BK/C520-5-R
BK/C520-5-R
    EATON(伊顿)
    D5.1xL14mm
    一次性保险丝(熔断) 5A 250V
BK/C520-5-R 数据手册
5 x 15mm Glass Tube Fuses C520 Series, Fast-Acting Description • Fast-acting • 5 x 14.48mm physical size • Glass tube, nickel-plated brass endcap construction • UL Listed product meets standard UL 248-14 Electrical Characteristics Amp Rating Opening Time 100% None 100mA - 5A 135% 1 hours max. 200% 2 seconds max. Rated Current Agency Information • UL Listed Card: Guide JDYX, File E19180 • CSA Certification Card: Class 1422-01, 53787 Ordering Specify product code • Insert packaging code prefix before part number. E.g. BK (or BK1)/C520-500-R Dimensions - mm Drawing Not to Scale 14.48 5.2 5.0 (Typ.) Specifications Part Number C520-100-R C520-125-R C520-250-R C520-375-R C520-500-R C520-750-R C520-1.5-R C520-2-R C520-2.5-R C520-3-R C520-3.5-R C520-4-R C520-5-R Voltage Rating Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 Interrupting Rating at Rated Voltage (amps) 250Vac 125Vac 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 200 10,000 200 10,000 Typical DC Cold Resistance* Ω) (Ω 22.30 15.20 5.60 2.53 1.66 0.91 0.900 0.064 0.046 0.038 0.032 0.022 0.018 Typical Melting I2t** AC 0.0010 0.0019 0.012 0.039 0.059 0.264 0.800 1.9 2.9 6.1 9.7 16.6 22.4 * DC Cold Resistance (Measured at
BK/C520-5-R 价格&库存
很抱歉,暂时无法提供与“BK/C520-5-R”相匹配的价格&库存,您可以联系我们找货
