ACE1V4532-220-R
ACE1V4532-220-R
    EATON(伊顿)
    水平式,4 PC 板
    22 µH @ 100 kHz 2 线路共模扼流圈 表面贴装型 1 kOhms @ 10 MHz 200mA DCR 1 欧姆
ACE1V4532-220-R 数据手册
Technical Data 10986 Effective November 2019 ACE1V4532 Automotive grade common-mode chip inductor Applications Product features • Controller area network (CAN) • Ethernet architectures • Automotive signal line filter • Advanced driver assistance systems (ADAS) • Infotainment, safety cameras, sensors, xEV, Powertrain • Engine control unit (ECU) Electric power steering system (EPS) Battery management systems (BMS) • AEC-Q200 qualified • • 1812 (4532 metric) package • • Impedance range from 700 ohms to 15000 ohms • Inductance range from 11 uH to 200 uH Environmental compliance and general specifications • Moisture sensitivity level (MSL): 1 • Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE ACE1V4532 Automotive grade common-mode chip inductor  Technical Data 10986 Effective November 2019 Product specifications Common-mode impedance Z (Ω) at 10 MHz Part number Common-mode inductance (μH) at 100 kHz DCR (Ω) @ +25 ° maximum Idc (mA) maximum Rated voltage (Vdc) typical Insulation resistance (MΩ) minimum ACE1V4532-110-R 300 minimum 700 typical 11 +50%/-30% 0.60 250 50 10 ACE1V4532-220-R 500 minimum 1000 typical 22 +50%/-30% 1.00 200 50 10 ACE1V4532-510-R 1000 minimum 2000 typical 51 +50%/-30% 1.00 200 50 10 ACE1V4532-101-R 2000 minimum 5000 typical 100 +50%/-30% 2.00 150 50 10 ACE1V4532-201-R 10000 minimum 15000 typical 200 +50%/-30% 4.50 100 50 10 1. Part Number Definition: ACE1V4532-xxn-R ACE1V4532 = Product code and size xx= inductance value in uH, n= multiplication factor: 10^n (i.e. 110 = 11 * 10^0 = 11 uH) -R suffix = RoHS compliant Mechanical parameters, schematic, pad layout (mm) Recommended pad layout B A Epoxy C D Terminations Wires E E F F Equivalent circuit 1 4 2 3 No polarity Part Number A B C D E F ACE1V4532-xxn-R 4.5±0.2 3.2 ±0.2 2.8 ±0.2 0.2 ±0.1 1.2typ. 1.0typ. All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended 2 www.eaton.com/electronics Technical Data 10986 ACE1V4532  Automotive grade common-mode chip inductor Effective November 2019  Packaging information (mm) Supplied in tape and reel packaging, 500 parts per 7” diameter reel Ao 3.45±0.10 Bo 4.90±0.10 Ko 3.05±0.10 W 12.00±0.20 E 1.75±0.10 F 5.50±0.05 Po 4.0±0.05 P1 8.0±0.10 Do 1.5+0.1,-0 www.eaton.com/electronics 3 ACE1V4532 Automotive grade common-mode chip inductor  Technical Data 10986 Effective November 2019 Performance curves ACE1V4532-220-R Impedance (Ω) Impedance (Ω) ACE1V4532-110-R Frequency (MHz) Frequency (MHz) ACE1V4532-101-R Impedance (Ω) Impedance (Ω) ACE1V4532-510-R Frequency (MHz) Common mode measurement method: Impedance (Ω) ACE1V4532-201-R Frequency (MHz) Differential mode measurement method: Frequency (MHz) 4 www.eaton.com/electronics Technical Data 10986 ACE1V4532  Automotive grade common-mode chip inductor Effective November 2019  Solder reflow profile Table 1 - Standard SnPb solder (Tc) Package Thickness Volume mm3
ACE1V4532-220-R 价格&库存
很抱歉,暂时无法提供与“ACE1V4532-220-R”相匹配的价格&库存,您可以联系我们找货
ACE1V4532-220-R
    ACE1V4532-220-R
      • 1+5.13000
      • 10+5.00040
      • 30+4.91400
      库存:23
      ACE1V4532-220-R
      • 1+6.605341+0.85450
      • 10+5.4609110+0.70646
      • 25+5.0517425+0.65352
      • 50+4.7614150+0.61596
      • 100+4.48885100+0.58070
      • 250+4.15286250+0.53724
      库存:5
      ACE1V4532-220-R
      • 500+4.05495500+0.52457
      • 1000+3.834801000+0.49609
      库存:5
