Sensor Connectivity
Global Plus Connector Cables
10.0
Introduction
Product Selection Guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.1
Multi-Connector Blocks
V8-T10-3
V8-T10-3
V8-T10-4
V8-T10-4
V8-T10-5
V8-T10-9
V8-T10-10
V8-T10-10
V8-T10-11
Product Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Application Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Standards and Certifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Product Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Technical Data and Specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Wiring Diagrams . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10
10
Catalog Number Selection . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
10.2
V8-T10-2
V8-T10-13
V8-T10-13
V8-T10-13
V8-T10-13
V8-T10-14
V8-T10-14
V8-T10-14
V8-T10-15
V8-T10-15
10
10
10
10
10
10
10
10
10
10
10
10
10
Unless otherwise noted, the products contained in this section should not
be used for functional safety applications. These products were not designed
or tested to IEC 60947-5-3 or recommended for functional safety.
10
10
10
Learn
Online
10
10
10
10
10
10
10
10
10
10
For Customer Service in the U.S. call 1-877-ETN CARE (386-2273),
in Canada call 1-800-268-3578.
For Application Assistance in the U.S. and Canada
call 1-800-426-9184.
Volume 8—Sensing Solutions CA08100010E—July 2015 www.eaton.com
V8-T10-1
10
10
10.0
Sensor Connectivity
Introduction
10
10
Global Plus
Connector Cables
Page V8-T10-3
Page V8-T10-13
Overview
Overview
Finish your sensor installation with high
quality Connector Cables from Eaton’s
Electrical Sector. Our Global Plus line is
designed to give you everything you want
without paying extra for the features you
don’t want. It includes a wide variety of
single- and double-connector cables in a
variety of sizes (mini, micro, nano), lengths
and jacket materials to fit any application
Junction Blocks from Eaton’s Electrical
Sector allow users to quickly connect
multiple sensors through one source
of power
Sensing Types and Ranges
Nano (M8)
Micro (M12)
Mini
Double-ended, straight, right-angle, and
field-installable connector styles
4-, 6- or 8-ports
Cable or connector models
Micro connector style
10
Product Features
Product Features
Industry standard connector types
10
Industrial-duty polymer jackets consisting
of PVC, PUR, or Irradiated PUR
LED status indicators for power and output
status
10
Stranded copper conductors and polymer
jackets provide a high resistance to
bending motions
10
10
10
10
10
10
10
10
10
10
10
10
10
10
Right angle units for applications that have
constricted space
Molded PUR cable models provide added
protection from moisture and most cutting
fluids
Pluggable terminal blocks provide easy and
quick installation
10
Operating voltage—
Operating voltage—
0–600 Vac/dc
0–30 Vdc
10
Maximum load current—
0–13A
4A per port
10
Enclosure ratings—
Enclosure ratings—
NEMA 6P, IP68
IP65
Approvals
Approvals
UL®
cUL®
CSA®
cUL
10
10
10
10
10
10
10
10
V8-T10-2
Sensor Connectivity
10.1
Contents
Description
Product Selection
Single Connector Cables . . . . . . . . . . . . . . .
Double Connector Cables . . . . . . . . . . . . . .
Receptacles—Micro and Mini . . . . . . . . . . .
Page
10
V8-T10-4
V8-T10-4
10
V8-T10-5
V8-T10-8
V8-T10-9
V8-T10-9
V8-T10-10
V8-T10-10
V8-T10-11
10
10
10
10
10
10
10
10
10
Product Description
with high quality connector
cables from Eaton’s Electrical
is designed to give you
everything you want without
you don’t want. It includes
a wide variety of single- and
double-connector cables.
Custom lengths are available
upon request from the factory.
UL Recognized
(Mini-Style)
CSA Certified
(Mini- and Nano-Styles)
cUL Recognized
(Micro- and Nano-Styles)
10
DANGER
10
THIS SENSOR IS NOT A
SAFETY DEVICE AND IS NOT
INTENDED TO BE USED AS A
SAFETY DEVICE. This sensor
is designed only to detect
and read certain data in an
electronic manner and
perform no use apart from
that, specifically no safetyrelated use. This sensor
product does not include
self-checking redundant
circuitry, and the failure of
this sensor product could
cause either an energized
or de-energized output
condition, which could result
in death, serious bodily
injury, or property damage.
10
10
10
10
10
10
10
10
10
10
10
10
10
10
10
For the most current information
on this product, visit our Web site:
www.eaton.com
V8-T10-3
10
10
10.1
10
10
10
10
Sensor Connectivity
What Type of Connector Cable Do You Need?
The majority of the sensors in this Product Guide are available with connectors for quick-disconnect installation.
Global Plus Connector Cable Selection
Sensor
Connector Cable Type
Style
Interfaces with …
Single-Connector Cable
Style
Junction Box or Control Panel
Micro
(see Page V8-T10-5)
10
For hard-wiring into a typical junction box
or control panel.
Mini
(see Page V8-T10-6)
10
Nano
(see Page V8-T10-7)
10
Double-Connector Cable
Connectorized Junction Box or Control Panel
10
Micro
(see Page V8-T10-8)
10
Mini
(see Page V8-T10-8)
10
Multi-Connector Block with Cable
Micro
(see Page V8-T10-8)
10
For connecting to a junction box or control panel
that has a receptacle connector interface.
Allows up to eight sensors to be consolidated into Micro (see Page V8-T10-8)
one cable for wiring to your control system
10
10
10
Global Plus Connector Cables 1
10
CS D S 4 A 4 C Y 22 02 - D
10
10
Product
CS = Cordset
10
Electrical Version/Connector Type
D = Euro (micro) connector
A = AC micro-connector
M = AC/DC mini-connector
N = DC nano (pico) connector
10
10
10
Pin Configuration
2 = 2-pin
5 = 5-pin
3 = 3-pin
9 = 9-pin
4 = 4-pin
10
10
Wire Gauge
24 = 24 AWG
22 = 22 AWG
16 = 16 AWG
Wire Color Code
A = IEC color code
F = North American color code
D = Industrial color code
10
10
Wire Configuration
2 = 2-wire
5 = 5-wire
3 = 3-wire
9 = 9-wire
4 = 4-wire
10
10
10
Cable Length
01 = 1 meter (3.2 ft)
01.5 = 1.5 meters (4.9 ft)
02 = 2 meters (6.5 ft)
03 = 3 meters (9.8 ft)
04 = 4 meters (13 ft)
05 = 5 meters (16.4 ft)
10 = 10 meters (32.8 ft)
Connector Type
S = Straight
R = Right angle
10
10
Connector Type
D = Double-ended
LN = LED NPN
LP= LED PNP
Jacket Color
Y = Yellow
B = Black
Jacket Material
C = PVC
R = PUR
Note
1 This is a representative guide to the catalog numbering system. All possible combinations may not be available for ordering.
Please verify the number with the following pages or call Application Support at (800) 426-9194 before ordering.
V8-T10-4
10.1
Sensor Connectivity
Product Selection
10
Micro-Style
Straight Female
10
Micro-Style Straight Female
Voltage
Style
Number
of Pins
Gauge
Length
18 AWG
6.0 ft (2m)
Pin Configuration/Wire Colors
(Face View Female Shown)
PVC Jacket
Catalog Number
PUR Jacket
Catalog Number
CSAS3F3CY1802
3-pin,
3-wire
16.4 ft (5m)
22 AWG
4-pin,
4-wire
1-Green
2-Red/Black
3-Red/White
18 AWG
CSAS3F3CY1810
6.0 ft (2m)
CSAS3F3CY2202
CSAS3F3RY2202
16.4 ft (5m)
CSAS3F3CY2205
CSAS3F3RY2205
32.8 ft (10m)
CSAS3F3CY2210
CSAS3F3RY2210
CSAS4F4CY1802
CSAS4F4CY1805
1-Red/Black
2-Red/White
3-Red
4-Green
16.4 ft (5m)
32.8 ft (10m)
22 AWG
22 AWG
CSAS4F4CY1810
CSAS4F4CY2202
CSAS4F4RY2202
16.4 ft (5m)
CSAS4F4CY2205
CSAS4F4RY2205
32.8 ft (10m)
CSAS4F4CY2210
CSAS4F4RY2210
CSAS4A4CY2202
CSAS4A4CY2205
CSAS4A4CY2210
1-Brown
2-Blue
3-Gray
4-Black
5-White
CSAS5A5CY2202
CSAS5A5CY2205
CSAS5A5CY2210
1-Brown
2-No Wire
3-Blue
4-Black
CSDS4A3CY2202
CSDS4A3RY2202
CSDS4A3CY2205
CSDS4A3RY2205
CSDS4A3CY2210
CSDS4A3RY2210
1-Brown
2-White
3-Blue
4-Black
CSDS4A4CY2202
CSDS4A4RY2202
CSDS4A4CY2205
CSDS4A4RY2205
CSDS4A4CY2210
CSDS4A4RY2210
6.0 ft (2m)
1-Brown
2-Blue
3-Black
4-White
32.8 ft (10m)
22 AWG
4-pin,
3-wire
22 AWG
6.0 ft (2m)
16.4 ft (5m)
32.8 ft (10m)
DC
6.0 ft (2m)
16.4 ft (5m)
32.8 ft (10m)
4-pin,
4-wire
22 AWG
6.0 ft (2m)
16.4 ft (5m)
32.8 ft (10m)
5-pin,
5-wire
22 AWG
10
10
10
10
10
10
10
10
10
10
CSDS4A4CY2220
6.0 ft (2m)
CSDS5A5CY2202
CSDS5A5CY2205
CSDS5A5CY2210
CSDS8A8CB2405
10
CSDS8A8CB2410
10
1
16.4 ft (5m)
24 AWG
10
65.6 ft (20m)
16.4 ft (5m)
2
3
2
1
7
32.8 ft (10m)
1-Brown
2-White
3-Blue
4-Black
5-Green/Yellow
5
4
32.8 ft (10m)
8-pin,
8-wire
10
10
6.0 ft (2m)
16.4 ft (5m)
5-pin,
5-wire
10
CSAS3F3CY1805
32.8 ft (10m)
6.0 ft (2m)
10
10
Standard Cables
AC
10
3
8
4
6
5
1-White
2-Brown
3-Green
4-Yellow
5-Gray
6-Pink
7-Blue
8-Red
10
10
10
10
10
10
10
10
10
V8-T10-5
10.1
10
Micro-Style
Right Angle Female
10
10
Sensor Connectivity
Micro-Style Right Angle Female
Voltage
Style
Number
of Pins
PUR Jacket
Catalog Number
CSAR3F3CY1802
CSAR3F3CY1805
32.8 ft (10m)
CSAR3F3CY1810
6.0 ft (2m)
CSAR3F3CY2202
CSAR3F3RY2202
16.4 ft (5m)
CSAR3F3CY2205
CSAR3F3RY2205
32.8 ft (10m)
CSAR3F3CY2210
CSAR3F3RY2210
6.0 ft (2m)
CSAR4F4CY1802
CSAR4F4CY1805
CSAR4F4CY1810
6.0 ft (2m)
CSAR4F4CY2202
CSAR4F4RY2202
16.4 ft (5m)
CSAR4F4CY2205
CSAR4F4RY2205
32.8 ft (10m)
CSAR4F4CY2210
CSAR4F4RY2210
1-Brown
2-No Wire
3-Blue
4-Black
CSDR4A3CY2202
CSDR4A3RY2202
CSDR4A3CY2205
CSDR4A3RY2205
CSDR4A3CY2210
CSDR4A3RY2210
1-Brown
2-White
3-Blue
4-Black
CSDR4A4CY2202
CSDR4A4RY2202
CSDR4A4CY2205
CSDR4A4RY2205
CSDR4A4CY2210
CSDR4A4RY2210
1-Brown
2-White
3-Blue
4-Black
5-Green/Yellow
CSDR5A5CY2202
CSDR5A5CY2205
CSDR5A5CY2210
Length
18 AWG
6.0 ft (2m)
Standard Cables
AC
10
3-pin,
3-wire
10
22 AWG
10
4-pin,
4-wire
1-Green
2-Red/Black
3-Red/White
16.4 ft (5m)
10
18 AWG
1-Red/Black
2-Red/White
3-Red
4-Green
16.4 ft (5m)
10
32.8 ft (10m)
22 AWG
10
10
DC
10
4-pin,
3-wire
22 AWG
6.0 ft (2m)
16.4 ft (5m)
32.8 ft (10m)
10
4-pin,
4-wire
22 AWG
6.0 ft (2m)
16.4 ft (5m)
10
32.8 ft (10m)
5-pin,
5-wire
10
22 AWG
6.0 ft (2m)
16.4 ft (5m)
10
32.8 ft (10m)
10
10
PVC Jacket
Catalog Number
Gauge
Mini-Style
Straight Female
1
2
5
4
3
Mini-Style Straight Female
Current Rating
at 600V
Voltage
Style
Number
of Pins
Gauge
Length
2-pin,
2-wire
16 AWG
6 ft (2m)
3-pin,
3-wire
16 AWG
4-pin,
4-wire
16 AWG
Catalog Number
10
10
Standard Cables
13A
10
10
13A
AC/DC
12 ft (4m)
12 ft (4m)
10
10A
10
6 ft (2m)
6 ft (2m)
12 ft (4m)
10
10
10
10
10
10
10
V8-T10-6
CSMS2D2CY1602
1-White
2-Black
1-Green
2-Black
3-White
1-Black
2-White
3-Red
4-Green
CSMS2D2CY1604
CSMS3F3CY1602
CSMS3F3CY1604
CSMS4F4CY1602
CSMS4F4CY1604
10.1
Sensor Connectivity
Mini-Style
Straight Female
Mini-Style Straight Female, continued
Current Rating
at 600V
Voltage
Style
Number
of Pins
Gauge
Length
4-pin,
4-wire
16 AWG
6 ft (2m)
5-pin,
5-wire
16 AWG
5-pin,
5-wire
16 AWG
10
Catalog Number
10
Standard Cables
10A
10
AC/DC
13.12 ft (4m)
19.69 ft (6m)
8A
8A
6 ft (2m)
12 ft (4m)
6 ft (2m)
13.12 ft (4m)
19.69 ft (6m)
7A
9-pin,
9-wire
16 AWG
6 ft (2m)
1-Black
2-Blue
3-Brown
4-White
CSMS4A4CY1602
1-White
2-Red
3-Green
4-Orange
5-Black
CSMS5D5CY1602
CSMS5D5CY1604
10
1-Black
2-Blue
3-Orange
4-Brown
5-White
CSMS5A5CY1602
10
1-Orange
2-Blue
3-Red/Black
4-Green/Black
5-White
6-Red
7-Green
8-White/Black
9-Black
CSMS9D9CY1602
CSMS4A4CY1604
CSMS4A4CY1606
CSMS5A5CY1604
CSMS5A5CY1606
10
10
10
10
10
10
10
Nano-Style
Straight Female
10
Nano-Style Straight Female
Voltage
Style
Number
of Pins
Gauge
Length
PVC Jacket
Catalog Number
PUR Jacket
Catalog Number
10
Standard Cables
3-pin,
3-wire
24 AWG
4-pin,
4-wire
24 AWG
6.0 ft (2m)
1-Brown
3-Blue
4-Black
16.4 ft (5m)
32.8 ft (10m)
DC
6.5 ft (2m)
16.4 ft (5m)
32.8 ft (10m)
Nano-Style
Right Angle Female
CSNS3A3CY2402
CSNS3A3RY2402
CSNS3A3CY2405
CSNS3A3RY2405
CSNS3A3CY2410
CSNS3A3RY2410
1-Brown
2-White
3-Blue
4-Black
CSNS4A4CY2402
CSNS4A4CY2405
CSNS4A4CY2410
PVC Jacket
Catalog Number
PUR Jacket
Catalog Number
4 2
3
1
Number
of Pins
Gauge
10
10
10
10
10
Nano-Style Right Angle Female
Voltage
Style
10
Length
10
10
Standard Cables
3-pin,
3-wire
24 AWG
6.0 ft (2m)
16.4 ft (5m)
32.8 ft (10m)
1-Brown
3-Blue
4-Black
CSNR3A3CY2402
CSNR3A3RY2402
CSNR3A3CY2405
CSNR3A3RY2405
CSNR3A3CY2410
CSNR3A3RY2410
10
10
10
10
10
10
10
10
V8-T10-7
10.1
Sensor Connectivity
10
10
Micro-Style
Straight Female/Male
10
10
Micro-Style Straight Female/Male
Voltage
Style
Number
of Pins
Gauge
Length
4-pin
22 AWG
3.0 ft (1m)
Catalog Number
Standard Cables
DC
10
5.0 ft (1.5m)
Face View
Female
Face View
Male
CSDS4A4CY2201-D
CSDS4A4CY2201.5-D
10
6.0 ft (2m)
CSDS4A4CY2202-D
10.0 ft (3m)
CSDS4A4CY2203-D
10
16.4 ft (5m)
DC
5-pin
22 AWG
10
10
3.0 ft (1m)
CSDS4A4CY2205-D
Face View
Female
Face View
Male
CSDS5A5CY2201-D
10.0 ft (3m)
CSDS5A5CY2203-D
16.4 ft (5m)
CSDS5A5CY2205-D
10
10
10
Micro-Style
Straight Female/
Right Angle Male
10
Micro-Style Straight Female/Right Angle Male
Voltage
Style
Number
of Pins
Gauge
Length
4-pin
22 AWG
3.0 ft (1m)
Catalog Number
Standard Cables
DC
10
5.0 ft (1.5m)
10
10
Face View
Male
CSDR4A4CY2201-D
CSDR4A4CY2201.5-D
6.0 ft (2m)
CSDR4A4CY2202-D
10.0 ft (3m)
CSDR4A4CY2203-D
16.4 ft (5m)
CSDR4A4CY2205-D
10
10
10
10
10
10
10
10
10
10
10
10
10
10
V8-T10-8
Face View
Female
10.1
Sensor Connectivity
Micro-Style
Straight Male
10
Micro and Mini
Voltage
Style
Number
of Pins
Gauge
Length
Mounting
Hole Size
4-pin,
4-wire
22 AWG
1.0 ft (0.3m)
1/2 in NPT
5-pin,
5-wire
22 AWG
1.6 ft (0.5m)
PG9
10
Pin Configuration
Catalog Number
10
1-Brown
2-White
3-Blue
4-Black
CSDS4A4CMR22.3
10
1-Brown
2-White
3-Blue
4-Black
5-Gray
CSDS5A5CMR.5
1-Brown
2-White
3-Blue
4-Black
CSMS4A4CMR16.5
Standard Cables—Micro
DC
Mini-Style
Straight Male
10
10
10
Standard Cables—Mini
AC/DC
4-pin,
4-wire
22 AWG
1.6 ft (0.5m)
1/2 in NPT
10
10
10
10
10
Accessories
Global Plus Accessories
Field Wireable,
Plastic
Description
Catalog Number
Micro female style, straight, four-position
CSDS4
Micro female style, right angle, four-position
CSDR4
Micro male style, straight, four-position
CSDSM4
Micro male style, right angle, four-position
CSDRM4
Nano female style, straight, three-position
CSNS3
Nano male style, straight, three-position
CSNSM3
Nano male style, straight, four-position
CSNSM4
Nano female style, straight, four-position
CSNS4
Nano female style, right angle, four-position
CSNR4
Micro female style, y-splitter, three-position
CSDY3 1
Micro female style, y-splitter, five-position
CSDY5 1
10
10
10
10
10
10
10
10
Closure Cap
Closure Cap
Seals off unused connector ports on multi-connector blocks, micro female type
CBCAP
10
Seals off unused parts on micro, male type
CBMCAP
10
Bulk Cable, Micro-Style
Bulk Cable,
Micro-Style
Four-conductor, 22 AWG, yellow jacket (blue, brown, white, black),
compatible with micro-style field wireable connectors shown above
10
CS4ACY22XX 2
10
10
Bulk Cable, Nano-Style
Bulk Cable, Nano Style
Three-conductor, 24 AWG, yellow jacket (brown, blue, black),
compatible with field wireable connectors shown above
CS3ACY24XX
10
1
10
10
Notes
1 For wiring diagrams explaining the difference between three- and five-position models,
see Wiring Diagrams on Page V8-T10-10.
2 Quantity ordered indicates length (for example, quantity of 5 equals 5 ft).
10
10
V8-T10-9
10.1
Sensor Connectivity
10
10
10
Description
Micro-Style
Specification
Mini-Style
Specification
Nano-Style
Specification
Jacket material
PVC/PUR/Irradiated PUR 1
PVC
PVC/PUR 1
10
Contact material
Gold-plated copper alloy
Gold-plated brass
Coupling nut material
Nickel-plated die-cast zinc
O-ring
Nitrile rubber
None
Nitrile rubber
Cable
PVC/PUR/Irradiated PUR, insulation and jacket,
stranded copper conductors
10
10
10
10
10
Cable strain relief
35 lbs minimum
35 lbs minimum
35 lbs minimum
Voltage rating
320V
(24 Vdc for LED plugs)
(30 Vdc for 8-pin, versions)
600V
100 Vdc
Current rating
4A
See model selection chart
4A
Contact resistance
5M ohms maximum
5M ohms maximum
5M ohms maximum
10
Isolation resistance
1000M ohms minimum
1000M ohms minimum
1000M ohms minimum
Protection
IP67
NEMA 6P, IP68
IP67
10
Temperature range
–13° to 176°F (–25° to 80°C)
–4° to 221°F (–20° to 105°C)
Cable diameter
See Dimensions on Page V8-T10-11.
Bend radius
Minimum recommended bend
radius is 12X cable diameter
10
10
10
10
Wiring Diagrams
CSDY3
CSDY5
1
1
1
1
10
2
2
2
2
3
3
3
3
10
4
4
4
4
5
5
5
5
10
1
2
3
4
5
1
2
3
4
5
10
10
Note
1 Jacket material dependent upon model selection.
10
10
10
10
10
10
10
10
10
10
V8-T10-10
10.1
Sensor Connectivity
Dimensions
Approximate Dimensions in Inches (mm)
10
Single Connector Cable Dimensions
10
Micro-Style Single Connector Cables, Straight Female
Length
1.77" Ref
(45.0 mm)
Micro-Style Single Connector Cables, Right Angle Female
Length
1.10" Ref
(28.0 mm)
2.16" Ref
(54.8 mm)
2.16" Ref
(54.8 mm)
M12 x 1 (DC)
M12 x 1 (DC)
1/2" - 20 UNF–2B (AC)
10
10
0.58" Dia. Ref
(14.8 mm)
Mini-Style Single Connector Cables,
2-, 3-, 4- and 5-pin, Versions
10
10
0.978" Ref
(24.8 mm)
0.58" Dia. Ref
(14.8 mm)
10
10
10
9-pin, Version
10
LENGTH
10
2.25”REF
[57.15mm]
2.79”REF
[70.87mm]
10
10
Ø1.25”REF
[31.75mm]
10
.38”REF
[9.65mm]
Ø.81”REF
[20.57mm]
10
7/8”–16 UN–2B
Nano-Style Single Connector Cables, Straight Female
10
Length
Length
1.56
(39.50)
Ref.
10
Right Angle Female (Standard and LED)
.75
(19.05)
Ref.
1.10
(27.90)
Ref.
.75
(19.05)
Ref.
10
10
Dia. .39
(10) Ref.
M8x1
.16
(4.06)
Ref.
.78
(19.70)
Ref.
M8x1
10
.16
(4.06)
Ref.
10
10
Dia. .39
(10) Ref.
10
10
10
10
10
10
10
10
V8-T10-11
10.1
10
10
10
10
Double Connector Cable Dimensions
Micro-Style Double Connector Cables,
Length
10
10
Sensor Connectivity
Length
1.77" Ref
(45.0 mm)
1.77" Ref
(45.0 mm)
M12 x 1 (DC)
1.10" Ref
(28.0 mm)
M12 x 1 (DC)
0.58"
(14.8 mm)
Dia. Ref
0.58"
(14.8 mm)
Dia. Ref
10
M12 x 1 (DC)
0.58"
(14.8 mm)
Dia. Ref
10
10
10
10
10
10
10
Receptacle Dimensions
Micro-Style Receptacles, Straight Male
(1/2 in NPT Mounting)
1.00" Ref
(25.4 mm)
PG9
10
Pin 2
(White)
0.47" Ref
(11.94 mm)
1/2-14 NPT
10
M12x1
10
Pin 5
(Green/
Yellow)
Pin 1
(Brown)
Pin 3 Male
(Blue)
Pin 4
(Black)
19.7
(500)
10
Mini-Style Receptacles, Straight Male
1.03" Ref
(26.162 mm)
6.00"
(152.4 mm)
Key
Pin 1
(Black)
0.345" Ref
(8.763 mm)
Pin 4
(White)
10
10
7/8-16
1/2-14 NPT
10
Pin 2 Male Pin 3
(Blue)
(Brown)
10
10
10
10
10
10
10
V8-T10-12
0.04 Pin 2 Key Pin 1
(1) (White)
(Brown)
Key
10
10
M12x1
Dia. 1.00" Ref
(25.4 mm)
12.00"
(304.8 mm)
0.25"
(6.35 mm)
(PG9 Mounting)
0.98
(25)
0.39 (10)
0.47 (12)
Pin 3 Male Pin 4
(Blue)
(Black)
Sensor Connectivity
10.2
Contents
Description
Page
V8-T10-14
V8-T10-14
V8-T10-14
V8-T10-15
V8-T10-15
10
10
10
10
10
10
10
10
10
10
10
Product Description
Features
The Multi-Connector Block
from Eaton’s Electrical Sector
is an easy way to quickly
connect sensors to a control
system. Using a variety of
double-ended, industrystandard M12 microconnector cables, a system
can be wired up in minutes,
therefore saving installation
time and money.
Typical Applications
Automotive manufacturing
Metalworking
Many types of Machinery
OEMs
Power Control and Panel
Shops
For further convenience and
installation troubleshooting,
LEDs provide both power and
output status on the block.
Global Plus Multi-Connector
Blocks were designed with
the most heavy-duty
applications in mind—such as
automotive manufacturing,
metalworking and machinery
OEMs. Put Eaton’s Global
Plus Multi-Connector Blocks
to the test for your next
machine design.
Model options with four,
six or eight sensor ports in
one block
Block capacity can be
doubled with Micro Splitter
Accessory (CSDY5)
Capacity of up to 4A per
port and 12A per block
Robust design to resist
vibration and moisture
penetration
Ideal for extreme
temperature environments
from –13° to 167°F
(–25° to 75°C)
UL Recognized
CSA Certified
10
10
10
10
10
DANGER
10
10
10
10
10
10
10
10
10
10
10
10
www.eaton.com
V8-T10-13
10
10
10.2
Sensor Connectivity
10
Product Selection
10
10
Micro-Style
Molded Cable
Micro-Style Molded Cable
10
Voltage
Style
Number
of Ports
DC PNP
4-port
10
10
10
Accessories
10
Closure Cap
Catalog Number
5m cable
See Wiring Diagrams on
Page V8-T10-15
CBDR4P05
10m cable
CBDR4P10
6-port
5m cable
CBDR6P05
10m cable
CBDR6P10
8-port
5m cable
CBDR8P05
10m cable
CBDR8P10
10
10
Connection
Closure Cap
10
10
Description
Catalog Number
Seals off unused connector ports on multiconnector blocks, micro female type
CBCAP
10
10
10
10
Master Cable—Pre-Wired Cable Connection
Specification
Description
Description
Specification
Signal line, stranded in mm2 (AWG)
0.34 (22)
3 x 1.0 (17)
10
General
Nominal voltage (Vdc)
24
Voltage supply, stranded in mm2 (AWG)
10
Maximum operating voltage (Vdc)
30
Cable diameter in mm [in]
Current capacity per port (A)
4
4- and 6-port
8.7 [0.3425]
Residual current (A)
12
8-port
9.2 [0.3622]
Operating current of each LED (mA)
≤5
Material
PUR
Protection type
(IEC 60 529 / EN 60 529 / DIN VDE 0470-1)
IP65
Cable strain relief
30 lbs. min.
Ambient temperature
–13° to 167°F (–25° to 75°C)
10
Jacket material
Nylon with brass receptacles
Contact material
10
O-ring
Nitrile rubber
10
Voltage rating
10–30 Vdc
Current rating
4A per port; 12A max. per unit
10
Contact resistance
5M ohms max.
1000M ohms min.
10
Protection
NEMA 6P, IP67
Temperature range
–13° to 194°F (–25° to 90°C)
10
10
10
10
LED Status Indication
10
Supply voltage
Green
Status display of I/O
Yellow
10
10
V8-T10-14
Sensor Connectivity
10.2
Wiring Diagrams
10
Micro-Style Connector Blocks
PNP Block
Main Power
(Green LED)
Port Status
(Yellow LED)
OV
1/4
2/4
6/4
4
4
3
1
3
1
3
3
6
UN
8/4
4
1
5
3
1
5
7
4-Port
6-Port
8-Port
Wire Color
Wire Color
Wire Color
1/4
WH
WH
WH
2/4
GN
GN
GN
Micro DC Port/pin,
4
1
5
2
1
7/4
4
5
5
10
Wiring Diagram for Molded Cable Blocks
8
3/4
YE
YE
YE
4/4
GY
GY
GY
5/4
PK
PK
6/4
RD
RD
7/4
BK
8/4
VT
1-8/1; UN (+V)
BN
BN
BN
1-8/3; 0V (-)
BU
BU
BU
1-8/5; PE (GND)
GN/YE
GN/YE
GN/YE
10
10
10
10
10
10
10
10
10
Dimensions
10
10
Four Sensor Ports
10
4.60 (116.9)
10
0.97
(24.5)
10
10
0.62 (15.8)
0.24 (6.0)
10
Ø0.17 (Ø4.2)
10
0.17 (4.2)
10
2.13
(54.0)
10
1.42
(36.0)
10
10
10
0.18 (4.5)
10
2.87 (73.0)
4.21 (107.0)
10
10
10
10
10
V8-T10-15
10.2
10
10
10
10
10
Sensor Connectivity
Six Sensor Ports
4.82 (122.5)
0.97
(24.5)
0.62 (15.8)
0.24 (6.0)
10
Ø0.17 (Ø4.2)
10
0.17 (4.2)
10
10
10
2.13
(54.0)
1.42
(36.0)
10
10
10
2.87 (73.0)
0.18 (4.5)
4.21 (107.0)
10
10
Eight Sensor Ports
5.85 (148.5)
10
10
10
10
0.97
(24.5)
0.62 (15.8)
0.24 (6.0)
10
Ø0.17 (Ø4.2)
0.17 (4.2)
10
10
10
10
2.13
(54.0)
1.42
(36.0)
10
10
10
0.18 (4.5)
2.87 (73.0)
4.21 (107.0)
10
10
10
V8-T10-16
