FNQ-15
FNQ-15
    EATON(伊顿)
    5AG,10.00 x 38.10mm
    FUSE CARTRIDGE 15A 500VAC 5AG
FNQ-15 数据手册
Effective February 2016 Supersedes April 2014 Technical Data 1012 FNQ 13⁄32˝ x 1-1⁄2˝ 500Vac time-delay supplemental fuses Catalog symbol / color code: • Dimensions - in (mm) FNQ - Orange (500Vac maximum voltage) Description: Bussmann® series time-delay FNQ supplemental fuses. For superior protection, upgrade to FNQ-R Class CC fuses. See data sheet no. 1014. Specifications: Ratings Fuse Amp Range 500Vac UL CSA 10kA X X • Features • Color coded for 500Vac maximum voltage rating • Fiber tube construction • Nickel-plated brass endcaps • Motor control transformers • Circuits with in-rush currents. Recommended fuse blocks/fuse holders Agency information 500Vac 1/10 to 30A 1.5" (38.1) Typical applications Interrupting Rating Agency at Rated Voltage Information 1/10 to 30 0.41" (10.3) Catalog symbol UL® Listed, Std. 248-14, Guide JDYX, File E19180 • CSA® Certified: C22.2 No. 248.14, Class 1422-01, File 53787, HRC-MISC • CE • RoHS compliant* Description Data sheet no.# Blocks 1-, 2- and 3-pole modular BMM blocks with optional covers 10235 BM 1-, 2- and 3-pole blocks 1104 DIN-rail holders / switches CCP-_-30M 1-, 2- and 3-pole switch 1157 CHM 1-, 2- and 3-pole 3185 * FNQ-1/8 not RoHS compliant. Optima NG 3-Pole protection module Catalog numbers (amps) FNQ-1/10 FNQ-8/10 FNQ-3-2/10 FNQ-9 FNQ-1/8 FNQ-1 FNQ-3-1/2 FNQ-10 FNQ-15/100 FNQ-1-1/8 FNQ-4 FNQ-12 FNQ-3/16 FNQ-1-1/4 FNQ-4-1/2 FNQ-14 FNQ-2/10 FNQ-1-1/2 FNQ-5 FNQ-15 FNQ-1/4 FNQ-1-6/10 FNQ-5-6/10 FNQ-20 FNQ-3/10 FNQ-2 FNQ-6 FNQ-25 FNQ-4/10 FNQ-2-1/4 FNQ-6-1/4 FNQ-30 FNQ-1/2 FNQ-2-1/2 FNQ-7 FNQ-6/10 FNQ-3 FNQ-8 1109 Optima 3-Pole holder 1102 Optima 3-Pole holder + switch 1103 Panel mount holders HPM and HPM-D 1-Pole holder 2112 HPC-D 1-Pole holder 2109 HPS2 2-Pole holder 2140 HPF, HPF-C and 1-Pole holder HPF-WT 2114 HPS 1-Pole holder 2113 HPG and HPD 1-Pole holder 2108 In-line holders Carton quantity HEB 1-Pole holder 2127 HEX 2-Pole holder 2126 Amps Qty. Fuseclips 1/10 to 30 10 1A3400, 5956 and PCB fuseclips 5960 2132 Fuse covers SAMI-7 Finger-safe fuse cover 1204 FNQ Series 500Vac Time-Delay Supplemental Fuses Technical Data 1012 Effective February 2016 15 20 25 30 4 5 6 7 10 3-2/10 Amp Rating 100 Amp Rating 1/2 300 1-6/10 2 1 Time-current characteristic curves – average melt 100 10 Time in Seconds Time in Seconds 10 1 0.1 1 0.1 600 Current in Amps 200 100 20 10 0.01 6 Current in Amps 200 100 20 10 1 0.6 0.01 The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 1012 — BU-SB14286 February 2016 Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. UL is a registered trademark of the Underwriters Laboratories, Inc. CSA is a registered trademark of the Canadian Standards Group. Follow us on social media to get the latest product and support information.
FNQ-15 价格&库存
很抱歉,暂时无法提供与“FNQ-15”相匹配的价格&库存,您可以联系我们找货
FNQ-15
    • 1+454.00213
    • 50+441.74864
    • 250+425.61427
    库存:5
