AHC-3-15-R
AHC-3-15-R
    EATON(伊顿)
    3AB,3AG,1/4"x1-1/4"
    3.15 A 600 V AC 直流保险丝 管筒,陶瓷 需要支座 3AB,3AG,1/4" x 1-1/4"
AHC-3-15-R 数据手册
Technical Data ELX1121 Effective February 2023 Supersedes December 2021 AHC High voltage 1/4” x 1-1/4” fast-acting ceramic tube fuse Applications High voltage ceramic tube fuse • Compact 3AB footprint: ¼” x 1 ¼” (6.3 x 32 mm) • Fast-acting performance • 600 V rating • Cartridge and axial lead versions available • Very high interrupting ratings to help safely protect against dangerous high fault currents • Fuse accessories (cartridge version): HVP Panel mount fuse holder (480V) HVI In-line fuse holder (600V) S-8000 Panel mount fuse block (600V) 1Axxxx (up to 600V) fuse clips Agency information • cURus recognition file number: E19180 Guide JDYX2 and JDYX8 Industrial control panels • Motor control - UL 508A panels • Uninterruptible power supplies (UPS) • Variable frequency drives • Energy storage and battery systems • High voltage power conversion Environmental compliance Product features • • HALOGEN Pb HF FREE Ordering part number BK-AHC-V-5-R Packaging prefix Family name Option code (V = leaded) Ampere rating RoHS compliance Packaging prefix • Blank 5 pieces in tin case for AHC-XXX-R, 4 pieces in tin case for AHC-V-XXX-R • BK11000 pieces in polybag for AHC-XXX-R • BK- 100 pieces in carton for AHC-XXX-R, AHC-V-XXX-R or AHC-V2-XXX-R • TR500 pieces on reel for AHC-V-XXX-R Option code • -V Axial leads with 38.1 mm length – copper tinned wire with nickel plated brass over caps • -V2 Axial leads with 50.8 mm length – copper tinned wire with nickel plated brass over caps AHC High voltage 1/4” x 1-1/4” fast-acting ceramic tube fuse  Technical Data ELX1121 Effective February 2023 Electrical characteristics Amp Rating 1.0 In minimum 2.5 In maximum 0.2 A - 10 A 4 hours 120 seconds Product specifications Part number Current rating (A) Voltage rating (Vac) Voltage rating (Vdc) Interrupting rating @ rated voltage (A) Vac Interrupting rating @ rated voltage (A) Vdc Typical resistance1 (mΩ) Typical voltage drop3 (mV) AHC-200(-V)-R 0.2 600 600 10,000 10,000 4310 1060 AHC-250(-V)-R 0.25 600 600 10,000 10,000 2703 895 AHC-400(-V)-R 0.4 600 600 10,000 10,000 1436 730 AHC-500(-V)-R 0.5 600 600 10,000 10,000 1047.5 680 AHC-600(-V)-R 0.6 600 600 10,000 10,000 784.5 585 AHC-1(-V)-R 1 600 600 10,000 10,000 360 425 AHC-1-5(-V)-R 1.5 600 600 10,000 10,000 250 550 AHC-1-6(-V)-R 1.6 600 600 10,000 10,000 196 425 AHC-2(-V)-R 2.0 600 600 10,000 10,000 162 500 AHC-2-5(-V)-R 2.5 600 600 10,000 10,000 119 475 AHC-3(-V)-R 3.0 600 600 10,000 10,000 95 450 AHC-3-15(-V)-R 3.15 600 600 10,000 10,000 83 400 AHC-4(-V)-R 4.0 600 600 10,000 10,000 53.8 350 AHC-5(-V)-R 5.0 600 600 10,000 10,000 42.5 350 AHC-6(-V)-R 6.0 600 600 10,000 10,000 30.3 250 AHC-8(-V)-R 8.0 600 600 10,000 10,000 23 300 AHC-10(-V)-R 10 600 - 10,000 10,000 16.5 300 1. Typical resistance measured at
AHC-3-15-R
物料型号:BUSSMANN系列的ELX1121型号,一个AHC高压快速作用陶瓷管保险丝。
器件简介:该保险丝适用于工业控制面板、电机控制、不间断电源(UPS)、变频器、能源存储和电池系统以及高压功率转换。
引脚分配:提供了两种引脚版本,轴向引线版本和卡式引线版本,具体引脚长度和材料在文档中有详细说明。
参数特性:具有600V的额定电压,非常高的断路能力,以安全地保护免受危险的高故障电流。
功能详解:提供了详细的电气特性表,包括额定电流、最小和最大熔断时间,以及产品规格表,包括电流额定值、电压额定值、断路能力、典型电阻和电压降。
应用信息:适用于多种高压应用,包括但不限于工业控制、电机控制、能源存储等。
封装信息:提供了不同封装选项的尺寸信息,包括卡式和轴向引线版本,以及相关的配件信息。
AHC-3-15-R 价格&库存
很抱歉,暂时无法提供与“AHC-3-15-R”相匹配的价格&库存,您可以联系我们找货
