FAK-R/V/KC11/1Y
FAK-R/V/KC11/1Y
    EATON(伊顿)
FAK-R/V/KC11/1Y 数据手册
Palm�switch,�1N/O+1N/C,�emergency�switching�off,�surface�mounting Delivery�programme Part�no.  Article�no.  Catalog�No.  FAK-R/V/KC11/IY 229748 FAK-R-V-KC11-IY Product range     Foot and palm switches Basic function     Basic devices Single unit/Complete unit     Complete unit Function     maintained Description     Pull to release Emergency stop pushbutton tamper-proof to ISO 13850/EN 418 Contacts       N/O = Normally open     1 N/O N/C = Normally closed     Notes           Colour     Enclosure base RAL 9005, black Operator only RAL 1004, yellow       yellow Contact sequence     Colour       Button     Red       enclosure top           Enclosure base           Enclosure�color 12/21/2015 1 NC = safety function, by positive opening to IEC/EN 60947-5-1 Yellow Black 229748 - HPL-ED2015 V18.0 EN 1/3 Approval     Connection to SmartWire-DT     Lifespan, mechanical Operations x 10 Operating frequency Operations/h   Actuating force   N 40 - 60 Degree of protection, IEC/EN 60529     IP67, IP69K Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Ambient temperature         °C -25 - +40 Mounting position     As required Mechanical shock resistance   g > 15 Shock duration 11 ms Sinusoidal according to IEC 60068-2-27 no Technical�data General Open Design�verification�as�per�IEC/EN�61439 Technical data for design verification 6 > 0.1 600       Rated operational current for specified heat dissipation In A 6 Heat dissipation per pole, current-dependent Pvid W 0.11 Equipment heat dissipation, current-dependent Pvid W 0 Static heat dissipation, non-current-dependent Pvs W 0 Heat dissipation capacity Pdiss W 0 Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 40 IEC/EN 61439 design verification       10.2 Strength of materials and parts       10.2.2 Corrosion resistance     Meets the product standard's requirements. 10.2.3.1 Verification of thermal stability of enclosures     Meets the product standard's requirements. 10.2.3.2 Verification of resistance of insulating materials to normal heat     Meets the product standard's requirements. 10.2.3.3 Verification of resistance of insulating materials to abnormal heat and fire due to internal electric effects     Meets the product standard's requirements. 10.2.4 Resistance to ultra-violet (UV) radiation     Please enquire 10.2.5 Lifting     Does not apply, since the entire switchgear needs to be evaluated. 10.2.6 Mechanical impact     Does not apply, since the entire switchgear needs to be evaluated. 10.2.7 Inscriptions     Meets the product standard's requirements. 10.3 Degree of protection of ASSEMBLIES     Does not apply, since the entire switchgear needs to be evaluated. 10.4 Clearances and creepage distances     Meets the product standard's requirements. 10.5 Protection against electric shock     Does not apply, since the entire switchgear needs to be evaluated. 10.6 Incorporation of switching devices and components     Does not apply, since the entire switchgear needs to be evaluated. 10.7 Internal electrical circuits and connections     Is the panel builder's responsibility. 12/21/2015 229748 - HPL-ED2015 V18.0 EN 2/3 10.8 Connections for external conductors     Is the panel builder's responsibility. 10.9 Insulation properties       10.9.2 Power-frequency electric strength     Is the panel builder's responsibility. 10.9.3 Impulse withstand voltage     Is the panel builder's responsibility. 10.9.4 Testing of enclosures made of insulating material     Is the panel builder's responsibility. 10.10 Temperature rise     The panel builder is responsible for the temperature rise calculation. Eaton will provide heat dissipation data for the devices. 10.11 Short-circuit rating     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.12 Electromagnetic compatibility     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.13 Mechanical function     The device meets the requirements, provided the information in the instruction leaflet (IL) is observed. Technical�data�ETIM�6.0 Low-voltage industrial components (EG000017) / Foot-/palm switch complete (EC000231) Electric engineering, automation, process control engineering / Low-voltage switch technology / Command and alarm device / Foot, palm switch (ecl@ss8.1-27-37-12-17 [AKF035011]) Unlocking method     Pull release Colour cap     Red Number of contacts as normally open contact     1 Number of contacts as normally closed contact     1 Switching function latching     Yes Spring-return     No Hole diameter   mm 0 Degree of protection (IP)     IP67 Product Standards     IEC/EN 60947-5; UL 508; CSA-C22.2 No. 14-05; CSA-C22.2 No. 94-91; CE marking UL File No.     E29184 UL Category Control No.     NKCR CSA File No.     012528 CSA Class No.     3211-03 North America Certification     UL listed, CSA certified Degree of Protection     UL/CSA Type 3R, 4X, 12, 13 Approvals Dimensions 3 x M20 (PG 13.5) on the side 1 x M16 in the base Additional�product�information�(links) IL04716006Z�(AWA1160-1696)�Indicator�light IL04716006Z (AWA1160-1696) Indicator light ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL04716006Z2011_02.pdf IL04716017Z�(AWA1160-1467)�Foot�and�palm�switches IL04716017Z (AWA1160-1467) Foot and palm switches 12/21/2015 ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL04716017Z2011_02.pdf Eaton Industries GmbH http://www.eaton.eu © 12/2015 by Eaton Industries GmbH 229748 - HPL-ED2015 V18.0 EN 3/3
FAK-R/V/KC11/1Y 价格&库存
很抱歉,暂时无法提供与“FAK-R/V/KC11/1Y”相匹配的价格&库存,您可以联系我们找货
