Type: DILM32−10(RDC24)
Article No.: 277274
Ordering information
Rated operational current AC−3 400 V
Ie
A
32
Max. rating for three−phase motors, 50 – 60 Hz AC−3
230 V
P
kW
10
400 V
P
kW
15
690 V
P
kW
17
Max. rating for three−phase motors, 50 – 60 Hz AC−4
230 V
P
kW
4
400 V
P
kW
7
690 V
P
kW
10
Ith = Ie
A
40
Conventional thermal current I th = I e AC−1 Open
DILM32−XHI..
DILA−XHI(V)..
For use with
General
Standards
IEC/EN 60947, VDE 0660, UL, CSA
Lifespan, mechanical
AC operated
Operations
× 106
10
DC operated
Operations
× 106
10
Operating frequency, mechanical
AC operated
Operations/h
5000
DC operated
Operations/h
5000
Climatic proofing
Ambient temperature
1
Damp heat, constant, to IEC 60068−2−78
Damp heat, cyclical, to IEC 60068−2−30
Open
°C
−25/60
Enclosed
°C
−25/40
Storage
°C
−40/80
Mechanical shock resistance (IEC/EN 60068−2−27)
Half−sinusoidal shock, 20 ms
Main contacts
Make contact
g
10
Make contact
g
7
Break contact
g
5
Auxiliary contacts
Protection type
IP00
Protection against direct contact when actuated from
front (IEC 536)
Finger− and back−of−hand proof
Weight
AC operated
kg
0,42
DC operated
kg
0,48
Terminal capacity Main cable
Solid
mm2
1 × (0.75 – 16)
2 × (0.75 – 10)
Flexible with ferrule
mm2
1 × (0.75 – 16)
2 × (0.75 – 10)
Stranded
mm2
1 × 16
Solid or stranded
AWG
18 – 6
Anschlussschraube Hauptleiter
Tightening torque
M5
Nm
3
Solid
mm2
1 × (0.75 – 4)
1 × (0.75 – 4)
mm2
1 × (0.75 – 2.5)
2 × (0.75 – 2.5)
Solid or stranded
AWG
18 – 14
Terminal capacity Control circuit cables
Anschlussschraube Hilfsleiter
Tightening torque
M3.5
Nm
1.2
Tool
Main cable
Pozidriv screwdriver
Standard screwdriver
Size
2
mm
0.8 × 5.5
1×6
Size
2
mm
0.8 × 5.5
1×6
Solid
mm2
0.75 – 2.5
Flexible
mm2
0.75 – 2.5
mm2
0.75 – 2.5
Solid or stranded
AWG
18 – 14
2
Tool
Stripping length
mm
10
Screwdriver blade width
mm
3,5
Main conducting paths
Rated impulse withstand voltage
Uimp
V AC
Overvoltage category/pollution degree
8000
III/3
Rated insulation voltage
AC
Ui
V AC
690
Rated operational voltage
Ue
V AC
690
between coil and contacts
V AC
440
between the contacts
V AC
440
A
384
A
320
Safe isolation to VDE 0106 Part 101 and Part 101/A1
Making capacity (cos Õ to IEC/EN 60947) up to 690
V
Breaking capacity
220/230 V
380/400 V
A
320
500 V
A
320
660/690 V
A
180
Component lifespan
AC−3/AC−4
Tripping characteristics
Maximum operating frequency
AC−1; 400 V
Ie
Ops/h
800
AC−3; 400 V
Ie
Ops/h
800
AC−4; 400 V
Ie
Ops/h
300
400 V
gG/gL 500 V
A
63
690 V
gG/gL 690 V
A
35
400 V
gG/gL 500 V
A
125
690 V
gG/gL 690 V
A
63
at 40 °C
Ith
A
45
at 50 °C
Ith
A
43
at 55 °C
Ith
A
42
at 60 °C
Ith
A
40
Enclosed
Ith
A
36
Ith
A
85
Short−circuit rating
Short−circuit protection Maximum fuse
Type “2” coordination
Type “1” coordination
AC
AC−1 duty
conv. therm. current 3−pole 50 – 60 Hz
open
Conventional free air thermal current, 1−pole
open
3
Enclosed
Ith
A
80
220/230 V
Ie
A
32
240 V
Ie
A
32
380/400 V
Ie
A
32
415 V
Ie
A
32
440V
Ie
A
32
500 V
Ie
A
32
660/690 V
Ie
A
18
220/230 V
P
kW
10
240V
P
kW
8,5
380/400 V
P
kW
15
415 V
P
kW
14,5
440 V
P
kW
17
500 V
P
kW
17,5
660/690 V
P
kW
17
220/230 V
Ie
A
15
240 V
Ie
A
15
380/400 V
Ie
A
15
415 V
Ie
A
15
440 V
Ie
A
15
500 V
Ie
A
15
660/690 V
Ie
A
12
220/230 V
P
kW
4
240 V
P
kW
4,5
380/400 V
P
kW
7
415 V
P
kW
7,5
440 V
P
kW
8
500 V
P
kW
9
660/690 V
P
kW
10
60 V
Ie
A
40
110 V
Ie
A
40
220 V
Ie
A
40
440 V
Ie
A
2,9
60 V
Ie
A
40
110 V
Ie
A
40
AC−3 duty
Rated operational current AC−3 open, 50 – 60 Hz,
3−pole
Motor rating
AC−4 duty
Rated operational current AC−4 open, 50 – 60 Hz,
3−pole
Motor rating
DC
of three−phase capacitors open
DC−1 operation
DC−3 operation
4
220 V
Ie
A
25
440 V
Ie
A
0,6
60 V
Ie
A
40
110 V
Ie
A
40
220 V
Ie
A
25
440 V
Ie
A
0,6
W
12,1
Current heat loss at Ie to AC−3/400 V
W
6,1
Impedance per pole
m&
2
Pick−up
× Uc
0,8 – 1,1
Abfall
× Uc
0,3 – 0,6
Pick−up
× Uc
0,7 – 1,2
Abfall
× Uc
0,15–0,6
50 Hz
Pick−up
VA
50
50 Hz
Pick−up
W
40
50 Hz
Sealing
VA
8
DC−5 operation
Current heat loss (3−pole)
Current heat loss at Ith
Magnet systems
Voltage tolerance
AC operated
AC operated
Drop−out voltage AC operated
DC operated
DC operated
DC operated
DC operated
Power consumption of the coil in a cold state and 1.0
× Uc
50 Hz
Sealing
W
2,4
60 Hz
Pick−up
VA
62
60 Hz
Pick−up
W
50
60 Hz
Sealing
60 Hz
Sealing
VA
2,7
50/60 Hz
Pick−up
VA
60
54
50/60 Hz
Pick−up
W
48
43
50/60 Hz
Sealing
VA
9,5
7,9
50/60 Hz
Sealing
W
2,8
2,4
DC operated
Pick−up
W
12 at 24 V
DC operated
Sealing
W
0.5 at 24 V
Duty factor
9,1
% DF
100
Closing delay
ms
25
Opening delay
ms
25
Switching times at 100 % Uc (approximate values)
Main contacts
AC operated
5
DC operated
Closing delay
ms
60
Opening delay
ms
15
Arcing time
ms
10
Electromagnetic compatibility (EMC)
Emitted interference
to EN 60947−1
Interference immunity
to EN 60947−1
Mounting position, AC− and DC operated
Moeller GmbH, Hein−Moeller−Str. 7−11, D−53115 Bonn
E−Mail: catalog@moeller.net, Internet: www.moeller.net, http://catalog.moeller.net
Copyright 2005 by Moeller GmbH. Subject to modifications. HPL−C2005GB−INT V3.0
6
