BK/C519-3-R
BK/C519-3-R
    EATON(伊顿)
    D5.2xL14.5mm
    一次性保险丝(熔断) 3A 250V
BK/C519-3-R 数据手册
5 x 15mm Time-Delay Glass Tube Fuses C519 Series Description • Time-delay • 5 x 15mm physical size • Nickel-plated brass endcap construction • UL Listed product meets standard UL 248-14 Electrical Characteristics Amp Rating Opening Time 135% 60 minutes max. 125mA - 250mA 3 seconds min. 200% 120 seconds max. 100% 4 hours min. 470mA 30 minutes max. 350mA 600mA 90 seconds max. 2A 2 seconds max. 6A 500 milliseconds max. 135% 60 minutes max. 375mA - 5A 3 seconds min. 200% 120 seconds max. Rated Current Agency Information • UL Listed Card: C519 125mA-250mA and 375mA-3A (Guide JDYX, File E19180) • UL Recognized Card: C519 350mA, and 3.5A-7A (Guide JDYX2, File E19180) • CSA Certification Card: C519 125mA-250mA and 375mA-3A (Class 1422-01, File 53787) Dimensions - mm Drawing Not to Scale 14.5 ± 0.5 5.2 ± 0.3 5.0 (Typ.) Ordering Specify product code • Insert packaging code prefix before part number. E.g. BK(BK1)/C519-2-R Specifications Part Number C519-125-R C519-250-R C519-350-R C519-375-R C519-500-R C519-600-R C519-750-R C519-1-R C519-1.25-R C519-1.5-R C519-1.6-R C519-2-R C519-2.25-R C519-2.5-R C519-3-R C519-3.5-R C519-4-R C519-5-R Voltage Rating Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 125 125 125 Interrupting Rating at Rated Voltage (amps) 600Vac 250Vac 125Vac 35 10,000 35 10,000 25 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 400 400 400 Typical DC Cold Resistance* Ω) (Ω 4.72 1.32 1.04 0.81 0.54 0.38 0.26 0.14 0.13 0.10 0.09 0.059 0.057 0.046 0.035 0.028 0.023 0.019 Typical Melting I2t** DC 0.101 0.467 1.169 1.531 2.280 6.982 9.162 14.289 22.961 31.989 31.156 60.256 97.724 78.163 80.426 149.279 233.346 354.813 * DC Cold Resistance (Measured at
BK/C519-3-R 价格&库存
很抱歉,暂时无法提供与“BK/C519-3-R”相匹配的价格&库存,您可以联系我们找货
BK-C519-3-R
  • 100+19.91008100+2.56510
BK/C519-3-R
    • 1+1.43090
    • 200+0.55383
    • 500+0.53428
    • 1000+0.52467
