B222-60NF
B222-60NF
    EATON(伊顿)
B222-60NF 数据手册
Effective June 2017 Supersedes January 2017 Technical Data 1143 Fused and non-fused HVAC disconnects Agency Information • UL® Listed to UL 1429, cUL Certified, UL Guide WGEW Conductors - AWG • 14-3 Cu/Al Enclosures Fused disconnect • Non-fused disconnect Metallic NEMA 3R housing with weather resistant coating Dimensions • See catalog numbers table Features and benefits • A/C disconnects meet NEC® Code requirements under articles 440.14. • Self-testing GFCI units meet NEC Code requirements under articles 210.63, 210.8, and 406.8(B)(1). Non-fused disconnect with GFCI receptacle. • NEMA 3R enclosures withstand outdoor environment. Catalog symbol: • Padlockable with two-position pullout handle to lock safety shield when in the ON position. (Not available on GFCI or 60 A switched units.) For added safety, pullout handle can be stored in the compartment in the OFF position. • B22__ Description: Fused and non-fused pullout HVAC disconnects in NEMA 3R enclosures. Fused versions are available in 30 and 60 amp ratings with or without selftesting GFCI receptacles. Non-fused versions are available in 60 amp versions with or without selftesting GFCI receptacles. Specifications: Ratings • Volts • 120 Vac single-phase • • 240 Vac split-phase Amps 30 or 60 A Catalog numbers • See table on page 2. Typical applications: • Residential, light industrial/commercial A/C and heat pump service • Spas/whirlpools, swimming pools, pump houses • Suitable for service entrance equipment applications with field installed ground bar — order catalog number DPFG Technical Data 1143 Fused and non-fused HVAC disconnects Effective June 2017 Catalog numbers Cat. nos. Fused disconnects B221-30F B221-30FGFST Description 30 amp, pullout 30 amp, pullout with GFCI 30 amp, pullout with weather-resistant/tamper-resistant B221-30FGFWTST rated GFCI B222-60F 60 amp, pullout B222-60FGFST 60 amp, pullout with GFCI 60 amp, pullout with weather-resistant/tamper-resistant B222-60FGFWTST rated GFCI Non-fused disconnects B222-60NF 60 amp, pullout B222-60NFGFST 60 amp, pullout with GFCI amp, pullout with weather-resistant/tamper-resistant B222-60NFGFWTST 60 rated GFCI B222-60NFNA 60 amp, switch Amp rating Max Hp rating Fuse 120 V 240 V class Approximate dimensions (in) Height Width Depth 30 30 1.5 1.5 3 3 H or R H or R 8-3/4 13 5-3/8 7-1/2 2-7/8 4-3/4 30 1.5 3 H or R 13 7-1/2 4-3/4 60 60 3 3 10 10 H or R H or R 8-3/4 13 5-3/8 7-1/2 2-7/8 4-3/4 60 3 10 H or R 13 7-1/2 4-3/4 60 60 3 3 10 10 * * 8-3/4 11-3/4 5-3/8 6-1/2 2-7/8 4-1/2 60 3 10 * 11-3/4 6-1/2 4-1/2 60 — 10 * 8-3/4 5-3/8 3-5/8 * Upstream overcurrent protective device (OPCD) not to exceed 60 A. For 30 and 60 amp pullout replacement handles, order catalog number 96-3258-4. Recommended Bussmann series fuses Fuse class H R Catalog symbol NON-(amp) FRN-R-(amp) LPN-RK-(amp)SP (non-indicating) LPN-RK-(amp)SPI (indicating Operation One time, general purpose Dual element, time-delay Available amps 1/8 to 60 1/10 to 60 1/10 to 60 35 to 60 Data sheet no. 1030 1019 1003 1003 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2017 Eaton All Rights Reserved Printed in USA Publication No. 1143 — BU-SB04150 June 2017 Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the U.S. and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. NEC is a registered trademark of the National Fire Protection Association, Inc. UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information.
B222-60NF 价格&库存
很抱歉,暂时无法提供与“B222-60NF”相匹配的价格&库存,您可以联系我们找货
