DILMP45-10(230V50HZ,240V60HZ)
    EATON(伊顿)
    EATON MOELLER - DILMP45-10(230V50HZ,240V60HZ) - Relay Contactor, DILMP Series, 4PST-NO, 4P, 15 A, 14...
DILMP45-10(230V50HZ,240V60HZ) 数据手册
DATASHEET - DILMP45-10(230V50HZ,240V60HZ) Contactor, 4 pole, 45 A, 1 N/O, 230 V 50 Hz, 240 V 60 Hz, AC operation Delivery program Part no.  Catalog No.  Alternate Catalog No.  EL-Nummer (Norway)  DILMP45-10(230V50HZ,240V60HZ) 109826 XTCF045C10F 4130405 Product range     Contactors Application     Contactors for 4 pole electric consumers Subrange     Contactors up to 200 A, 4 pole Utilization category     AC-1: Non-inductive or slightly inductive loads, resistance furnaces NAC-3: Normal AC induction motors: starting, switch off during running Connection technique     Screw terminals Number of poles     4 pole Rated operational current                   at 40 °C Ith =Ie A 45 at 50 °C Ith =Ie A 41 at 55 °C Ith =Ie A 40 at 60 °C Ith =Ie A 39           1 N/O Contact sequence     For use with     DILM32-XHI(C)… DILA-XHI(V)(C)… Actuating voltage     230 V 50 Hz, 240 V 60 Hz Voltage AC/DC     AC operation Connection to SmartWire-DT     no Instructions     Contacts to EN 50 012. Standards     IEC/EN 60947, VDE 0660, UL, CSA Lifespan, mechanical     AC-1 Conventional free air thermal current, 3 pole, 50 - 60 Hz Contacts N/O = Normally open Technical data General AC operated Operations DC operated Operating frequency, mechanical   x 10 6 10 Operations x 10 6 10       AC operated Operations/h   5000 DC operated Operations/h   5000 Climatic proofing     Damp heat, constant, to IEC 60068-2-3 Damp heat, cyclic, to IEC 60068-2-30 Ambient temperature       Open   °C -25 - +60 Enclosed   °C - 25 - 40 Storage   °C - 40 - 80 Mounting position       07/10/2020 Eaton 109826 ED2020 V70.0 EN 1 / 11 Mounting position Mechanical shock resistance (IEC/EN 60068-2-27) Half-sinusoidal shock, 10 ms Main contacts                       N/O contact   g 10 Auxiliary contacts       N/O contact   g 7 N/C contact   g 5 Degree of Protection     IP00 Altitude   m Max. 2000 Protection against direct contact when actuated from front (EN 50274)     Finger and back-of-hand proof Stripping length   mm 10 Terminal capacity main cable       Solid   mm Flexible with ferrule   mm Stranded   Solid or stranded Terminal screw 2 1 x (0.75 - 16) 2 x (0.75 - 10) 2 1 x (0.75 - 16) 2 x (0.75 - 10) mm 2 1 x 16   AWG 18 - 6     M5 Tightening torque   Nm 3 Stripping length   mm 10       Terminal capacity control circuit cables Solid   mm Flexible with ferrule   mm 1 x (0.75 - 2.5) 2 x (0.75 - 2.5) Solid or stranded   AWG 18 - 14 Stripping length   mm 10 Terminal screw     M3.5 Tightening torque   Nm 1.2       Tool Main cable 2 1 x (0.75 - 4) 2 x (0.75 - 2.5) 2       Pozidriv screwdriver   Size 2 Standard screwdriver   mm 0.8 x 5.5 1x6 Control circuit cables       Pozidriv screwdriver   Size 2 Standard screwdriver   mm 0.8 x 5.5 1x6 Rated impulse withstand voltage Uimp V AC 8000 Overvoltage category/pollution degree     III/3 Rated insulation voltage Ui V AC 690 Rated operational voltage Ue V AC 690 Safe isolation to EN 61140 Main conducting paths       between coil and contacts   V AC 440 between the contacts   V AC 440 Making capacity (cos ϕ) Up to 690 V A 350 According to IEC/EN 60947 Breaking capacity       220 V 230 V   A 250 380 V 400 V   A 250 07/10/2020 Eaton 109826 ED2020 V70.0 EN 2 / 11 500 V   A 250 660 V 690 V   A 144 Short-circuit rating             Short-circuit protection maximum fuse Type “2” coordination       400 V gG/gL 500 V A 35 690 V gG/gL 690 V A 35       400 V gG/gL 500 V A 100 690 V gG/gL 690 V A 50                   Type “1” coordination AC AC-1 Rated operational current Conventional free air thermal current, 3 pole, 50 - 60 Hz Open       at 40 °C Ith =Ie A 45 at 50 °C Ith =Ie A 41 at 55 °C Ith =Ie A 40 at 60 °C Ith =Ie A 39 Ith A 36 enclosed Conventional free air thermal current, 1 pole       open Ith A 117 enclosed Ith A 105 Motor rating P kWh   220/230 V P kW 16 240 V P kW 18 380/400 V P kW 28 415 V P kW 31 440 V P kW 33 500 V P kW 37 690 V P kW 49             AC-3 Rated operational current Open, 3-pole: 50 – 60 Hz       Notes     At maximum permissible ambient temperature (open.) 220 V 230 V Ie A 25 240 V Ie A 25 380 V 400 V Ie A 25 415 V Ie A 25 440V Ie A 25 500 V Ie A 25 660 V 690 V Ie A 15 P kWh   220 V 230 V P kW 7.5 240V P kW 8.5 380 V 400 V P kW 11 415 V P kW 14.5 440 V P kW 15.5 500 V P kW 17.5 660 V 690 V P kW 14             Ie A 45 Motor rating DC Rated operational current, open DC-1 60 V 07/10/2020 Eaton 109826 ED2020 V70.0 EN 3 / 11 110 V Ie A 45 220 V Ie A 45 3 pole, at Ith (60°)   W 13.2 Impedance per pole   mΩ 2.7 Voltage tolerance Current heat loss Magnet systems       AC operated 50 Hz Pick-up x Uc 0.8 - 1.1 AC operated 50/60 Hz   x Uc 0.85 - 1.1 Drop-out voltage AC operated Drop-out x Uc 0.4 - 0.6       AC operated 50/60 Hz Pick-up VA 50 AC operated 50/60 Hz Pick-up W 40 AC operated 50/60 Hz Sealing VA 8 AC operated 50/60 Hz Power consumption of the coil in a cold state and 1.0 x US Sealing W 2.1 Duty factor   % DF 100 Changeover time at 100 % US (recommended value)                   Closing delay   ms 16 - 22 Opening delay   ms 8 - 14 Permissible residual current with actuation of A1 - A2 by the electronics (with   0 signal). mA ≦1             Three-phase       200 V 208 V   HP 7.5 230 V 240 V   HP 10 460 V 480 V   HP 15 575 V 600 V   HP 20 Single-phase       115 V 120 V   HP 2 230 V 240 V   HP 5 General use   A 40 Auxiliary contacts       Pilot Duty       AC operated     A600 DC operated     P300       AC   V 600 AC   A 10 DC   V 250 DC   A 1 Main contacts AC operated Rating data for approved types Switching capacity Maximum motor rating General Use Short Circuit Current Rating   SCCR   Basic Rating       SCCR   kA 5 max. Fuse   A 125 max. CB   A 125 480 V High Fault       SCCR (fuse)   kA 10/100 max. Fuse   A 125/70 Class J 07/10/2020 Eaton 109826 ED2020 V70.0 EN 4 / 11 SCCR (CB)   kA 10/65 max. CB   A 50/32 600 V High Fault       SCCR (fuse)   kA 10/100 max. Fuse   A 125/100 Class J SCCR (CB)   kA 10/22 max. CB   A 50/32             480V 60Hz 3phase, 277V 60Hz 1phase   A 40 600V 60Hz 3phase, 347V 60Hz 1phase   A 40 Special Purpose Ratings Electrical Discharge Lamps (Ballast) Incandescent Lamps (Tungsten)       480V 60Hz 3phase, 277V 60Hz 1phase   A 40 600V 60Hz 3phase, 347V 60Hz 1phase   A 40       480V 60Hz 3phase, 277V 60Hz 1phase   A 40 600V 60Hz 3phase, 347V 60Hz 1phase   A 40       LRA 480V 60Hz 3phase   A 240 FLA 480V 60Hz 3phase   A 40 LRA 600V 60Hz 3phase   A 180 FLA 600V 60Hz 3phase   A 30       LRA 480V 60Hz 3phase   A 150 FLA 480V 60Hz 3phase   A 25       200V 60Hz 3phase   HP 3 200V 60Hz 3phase   A 11 240V 60Hz 3phase   HP 5 240V 60Hz 3phase   A 15.2 480V 60Hz 3phase   HP 10 480V 60Hz 3phase   A 14 600V 60Hz 3phase   HP 15 600V 60Hz 3phase   A 17       Rated operational current for specified heat dissipation In A 45 Heat dissipation per pole, current-dependent Pvid W 4.4 Equipment heat dissipation, current-dependent Pvid W 13.2 Static heat dissipation, non-current-dependent Pvs W 2.1 Heat dissipation capacity Pdiss W 0 Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 60 Resistance Air Heating Refrigeration Control (CSA only) Definite Purpose Ratings (100,000 cycles acc. to UL 1995) Elevator Control Design verification as per IEC/EN 61439 Technical data for design verification IEC/EN 61439 design verification       10.2 Strength of materials and parts       10.2.2 Corrosion resistance     Meets the product standard's requirements. 10.2.3.1 Verification of thermal stability of enclosures     Meets the product standard's requirements. 10.2.3.2 Verification of resistance of insulating materials to normal heat     Meets the product standard's requirements. 10.2.3.3 Verification of resistance of insulating materials to abnormal heat and fire due to internal electric effects     Meets the product standard's requirements. 10.2.4 Resistance to ultra-violet (UV) radiation     Meets the product standard's requirements. 10.2.5 Lifting     Does not apply, since the entire switchgear needs to be evaluated. 10.2.6 Mechanical impact     Does not apply, since the entire switchgear needs to be evaluated. 10.2.7 Inscriptions     Meets the product standard's requirements. 07/10/2020 Eaton 109826 ED2020 V70.0 EN 5 / 11 10.3 Degree of protection of ASSEMBLIES     Does not apply, since the entire switchgear needs to be evaluated. 10.4 Clearances and creepage distances     Meets the product standard's requirements. 10.5 Protection against electric shock     Does not apply, since the entire switchgear needs to be evaluated. 10.6 Incorporation of switching devices and components     Does not apply, since the entire switchgear needs to be evaluated. 10.7 Internal electrical circuits and connections     Is the panel builder's responsibility. 10.8 Connections for external conductors     Is the panel builder's responsibility. 10.9 Insulation properties       10.9.2 Power-frequency electric strength     Is the panel builder's responsibility. 10.9.3 Impulse withstand voltage     Is the panel builder's responsibility. 10.9.4 Testing of enclosures made of insulating material     Is the panel builder's responsibility. 10.10 Temperature rise     The panel builder is responsible for the temperature rise calculation. Eaton will provide heat dissipation data for the devices. 10.11 Short-circuit rating     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.12 Electromagnetic compatibility     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.13 Mechanical function     The device meets the requirements, provided the information in the instruction leaflet (IL) is observed. Technical data ETIM 7.0 Low-voltage industrial components (EG000017) / Power contactor, AC switching (EC000066) Electric engineering, automation, process control engineering / Low-voltage switch technology / Contactor (LV) / Power contactor, AC switching (ecl@ss10.0.1-27-37-10-03 [AAB718015]) Rated control supply voltage Us at AC 50HZ   V 230 - 230 Rated control supply voltage Us at AC 60HZ   V 240 - 240 Rated control supply voltage Us at DC   V 0-0 Voltage type for actuating     AC Rated operation current Ie at AC-1, 400 V   A 45 Rated operation current Ie at AC-3, 400 V   A 25 Rated operation power at AC-3, 400 V   kW 11 Rated operation current Ie at AC-4, 400 V   A 15 Rated operation power at AC-4, 400 V   kW 7 Rated operation power NEMA   kW 11 Modular version     No Number of auxiliary contacts as normally open contact     1 Number of auxiliary contacts as normally closed contact     0 Type of electrical connection of main circuit     Screw connection Number of normally closed contacts as main contact     0 Number of main contacts as normally open contact     4 Product Standards     IEC/EN 60947-4-1; UL 60947-4-1; CSA - C22.2 No. 60947-4-1-14; CE marking UL File No.     E29096 UL Category Control No.     NLDX CSA File No.     012528 CSA Class No.     2411-03, 3211-04 North America Certification     UL listed, CSA certified Specially designed for North America     No 07/10/2020 Eaton 109826 ED2020 V70.0 EN Approvals 6 / 11 Characteristics 1: Auxiliary contact module 2: Suppressor 07/10/2020 Eaton 109826 ED2020 V70.0 EN 7 / 11 Switching conditions for 4 pole, non-motor loads Operating characteristics Non inductive and slightly inductive loads Electrical characteristics Switch on: 1 x rated operational current Switch off: 1 x rated operational current Utilization category 100 % AC-1 Typical examples of application Electric heat 07/10/2020 Eaton 109826 ED2020 V70.0 EN 8 / 11 Dimensions Contactor with auxiliary contact module 07/10/2020 Eaton 109826 ED2020 V70.0 EN 9 / 11 distance at side to earthed parts: 6 mm DILMP32 DILMP45 Additional product information (links) IL03407049Z (AWA2100-2356) 4 pole Contactor IL03407049Z (AWA2100-2356) 4 pole Contactor ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL03407049Z2018_05.pdf Motor starters and "Special Purpose Ratings" for the North American market http://www.eaton.eu/ecm/groups/public/@pub/@europe/@electrical/documents/content/pct_3258146.pdf Switchgear of Power Factor Correction Systems http://www.moeller.net/binary/ver_techpapers/ver934en.pdf X-Start - Modern Switching Installations Efficiently Fitted and Wired Securely http://www.moeller.net/binary/ver_techpapers/ver938en.pdf Mirror Contacts for Highly-Reliable Information http://www.moeller.net/binary/ver_techpapers/ver944en.pdf Relating to Safety-Related Control Functions Effect of the Cabel Capacitance of Long Control http://www.moeller.net/binary/ver_techpapers/ver949en.pdf Cables on the Actuation of Contactors 07/10/2020 Eaton 109826 ED2020 V70.0 EN 10 / 11 Switchgear for Luminaires http://www.moeller.net/binary/ver_techpapers/ver955en.pdf http://www.moeller.net/binary/ver_techpapers/ver956en.pdf Standard Compliant and Functionally Safe Engineering Design with Mechanical Auxiliary Contacts The Interaction of Contactors with PLCs http://www.moeller.net/binary/ver_techpapers/ver957en.pdf Busbar Component Adapters for modern Industrial control panels http://www.moeller.net/binary/ver_techpapers/ver960en.pdf 07/10/2020 Eaton Industries GmbH http://www.eaton.eu © 07/2020 by Eaton Industries GmbH Eaton 109826 ED2020 V70.0 EN 11 / 11
DILMP45-10(230V50HZ,240V60HZ) 价格&库存
很抱歉,暂时无法提供与“DILMP45-10(230V50HZ,240V60HZ)”相匹配的价格&库存,您可以联系我们找货
