Technical Data 11045
Effective February 2020
HVP
1/4” x 1-1/4” High voltage panel mount fuse holder
Agency information
UL Recognized: IZLT2, E14853
General specifications
Product features
Compact, front panel mount fuse holder ¼” x 1
¼” (6.3 mm x 32 mm) fuses
High voltage rating and current rating, up to
480 V and 30 A for higher power assemblies
Bayonet-type knob as fuse carrier
Robust design provides vibration resistance
Tin plated brass terminals
Thermoset fuse holder body and knob
Threaded thermoplastic nut as standard
Optional accessories available for field
replacement
Temperature rating (RTI):
The mounting body for all devices has a
temperature rating of +150 °C.
The knob for these devices is molded
plastic with a temperature rating of +150 °C.
Plastic body meets UL 94HB
Terminal strength: 5 pounds
Torque: Mounting – 20 inch-pound
Salt spray (corrosion): Test condition B
HVP
Specifications
Part number
Description
Voltage rating (V)
Current rating (A)
HVP-R
Standard HVP fuse holder
480
30
HVP-W-R
Drip proof fuse knob (IP53 rated)
480
30
HVP-HH-R
1/4” Quick connects
480
15
HVP-L-R
2250 V Stand-off barrier
480
30
HVP-LW-HH-R
Drip proof knob, 2250 V stand-off, 1/4” quick connects
480
15
HVP-OO-R
Snap-lock design
480
30
HVP-CC-R
Extended panel mount
480
30
Ordering details
Ordering number is the part number plus the packaging prefix. i.e. BK-HVP-R
Packaging code prefix
Description
Blank
10 fuse holders with components bagged separately
BK-
100 fuse holders with components bagged separately
Additional accessories
Ordering number
Description
BK-1A4287
100 unit package of plastic fastening nuts
BK-1A4806-2
100 unit package of metal fastening nuts
9435-1/2
10 unit package of bayonet fuse knobs
BK-9435-1/2
100 unit package of bayonet fuse knobs
9732
10 unit pakage of neoprene washers
BK-9732
100 unit package of neoprene washers
Dimensions- mm [inches]
HVP-OO-R
Mounting: HVP-OO-R
59.1
[2.33]
with fuse installed
39.7
[1.56]
max.
2.9
[0.115]
19.1
[0.75]
max.
Hole for panel mounting
20.6
[0.81]
+ 0.76
[0.003]
+ 0.076
[0.003] dia. hole
in terminals
16.7
[0.66]
22.6
[0.89]
+ 0.127
[0.005]
for panels 0.635 - 1.98 thick
[0.025] - [0.078]
panel
2
www.eaton.com/electronics
HVP
HVP-HH-R
HVP-R, HVP-L-R, HVP-W-R
59.1
[2.33]
max.
with fuse installed
11.9
[.47]
67.1
[2.64]
max.
when fuse is inserted
56.4
[2.22]
max.
60.3
[2.38]
max.
1/2 ”- 24 threads
17.37
[0.684]
17.5
[.69]
17.5
[0.69]
max.
19.1
[.75]
max.
32.9
[1.30]
2.92 +- .08
[.115 +- .003]
panel front
HVP-CC-R
HVP-LW-HH-R
panel front
67.1
[2.64]
29.4
[1.16]
max.
22.2
[0.88]
62.0
[2.44]
max.
17.42
[0.686]
17.5
[0.69]
max.
19.1
[0.75]
max.
32.9
[1.30]
body marking
buss
HVP
30A
480V
Reference B/P: 9631-29
Mounting: HVP-R, HVP-L-R, HVP-W-R, HVPHH-R, HVP-LW-HH-R, HVP-CC-R
punched hole
drilled hole
6.8
[0.27]
12.0
[0.47]
locking key - 2.39 [.094] dia.
thickness not to be greater
than panel thickness
12.8
[0.51]
#41 drill
12.7 drill
[0.50]
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2020 Eaton
All Rights Reserved
Printed in USA
Publication No. 11045 BU-MC20021
February 2020
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
Follow us on social media to get the
latest product and support information.
很抱歉,暂时无法提供与“HVP-CC-R”相匹配的价格&库存,您可以联系我们找货
