DWM1742MA
DWM1742MA
    EATON(伊顿)
    EATON TRIPP LITE - DWM1742MA - SWIVEL/TILT WALL MOUNT W/ARM, 35KG
DWM1742MA 数据手册
Swivel/Tilt Wall Mount with Arms for 17" to 42" TVs and Monitors, UL certified MODEL NUMBER: DWM1742MA Highlights ● Fits most flat-panel displays from 17 to 42 in. ● One-touch adjustment for comfortable viewing ● 180° swivel, -15° to +15° tilt and -3° to +3° screen adjustment ● Supports up to 77 lbs (34.9 kgs) ● UL certified Package Includes Hangs a flat-panel television, monitor or other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants. Swivels and tilts to provide optimal viewing angles. Description The VESA-compliant DWM1742MA Swivel/Tilt Wall Mount allows you to mount your flat-panel television, monitor or other display on the wall. Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurants, it fits most flat-panel displays from 17 to 42 inches. The full-motion swivel arm can be adjusted for angle to give you maximum flexibility in positioning your display to fit your environment and comfort level. A 180° swivel, -15° to +15° tilt and -3° to +3° screen level adjustment capability minimizes glare and provides comfortable viewing from multiple angles. Durable all-metal frame with scratch-resistant powder-coated finish supports up to 77 lbs (34.9 kgs). Mounting hardware included. Conforms to VESA-compliant displays with any of the following mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 75 x 200 mm, 100 x 75 mm, 100 x 100 mm, 100 x 200 mm, 200 x 75 mm, 200 x 100 mm and 200 x 200 mm. Features Mounts Your TV or Monitor to the WallFits most flat-panel televisions, monitors and other displays from 17 to 42 in.Ideal for home theaters, classrooms, boardrooms, hotels, bars and restaurantsFull-motion swivel arm adjusts for angleMounting hardware includedUL certified Convenient One-Touch Adjustment180° swivel, -15° to +15° tilt and -3° to +3° screen level adjustment capability provides comfortable viewing from multiple angles Durable Metal ConstructionSupports up to 77 lbs (34.9 kgs)Scratch-resistant powder-coated finish blends with any décorDisplay cables attach to mount to reduce clutter VESA ComplianceSupports the following VESA mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 75 x 200 mm, 100 x 75 mm, 100 x 100 mm, 100 x 200 mm, 200 x 75 mm, 200 x 100 mm and 200 x 200 mm Specifications OVERVIEW UPC Code 037332183545 1/3 ● Arm assembly ● (2) Top/bottom covers ● Middle cover ● Mounting template ● Cable cover ● Cable clip ● M4 x 5 screw ● (4) M4 x 14 screws ● (4) M5 x 14 screws ● (4) M6 x 14 screws ● (4) M8 x 20 screws ● (4) D5 washers ● (4) D8 washers ● (8) Small spacers ● (4) Anchor bolts ● (4) Concrete anchors ● (4) D6 washers ● Hex key ● Owner’s manual Device Compatibility Monitor/HDTV PHYSICAL Color Black Material of Construction Steel VESA Pattern (mm) 100x100; 100x200; 100x75; 200x100; 200x200; 200x75; 75x100; 75x200; 75x75 Motion Full Mounting Location Wall Degrees of Motion -15/+15 Tilt; 180 Swivel; -3/+3 Level Adjustment Minimum Screen Size (in.) 17 Minimum Screen Size (cm) 43.18 Maximum Screen Size (in.) 42 Maximum Screen Size (cm) 106.68 Maximum Weight Capacity (lbs.) 77 Maximum Weight Capacity (kg) 35 Min/Max Arm Extension (in.) 2.21 min to 20.08 max Min/Max Arm Extension (cm) 5.6 min to 51 max Number of Displays 1 Shipping Dimensions (hwd / in.) 3.40 x 15.60 x 11.70 Shipping Dimensions (hwd / cm) 8.64 x 39.62 x 29.72 Shipping Weight (lbs.) 8.50 Shipping Weight (kg) 3.86 Unit Dimensions (hwd / in.) 11.100 x 8.740 x 21.960 Unit Dimensions (hwd / cm) 28.2 x 49.4 x 22.2 Unit Weight (lbs.) 7.88 Unit Weight (kg) 3.57 Assembly Required Yes FEATURES & SPECIFICATIONS Antimicrobial No Cord Management Yes Tools Necessary Yes Security Lock No STANDARDS & COMPLIANCE Product Certifications UL 2442 Product Compliance RoHS; REACH 2/3 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 1000 Eaton Boulevard © 2024 Eaton. All Rights Reserved. Cleveland, OH 44122 Eaton is a registered trademark. All other trademarks United States are the property of their respective owners. https://tripplite.eaton.com 3/3
DWM1742MA 价格&库存
很抱歉,暂时无法提供与“DWM1742MA”相匹配的价格&库存,您可以联系我们找货
