BK/S-8102-1-SNP
BK/S-8102-1-SNP
    EATON(伊顿)
    BK/S-8102-1-SNP
BK/S-8102-1-SNP 数据手册
S-8000 Series 1 /4" x 11/4" Fuse Blocks Multiple Pole Mounting Dimensions No. of Poles 1 2 3 4 5 6 7 8 9 10 11 12 Description • For 1/4" x 11/4" (6.3 x 32mm) fuses • Bolt-in and snap-in mounting available • Tight cluster mounting • All types of terminal configurations • Clips made of spring-bronze • Anti-rotational pin provided • Flame retardant thermoplastic meets UL 94V0 Environmental Data • Relative Temperature Index (RTI) - Bolt-in 130°C - Snap-in 110°C Agency Information • UL Recognized: E14853 • CSA Certified: 47235 Inches A – 11/8" 13/4" 23/8" 3" 35/8" 41/4" 47/8" 51/2" 61/8" 63/4" 73/8" B – 5 /8" 11/4" 17/8" 21/2" 31/8" 33/4" 43/8" 5" 55/8" 61/4" 67/8" Millimeters A B – – 28.6 15.9 44.4 31.8 60.3 47.6 76.2 63.5 92.1 79.4 108.0 95.2 123.8 111.1 139.7 127.0 155.6 142.9 171.4 158.8 187.3 174.6 Dimensions - mm/in. S-8000 Single-Pole Bolt-In Mounting Series 40° Terminal Specifications Series S-8000 S-8100 S-8200 S-8300 Volts 300Vac/dc 300Vac/dc 300Vac/dc 300Vac/dc UL Max Amps 25 20 20 30 CSA Max. Amps 21 13 16 25 Dimensions - mm/in. S-8000 Single-Pole Snap-In Mounting Series 0° Terminal Screw Terminal 40° Terminal Side Terminal 0° Terminal Mounting Side Terminal Mounting Component Clip Body 1207 BU-SB07222 Page 1 of 2 Material Spring-Bronze, Bright Tin-Plate Thermoplastic Data Sheet 2101 Packaging Code Catalog Number Prefix Blank BK/ Description Varies with number of poles. Contact customer service. Varies with number of poles. Contact customer service. Ordering • Specify packaging, product, and option code Bolt-in Mounting Example: BK/S-8102-6-R BK/ â 1 S-8 â 2 1 â 3 02 â 4 6 - R â â 5 7 Snap-in Mounting Example: BK/S-8001-1-SNP-R BK/ â 1 S-8 â 2 0 â 3 01 - 1 - SNP - R â â â â 4 5 6 7 1. Packaging Code: 2. Series Number: 3. Type Terminal: 4. Terminal Angle: 5. Number of Poles: 6. Mounting Style: 7. RoHS Compliant Version BK/ S-8 0 = Solder 1 = 3/16" quick connect 2 = 1/4" quick connect 3 = Screw 01 = Straight (0°) 02 = 40° Angle 03 = Side* (1 – 12) 1X = One pole, No Mounting Stud SNP = Snap-in Mounting* -R *Available only in single pole This bulletin is intended to present product design solutions and technical information that will help the end user with design applications. Cooper Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Cooper Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Life Support Policy: Cooper Bussmann does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. © 2007 Cooper Bussmann S t . L o u i s, M O 6 3 1 7 8 w w w. c o o p e r bu s s m a n n . c o m 1207 BU-SB07222 Page 2 of 2 Data Sheet 2101
BK/S-8102-1-SNP 价格&库存
很抱歉,暂时无法提供与“BK/S-8102-1-SNP”相匹配的价格&库存,您可以联系我们找货
