14002-3
14002-3
    EATON(伊顿)
    接线端子 间距P=9.53mm
14002-3 数据手册
Technical Data 10614 Effective October 2016 14002-3 high SCCR barrier terminal block Mechanical • Panel mount 3-pole configuration • 75°C rated connectors • Flammability: UL 94 HB Conductors Wire size (AWG) 2-3 Cu/Al 4-6 Cu/Al 8 Cu/Al 10-14 Cu Torque (lb-in) 50 45 35 35 Dimensions - in 2.38 0.875 Catalog number: • 14002-3 Description: Eaton’s Bussmann series catalog number 14002-3 is a three-pole barrier terminal block featuring a high Short-Circuit Current Rating (SCCR) when protected by specific, tested upstream overcurrent protective devices (see SCCR data table for details). Specifications: 0.375 Ref. 0.75 Ref. 0.625 Ref. Ratings • Volts: 600 Vac/dc • Amps: 115 A • SCCR: • 10 kA default • Up to 200 kA (see SCCR data on page 2) Agency information • UL 1953 Recognized, Guide XCFR2, File E62622 • General Industry Class per UL 1059, usage Category C • RoHS compliant 1.25 Technical Data 10614 14002-3 high SCCR barrier terminal block Effective October 2016 Short-Circuit Current Rating data The high SCCR of this block relies upon the tested, upstream overcurrent protective devices listed in this table Catalog no. Amps 14002-3 115 Cu wire range line and load (AWG) 2 to 3 Cu/Al 4 to 6 Cu/Al 8 Cu/Al 10 to 14 Cu Torque lb-in (max) 50 45 35 35 Max. Fuse Class and Amp* (1) Cu wire JJN, LPN-RK, FRN-R, range (AWG) LPJ JJS LPS-RK FRS-R 2 to 8 200 200 100 60 SCCR Min. enclosure (kA) size (in) 200 2 to 14 100 175 175 100 60 8x8x4 * Class G 60A (SC-60) or less or Class CC 30A (LP-CC-30, FNQ-R-30, KTK-R-30) or less are suitable for all SCCRs in this table. The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2016 Eaton All Rights Reserved Printed in USA Publication No. 10614 — BU-MC16124 October 2016 Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. Follow us on social media to get the latest product and support information.
14002-3 价格&库存
很抱歉,暂时无法提供与“14002-3”相匹配的价格&库存,您可以联系我们找货
  • 1+640.386101+82.95240
  • 10+472.4668610+61.20099
  • 30+424.0043730+54.92340
  • 50+406.8116650+52.69634
  • 100+387.86574100+50.24218
库存:49
