CCP2-NFPA-2
CCP2-NFPA-2
    EATON(伊顿)
    Eaton Bussmann series Compact Circuit Protector
CCP2-NFPA-2 数据手册
Effective April 2019 Supersedes March 2019 Technical Data 10801 BUSSMANN SERIES Compact Circuit Protector UL 98 Class CF disconnect switches up to 200 A (cat. no. CCP2) 2011/65/EU CCP2 switch up to 100 A 200 A CCP2 switch Contents Page 30, 60 and 100 amp switches Descriptions and specifications. . . . . . . . . . . . . . . . 2-3 200 A switches Catalog numbers. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Front and side rotary mechanisms. . . . . . . . . . . . 16 Terminal data. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Terminal shroud kits . . . . . . . . . . . . . . . . . . . . . . . 16 Dimensions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5-7 Phase barrier kits. . . . . . . . . . . . . . . . . . . . . . . . . . 16 200 A switches Descriptions and specifications. . . . . . . . . . . . . . . . . . 8 Catalog numbers and horsepower ratings . . . . . . . . . 9 Handle extension. . . . . . . . . . . . . . . . . . . . . . . . . . 16 Auxiliary contacts 30, 60 and 100 A switches. . . . . . . . . . . . . . . . . . 17 Available lugs. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 200 A switches . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Dimensions. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 PLC fuse monitor (30, 60 and 100 A switches). . . 19-20 Accessories How to order Multi-wire lug kits 30 and 60 A switches 30, 60 and 100 A switches . . . . . . . . . . . . . . . . . . 11 Front and right side rotary switches. . . . . . . . 21-22 200 A switches . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Switch only . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Handles and shafts Selector and pistol handles. . . . . . . . . . . . . . . . . . 13 Left side rotary switches. . . . . . . . . . . . . . . . . . . . 24 100 A switches Handle shafts. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Front and right side rotary switches. . . . . . . . 25-26 NFPA 79 compliant handles . . . . . . . . . . . . . . . . . 14 Switch only . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Flange handle rod and cable operators. . . . . . . . . . . 15 Left side rotary switches. . . . . . . . . . . . . . . . . . . . 28 200 A switches 200 A switches . . . . . . . . . . . . . . . . . . . . . . . . 29-30 Motor fuse sizing table. . . . . . . . . . . . . . . . . . . 31-32 bus-ele-ds-10801-ccp2-cf-67.indd 1 5/2/2019 10:53:32 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Catalog symbols for 30, 60 and 100 A switches Symbol CCP2-(pole)-(amps)CF Description Switch only CCP2R-(pole)-(amps)CF Right front rotary, clockwise operated switch CCP2RL-(pole)-(amps)CF Left front rotary, clockwise operated switch CCP2S-(pole)-(amps)CF Right side rotary, clockwise operated switch side rotary, counterclockwise operated CCP2SL-(pole)-(amps)CF Left switch Description The revolutionary, next generation Bussmann™ series Compact Circuit Protector (cat. no. CCP2) is a fused UL® 98 branch circuit disconnect switch utilizing the UL Class CF time-delay or fast-acting CUBEFuse™ with Class J electrical performance. With up to a 51 percent smaller footprint than a traditional fusible solution, these switches provide a high 200 kA SCCR to help improve panel and assembly SCCR. The 35 mm DIN-Rail mount CCP2 is available in a variety of 30, 60 and 100 amp configurations to meet many application needs including rotary operation. The switch-only versions of the 30, 60 and 100 A disconnects are direct, drop-in replacements for the earlier models (noted by a catalog number starting “CCP-”). The auxiliary contacts and PLC remote fuse indicator are backwards compatible. The multi-wire lug kits and terminal shrouds are not. Conductors/terminals • 75°C Cu, see conductor tables for size, type and torque information • Box lug, single/dual conductor • Fork terminal suitable for line, load or accessory connection, max. 30 A suitable for use with: • 10-24 screw for 30 and 60 A switches • • 1/4-28 screw for 100 A switches Multi-wire lug kits — see accessories for details Storage and operating temperature • -20°C to 75°C (-4°F to 167°F)* * For fuse performance under or above 25°C, consult fuse performance derating charts in the Bussmann Division publication no. 3002, titled Selecting Protective Devices (SPD) Lockout/tagout provisions • 1/4” lock, direct use on switches without rotary mechanisms requires a lock with a straight shank of sufficient length to engage all poles Minimum enclosure size per UL 98* • 30 and 60 A switch 10”x 8”x 6”(254 x 203 x 152 mm) • 100 A switch, 12” x 10” x 6” (305 x 254 x 152 mm) Application flexibility is extended with an optional multi-wire lug kit, featuring finger-safe shrouds, that provides three (30 and 60 A switches) and six (100 A switches) additional wire ports on each pole for power distribution applications. * Smaller enclosures may be used at the discretion of the user, with adherence to NEC minimum wire bend radius requirements. Other accessories include a PLC fuse monitor for open fuse indication and NO/NC auxiliary contacts that easily integrate into various monitoring systems. • Mounting** 35 mm DIN-Rail ** Switch is panel mount with flange handle cable operator. Front and side rotary operated versions are easily applied for through-the-door or through the left or right side operation to enhance safety. Local open fuse indication minimum voltage Ratings Accessories • • • Volts • Multi-wire lug kits with terminal shrouds 347 Vac (1-pole switches) • Selector and pistol handles for use with rotary operated switches • 600 Vac (2- and 3-pole switches) • 8 mm shafts for use with selector and pistol handles • 125 Vdc* • Auxiliary contacts • PLC fuse monitor Amps • 30 A • NFPA 79 compliant handle • 60 A • Flange handle rod and cable operators • 100 A Carton quantity and shipping weight SCCR • 200 kA RMS Sym. • 100 kA DC 1-, 2- and 3-poles catalog number dependent * Switch amp rating and installed fuse amp rating dependent, see catalog number table for details. Agency information • UL 98 Listed, Guide WHTY, File E302370 • cULus to Canadian Standard 22.2 No. 4-04, Guide WHTY7, File E302370 • RoHS compliant • CE 2 90 Vac, requires an open fuse to be in the CCP2 and the switch in the ON position • Poles • • Item 30 and 60 amp switches Switch only Switch with side rotary mechanism Switch with front rotary mechanism 100 amp switches Switch only Switch with side rotary mechanism Switch with front rotary mechanism Poles Qty. Weight lb (kg) 1-pole 2-pole 3-pole 2-pole 3-pole 12 1 1 1 1 3.8 (1.7) 1.3 (0.6) 1.6 (0.7) 1.3 (0.6) 1.6 (0.7) 1-pole 2-pole 3-pole 2-pole 3-pole 6 1 1 1 1 3.1 (1.4) 1.7 (0.8) 2.3 (1.0) 1.7 (0.8) 2.3 (1.0) Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 2 5/2/2019 10:53:33 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Features • Uses UL Class CF time-delay or fast-acting CUBEFuse with Class J electrical performance • Extremely compact design at 25.4 mm (1 inch) wide per pole • Amp rating rejection disconnects will not accept a CUBEFuse amp rating greater than switch rating • High 200 kA short-circuit current rating • Disconnect rated to provide means for load isolation • Full voltage rated at 347 Vac (1-pole switches) and 600 Vac (2- and 3-pole switches) • 125 Vdc* rated to meet specialized applications • UL 98 Listed and suitable for branch circuit disconnect and branch circuit protection with installed fuses • Horsepower rated • Open fuse indication: • Local open fuse indication light standard on each pole • Optional PLC fuse monitor for wired remote open fuse indication by signaling a PLC and opening a contactor to de-energize all phases, if required • Additional open fuse indication can be provided by the indicating time-delay CUBEFuse (6 to 100 A) • Finger-safe construction with 10 AWG (6 mm2) wire or larger • Built-in switch interlock prohibits removing or installing the fuse while in the ON position • Padlockable for lockout/tagout procedures with a 1/4” lock • Rotary operated versions provide for through-the-door and through-the-side operation flexibility and enhanced safety with: • Right or left front operation • Right front rotary operated CCP2 switch with PLC fuse monitor. Right or left side operation • Optional selector and pistol handles, and shafts available for use with rotary operated versions • Multi-wire lug kits with terminal shrouds allow for power distribution to multiple loads. Each lug has three (30 and 60 A switches) or six (100 A switches) ports rated for single and dual wires (see lug kits in accessories for details). Rotary operating versions * Switch amp rating and installed fuse amp rating dependent, see catalog number table for details. Switch handle (ganged on 2- and 3-pole versions) Open fuse indicating light Fuse holder Left front Right front Uses clockwise handles Uses clockwise handles Fork terminal 1/4” Lockout/ tagout provision Box lug terminal Left side Right side Uses counterclockwise handles Uses clockwise handles Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 3 3 5/2/2019 10:54:01 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 30, 60 and 100 A switch catalog numbers Max Hp rating (Vac) Catalog no. Poles Description/switch operation Volts SCCR 120 240 480 600 30 amp switches CCP2-1-30CF 1 CCP2-2-30CF 2 347 Vac/125 Vdc 1-1/2 — — — 600 Vac/125 Vdc — 3 — CCP2-3-30CF — 3 600 Vac — 5 15 10 CCP2R-2-30CF 2 600 Vac/125 Vdc — 3 — — CCP2R-3-30CF 3 600 Vac — 5 15 10 CCP2RL-2-30CF 2 — 3 — — CCP2RL-3-30CF 3 CCP2S-2-30CF 2 CCP2S-3-30CF 3 CCP2SL-2-30CF 2 CCP2SL-3-30CF 3 Switch only Right front rotary, clockwise Left front rotary, clockwise Right side rotary, clockwise Left side rotary, counterclockwise 600 Vac/125 Vdc 600 Vac 200 kA AC 100 kA DC — 5 15 10 600 Vac/125 Vdc — 3 — — 600 Vac — 5 15 10 600 Vac/125 Vdc — 3 — — 600 Vac — 5 15 10 347 Vac/125 Vdc* 3 — — — 600 Vac/125 Vdc* — 7-1/2 — — 60 amp switches CCP2-1-60CF 1 CCP2-2-60CF 2 CCP2-3-60CF 3 600 Vac — 7-1/2 20 10 CCP2R-2-60CF 2 600 Vac/125 Vdc* — 7-1/2 — — CCP2R-3-60CF 3 600 Vac — 7-1/2 20 10 CCP2RL-2-60CF 2 — 7-1/2 — — CCP2RL-3-60CF 3 — 7-1/2 20 10 CCP2S-2-60CF 2 600 Vac/125 Vdc* — 7-1/2 — — CCP2S-3-60CF 3 600 Vac — 7-1/2 20 10 CCP2SL-2-60CF 2 600 Vac/125 Vdc* — 7-1/2 — — CCP2SL-3-60CF 3 600 Vac — 7-1/2 20 10 347 Vac/125 Vdc** 5 — — — 600 Vac/125 Vdc** — 10 — — Switch only Right front rotary, clockwise Left front rotary, clockwise Right side rotary, clockwise Left side rotary, counterclockwise 600 Vac/125 Vdc* 600 Vac 200 kA AC 100 kA DC 100 amp switches CCP2-1-100CF 1 CCP2-2-100CF 2 CCP2-3-100CF 3 600 Vac — 20 50 40 CCP2R-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2R-3-100CF 3 600 Vac — 20 50 40 CCP2RL-2-100CF 2 — 10 — — CCP2RL-3-100CF 3 — 20 50 40 CCP2S-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2S-3-100CF 3 600 Vac — 20 50 40 CCP2SL-2-100CF 2 600 Vac/125 Vdc** — 10 — — CCP2SL-3-100CF 3 600 Vac — 20 50 40 Switch only Right front rotary, clockwise Left front rotary, clockwise Right side rotary, clockwise Left side rotary, counterclockwise 600 Vac/125 Vdc** 600 Vac 200 kA AC 100 kA DC * 125 Vdc for installed fuse amp ratings up to 40 A. 24 Vdc for installed fuse amp ratings from 45 to 60 A. ** 125 Vdc for installed fuse amp ratings up to 80 A, 24 Vdc for installed fuse amp ratings from 90 to 100 A. 4 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 4 5/2/2019 10:54:02 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Box lug terminal conductor data Wire type AWG range Class Technical Data 10801 Effective April 2019 Dimensions – mm (in) Quantity Torque N•m (lb-in) Switch (shown with optional terminal shrouds) 30 and 60 A switches 4-6 8-18 6-8 75°C Cu Stranded, Class B to K 3.95 (35) Single 2.26 (20) Stranded, Class B/C Stranded, Class K 3.39 (30) Dual 2.26 (20) 10-18 Stranded, Class B to K 10-18 Solid Single/dual 4-18 Stranded, UL ferrule, Class B/C Single Stranded, UL ferrule, Class K Single 6-18 4-18 6-18 114 4.5 206 8.1 2.26 (20) 76 3.0 50 2.0 3.39 (30) Twin† 25 1.0 2.82 (25) Twin† 83 3.3 75 3.0 30A Fuse 100 A switches 12-18 2.26 (20) 10 2.82 (25) 8 4-6 Stranded, Class B/C Single 4.52 (40 Dual 5.08 (45) 12-18 75°C Cu 1-8 10-18 Stranded, UL ferrule, Class B/C Solid Class K 3-10 3.95 (35) 4.52 (40) 2.26 (20) 2.82 (25) Single/Dual Class K, UL ferrule 6-18 2.26 (20) 2.26 (20) Single 3.39 (30) Dual 8-18 1-7 Single Twin† 8-18 1-7 30 and 60 amp switches 2.26 (20) 6-9 10-18 60A Fuse 6.21 (55) 4-12 89 3.5 5.08 (45) 1-3 10 75 3.0 75 3.0 50 2.0 25 1.0 5.08 (45) 148 5.8 240 9.5 2.26 (20) Single 3.39 (30) Twin 100 3.9 2.26 (20) † Two stranded conductors placed in one UL Listed twin ferrule. Lineside and loadside fork terminal • Fork terminal suitable for line, load or accessory connection, max. 30 A suitable for use with: • 10-24 screw for 30 and 60 A switches • 100 amp switches 1/4-28 screw for 100 A switches Available Bussmann series fuses UL fuse class Type/description Indicating time-delay, Low-Peak™ CUBEFuse (6-100 A) Non-indicating time-delay, Low-Peak CF CUBEFuse (1-100 A) Non-indicating fast-acting CUBEFuse (1-100 A) Volts Data sheet no. 600 Vac/ 300 Vdc 9000 600 Vac/dc 2147 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 5 5 5/2/2019 10:54:09 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Left front rotary switches (shown with optional terminal shrouds) 114 4.5 114 4.5 206 8.1 99 3.9 101 4.0 76 3.0 Right front rotary switches (shown with optional terminal shrouds) 83 3.3 76 3.0 30 A Fuse 99 3.9 101 4.0 99 3.9 30 A Fuse 60 A Fuse 30 and 60 amp switches 101 4.0 148 5.8 101 4.0 76 3.0 240 9.5 100 106 3.9 4.2 100 amp switches 6 89 3.5 60 A Fuse 30 and 60 amp switches 76 3.0 83 3.3 99 3.9 89 3.5 206 8.1 148 5.8 240 9.5 100 106 3.9 4.2 100 amp switches Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 6 5/2/2019 10:54:22 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Left side rotary switches (shown with optional terminal shrouds) 114 4.5 114 4.5 206 8.1 206 8.1 83 3.3 75 3.0 101 4.0 Right side rotary switches (shown with optional terminal shrouds) 101 4.0 76 3.0 30 A Fuse 89 3.5 75 3.0 30 A Fuse 75 3.0 60 A Fuse 76 3.0 89 3.5 60 A Fuse 30 and 60 amp switches 101 4.0 83 3.3 75 3.0 30 and 60 amp switches 101 4.0 148 5.8 76 3.0 240 9.5 148 5.8 240 9.5 100 3.9 100 3.9 100 amp switches 100 amp switches Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 7 7 5/2/2019 10:54:34 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 200 A switches Poles • 1-, 2- and 3-poles catalog number dependent Agency information • UL 98 Listed, Guide WHTY, File E302370 • cULus to Canadian Standard 22.2 No. 4-04, Guide WHTY7, File E302370 • RoHS compliant Conductors/terminals 200 A switch • See available lug table for size, type and torque information Storage and operating temperature • -20°C to 75°C (-4°F to 167°F)* * For fuse performance under or above 25°C, consult fuse performance derating charts in the Bussmann Division publication no. 3002, titled Selecting Protective Devices (SPD) Lockout/tagout provisions using 1/4” lock With front rotary accessory Catalog no. With side rotary accessory Poles CCP2-1-200CF 1 CCP2-2-200CF 2 CCP2-3-200CF 3 Amps Description • Integral with switch handle • Front rotary operating mechanism • Rotary pistol handles • Flange rod and cable operators Minimum enclosure size 200 Switch only • 200 A switch 16 x 12 x 6” (405 x 305 x 150 mm) Mounting Panel mount Description • The Bussmann series 200 A Compact Circuit Protector (CCP2) fused disconnect switches utilize the finger-safe UL Class CF time-delay CUBEFuse with Class J electrical performance. With up to a 69 percent smaller footprint than a traditional fusible solution, these switches provide a high 200 kA SCCR to help improve panel and assembly SCCR. Local open fuse indication minimum voltage • 90 Vac, requires an open fuse to be in the CCP2 and the switch in the ON position Accessories • Lugs and lug kits with terminal shrouds • Pistol handles for use with rotary operated switches • NFPA 79 compliant handle Rotary operators are available for front or side (right or left) operation. Front rotary operators are for three-pole switches only while the side operator may be applied to the right or left side of 1-, 2- and 3-pole units. • 12 mm shafts for use with selector and pistol handles • Auxiliary contacts • Flange handle rod and cable operators Other accessories include lugs, terminal shrouds, rotary pistol handles, flange rod and cable operating mechanisms, NO/NC auxiliary contacts that easily integrate into various monitoring systems and a handle extension. Carton quantity The panel mount 200 A CCP2 switches are available with a variety of accessories to meet many application needs including rotary and flange handle operation. Front and side rotary operated versions are easily applied for through-the-door or through the left or right side operation to enhance safety. Item 200 amp switches Poles Qty. 1 1 2 1 3 1 Ratings • Volts • 347 Vac (1-pole) 600 Vac (2- and 3-pole) • Amps • SCCR • • 8 200 A 200 kA RMS Sym. Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 8 5/2/2019 10:54:56 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Features • • • • • • • Uses UL Class CF time-delay CUBEFuse with Class J electrical performance Amp rating rejection feature will not accept a CUBEFuse amp ratings greater than switch rating High 200 kA short-circuit current rating Disconnect rated to provide means for load isolation Full voltage rated at 600 Vac UL 98 Listed and suitable for branch circuit disconnect and branch circuit protection with installed fuses Horsepower rated (see table below) Catalog numbers and horsepower ratings Catalog no. 200 amp switches CCP2-1-200CF CCP2-2-200CF CCP2-3-200CF Poles Description 1 2 3 Switch only Volts AC • • • • • • Standard local open fuse indication light on each pole speeds troubleshooting Built-in switch interlock prevents inserting or removing fuse while in the ON position Padlockable for lockout/tagout procedures with a 1/4” lock Front and side rotary operator accessories provide for throughthe-door and through-the-side operation flexibility and enhanced safety Optional pistol handles and shafts available for use with rotary operator accessories Multi-wire lug kits with terminal shrouds allow for power distribution to multiple loads. SCCR 240 Max Hp rating (Vac) 480 600 200 kA — 10 50 — — 100 — — 150 347 600 Available lugs, conductor ratings and terminal torques Catalog no. Description 200 A switches CCP2-L2-1 Stainless steel lug CCP2-L2-1A Aluminum lug* CCP2-MW2-3 3-port multi-wire terminal with shroud* CCP2-MW2-6 6-port multi-wire terminal with shroud* Lugs per cat. no. Wire range AWG (mm2) Wire type/ temp. 1 1 3 3 350-4 (185-25) 350-4 (185-25) 2-14 (35-2.5) 6-14 (16-2.5) Cu 75°C Cu/Al 75°C Cu/Al 75°C Cu/Al 75°C Conductor torque Lug mounting screw N•m (lb-in) torque N•m (lb-in) 20.3 (180) 28.2 (250) 7.9 (70) 2.8 (25) 0.9 (8) 13.5 (120) 10.8 (95) 10.8 (95) * These lugs also accept 1/4” quick connect control wire terminals. Order catalog number CCP2-CWK2 (package of 12 terminals). Carton quantity Catalog no. CCP2-L2-1 CCP2-L2-1A CCP2-MW2-3 CCP2-MW2-6 CCP2-CWK2 Description Stainless steel lug Aluminum lug 3-port multi-wire terminal with shroud 6-port multi-wire terminal with shroud 1/4” quick connect control wire terminals Accessories Qty. 1 1 3 3 12 Catalog no. CCP2-TS2-3 CCP2-PB2 CCP2-RM2 CCP2-SM Switch amps 200 Description 3-pole terminal shroud Phase barriers (pack of 2) Front rotary operator* (3-pole switch only) Side rotary operator* (1-, 2- or 3-pole switches) * Complete installation requires pistol handle and shaft, order separately. Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 9 9 5/2/2019 10:54:56 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 200 amp switch dimensions — mm (in) Ø 5.0 (0.2) Thru Ø 9.2 (0.4) 5.4 (0.2) 133.2 (5.2) 104.7 (4.1) 160.4 (6.3) 119.7 (4.7) 85.4 (3.4) 34.9 (1.4) 34.9 (1.4) 56.0 (2.2) 55.2 (2.2) 177.9 (7.0) Front rotary mechanism accessory CCP2-RM2 152.4 (6.0) 139.7 (5.5) Side rotary mechanism accessory CCP2-SM 34.9 (1.4) 87.3 (3.4) 335.9 (13.2) 34.9 (1.4) 119.7 (4.7) 3-pole terminal shroud accessory CCP2-TS2-3 104.8 (4.1) 10 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 10 5/2/2019 10:55:01 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 30, 60 and 100 A switch multi-wire lug kits Installed on CCP2-3-xx Catalog numbers • CCP2-MW1-3 (30 and 60 A switches only) • CCP2-MW1-6 (100 A switches only) Description The multi-wire lug kits permit expanding each box lug terminal on the switch into a three-port (30 and 60 A switches) or six-port (100 A switches) terminal for power distribution applications. Each multi-wire lug kit comes with three lugs and three terminal shrouds. Shrouds provide finger-safe protection when properly installed. Lugs may be mounted on either the loadside or lineside to meet various application needs. Ports on any one lug accept any conductor combination listed, e.g., one of the ports may have dual 14 AWG wires and the other two ports single 10 AWG wires. Multi-wire lugs mount in switch box lug terminals to provide three additional wire ports per pole. Lugs can be mounted on the switch lineside or loadside. Each multi-wire lug kit comes with three lugs and three shrouds. Ratings • Volts 600 V • Amps • 60 A max (CCP2-MW1-3) • 100 A max (CCP2-MW1-6) • Wire insulation strip lengths SCCR 200 kA Agency information • UL Recognized, Guide WHTY2, File E302370 1 = 11/16” • RoHS compliant 2 = 1-1/8” Storage and operating temperature • 1/8” Allen head screw 1/8” Allen head screw 1 = 11/16” 2 = 1-1/8” 3 = 1-9/16” 3 = 1-9/16” -20°C to 75°C (-4°F to 167°F) Multi-wire lug conductor information Strip back wire insulation to the lengths as indicated in the illustration above and the table below. • 75°C Cu/AL • AWG size and quantity per port - see table below Type Cu/Al Cu AWG range 4-6 Class Quantity Torque N•m (lb-in) 3.95 (35) Stranded, Class B/C Single 10-14 Stranded, Class B/C Single/dual* 2.26 (20) 10-14 Solid Single 2.26 (20) UL ferrule, Class B to K Single/twin† 8 8 10-14 2.82 (25) Lug port Strip wire insulation back (inch) 1 11/16 2 1-1/8 3 1-9/16 2.82 (25) 2.26 (20) * Dual wire to be same size and type. † Two stranded conductors placed in one UL Listed twin ferrule. CCP2 box lug torque for multi-wire lugs • 30/60 A switch lug, 4.52 N•m (40 lb-in) • 100 A switch lug, 5.09 N•m (45 lb-in) Carton quantity Catalog no. Application CCP2-MW1-3 For 30/60 A switches only CCP2-MW1-6 For 100 A switches only 11 Qty. 3 lugs and 3 shrouds Wiring versatility is provided by single/dual rated box lug terminals on the switch, or by the three-port or six-port multi-wire lug kits that are also single/dual wire rated. Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 11 5/2/2019 10:55:16 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A 200 A switch multi-wire lug kits Technical Data 10801 Effective April 2019 Installed on CCP2-3-xx Catalog numbers • CCP2-MW2-3 ( 3-port, 200 A switches only) • CCP2-MW2-6 (6-port, 200 A switches only) Description The multi-wire lug kits permit expanding the terminal on the switch into a three-port (200 A switches) or six-port (200 A switches) terminal for power distribution applications. Each multi-wire lug kit comes with three lugs and a 3-pole terminal shroud. The shroud provides finger-safe protection when properly installed. 3- and 6-port multi-wire lugs mounted on 200 A switches Lugs can only be mounted on loadside to meet application needs. Ports on any one lug accept any conductor combination listed, e.g., one of the ports may have dual 14 AWG wires and the other two ports single 10 AWG wires. Wire insulation strip lengths Ratings • Volts 600 V • Amps • 225 A max (CCP2-MW2-3 and CCP2-MW2-6) • SCCR 200 kA • 1 = 3/8 to 1/2” 1 = 3/8 to 1/2” 2 = 3/4 to 7/8” 2 = 3/4 to 7/8” 3 = 1-1/4 to 1-3/8” 3 = 1-1/4 to 1-3/8” CCP2-MW2-6 Strip back wire insulation to the lengths indicated in the illustration above and the table below. Wire insulation strip length (inch) UL Recognized, Guide WHTY2, File E302370 Lug kit RoHS compliant CCP2-MW2-3 Storage and operating temperature • 4 mm Allen head screw CCP2-MW2-3 Agency information • 4 mm Allen head screw CCP2-MW2-6 -20°C to 75°C (-4°F to 167°F) Lug port 1 Lug port 2 Lug port 3 3/8 to 1/2 3/4 to 7/8 1-1/4 to 1-3/8 Multi-wire lug conductor information • 75°C Cu/AL • AWG size and quantity per port Carton quantity Catalog no. CCP2-MW2-3 CCP2-MW2-6 Application For 200 A switches only Qty. 3 lugs and 1 3-pole shroud Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 12 12 5/2/2019 10:55:24 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Selector and pistol handles Selector handles Pistol handles —short and long Catalog symbol • CCP2-H4X-_1 (selector handle for 30, 60 and 100 A switches) • CCP2-H4X-_2 (pistol handle for 30, 60 and 100 A switches) • CCP2-H4X-_3 (short pistol handle for 200 A switches) • CCP2-H4X-_4 (long pistol handle for 200 A switches) Description Selector and pistol handles are used with rotary operated switches. Pistol handles for 200 A switches come in short and long versions. All handles are available in black/gray and red/yellow colors, and clockwise/counterclockwise operating modes. Front and right side operated switches use clockwise handles while left side operated switches use counterclockwise handles. Installation requires an 8 mm shaft for 30, 60 and 100 A switches and a 12 mm shaft for 200 A switches (ordered separately). Each handle is rated Type 1, 4X and 12, and accepts up to three (3) 1/4” diameter shank locks for lockout/tagout in the OFF position. They can also be field configured for lock-on and are defeatable. Only the clockwise operating handles in combination with front rotary operating switches provide a door interlock means to ensure the enclosure door remains shut during lockout/tagout or lock-on. Rotary handles mounted on the enclosure’s left or right side do NOT provide a door interlock means. See the catalog number table below for applicable rotary switch, handle and shaft combinations. Agency information • UL Listed, Guide DIHS/DIHS7, File E140305 • Type 1, 4X and 12 • RoHS compliant • CE Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) Carton quantity Catalog no. Description CCP2-H4X-_1 30/60/100 A selector handles Qty. 1 CCP2-H4X-_2 30/60/100 A pistol handles 1 CCP2-H4X-_3 200 A short pistol handles 1 CCP2-H4X-_4 200 A long pistol handles 1 Handles and shafts for 30, 60 and 100 A switches For catalog no. CCP2R-(pole)-30CF CCP2R-(pole)-60CF CCP2R-(pole)-100CF CCP2RL-(pole)-30CF CCP2RL-(pole)-60CF CCP2RL-(pole)-100CF CCP2S-(pole)-30CF CCP2S-(pole)-60CF CCP2S-(pole)-100CF Description/operation Order handle cat. no. Order either 8 mm shaft cat. no. Right front rotary, clockwise CCP2-H4X-B1 (selector, black/grey) Left front rotary, clockwise CCP2-H4X-R1(selector, red/yellow) CCP2-H4X-B2 (pistol, black/grey) CCP2-H4X-R2 (pistol, red/yellow) Right side rotary, clockwise CCP2SL-(pole)-30CF CCP2-SH1-290 (11.5”/290 mm) CCP2-SH1-490 (19.3”/490 mm) CCP2-H4X-B1L (selector, black/grey) Left side rotary, counterclockwise CCP2SL-(pole)-60CF CCP2-H4X-R1L (selector, red/yellow) CCP2-H4X-B2L (pistol, black/grey) CCP2-H4X-R2L (pistol, red/yellow) CCP2SL-(pole)-100CF Handles and shafts for 200 A switches For catalog no. Order front rotary mechanism cat. no. CCP2-(poles)-200CF CCP2-RM2* Order right/ left side rotary Order left side counterclockwise mechanism Order front/right side clockwise handles (use only with CCP2-SM) cat. no. handle cat. no. cat. no. CCP2-SM CCP2-H4X-B3 (short - black/grey) CCP2-H4X-B3L (short - black/grey) CCP2-H4X-R3 (short - red/yellow) CCP2-H4X-R3L (short - red/yellow) Order either 12 mm shaft cat. no. CCP2-SH2-225 (8.9”/225 mm) * For three-pole switches only. 13 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 13 5/2/2019 10:55:42 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Handle shafts Handle dimensions — mm (in) Selector for 8 mm shafts 28 (1.1) 8 mm shafts 71 (2.8) 26 (1.0) 73 (2.9) 85 (3.3) 48 (1.9) Ø7 (0.3) 85 (3.3) 71 (2.8) Short pistol for 8 mm and 12 mm shafts 12 mm shafts 33 (1.3) 85 (3.3) Ø7 (0.3) 71 (2.8) 85 (3.3) 96 (3.8) 69 (2.7) ON OFF 27 (1.1) 129 (5.1) 71 (2.8) Catalog numbers Long pistol for 12 mm shafts 85 (3.3) 34 (1.3) Ø7 (0.3) 68 (2.7) 96 85 (3.8) (3.3) 71 (2.8) 28 (1.1) 179 (7.0) 71 (2.8) • CCP2-SH1-290 (8 mm, 290 mm long) • CCP2-SH1-490 (8 mm, 490 mm long) • CCP2-SH2-225 (12 mm, 225 mm long) • CCP2-SH2-425 (12 mm, 425 mm long) Description Square shafts available in: • 8 mm square by 290 and 490 mm lengths for 30, 60 and 100 A switches • 12 mm square by 225 and 425 mm lengths for 200 A switches All shafts are indexed to ensure handle/switch orientation for correct operation. Shafts are to be cut to length when installed. Carton quantity Catalog no. CCP2-SH1-290 CCP2-SH1-490 NFPA 79 compliant handles CCP2-SH2-225 Catalog numbers CCP2-SH2-425 • CCP2-NFPA-1 (8 mm shafts for 30-100 A switches) • CCP2-NFPA-2 (12 mm shafts for 200 and 400 A switches) Size 8 mm 12 mm Length Qty. 290 mm 1 490 mm 1 225 mm 1 425 mm 1 Description NFPA 79 handles mount on the shaft of front rotary operated switch installations and provide a lockout means independent of the door position. Carton quantity Catalog no. Fits shaft size Qty. CCP2-NFPA-1 8 mm 1 CCP2-NFPA-2 12 mm 1 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 14 14 5/2/2019 10:56:06 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Flange handle rod and cable operators Catalog no. Description Rating 30, 60 and 100 amp switches CCP2-FLR1* Rod operator with painted handle Type 1, 3R, 12 CCP2-FLR1X* Rod operator with chrome handle Type 4X CCP2-FLC1-36 36” Cable with painted handle Type 1, 3R, 12 CCP2-FLC1-36X 36” Cable with chrome handle Type 4X CCP2-FLC1-60 60” Cable with painted handle Type 1, 3R, 12 CCP2-FLC1-60X 60” Cable with chrome handle Type 4X CCP2-FLC1-120 120” Cable with painted handle Type 1, 3R, 12 CCP2-FLC1-120X 120” Cable with chrome handle Type 4X Flange rod operator kit for 30, 60 and 100 A switches. 200 amp switches CCP2-FLR2 Rod operator with painted handle Type 1, 3R, 12 CCP2-FLR2X Rod operator with chrome handle Type 4X CCP2-FLC2-36 36” Cable with painted handle Type 1, 3R, 12 CCP2-FLC2-36X 36” Cable with chrome handle Type 4X CCP2-FLC2-60 60” Cable with painted handle 1, 3R, 12 CCP2-FLC2-60X 60” Cable with chrome handle Type 4X CCP2-FLC2-120 120” Cable with painted handle Type 1, 3R, 12 CCP2-FLC2-120X 120” Cable with chrome handle Type 4X * Installing these flange handle rod operators prohibits also installing a PLC fuse monitor or auxiliary contact. Flange rod operator kit for 200 A switches. Description Flange rod and cable operators for use on 2- and 3-pole CCP2 switches (cannot be used with 2- or 3-pole 30, 60 or 100 amp switches already having a front or side rotary operating mechanism). Handles are available in painted versions with Type 1, 3R and 12 ratings or chrome versions with a Type 4X rating. Cable operators are available with 36, 60 and 120 inch cable lengths. Agency information • Type 1, 4X and 12 • RoHS compliant Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) Flange cable operator kit for 30, 60 and 100 A switches. Packaging • Each handle is packaged individually as a kit Carton quantities Catalog no. Switch amps/description CCP2-FLR1_ 30/60/100 A rod operator 1 CCP2-FLR2_ 200 A rod operator 1 CCP2-FLC1-36_ 30/60/100 A 36” cable operator 1 CCP2-FLC2-36_ 200 A 36” cable operator 1 CCP2-FLC1-60_ 30/60/100 A 60” cable operator 1 CCP2-FLC2-60_ 200 A 60” cable operator 1 CCP2-FLC1-120_ 30/60/100 A 120” cable operator 1 CCP2-FLC2-120_ 200 A 120” cable operator 1 15 Qty. Flange cable operator kit for 200 A switches. Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 15 5/2/2019 10:56:28 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Front rotary mechanisms for 200 A switches Technical Data 10801 Effective April 2019 Phase barriers Catalog numbers • CCP2-PB2 (3-pole 200 A switches) Description Phase barrier kit with two phase barriers for isolation between the lugs on 3-pole 200 A switches. Packaged individually. Catalog numbers • CCP2-RM2 (3-pole 200 A switches) Handle extension Description Front rotary mechanisms for through-the-door operation and install on the front of 3-pole switches only. These units provide at-switch lockout/tagout capability for enhanced safety. Complete installation requires installing pistol handle (short or long) and 12 mm shaft. Packaged individually. Side rotary mechanism for 200 A switches Catalog number • CCP2-HEX (1-, 2- and 3-pole 200 A switches) Description A handle extension to provide additional leverage for operating the switch in installations that do not have rotary mechanisms or flange operators installed. Does not mount on switch, provision for tether provided. Packaged individually. Catalog number • CCP2-SM (1-, 2- or 3-pole 200 A switches) Description Side rotary mechanism for through-the-side operation and installs on the left or right side (right side installation recommended) of any 1-, 2- or 3-pole 200 A switch. The side rotary mechanism does not provide for door interlock nor local lockout/tagout capability. Complete installation requires installing pistol handle (short or long) and 12 mm shaft. Packaged individually. Terminal shrouds Catalog numbers • CCP2-TS2-3 (3-pole 200 A switches) Description 3-pole shroud kit with shields for isolating the lugs on 3-pole 200 A switches. Packaged individually. Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 16 16 5/2/2019 10:56:54 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Auxiliary contacts for 30, 60 and 100 A switches Installed on a CCP2-3-xx Catalog numbers Note: CCP2-AUX and CCP2-AUX-100 CANNOT be mounted on the right front and right side rotary operated versions, nor if a flange handle rod or cable operator is installed. • CCP2-AUX (30 and 60 A switches) • CCP2-AUX-100 (100 A switches) Description NO+NC contact output to indicate the switching mechanism status on the CCP2. A single unit can be mounted on any 1-, 2- or 3-pole CUBEFuse CCP2 switch and the left front/left side rotary operated switches. Ratings • 240 Vac max • 5 A max • NC/NO contacts are closed/open when the CCP2 switch is in the “ON” position (closed) Catalog no. Switch CCP2-AUX 30/60 A only CCP2-AUX-100 100 A only Description Max per CCP2* Ratings Auxiliary contacts N/NC for switch status 1 per CCP2 (1-, 2- or 3-pole) 5 A / 240 Vac Dimensions — in 1.8 * The CCP2-AUX CANNOT be mounted on the right front and right side rotary operated versions, nor installed with the flange handle rod or cable operator. De-energize all circuits and follow all prescribed safety procedures before installing or removing the auxiliary contact device. Agency information • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 • Finger-safe in installed state • RoHS compliant • CE 2.6 STRIP 33 NO 34 NO 41 NC 42 NC Wiring • 16-20 AWG (1.5 to 0.5 mm2) single and dual stranded wire • 20 AWG (1.5 mm2) single and dual solid wire • Torque 0.56 N•m (5 lb-in) • Use only 75°C Cu wire .190 3.7 0.3 CCP2-AUX Packaging • 1.9 1.8 CCP2-AUX and CCP2-AUX-100 are packaged individually Installation technique • Mounts on the CCP2’s right side ONLY and mechanically interlocks with the CCP2 switch handle with provided hardware. The CCP2-AUX and CCP2-AUX-100 CANNOT be mounted on the right front and right side rotary operated versions, or installed with the flange handle rod or cable operator. 2.9 33 NO STRIP 34 NO 2.2 Storage and operating temperature • 42 NC 41 NC -20°C to 75°C (-4°F to 167°F) Carton quantity and shipping weight Catalog no. Application CCP2-AUX For 30 and 60 A switches only CCP2-AUX-100 For 100 A switches only 17 Qty. Weight lb (kg) 1 0.14 (0.063) .190 3.7 0.3 CCP2-AUX-100 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 17 5/2/2019 10:57:05 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Auxiliary contacts for 200 A switches Installed on a CCP2-3-xx Catalog number Note: CCP2-AUX-S CANNOT be mounted on the same side as the side rotary mechanism CCP2-SM or the right side if a flange handle rod or cable operator is installed. • CCP2-AUX-S (200 A switches) Description NO+NC contact output to indicate the switching mechanism status on the CCP2. A single unit can be mounted on either side of any 1-, 2- or 3-pole switch (cannot be mounted on the same side as the CCP2-SM side rotary mechanism or the right side if a flange handle rod or cable operator is installed). Ratings • 240 Vac max • 5 A max • NC/NO contacts are closed/open when the CCP2 switch is in the “ON” position (closed) Catalog no. CCP2-AUX-S Switch Description Max per CCP2* Ratings 200 A Auxiliary contacts NO+NC for switch status 1 per CCP2 (1-, 2- or 3-pole) 5 A / 240 Vac * The CCP2-AUX-S CANNOT be mounted on the same side where the side rotary mechanism (CCP2-SM) is installed. De-energize all circuits and follow all prescribed safety procedures before installing or removing the auxiliary contact device. Agency information • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 • Finger-safe in installed state • RoHS compliant Wiring • 16-20 AWG (1.5 to 0.5 mm2) single and dual stranded wire • 20 AWG (1.5 mm2) single and dual solid wire • Torque 0.56 N•m (5 lb-in) • Use only 75°C Cu wire Installation technique • Mounts on either side of the 200 A switches and mechanically interlocks with the switch’s handle with provided hardware. The CCP2-AUX-S CANNOT be mounted on the same side with an installed CCP2-SM side rotary mechanism, or the flange cable/rod operating mechanisms. Storage and operating temperature • -20°C to 75°C (-4°F to 167°F) Packaging • Packaged individually. Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 18 18 5/2/2019 10:57:15 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 PLC fuse monitor for 30, 60 and 100 A switches Agency information Catalog numbers • UL 98 Recognized, Guide WHTY2, File E155130 • cURus to Canadian Standard 22.2 No. 4-04 • CCP2-PLC-IND (30/60 A switches) • CCP2-PLC-100 (100 A switches) Local indication • Description A resettable three-phase fuse monitor that integrates with the I/O card in a Programmable Logic Controller (PLC). A single unit can be mounted on any 1-, 2- or 3-pole CUBEFuse CCP2 switch up to 100 A and the left front/ left side rotary operated switches. A single unit monitors up to three phases. When used on 1- and 2-pole switches unused conductor(s) are removed after installation. The CCP2-PLC-IND and CCP2-PLC-100 CANNOT be mounted on the left front/left side rotary operated versions or if a multi-wire lug kit is installed, or if the flange handle rod operator is installed. Wiring • • Signal output to PLC* • +24 Vdc, 10 mA max • Output signals • Digital 0 Vdc (low), 24 Vdc max (high) For power, signal and ground connections use shielded twisted pair 22-24 AWG (0.34-0.25 mm2) 300 V rated wire Carton quantity and shipping weight Catalog no.* Application CCP2-PLC-IND 30 and 60 A switches only CCP2-PLC-100 100 A switches only IP20 rating — yes Storage and operating temperature • 24 Vdc High – fuse has opened • * When the fuse opens, the output signal is sent high and will remain high until the unit is reset. Emissions and immunity testing • IEC 60947-1: Voltage Switchgear and Control Gear • IEC 61000-6-2: Electromagnetic Compatibility (EMC) • IEC 61000-4-2: Electrostatic Discharge Immunity - Test at level 3 (6 kV-Contact Discharge) and level 2 (4 kV-Air Discharge) • IEC 61000-4-3: Electromagnetic Compatibility - Radiated, Radiofrequency, Electromagnetic Field Immunity test at level x (20 V/m) • IEC 61000-4-4: Electromagnetic Compatibility - Testing and Measurement Techniques at level 3 (± 2kV - Power Port and ±1 kV - I/O Ports) • IEC 61000-4-5: Electromagnetic Compatibility - Surge Immunity test at level 4 (±4 kV) • IEC 61000-4-6: Immunity to Conducted Disturbances at level 3 (10 V) CCP2-PLC-IND CCP2-PLC-100 Switch Description 30/60 A Wired only remote fuse 1 per CCP2 indication (1, 2- or 3-pole) 100 A for PLC only applications 0.17 (0.077) Mounts on the left side ONLY of the CCP2 and mechanically interlocks with the CCP2 switch handle with hardware provided. The CCP2-PLC-IND and CCP2-PLC-100 CANNOT be mounted on the left front/left side rotary operated versions, or if a multi-wire lug kit is installed or if the flange handle rod operator is installed. 0 Vdc Low – fuse is good Catalog no. 1 Weight lb (kg) Installation technique • Max per CCP2** Qty. * Includes 0.110” (2.8 mm) quick connects for power, signal and ground connections. • Ratings Two distinct LEDs indicate unit power (green) and open fuse (red). Open fuse LED is resettable upon fuse replacement and the actuating the reset switch Signal output to PLC Min. circuit volts 24 Vdc/ 10 mA 100 Vac -20°C to 75°C (-4°F to 167°F) PLC programming • The CCP2-PLC-IND or CCP2-PLC-100 signal line is designed to provide a digital input to a PLC I/O card. In this case, a Programmable Logic Control program must be written to properly interpret the input signal to the PLC. The PLC program should check for consecutive high signals before taking action on a critical process. ** The CCP2-PLC-IND and CCP2-PLC-100 CANNOT be mounted on the left front/ left side rotary operated versions, or if a multi-wire lug kit is installed or if the flange handle rod operator is installed. De-energize all circuits and follow all prescribed safety procedures before installing or removing the CCP2-PLC-IND or CCP2-PLC-100. 19 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 19 5/2/2019 10:57:19 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Installed on a CCP2-3-xx Technical Data 10801 Effective April 2019 PLC wiring schematic PLC power supply PLC fuse monitor +24 Vdc +24 Vdc 0 Vdc/Gnd 0 Vdc/Gnd Signal 10 mA max. The PLC fuse monitor needs to be powered by the same +24 Vdc and ground (0 Vdc/Gnd return) terminals that feed the PLC input card. If it is not, it may improperly signal. +24 Vdc 0 Vdc/Gnd PLC input card CCP2-PLC-IND mounted on a 3-pole switch and using the fork terminals. When mounted on a 2- or 1-pole switch, remove unused leads. If feeding multiple PLC fuse monitors from different power supplies, there must be multiple input cards being powered by those same power supplies as well. Note: the CCP2-PLC-IND CANNOT be mounted on the left front/left side rotary operated versions or if the multi-wire lug kit is installed or if the flange handle rod operator is installed. Dimensions — in Pin interlocks with CCP2 switch handle SIG GND +24vDC +24vDC RESET STATUS 2 4T 1.9 6T 5L 3 3 2.6 3L 2 2T 1L 1 1 ON 1.8 3.7 30 and 60 A CCP 0.3 Pin interlocks with CCP2 switch handle 4T 2 2.2 6T 3 5L 3 2.9 3L 2 2T 1L 1 SIG GND +24vDC +24vDC RESET STATUS 1 ON 2.0 3.7 0.3 100 A CCP Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 20 20 5/2/2019 10:57:29 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Ordering a complete switch installation 30 and 60 A CCP2 clockwise rotary switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Right front rotary CCP2R-2-30CF 2 30 CCP2R-3-30CF CCP2R-2-60CF 3 2 60 CCP2R-3-60CF 3 Left front rotary CCP2RL-2-30CF 2 30 CCP2RL-3-30CF CCP2RL-2-60CF 3 2 60 CCP2RL-3-60CF 3 Right side rotary CCP2S-2-30CF CCP2S-3-30CF CCP2S-2-60CF 3 2 60 CCP2S-3-60CF Required 2 30 3 And Rotary handles Description Rating CCP2-H4X-B1 Selector handle — black/grey CCP2-H4X-R1 Selector handle — red/yellow Type 1, 4X, 12 CCP2-H4X-B2 Pistol handle — black/grey CCP2-H4X-R2 Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Multi-wire lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Optional And 21 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 21 5/2/2019 10:57:59 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Accessories And Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description — use with CCP2RL-(poles)-30/60CF switches CCP2-AUX NO/NC, 5 A / 240 V PLC fuse monitor Description — use with CCP2R-(poles)-30/60CF and CCP2S-(poles)-30/60CF switches CCP2-PLC-IND Signal output 24 Vdc / 10 mA Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 22 22 5/2/2019 10:58:08 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Ordering a complete switch installation 30 and 60 A CCP2 switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Required Switches Amps Poles Switch (used alone or with flange cable or flange rod handles) CCP2-1-30CF 1 CCP2-2-30CF 2 30 CCP2-3-30CF 3 CCP2-1-60CF 1 CCP2-2-60CF 60 2 CCP2-3-60CF 3 And Flange handle rod operator Description — 3-pole switches only CCP2-FLR1-21 Red/black painted handle CCP2-FLR1-21X Chrome handle Flange handle cable operator Description - 3-pole switches only, cannot be used with side or front rotary mechanisms CCP2-FLC1-36 36” cable, red/black painted handle CCP2-FLC1-36X 36” cable, chrome handle CCP2-FLC1-60 60” cable, red/black painted handle CCP2-FLC1-60X 60” cable, chrome handle CCP2-FLC1-120 120” cable, red/black painted handle CCP2-FLC1-120X 120” cable, chrome handle Multi-wire lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description — mounts on right side, cannot be used with flange handle rod or cable operator CCP2-AUX NO/NC, 5 A / 240 V PLC fuse monitor Description — mounts on left side, cannot be used with flange handle rod operator CCP2-PLC-IND Signal output 24 Vdc / 10 mA Rating 1, 3R and 12 4X Optional Or Rating Type 1, 3R, 12 Type 4X Type 1, 3R, 12 Type 4X Type 1, 3R, 12 Type 4X Accessories And 23 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 23 5/2/2019 10:58:31 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Ordering a complete switch installation 30 and 60 A CCP2 counterclockwise switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Left side rotary CCP2SL-2-30CF 2 30 CCP2SL-3-30CF CCP2SL-2-60CF 3 2 60 CCP2SL-3-60CF 3 Required And Rotary handles Description Rating CCP2-H4X-B1L Selector handle — black/grey CCP2-H4X-R1L Selector handle — red/yellow Type 1, 4X, 12 CCP2-H4X-B2L Pistol handle — black/grey CCP2-H4X-R2L Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Multi-wire lug kits Description CCP2-MW1-3 3-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Terminal shrouds Description CCP2-TS1-3 Pack of 3 Auxiliary contacts Description —mounts on right side CCP2-AUX NO/NC, 5 A / 240 V Optional And Accessories And Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 24 24 5/2/2019 10:59:00 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Ordering a complete switch installation 100 A CCP2 clockwise rotary switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Right front rotary CCP2R-2-100CF 2 100 CCP2R-3-100CF 3 Left front rotary CCP2RL-2-100CF 2 100 CCP2RL-3-100CF 3 Right side rotary CCP2S-2-100CF 2 100 Required CCP2S-3-100CF 3 And Rotary handles Description Rating CCP2-H4X-B1 Selector handle — black/grey CCP2-H4X-R1 Selector handle — red/yellow Type 1, 4X, 12 CCP2-H4X-B2 Pistol handle — black/grey CCP2-H4X-R2 Pistol handle — red/yellow And Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Optional And 25 Multi-wire lug kits Description CCP2-MW1-6 6-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 25 5/2/2019 10:59:33 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Accessories And Terminal shrouds Description CCP2-TS1-6 Pack of 3 Auxiliary contacts Description — cannot be used on right front or right side operated switches CCP2-AUX-100 NO/NC, 5 A / 240 V PLC fuse monitor Description — Cannot be used on left front or left side operated switches CCP2-PLC-100 Signal output 24 Vdc / 10 mA Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 26 26 5/2/2019 10:59:42 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Ordering a complete switch installation 100 A CCP2 switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Required Switch (used alone or with flange cable or flange rod handles) CCP2-1-100CF 1 CCP2-2-100CF 100 2 CCP2-3-100CF 3 And Flange handle rod operator Description — 3-pole switches only CCP2-FLR1-21 Red/black painted handle CCP2-FLR1-21X Chrome handle Flange handle cable operator Description - 3-pole switches only, cannot be used with side or front rotary mechanisms CCP2-FLC1-36 36” cable, red/black painted handle CCP2-FLC1-36X 36” cable, chrome handle CCP2-FLC1-60 60” cable, red/black painted handle CCP2-FLC1-60X 60” cable, chrome handle CCP2-FLC1-120 120” cable, red/black painted handle CCP2-FLC1-120X 120” cable, chrome handle Multi-wire lug kits Description CCP2-MW1-6 6-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Rating 1, 3R and 12 4X Optional Or Rating Type 1, 3R, 12 Type 4X Type 1, 3R, 12 Type 4X Type 1, 3R, 12 Type 4X Accessories And 27 Terminal shrouds Description CCP2-TS1-6 Pack of 3 Auxiliary contacts Description — mounts on right side, cannot be used with flange handle rod or cable operator CCP2-AUX-100 NO/NC, 5 A / 240 V PLC fuse monitor Description — mounts on left side, cannot be used with flange handle rod operator CCP2-PLC-100 Signal output 24 Vdc / 10 mA Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 27 5/2/2019 11:00:05 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Ordering a complete switch installation 100 A CCP2 counterclockwise switches For a complete assembly, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles Left side rotary CCP2SL-2-100CF 2 100 CCP2SL-3-100CF 3 Required And Rotary handles Description Rating CCP2-H4X-B1L Selector handle — black/grey CCP2-H4X-R1L Selector handle — red/yellow CCP2-H4X-B2L Pistol handle — black/grey CCP2-H4X-R2L Pistol handle — red/yellow Shafts (8 mm) Length CCP2-SH1-290 290 mm CCP2-SH1-490 490 mm NFPA 79 compliant handle Color CCP2-NFPA-1 Red Multi-wire lug kits Description CCP2-MW1-6 6-port multi-wire, 75°C Cu/Al, 6-14, includes terminal shrouds, pack of 3 Type 1, 4X, 12 And Optional And Accessories And Terminal shrouds Description CCP2-TS1-6 Pack of 3 Auxiliary contacts Description — mounts on right side CCP2-AUX-100 NO/NC, 5 A / 240 V Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 28 28 5/2/2019 11:00:32 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Ordering a complete switch installation 200 A CCP2 switches For a complete installation, select from the following required and optional components, and accessories. Catalog no. Switches Amps Poles CCP2-1-200CF 1 CCP2-2-200CF 200 2 Required CCP2-3-200CF 3 And Lug kits Description CCP2-L2-1 Stainless steel lug, 75° Cu only, 350 kcmil-4, 1 per pack CCP2-L2-1A Aluminum lug, 75°C Cu/Al, 350 kcmil-4, 1 per pack CCP2-MW2-3 3-port multi-wire lug, 75°C Cu/Al, 2-14, 3 per pack, includes terminal shroud CCP2-MW2-6 6-port multi-wire lug, 75°C Cu/Al, 6-14, 3 per pack, includes terminal shroud And Rotary mechanisms Description CCP2-SM Side rotary mechanism - mounts on left or right side of 1-, 2- and 3-pole switches CCP2-RM2 Front rotary mechanism - mounts only on 3-pole switches, requires clockwise rotating handle Optional And Rotary handles Description Rotation - must match switch rotation CCP2-H4X-B3 Short pistol handle — black/grey Clockwise CCP2-H4X-R3 Short pistol handle — red/yellow CCP2-H4X-B4 Long pistol handle — black/grey CCP2-H4X-R4 Long pistol handle — red/yellow For use with front rotary mechanism or side rotary mechanism CCP2-SM on the switch’s right side CCP2-H4X-B3L Short pistol handle — black/grey Counterclockwise CCP2-H4X-R3L Short pistol handle — red/yellow CCP2-H4X-B4L Long pistol handle — black/grey CCP2-H4X-R4L Long pistol handle — red/yellow Use only if installing side rotary mechanism CCP2SM on the switch’s left side Shafts (12 mm) Length CCP2-SH2-225 225 mm CCP2-SH2-425 425 mm NFPA 79 compliant handle Color CCP2-NFPA-2 Red Rating Type 1, 4X, 12 And 29 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 29 5/2/2019 11:01:08 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Optional Or Flange handle rod operator Description — 3-pole switches only, cannot be used with side or front rotary mechanisms CCP2-FLR2-21 Red/black, painted handle CCP2-FLR2-21X Chrome handle Flange handle cable operator Description - 3-pole switches only, cannot be used with side or front rotary mechanisms CCP2-FLC2-36 36“ cable, red/black painted handle CCP2-FLC2-36X 36“ cable, chrome handle CCP2-FLC2-60 60“ cable, red/black painted handle CCP2-FLC2-60X 60“ cable, chrome handle CCP2-FLC2-120 120“ cable, red/black painted handle CCP2-FLC2-120X 120“ cable, chrome handle Rating Type 1, 3R and 12 Type 4X Or Rating Type 1, 3R and 12 Type 4X Type 1, 3R and 12 Type 4X Type 1, 3R and 12 Type 4X And Terminal shrouds Description CCP2-TS2-3 3-pole terminal shroud with phase shields, 1 per pack Phase barriers Description CCP2-PB2 Phase barriers, 2 per pack Accessories And Control wire terminals Description CCP2-CWK2 1/4” quick-connect control wire terminals - mounts on installed lug (cannot be used with lug CCP2-L2-1), 12 per pack Auxiliary contacts Description CCP2-AUX-S NO/NC, 5 A, 240 V - Can be mounted on right or left side Handle extension Description CCP2-HEX Handle extension to facilitate operating 1-, 2 and 3-pole switches. Cannot be used when side or front rotary mechanisms or flange handle rod or cable operators are installed. Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 30 30 5/2/2019 11:01:34 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 Motor sizing table (from NEC Tables 430.248 and 430.250) Bussmann series TCF Low-Peak time-delay Class CF fuses Voltage 115 Vac, 1-phase 230 Vac, 1-phase 200 Vac, 3-phase Motor size (Hp) Motor FLA (amps) Min (amps) NEC code max (amps) Heavy start* (amps) 1/6 4.4 10 10 1/4 5.8 10 15 1/3 7.2 15 15 1/2 9.8 15 20 3/4 13.8 25 25 30 1 16 25 30 35 1-1/2 20 30 35 45 2 24 40 45 50 3 34 50 60 70 NEC code max (amps) Heavy start* (amps) Motor size (Hp) Motor FLA (amps) Min (amps) 10 1/2 2.4 6 6 6 15 3/4 3.5 6 10 10 15 1 4.6 10 10 10 20 1-1/2 6.6 10 15 15 Voltage 208 Vac, 3-phase 2 7.5 15 15 15 3 10.6 17.5 20 20 5 16.7 25 30 35 7-1/2 24.2 40 45 50 20** 59.4 90 110 125 150 5** 56 90 100 125 25 74.8 125 150 7-1/2 80 125 150 175 30 88 150 175 175 10 100 150 175 225 40 114 175 200 250 1/6 2.2 6 6 6 1/2 2.2 6 6 6 1/4 2.9 6 6 6 3/4 3.2 6 6 6 1/3 3.6 6 10 10 1 4.2 10 10 10 1/2 4.9 10 10 10 1-1/2 6 10 15 15 3/4 6.9 15 15 15 2 6.8 15 15 15 1 8 15 15 17.5 3 9.6 15 20 20 1-1/2 10 15 20 20 5 15.2 25 30 30 2 12 20 25 25 7-1/2 22 35 40 45 3 17 25 30 35 20** 54 90 100 110 150 230 Vac, 3-phase 5 28 45 50 60 25 68 110 125 7-1/2 40 60 70 90 30 80 125 150 175 10** 50 80 90 110 40 104 175 200 225 1/2 2.5 6 6 6 1/2 1.1 3 3 3 3/4 3.7 6 10 10 3/4 1.6 3 3 3 1 4.8 10 10 10 1 2.1 6 6 6 1-1/2 6.9 15 15 15 1-1/2 3 6 6 6 2 7.8 15 15 17.5 2 3.4 6 6 6 3 11 17.5 20 20 3 4.8 10 10 10 5 7.6 15 15 15 7-1/2 11 17.5 20 20 5 17.5 30 35 35 7-1/2 25.3 40 45 50 20** 62.1 100 110 125 10 14 25 25 30 25 78.2 125 150 175 15 21 35 40 45 30 92 150 175 200 20 27 40 50 60 50** 65 100 125 125 60 77 125 150 150 75 96 150 175 200 Note: Use NEC code max column for low to moderate reverse/jog/ plug applications. * Heavy Start permitted only if NEC code max does not allow motor start-up. ** If equipment terminations are rated for 60°C conductors only, the 60°C conductor ampacities must be utilized and therefore larger conductor sizes or conduit sizes may be required. 460 Vac, 3-phase Note: Use NEC code max column for low to moderate reverse/jog/ plug applications. * Heavy Start permitted only if NEC code max does not allow motor start-up. ** If equipment terminations are rated for 60°C conductors only, the 60°C conductor ampacities must be utilized and therefore larger conductor sizes or conduit sizes may be required. 31 Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 31 5/2/2019 11:01:35 PM Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Technical Data 10801 Effective April 2019 Motor sizing table (from NEC Tables 430.248 and 430.250) Bussmann series TCF Low-Peak time-delay Class CF fuses Voltage Motor size (Hp) Motor FLA (amps) Min (amps) NEC code max (amps) Heavy start* (amps) 1/2 0.9 3 3 3 3/4 1.3 3 3 3 575 Vac, 3-phase 1 1.7 3 3 3 1-1/2 2.4 6 6 6 2 2.7 6 6 6 3 3.9 6 10 10 5 6.1 10 15 15 7-1/2 9 15 20 20 20 10 11 17.5 20 40** 41 70 80 80 50 52 80 100 110 60 62 100 110 125 75 77 125 150 150 100 99 150 175 200 Note: Use NEC code max column for low to moderate reverse/jog/ plug applications. * Heavy Start permitted only if NEC code max does not allow motor start-up. ** If equipment terminations are rated for 60°C conductors only, the 60°C conductor ampacities must be utilized and therefore larger conductor sizes or conduit sizes may be required. Eaton.com/bussmannseries bus-ele-ds-10801-ccp2-cf-67.indd 32 32 5/2/2019 11:01:35 PM Technical Data 10801 Compact Circuit Protector (CCP2) UL 98 Class CF disconnect switches up to 200 A Effective April 2019 The only controlled copy of this data sheet is the electronic read-only version located on the Eaton network drive. All other copies of this document are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. Eaton 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com Bussmann Division 114 Old State Road Ellisville, MO 63021 United States Eaton.com/bussmannseries © 2019 Eaton All Rights Reserved Printed in USA Publication No. 10801- BU-MC18088 April 2019 bus-ele-ds-10801-ccp2-cf-67.indd 33 For Eaton’s Bussmann series product information, call 1-855-287-7626 or visit: Eaton.com/bussmannseries Eaton and Bussmann are valuable trademarks of Eaton in the US and other countries. You are not permitted to use the Eaton trademarks without prior written consent of Eaton. CSA is a registered trademark of the Canadian Standards Group UL is a registered trademark of the Underwriters Laboratories, Inc. Follow us on social media to get the latest product and support information. 5/2/2019 11:01:36 PM
CCP2-NFPA-2 价格&库存
很抱歉,暂时无法提供与“CCP2-NFPA-2”相匹配的价格&库存,您可以联系我们找货
CCP2-NFPA-2
  • 1+3546.095081+458.68752
