIGURE 5-8. METERED SURFACE TYPE 9.50 (241.3) 5.00 (127.0) 52.00 (1320.8) 6.80 (172.7) 4.30 (109.2) Power Outlet Panels Locking Provision Locking Provision 44.50 (1130.3) 25.80 (655.3) 22.00 (558.8) 16.90 (429.3) Sealing Provision FIGURE 5-9. METERED PEDESTAL TYPE EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — ©Copyright 2005 5-15 DIMENSIONS IN INCHES (MM) — METERED UNITS (RING AND RINGLESS) Power Outlet Panels FIGURE 5-10. METERED BACK-TO-BACK PEDESTAL TYPE 6.80 (172.8) 4.31 9.49 (241.1) .06 (1.6) Locking Provision 30.10 (764.6) 17.11 (434.7) 12.97 (329.4) 6.15 (156.2) Sealing Provision 4.93 (125.2) FIGURE 5-11. BOTTOM FED TYPE 5-16 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — Effective August 2005 DIMENSIONS IN INCHES (MM) — UNMETERED UNITS 9.50 (241.3) 4.30 (109.2) .07 (1.7) 17.10 (434.3) 14.50 (368.3) 6.70 (170.2) 1.30 (33.0) FIGURE 5-12. UNMETERED SURFACE TYPE 9.50 (241.3) 13.60 (345.4) 8.60 (218.4) 9.50 Locking Provision 17.10 (434.3) 39.10 (993.1) Power Outlet Panels Locking Provision 39.90 (1013.5) 19.20 (487.7) 9.20 (233.7) 9.40 (238.8) FIGURE 5-13. UNMETERED PEDESTAL TYPE .75 (19.1) 3.30 (83.8) FIGURE 5-14. UNMETERED BACK-TO-BACK PEDESTAL TYPE Cutler-Hammer is a federally registered trademark of Eaton Corporation. NEMA is the registered trademark and service mark of the National Electrical Manufacturers Association. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — ©Copyright 2005 5-17 Power Outlet Panels 5-18 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Power Outlet Panels — Effective August 2005 Product Description Spa Panels 6-1 6-5 6-6 6-6 6-6 6-6 Features, Functions and Benefits ✓ Unit arrives assembled, prewired, factory tested 6-10 6-11 ✓ ✓ 6-12 6-13 6-14 ✓ ✓ 6-15 6-16 6-18 6-21 ✓ and ready to install. Preinstalled neutral and ground bars. Comes with a 4-circuit interior that allows for two extra 120 volt circuits for convenience receptacles or lighting (Type CH only). Padlockable doors to prevent unauthorized entry. A push-to-test button to ensure the ground fault breaker is working. Door swings open and stays open for easy interior access. Catalog Numbering System TABLE 6-1. CATALOG NUMBERING SYSTEM CH 50 SPA Type CH = .75-Inch (19.1 mm) BR = 1-Inch (25.4 mm) Amperes 30 40 50 60 = = = = 30 40 50 60 Unit Type SPA = Spa Panel Disconnects Spa Panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Air Conditioner Disconnects Metallic and Non-Metallic . . . . . . . . . . . . . . . With Ground Fault Receptacle. . . . . . . . . . . . With Whips . . . . . . . . . . . . . . . . . . . . . . . . . . Three-Phase. . . . . . . . . . . . . . . . . . . . . . . . . . Cross-Reference . . . . . . . . . . . . . . . . . . . . . . General-Duty Fused Safety Switch — 120/240 V . . . . . . . . Non-fused Safety Switch — 120/240 V . . . . . Heavy-Duty Fusible Safety Switch — 240 V . . . . . . . . . . . Fusible Safety Switch — 600 V . . . . . . . . . . . Non-fusible Safety Switch – 600 V . . . . . . . . Non-fusible and Fusible Double Throw Safety Switch — 240 V. . . . . . . . . . . . . . . . . Non-fusible and Fusible Double Throw Safety Switch — 600 V. . . . . . . . . . . . . . . . . Safety Switch Accessories . . . . . . . . . . . . . . . . . Safety Switch Cross-Reference . . . . . . . . . . . . . A spa panel is a factory-assembled “combination” unit that provides ground fault protection, as well as a convenient way to turn spa pumps on and off. The National Electrical Code姞 requires that all pool and spa pumps be protected by a ground fault interrupter and a disconnect switch mounted within 10 feet of the tub or spa. Now you can have both in one simple device and protect your family and friends from serious shock or electrocution. Cutler-Hammer Quick-Pro SM Spa Panels Enclosure (1 5 Feet – – Hot Tub All you need to know to save time and make more money. Specified on certain Cutler-Hammer products, the Quick-Pro symbol allows for immediate recognition of products that are designed for straightforward installation. When you see Quick-Pro, you know you can install quickly — sometimes up to 50% less than the usual installation time — and move onto your next job. Feet 24 Inches – 44 Inches (610 mm – 8 mm) Check national and local codes for compliance. FIGURE 6-1. HOT TUB DIAGRAM EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-1 Data Tables TABLE 6-2. PRODUCT SELECTION Main Ampere Rating Circuit Breaker Included Enclosure Type Trim Type Included Box Size Wire Size Range Cu/Al 60°C or 75°C for Main Lugs Catalog Number UPC Code 30 40 50 40 50 60 CH230GF CH240GF CH250GF GFCB240 GFCB250 CH260GF Outdoor Outdoor Outdoor Outdoor Outdoor Outdoor — — — — — — 6R 6R 6R 5R 5R 6R #14 – 2 kcmil #14 – 2 kcmil #14 – 2 kcmil #8 – 2 kcmil #8 – 2 kcmil #14 – 2 kcmil CH30SPA CH40SPA CH50SPA BR40SPA BR50SPA CH60SPA 782116141890 782116056583 782116056590 786679138045 782114555866 782116056606 See Loadcenters Section, Page 2-18 for dimensions. Contains only a two circuit interior while all others contain a four circuit interior. Cross-Reference TABLE 6-3. CROSS-REFERENCE SELECTION Disconnects 6-2 Description Cutler-Hammer姞 Square D姞 GE姞 (Midwest) Single-phase, 4 circuit CH loadcenter with 30 ampere 2-pole ground fault breaker factory installed. CH30SPA — — Single-phase, 4 circuit CH loadcenter with 40 ampere 2-pole ground fault breaker factory installed. CH40SPA — — Single-phase, 4 circuit CH loadcenter with 50 ampere 2-pole ground fault breaker factory installed. CH50SPA QOE250GFINM TL412R250GF Single-phase, 4 circuit CH loadcenter with 60 ampere 2-pole ground fault breaker factory installed. CH60SPA — TL412R260GF Single-phase, 2 circuit BR loadcenter with 50 ampere 2-pole ground fault breaker factory installed. BR50SPA HOME250SPA TL412R250GF EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 Air Conditioner Disconnects Installation An Air Conditioner Disconnect (ACD) is a disconnect located between a loadcenter (distribution panel) and air conditioner. The Cutler-Hammer ACD by Eaton provides an installer or repair personnel with a visible disconnection means when performing maintenance. ACDs are also known as disconnects, pullouts or air conditioner switches. Cutler-Hammer Quick-Pro SM All you need to know to save time and make more money. Specified on certain Cutler-Hammer products, the Quick-Pro symbol allows for immediate recognition of products that are designed for straightforward installation. When you see Quick-Pro, you know you can install quickly — sometimes up to 50% less than the usual installation time — and move onto your next job. Features, Functions and Benefits ✓ ✓ ✓ ✓ ✓ ✓ Provides visible means of disconnect. Easy to install. Fused or non-fused. Single-phase or 3-phase. UL姞 listed, File No. E5239. Separate CSA姞 approved unit. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 Disconnects Product Description 6-3 Catalog Numbering System TABLE 6-4. METALLIC ACDS — CATALOG NUMBERING SYSTEM DP U 2 2 2 R P 12 GF Type Factory-Installed Options Metallic ACD Packaged for Retail Poles Disconnect Type B = Molded Case Switch F = Fused U = Non-Fused 2 = 2-Pole 3 = 3-Pole Voltage 2 = 240 Vac 3 = 600 Vac Amperes 1 = 30 2 = 60 Wire Harness Size Options Blank = None GF = Ground Fault Receptacle W = Wire Harness Blank = None 12 = 1/2-Inch 34 = 3/4-Inch Enclosure R = NEMA姞 3R Available only on non-fused units. Available only on non-fused, 3-pole units. Available only on fused units. Available only on non-fused, 60 ampere units. Available only on non-fused, 60 ampere and fused 30 or 60 ampere units. TABLE 6-5. NON-METALLIC ACDS — CATALOG NUMBERING SYSTEM AC 2 2 2 U R NM P - A2 Type AC Disconnects 6-4 Series Number Poles Voltage 2 = 2-Pole Packaged for Retail 2 = 240 Vac Type Amperes Fused Type Enclosure 1 = 30 2 = 60 Blank = Fused U = Non-Fused R = NEMA 3R Non-Metallic Available only on non-fused units. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 Data Tables TABLE 6-6. DIMENSIONS AND SHIPPING CARTON INFORMATION Dimensions in Inches (mm) Description Height Width Depth Catalog Number UPC Code 8.70 (220.9) 8.70 (220.9) 8.70 (220.9) 8.60 (218.4) 5.40 (137.2) 5.40 (137.2) 5.40 (137.2) 5.30 (134.6) 3.15 (80.0) 3.15 (80.0) 3.15 (80.0) 3.74 (95.0) DPF221RP DPF222RP DPU222RP DPB222RP 782114103210 782114103227 782114103234 782114208250 8.63 (219.0) 8.63 (219.0) 8.63 (219.0) 8.63 (219.0) 5.00 (127.0) 5.00 (127.0) 5.00 (127.0) 5.00 (127.0) 3.50 (88.9) 3.50 (88.9) 3.50 (88.9) 3.50 (88.9) AC221RNMP-A2 AC222RNMP-A2 AC222URNMP-A2 B60NARNMP-A2 786676405904 786676405959 786676406086 786676030175 Metallic/Galvanized Steel Enclosure 30 A Fused 60 A Fused 60 A Non-Fused 60 A Molded Case Switch Nonmetallic/Polycarbonate Enclosure UPC Code — 10 #14 – 3 DPB222RP 782114208250 10 #14 – 2 B60NARNMP-A2 786676030175 Non-Metallic 60 — Wire Size Range Cu/Al 60ºC or 75ºC Main Ampere Rating UPC Code 1-1/2 3 3 10 #14 – 3 #14 – 3 DPF221RP DPF222RP 782114103210 782114103227 #14 – 2 #14 – 2 AC221RNMP-A2 786676406208 AC222RNMP-A2 786676406253 Non-Metallic 1-1/2 3 3 10 For replacement pullout head, order part number 96-3258-4. To obtain a Service Entrance Rating, the addition of GB4NM (Ground Bar Kit) is required. Catalog Number 10 #14 – 3 DPU222RP 10 #14 – 2 AC222URNMP-A2 786676406154 120 V 240 V 30 60 30 60 TABLE 6-8. NON-FUSED PULLOUTS Maximum hp Rating 120 V 240 V Catalog Number Galvanized Steel Galvanized Steel 60 Maximum hp Rating UPC Code 782114103234 Galvanized Steel 60 3 Non-Metallic 60 3 Disconnects 120 V 240 V Catalog Number TABLE 6-9. FUSED PULLOUTS Wire Size Range Cu/Al 60ºC or 75ºC Maximum hp Rating Wire Size Range Cu/Al 60ºC or 75ºC Main Ampere Rating TABLE 6-7. MOLDED CASE SWITCH Main Ampere Rating 30 A Fused 60 A Fused 60 A Non-Fused 60 A Molded Case Switch For replacement pullout head, order part number 96-3258-4. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-5 Data Tables TABLE 6-10. ACD WITH GROUND FAULT RECEPTACLE Maximum Main Wire Size hp Rating Ampere Range Cu/AI Catalog Rating 120 V 240 V 60°C or 75°C Number TABLE 6-11. THREE-PHASE ACD Maximum Main Wire Size hp Rating Ampere Range Cu/AI Catalog Rating 120 V 240 V 60° C or 75° C Number UPC Code 60 Non-Fused Pullouts 60 3 10 #14 – 3 DPU222RGF 782116080212 10 10 #14 – 3 #14 – 3 DPF221RGF 782116343508 DPF222RGF 782116343515 #12 — 10 15 #14 – 3 UPC Code DPU362R 782116175956 Fused Pullouts 30 60 3 3 GFCI Receptacle 20 — — — Included in above. TABLE 6-12. ACD WITH WHIP SPECIFICATIONS Whip Diameter Hot Wire Size Ground Wire Size Flexible Conduit Length Non-Metallic Fittings Catalog Number UPC Code 1/2 Inch 3/4 Inch #10 #8 #10 #10 6 ft. (1.8 m) 6 ft. (1.8 m) 1 – 90°, 1 – Straight 1 – 90°, 1 – Straight DPU222R12W DPU222R34W 782116107520 782116107537 Cross-Reference TABLE 6-13. CROSS-REFERENCE Disconnects CutlerHammer Catalog Number Description Catalog Number UPC Code Square D姞 GE姞 Siemens姞 (Midwest) (Murray姞) Milbank Thomas & Betts姞 Metallic/Galvanized Steel Enclosure 30 A Fused 60 A Fused 60 A Non-Fused 60 A Non-Fused Compact Design 60 A Molded Case Switch 60 A Non-Fused with GF Receptacle DPF221R DPF222R DPU222R DPU222R DPB222R DPU222RGF 782113926865 782114166932 782113926858 782113926858 782114205686 782116080212 FP221R FP222R UFP222R — QO200TR — TF30R TF60R TFN60R — TNA60R1 TFN60RGFR WFFS2030 WFS2060 WNF & WNFS2060 WNFC2060 WBQS2060 — U3803 U3806 U3800 — — U3822-20GR ACM221 ACM222 ACM222NF ACPO222NF ACM2620NA — 30 A Fused with GF Receptacle 60 A Fused with GF Receptacle 60 A Non-Fused 60 A Non-Fused 60 A 3-Phase 600 V Molded Case Switch DPF221RGF DPF222RGF DPU222R12W DPU222R34W DPU362R 782116343508 782116343515 782116107520 782116107537 782116175956 — — — — — — — — — — — — — — — — — — — — — — — — — 786676406208 786676406253 786676406154 786676030175 FP221RNM FP222RNM UFP222RNM QO200TRNM TPF30R TPF60R TPN60R1 TPNA60R1 — — — — — — — — ACP221 ACP222 ACP222NF ACP260NA Non-Metallic/Polycarbonate Enclosure 30 A Fused 60 A Fused 60 A Non-Fused 60 A Molded Case Switch AC221RNMP-A2 AC222RNMP-A2 AC222URNMP-A2 B60NARNMP-A2 Cutler-Hammer Quick-Pro designated item. With 1/2-inch wire harness. With 3/4-inch wire harness. 6-6 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 Safety Switches Product Description SAFETY SWITCH A safety switch is used to open or close an electrical circuit. Non-fusible safety switches provide a means to manually connect or disconnect the equipment from the power source. Fusible safety switches provide a means to manually open and close a circuit and overcurrent protection by using customer-installed fuses. Safety switches are also commonly referred to as a disconnect switch or simply a disconnect. DP221NGB Plug Fuse Safety Switch, 30 Amperes, 120/240 Volts DOUBLE THROW SAFETY SWITCH A double throw safety switch is sometimes referred to as a transfer switch. It performs the same function as a safety switch by opening or closing a circuit; however, its primary use is to transfer service from a normal power source to an alternate source (i.e., a residential generator) or to switch from one load circuit to another. ✓ ✓ ✓ ✓ ✓ 120/240, 240 or 600 volts. Easy to install. Ample wiring space. Padlockable. UL listed. DG322URB General-Duty, Non-Fusible Safety Switch, 60 Amperes, 240 Volts DT224URK-NPS General-Duty, Non-Fusible Double Throw Emergency Power Safety Switch, 200 Amperes, 120/240 Volts Disconnects Features, Functions and Benefits DH362UGK Heavy-Duty, Non-Fusible Safety Switch, 60 Amperes, 600 Volts EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-7 Safety Switches DG321NRB General-Duty, Cartridge Fuse Safety Switch, 30 Amperes, 120/240 Volts DP221NGB DT223URH-N General-Duty, Non-Fusible Double Throw Emergency Power Safety Switch, 100 Amperes, 120/240 Volts DT224URK-NPS DG324NGK Disconnects DH362NGK Heavy-Duty, Fusible Safety Switch, 60 Amperes, 600 Volts DT363URK Heavy-Duty, Non-Fusible Double Throw Emergency Power Safety Switch, 100 Amperes, 600 Volts 6-8 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 Applications FIGURE 6-3. RESIDENTIAL GENERATOR APPLICATION WITH MANUALLY OPERATED DOUBLE THROW SAFETY SWITCH FIGURE 6-4. RESIDENTIAL GENERATOR APPLICATION WITH AUTOMATIC TRANSFER SWITCH AND SERVICE ENTRANCE RATED SAFETY SWITCH Catalog Numbering System TABLE 6-14. SAFETY SWITCH CATALOG NUMBERING SYSTEM DG 2 2 1 N R B Switch Type DP = General-Duty/Plug Fuse DG = General-Duty/Cartridge Fuse DH = Heavy-Duty DT = Double Throw Disconnects FIGURE 6-2. HOUSEHOLD WORKBENCH APPLICATION Series Poles/Blades 1 2 3 4 = = = = 1-Pole 2-Pole 3-Pole 4-Pole Voltage 1 = 120 Vac 2 = 240 Vac 6 = 600 Vac NEMA Enclosure Ratings Amperes 1= 2= 3= 4= 5= 6= 7= 8= 30 60 100 200 400 600 800 1200 G = NEMA 1 R = NEMA 3R D = NEMA 12 W = NEMA 4X Corrosion Resistant (304 Grade Stainless Steel) K = Design (All General-Duty Switches Above 200 Amperes and All Heavy-Duty Switches Incorporate K-Series Switch Design Features Listed Below) B = Design General-Duty (30 – 100 Amperes) H = General-Duty Double Throw Switch (Compact Design 30 – 100 Amperes) Fusible/Non-Fusible or Neutral F = Fusible without Neutral U = Non-Fusible N = Fusible with Neutral EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-9 Data Tables 120/240 VAC GENERAL-DUTY, FUSIBLE, SINGLE THROW Specifications ✓ 30 – 600 amperes. ✓ Suitable for service entrance applications unless ✓ Bolt-on hub provision. Provided for general-duty switches in a NEMA 3R enclosure. ✓ UL listed File No. E5239. Meets UL 98 for enclosed switches and NEMA Std. KS-1. otherwise noted. ✓ Horsepower rated. TABLE 6-15. 120/240 VAC GENERAL-DUTY, FUSIBLE, SINGLE THROW Maximum Horsepower Ratings Ampere Rating Fuse Type Provision 1-Phase ac 3-Phase ac dc NEMA 1 Enclosure Indoor 120 Volt 240 Volt 250 Volt Catalog Number UPC Code Catalog Number UPC Code — — DP111NGB 782113140827 — — — — DP221NGB 782113140841 Use cartridge- — type fuse catalog number DG221NRB 3 – 7-1/2 7-1/2 – 15 15 – 30 25 – 60 50 – 125 75 – 200 — — — — — — DG225FGK DG226FGK — — — — 782114001943 782114001967 DG225FRK DG226FRK — — — — 782114001950 782114001974 3 – 7-1/2 7-1/2 – 15 15 – 30 25 – 60 50 – 125 75 – 200 — — — — 50 — DG221NGB DG222NGB DG223NGB DG224NGK DG225NGK DG226NGK 782113120171 782113144214 782113144245 782113213491 782113589497 782113589558 DG221NRB DG222NRB DG223NRB DG224NRK DG225NRK DG226NRK 782113120317 782113144221 782113144252 782113213507 782113589503 782113589565 240 Volt NEMA 3R Enclosure Rainproof Fusible — Plug Type 2-Wire (One Blade, One Fuse, S/N) — 120 Vac 30 Plug (Type S, T or W) 1/2 – 2 — 3-Wire (Two Blades, Two Fuses, S/N) — 120/240 Vac 30 Plug (Type S, T or W) 1/2 – 2 1-1/2 – 3 Fusible — Cartridge Type 2-Pole 2-Wire (Two Blades, Two Fuses) — 240 Vac Disconnects 30 60 100 200 400 600 — — — — H H — — — — — — 1-1/2 – 3 3 – 10 7-1/2 – 15 15 — — 3-Wire (Two Blades, Two Fuses, S/N) — 120/240 Vac 30 60 100 200 400 600 H H H H H H — — — — — — 1-1/2 – 3 3 – 10 7-1/2 – 15 15 — — Maximum hp ratings apply only when dual element time delay fuses are used. These switches do not have an interlock which prevents door from being opened when switch is in the ON position. Use 3-wire catalog numbers below. Solid neutral bars are not included. Order separately from Table 6-27 on Page 6-18. Grounded B phase rating, UL listed. Note: All general-duty safety switches are individually packaged. Note: Accessories are limited in scope on general-duty safety switches. In addition, clear line shields are available as an accessory on 200 – 600 ampere general-duty switches. Catalog Numbers: 200 A = 70-7759-11, 400 A = 70-8063-8, 600 A = 70-8064-8. Note: Plug fuse safety switches are not suitable for service entrance use. 6-10 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 120/240 VAC GENERAL-DUTY, FUSIBLE, SINGLE THROW TABLE 6-16. 120/240 VAC GENERAL-DUTY, FUSIBLE, SINGLE THROW Maximum Horsepower Ratings Ampere Rating Fuse Type Provision 1-Phase ac 3-Phase ac dc NEMA 1 Enclosure Indoor 120 Volt 240 Volt 250 Volt Catalog Number UPC Code Catalog Number UPC Code — — — — — — DG325FGK DG326FGK — — — — 782113589510 782113589572 DG325FRK DG326FRK — — — — 782113589527 782113589589 — — — — — — DG321NGB DG322NGB DG323NGB DG324NGK DG325NGK DG326NGK 782113120201 782113144283 782113144344 782113213538 782113639208 782113639222 DG321NRB DG322NRB DG323NRB DG324NRK DG325NRK DG326NRK 782113120348 782113144290 782113144351 782113213545 782113639215 782113639239 240 Volt NEMA 3R Enclosure Rainproof 3-Pole 3-Wire (Three Blades, Three Fuses) — 240 Vac 30 60 100 200 400 600 — — — — — — — — — — H H — — — — — — — — — — 50 – 125 75 – 200 4-Wire (Three Blades, Three Fuses, S/N) — 120/240 Vac 30 60 100 200 400 600 — — — — — — H H H H H H 1-1/2 – 3 3 – 10 7-1/2 – 15 15 — — 3 – 7-1/2 7-1/2 – 15 15 – 30 25 – 60 50 – 125 75 – 200 Maximum hp ratings apply only when dual element time delay fuses are used. Use 4-wire catalog numbers below. Solid neutral bars are not included. Order separately from Table 6-27 on Page 6-18. 120/240 VAC GENERAL-DUTY, NON-FUSIBLE, SINGLE THROW Maximum Horsepower Ratings 1-Phase ac Ampere Rating 120 Volt 240 Volt 3-Phase ac dc NEMA 1 Enclosure Indoor 240 Volt 250 Volt Catalog Number UPC Code Catalog Number UPC Code — — — — DG221UGB DG222UGB DG223UGB DG221URB DG222URB DG223URB 782113120102 782114731130 782114731147 — 782113120232 782113144238 782114731154 — — — — — — — DG321UGB DG322UGB DG323UGB DG324UGK DG325UGK DG326UGK 782113120140 782113144306 782113144368 782113213552 782113589534 782113589596 DG321URB DG322URB DG323URB DG324URK DG325URK DG326URK 782113120287 782113144313 782113144375 782113213576 782113589541 782113589602 NEMA 3R Enclosure Rainproof Non-Fusible — 2-Pole 2-Wire (Two Blades) — 240 Vac 30 60 100 200 2 3 — — 3 10 15 — — — — — Disconnects TABLE 6-17. 120/240 VAC GENERAL-DUTY, NON-FUSIBLE, SINGLE THROW 3-Pole 3-Wire (Three Blades) — 240 Vac 30 60 100 200 400 600 2 3 — — — — 3 10 15 15 — — 7-1/2 15 30 60 125 200 WARNING! Switch is not approved for service entrance unless a neutral kit is installed. Use 3-wire catalog numbers below. Drilled to accept field installed neutral kits. Note: All general-duty safety switches are individually packaged. Note: Accessories are limited in scope on general-duty safety switches. In addition, clear line shields are available as an accessory on 200 – 600 ampere general-duty switches. Catalog Numbers: 200 A = 70-7759-11, 400 A = 70-8063-8, 600 A = 70-8064-8. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-11 240 VAC HEAVY-DUTY, FUSIBLE, SINGLE THROW Specifications ✓ Suitable for service entrance use, except 4-pole ✓ 30 – 1200 amperes. ✓ Horsepower rated. switches. ✓ UL listed File No. E5239. Maximum Horsepower Ratings Catalog Number ac dc 250 V 3-Phase Time Delay 1-Phase 3-Phase Standard Fuse 1-Phase Fuse Type Provision Ampere Rating TABLE 6-18. FUSIBLE NEMA 1 Enclosure Indoor UPC Code NEMA 3R Enclosure UPC Rainproof Code NEMA 12 Enclosure Industrial, Dust-tight UPC Code NEMA 4X Enclosure Corrosion Resistant, Stainless Steel UPC Code 2-Pole — 240 Vac, 250 Vdc (Suitable for Service Entrance Use with a Neutral or Ground Lug Kit Installed) 30 60 100 200 400 600 800 H — — — H H L — — — — 50 75 100 — — — — — — — — — — — — — — — — — — 125 200 — — — — — 50 — — DH221FGK 782114370322 — — — DH225FGK 782113207018 DH226FGK 782113207360 DH227FGK 782113589657 — — — — DH225FRK 782114001981 DH226FRK 782114001998 — — — — — — DH225FDK 782113207094 DH226FDK 782113207445 DH227FDK 782113589763 or — — — — — — — DH221NRK DH222NRK DH223NRK DH224NRK DH225NRK DH226NRK DH227NRK DH221NDK DH222NDK DH223NDK DH224NDK DH225NDK DH226NDK DH227NDK 782113205397 782113205861 782113206295 782113206707 782113207117 782113207469 782113589787 DH221NWK DH222NWK DH223NWK DH224NWK DH225NWK DH226NWK DH227NWK 782113205403 782113205885 782113206301 782113206714 782114375198 782114371220 782113589770 3-Wire (Two Blades, Two Fuses, S/N) — 240 Vac, 250 Vdc 30 60 100 200 400 600 800 H H H H H H L 1-1/2 3 3 7-1/2 7-1/2 15 15 25 — 50 — 75 — 100 7-1/2 3 10 15 15 30 15 60 — 125 — 200 — — 5 10 20 40 50 — — DH221NGK DH222NGK DH223NGK DH224NGK DH225NGK DH226NGK DH227NGK 782113205342 782113205779 782113206226 782113206646 782113207025 782113207377 782113589664 782113205359 782113205793 782113206233 782113206653 782113207032 782113207384 782113589671 3-Pole — 240 Vac, 250 Vdc (Suitable for Service Entrance Use with a Neutral or Ground Lug Kit Installed) H H H H H H L L 1-1/2 3 7-1/2 3 7-1/2 15 25 15 50 — 75 — 100 — — — — — — — — — — — 7-1/2 15 30 60 125 200 250 — — — 20 40 50 — — — DH321FGK DH322FGK DH323FGK DH324FGK DH325FGK DH326FGK DH327FGK DH328FGK 782113208510 782113205809 782113206240 782113206660 782113207049 782113207391 782113589701 782114312872 DH321FRK DH322FRK DH323FRK DH324FRK DH325FRK DH326FRK DH327FRK DH328FRK 782113208497 782113205816 782113206257 782113206677 782113207056 782113207407 782113589718 782114312988 DH321FDK DH322FDK DH323FDK DH324FDK DH325FDK DH326FDK DH327FDK DH328FDK 782113205410 782113205908 782113206318 782113206721 782113207148 782113207483 782113589824 782116120932 DH321FWK 782113205427 DH322FWK 782113205915 — DH324FWK 782113206738 DH325FWK 782114357224 DH326FWK 782114357286 DH327FWK 782114357330 DH328FWK 782116120956 782113205434 782113205922 782113206332 782113206745 782113207162 782113207506 — 782116120949 DH321NWK DH322NWK DH323NWK DH324NWK DH325NWK DH326NWK 782113205441 782113205939 782113206349 782113206752 782114375181 782114375211 — DH328NWK 782116120963 782113205458 782113205946 782113206356 782113206769 — — 4-Wire (Three Blades, Three Fuses, S/N) — 240 Vac, 250 Vdc 4-Pole — 240 Vac, 250 Vdc H H H H H H 3 7-1/2 15 30 50 — 30 60 100 200 400 600 3 7-1/2 15 25 50 75 — — — — — — — — 7-1/2 15 30 60 125 200 — — — — 20 — 50 — — — DH321NGK DH322NGK DH323NGK DH324NGK DH325NGK DH326NGK DH327NGK DH328NGK 782113208503 782113205823 782113206264 782113206684 782113207063 782113207414 782113639246 782114312896 DH321NRK DH322NRK DH323NRK DH324NRK DH325NRK DH326NRK DH327NRK DH328NRK 782113205373 782113205830 782113206271 782113206691 782113207070 782113207421 782113639253 782114313008 DH321NDK DH322NDK DH323NDK DH324NDK DH325NDK DH326NDK 5 10 20 40 50 — DH421FGK DH422FGK DH423FGK DH424FGK DH425FGK DH426FGK 782113205380 782113205847 782113206288 782114121306 782113952192 782113207438 — — — — — — DH421FDK DH422FDK DH423FDK DH424FDK DH328NDK 3-Phase 3 7-1/2 15 25 50 75 100 — — — — — — — — — 2-Phase H H H H H H L L 3-Phase 30 60 100 200 400 600 800 1200 2-Phase Disconnects 30 60 100 200 400 600 800 1200 7-1/2 10 20 15 30 30 50 60 — 125 — 200 — — — — — — Horsepower ratings apply only when neutral is field installed and switch is used on a grounded B phase system. Use 3-pole catalog numbers below. NEMA 12 enclosures (30 – 800 amperes) can be field modified to meet NEMA 3R rainproof requirements when a factory provided drain hole is opened. Contact the Safety Switch Flex Center (1-888-329-9272) for availability of this product. Grounded B phase ratings, UL listed. Note: 30 ampere heavy-duty switches with Type J fuse provisions are available from the factory only. 6-12 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 600 VAC HEAVY-DUTY, FUSIBLE, SINGLE THROW Specifications ✓ Suitable for service entrance use, except 1200 ampere ✓ 30 – 1200 amperes. ✓ Horsepower rated. on 480Y/277 or 600Y/347 grounded wye systems, per NEC姞 215-10 and 230-95, and 4-pole switches. ✓ UL listed File No. E5239. Maximum Horsepower Ratings with Time Delay Fuses Catalog Number 600 V 250 V 600 V 480 V 600 V 1-Phase ac 3-Phase ac dc 480 V Fuse Class Provision Ampere Rating TABLE 6-19. FUSIBLE 277/480 – 600 VOLTS NEMA 1 Enclosure UPC Indoor Code NEMA 3R Enclosure UPC Rainproof Code NEMA 12 Enclosure Industrial, Dust-tight UPC Code NEMA 4X Enclosure Corrosion Resistant, Stainless Steel UPC Code 2-Pole — 480 Vac — 600 Vac or dc (Suitable for Service Entrance Use with a Neutral or Ground Lug Kit Installed) 30 60 100 200 400 600 800 1200 H H H H H H L L 7-1/2 20 30 50 — — — — 10 25 40 50 — — — — — — — — — — — — — — — — — — — — — — 20 — 50 — — — 15 25 — 50 — — — — DH261FGK DH262FGK DH263FGK DH264FGK DH265FGK DH266FGK DH267FGK 782113205465 782113205960 782113206363 782113206776 782113207186 782113207537 782113589688 — DH261FDK DH262FDK DH263FDK DH264FDK DH265FDK DH266FDK DH267FDK DH261FWK or or DH264FWK or or or 782113205564 782113206097 782113206523 782113206844 782113207292 782113589626 782113589794 — 782113205588 — — 782113206868 — — — — 782113205496 782113205991 782113206424 782113206790 782113207216 782113207568 782113589732 782114313022 DH361FDK DH362FDK DH363FDK DH364FDK DH365FDK DH366FDK DH367FDK DH368FDK 782113205595 782113206141 782113206554 782113206875 782113207315 782113207636 782113589848 782116120970 DH361FWK DH362FWK DH363FWK DH364FWK DH365FWK DH366FWK DH367FWK DH368FWK 782113205618 782113206165 782113206585 782113206905 782114357378 782114357491 782114357606 782116121007 782113205731 782113206189 782113206592 782113206912 782113207346 782113207667 — 782116120987 DH361NWK DH362NWK DH363NWK DH364NWK DH365NWK DH366NWK — — — — — — — — — DH361FRK DH362FRK DH363FRK DH364FRK DH365FRK DH366FRK DH367FRK DH368FRK 30 60 100 200 400 600 800 1200 H H H H H H L L 7-1/2 20 30 50 — — — — 10 25 40 50 — — — — 15 30 60 125 250 400 500 500 20 50 75 150 350 500 500 500 — — — — — — — — — — — — — — — — DH361FGK DH362FGK DH363FGK DH364FGK DH365FGK DH366FGK DH367FGK DH368FGK 782113205489 782113205977 782113206417 782113206783 782113207209 782113207551 782113589725 782114312919 4-Wire (Three Blades, 3-Fuses, S/N) 480 Vac— 600 Vac, 250 Vdc 30 60 100 200 400 600 800 1200 H H H H H H L L 7-1/2 20 30 50 — — — — 10 25 40 50 — — — — 15 30 60 125 250 400 500 500 20 50 75 150 350 500 500 500 — — — — — — — — — — — — — — — — DH361NGK DH362NGK DH363NGK DH364NGK DH365NGK DH366NGK DH367NGK DH368NGK 782113205526 782113206035 782113206486 782113206820 782113207247 782113207599 782113639260 782114312933 DH361NRK DH362NRK DH363NRK DH364NRK DH365NRK DH366NRK DH367NRK DH368NRK 782113205533 782113206059 782113206493 782113206837 782113207261 782113207605 782113639277 782114313046 DH361NDK DH362NDK DH363NDK DH364NDK DH365NDK DH366NDK — — — 40 50 — — — — — — — — — DH461FGK DH462FGK DH463FGK DH464FGK DH465FGK DH466FGK 782113205540 782113206066 782113206509 782114121313 782113952208 782113952222 — — — — — — — — DH368NDK 782113211770 782113206196 782113206608 782113206929 782114357415 782114357538 — DH368NWK 782116121014 Disconnects 3-Pole — 480 Vac — 600 Vac, 250 Vdc (Suitable for Service Entrance Use with a Neutral or Ground Lug Kit Installed) 4-Pole — 2-Phase ac 3-Phase ac 480 Vac— 600 Vac, 250 Vdc 30 60 100 200 400 600 800 H H H H H H L 20 40 50 — — — — 25 50 50 — — — — 15 30 60 125 250 400 500 20 50 75 150 350 500 500 — — DH463FDK 782113206615 DH464FDK 782113206981 — — — — — — — — — — dc rating for 400 – 800 ampere switches is 250 volts. Contact the Safety Switch Flex Center (1-888-329-9272) for availability of this product. Use 3-pole catalog numbers below. NEMA 12 enclosures (30 – 800 amperes) can be field modified to meet NEMA 3R rainproof requirements when a factory provided drain hole is opened. Use 3-pole catalog numbers below. Note: 30 ampere heavy-duty switches with Type J fuse provisions are available from the factory only. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-13 600 VAC HEAVY-DUTY, NON-FUSIBLE, SINGLE THROW Specifications ✓ Suitable for service entrance use, except 1200 ampere ✓ 30 – 1200 amperes. ✓ Horsepower rated. on 480Y/277 or 600Y/347 grounded wye systems, per NEC 215-10 and 230-95, and 4-pole switches. ✓ UL listed File No. E5239. TABLE 6-20. NON-FUSIBLE 277/480 – 600 VOLTS Maximum Horsepower Ratings UPC Code NEMA 4X Enclosure Corrosion Resistant, Stainless UPC Steel Code or or or or or or — — — — — — — — 782113205724 782113206172 782113206578 782113206899 782114366110 782114357576 782114357651 782116121021 600 V dc 250 V 600 V 480 V 240 V 3-Phase ac 600 V 480 V 240 V Ampere Rating 1-Phase ac Catalog Number NEMA 1 Enclosure UPC Indoor Code NEMA 3R Enclosure UPC Rainproof Code NEMA 12 Enclosure Industrial, Dust-tight 2-Pole — 480 Vac — 600 Vac or dc (Suitable for Service Entrance Use with a Neutral or Ground Lug Kit Installed) 30 60 100 200 400 600 800 1200 3 10 20 15 — — — — 7-1/2 20 30 50 — — — — 10 25 40 50 — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — 20 — 50 — — — 15 25 25 50 — — — — DH261UGK DH262UGK DH263UGK — DH265UGK DH266UGK DH267UGK 782113205472 782114858844 782113206394 — 782113207193 782113207544 782113589695 — — — — — — — — — DH261UDK DH262UDK DH263UDK DH264UDK DH265UDK DH266UDK DH267UDK 782113205571 782113206110 782113206530 782113206851 782113207308 782113589633 782113589800 — 3-Pole — 480 Vac — 600 Vac, 250 Vdc (Suitable for Service Entrance Use with a Neutral or Ground Lug Kit Installed) Disconnects 30 60 100 200 400 600 800 1200 3 10 20 15 — — — — 7-1/2 20 40 50 — — — — 4-Pole/ 2-Phase ac 480 Vac/ 600 Vac, 250 Vdc 30 60 100 200 400 600 800 10 20 40 50 50 — — 20 40 50 50 — — — 10 25 50 50 — — — — 10 20 40 60 125 200 — — 20 50 75 125 250 400 500 500 30 60 100 150 350 500 500 500 5 10 20 40 50 — — — — — — — — — — — DH361UGK DH362UGK DH363UGK DH364UGK DH365UGK DH366UGK DH367UGK DH368UGK 782113205502 782113206004 782113206455 782113206806 782113207223 782113207575 782113589749 782114312964 DH361URK DH362URK DH363URK DH364URK DH365URK DH366URK DH367URK DH368URK 782113205519 782113206028 782113206479 782113206813 782113207230 782113207582 782113589756 782114313077 DH361UDK DH362UDK DH363UDK DH364UDK DH365UDK DH366UDK DH367UDK DH368UDK 782113205601 782113206158 782113206561 782113206882 782113207322 782113207643 782113589862 782116120994 DH361UWK DH362UWK DH363UWK DH364UWK DH365UWK DH366UWK DH367UWK DH368UWK 5 10 20 40 50 — — — — — — — — — DH461UGK DH462UGK DH463UGK DH464UGK DH465UGK DH466UGK 782113205557 782113206080 782113206516 782114121320 782113952215 782113952239 — — — — — — — — DH461UDK DH462UDK DH463UDK DH464UDK 782113205748 782113206202 782113206622 782113207001 — — — DH461UWK 782113713366 — — — — — — 3-Phase ac 25 10 20 30 50 20 50 60 50 40 75 100 50 60 125 150 — 125 250 350 — 200 400 500 — — — — dc rating for 400 – 800 ampere switches is 250 volts. Contact the Safety Switch Flex Center (1-888-329-9272) for availability of this product. Use 3-pole catalog numbers below. NEMA 12 enclosures (30 – 800 amperes) can be field modified to meet NEMA 3R rainproof requirements when a factory provided drain hole is opened. 6-14 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 240 VAC HEAVY-DUTY, FUSIBLE, NON-FUSIBLE, DOUBLE THROW Specifications ✓ Suitable for use as a manually operated switch ✓ 30 – 800 amperes. ✓ Horsepower rated. ✓ Suitable for service entrance use with neutral or per 2002 NEC Article 702. ✓ Fusible and non-fusible. ✓ UL listed File No. E5239. ground lug kit installed. TABLE 6-21. FUSIBLE Ampere Rating Main and Standby Maximum Horsepower Ratings with Time Delay Fuses Fuse Class Provision Catalog Number 240 V 480 V 600 V 240 V NEMA 1 dc Enclosure 480 V 600 V 250 V Indoor 15 1-Phase ac UPC Code NEMA 3R Enclosure Rainproof UPC Code 3-Phase ac 2-Pole — 240 Vac — 250 Vdc 200 H — — — — — 40 DT224FGK 782113614007 DT224FRK 782113614014 — — — — — — — — — — — — 7-1/2 15 30 60 125 50 — — — — — — — — — — — — 5 10 20 40 50 50 DT321FGK DT322FGK DT323FGK DT324FGK DT325FGK DT326FGK 782113426280 782113426303 782113426327 782113614021 782113725758 782113725765 DT321FRK DT322FRK DT323FRK DT324FRK DT325FRK DT326FRK 782113426297 782113426310 782113426334 782113614038 782114215821 782114733639 3-Pole — 240 Vac — 250 Vdc 30 60 100 200 400 600 H H H H H T 3 10 15 15 — — Only available for use with fast acting fuses. Standard hp rating is shown. TABLE 6-22. NON-FUSIBLE Maximum Horsepower Ratings 1-Phase ac 240 V 480 V Catalog Number 3-Phase ac 600 V NEMA 1 Enclosure Indoor UPC Code NEMA 3R Enclosure Rainproof 240 V 480 V 600 V dc 250 V — — — — — — — — — — — — — — — — — — 5 10 20 40 50 — DT221UGK DT222UGK DT223UGK DT224UGK DT225UGK DT226UGK 782113439990 782113440002 782113440019 782113613932 782113738253 782113738284 10 20 40 60 125 125 125 125 — — — — — — — — — — — — — — — — 5 10 20 40 50 50 50 50 DT321UGK DT322UGK DT323UGK DT324UGK DT325UGK DT326UGK DT327UGK DT327UGK-N 782113440026 782113440033 782113440040 782113613963 782113696423 782113696454 782113696485 782114176900 UPC Code Non-Fusible 2-Pole — 240 Vac — 250 Vdc 30 60 100 200 400 600 3 10 20 15 — — — — — — — — — — — — — — DT224URK DT225URK — — — 782113713380 782113752280 — Disconnects Ampere Rating Main and Standby Non-Fusible 3-Pole — 240 Vac — 250 Vdc 30 60 100 200 400 600 800 800 3 10 20 15 — — — — — — — — — — — — — — — — — — — — DT323URK DT324URK DT325URK — — 782113757032 782113638874 782116153466 — — — WARNING! Switch is not approved for service entrance. Field-installable neutral kit is not available. If a neutral is required, order the catalog number shown in the table with “N” suffix. Contact the Safety Switch Flex Center (1-888-329-9272) for availability of this product. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-15 600 VAC HEAVY-DUTY, FUSIBLE, NON-FUSIBLE, DOUBLE THROW Maximum Horsepower Ratings with Time Delay Fuses NEMA 1 Enclosure UPC Code Indoor — — — 40 50 DT361FGK DT362FGK DT363FGK DT364FGK DT365FGK NEMA 3R Enclosure UPC Rainproof Code UPC Code — — — — — NEMA 4X Enclosure Corrosion Resistant, Stainless Steel 250 V 600 V dc NEMA 12 Enclosure Industrial, Dust-tight Catalog Number 3-Phase ac 480 V 600 V 1-Phase ac 480 V Fuse Class Provision Ampere Rating Main and Standby TABLE 6-23. FUSIBLE UPC Code 3-Pole — 600 Vac — 250 Vdc 30 60 100 200 400 7-1/2 20 30 50 — H H H H T 10 25 40 50 — 15 30 60 125 250 20 50 75 150 350 782113426341 782113426372 782113426402 782113614045 782113725772 DT363FRK DT364FRK DT365FRK — — 782113701011 782113614052 782114140635 DT361FWK DT362FWK DT363FWK DT364FWK DT365FWK 782114358085 782114344460 782114358047 782114264584 782114344484 Contact the Safety Switch Flex Center (1-888-329-9272) for availability of this product. TABLE 6-24. NON-FUSIBLE NEMA 4X Enclosure Corrosion Resistant, Stainless Steel Catalog Number UPC Code NEMA 12 Enclosure Industrial, Dust-tight UPC Code DT264URK DT265URK DT266URK — — — 782113613956 782113738277 782113738291 — — — — — — — — — — — — — — — — — — — — — — — — 782113426358 782113426389 782113426419 782113613970 782113696430 782113696461 782113696492 782114176894 DT361URK DT362URK DT363URK DT364URK DT365URK DT366URK DT367URK DT367URK-N 782113426365 782113426396 782113426426 782113613987 782113696447 782113696478 782113696508 782114792117 DT361UDK DT362UDK DT363UDK DT364UDK DT365UDK DT361UWK DT362UWK DT363UWK DT364UWK DT365UWK 782113740812 782113740829 782113740836 782113774367 782113916224 — — — 782113747941 782113747958 782113747965 782113865621 782114140642 — — — — — — 782113613994 782113949314 782113960678 782113949352 DT461URK DT462URK DT463URK DT464URK DT465URK DT466URK DT467URK 782113620626 782113620633 782113620640 782113638881 782113949321 782113949345 782113949369 — — — — — — — — — — — — — — — — — DT661URK DT662URK DT663URK 782113573755 782113573854 782113573762 — — — — — — 250 V 600 V 480 V 600 V 480 V Ampere Rating Main and Standby Maximum Horsepower Ratings NEMA 1 Enclosure Indoor NEMA 3R Enclosure Rainproof UPC Code 5 10 20 40 50 50 DT261UGK DT262UGK DT263UGK DT264UGK DT265UGK DT266UGK 782113426259 782113426266 782113426273 782113613949 782113738260 782113741147 5 10 20 40 50 50 50 50 DT361UGK DT362UGK DT363UGK DT364UGK DT365UGK DT366UGK DT367UGK DT367UGK-N UPC Code 2-Pole — 600 Vac — 250 Vdc Disconnects 30 60 100 200 400 600 7-1/2 20 40 50 — — 10 25 50 50 — — — — — — — — — — — — — — 3-Pole — 600 Vac — 250 Vdc 30 60 100 200 400 600 800 800 7-1/2 20 40 50 — — — — 10 25 50 50 — — — — 20 50 75 125 250 250 250 250 30 60 100 150 350 350 350 350 4-Pole — 600 Vac — 250 Vdc 30 60 100 200 400 600 800 7-1/2 20 40 — — — — 10 25 50 50 — — — 20 50 75 125 250 250 250 30 60 100 150 350 350 350 5 10 20 40 50 50 50 DT464UGK DT465UGK DT466UGK DT467UGK 6-Pole — 600 Vac — 250 Vdc 30 60 100 7-1/2 10 20 25 40 50 15 30 5 50 60 10 75 100 20 Rated 600 Vdc, 50 hp in addition to ratings shown in table. Contact the Safety Switch Flex Center (1-888-329-9272) for availability of this product. WARNING! Switch is not approved for service entrance. Field installable neutral kit is not available. If a neutral is required, order the catalog number shown in the table with “N” suffix. NEMA 12 enclosures (30 – 800 amperes) can be field modified to meet NEMA 3R rainproof requirements when a factory provided drain hole is opened. Also available in 240 Vac catalog number DT325UDK. 6-16 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 240 VAC GENERAL-DUTY, NON-FUSIBLE, COMPACT DESIGN, DOUBLE THROW Specifications TABLE 6-25. NON-FUSIBLE ✓ 30 – 100 amperes. ✓ Suitable for service entrance use with neutral kit installed. ✓ Suitable for use as a manually operated switch per 2002 NEC Article 702. ✓ Non-fusible. ✓ UL listed File No. E5239. NEMA 3R Enclosure Rainproof Ampere Rating Main and Standby Catalog Number UPC Code Non-Fusible 2-Pole — 240 Vac 30 60 100 DT221URH DT222URH DT223URH 782114886793 782114886809 782114886816 Non-Fusible 2-Pole, 3-Wire — 240 Vac — Solid Neutral 30 60 100 DT221URH-N DT222URH-N DT223URH-N 782114886823 782114886830 782114886854 240 VAC GENERAL-DUTY, NON-FUSIBLE, DOUBLE THROW Specifications ✓ 30 – 400 amperes. ✓ Horsepower rated. ✓ Suitable for service entrance use with neutral kit ✓ Suitable for use as a manually operated switch per 2002 NEC Article 702. ✓ Quick-make, quick-break operating mechanism. ✓ UL listed File No. E5239. installed. Maximum Horsepower Ratings with Time Delay Fuses Ampere Rating Main and Standby 1-Phase ac 240 V 3-Phase ac 480 V 600 V 240 V 480 V 600 V dc 250 V — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — NEMA 3R Enclosure Rainproof Catalog Number UPC Code 5 10 20 40 50 DT221URKPS DT222URKPS DT223URKPS DT224URKPS DT225URKPS 782114224380 782114224373 782114223970 782114223956 782114223963 5 10 20 40 50 DT221URK-NPS DT222URK-NPS DT223URK-NPS DT224URK-NPS DT225URK-NPS 782114495810 782114495827 782114495834 782114229262 782114229279 Non-Fusible 2-Pole — 240 Vac — 250 Vdc 30 60 100 200 400 3 10 20 15 — Non-Fusible 2-Pole, 3-Wire — 240 Vac — 250 Vdc, Solid Neutral 30 60 100 200 400 3 10 20 15 — — — — — — — — — — — — — — — — EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 Disconnects TABLE 6-26. 240 VAC GENERAL-DUTY, NON-FUSIBLE, DOUBLE THROW 6-17 Accessories TABLE 6-27. SAFETY SWITCHES — ACCESSORIES Disconnects Description Catalog Number UPC Code Neutral Kits/Ground Kits 30 Ampere DG 60 – 100 Ampere DG 200 Ampere DG, DH (NEMA 1, 3R Enclosures) 30 – 60 Ampere DH 100 Ampere DH 200 Ampere DH (NEMA 4X, 12 Enclosures) 400 Ampere DG, DH 600 Ampere DG, DH 400 – 600 Ampere Fusible DT, 800 – 1200 Ampere DH 30 – 100 Ampere DT 200 Ampere DT 400 Ampere Non-Fusible DT 600 Ampere Non-Fusible DT DG030NB DG100NB DG200NK DH030NK DH100NK DH200NK DS400NK DS600NK DS800NK DT100NK DT200NK DT400NK DT600NK 782114731178 782114731185 782113213583 782113253251 782113253268 782113253275 782113208206 782113208213 782113584621 782113445717 782113617619 782113774961 782113774978 Ground Lug Kits 30 – 100 Ampere DG 30 – 100 Ampere DH, DT 200 Ampere DG, DH, DT 400 – 600 A DG, 400 – 1200 A DH, 400 – 800 A DT DG030GB DS100GK DS200GK DS468GK 782114496053 782113324609 782113381206 782113552033 Switching Neutral Bonding Kits 30 – 100 Ampere DT, 3-Pole, 4-Pole Non-Fusible 200 Ampere DT, 3-Pole, 4-Pole Non-Fusible 400 Ampere DT, 3-Pole, 4-Pole Non-Fusible 600 Ampere DT, 3-Pole, 4-Pole Non-Fusible 800 Ampere DT, 3-Pole, 4-Pole Non-Fusible DT100BK DT200BK DT400BK DT600BK DT800BK 782116153411 782116153428 782116153435 782116153442 782116153459 Control Pole Kit (for 2-Pole, 3-Pole Switches, Non-Fusible) 400 – 600 A DG, 30 – 1200 A DH, 30 – 800 A DT DS16CP 782113392127 Auxiliary Contact Kits All Switches (except 30 – 100 Ampere DG) 1NO/1NC All Switches (except 30 – 100 Ampere DG) 2NO/2NC DS200EK1 DS200EK2 782113208121 782113208145 Copper Lug Kits 30 Ampere DH, DT 60 Ampere DH, DT 100 Ampere DH, DT 200 Ampere DH 400 Ampere DH (NEMA 4, 4X, 12 Enclosures) 600 – 800 Ampere DH (NEMA 4, 4X, 12 Enclosures) DS16CL DS16CL DS36CL DS46CL DS56CL DS66CL 782113207995 782113207995 782113208084 782113208091 782113208107 782113208114 Crimp Lug Pad Kit (NEMA 4, 4X, 12 Enclosures) 400 – 600 Ampere DH 800 Ampere DH 400 – 800 Ampere Neutral DH DS56CK DS76CK DS800CNK 782113552057 782113552064 782113690193 Ground bar kit is not listed on device publications. Order one kit for 3 poles. Order one kit for each pole. Order one kit per switch. DH030NK DS200GK DS16CP DS200EK1 DS36CL Note: A factory-installed ground lug is supplied on all NEMA 4, 4X and 12 safety switches, as well as all 400 ampere and higher NEMA 1 and 3R safety switches. A factory-installed ground lug is also supplied on all Heavy-Duty NEMA 1 and 3R 30 – 200 ampere switches that do NOT have factory-installed neutral. DS56CK 6-18 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 Accessories Table 6-27. SAFETY SWITCHES — ACCESSORIES (CONTINUED) Catalog Number UPC Code Fuse Puller Kits 30 – 60 Ampere DH 30 – 60 Ampere DH 100 Ampere DH 200 Ampere DH DS30FP DS60FP DS100FP DS200FP 782113730424 782113730431 782113730448 782113730455 “J” Fuse Adapter Kits 60 Ampere 240 Volt DH 60 Ampere DT and Receptacle Switches 400 Ampere 600 Volt DT 600 Ampere 240 – 600 Volt DH only DS22JK DS26JK DT400JK DS600JK 782113207773 782113207780 782113774985 782113110912 “R” Fuse Adapter Kits 30 Ampere DG 100 Ampere DG 30 Ampere 240 Volt DH, DT 30 A 600 Volt DH, DT, 60 A 240 Volt DH, DT, 60 A DG 60 Ampere 600 Volt DH, DT 100 Ampere 240 – 600 Volt DH, DT 200 Ampere 240 – 600 Volt DH, DT, 200 A DG 400 Ampere 240 – 600 Volt DH, 240 Volt DT, 400 A DG 600 Ampere 240 – 600 Volt DH, 600 Ampere DG DG030RB DG100RB DS12FK DS16FK DS26FK DS36FK DS46FK DS56FK DS66FK 782114496046 782114731161 782113207681 782113207698 782113207704 782113209678 782113207728 782113207735 782113207742 “T” Fuse Adapter Kits 200 Ampere 240 Volt DH 200 Ampere 600 Volt DH 400 Ampere 240 Volt DG, DH 400 Ampere 600 Volt DH 600 Ampere 240 Volt DG, DH 600 Ampere 600 Volt DH 800 Ampere 240 Volt DH 800 Ampere 600 Volt DH DS426TK DS466TK DS526TK DS566TK DS626TK DS666TK DS726TK DS766TK 782113207810 782113207896 782113207872 782113207902 782113207889 782113207919 782113536453 782113536460 Hookstick Handle DH800HSH 782114112984 Lubricating Grease for Safety Switch Blades and Contacts (Each kit contains three 30 cc tubes of lubricating grease.) DSLUBEKIT 782113691404 Order one kit for 3 poles. Receptacle switches. Order one kit for 6 poles. Order one kit for each pole. DS60FP DS12FK DS22JK DS426TK Disconnects Description Note: A factory-installed ground lug is supplied on all NEMA 4, 4X and 12 safety switches, as well as all 400 ampere and higher NEMA 1 and 3R safety switches. A factory-installed ground lug is also supplied on all Heavy-Duty NEMA 1 and 3R 30 – 200 ampere switches that do NOT have factory-installed neutral. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-19 ACCESSORIES, HUBS, LUG DATA TABLE 6-28. PLATE TYPE HUBS For NEMA 3R Enclosures (Up to 200 Amperes) Group 1 General-Duty, Heavy-Duty, Double Throw Through 100 A Group 2 General-Duty, Heavy-Duty, Double Throw — 200 A Conduit Size Conduit Size Inches mm Catalog Number 0.75 1.00 1.25 1.50 2.00 19.1 25.4 31.8 38.1 50.8 DS075H1 DS100H1 DS125H1 DS150H1 DS200H1 UPC Code Inches mm Catalog Number UPC Code 782113109916 782113109923 782113109930 782113109947 782113109954 2.00 2.50 3.00 — — 50.8 63.5 76.2 — — DS200H2 DS250H2 DS300H2 — — 782113109961 782113109978 782113342276 — — Catalog Number DS900AP Adapter Kit — Permits Installation of Group 1 Hubs on 200 Ampere Type General-Duty, Heavy-Duty and Double Throw Switches TABLE 6-29. MYERS TYPE HUBS TABLE 6-30. STANDARD LUG CAPACITIES NEMA 3R (400 Amperes and Above) NEMA 4, 4X (Stainless Steel), 12 Conduit Size Disconnects Inches mm Catalog Number 0.50 0.75 1.00 1.25 1.50 2.00 2.50 3.00 3.50 4.00 5.00 12.7 19.1 25.4 31.8 38.1 50.8 63.5 76.2 88.9 101.6 127.0 DS050MH DS075MH DS100MH DS125MH DS150MH DS200MH DS250MH DS300MH DS350MH DS400MH DS500MH Minimum Maximum Wire Size Wire Size Wire Type 30 Ampere DP #14 #12 #10 #10 Cu OR Al 30 Ampere DG 30 Ampere DH, DT #14 #14 #6 #2 Cu/Al Cu/Al 60 Ampere DG 60 Ampere DH, DT #14 #14 #1/0 #2 Cu/Al Cu/Al 100 Ampere DG 100 Ampere DH, DT #14 #14 #1/0 #1/0 Cu/Al Cu/Al 200 Ampere DG, DT 200 A DH Type 1 and 3R 200 A DH Type 4 and 12 #6 #6 #6 250 kcmil 250 kcmil 300 kcmil Cu/Al Cu/Al Cu/Al 400 Ampere DG, DH, DT (2) #1/0 (1) #1/0 (2) 300 kcmil Cu/Al OR (1) 750 kcmil Cu/Al Description UPC Code 782113120508 782113110981 782113111001 782113111025 782113111049 782113120522 782113111070 782113111094 782113111117 782113111131 782113111155 Note: Contact the Flex Center at 1-888-329-9272 for information on hubs for non-metallic NEMA 4X switches. 600 A DG, DH, Fusible DT (1) #2 (1) #1/0 (1) 600 kcmil Cu/Al AND (1) 750 kcmil Cu/Al 600 A Non-Fusible DT (2) #250 (2) 500 kcmil Cu/Al 800 Ampere DH 800 Ampere DT (4) #1/0 (3) #250 (4) 750 kcmil Cu/Al (3) 500 kcmil Cu/Al 1200 Ampere DH (4) #1/0 (4) 750 kcmil Cu/Al 30 Ampere Cu 60 Ampere Cu 100 Ampere Cu #14 #14 #6 #6 #4 #1/0 200 Ampere Cu 400 Ampere Cu 600 Ampere Cu #6 #1/0 (2) #1/0 250 kcmil Cu 500 kcmil Cu (2) 500 kcmil Cu Copper-Bodied Lugs DS075H1 Cu Cu Cu The maximum size aluminum or copper-clad aluminum wire allowable for applications where the conductor enters or leaves the enclosure through the wall opposite its terminal is #1 gauge. Note: Although certain lug capacities are larger than required, only minimum wire bending space is provided per the requirements noted in NEC Tables 373-6 (a) and (b) for respective ampere ratings. Related Products Air-Conditioning Disconnects 6-20 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 Cross-Reference GENERAL-DUTY SAFETY SWITCHES TABLE 6-31. GENERAL-DUTY GENERAL-DUTY (CONTINUED) Catalog Number CutlerHammer姞 General Electric姞 Siemens姞 Square D姞 Plug Fuse, 1-Pole, 2-Wire, 120 Vac, NEMA 1 30 DP111NGB TPF130 LF111N DP221NGB TPF230 D211N LF211N D211N GF221N GF222N GF223N GF224N GF225N GF226N D221N D222N D223N D224N D225N D226N GF321N GF322N GF323N GF324N GF325N GF326N D321N D322N D323N D324N D325N D326N GF321N GF322N GF323N GF324N GF325N GF326N D321N D322N D323N D324N D325N D326N Fusible, 2-Pole, 3-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 DG221NGB DG222NGB DG223NGB DG224NGK DG225NGK DG226NGK TG3221 TG3222 TG3223 TG3224 TG3225 TG3226 Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 DG321NGB DG322NGB DG323NGB DG324NGK DG325FGK DG326FGK TG4321 TG4322 TG4323 TG4324 TG3325 TG3326 Fusible, 3-Pole, 4-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 DG321NGB DG322NGB DG323NGB DG324NGK DG325NGK DG326NGK TG4321 TG4322 TG4323 TG4324 TG4325 TG4326 DG221UGB DG222UGB DG223UGB DG324UGK DG325UGK DG326UGK TGN3321 TGN3322 TGN3323 TGN3324 TGN3325 TGN3326 N/A N/A N/A N/A N/A N/A N/A QO260NATS QO2000NS DU324 DU325 DU326 DG321UGB DG322UGB DG323UGB DG324UGK DG325UGK DG326UGK TGN3321 TGN3322 TGN3323 TGN3324 TGN3325 TGN3326 GNF321 GNF322 GNF323 GNF324 GNF325 GNF326 Siemens Square D 30 60 100 200 400 600 DG221NRB DG222NRB DG223NRB DG224NRK DG225NRK DG226NRK TG3221R TG3222R TG3223R TG3224R TG3225R TG3226R GF221NR GF222NR GF223NR GF224NR GF225NR GF226NR D221NRB D222NRB D223NRB D224NRB D225NR D226NR GF321NR GF322NR GF323NR GF324NR GF325NR GF326NR D321NRB D322NRB D323NRB D324NRB D325NR D326NR GF321NR GF322NR GF323NR GF324NR GF325NR GF326NR D321NRB D322NRB D323NRB D324NRB D325NR D326NR Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 3R 30 60 100 200 400 600 DG321NRB DG322NRB DG323NRB DG324NRK DG325FRK DG326FRK TG4321R TG4322R TG4323R TG4324R TG3325R TG3326R Fusible, 3-Pole, 4-Wire, 240 Vac, NEMA 3R 30 60 100 200 400 600 DG321NRB DG322NRB DG323NRB DG324NRK DG325NRK DG326NRK TG4321R TG4322R TG4323R TG4324R TG3325R TG3326R Non-Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 3R 30 60 100 200 DG221URB DG222URB DG223URB DG324URK TGN3321R TGN3322R TGN3323R TGN3324R GNF321R GNF322R GNF323R GNF324R DU221RB DU222RB QO2000NRB DU324RB 30 60 100 200 400 600 DG321URB DG322URB DG323URB DG324URK DG325URK DG326URK TGN3321R TGN3322R TGN3323R TGN3324R N/A N/A GNF321R GNF322R GNF323R GNF324R N/A N/A DU321RB DU322RB DU323RB DU324RB N/A N/A Separate neutral kit required. Non-Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 General Electric Non-Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 3R Non-Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 CutlerHammer Fusible, 2-Pole, 3-Wire, 240 Vac, NEMA 3R Plug Fuse, 2-Pole, 3-Wire, 240 Vac, NEMA 1 30 Ampere Rating Disconnects Ampere Rating Catalog Number DU321 DU322 DU323 DU324 DU325 DU326 Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-21 HEAVY-DUTY SAFETY SWITCHES TABLE 6-32. HEAVY-DUTY HEAVY-DUTY (CONTINUED) Catalog Number Ampere Rating CutlerHammer General Electric Catalog Number Siemens Square D Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 800 1200 DH221FGK DH222NGK DH223NGK DH224NGK DH225FGK DH226FGK DH227FGK DH328FGK TH3221 TH3222 TH3223 TH3224 TH3225 TH3226 TC72267 TC72268 DH221NGK DH222NGK DH223NGK DH224NGK DH225NGK DH226NGK DH227NGK DH328NGK TH3221 TH3222 TH3223 TH3224 TH3225 TH3226 TC72267 TC72268 N/A N/A N/A N/A N/A N/A N/A N/A H221N H222N H223N H224N H225 H226 H227 H228 Disconnects DH321FGK DH322FGK DH323FGK DH324FGK DH325FGK DH326FGK DH327FGK DH328FGK TH4321 TH4322 TH4323 TH4324 TH3325 TH3326 TC72367 TC72368 HF221N HF222N HF223N HF224N HF225N HF226N HF227N HF228N H221N H222N H223N H224N H225N H226N H227N H228N DH321NGK DH322NGK DH323NGK DH324NGK DH325NGK DH326NGK DH327NGK DH328NGK TH4321 TH4322 TH4323 TH4324 TH4325 TH4326 TC72367 TC72368 30 60 100 200 400 600 800 1200 DH221NRK DH222NRK DH223NRK DH224NRK DH225FRK DH226FRK DH227NRK DH328FRK 30 60 100 200 400 600 800 1200 DH221NRK DH222NRK DH223NRK DH224NRK DH225NRK DH226NRK DH227NRK DH328NRK N/A N/A N/A N/A N/A N/A N/A N/A H321N H322N H323N H324N H325 H326 H327 H328 HF321N HF322N HF323N HF324N HF325N HF326N HF327N HF328N H321N H322N H323N H324N H325N H326N H327N H328N F421 F422 F423 F424 F425 F426 H461 H462 H463 H464 H465 H466 30 60 100 200 400 600 800 1200 DH321FRK DH322FRK DH323FRK DH324FRK DH325FRK DH326FRK DH327FRK DH328FRK DH421FGK DH422FGK DH423FGK DH424FGK DH425FGK DH426FGK N/A N/A N/A N/A N/A N/A Non-Fusible, 3-Pole, 3-Wire, 240 Volt/600 Vac, NEMA 1 30 60 100 200 400 600 800 1200 DH361UGK DH362UGK DH363UGK DH364UGK DH365UGK DH366UGK DH367UGK DH368UGK THN3361 THN3362 THN3363 THN3364 THN3365 THN3366 TC36367 TC36368 HNF361 HNF362 HNF363 HNF364 HNF365 HNF366 HNF367 HNF368 HU361 HU362 HU363 HU364 HU365 HU366 HU367 HU368 Separate neutral kit required. 600 volt switch. Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. 6-22 Square D TH3221R TH3222R TH3223R TH3224R TH3225R TH3226R TC72267R TC72268R N/A N/A N/A N/A N/A N/A N/A N/A H221NRB H222NRB H223NRB H224NRB H225R H226R H227R H228R TH3221R TH3222R TH3223R TH3224R TH3225R TH3226R TC72267R TC72268R HF221NR HF222NR HF223NR HF224NR HF225NR HF226NR HF227NR HF228NR H221NRB H222NRB H223NRB H224NRB H225NR H226NR H227NR H228NR TH4321R TH4322R TH4323R TH4324R TH3325R TH3326R TC72367R TC72368R N/A N/A N/A N/A N/A N/A N/A N/A H321NRB H322NRB H323NRB H324NRB H325NR H326NR H327NR H328NR HF321NR HF322NR HF323NR HF324NR HF325NR HF326NR HF327NR HF328NR H321NRB H322NRB H323NRB H324NRB H325R H326R H327R H328R Fusible, 3-Pole, 4-Wire, 240 Vac, NEMA 3R 30 60 100 200 400 600 800 1200 DH321NRK DH322NRK DH323NRK DH324NRK DH325NRK DH326NRK DH327NRK DH328NRK Fusible, 4-Pole, 4-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 Siemens Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 3R Fusible, 3-Pole, 4-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 800 1200 General Electric Fusible, 2-Pole, 3-Wire, 240 Vac, NEMA 3R Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 800 1200 CutlerHammer Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 3R Fusible, 2-Pole, 3-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 800 1200 Ampere Rating TH4321R TH4322R TH4323R TH4324R TH3325R TH3326R TC72367R TC72368R Non-Fusible, 3-Pole, 3-Wire, 240 Volt/600 Vac, NEMA 3R 30 60 100 200 400 600 800 1200 DH361URK DH362URK DH363URK DH364URK DH365URK DH366URK DH367URK DH368URK THN3361R THN3362R THN3363R THN3364R THN3365R THN3366R N/A N/A HNF361R HNF362R HNF363R HNF364R HNF365R HNF366R HNF367R HNF368R HU361RB HU362RB HU363RB HU364RB HU365R HU366R HU367R HU368R HF221S HF222S HF223S HF224S HF325S HF326S H221DS H222DS H223DS H224DS H225DS H226DS Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 4/4X 30 60 100 200 400 600 DH221NWK DH222NWK DH223NWK DH224NWK DH225FWK DH226FWK TH2221SS TH2222SS TH3223SS TH3224SS TH3225SS TH3226SS Separate neutral kit required. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 HEAVY-DUTY SAFETY SWITCHES TABLE 6-32. HEAVY-DUTY (CONTINUED) HEAVY-DUTY (CONTINUED) Catalog Number CutlerHammer General Electric Siemens Square D Fusible, 2-Pole, 3-Wire 240 Vac, NEMA 4/4X 30 60 100 200 400 600 800 DH221NWK DH222NWK DH223NWK DH224NWK DH225NWK DH226NWK DH227NWK TH3221SS TH3222SS TH3223SS TH3224SS TH3225SS TH3226SS N/A HF321S HF322S HF323S HF324S HF325S HF326S HF327S DH321FWK DH322FWK DH323NWK DH324NWK DH325FWK DH326FWK DH327FWK TH3321SS TH3322SS TH4323SS TH4324SS TH4325SS TH4326SS N/A HF321S HF322S HF323S HF324S HF325S HF326S HF327S H221DS H222DS H223DS H224DS H225NDS H226NDS N/A H321DS H322DS H323DS H324DS H325DS H326DS N/A Fusible, 3-Pole, 4-Wire, 240 Vac, NEMA 4/4X 30 60 100 200 400 600 DH321NWK DH322NWK DH323NWK DH324NWK DH325NWK DH326NWK TH4321SS TH4322SS TH4323SS TH4324SS TH4325SS TH4326SS HF321S HF322S HF323S HF324S HF325S HF326S H321DS H322DS H323DS H324DS H325NDS H326NDS Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 12 30 60 100 200 400 600 800 1200 DH221NDK DH222NDK DH223NDK DH224NDK DH225FDK DH226FDK DH227FDK N/A TH2221J TH2222J TH3223J TH3224J TH3225J TH3226J N/A N/A DH221NDK DH222NDK DH223NDK DH224NDK DH225NDK DH226NDK DH227NDK N/A TH3221J TH3222J TH3223J TH3224J TH3225J TH3226J N/A N/A HF221J HF222J HF223J HF224J HF325J HF326J HF327J N/A H221AWK H222AWK H223AWK H224AWK H225AWK H226AWK H227AWK H228AWK DH321FDK DH322FDK DH323FDK DH324FDK DH325FDK DH326FDK DH327FDK N/A TH3321J TH3322J TH4323J TH4324J TH4325J TH4326J N/A N/A Siemens Square D 30 60 100 200 400 600 800 1200 DH321NDK DH322NDK DH323NDK DH324NDK DH325NDK DH326NDK N/A N/A TH4321J TH4322J TH4323J TH4324J TH4325J TH4326J N/A N/A HF321J HF322J HF323J HF324J HF325J HF326J HF327J N/A H321AWK H322AWK H323AWK H324AWK H325NAWK H326NAWK H327NAWK H328NAWK N/A N/A N/A N/A N/A N/A N/A N/A HF261 HF262 HF263 N/A HF265 HF266 N/A N/A H361 H362 H363 H364 H265 H266 H267 H268 HF361 HF362 HF363 HF364 HF365 HF366 HF367 HF368 H361 H362 H363 H364 H365 H366 H367 H368 HF361N HF362N HF363N HF364N HF365N HF366N HF367N HF368 H361N H362N H363N H364N H365N H366N H367N H368N N/A N/A N/A N/A N/A N/A H461 H462 H463 H464 H465 H466 Fusible, 4-Pole, 4-Wire, 240 Vac, NEMA 12 30 60 100 200 DH421FDK DH422FDK DH423FDK DH424FDK N/A N/A N/A N/A Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 1 30 60 100 200 400 600 800 1200 DH261FGK DH262FGK DH263FGK DH264FGK DH265FGK DH266FGK DH267FGK N/A TH2261DC TH2262DC TH2263DC N/A N/A N/A N/A N/A 30 60 100 200 400 600 800 1200 DH361FGK DH362FGK DH363FGK DH364FGK DH365FGK DH366FGK DH367FGK DH368FGK TH3361 TH3362 TH3363 TH3364 TH3365 TH3366 TC72367 TC72368 Fusible, 3-Pole, 4-Wire, 600 Vac, NEMA 1 HF221J HF222J HF223J HF224J HF325J HF326J HF327J N/A H221AWK H222AWK H223AWK H224AWK H225NAWK H226NAWK H227NAW H228NAWK Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 12 30 60 100 200 400 600 800 1200 General Electric Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 1 Fusible, 2-Pole, 3-Wire, 240 Vac, NEMA 12 30 60 100 200 400 600 800 1200 CutlerHammer Fusible, 3-Pole, 4-Wire, 240 Vac, NEMA 12 Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 4/4X 30 60 100 200 400 600 800 Ampere Rating Disconnects Ampere Rating Catalog Number 30 60 100 200 400 600 800 1200 DH361NGK DH362NGK DH363NGK DH364NGK DH365NGK DH366NGK DH367NGK DH368NGK TH3361 TH3362 TH3363 TH3364 TH3365 TH3366 TC72367 TC72368 Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 1 HF321J HF322J HF323J HF324J HF325J HF326J HF327J N/A H321AWK H322AWK H323AWK H324AWK H325AWK H326AWK H327AWK H328AWK Separate neutral kit required. 30 60 100 200 400 600 DH461FGK DH462FGK DH463FGK DH464FGK DH465FGK DH466FGK TH6661 TH6662 TH6663 TH6664 N/A N/A Separate neutral kit required. Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-23 HEAVY-DUTY SAFETY SWITCHES TABLE 6-32. HEAVY-DUTY (CONTINUED) HEAVY-DUTY (CONTINUED) Catalog Number Ampere Rating CutlerHammer Catalog Number General Electric Siemens Square D Non-Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 1 30 60 100 200 400 600 800 1200 DH261UGK DH362UGK DH263UGK DH364UGK DH265UGK DH266UGK DH267UGK N/A THN2261DC THN2262DC THN2263DC N/A N/A N/A N/A N/A DH461UGK DH462UGK DH463UGK DH464UGK DH465UGK DH466UGK THN6661 THN6662 THN6663 THN6664 N/A N/A HNF261 HNF262 HNF263 N/A HNF265 HNF266 N/A N/A HU361 HU362 HU363 HU364 HU265 HU266 HU267 HU268 N/A N/A N/A N/A N/A N/A HU461 HU462 HU463 HU464 HU465 HU466 HF261R HF262R HF263R N/A N/A HF265R HF266R N/A H361RB H362RB H363RB H364RB H265R H266R H267R H268R HF361R HF362R HF363R HF364R HF365R HF366R HF367R HF368R H361RB H362RB H363RB H364RB H365R H366R H367R H368R HF361NR HF362NR HF363NR HF364NR HF365NR HF366NR HF367NR HF368R H361NRB H362NRB H363NRB H364NRB H365NR H366NR H367NR H368NR HNF261R HNF262R HNF263R N/A HNF265R HNF266R N/A N/A HU361RB HU362RB HU363RB HU364RB HU265R HU266R HU267R HU268R Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 3R Disconnects 30 60 100 200 400 600 800 1200 DH361FRK DH362FRK DH363FRK DH364FRK DH365FRK DH366FRK DH367FRK DH368FRK TH2261RDC TH2262RDC TH2263RDC N/A N/A N/A N/A N/A Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 3R 30 60 100 200 400 600 800 1200 DH361FRK DH362FRK DH363FRK DH364FRK DH365FRK DH366FRK DH367FRK DH368FRK TH3361R TH3362R TH3363R TH3364R TH3365R TH3366R TC72367R TC72368R Fusible, 3-Pole, 4-Wire, 600 Vac, NEMA 3R 30 60 100 200 400 600 800 1200 DH361NRK DH362NRK DH363NRK DH364NRK DH365NRK DH366NRK DH367NRK DH368NRK TH3361R TH3362R TH3363R TH3364R TH3365R TH3366R TC72367R TC72368R Non-Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 3R 30 60 100 200 400 600 800 1200 DH361URK DH362URK DH363URK DH364URK DH365URK DH366URK DH367URK DH368URK THN2261RDC THN2262RDC THN2263RDC N/A N/A N/A N/A N/A Separate neutral kit required. Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. 6-24 General Electric Siemens Square D Non-Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 3R Non-Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 1 30 60 100 200 400 600 Ampere CutlerRating Hammer 30 60 100 200 DH461UDK DH462UDK DH463UDK DH464UDK THN6661 THN6662 THN6663 THN6664 N/A N/A N/A N/A N/A N/A N/A N/A Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 4/4X Stainless Steel 30 60 100 200 400 600 800 DH261FWK DH362FWK DH363FWK DH264FWK DH365FWK DH366FWK DH367FWK TH2261SSDC TH2262SSDC TH2263SSDC N/A N/A N/A N/A HF261S HF262S HF263S N/A HF265S HF266S N/A H361DS H362DS H363DS H364DS H265DS H266DS N/A Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 4/4X Stainless Steel 30 60 100 200 400 600 800 DH361FWK DH362FWK DH363FWK DH364FWK DH365FWK DH366FWK DH367FWK TH3361SS TH3362SS TH3363SS TH3364SS TH3365SS TH3366SS N/A HF361S HF362S HF363S HF364S HF365S HF366S HF367S H361DS H362DS H363DS H364DS H365DS H366DS N/A Fusible, 3-Pole, 4-Wire, 600 Vac, NEMA 4/4X Stainless Steel 30 60 100 200 400 600 DH361NWK DH362NWK DH363NWK DH364NWK DH365NWK DH366NWK TH3361SS TH3362SS TH3363SS TH3364SS TH3365SS TH3366SS HF361S HF362S HF363S HF364S HF365S HF366S H361DS H362DS H363DS H364NDS H365NDS H366NDS Non-Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 4/4X Stainless Steel 30 60 100 200 400 600 800 DH361UWK DH362UWK DH363UWK DH364UWK DH365UWK DH366UWK DH367UWK THN2261SSDC THN2262SSDC THN2263SSDC N/A N/A N/A N/A HNF261S HNF262S HNF263S N/A HNF265S HNF266S N/A HU361DS HU362DS HU363DS HU364DS HU265DS HU266DS N/A Non-Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 4/4X Stainless Steel 30 60 100 200 400 600 800 DH361UWK DH362UWK DH363UWK DH364UWK DH365UWK DH366UWK DH367UWK THN3361SS THN3362SS THN3363SS THN3364SS THN3365SS THN3366SS N/A HNF361S HNF362S HNF363S HNF364S HNF365S HNF366S HNF367S HU361DS HU362DS HU363DS HU364DS HU365DS HU366DS N/A Non-Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 4/4X Stainless Steel 30 60 100 200 DH461UWK N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A HU461DS HU462DS HU463DS HU464DS Separate neutral kit required. Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 HEAVY-DUTY SAFETY SWITCHES TABLE 6-32. HEAVY-DUTY (CONTINUED) HEAVY-DUTY (CONTINUED) Catalog Number General Electric Siemens Square D Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 12 30 60 100 200 400 600 800 1200 DH261FDK DH262FDK DH263FDK DH264FDK DH265FDK DH266FDK DH267FDK N/A TH2261JDC TH2262JDC TH2263JDC N/A N/A N/A N/A N/A DH361FDK DH362FDK DH363FDK DH364FDK DH365FDK DH366FDK DH367FDK N/A TH3361J TH3362J TH3363J TH3364J TH3365J TH3366J N/A N/A HF261J HF262J HF263J N/A HF265J HF266J N/A N/A H361AWK H362AWK H363AWK H364AWK H265AWK H266AWK H267AWK H268AWK HF361J HF362J HF363J HF364J HF365J HF366J HF367J N/A H361AWK H362AWK H363AWK H364AWK H365AWK H366AWK H367AWK H368AWK HF361J HF362J HF363J HF364J HF365J HF366J HF367J N/A H361AWK H362AWK H363AWK H364NAWK H365NAWK H366NAWK H367NAWK H368NAWK N/A N/A N/A N/A N/A H461AWK H462AWK H463AWK H464AWK H465AWK Fusible, 3-Pole, 4-Wire, 600 Vac, NEMA 12 30 60 100 200 400 600 800 1200 DH361NDK DH362NDK DH363NDK DH364NDK DH365NDK DH366NDK DH367NDK N/A THN3361J THN3362J THN3363J THN3364J THN3365J THN3366J N/A N/A Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 12 30 60 100 200 400 N/A N/A DH463FDK DH464FDK N/A TH6661 TH6662 TH6663 TH6664 N/A General Electric Siemens Square D N/A N/A N/A N/A N/A H461AWK H462AWK H463AWK H464AWK H465AWK Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 12 Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 12 30 60 100 200 400 600 800 1200 Ampere CutlerRating Hammer 30 60 100 200 400 N/A N/A DH463FDK DH464FDK N/A TH6661 TH6662 TH6663 TH6664 N/A Non-Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 12 30 60 100 200 400 600 800 1200 DH261UDK DH262UDK DH263UDK DH264UDK DH265UDK DH266UDK DH267UDK N/A THN2261JDC THN2262JDC THN2263JDC N/A N/A N/A N/A N/A HNF261J HNF262J HNF263J N/A HNF265J HNF266J N/A N/A HU361AWK HU362AWK HU363AWK HU364AWK HU265AWK HU266AWK HU267AWK HU268AWK Non-Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 12 30 60 100 200 400 600 800 1200 DH361UDK DH362UDK DH363UDK DH364UDK DH365UDK DH366UDK DH367UDK N/A THN3361J THN3362J THN3363J THN3364J THN3365J THN3366J N/A N/A HNF361J HNF362J HNF363J HNF364J HNF365J HNF366J HNF367J N/A HU361AWK HU362AWK HU363AWK HU364AWK HU365AWK HU366AWK HU367AWK HU368AWK Non-Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 12 30 60 100 200 400 DH461UDK DH462UDK DH463UDK DH464UDK N/A THN6661 THN6662 THN6663 THN6664 N/A N/A N/A N/A N/A N/A HU461AWK HU462AWK HU463AWK HU464AWK HU465AWK Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. Disconnects Ampere CutlerRating Hammer Catalog Number Separate neutral kit required. Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-25 DOUBLE-THROW SAFETY SWITCHES TABLE 6-33. DOUBLE THROW DOUBLE THROW (CONTINUED) Catalog Number Ampere Rating CutlerHammer General Electric Catalog Number Siemens Square D DT321FGK DT322FGK DT323FGK DT224FGK DT325FGK DT326FGK TDT3321 TDT3322 TDT3323 TDT3324 TDT3325 TDT3326 N/A N/A N/A DTF224 N/A N/A N/A N/A DT223 DT224 N/A N/A DTF321 DTF322 DTF323 DTF324 DTF325 DTF326 DT321 DT322 DT323 DT324 N/A N/A Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 DT321FGK DT322FGK DT323FGK DT324FGK DT325FGK DT326FGK TDT3321 TDT3322 TDT3323 TDT3324 TDT3325 TDT3326 Non-Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 800 DT221UGK DT222UGK DT223UGK DT224UGK DT225UGK DT226UGK DT327UGK N/A N/A N/A N/A N/A N/A N/A DTNF221 DTNF222 DTNF223 DTNF224 DTNF225 DTNF226 N/A 92251 DTU222 DTU223 DTU224 92255 N/A N/A Non-Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 1 Disconnects 30 60 100 200 400 600 800 DT321UGK DT322UGK DT323UGK DT324UGK DT325UGK DT326UGK DT327UGK TC35321 TC35322 TC35323 TC35324 TC35325 TC35326 N/A DTNF321 DTNF322 DTNF323 DTNF324 DTNF325 DTNF326 DTNF327 DTU321 DTU322 DTU323 DTU324 92355 92356 N/A DTNF361 DTNF362 DTNF363 DTNF364 DTNF365 N/A DT361 DT362 DT363 DT364 N/A N/A Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 1 30 60 100 200 400 600 DT361FGK DT362FGK DT363FGK DT364FGK DT365FGK N/A TDT3361 TDT3362 TDT3363 TDT3364 TDT3365 N/A Non-Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 1 30 60 100 200 400 600 DT261UGK DT262UGK DT263UGK DT264UGK DT265UGK DT266UGK N/A N/A N/A N/A N/A N/A DTNF261 DTNF262 DTNF263 DTNF264 DTNF265 DTNF266 N/A 82342 82343 82344 92345 92346 Non-Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 1 30 60 100 200 400 600 800 1200 6-26 DT361UGK DT362UGK DT363UGK DT364UGK DT365UGK DT366UGK DT367UGK N/A TC35361 TC35362 TC35363 TC35364 TC35365 TC35366 N/A N/A CutlerHammer General Electric Siemens Square D Non-Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 1 Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 1 30 60 100 200 400 600 Ampere Rating DTNF361 DTNF362 DTNF363 DTNF364 DTNF365 DTNF366 DTNF367 N/A DTU361 DTU362 DTU363 DTU364 92345 92346 N/A N/A 30 60 100 200 400 600 800 N/A N/A N/A DT464UGK DT465UGK DT466UGK DT467UGK N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A NF454DTK NF455DTK NF456DTK NF457DTK N/A DTU462 DTU463 DTU464 92445 92446 N/A Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 3R 30 60 100 200 DT321FRK DT322FRK DT323FRK DT224FRK TDT3321R TDT3322R TDT3323R TDT3324R N/A N/A N/A DTF224R N/A N/A DT223RB DT224RB Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 3R 30 60 100 200 400 600 DT321FRK DT322FRK DT323FRK DT324FRK DT325FRK DT326FRK TDT3321R TDT3322R TDT3323R TDT3324R N/A N/A N/A N/A N/A N/A FR325DTK FR326DTK DT321RB DT322RB DT323RB DT324RB N/A N/A Non-Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 3R 30 60 100 200 400 N/A N/A DT323URK DT224URK DT225URK N/A N/A N/A N/A N/A N/A N/A N/A DTNF224R DTNF225R N/A N/A DTU223RB DTU224RB 92255R Non-Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 3R 30 60 100 200 400 600 N/A N/A DT323URK DT324URK N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A DTNF323R DTNF324R N/A N/A N/A N/A DTU323RB DTU324RB 92355R 92356R Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 3R 30 60 100 200 400 N/A N/A DT363FRK DT364FRK DT365FRK N/A N/A N/A N/A N/A N/A N/A DTF363R DTF364R FR355DTK DT361RB DT362RB DT363RB DT364RB N/A Non-Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 3R 30 60 100 200 400 600 N/A N/A N/A DT264URK DT265URK DT266URK N/A N/A N/A N/A N/A N/A N/A N/A N/A DTNF264R DTNF265R NFR256DTK N/A 82342RB 82343RB 82344RB 92345RB 92346RB Non-Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 3R 30 60 100 200 400 600 800 DT361URK DT362URK DT363URK DT364URK DT365URK DT366URK DT367URK N/A N/A N/A N/A N/A N/A N/A DTNF361R DTNF362R DTNF363R DTNF364R DTNF365R DTNF366R DTNF367R DTU361RB DTU362RB DTU363RB DTU364RB 92345RB 92346RB N/A EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 DOUBLE-THROW SAFETY SWITCHES TABLE 6-33. DOUBLE THROW (CONTINUED) DOUBLE THROW (CONTINUED) Catalog Number CutlerHammer General Electric Siemens Square D Non-Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 3R 30 60 100 200 400 600 800 DT461URK DT462URK DT463URK DT464URK DT465URK DT466URK DT467URK N/A N/A N/A N/A N/A N/A N/A NFR451DTK NFR452DTK NFR453DTK NFR454DTK NFR455DTK NFR456DTK NFR457DTK DT661URK DT662URK DT663URK N/A 92442RB 92443RB 92444RB 92445R 92446R N/A DT361UDK DT362UDK DT363UDK DT364UDK DT365UDK N/A N/A N/A NFR651DTK N/A NFR652DTK N/A NFR653DTK N/A N/A N/A N/A N/A N/A DTNF361J DTNF362J DTNF363J DTNF364J DTNF365J DT361UDK DT362UDK DT363UDK DT364UDK DT365UDK N/A Siemens 30 60 100 200 400 600 N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A DTNF361J DTNF362J DTNF363J DTNF364J DTNF365J N/A 30 60 100 200 400 DT361UWK DT362UWK DT363UWK DT364UWK DT365UWK N/A N/A N/A N/A N/A DTNF361S DTNF362S DTNF363S DTNF364S DTNF365S H92251 H82252 H82253 H82254 H92255 Non-Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 4X H92351 DTU362AWK DTU363AWK DTU364AWK H92355 H92356 Non-Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 4X Non-Fusible, 3-Pole, 3-Wire, 240 Vac, NEMA 12 30 60 100 200 400 600 General Electric Square D N/A DTU462AWK DTU463AWK DTU464AWK H92445 H92446 Non-Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 4X Non-Fusible, 2-Pole, 2-Wire, 240 Vac, NEMA 12 30 60 100 200 400 CutlerHammer Non-Fusible, 4-Pole, 4-Wire, 600 Vac, NEMA 12 Non-Fusible, 6-Pole, 6-Wire, 600 Vac, NEMA 3R 30 60 100 Ampere Rating 30 60 100 200 400 30 60 100 200 DT361UWK DT362UWK DT363UWK DT364UWK DT365UWK N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A DTNF361S DTNF362S DTNF363S DTNF364S DTNF365S N/A N/A N/A N/A N/A 82342DS 82343DS 82344DS N/A N/A DTU362DS DTU363DS DTU364DS N/A N/A DTU462DS DTU463DS DTU464DS Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 4X Non-Fusible, 4-Pole, 4-Wire, 240 Vac, NEMA 12 30 60 100 200 400 600 N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A N/A H92451 DTU462AWK DTU463AWK DTU464AWK H92455 H92456 Non-Fusible, 2-Pole, 2-Wire, 600 Vac, NEMA 12 30 60 100 200 400 600 DT361UDK DT362UDK DT363UDK DT364UDK DT365UDK N/A N/A N/A N/A N/A N/A N/A DTNF361J DTNF362J DTNF363J DTNF364J DTNF365J N/A N/A H82342 H82343 H82344 H92345 H92346 30 60 100 200 400 DT361FWK DT362FWK DT363FWK DT364FWK DT365FWK N/A N/A N/A N/A N/A F351SSDTK F352SSDTK F353SSDTK F354SSDTK F355SSDTK N/A N/A N/A N/A N/A Disconnects Ampere Rating Catalog Number Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables Cutler-Hammer is a federally registered trademark of Eaton Corporation. General Electric is a federally registered trademark of General Electric Company. National Electrical Code and NEC are registered trademarks of the National Fire Protection Association, Quincy, Mass. NEMA is the registered trademark and service mark of the National Electrical Manufacturers Association. Siemens is a federally registered trademark of Siemens AG. Square D is a federally registered trademark of Schneider Electric. UL is a federally registered trademark of Underwriters Laboratories Inc. CSA is a registered trademark of the Canadian Standards Association. Thomas & Betts is a federally registered trademark of Thomas & Betts Corporation. Non-Fusible, 3-Pole, 3-Wire, 600 Vac, NEMA 12 30 60 100 200 400 600 DT361UDK DT362UDK DT363UDK DT364UDK DT365UDK N/A N/A N/A N/A N/A N/A N/A DTNF361J DTNF362J DTNF363J DTNF364J DTNF365J N/A N/A DTU362AWK DTU363AWK DTU364AWK H92345 H92346 Note: Always verify the number of poles and wires required since catalog numbers may appear in multiple tables. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — ©Copyright 2005 6-27 Disconnects 6-28 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Disconnects — Effective August 2005 Features, Functions and Benefits ✓ Pressure ratings: 20 – 40 PSI (pounds per-square inch), 30 – 50 PSI, 40 – 60 PSI. ✓ Adjustable cut-in and cut-out pressure. ✓ Easy installation. SPECIFICATIONS UL姞 listed and CSA姞 certified. WARRANTY Pressure Switch Product Description The water pump pressure switch is used to operate a water pump in commercial, residential and agricultural applications. The pressure switch opens or closes electrical contacts in response to pressure changes to maintain the pressure in your water system. This helps to ensure a smooth delivery of water into your house. The pressure switch can be used on all types of pumps. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Pressure Switches — ©Copyright 2005 Pressure Switches Three-year product warranty. 7-1 Applications FIGURE 7-1. PRESSURE SWITCH FIGURE 7-2. PRESSURE SWITCH ASSEMBLY Catalog Numbering System TABLE 7-1. CATALOG NUMBERING SYSTEM Pressure Switches 7-2 CH WPS 2040 D P Accessories Manufacturer Cutler-Hammer Type PSI Water Pressure Switch 2040 = 20 – 40 3050 = 30 – 50 4060 = 40 – 60 Blank = None L= Low Pressure Cut-off P= Pulsation Plug Contacts Action Diaphragm Actuated Available on 2040, 3050 models. Available only on 2040 models. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Pressure Switches — Effective August 2005 Data Tables TABLE 7-2. PRODUCT SELECTION Description Enclosure Catalog Number UPC Code 20-40 PSI Pressure Switch 20-40 PSI w/ Pulsation Plug 20-40 PSI w/ Low Pressure Cut-off NEMA姞 1 NEMA 1 NEMA 1 CHWPS2040D CHWPS2040DP CHWPS2040DL 782116159208 782116183869 782116183852 30-50 PSI Pressure Switch 30-50 PSI w/ Low Pressure Cut-off 40-60 PSI Pressure Switch NEMA 1 NEMA 1 NEMA 1 CHWPS3050D CHWPS3050DL CHWPS4060D 782116159215 782116336869 782116159222 PULSATION PLUG (20 – 40 PSI PRESSURE SWITCH ONLY) LOW PRESSURE CUT-OFF (20 – 40 & 30 – 50 PSI PRESSURE SWITCHES ONLY) Pulsation plug reduces water surges to the switch that would cause the switch to go on and off rapidly every pulse it received. This prevents your pump from cycling on and off which shortens the pump motor life. Low pressure cut-off prevents pump from burning up due to lack of water in the well. Will shut down the switch if the pressure drops to 10 PSI below the turn on pressure. RATINGS TABLE 7-3. 2-POLE HORSEPOWER RATINGS Phase Vac Amperes hp Single Single 115 230 20 12 1.5 2.0 Cross-Reference Description Cutler-Hammer Catalog UPC Code Number 20/40 Standard Pressure Switch 30/50 Standard Pressure Switch 40/60 Standard Pressure Switch CHWPS2040D CHWPS3050D CHWPS4060D Square D姞 782116159208 9013FSG2J20 782116159215 9013FSG2J21 782116159222 9013FSG2J24 Flotec姞 Water Ace姞 Furnas姞 — TC2151 TC2153 15767A510 15760A501 — 20/40 Pressure Switch w/ Pulsation Plug CHWPS2040DP 782116183869 9013FSG2J20P — — 20/40 Pressure Switch w/ Low Pressure Cut-off CHWPS2040DL 782116183852 9013FSG2J20M4 — — 30/50 Pressure Switch w/ Low Pressure Cut-off CHWPS2050DL 782116336869 9013FSG2J21M4 FP217-1140 19180A501 UL is a federally registered trademark of Underwriters Laboratories Inc. CSA is a registered trademark of the Canadian Standards Association. Cutler-Hammer is a federally registered trademark of Eaton Corporation. NEMA is the registered trademark and service mark of the National Electrical Manufacturers Association. Square D is a federally registered trademark of Schneider Electric. Flotec is a registered trademark of Flotec. Furnas is a registered trademark of Siemens Energy & Automation, Inc. Water Ace is a registered trademark of the Pentair Pump Group. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Pressure Switches — ©Copyright 2005 69WA4Z2040 69WA4 69WA4Z4060 69WA4Z2040B 69WEC — Pressure Switches TABLE 7-4. PRESSURE SWITCH CROSS-REFERENCE 7-3 Pressure Switches 7-4 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Pressure Switches — Effective August 2005 Features, Functions and Benefits STAGE 1 PROTECTION — CHSP SERIES (LOADCENTER OR BREAKER PANEL) ✓ Reduces voltage surges to an acceptable level for NEED ✓ ✓ ✓ ✓ appliances and surge strips. Available in Micro, Max and Ultra Series for different levels of protection. Optional protection for Telephone / Cable / Ethernet (computer networks). May be ordered factory installed in loadcenter or breaker box. Lifetime product warranty. STAGE 2 PROTECTION — SURGE STRIP SERIES (AT POINT-OF-USE) ✓ Recommended for sensitive electronic loads like ✓ A surge protector is a device that protects electronics in your home from voltage surges caused by various sources. The most common causes are lightning, utility grid switching, other users on the power line, and internal surges from air conditioner and power tools. The best way to protect your home electronics against these power surges is to apply surge protection where service is brought into the house (loadcenter or breaker panel) and to also apply protection with a surge strip at the point-of-use. ✓ ✓ ✓ Surge Protection Product Description computers or entertainment centers. Available in Micro, Max and Ultra Series for different levels of protection. One to 10 outlets. Heavy-duty construction series available. Lifetime product warranty. FIGURE 8-1. STAGE 1 AND STAGE 2 — HOME SURGE PROTECTION EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Surge Protection — ©Copyright 2005 8-1 Data Tables Surge Protection FIGURE 8-2. CHSP (STAGE 1) AND SURGE STRIP (STAGE 2) SERIES TABLE 8-1. PRODUCT SELECTION 8-2 Type Catalog Number UPC Code Type Catalog Number UPC Code Catalog Number UPC Code Whole House CHSPMICRO CHSPMAX CHSPULTRA CHSPCHSR4P Surge Strip SGXMICRONET1 SGXMICRONET6 SGXMICROTV6 SGXMICROAC6 SGXMAXNET SGXMAXTV SGXMAXAC SGXULTNET SGXULTTV SGXULT3WAY SGXULTAC SGXCONST6 SGXCONST8 — 782114795828 782114795835 782114795842 782114795859 782116077243 782116077267 782116077274 782116077250 782114300077 782114300114 782114300091 782114300138 782114300145 782114665732 782114300121 782116077281 782116077298 — EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Surge Protection — Effective August 2005 Accessories ✓ SurgeTel (DHW4PT) — Stage 1 protection for ✓ Flushmount Kit (CHSPFMKIT) — Cover for CHSP telephone, modem and DSL services. ✓ SurgeCable (DCXCAB2) — Stage 1 protection for cable TV, satellite and cable modem services. ✓ SurgeEthernet (DRJ45D30R) — Stage 1 protection for home computer networks (RJ45 connectors). surge protectors when used on finished wall. ✓ Power Strips (no surge protection): – PSXVAL6AC3 — 6 outlet, 3 ft. cord – PSXVAL6AC4 — 6 outlet, 4 ft. cord – PSXVAL6AC8 — 6 outlet, 8 ft. cord Related Products TABLE 8-2. SURGE PANELS AVAILABLE WITH FACTORY-INSTALLED WHOLE-HOME SURGE PROTECTION Description Catalog Number UPC Code 100 Ampere Loadcenter; 24 Circuits; Main Breaker; Factory-Installed CHSP Ultra (175,000 Ampere Maximum Surge Current) CHSUR24B100E 782116200054 100 Ampere Loadcenter; 32 Circuits; Main Breaker; Factory-Installed CHSP Ultra (175,000 Ampere Maximum Surge Current) CHSUR32B100K 782116200078 150 Ampere Loadcenter; 32 Circuits; Main Breaker; Factory-Installed CHSP Ultra (175,000 Ampere Maximum Surge Current) CHSUR32B150K 782116200085 200 Ampere Loadcenter; 32 Circuits; Main Breaker; Factory-Installed CHSP Ultra (175,000 Ampere Maximum Surge Current) CHSUR32B200K 782116200108 200 Ampere Loadcenter; 42 Circuits; Main Breaker; Factory-Installed CHSP Ultra (175,000 Ampere Maximum Surge Current) CHSUR42B200L2 782116320196 125 Ampere Loadcenter; 24 Circuits; Main Lug; Factory-Installed CHSP Ultra (175,000 Ampere Maximum Surge Current) CHSUR24L125E 782116200061 225 Ampere Loadcenter; 32 Circuits; Main Lug; Factory-Installed CHSP Ultra (175,000 Ampere Maximum Surge Current) CHSUR32L225K 782116200092 225 Ampere Loadcenter; 42 Circuits; Main Lug; Factory-Installed CHSP Ultra (175,000 Ampere Maximum Surge Current) CHSUR42L225L2 782116320202 100 Ampere CH Surge Provision Loadcenter; 24 Circuits; Main Breaker CHEC24B100E 782116200139 100 Ampere CH Surge Provision Loadcenter; 32 Circuits; Main Breaker CHEC32B100K 782116200153 150 Ampere CH Surge Provision Loadcenter; 32 Circuits; Main Breaker CHEC32B150K 782116200160 200 Ampere CH Surge Provision Loadcenter; 32 Circuits; Main Breaker CHEC32B200K 782116200252 200 Ampere CH Surge Provision Loadcenter; 42 Circuits; Main Breaker CHEC42B200L 782116200184 125 Ampere CH Surge Provision Loadcenter; 24 Circuits; Main Lug Only CHEC24L125E 782116200146 225 Ampere CH Surge Provision Loadcenter; 32 Circuits; Main Lug Only CHEC32L225K 782116200177 225 Ampere CH Surge Provision Loadcenter; 42 Circuits; Main Lug Only CHEC42L225L 782116200191 Main Breaker Design Main Lug Only Loadcenter EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Surge Protection — ©Copyright 2005 Surge Protection “Surge Ready” Panels 8-3 How Much Can You Afford to Lose? Homeowners often underestimate, or ignore, their investment in electrical and electronic equipment... an investment which could be wiped out by an unchecked voltage surge. The cost of replacing electronic equipment in an average home is $8,000. Add a few extra items and the cost can rise dramatically — up to $20,000 for sophisticated entertainment systems and home offices. Where does your home fall on the list? Pick the spot on the chart to the right that best represents your home. It will show your approximate level of investment and risk, without considering compensation, if any, from homeowner’s insurance. “Silence the surge” with Eaton’s Cutler-Hammer姞 residential surge protection products. FIGURE 8-3. ESTIMATED EQUIPMENT REPLACEMENT COSTS Cutler-Hammer is a federally registered trademark of Eaton Corporation. Surge Protection 8-4 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Surge Protection — Effective August 2005 9-2 9-3 9-3 9-4 9-4 9-7 Generators FIGURE 9-1. PORTABLE SYSTEM — INSTALLATION DIAGRAM FIGURE 9-2. STANDBY SYSTEM — INSTALLATION DIAGRAM Product Description A generator is a device designed to provide substitute electrical power to a residence in the event of a utility power outage or other emergency. There are two basic types of generators: portable and standby. A portable generator is a wheeled unit that requires you to roll the generator outside, start it up, and hook it up to a power inlet box. Power is then transferred manually from the main line to the generator. One of the clear advantages with an automatic standby generator system is that the unit turns itself on and off automatically without you ever having to leave the safety of your home. Features, Functions and Benefits Emergency Power Solutions Size Your Generator Guide . . . . . . . . . . . . . . . . . Portable Generators . . . . . . . . . . . . . . . . . . . . . . Standby Generators . . . . . . . . . . . . . . . . . . . . . . Manual Generator Panels . . . . . . . . . . . . . . . . . . Automatic Generator Panels . . . . . . . . . . . . . . . . Generator Accessories . . . . . . . . . . . . . . . . . . . . PORTABLE GENERATORS ✓ Reliable, convenient and versatile to use. ✓ Connects up to six essential household circuits. ✓ Provides up to 12 hours of uninterrupted run time (at 1/2 load). ✓ Manual power transfer. ✓ Fold-down handle. ✓ Available in 3250, 5500 and 7000 watt ratings. Generators STANDBY GENERATORS ✓ ✓ ✓ ✓ ✓ ✓ The ultimate in convenience and power. Fully-automatic operation. Extra quiet operation. Powered by natural gas or liquid propane. All-weather protection and durability. Built-in diagnostic center that relays performance messages. ✓ Available with Air Cooled Engine from 7000 – 12,000 watts. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Emergency Power Solutions — ©Copyright 2005 9-1 Data Tables When selecting the essential circuits that will be switched to “Backup Power,” it is important that the sum of the combined circuit loads does not exceed the wattage/amperage capacity of the generator. Add up the total wattage of all electrical devices to be connected at one time. This total should NOT be greater than the generator’s wattage capacity. TABLE 9-1. CIRCUIT SELECTION — SIZING YOUR GENERATOR Emergency Power Solutions 9-2 Device Running Watts Air Conditioner (12,000 Btu) Air Conditioner (24,000 Btu) Air Conditioner (40,000 Btu) 1700 3800 6000 Battery Charger (20 Amp) Circular Saw (6-1/2-inch) Clothes Dryer (Electric) 500 800 – 1000 5750 Clothes Dryer (Gas) Clothes Washer Coffee Maker 700 1150 1750 Compressor (1 hp) Compressor (1/2 hp) Compressor (3/4 hp) 2000 1400 1800 Curling Iron Dehumidifier Electric Blanket Refrigerator/ Freezer (800 W) 700 650 400 Electric Range (per element) Electric Skillet Freezer 1500 1250 700 Furnace Fan (3/5 hp) Garage Door Opener Hair Dryer 875 500 – 750 1200 Hand Drill Iron Jet Pump 250 – 1100 1200 800 Light Bulb Microwave Oven Milk Cooler 100 700 – 1000 1100 Oil Burner on Furnace Oil Fired Space Heater (140,000 Btu) Oil Fired Space Heater (30,000 Btu) 300 400 150 Oil Fired Space Heater (85,000 Btu) Radio Refrigerator 225 50 – 200 700 Slow Cooker Submersible Pump (1 hp) Submersible Pump (1/2 hp) 200 2000 1500 Submersible Pump (1-1/2 hp) Sump Pump Table Saw (10-inch) 2800 800 – 1050 1750 – 2000 Television Toaster 200 – 500 1000 – 1650 Television (500 W) Computer (800 W) Water Pump (100 W) Sump Pump (800 W) Lighting (60 W) Heating/ Air Conditioning (800 – 4500 W) To help you with your selection of essential circuits, please consider the following: ■ The rated wattage of lights can be taken from light bulbs. The rated wattage of tools, appliances and motors can usually be found on a data plate or decal affixed to the device. ■ If the appliance, tool or motor does not give wattage, multiply 120 volts times the ampere rating to determine watts (volts x amps = watts). ■ Some electric motors (induction types) require about three times more watts of power for starting than for running. This surge lasts for only a few seconds. Be sure you allow for this high starting wattage when selecting electrical devices that will be energized by the backup power system: — Figure the watts required to start the largest motor. — Add that to the total running watts of all other connected loads. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Emergency Power Solutions — Effective August 2005 Data Tables TABLE 9-2. PORTABLE GENERATORS Rated Starting Watts Watts Engine Run Time Warranty Part Number Features 3250 Watt Portable Generator 3250 4,550 6.5 hp Briggs & Stratton OHV Engine Up to 2.7 hrs. Two-Year • 3 Convenient Outlets (at 1/2 Load) Limited Warranty • Manual Start • Ideal for Work/Tool Power or Recreational Use 1653CH Up to 13 hrs. (at 1/2 Load) Two-Year • 5 Convenient Outlets Limited Warranty • Easy Start (Manual) • Basic Power to Run Essential Items During a Power Outage 1654CH Up to 8 hrs. (at 1/2 Load) Two-Year • 6 Convenient Outlets Limited Warranty • Electric Start • Enough Power to Keep You Comfortable During a Power Outage 1894CH 5500 Watt Portable Generator 5500 8,500 10 hp Briggs & Stratton OHV Engine 7000 12,250 15 hp Briggs & Stratton OHV Engine If you purchase a portable generator, you will also need to purchase the following: ✓ Manual transfer switch or emergency generator panel. ✓ Power inlet box. ✓ Power cord. TRANSFER SWITCHES TABLE 9-3. STANDBY GENERATORS Model Number Feature CHGEN7000 Related Products CHGEN10000 CHGEN12000 Running Watts Liquid Propane Natural Gas 7,000 6,000 10,000 9,000 12,000 11,000 Starting Watts Liquid Propane Natural Gas 10,500 9,000 12,500 11,250 15,000 13,750 Operation Fully Automatic Fully Automatic Fully Automatic Run Time Continuous based Continuous based Continuous based on fuel supply on fuel supply on fuel supply Engine Brand Briggs & Stratton Briggs & Stratton Briggs & Stratton Engine 504 cc ELS 570 cc Vanguard 627 cc Vanguard Engine Type OHV OHV V-Twin OHV V-Twin RPM 3600 3600 3600 Sound Rating 77 dB 70 dB 69 dB System Exerciser Every 7 days Every 7 days Every 7 days Remote Status Yes Yes Yes Diagnostic Alerts 4 Functions 7 Functions 7 Functions Dimensions 30.5 x 22 x 32.5 40 x 22 x 23 40 x 22 x 23 Weight 280 lbs. 379 lbs. 379 lbs. Warranty 2 Years 3 Years/1500 Hrs. 3 Years/1500 Hrs. A transfer switch is required to transfer power from utility power to generator power. Transfer switch selection will vary based on the generator type and can be found on Page 9-5 of this catalog. Extra Stuff A power outage is more than an inconvenience. It could cost you thousands of dollars. ✓ Loss of heat (even gas furnaces have electric fans) could send families to motels and restaurants. ✓ Basements flood when sump pumps have no power. ✓ Food spoils when freezer and refrigerator are out. Your home, and what’s inside it, is the biggest and most important investment you will ever make. So why leave it all to chance? Emergency Power Solutions 7000 Watt Portable Generator If you purchase a standby generator, you will also need to purchase the following: ✓ Automatic transfer switch. Optional Cold Weather Accessories for Standby Generators ✓ Battery heater — Catalog Number 1915CH. ✓ Engine oil warmer — Catalog Number 1916CH. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Emergency Power Solutions — ©Copyright 2005 9-3 Transfer Switches Manual Transfer Switch Product Description Emergency Power Solutions When your normal power source has been interrupted, a transfer switch is used to transfer your homes circuits to generator power. Transfer switch selection varies depending on the needs of the homeowner and the type of generator. Manual transfer switches are typically used with portable generators. With this type of switch, the homeowner must transfer power manually each time the utility power is interrupted. Automatic transfer switches monitor utility and generator voltages and will automatically connect to the appropriate source. When the power goes out, the transfer switch automatically senses the power disruption, signals the generator to turn on, and transfers power from utility to standby power for the duration of the power outage. When utility power is restored, the switch senses that power has returned, shuts down the generator and resumes monitoring. Features, Functions and Benefits MANUAL TRANSFER SWITCHES ✓ For use with portable generators. ✓ Hardwired connection to Power Inlet Box Emergency Generator Panel (sold separately). ✓ Accepts Cutler-Hammer姞 Type CH and CHNT Breakers (sold separately). ✓ Sturdy copper bus loadcenter construction for long service life. ✓ Mechanically interlocked to prevent paralleling of normal and emergency power source. EMERGENCY GENERATOR PANELS ✓ For use with portable generators. ✓ Plug-in generator connection. ✓ All circuit breakers are included — switching duty rated. ✓ Includes dual wattmeters for load balancing. ✓ Mechanically interlocked main disconnects prevent paralleling of normal and emergency power source. AUTOMATIC TRANSFER SWITCHES ✓ ✓ ✓ ✓ ✓ Automatic Transfer Switch 9-4 For use with standby generators. Fully automatic. “Whole house” transfer (100 and 200 amperes). Computer friendly. Electrically interlocked to prevent paralleling of normal and emergency power source. ✓ Designed exclusively for use with Eaton’s Cutler-Hammer brand Home Standby Generators. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Emergency Power Solutions — Effective August 2005 Data Tables Main/ Emergency Rating Watts Ampere Rating Enclosure Type Number of Circuits TABLE 9-4. SELECTION OF MANUAL TRANSFER SWITCHES AND GENERATOR PANELS FOR USE WITH PORTABLE GENERATORS Feeder Breakers Included Accessories Catalog Number UPC Code Provision Provision Provision Provision None None CH48GEN3060R CH816GEN6060 782114511794 782114511800 Manual Transfer Switch NEMA姞 3R 5,000 NEMA 1 10,000 4 – 8 30 8 – 16 60 NEMA 1 NEMA 3R NEMA 1 NEMA 3R 5,000 5,000 5,000 5,000 6 6 6 6 20 20 20 20 60/20 A 60/20 A 60/20 A 60/20 A 5 – 1P 15 1 – 1P 20 5 – 1P 15 1 – 1P 20 5 – 1P 15 1 – 1P 20 5 – 1P 15 1 – 1P 20 None None 2-Pole Surge Protector 2-Pole Surge Protector CH6EGEN2060 CH6EGEN2060R CH6EGEN2060SUR CH6EGEN2060RSU 782114556948 782114606414 782114556931 782114627983 NEMA 1 NEMA 3R NEMA 1 NEMA 3R 7,500 7,500 7,500 7,500 10 10 10 10 30 30 30 30 60/30 A 60/30 A 60/30 A 60/30 A 6 – 1P 15 2 – 1P 20 1 2P 30 6 – 1P 15 2 – 1P 20 1 2P 30 7 – 1P 15 2 – 1P 20 1 2P 30 7 – 1P 15 2 – 1P 20 1 2P 30 None None 2-Pole Surge Protector 2-Pole Surge Protector CH10EGEN3060 CH10EGEN3060R CH10EGEN3060SUR CH10EGEN3060RSU 782114556962 782114606421 782114556955 782114627990 TABLE 9-5. SELECTION OF TRANSFER SWITCHES FOR USE WITH STANDBY GENERATORS Models Description CHGEN50ATS CHGEN50ATSR CHGEN100ATSR CHGEN200ATSR Switch Type NEMA姞 1/Indoor NEMA 3R/Indoor or Outdoor NEMA 3R/Indoor or Outdoor NEMA 3R/Indoor or Outdoor Circuits 10 10 All All Amperes 50 50 100 200 Poles 2 2 2 2 Frequency 50/60 50/60 50/60 50/60 Dimensions (L x W x H) in Inches (mm) 4.00 x 14.25 x 21.00 (101.6 x 362.0 x 533.4) 6.00 x 14.50 x 21.00 (152.4 x 368.3 x 533.4) 6.00 x 12.00 x 16.00 (152.4 x 304.8 x 406.4) 7.00 x 16.00 x 22.00 (177.8 x 406.4 x 558.8) Weight in lbs. (kg) 25 (11) 29 (13) 21 (10) 34 (15) EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Emergency Power Solutions — ©Copyright 2005 Emergency Power Solutions Emergency Generator Panel 9-5 Applications 2-Pole, 60 Amp Breaker* to Feed the Emergency Generator Panel From Your Existing Main Power Panel Utility Power Feed Emergency Generator Panel Power Inlet Box* Existing Main Power Panel Power Cord* Emergency Generator Panel Prewired Connector for Faster Installation - (Loadcenter) Included 2-Pole, 60 Amp Breaker* to Feed the Emergency Generator Panel From Your Existing Main Power Panel (Loadcenter) Generator* Power Cord* Prewired Connector for Faster Installation - Included Electrical Wiring or Power Cord* Utility Power Feed Generator* * Not Included *Not Included Emergency Power Solutions FIGURE 9-3. RESIDENTIAL GENERATOR APPLICATION WITH MANUALLY OPERATED DOUBLE THROW SAFETY SWITCH Standby Generator FIGURE 9-4. RESIDENTIAL GENERATOR APPLICATION WITH AUTOMATIC TRANSFER SWITCH AND SERVICE ENTRANCE RATED SAFETY SWITCH Meter 50 Ampere Indoor Transfer Switch Sound Shield 100/200 Ampere Service Panel Fuel Supply (NG or LP) Air Conditioner FIGURE 9-5. CHGEN50ATS & CHGEN50ATSR Standby Generator Sound Shield Meter Service Disconnect Low Voltage Disconnect 100/200 Ampere Outdoor Transfer Switch 100/200 Ampere Service Panel Fuel Supply (NG or LP) Air Conditioner FIGURE 9-6. CHGEN100ATS & CHGEN200ATSR 9-6 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Emergency Power Solutions — Effective August 2005 Accessories TABLE 9-6. ACCESSORIES FOR MANUAL TRANSFER SWITCHES AND EMERGENCY POWER GENERATOR PANELS Description Ampere Rating Catalog Number UPC Code Flange Kit for Flush Mount Applications 10-Foot (3.05 m) Power Cord 10-Foot (3.05 m) Power Cord — 20 30 CHEGENFKIT CH6EGEN10CORD CH10EGEN10CORD 782114606438 782114606452 782114606506 25-Foot (7.62 m) Power Cord 25-Foot (7.62 m) Power Cord 20 30 CH6EGEN25CORD CH10EGEN25CORD 782114606469 782114606513 Power Inlet Box Power Inlet Box 20 30 CH6EGENPIB CH10EGENPIB 782114606483 782114606537 For use with Emergency Generator Panel Only. Related Products See Pages 9-1 through 9-3 of this section. Briggs & Stratton is a registered trademark of Briggs & Stratton Corporation. Cutler-Hammer is a federally registered trademark of Eaton Corporation. NEMA is the registered trademark and service mark of the National Electrical Manufacturers Association. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Emergency Power Solutions — ©Copyright 2005 Emergency Power Solutions GENERATORS 9-7 Emergency Power Solutions 9-8 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Emergency Power Solutions — Effective August 2005 10-3 10-3 10-4 10-7 10-8 10-9 10-10 10-11 10-12 10-14 Product Description Structured wiring is a simple, affordable way to wire a home for state-of-the-art communications, entertainment and security now and for many years to come. The basic concept is that all telephone, television, satellite, coaxial, audio and data communications cables are wired in a star topology (home run) to each room in the home and terminate at a central distribution panel. This distribution panel allows flexibility for future modifications and/or additions to keep pace with a homeowner’s lifestyle and needs. Structured wiring can also be used as a central hub to interconnect a security system, home automation, HVAC and load control providing a complete system to increase the security, comfort and convenience for a homeowner. Features, Functions and Benefits ✓ ✓ ✓ ✓ ✓ ✓ Wall Outlets & Quick Network Box Telephone. High-speed Internet. Computer networks. Web-safe Internet router. Whole-house sound. Satellite/cable TV. CHAUDPAK EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — ©Copyright 2005 Structured Wiring Entry Level Network Panels . . . . . . . . . . . . . . . Distribution Network Panels . . . . . . . . . . . . . . . Networking Modules . . . . . . . . . . . . . . . . . . . . Entertainment System Components . . . . . . . . Speakers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Home Automation Systems and Components. . . Networking Housings and Covers. . . . . . . . . . . . . . . . . . Panel Inserts . . . . . . . . . . . . . . . . . . . . . . . . Receptacles . . . . . . . . . . . . . . . . . . . . . . . . . Accessories and Patch Cords . . . . . . . . . . . 10-1 Structured Wiring FIGURE 10-1. A HOME WITH STRUCTURED WIRING SOLUTIONS GIVES YOU READY CONTROL OF THE LATEST IN COMPUTING, AUDIO, VIDEO AND COMMUNICATIONS. WITH THE RIGHT COMPONENTS, YOUR DREAM HOME IS READY FOR TODAY’S WORLD AND TOMORROW’S ADVANCEMENTS. YOUR VALUE IS ENSURED...AND SO IS YOUR PEACE OF MIND. 10-2 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — Effective August 2005 Data Tables TABLE 10-1. ENTRY-LEVEL NETWORKS Part Number UPC Code Product Description CHAN100 782116136285 Perfect for apartments, condos or even entry level homes. This distribution panel distributes four incoming telephone lines to six locations, punchdown, and one incoming coax signal to four locations, passive. Installation is easy and a stylish three-gang wall plate cover provides a professional looking finish. CHAN100P 782116299591 Same as CHAN100, except punchdown for telephone is doubled for 11 locations and there is no coax distribution. Perfect for commercial and resi applications for phone only, or for six phone locations and/or six computer locations. CHQND200 782116136179 Perfect for apartments, condos or even entry level homes. This 6" x 14-1/2" distribution panel distributes one incoming coax signal to four locations with two pass-throughs for satellite, eight RJ45 connectors for telephone distribution. Also includes one RJ31X jack. Has room for one expansion module. Includes cover. *110 outlet not included. CHQND200P 782116136193 Same as CHAN200, except punchdown for telephone. CHQND2008 782116136230 Perfect for apartments, condos or even entry level homes. This 6" x 14-1/2" distribution panel distributes one incoming coax signal to eight locations with two pass-throughs for satellite, eight RJ45 connectors for telephone distribution. Also includes one RJ31X jack. Has room for one expansion module. Includes cover. *110 outlet not included. CHQND200P8 782116136209 Same as CHAN2008, except punchdown for telephone. CHQND2008A 782116136223 Perfect for apartments, condos or even entry level homes. This 6" x 14-1/2" distribution panel distributes one incoming coax signal to eight locations, with bi-directional 12 dB amplification, two pass-throughs for satellite, eight RJ45 connectors for telephone distribution. Also includes one RJ31X jack. Has room for one expansion module. Includes cover. *110 outlet not included. Must be powered with nearby wall outlet. Comes with transformer. CHQND200P8A 782116136216 Same as CHAN2008A, except punchdown for telephone. Part Number UPC Code CHSWPAK1 782113533704 QuickNetwork Panel. Services up to eight telephone locations and eight TV locations. 1 in, 8 out coax (TV) distribution module with two pass-through connections for DBS satellite. 4-line to 8 location telephone module (CAT5 rated, RJ45 w/ RJ31X connector) four expansion bays. Built-in 110 V power outlet. 18" install can and cover. 19 lbs. CHSWPAK1P 782116136186 QuickNetwork Panel. Same features as CHSWPAK1, except with punchdown style connector on telephone module instead of RJ45 connectors. 19 lbs. CHSWPAK2 782113533711 Entertainment Upgrade Package. Services up to eight telephone locations and eight TV locations. 5 in, 8 out coax (TV) distribution module with four pass-through connections for DBS satellite, 20 dB bi-directional amplifier and surge suppression. 4-line to 8 location telephone module (CAT5 rated, RJ45 w/ RJ31X connector). Two expansion bays. Built-in 110 V power outlet. 18" install can and cover. 19 lbs. CHSWPAK4 782113533735 Education and Home Office Upgrade Package. Comes standard with two patching modules that allow 12 coax connections and 12 CAT5e connections to be professionally terminated, and connected by patch cording to the phone, video or computer service modules. Six CAT5 patch cords, and six RG6-rated coax patch cords are included. System also includes one 5 in, 8 out coax (TV) distribution module with four pass-throughs, surge suppression and 20 dB bi-directional amplifier; one 4 line to 12 location telephone module (CAT5 rated, RJ45) with surge suppression, RJ31X security system connection, and a connection for a PBX/KSU; four expansion bays; one 4 port, 10 / 100 auto switching cable / DSL Firewall Internet Router; Built-in 110 V power outlet; 36" install can and cover. 37 lbs. Product Description EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — ©Copyright 2005 Structured Wiring TABLE 10-2. DISTRIBUTION PANELS QUICKNETWORK SERIES 10-3 Data Tables TABLE 10-3. MODULES FOR QUICKNETWORK SERIES PANELS Structured Wiring 10-4 Part Number UPC Code Product Description CHMDT124P 782113533599 12 Port, 4 Line Telephone Module. Twelve RJ45 ports (CAT5 rated) support four incoming phone lines with speeds up to 100 Mbps. Includes two Amphenol connectors for interface to a Key System Unit (KSU) or PBX. The Amphenol connectors include a shorting block for compatibility with Plain Old Telephone (POTS) lines. Includes surge suppression and one RJ31X port. 12". 2.5 lbs. CHMDT412100 782113726625 12 Port, 4 Line Punchdown Telephone Module. The 12/4 punchdown Telephone Module has 12 110 punchdown blocks which distribute four incoming lines to 12 locations. 6" form factor. 1 lb. CHMDT122P 782116009411 12 Port, 2 Line Telephone Module. This 12 location, two line, RJ11 harmonica-style twisted pair module is used for connecting and distributing voice at speeds up to 10 Mbps. Includes 12 RJ11 ports, supports two incoming telephone lines, and includes an Amphenol connector for interface with a telephone Key System Unit (KSU) or PBX. The Amphenol connector includes a shorting block for compatibility with Plain Old Telephones (POTS) lines. Includes surge suppression. 12" form factor. 1.8 lbs. CHMDT083P 782116031481 8 Port, 3 Line Telephone Hub. This eight location, three line, RJ11 harmonica-style twisted pair module is designed to work with Panasonic Key Service Units (KSUs) that require a three-pair connection rather than a two-pair connection. Note: A shorting block is not provided with this module. Can not be used with Plain Old Telephones (POTS). 0.6 lbs. 6" form factor. CHMDT8RJ 782113533612 8 Port, 4 Line Telephone Module. Eight RJ45 ports support four incoming phone lines. One RJ31X port for security. 6" form factor. 1.0 lb. CHMDT416100 782116150380 16 Port, 4 Line Telephone Module. 16 RJ45 ports support four incoming phone lines. One RJ31X port for security. 6" form factor. 1.25 lbs. CHMDC4T8RJ 782113965864 Combo 4 x 8 Coax/Phone Distribution Module (with RJ45 patch connectors). Distributes one incoming coax TV line to four locations (plus two pass-through) and four telephone lines to eight locations. Includes an RJ31X connection. 6" form factor. 1.1 lbs. CHMDX48300 782113965857 Combo 4 x 8 Coax/Phone Distribution Module (with 110 punchdown connectors). Distributes one incoming coax TV line to four locations (plus two pass-through) and four telephone lines to eight locations. 6" form factor. 1.2 lbs. CHMDC8T8RJ 782113533537 Combo 8 x 8 Passive Coax/Phone Distribution Module (with RJ45 patch connectors). Distributes one incoming coax TV line to eight locations (plus two pass-through) and four telephone lines to eight locations. Includes an RJ31X connection. 6" form factor. 1.2 lbs. CHMDX88200 782113680705 Combo 8 x 8 Active Coax/Phone Distribution Module (with RJ45 patch connectors). Distributes one incoming coax TV line to eight locations with built-in amplification (plus two pass-throughs) and four telephone lines to eight locations. Includes an RJ31X connection. 6" form factor. 1.2 lbs. CHMDX88300 782113533520 Combo 8 x 8 Passive Coax/Phone Distribution Module (with 110 punchdown connectors). Distributes one incoming coax TV line to eight locations (plus two pass-through) and four telephone lines to eight locations. 6" form factor. 1.2 lbs. CHMDX88400 782116031498 Combo 8 x 8 Active Coax/Phone Distribution Module (with 110 punchdown connectors). Distributes one incoming coax TV line to eight locations with built-in amplification (plus two passthroughs) and four telephone lines to eight locations. Includes an RJ31X connection. 6" form factor. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — Effective August 2005 Data Tables TABLE 10-3. MODULES FOR QUICKNETWORK SERIES PANELS (CONTINUED) UPC Code Product Description CHMDC104 782113965871 1 x 4 Coax Module. 1 in, 4 out coax module with four pass-through connectors. 6" form factor. 1.0 lb. CHMDC108 782113534336 1 x 8 Coax Module. 1 in, 8 out coax module with two pass-through connectors. 6" form factor. 1.3 lbs. CHMDC108200 782116126262 1 x 8 Amplified Coax Module. 1 in, 8 out coax module with 12 dB bi-directional amplifier and two pass-through connectors. 6" form factor. 2.4 lbs. CHMDC408 782113533506 5 x 8 Coax Module. 5 in, 8 out coax module with 20 dB bi-directional amplifier, surge protection, and four pass-through connectors, and four inputs for modulated signals. 12" form factor. 3 lbs. CHMDC412 782113533513 5 x 12 Coax Module. 5 in, 12 out coax module with 20 dB bi-directional amplifier, surge protection, and four pass-through connectors, and four inputs for modulated signals. 12" form factor. 3.5 lbs. CHMDC416 782113965888 5 x 16 Coax Module. 5 in, 16 out coax module with 20 dB bi-directional amplifier, surge protection, with one direct and four inputs for modulated signals. 12" form factor. 3.6 lbs. CHMDB100 782116031467 Expansion Bay Blank. This blank is used to cover open areas or conceal wires that are running through the QuickNetwork distribution panel. 6" form factor. CHMDPB 782113533575 Blank Patch Module. Use this blank patch module to custom design a zone. The blank patch module accepts any configuration of CAT5e, RG6 coax or fiber optic inserts. Labeling areas allow you to identify the connections and what rooms they represent. 6" form factor. CHMDP2 782116009404 2-Zone Patch Module. 12 connection ports (two CAT5, two coax, and two fiber optic connections per zone). 6" form factor. 0.8 lbs. Use only when terminating fiber optic connections. CHMDP3 782113533568 3-Zone Patch Module. 12 connection ports (two CAT5 and two coax per zone). 6" form factor. 0.8 lbs. Allows for many room locations (wall plates) to be terminated cleanly and professionally without having to add expensive service modules. Active wall plates can be patch corded to data, voice or video modules as needed without complication or added expense. Outlet locations can be permanently labeled for easy consumer plug n' play, and changing applications and life styles. CHMDDS4 782113533544 4-Location DBS Distribution Module. Provides distribution of a dual LNB DBS Digital Satellite Dish signal to four locations through a single coax cable without modulation. Each TV location must be connected to a separate DBS receiver where desired. 6" form factor. 1.7 lbs. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — ©Copyright 2005 Structured Wiring Part Number 10-5 Data Tables TABLE 10-3. MODULES FOR QUICKNETWORK SERIES PANELS (CONTINUED) Structured Wiring 10-6 Part Number UPC Code Product Description CHMDDS8100 782116031474 8-Location High Definition Satellite TV Distribution Module CHMDAD86 782113533483 8-Location Audio Distribution Module. The Audio Distribution Module allows an audio signal to be distributed to eight stereo or 16 mono speaker locations. 6" form factor. 1 lb. CHMDMD03 782113920894 Triple Channel Modulator Module. Used for creating in-home television channels for viewing from any TV in the home. Signals from three different audio/video sources such as TV, VCR, DVD, DBS, satellite TV and security cameras may be identified and displayed by any television. 6" form factor. 2.1 lbs. CHMDSG100 782116049318 Universal Security System Module. Accepts the following security system boards; Electronic Lines 3208 gold, Caddx NX8, Vista 15P, First Alert FA148CP, DSC 1555, DSC 832. CHMDSC100 782116049325 Non-Locking Cover for the Security System CHMDSC200 782116049332 Locking Cover for the Security System CHMDFDS 782113967462 Door Station Module. This module allows the homeowner to speak to visitors at a front door or entry using existing telephones. Includes one door station speaker. 6" form factor. 2.1 lbs. CHMDFDSR 782116009398 Door Station Module with Door Lock Release. Same as MDFDS, plus a door lock release feature that permits the homeowner to release electric door locks via telephone, allowing visitors to enter. Includes one door station speaker. 6" form factor. CHFDS100 782116009053 Door Station Speaker. Each door station module can support one additional speaker location. CHMDEN108 782113965895 8 Port, 10/100Base-T Ethernet Switch Module. Used to create a Local Area Network (LAN) by connecting up to eight computers, printers, scanners, fax machines, etc. Supports data transfer speeds up to 100 Mbps. Stackable, bridgeable. 12" form factor. Can be added to a router (CHMDENR100) to create 10 routed data ports. CHMDEN105 782116009381 5 Port, 10/100Base-T Ethernet Switch Module. Used to create a Local Area Network (LAN) by connecting up to five computers, printers, scanners, fax machines, etc. Supports data transfer speeds up to 100 Mbps. Stackable, bridgeable. 12" form factor. Can be added to a router (CHMDENR100) to create seven routed data ports. CHMDENR100 782116126965 DSL or Cable Router with 4 Port 10/100M Fast Ethernet Switch. Built-in NAT Firewall. 6" form factor. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — Effective August 2005 Data Tables TABLE 10-4. ENTERTAINMENT SYSTEM COMPONENTS UPC Code Product Description CHMDADZ600 782116153084 A-Bus Audio Distribution Module (6" form factor). For use in QuickNetwork panels. The Zone 6 Audio Distribution Module distributes CAT5 audio to six locations. Can be cascaded to one or two additional modules for 12 or 18 locations. CHHBADZ600 782116153091 A-Bus Audio Distribution Hub (12" form factor). For use in SuperPro Distribution panels. The Zone 6 Audio Distribution Hub distributes CAT5 audio to six locations. Can be cascaded to one or two additional hubs for 12 or 18 locations. CHAUDZ200A 782116153114 A-Bus Volume Control (Almond). The volume control is the down line amplifier that converts the distributed audio signal back to an analog signal that is then distributed over speaker wire to in-wall/ ceiling speakers. CHAUDZ200W 782116153107 A-Bus Volume Control (White) CHAUDZ300A 782116153138 A-Bus Volume Control with “IR” Input Option (Almond). The IR allows the entertainment center's wireless remote to be used in rooms that have this feature. CHAUDZ300W 782116153121 A-Bus Volume Control with “R” Input Option (White) CHAUDZ700A 782116153169 A-Bus Local Input Plate (Almond). Allows a local source that will override the main hub input. CHAUDZ700W 782116153152 A-Bus Local Input Plate (White). Allows a local source that will override the main hub input. CHAUDZ500 782116153145 A-Bus Component Interface Unit. The CHAUDZ500 is used when the customer’s amplifier does not have an A-Bus CAT5e output built in. RCA connectors are run from the amplifier to the CHAUDZ500, and then a CAT5e homerun is made to the CHMDADZ600 in the main distribution panel. CHAUDPAK 782113533469 "Whole-House” Audio Package. Services up to eight stereo or 16 mono speaker locations. For use in QuickNetwork panels. System includes three 75-Watt Volume Controls, three Speakers (set of 2) In-Ceiling and one Audio Distribution Module; 6" form factor. 26 lbs. This is an analog distribution system for a low-cost background sound, distributed audio system. CHHBAD8 782116009107 8-Location Audio Distribution Hub. For use in Pro, SuperPro, and Hotwired eight panels. The Audio Distribution Hub allows an audio signal to be distributed to eight stereo or 16 mono speaker locations. This is an analog distribution system for a low-cost background sound, distributed audio system. CHMDAD86 782113533483 8-Location Audio Distribution Module (6" form factor). For use in QuickNetwork panels. The Audio Distribution Module allows an audio signal to be distributed to eight stereo or 16 mono speaker locations. This is an analog distribution system for a low-cost background sound, distributed audio system. CHAUD75VC 782113533445 75-Watt Volume Control (White) for analog audio systems. CHAUD75VCA 782116142941 75-Watt Volume Control (Almond) for analog audio systems. CHAUD35VC 782116008964 35-Watt Volume Control (White) for analog audio systems. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — ©Copyright 2005 Structured Wiring Part Number 10-7 Data Tables TABLE 10-4. ENTERTAINMENT SYSTEM COMPONENTS (CONTINUED) Part Number UPC Code Product Description CHAUDW65 782113965901 Speakers (set of 2), In-Wall, 6.5" Poly Woofer, .75" Tweeter. Surround sound capable. Suitable for all audio systems. CHAUDC65 782113533452 Speakers (set of 2), In-Ceiling, 6.5" Poly Woofer, 1" Swivel Tweeter. Surround sound capable. Suitable for all audio systems. CHAUDO55B 782113965925 Speakers (set of 2), Outdoor, 5.5" Poly Woofer, .75" Tweeter, Black. Surround sound capable. Suitable for all audio systems. CHAUDO55W 782113965918 Speakers (set of 2), Outdoor, Same as above in White. Suitable for all audio systems. Structured Wiring 10-8 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — Effective August 2005 Data Tables TABLE 10-5. AUTOMATION SYSTEMS AND COMPONENTS UPC Code Product Description CHMDHC100 782116341511 Home Automation Control Module. For QuickNetwork Panels. Comprehensive control of lights, appliances, heating/cooling, telephone, fire and security features. CHHBHC100 782116009091 Home Automation Control Hub. For Pro and SuperPro Panels. Comprehensive control of lights, appliances, heating/cooling, telephone, fire and security features. CHOFS10A07 782116009442 4 Relay Module. 4 separate relays convert voltage outputs to Form C relay contacts. LED indicators show which relays are energized. CHOFS10A097 782116009459 2-Way X-10 Transceiver Kit. Use with Control Module (MDHA) or Control Hub (HBHA) to inject X-10 signals onto powerline. CHOFS10A11 782116009466 2-Way Voice Module Kit. Allows for two-way voice communication between premises and central station after an alarm event, or to announce alarms inside the premises using built-in voice capabilities. Listen/Talk features accessible from any touch tone phone. Can be used as internal paging/intercom system. CHOFS1101A 782116009473 Programmable Energy Saver Module. Used to override existing thermostats for setback control, and for sensing and controlling other temperatures, such as attic fans, garage fans, greenhouses, basements etc. Works as a freeze sensor, causing the controller to dial out in the event of a furnace failure. CHOFS11A009 782116106110 LCD Surface Mount Console. For use with MDHA or HBHA Home Automation Control Module or Hub. 48-character backlighted LCD display with menu operation, backlighted keys, selectable keyclick, beeper functions and viewing angle. Surface mount. CHOFS11A002 782116009510 LCD Flush Mount Console. For use with MDHA or HBHA Home Automation Control Module or Hub. 48-character backlighted LCD display with menu operation, backlighted keys, selectable keyclick, beeper functions and viewing angle. Painted aluminum back box mounts in wall. Face of console snaps into back box for professional, built-in appearance. CHOFS14A00 782116009558 Outdoor Temperature Sensor. Mounts in an outdoor location to send temperature to Control Module or Hub. CHOFS21A052 782116009565 Controller Serial Cable. Connects personal computer to Control Module/Hub. DB-9F connector. CHOFS22A001 782116009572 16-Zone Expansion Module. Adds 16 zones and eight voltage outputs with overload protection and reset. CHOFS13A001 782116009534 Single-Stage Communicating Thermostat. For single-stage heating and cooling system, gas or electric heat. CHOFS13A003 782116009541 Single-Stage Communicating Heat Pump Thermostat. For single-stage heat pump. CHOFS1106W 782116009497 Upload/Download End User Software. For Windows姞 95/98/NT. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — ©Copyright 2005 Structured Wiring Part Number 10-9 Data Tables TABLE 10-6. HOUSINGS, CANS, COVERS Part Number UPC Code Product Description CHQND6 CHQN18 CHQN24 CHQN36 CHQN48 782116136247 782113533667 782113533674 782113533681 782113726779 QuickNetwork 6" Install Can with 110 V Power and Cover (Metal) QuickNetwork 18" Install Can with 110 V Power and Cover (Metal) QuickNetwork 24" Install Can with 110 V Power and Cover (Metal) QuickNetwork 36" Install Can with 110 V Power and Cover (Metal) QuickNetwork 48" Install Can with 110 V Power and Cover (Metal) CHQNIC18 CHQNIC24 CHQNIC36 CHQNIC48 782116009763 782116009770 782116009787 782116009794 QuickNetwork 18" Install Can with 110 V Power QuickNetwork 24" Install Can with 110 V Power QuickNetwork 36" Install Can with 110 V Power QuickNetwork 48" Install Can with 110 V Power CHQNCC18C CHQNCC24C CHQNCC36C CHQNCC48C 782116009695 782116009718 782116009732 782116009756 QuickNetwork Cover for QNIC-18 (Clear Plastic) QuickNetwork Cover for QNIC-24 (Clear Plastic) QuickNetwork Cover for QNIC-36 (Clear Plastic) QuickNetwork Cover for QNIC-48 (Clear Plastic) CHQNCC18 CHQNCC24 CHQNCC36 CHQNCC48 782116009688 782116009701 782116009725 782116009749 QuickNetwork Cover for QNIC-18 (Metal) QuickNetwork Cover for QNIC-24 (Metal) QuickNetwork Cover for QNIC-36 (Metal) QuickNetwork Cover for QNIC-48 (Metal) CHGRM100 782116031450 3-Pack Grommet Package for QuickNetwork Enclosure Knockouts Structured Wiring 10-10 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — Effective August 2005 Data Tables TABLE 10-7. PANEL INSERTS UPC Code Product Description CHBLNY 782116009008 Blank Inserts for Distribution Panel (Yellow). Sold in 12 pack. CHBLNR 782116008988 Blank Inserts for Distribution Panel (Red). Sold in 12 pack. CHBLNB 782116008971 Blank Inserts for Distribution Panel (Blue). Sold in 12 pack. CHBLNW 782116008995 Blank Inserts for Distribution Panel (White). Sold in 12 pack. CHMLFN 782116009428 ST Fiber Optic Connectors for Distribution Panel. Sold in 12 pack. CHMLCN 782113533636 RG6 Coax Connectors for Distribution Panel. Sold in 12 pack. CHML5N 782113533629 RJ45, CAT5e Rated Connectors for Distribution Panel. Sold in 12 pack. CHBZ5N 782116009015 CAT5e Bezels for Distribution Panel (Blue). Sold in 12 pack. CHQNS100 782116153398 Panel Door Clips. Sold in 10 pack. CHQNS150 782116126941 Panel Door Screws. Sold in 10 pack. CHRIV100 782116103126 Rivet Grommet/Plunger (White). For holding modules into QuickNetwork cans. Sold in 20 pack. CHIIDT 782116009336 Icons for CAT5 Inserts. Computer/Data Icon, wheel of 16. These are snap-in data labels for the distribution bezels in the SuperPro series and the MDP3 modules. CHIITP 782116009343 Icons for CAT5 Inserts. Telephone/Voice Icon, wheel of 16. These are the snap-in telephone labels for the distribution bezels in the SuperPro series and the MDP3 modules. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — ©Copyright 2005 Structured Wiring Part Number 10-11 Data Tables TABLE 10-8. RECEPTACLES AND MULTIMEDIA WALL OUTLETS Structured Wiring 10-12 Part Number UPC Code Product Description CHREC101CW 782116126712 1 Port Wall Outlet: 1 Coax TV connection (RG6) White color CHREC101CA 782116126729 1 Port Wall Outlet. Same as CHREC101CW above except in almond color. CHREC101CI 782116126736 1 Port Wall Outlet. Same as CHREC101CW above except in ivory color. CHREC101TW 782116126743 1 Port Wall Outlet: 1 RJ11 telephone connection (CAT3 rated) White color CHREC101TA 782116126750 1Port Wall Outlet. Same as CHREC101TW above except in almond color. CHREC101TI 782116126767 1 Port Wall Outlet. Same as CHREC101TW above except in ivory color. CHREC101THW 782116126774 1 Port Wall Hanging Outlet: 1 RJ11 telephone connection (CAT3 rated) White color CHREC101THA 782116126781 1 Port Wall Outlet. Same as CHREC101THW above except in almond color. CHREC101THI 782116126798 1 Port Wall Outlet. Same as CHREC101THW above except in ivory color. CHREC101T5W 782116126804 1 Port Wall Outlet: 1 RJ45 Telephone/Data connection (CAT5e rated) White color CHREC101T5A 782116126811 1 Port Wall Outlet. Same as CHREC101T5W above except in almond color. CHREC101T5I 782116126828 1 Port Wall Outlet. Same as CHREC101T5W above except in ivory color. CHREC102W 782116126835 2 Port Multimedia Wall Outlet. Telephone/Data connection (CAT5e) 1 Coax TV connection (RG6) White color CHREC102A 782116126842 2 Port Multimedia Wall Outlet. Same as CHREC102W above except in almond color. CHREC102I 782116126859 2 Port Wall Outlet. Same as CHREC102W above except in ivory color. CHREC103W 782116126866 3 Port Multimedia Wall Outlet. 1 Telephone/Data connection (CAT5e) 2 Coax TV connections (RG6) White color CHREC103A 782116126873 3 Port Multimedia Wall Outlet. Same as CHREC103W above except in almond color. CHREC103I 782116126880 3 Port Wall Outlet. Same as CHREC103W above except in ivory color. CHREC104W 782116126897 4 Port Multimedia Wall Outlet. 2 Telephone/Data connections (CAT5e) 2 Coax TV connections (RG6) White color CHREC104A 782116126903 4 Port Multimedia Wall Outlet. Same as CHREC104W above except in almond color. CHREC104I 782116126910 4 Port Wall Outlet. Same as CHREC104W above except in ivory color. CHREC106W 782116126927 6 Port Multimedia Wall Outlet. 2 Telephone/Data connections (CAT5e) 2 Blanks (may be populated with CAT5e, Coax, or Fiber Optic connectors) 2 Coax TV connections (RG6) White color CHREC106A 782116126439 6 Port Multimedia Wall Outlet. Same as CHREC106W above except in almond color. CHREC106I 782116126972 6 Port Wall Outlet. Same as CHREC106W above except in ivory color. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — Effective August 2005 Data Tables Part Number UPC Code Product Description CHREC201W 782116126446 1 Port Blank Receptacle (White). (Blank face plates.) CHREC201A 782116126453 1 Port Blank Receptacle (Almond). (Blank face plates.) CHREC201I 782116126460 1 Port Blank Receptacle (Ivory). (Blank face plates.) CHREC202W 782116126477 2 Port Blank Receptacle (White). (Blank face plates.) CHREC202A 782116126484 2 Port Blank Receptacle (Almond). (Blank face plates.) CHREC202I 782116126491 2 Port Blank Receptacle (Ivory). (Blank face plates.) CHREC203W 782116126507 3 Port Blank Receptacle (White). (Blank face plates.) CHREC203A 782116126514 3 Port Blank Receptacle (Almond). (Blank face plates.) CHREC203I 782116126521 3 Port Blank Receptacle (Ivory). (Blank face plates.) CHREC204W 782116126538 4 Port Blank Receptacle (White). (Blank face plates.) CHREC204A 782116126545 4 Port Blank Receptacle (Almond). (Blank face plates.) CHREC204I 782116126552 4 Port Blank Receptacle (Ivory). (Blank face plates.) CHREC206W 782116126569 6 Port Blank Receptacle (White). (Blank face plates.) CHREC206A 782116126576 6 Port Blank Receptacle (Almond). (Blank face plates.) CHREC206I 782116126583 6 Port Blank Receptacle (Ivory). (Blank face plates.) CHINSBLRW CHINSBLRA CHINSBLRI 782116126590 782116126606 782116126613 Blank Insert for Receptacles (White) Blank Insert for Receptacles (Almond) Blank Insert for Receptacles (Ivory) CHINSC5RW CHINSC5RA CHINSC5RI 782116126620 782116126637 782116126644 CAT5e Insert for Receptacles (White) CAT5e Insert for Receptacles (Almond) CAT5e Insert for Receptacles (Ivory) CHINSCXRW CHINSCXRA CHINSCXRI 782116126651 782116126668 782116126675 RG6 Coax Inserts for Receptacles (White) RG6 Coax Inserts for Receptacles (Almond) RG6 Coax Inserts for Receptacles (Ivory) CHINSFORW CHINSFORA CHINSFORI 782116126682 782116126699 782116126705 ST Fiber Optic Inserts for Receptacles (White) ST Fiber Optic Inserts for Receptacles (Almond) ST Fiber Optic Inserts for Receptacles (Ivory) EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — ©Copyright 2005 Structured Wiring TABLE 10-9. BLANK RECEPTACLES AND RECEPTACLE INSERTS (SOLD IN 10 PACKS) 10-13 Accessories TABLE 10-10. PATCH CORDS AND MISCELLANEOUS Part Number UPC Code Product Description CHPCT21 CHPCT22 CHPCT2 782116009633 2 Pair, CAT3 Telephone Patch Cord (8 inches) 782116009640 2 Pair, CAT3 Telephone Patch Cord (24 inches) 782116009626 2 Pair, CAT3 Telephone Patch Cord (36 inches) CHPCT41 CHPCT42 CHPCT4 782116009664 4 Pair, CAT5e Telephone Patch Cord (8 inches) 782113533650 4 Pair, CAT5e Telephone Patch Cord (24 inches) 782116009657 4 Pair, CAT5e Telephone Patch Cord (36 inches) CHPCCXM CHPCCXM1 CHPCCXM2 CHPCCXM3 CHPCFO 782116009589 782116009596 782113533643 782116009602 782116009619 CHMOD01 782113965932 Single Channel Modulator. Used for creating an in-home television channel for viewing from any TV in the home. A signal from audio/video sources such as TV, VCR, DVD, DBS, satellite TV, and security cameras may be identified and displayed by any television. CHMOD03 782116009435 Triple Channel Modulator. Attach to a home entertainment center for creating an in-home television channel for viewing from any TV in the home. A single signal from audio/video sources such as TV, VCR, DVD, or satellite TV may be identified and displayed by any television. For multi-room video distribution, a separate Triple Channel Modulator (part Number MDMD or HBMD) must be installed in the distribution panel. CHLBO1 782113533476 Telephone Line Breakout Module. This module can be hung from an RJ45 wall plate to break out and put lines 1 – 4 on individual center pairs so that all four lines in the RJ45 jack are connectable to a standard RJ11 wired device. RG6-rated Mini Digital Cable (8 inches) RG6-rated Mini Digital Cable (14 inches) RG6-rated Mini Digital Cable (24 inches) RG6-rated Mini Digital Cable (36 inches) ST Fiber Optic Patch Cord (36 inches) TABLE 10-11. WIRE Structured Wiring 10-14 Part Number UPC Code Product Description CHHYD8 CHHYD12 782116009329 8 Leg, 3 Line KSU Hydra for connecting to KSU. 782116009312 12 Leg, 2 Line KSU Hydra for connecting to KSU. TABLE 10-12. POWER SUPPLIES Part Number UPC Code Product Description CHPSV110 782116009671 110 power supply for all coax hubs and modules (HBC-408, HBC-412, HBC-416, MDC-408, MDC-412, MDC-416). Windows is a registered trademark of Microsoft Corporation. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Structured Wiring — Effective August 2005 Terms and Conditions of Sale The Terms and Conditions of Sale set forth herein, and any supplements which may be attached hereto, constitute the full and final expression of the contract for the sale of products or services (hereinafter referred to as Product(s) or Services by Eaton Electrical Inc. (hereinafter referred to as Seller) to the Buyer, and supersedes all prior quotations, purchase orders, correspondence or communications whether written or oral between the Seller and the Buyer. Notwithstanding any contrary language in the Buyer’s purchase order, correspondence or other form of acknowledgment, Buyer shall be bound by these Terms and Conditions of Sale when it sends a purchase order or otherwise indicates acceptance of this contract, or when it accepts delivery from Seller of the Products or Services. THE CONTRACT FOR SALE OF THE PRODUCTS OR SERVICES IS EXPRESSLY LIMITED TO THE TERMS AND CONDITIONS OF SALE STATED HEREIN. ANY ADDITIONAL OR DIFFERENT TERMS PROPOSED BY BUYER ARE REJECTED UNLESS EXPRESSLY AGREED TO IN WRITING BY SELLER. No contract shall exist except as herein provided. COMPLETE AGREEMENT No amendment or modification hereto nor any statement, representation or warranty not contained herein shall be binding on the Seller unless made in writing by an authorized representative of the Seller. Prior dealings, usage of the trade or a course of performance shall not be relevant to determine the meaning of this contract even though the accepting or acquiescing party had knowledge of the nature of the performance and opportunity for objection. QUOTATIONS Written quotations are valid for 30 days from its date unless otherwise stated in the quotation or terminated sooner by notice. Verbal quotations, unless accepted, expire the same day they are made. A complete signed order must be received by Seller within 20 calendar days of notification of award, otherwise the price and shipment will be subject to re-negotiation. TERMINATION AND CANCELLATION Any order may be terminated by the Buyer only by written notice and upon payment of reasonable termination charges, including all costs plus profit. Seller shall have the right to cancel any order at any time by written notice if Buyer breaches any of the terms hereof, becomes the subject of any proceeding under state or federal law for the relief of debtors, or otherwise becomes insolvent or bankrupt, generally does not pay its debts as they become due or makes an assignment for the benefit of creditors. PRICES All prices are subject to change without notice. In the event of a price change, the effective date of the change will be the date of the new price or discount sheet, letter or telegram. All quotations made or orders accepted after the effective date will be on the new basis. For existing orders, the price of the unshipped portion of an order will be the price in effect at time of shipment. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Terms & Conditions — ©Copyright 2005 Terms & Conditions All terms and conditions are per your current vendor buying agreement. If there is no vendor buying agreement, then terms and conditions will be in accordance to the Eaton Electrical, Inc. selling policy 25000. The most recent version, at the time of printing this catalog, is on the following pages for your reference. 11-1 PRICE POLICY — PRODUCTS AND SERVICES When prices are quoted as firm for quoted shipment, they are firm provided the following conditions are met: 1. The order is released with complete engineering details. 2. Shipment of Products are made, and Services purchased are provided within the quoted lead-time. 3. When drawings for approval are required for any Products, the drawings applicable to those Products must be returned within 30 calendar days from the date of the original mailing of the drawings by Seller. The return drawings must be released for manufacture and shipment and must be marked “APPROVED” or “APPROVED AS NOTED.” Drawing re-submittals which are required for any other reason than to correct Seller errors will not extend the 30-day period. Terms of Payment PRODUCTS Acceptance of all orders is subject to the Buyer meeting Seller’s credit requirements. Terms of payment are subject to change for failure to meet such requirements. Seller reserves the right at any time to demand full or partial payment before proceeding with a contract of sale as a result of changes in the financial condition of the Buyer. Terms of Payment are either Net 30 days from the date of invoice of each shipment or carry a cash discount based on Product type. Specific payment terms for Products are outlined in the applicable Product discount schedules. SERVICES Orders less than $1,000 will be assessed a shipping and handling charge of 5% of the price of the order, with a minimum charge of $25.00 unless noted differently on Product discount sheets. Terms of payment are net within 30 days from date of invoice for orders amounting to less than $50,000.00. Terms of payment for orders exceeding $50,000.00 shall be made according to the following: 1. Twenty percent (20%) of order value with the purchase order payable 30 days from date of invoice. 2. Eighty percent (80%) of order value in equal monthly payments over the performance period payable 30 days from date of invoice. Except for work performed (i) under a firm fixed price basis or (ii) pursuant to terms of a previously priced existing contract between Seller and Buyer, invoices for work performed by Seller shall have added and noted on each invoice a charge of 3% (over and above the price of the work) which is related to Seller compliance with present and proposed environmental, health and safety regulations associated with prescribed requirements covering hazardous materials management and employee training, communications, personal protective equipment, documentation and record keeping associated therewith. TAXES ADEQUATE ASSURANCES The price does not include any taxes. Buyer shall be responsible for the payment of all taxes applicable to, or arising from the transaction, the Products, its sale, value, or use, or any Services performed in connection therewith regardless of the person or entity actually taxed. If, in the judgment of Seller, the financial condition of the Buyer, at any time during the period of the contract, does not justify the terms of payment specified, Seller may require full or partial payment in advance. 60 days for orders through contractors to allow time for their review and approval before and after transmitting them to their customers. If the Buyer initiates or in any way causes delays in shipment, provision of Services or return of approval drawings beyond the periods stated above, the price of the Products or Services will be increased 1% per month or fraction thereof up to a maximum of 18 months from the date of the Buyer’s order. For delays resulting in shipment or provision of Services beyond 18 months from the date of the Buyer’s order, the price must be renegotiated. PRICE POLICY — BLS Refer to Price Policy 25-050. MINIMUM BILLING Terms & Conditions DELAYED PAYMENT If payments are not made in accordance with these terms, a service charge will, without prejudice to the right of Seller to immediate payment, be added in an amount equal to the lower of 1.5% per month or fraction thereof or the highest legal rate on the unpaid balance. FREIGHT Freight policy will be listed on the Product discount sheets, or at option of Seller, one of the following freight terms will be quoted. 11-2 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Terms & Conditions — Effective August 2005 F.O.B. — P/S — FRT./PPD. AND INVOICED WITNESS TESTS/CUSTOMER INSPECTION Automatic Transfer Switches and Renewal Parts, and Electronic Operator Interface Products are sold F.O.B. point of shipment freight prepaid and invoiced to the Buyer. Standard factory tests may be witnessed by the Buyer at Seller’s factory for an additional charge calculated at the rate of $2,500 per day (not to exceed eight (8) hours) per Product type. Buyer may final inspect Products at the Seller’s factory for $500 per day per Product type. Witness tests will add one (1) week to the scheduled shipping date. Seller will notify Buyer fourteen (14) calendar days prior to scheduled witness testing or inspection. In the event Buyer is unable to attend, the Parties shall mutually agree on a rescheduled date. However, Seller reserves the right to deem the witness tests waived with the right to ship and invoice Products. All other Products sold are delivered F.O.B. point of shipment, freight prepaid and included in the price. F.O.B. DESTINATION — FRT./PPD. AND ALLOWED At Buyer’s option, Seller will deliver the Products F.O.B. destination freight prepaid and 2% will be added to the net price. The term “freight prepaid” means that freight charges will be prepaid to the accessible common carrier delivery point nearest the destination for shipments within the United States and Puerto Rico unless noted differently on the Product discount sheets. For any other destination, contact Seller’s representative. SHIPMENT AND ROUTING Seller shall select the point of origin or shipment, the method of transportation and the routing of the shipment. If the Buyer specifies a special mode of transportation, routing or delivery requirement, Buyer shall pay all special freight and handling charges. When freight is included in the price, no allowance will be made in lieu of transportation if the Buyer accepts shipment at factory, warehouse or freight station, or otherwise supplies its own transportation. RISK OF LOSS Risk of loss or damage to the Products shall pass to Buyer at the F.O.B. point. CONCEALED DAMAGE Except in the event of F.O.B. destination shipments, Seller will not participate in any settlement of claims for concealed damage. When shipment has been made on an F.O.B. destination basis, the Buyer must unpack immediately and, if damage is discovered, must: 1. Not move the Products from the point of examination. 2. Retain shipping container and packing material. 3. Notify the carrier in writing of any apparent damage. 4. Notify Seller representative within 72 hours of delivery. 5. Send Seller a copy of the carrier’s inspection report. HELD ORDERS For any order held, delayed or rescheduled at the request of the Buyer, Seller may, at its sole option (1) require payment to be based on any reasonable basis, including but not limited to the contract price, and any additional expenses, or cost resulting from such a delay; (2) store Products at the sole cost and risk of loss of the Buyer; and/or (3) charge to the Buyer those prices under the applicable price policy. Any order so held delayed or rescheduled beyond twelve (12) months will be treated as a Buyer termination. DRAWING APPROVAL Seller will design the Products in line with, in Seller’s judgment, good commercial practice. If at drawing approval Buyer makes changes outside of the design as covered in their specifications, Seller will then be paid reasonable charges and allowed a commensurate delay in shipping date based on the changes made. DRAWING RE-SUBMITTAL When Seller agrees to do so in its quotation, Seller shall provide Buyer with the first set of factory customer approval drawing(s) at Seller’s expense. The customer approval drawing(s) will be delivered at the quoted delivery date. If Buyer requests drawing changes or additions after the initial factory customer approval drawing(s) have been submitted by Seller, the Seller, at its option, may assess Buyer drawing charges. Factory customer approval drawing changes required due to misinterpretation by Seller will be at Seller’s expense. Approval drawings generated by Bid Manager姠 are excluded from this provision. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Terms & Conditions — ©Copyright 2005 Terms & Conditions F.O.B. — P/S — FRT./PPD. AND ALLOWED 11-3 Warranty WARRANTY FOR SERVICES WARRANTY FOR PRODUCTS Seller warrants that the Products manufactured by it will conform to Seller’s applicable specifications and be free from failure due to defects in workmanship and material for one (1) year from the date of installation of the Product or eighteen (18) months from the date of shipment of the Product, whichever occurs first. In the event any Product fails to comply with the foregoing warranty Seller will, at its option, either (a) repair or replace the defective Product, or defective part or component thereof, F.O.B. Seller’s facility freight prepaid, or (b) credit Buyer for the purchase price of the Product. All warranty claims shall be made in writing. Seller requires all non-conforming Products be returned at Seller’s expense for evaluation unless specifically stated otherwise in writing by Seller. This warranty does not cover failure or damage due to storage, installation, operation or maintenance not in conformance with Seller's recommendations and industry standard practice or due to accident, misuse, abuse or negligence. This warranty does not cover reimbursement for labor, gaining access, removal, installation, temporary power or any other expenses, which may be incurred in connection with repair or replacement. This warranty does not apply to equipment not manufactured by Seller. Seller limits itself to extending the same warranty it receives from the supplier. EXTENDED WARRANTY FOR PRODUCTS Terms & Conditions 11-4 If requested by the Buyer and specifically accepted in writing by Seller, the foregoing standard warranty for Products will be extended from the date of shipment for the period and price indicated below: ✓ 24 months — 2% of Contract Price ✓ 30 months — 3% of Contract Price ✓ 36 months — 4% of Contract Price SPECIAL WARRANTY (IN AND OUT) FOR PRODUCTS If requested by the Buyer and specifically accepted in writing by Seller, Seller will, during the warranty period for Products, at an additional cost of 2% of the contract price, be responsible for the direct cost of: 1. Removing the Product from the installed location. 2. Transportation to the repair facility and return to the site. 3. Reinstallation on site. The total liability of Seller for this Special Warranty for Products is limited to 50% of the contract price of the particular Product being repaired and excludes expenses for removing adjacent apparatus, walls, piping, structures, temporary service, etc. Seller warrants that the Services performed by it hereunder will be performed in accordance with generally accepted professional standards. The Services, which do not so conform, shall be corrected by Seller upon notification in writing by the Buyer within one (1) year after completion of the Services. Unless otherwise agreed to in writing by Seller, Seller assumes no responsibility with respect to the suitability of the Buyer’s, or its customer’s, equipment or with respect to any latent defects in equipment not supplied by Seller. This warranty does not cover damage to Buyer’s, or its customer’s, equipment, components or parts resulting in whole or in part from improper maintenance or operation or from their deteriorated condition. Buyer will, at its cost, provide Seller with unobstructed access to the defective Services, as well as adequate free working space in the immediate vicinity of the defective Services and such facilities and systems, including, without limitation, docks, cranes and utility disconnects and connects, as may be necessary in order that Seller may perform its warranty obligations. The conducting of any tests shall be mutually agreed upon and Seller shall be notified of, and may be present at, all tests that may be made. WARRANTY FOR POWER SYSTEMS STUDIES Seller warrants that any power systems studies performed by it will conform to generally accepted professional standards. Any portion of the study, which does not so conform, shall be corrected by Seller upon notification in writing by the Buyer within six (6) months after completion of the study. All warranty work shall be performed in a single shift straight time basis Monday through Friday. In the event that the study requires correction of warranty items on an overtime schedule, the premium portion of such overtime shall be for the Buyer’s account. LIMITATION ON WARRANTIES FOR PRODUCTS, SERVICES AND POWER SYSTEMS STUDIES THE FOREGOING WARRANTIES ARE EXCLUSIVE EXCEPT FOR WARRANTY OF TITLE. SELLER DISCLAIMS ALL OTHER WARRANTIES INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. CORRECTION OF NON-CONFORMITIES IN THE MANNER AND FOR THE PERIOD OF TIME PROVIDED ABOVE SHALL CONSTITUTE SELLER’S SOLE LIABILITY AND BUYER’S EXCLUSIVE REMEDY FOR FAILURE OF SELLER TO MEET ITS WARRANTY OBLIGATIONS, WHETHER CLAIMS OF THE BUYER ARE BASED IN CONTRACT, IN TORT (INCLUDING NEGLIGENCE OR STRICT LIABILITY), OR OTHERWISE. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Terms & Conditions — Effective August 2005 ASBESTOS LIQUIDATED DAMAGES Federal Law requires that building or facility owners identify the presence, location and quantity of asbestos containing material (hereinafter “ACM”) at work sites. Seller is not licensed to abate ACM. Accordingly, for any contract which includes the provision of Services, prior to (i) commencement of work at any site under a specific Purchase Order, (ii) a change in the work scope of any Purchase Order, the Buyer will certify that the work area associated with the Seller’s scope of work includes the handling of Class II ACM, including but not limited to generator wedges and high temperature gaskets which include asbestos materials. The Buyer shall, at its expense, conduct abatement should the removal, handling, modification or reinstallation, or some or all of them, of said Class II ACM be likely to generate airborne asbestos fibers; and should such abatement affect the cost of or time of performance of the work then Seller shall be entitled to an equitable adjustment in the schedule, price and other pertinent affected provisions of the contract. Contracts which include liquidated damage clauses for failure to meet shipping or job completion promises are not acceptable or binding on Seller, unless such clauses are specifically accepted in writing by an authorized representative of the Seller at its headquarters office. Seller’s Products are sold as commercial grade Products not intended for application in facilities or activities licensed by the United States Nuclear Regulatory Commission for atomic purposes. Further certification will be required for use of the Products in any safety-related application in any nuclear facility licensed by the U.S. Nuclear Regulatory Commission. RETURNING PRODUCTS Authorization and shipping instructions for the return of any Products must be obtained from Seller before returning the Products. When return is occasioned due to Seller error, full credit including all transportation charges will be allowed. PRODUCT NOTICES Buyer shall provide the user (including its employees) of the Products with all Seller supplied Product notices, warnings, instructions, recommendations, and similar materials. FORCE MAJEURE Seller shall not be liable for failure to perform or delay in performance due to fire, flood, strike or other labor difficulty, act of God, act of any governmental authority or of the Buyer, riot, embargo, fuel or energy shortage, car shortage, wrecks or delays in transportation, or due to any other cause beyond Seller’s reasonable control. In the event of delay in performance due to any such cause, the date of delivery or time for completion will be extended by a period of time reasonably necessary to overcome the effect of such delay. Seller will defend or, at its option, settle any suit or proceeding brought against Buyer, or Buyer’s customers, to the extent it is based upon a claim that any Product or part thereof, manufactured by Seller or its subsidiaries and furnished hereunder, infringes any United States patent, other than a claim of infringement based upon use of a Product or part thereof in a process, provided Seller is notified in reasonable time and given authority, information and assistance (at Seller’s expense) for the defense of same. Seller shall pay all legal and court costs and expenses and court-assessed damages awarded therein against Buyer resulting from or incident to such suit or proceeding. In addition to the foregoing, if at any time Seller determines there is a substantial question of infringement of any United States patent, and the use of such Product is or may be enjoined, Seller may, at its option and expense: either (a) procure for Buyer the right to continue using and selling the Product; (b) replace the Product with non-infringing apparatus; (c) modify the Product so it becomes non-infringing; or (d) as a last resort, remove the Product and refund the purchase price, equitably adjusted for use and obsolescence. In no case does Seller agree to pay any recovery based upon its Buyer’s savings or profit through use of Seller’s Products whether the use be special or ordinary. The foregoing states the entire liability of Seller for patent infringement. The preceding paragraph does not apply to any claim of infringement based upon: (a) any modification made to a Product other than by Seller; (b) any design and/or specifications of Buyer to which a Product was manufactured; or (c) the use or combination of Product with other products where the Product does not itself infringe. As to the above-identified claim situations where the preceding paragraph does not apply, Buyer shall defend and hold Seller harmless in the same manner and to the extent as Seller’s obligations described in the preceding paragraph. Buyer shall be responsible for obtaining (at Buyer’s expense) all license rights required for Seller to be able to use software products in the possession of Buyer where such use is required in order to perform any Service for Buyer. With respect to a Product or part thereof not manufactured by Seller or its subsidiaries, Seller will attempt to obtain for Buyer, from the supplier(s), the patent indemnification protection normally provided by the supplier(s) to customers. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Terms & Conditions — ©Copyright 2005 Terms & Conditions COMPLIANCE WITH NUCLEAR REGULATION PATENT INFRINGEMENT 11-5 COMPLIANCE WITH OSHA Seller offers no warranty and makes no representation that its Products comply with the provisions or standards of the Occupational Safety and Health Act of 1970, or any regulation issued thereunder. In no event shall Seller be liable for any loss, damage, fines, penalty or expenses arising under said Act. LIMITATION OF LIABILITY Terms & Conditions 11-6 THE REMEDIES OF THE BUYER SET FORTH IN THIS CONTRACT ARE EXCLUSIVE AND ARE ITS SOLE REMEDIES FOR ANY FAILURE OF SELLER TO COMPLY WITH ITS OBLIGATIONS HEREUNDER. NOTWITHSTANDING ANY PROVISION IN THIS CONTRACT TO THE CONTRARY, IN NO EVENT SHALL SELLER BE LIABLE IN CONTRACT, IN TORT (INCLUDING NEGLIGENCE OR STRICT LIABILITY) OR OTHERWISE FOR DAMAGE TO PROPERTY OR EQUIPMENT OTHER THAN PRODUCTS SOLD HEREUNDER, LOSS OF PROFITS OR REVENUE, LOSS OF USE OF PRODUCTS, COST OF CAPITAL, CLAIMS OF CUSTOMERS OF THE BUYER OR ANY SPECIAL, INDIRECT, INCIDENTAL OR CONSEQUENTIAL DAMAGES WHATSOEVER, REGARDLESS OF WHETHER SUCH POTENTIAL DAMAGES ARE FORESEEABLE OR IF SELLER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. THE TOTAL CUMULATIVE LIABILITY OF SELLER ARISING FROM OR RELATED TO THIS CONTRACT WHETHER THE CLAIMS ARE BASED IN CONTRACT, IN TORT (INCLUDING NEGLIGENCE OR STRICT LIABILITY) OR OTHERWISE, SHALL NOT EXCEED THE PRICE OF THE PRODUCT OR SERVICES ON WHICH SUCH LIABILITY IS BASED. EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Terms & Conditions — Effective August 2005 A G A-Bus. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-7 General-Duty . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-7 ACD . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-3 Generator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 AFCI Tester . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-18 GFCI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-15 Air Conditioner Disconnect (ACD) . . . . . . . . . . . . . . . . . . . . . . 6-3 GFI. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-15 Air Conditioner Switches. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-3 Ground Fault . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-10 Air Conditioning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-1 Ground Fault Circuit Interrupter (GFCI) . . . . . . . . . . . . . . . . . 1-16 Alarm Contacts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-25 Grounded Fifth Terminal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-2 All-in-Ones . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-1 Group Metering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-8 Arc Fault Circuit Interrupters (AFCIs) . . . . . . . . . . . . . . . . . . . 1-13 H Audio. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 Automatic Transfer Switches . . . . . . . . . . . . . . . . . . . . . . . . . . 9-3 HACR Rated . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-2 Auxiliary . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-25 Handle Lockdogs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-3 Handle Lockoffs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-3 B Handle Ties . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-3 Backup Power. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-2 Heating . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-1 BJ Main Breaker . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-27 Heavy-Duty. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-7 BJH Main Breaker . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-27 High Magnetic . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-6 Breaker Box . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-1 Hold-Down Kits . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-3 Home Automation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-9 C Horn Bypass. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-2 Cable . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-1 Hot Tub. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-1 CAT5e . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-13 House Panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-6 CHSP Series . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-1 I Circuit Analyzer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-18 Circuit Breakers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-1 Internet . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 Classified Breaker. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-19 L Coaxial . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 Combination Service Entrance Devices (Non-EUSERC) . . . . . 3-3 Lever Bypass . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-5 Combo Units. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-1 Loadcenter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-1 Lug Tree Kit . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-19 D M Data Communications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 Disconnects . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-3 Main Breakers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-24 Double Throw Emergency Power Safety Switch . . . . . . . . . . 6-7 Main Fusible Switches . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-15 Duplex Breaker . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-8 Main Tenant Circuit Breakers . . . . . . . . . . . . . . . . . . . . . . . . . 4-20 Main Terminal Box . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-10 Manual Transfer Switch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-4 Electric Utility . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-1 Mechanical Interlock . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-3 Electrical Box . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-1 Meter Breaker . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-1 Emergency Generator Panel . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-4 Meter Pack . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-9 Emergency Power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 Meter Socket . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-1 Emergency Power Safety Switch . . . . . . . . . . . . . . . . . . . . . . . 6-7 Meter Stacks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-9 Ethernet. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-1 Mounting Bases. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-3 EUSERC. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3-5 Multi-Family . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-8 Multiple Metering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-8 F N FIRE-GUARD . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-13 Fuse Box . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-1 Index E Non-CTL . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-11 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Index — ©Copyright 2005 12-1 P W Plug Fuse Safety Switch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-7 Water Pump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7-1 Plug-on Circuit Breakers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-4 Water Pump Pressure Switch . . . . . . . . . . . . . . . . . . . . . . . . . . 7-1 POPs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-1 Portable Generators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 Power Outlet Panel (POP) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-1 Power Strips . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-3 Pressure Switch. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7-1 Pull Box . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-15 Pullouts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-3 Pumps . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7-1 Q Quadplex Breaker . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-8 QuickPro. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2-44 R Refrigeration Equipment Application . . . . . . . . . . . . . . . . . . . 1-1 Replacement Circuit Breakers . . . . . . . . . . . . . . . . . . . . . . . . . 1-4 Ring Type Cover . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-5 Ringless Type Cover . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4-5 S Safety Switch. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-7 Safety Switch Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-18 Satellite . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 Security . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 Service Entrance . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-24 Shunt Trips . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-25 Solid and stranded wire . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-1 Spa Panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-1 Spa Pumps. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-1 Speakers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-8 Standby Generators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-1 Structured Wiring . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 Sub-feed Blocks. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-9 Surge Breaker . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-9 Surge Panels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-3 Surge Protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-1 Surge Strip. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-1 Switching Duty Rated . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-2 T Index Telephone . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8-1 Television. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10-1 Temporary Power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-1 Transfer Switch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9-3 Twin Circuit Breakers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-4 Type BR . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1-5 12-2 EATON CORPORATION Cutler-Hammer Retail Solutions Book — 1-877-932-9322 — Index — Effective August 2005
DH364FRK 价格&库存
很抱歉,暂时无法提供与“DH364FRK”相匹配的价格&库存,您可以联系我们找货
