EASY-E4-DC-8TE1
EASY-E4-DC-8TE1
    EATON(伊顿)
    EATON MOELLER - EASY-E4-DC-8TE1 - Digital I/O Module, 4 I/O, 24 VDC, easyE4 Series
EASY-E4-DC-8TE1 数据手册
DATASHEET - EASY-E4-DC-8TE1 I/O expansion, For use with easyE4, 24 V DC, Inputs expansion (number) digital: 4, screw terminal Delivery program Part no.  Catalog No.    EL-Nummer (Norway)  EASY-E4-DC-8TE1 197219 4500552 Product range     Control relays easyE4 Subrange     easyE4 digital input/output enhancements Basic function     easyE4 extensions Description     Input/output extension for easyE4 control relay Expandable with the easyE4 series of digital input/output expansions with easy-E4CONNECT1 connector (Item Y7-197225) Rated operating voltage 24V DC Digital inputs: 4 Digital outputs: 4 transistor Screw terminals Inputs           digital: 4           4       Display     with diagnostic LED Software     EASYSOFT-SWLIC/easySoft 7 Supply voltage     24 V DC For use with     easyE4 Standards     EN 61000-6-2 EN 61000-6-3 IEC 60068-2-6 IEC 60068-2-27 IEC 60068-2-30 IEC 61131-2 EN 61010 EN 50178 Approvals       Approvals     cULus certificate     CE shipping classification     DNV GL       Dimensions (W x H x D)   mm 35.5 x 90 x 58 Weight   kg 0.081 Mounting     Top-hat rail IEC/EN 60715, 35 mm or screw fixing using fixing brackets ZB4-101-GF1 (accessories) Connection type     Screw terminal Screw terminals     Inputs expansion (number) Outputs Transistor Additional features Technical data General Terminal capacities   Solid   2 mm 0.2 - 4 flexible   mm 2 0.2 - 2.5 Solid or flexible conductor, with ferrule   mm 2 0,2 - 2,5 Solid or stranded   AWG 22 - 12 Standard screwdriver   mm 0.8 x 3.5 Tightening torque   Nm 0.5 - 0.7 02/18/2020 Eaton Y7-197219 ED2020 V65.0 EN 1/6 Stripping length   mm 6.5 Operating ambient temperature   °C -25 to 55, cold as per IEC 60068-2-1, heat as per IEC 60068-2-2 Condensation     Take appropriate measures to prevent condensation Storage ϑ °C -40 - +70 relative humidity   % in accordance with IEC 60068-2-30, IEC 60068-2-78 5 - 95 Air pressure (operation)   hPa 795 - 1080 Protection type (IEC/EN 60529, EN50178, VBG 4)     IP20 Vibrations   Hz In accordance with IEC 60068-2-6 constant amplitude 0.15 mm: 10 - 57 constant acceleration 2 g: 57 - 150 Mechanical shock resistance (IEC/EN 60068-2-27) semi-sinusoidal 15 g/11 ms   Impacts 18 Drop to IEC/EN 60068-2-31 Drop height mm 50 Free fall, packaged (IEC/EN 60068-2-32)   m 0.3 Mounting position     Vertical or horizontal Overvoltage category/pollution degree     III/2 Electrostatic discharge (ESD)       applied standard     according to IEC EN 61000-4-2 Air discharge   kV 8 Contact discharge   kV 6 Electromagnetic fields (RFI) to IEC EN 61000-4-3   V/m 0.8 - 1.0 GHz: 10 1.4 - 2 GHz: 3 2.0 - 2.7 GHz: 1 Radio interference suppression     EN 61000-6-3 Class B Burst   kV according to IEC/EN 61000-4-4 Supply cables: 2 Signal cables: 2 power pulses (Surge)     according to IEC/EN 61000-4-5 0.5 kV (supply cables, symmetrical) 1 kV (supply cables, asymmetrical) Immunity to line-conducted interference to (IEC/EN 61000-4-6)   V 10 Clearance in air and creepage distances     nach EN 50178, EN 61010-2-201, UL61010-2-201, CSA-C22.2 NO. 61010-2-201 Insulation resistance     in accordance with EN 50178, EN 61010-2-201, UL61010-2-201, CSA-C22.2 NO. 61010-2-201 Rated operational voltage Ue V 24 DC (-15/+20%) Permissible range Ue   20.4 - 28.8 V DC Residual ripple   % ≦5 Siemens MPI, (optional)     yes Input current     max. 40 mA at Ue Voltage dips   ms ≤ 10 Fuse   A ≧ 2.5A (T) Power loss P W Normally 1 Heat dissipation at 24 V DC   W 1 Number     4 Potential isolation     from power supply: no between inputs: no from the outputs: no to expansion devices: yes to base unit: yes Rated operational voltage Ue V DC 24 Input voltage   V DC Signal 0: ≦ 5 (I1 - I4) Signal 1: ≧ 15 (I1 - I4) Input current at signal 1   mA 3.3 (I1 – I4) Deceleration time   ms type 0.1 (0 -> 1) type 0.2 (1 -> 0) Cable length   m 100 (unshielded) Climatic environmental conditions Ambient conditions, mechanical Electromagnetic compatibility (EMC) Insulation resistance Power supply Digital inputs 24 V DC 02/18/2020 Eaton Y7-197219 ED2020 V65.0 EN 2/6 Transistor outputs Number     4 Rated operational voltage Ue V DC 24 Permissible range Ue   20.4 - 28.8 V DC Residual ripple   % 5 Siemens MPI, (optional)     Yes (Caution: A short circuit will occur if a supply voltage of the wrong polarity is applied to the outputs.) Potential isolation     from power supply: no between the inputs: no to the outputs: no to base unit: yes to expansion devices: yes Rated operational current at signal „1” DC per channel Ie A Max. 0.5 Residual current on 0 signal per channel   mA < 0.005 Max. output voltage   V 1 (at status 0 per channel) U = Ue - 1 V (signal 1 at Ie = 0.5 A) Short-circuit protection     yes, electronic (Q1 - Q4) Short-circuit tripping current for Ra ≦ 10 mΩ   A 0.7 ≦ Ie ≦ 1.7 per output depending on number of active channels and their load Total short-circuit current   A 6.8 Thermal cutout     Yes Max. operating frequency with constant resistive load   Operations/ abhängig von der Zykluszeit des Basisgeräts und bei Erweiterungsgeräten auch h von deren Übertragungszeit Parallel connection of outputs       With resistive load, inductive load with external suppressor circuit, combination within a group     Group 1: Q1 to Q4 Number of outputs max.   4 Max. total current   A 2                   Utilization factor   g 0.25 Duty factor   % DF 100       Utilization factor   g 0.25 Duty factor   % DF 100       Utilization factor   g 1 Duty factor   % DF 100 Max. switching frequency, max. duty factor   OperationsDepending on the suppressor circuit P W 1       Static heat dissipation, non-current-dependent Pvs W 1 Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 55       10.2 Strength of materials and parts       10.2.2 Corrosion resistance     Meets the product standard's requirements. 10.2.3.1 Verification of thermal stability of enclosures     Meets the product standard's requirements. 10.2.3.2 Verification of resistance of insulating materials to normal heat     Meets the product standard's requirements. 10.2.3.3 Verification of resistance of insulating materials to abnormal heat and fire due to internal electric effects     Meets the product standard's requirements. 10.2.4 Resistance to ultra-violet (UV) radiation     Meets the product standard's requirements. 10.2.5 Lifting     Does not apply, since the entire switchgear needs to be evaluated. 10.2.6 Mechanical impact     Does not apply, since the entire switchgear needs to be evaluated. 10.2.7 Inscriptions     Meets the product standard's requirements. Inductive load to EN 60947-5-1 Without external suppressor circuit DC-13, T0.95 = 72 ms, R = 48 Ω, L = 1.15 H T0.95 = 15 ms, R = 48 Ω, L = 0.24 H With external suppressor circuit Supply voltage UAux Power loss Design verification as per IEC/EN 61439 Technical data for design verification IEC/EN 61439 design verification 02/18/2020 Eaton Y7-197219 ED2020 V65.0 EN 3/6 10.3 Degree of protection of ASSEMBLIES     Meets the product standard's requirements. 10.4 Clearances and creepage distances     Meets the product standard's requirements. 10.5 Protection against electric shock     Does not apply, since the entire switchgear needs to be evaluated. 10.6 Incorporation of switching devices and components     Does not apply, since the entire switchgear needs to be evaluated. 10.7 Internal electrical circuits and connections     Is the panel builder's responsibility. 10.8 Connections for external conductors     Is the panel builder's responsibility. 10.9 Insulation properties       10.9.2 Power-frequency electric strength     Is the panel builder's responsibility. 10.9.3 Impulse withstand voltage     Is the panel builder's responsibility. 10.9.4 Testing of enclosures made of insulating material     Is the panel builder's responsibility. 10.10 Temperature rise     The panel builder is responsible for the temperature rise calculation. Eaton will provide heat dissipation data for the devices. 10.11 Short-circuit rating     Is the panel builder's responsibility. 10.12 Electromagnetic compatibility     Is the panel builder's responsibility. 10.13 Mechanical function     The device meets the requirements, provided the information in the instruction leaflet (IL) is observed. Technical data ETIM 7.0 PLC's (EG000024) / Logic module (EC001417) Electric engineering, automation, process control engineering / Control / Programmable logic control (SPS) / Logic module (ecl@ss10.0.1-27-24-22-16 [AKE539014]) Supply voltage AC 50 Hz   V 0-0 Supply voltage AC 60 Hz   V 0-0 Supply voltage DC   V 20.4 - 28.8 Voltage type of supply voltage     DC Switching current   A 0.5 Number of analogue inputs     0 Number of analogue outputs     0 Number of digital inputs     4 Number of digital outputs     4 With relay output     No Number of HW-interfaces industrial Ethernet     0 Number of interfaces PROFINET     0 Number of HW-interfaces RS-232     0 Number of HW-interfaces RS-422     0 Number of HW-interfaces RS-485     0 Number of HW-interfaces serial TTY     0 Number of HW-interfaces USB     0 Number of HW-interfaces parallel     0 Number of HW-interfaces Wireless     0 Number of HW-interfaces other     2 With optical interface     No Supporting protocol for TCP/IP     No Supporting protocol for PROFIBUS     No Supporting protocol for CAN     No Supporting protocol for INTERBUS     No Supporting protocol for ASI     No Supporting protocol for KNX     No Supporting protocol for MODBUS     No Supporting protocol for Data-Highway     No Supporting protocol for DeviceNet     No Supporting protocol for SUCONET     No Supporting protocol for LON     No Supporting protocol for PROFINET IO     No Supporting protocol for PROFINET CBA     No Supporting protocol for SERCOS     No Supporting protocol for Foundation Fieldbus     No 02/18/2020 Eaton Y7-197219 ED2020 V65.0 EN 4/6 Supporting protocol for EtherNet/IP     No Supporting protocol for AS-Interface Safety at Work     No Supporting protocol for DeviceNet Safety     No Supporting protocol for INTERBUS-Safety     No Supporting protocol for PROFIsafe     No Supporting protocol for SafetyBUS p     No Supporting protocol for other bus systems     No Radio standard Bluetooth     No Radio standard WLAN 802.11     No Radio standard GPRS     No Radio standard GSM     No Radio standard UMTS     No IO link master     No Redundancy     No With display     No Degree of protection (IP)     IP20 Basic device     No Expandable     Yes Expansion device     Yes With timer     No Rail mounting possible     Yes Wall mounting/direct mounting     Yes Front build in possible     No Rack-assembly possible     No Suitable for safety functions     No Category according to EN 954-1       SIL according to IEC 61508     None Performance level acc. EN ISO 13849-1     None Appendant operation agent (Ex ia)     No Appendant operation agent (Ex ib)     No Explosion safety category for gas     None Explosion safety category for dust     None Width   mm 35.5 Height   mm 90 Depth   mm 58 UL File No.     E205091 UL Category Control No.     NRAQ/7 North America Certification     UL listed Degree of Protection     IEC: IP20, UL/CSA Type: - Approvals 02/18/2020 Eaton Y7-197219 ED2020 V65.0 EN 5/6 Dimensions Assets (links) Declaration of CE Conformity 00003206 Instruction Leaflets IL050021ZU2019_02 Manuals MN050009_EN (English) Additional product information (links) assembly instructions easyE4 IL050021ZU assembly instructions easyE4 IL050021ZU ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL050021ZU2019_02.pdf easyE4 (MN050009) manual easyE4 – Handbuch (MN050009) - Deutsch ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_DE.pdf easyE4 (MN050009) manual - English ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_EN.pdf Manuale easy E4 (MN050009) - italiano ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_IT.pdf instrukcja easyE4 (MN050009) - polski ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_PL.pdf f1=1454&f2=1174&f3=1755;Download Software http://applications.eaton.eu/sdlc?LX=11& easySoft V7 Product overview (WEB) 02/18/2020 http://www.eaton.eu/easyE4 Eaton Industries GmbH http://www.eaton.eu © 02/2020 by Eaton Industries GmbH Eaton Y7-197219 ED2020 V65.0 EN 6/6
EASY-E4-DC-8TE1 价格&库存
很抱歉,暂时无法提供与“EASY-E4-DC-8TE1”相匹配的价格&库存,您可以联系我们找货
