Inductive Proximity Sensors
iProx®
3.0
Introduction
Quick Reference Guide . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.1
3.2
3.3
3.4
3.5
V8-T3-29
V8-T3-36
3.6
V8-T3-45
Ferrous Only Tubular Sensors
Product Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
3.7
V8-T3-51
V8-T3-54
High Current Output Sensors
3.9
V8-T3-58
V8-T3-61
E56 Pancake Sensors
Nonmetallic Tubular
3.11
V8-T3-66
3.13
3.16
V8-T3-81
E51 Modular Limit Switch Style Sensors
E51, Factory Sealed
3
V8-T3-83
E51 Limit Switch Style, Factory Sealed 6P+ Sensors
3
3
3
3
3
3
3
V8-T3-78
E55 Limit Switch Style Sensors with Nonmetallic Housings
3.15
V8-T3-74
E52 Rectangular Style Sensors
3.14
V8-T3-71
E52 Cube Style Sensors
E52 Cube Style
3
3
Nonmetallic Tubular Sensors
3.12
3
3
Miniature Short Body Sensors
3.10
3
3
Metal Face Sensors
3.8
3
3
AccuProx Analog Sensors
3
3
Global Proximity Sensors
E56 Pancake
V8-T3-17
E57 Premium+ Series Short Barrel Sensors
Accu™ Prox
V8-T3-10
E57 Premium+ Series Sensors
3
3
iProx Sensors
Global Proximity
V8-T3-2
V8-T3-92
Unless otherwise noted, the products contained in this section should not
be used for functional safety applications. These products were not designed
or tested to IEC 60947-5-3 or recommended for functional safety.
3
3
3
3
3
3
3
3
Learn
Online
For Customer Service in the U.S. call 1-877-ETN CARE (386-2273),
in Canada call 1-800-268-3578.
For Application Assistance in the U.S. and Canada
call 1-800-426-9184.
Volume 8—Sensing Solutions CA08100010E—January 2012 www.eaton.com
V8-T3-1
3
3
3.0
Introduction
3
3
Sensing Application
3
Shielded
Sensor
Sensing Style
Size
Max Range
Product Family
Page
Shielded tubular
8 mm
3 mm
V8-T3-36
12 mm
4 mm
iProx Sensors
V8-T3-10
3
3
Target
Mounting
18 mm
3
3
Unshielded tubular
Mounting
Target
V8-T3-17, V8-T3-29
V8-T3-36
V8-T3-10
V8-T3-17, V8-T3-29
15 mm
V8-T3-36
8 mm
6 mm
V8-T3-36
12mm
10 mm
iProx Sensors
V8-T3-10
10 mm
E57 Premium + Series
V8-T3-17, V8-T3-29
V8-T3-36
3
3
30 mm
10 mm
18 mm
iProx Sensors
V8-T3-10
20 mm
V8-T3-17, V8-T3-29
18 mm
V8-T3-36
29 mm
iProx Sensors
V8-T3-10
22 mm
V8-T3-17, V8-T3-29
29 mm
V8-T3-36
12 mm
8mm
V8-T3-45
18 mm
15 mm
V8-T3-45
30 mm
25 mm
V8-T3-45
Shielded cube
40 x 40 x 40 mm
20 mm
V8-T3-74
Unshielded cube
40 x 40 x 40 mm
40 mm
V8-T3-74
Analog tubular
3
V8-T3-10
5 mm
10 mm
3
3
iProx Sensors
iProx Sensors
18 mm
3
V8-T3-36
8 mm
3
3
V8-T3-17, V8-T3-29
8 mm
3
Unshielded
Sensor
15 mm
30 mm
3
2 mm
5 mm
Analog
Sensor
Target
3
Shielded
Sensor
3
3
Target
3
Mounting
3
Unshielded
Sensor
3
3
Target
Mounting
3
3
3
3
3
3
V8-T3-2
Introduction
3.0
Inductive Proximity Sensors, continued
Sensing Application
Target
Sensing Style
Size
Max Range
Product Family
Page
3
Shielded limit switch
118 x 40 x 40 mm
114 x 39 x 38.4 mm
13 mm
V8-T3-83,
V8-T3-92
3
Mounting
3
3
3
Shielded
Sensor
Unshielded limit switch
Target
118 x 40 x 40 mm
114 x 39 x 38.4 mm
24 mm
E51 Series
E55 Series
V8-T3-83,
V8-T3-92
Mounting
3
3
3
Unshielded
Sensor
Target
3
Shielded
Sensor
Shielded pancake
79 x 79 x 39 mm
40 mm
E56 Series
V8-T3-66
3
3
3
3
Mounting
Unshielded pancake
Target
Unshielded
Sensor
79 x 79 x 39 mm
110 x 110 x 41 mm
171.5 x 171.5 x 67.5 mm
100 mm
E56 Series
V8-T3-66
3
3
3
3
Mounting
3
3
3
3
3
3
3
3
3
3
3
3
3
V8-T3-3
3.0
Introduction
3
Technical Reference
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
General
There are a number of factors which should be considered when applying induction proximity
sensors. A detailed discussion of these factors can be found on Page V8-T12-4. Presented below
are a few of the more important considerations for quick reference.
Mounting
Inductive proximity sensors
are available in two
classifications: shielded (also
known as embeddable or
flush mountable) and
unshielded (non-embeddable
or non-flush mountable).
What these terms refer to is
the distance to surrounding
metal that the device can be
mounted. In the case of a
shielded sensor the device
can be mounted with the
sensor completely
surrounded by metal.
In the case of an unshielded
sensor, a metal free zone
must be provided when
mounting the sensor. The
size of the metal free zone is
dependent on both the size of
the sensor and the type of
sensing range it has, i.e.,
standard or extended.
When mounting the sensors,
do not exceed the following
recommended torque
specifications.
Mounting Ranges
a
d
b
Torque Specifications
Stainless Steel
Shielding
a
b
Standard Range
3
Shielded
Unshielded
2 x Sn
Cap height
Semi-shielded
Sn
d
Non-embeddable
2 x Sn
Cap height
3
3
3
V8-T3-4
35 lb-in (4.0 Nm)
70 lb-in (7.9 Nm)
20 lb-in (2.3 Nm)
70 lb-in (7.9 Nm)
30 mm Diameter
70 lb-in (7.9 Nm)
Where a and b are the metal
free dimensions.
3
12 mm Diameter
18 mm Diameter
Extended Range
3
Nickel-Plated
Brass
70 lb-in (7.9 Nm)
Introduction
3.0
Extended Range Sensors
3
Extended range proximity sensors by Eaton’s electrical sector offer sensing distances almost three
times greater than conventional devices. They are available in semi-shielded designs: mounted
similar to an embeddable sensor—and non-embeddable designs requiring more metal free zone
area than conventional unshielded sensors. All are available in a variety of circuits and terminations.
3
3
Target Material
When manufacturers of
inductive proximity sensors
state the sensing range of
their devices, they are usually
based upon a ferrous target
made of carbon-rolled steel
(IE FE 360) defined by
ISO630. For example, in this
product guide the
E57LAL18A2 has a sensing
range of 5 mm based upon a
target of mild steel.
Sensing ranges to targets
made of non-ferrous metals
have to have a correction
factor applied as listed in the
table below. To use this
table, multiply the sensing
distance of the device by
the factor given.
3
Example: The E57LAL18A2
has a sensing range of
5 mm. When used to sense
a brass target, the sensing
range becomes 2.25 mm
(5 mm x 0.45).
3
3
3
3
3
3
Table of Correction Factors
Multiply sensing range of device by factor given below.
3
Correction Factors
3
Target
Sensor Size
4–8 mm 12 mm
18 mm
30 mm
Limit Switch
Stainless steel 400
0.90
0.90
1.0
1.0
1.0
Stainless steel 300
0.65
0.70
0.70
0.75
0.85
Brass
0.35
0.45
0.45
0.45
0.5
Aluminum
0.35
0.40
0.45
0.40
0.47
Copper
0.30
0.25
0.35
0.30
0.40
3
3
3
3
Target Size
Often overlooked when
applying sensors is the fact
that the manufacturer’s
stated sensing ranges are
also dependent upon target
size. The table below reflects
the standard target sizes
which were used to
determine sensing ranges.
If targets are the same size
or greater than standard, no
reduction in sensing distance
will occur. However, a
smaller target size will result
in a decrease in sensing
range.
3
A general rule of thumb is
that the target size shall be
three times the range or the
size of the sensor face,
whichever is larger.
3
3
3
3
Standard Target Size 1
Target
Standard Sensing Range
Shielded Devices
Unshielded Devices
3
Extended Sensing Range
Semi-Shield Devices
Non-Embeddable Devices
4 mm
4 mm square
4 mm square
5 mm
5 mm square
5 mm square
6.5 mm
6.5 mm square
6.5 mm square
8 mm
8 mm square
8 mm square
12 mm
12 mm square
12 mm square
18 mm square
30 mm square
18 mm
18 mm square
24 mm square
36 mm square
60 mm square
30 mm
30 mm square
45 mm square
66 mm square
Limit switch
45 mm square
72 mm square
3
3
3
3
3
Note
1 Targets are 1 mm thick.
3
3
3
V8-T3-5
3.0
Introduction
3
Product Selection Guide
3
iProx
E57 Premium+ Series
E57 Premium+ Series
Short Barrel
Global Proximity
Page V8-T3-10
Page V8-T3-17
Page V8-T3-29
Page V8-T3-36
Overview
Overview
Overview
Overview
Designed to be the highest performing
tubular inductive sensor. Standard features
include extended sensing ranges, high
noise-immunity, extreme durability and
includes Autoconfigure Technology.
Advanced features include output delay,
speed detection and cloning with
ProxView Software.
High performance inductive sensors include
stainless steel models, extended ranges
and right-angle sensing.
Full featured sensors with shorter overall
length than standard tubular sensors.
This full-line, tubular proximity sensor
family provides a cost-effective solution for
high volume OEM use.
Applications
Applications
Applications
Applications
Automotive, machine tool, material
handling where high sensing performance
and inventory consolidation is a priority
A wide variety of applications including
those where customers require AC/DC
universal inventory sensors
Automation, robotics, transfer lines,
conveyors, material handling
Machine tool detection, press applications,
cam detection, material handling, valve and
shaft position, automotive assembly
Product Features
Product Features
Product Features
Product Features
Auto-configure technology automatically
detects a sinking (NPN) or sourcing (PNP)
connection and switches the sensor
accordingly, without any user intervention
Optional computer programming cable and
Windows-based ProxView configuration
software makes it easy to customize
sensors
Clone the sensor to match the
characteristics of more than 4,800
competitive models, or configure it to
match your specific application needs
Advanced programmable features such as
dual outputs, output delay, speed detection
and more
12, 18 and 30 mm diameters
Two- and three-wire AC and DC sensors
360° LED indicators standard
NO or NC outputs
Variety of terminations
Resettable short circuit protected and
reverse polarity on select models
Robust stainless steel tubes, shockresistant front caps, polycarbonate end
bells, and impact-absorbing potting
compound are resistant to physical and
environmental abuse in high temperature,
high pressure washdown and high shock
and vibration applications
Available in 12, 18 and 30 mm diameters
Two-wire sensors offer 20–250 Vac or
Vdc operation; AC only 20–135 Vac
Three-wire models operate on 6–30 Vdc
360° LED indicators
Same sensing ranges as standard sensors
High flex extra long 5m cable or pigtail
micro-pin connector
Short circuit protection on AC/DC and
DC-only versions
8, 12, 18 and 30 mm diameters
Two-wire sensors available in AC or DC
versions
Three-wire sensors available in DC versions
Shielded and unshielded models
Cable, micro-connector and nano-connector
terminations
Short circuit protection on DC models
NO or NC outputs
Technical Data and Specifications
Current ratings—
AC: 250–500 mA
DC: 300–500 mA
Enclosure ratings—
NEMA 4, 4X, 6, 6P, 12, 13
IEC IP67, IP69K
Construction—
Stainless steel
Current ratings—
AC: 250–500 mA
DC: 200 mA
Enclosure ratings—
IEC IP6, IP69K7
Construction—
Stainless steel
Current ratings—
AC mode—250–500 mA continuous
DC mode—200 mA continuous
Enclosure ratings—
IEC IP67
Construction—
Stainless steel
Semi-shielded models: nickel plated brass
Current ratings—
AC mode—200 mA
DC mode—100 mA
Enclosure ratings—
IEC IP67, IP69K
Approvals
Approvals
Approvals
Approvals
cUL Listed
cUL Listed
CE (AC/DC and DC-only models)
UL Listed
CSA Certified
cCSAus
CE (DC-only models)
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
V8-T3-6
Construction—
Nickel plated brass
8 mm Nano: stainless steel
Introduction
AccuProx
Metal Face
3.0
3
High Current Output
3
3
3
3
Page V8-T3-45
Page V8-T3-51
Page V8-T3-54
Page V8-T3-58
Overview
Overview
Overview
Overview
3
AccuProx™ sensors feature analog outputs
that change linearly as the target moves
closer or further from the sensor face.
Sensors designed to detect only ferrous
metals (steel/iron).
Tough sensors with thick stainless steel
sensing faces and barrels.
DC sensors which can carry extremely large
continuous inrush current.
3
3
3
Applications
Applications
Applications
Applications
3
Part positioning, distance, size and
thickness measurement, general inspection
and error proofing (such as material
imperfection or blemish detection),
eccentricity or absolute angle detection,
identification of different metals
Workcell applications, automotive and
aircraft production
Metal cutting operations where damage to
sensor face could occur
Heavy-duty vehicles, cement mixers, lift
trucks, front end loaders, farm equipment
3
Product Features
Product Features
Product Features
Product Features
Extended linear sensing range of up to
25 mm—three times longer than standard
tubular analog inductive sensors
Outputs available in current
(4–20 or 0–20 mA) and voltage (0–10V)
High output resolution and repeatability
for applications requiring precision sensing
performance
Robust stainless steel barrel, shockresistant front cap, polycarbonate end bell
and impact-absorbing potting compound
Ideal for extreme temperature or high
pressure washdown environments
18 mm diameters
Two-wire AC or three-wire DC
NO or NC outputs
Micro- and mini-pin terminations
LED indicators
20 mil thick stainless steel face
303 stainless steel barrel
LED indicator
2-meter cable, micro- and mini-pin
connections
30 mm diameter stainless steel housing
Solid-state output for 12 ampere
continuous, 50 ampere inrush capacity
–40° to 158°F (–40° to 70°C) temperature
range
NO and NC isolated outputs
Heavy gauge SJO cable
Current ratings—
0–10 Vdc, 0–20 mA, 4–20 mA
Enclosure ratings—
NEMA 4, 4X, 6, 6P, 13
Construction—
Stainless steel
Current ratings—
AC: 500 mA continuous
DC: 200 mA continuous
Enclosure ratings—
IEC IP67
Construction—
Stainless steel
Current ratings—
Enclosure ratings—
IEC IP67
Construction—
Stainless steel
Current ratings—
Varies by model
Enclosure ratings—
IEC IP67
Construction—
Stainless steel
Approvals
Approvals
Approvals
Approvals
cUL Listed
UL Listed
CSA Certified
UL Listed
CSA Certified
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
V8-T3-7
3.0
Introduction
E56 Pancake
Tubular, Nonmetallic
Housing
E52 Cube Style
Page V8-T3-61
Page V8-T3-66
Page V8-T3-71
Page V8-T3-74
Overview
Overview
Overview
Overview
3
Small diameter and short body (4, 5, 6.5
and 8 mm) tubular housings for tight
sensing applications.
Self-contained sensors capable of sensing
up to 3.94 inches (100 mm).
Tubular sensors with nonmetallic housings
offer high corrosion resistance.
A family of industry-standard, cube-sized
inductive sensors with long range
capabilities.
3
Applications
Applications
Applications
Applications
3
Automation equipment, robotics, machine
tool, counting, sorting
Oil rig operations, floor conveyors,
automotive assembly, overhead cranes
Food processing lines, high washdown
environments
Automotive, manufacturing,
machinery OEMs
3
Product Features
Product Features
Product Features
Product Features
Variety of diameters in stainless steel
housings
PVC cable, micro- and nano-pin connections
Short overall lengths
Short circuit and reverse polarity protection
40, 50, 70 and 100 mm sensing distances
Four-wire DC models have complementary
outputs (1 NO/1 NC)
Four-wire DC models use auto-configure
technology, which allows the sensor to
automatically adapt for NPN or PNP
without user intervention
Available in two-wire AC/DC versions
Power and output LED indicator
Quick disconnect option
Short circuit protected in DC
Longest sensing distances available
12, 18 and 30 mm diameters shielded and
unshielded sensing
Normally open or closed outputs
AC and DC voltages
Tough ABS plastic housing
Output LED on all models
Long inductive proximity ranges available
(up to 40 mm sensing distance)
outputs (1 NO/1 NC)
Robust design featuring vibration and
Ideal for extreme temperatures or high
Current ratings—
DC: 200 mA maximum
Enclosure ratings—
IEC IP67
Construction—
Stainless steel
Current ratings—
Enclosure ratings—
NEMA 4, 4X, 12, 13
(some models also rated NEMA 6)
IEC IP66
Construction—
PPS
Current ratings—
AC: 150 mA
DC: 200 mA
Enclosure ratings—
NEMA 3, 3S, 4, 4X, 13
IEC IP66
Construction—
ABS plastic
Current ratings—
AC: 400 mA maximum
DC: 300 mA maximum
Enclosure ratings—
IEC IP67
Construction—
Zinc alloy/PPS, PL
Approvals
Approvals
Approvals
Approvals
CE
cULus Listed
cULus Listed
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
3
V8-T3-8
Introduction
E55 Limit Switch Style,
Nonmetallic Housing
Factory Sealed 6P +
3.0
Modular
3
3
3
3
3
3
3
Page V8-T3-78
Page V8-T3-81
Page V8-T3-83
Page V8-T3-92
Overview
Overview
Overview
Overview
A variety of small rectangular sensors for
limited space applications.
These nonmetallic sensors provide
corrosion resistance in a limit switch style
housing.
Completely epoxy filled in unitized, one
piece limit switch style construction for
reliable performance under the most
adverse of environmental conditions.
Modular design allows maximum use of
inventories in these limit switch style
housings. Solid-state circuitry in a variety
of sensing ranges.
Applications
Applications
Applications
Applications
3
Tight applications where conventional
sensor are too large
environments
All corrosive environments: Coolants/
cutting oils, automotive applications
Machine tool, punch presses, automotive,
conveyor systems
3
Product Features
Product Features
Product Features
Product Features
3
Variety of housing styles R12, R18, Q16,
Q25
10 to 30 Vdc
NPN and PNP output
LED indicator for output status
5 position head can be top mounted or in
any of four side positions
Long sensing ranges up to 40 mm
AC voltages
Tough PBT resin housing
One piece housing on switch body/
receptacle
Head and housing totally epoxy
encapsulated
Side sensing head can be unfastened and
moved to any of four positions
Quick disconnect options
Corrosive resistant epoxy coated housing
Modular heads, switch bodies, receptacles
Shielded or unshielded sensing ranges
Solid-state electronics
Viton gasket seals
LED indicators for power and output status
Top and side sensing heads
Alternate frequency for side by side
operation
Components individually labeled for easy
identification
3
3
3
3
3
3
3
3
Current ratings—
DC: 100 mA maximum
Enclosure ratings—
NEMA 1, 2, 3, 3S, 4, 12
IEC IP66
Construction—
PBT composition housing
Current ratings—
AC: 400 mA
Enclosure ratings—
NEMA 4, 4X, 6, 12, 13
IEC IP67
Construction—
PBT resin
Current ratings—
AC: 1 ampere continuous
DC: 0.6 ampere continuous
Enclosure ratings—
NEMA 3, 3S, 4, 4X, 6, 6P, 12, 13
IEC IP67
Construction—
Die cast zinc
Gasket material: Viton
Current ratings—
Enclosure ratings—
IEC IP67
Class I, Class II, Division 2
Groups A, B, C, D, F and G; Class III
Construction—
Die cast zinc
Approvals
Approvals
Approvals
Approvals
cUL Listed
UL Listed
CSA Certified (most models)
3
3
3
3
3
3
3
3
3
3
3
3
V8-T3-9
3.1
3
iProx Sensors
Contents
iProx Sensors
Description
3
Page
iProx Sensors
Product Selection
iProx Sensors . . . . . . . . . . . . . . . . . . . . . . .
Complementary and Dual Output Sensors .
Compatible Connector Cables . . . . . . . . . .
Accessories . . . . . . . . . . . . . . . . . . . . . . . . . . .
Technical Data and Specifications . . . . . . . . . .
Wiring Diagrams . . . . . . . . . . . . . . . . . . . . . . .
Dimensions . . . . . . . . . . . . . . . . . . . . . . . . . . .
3
3
3
3
V8-T3-11
V8-T3-13
V8-T3-14
V8-T3-14
V8-T3-15
V8-T3-16
V8-T3-16
3
3
3
3
3
iProx Sensors
3
Product Description
3
3
3
3
3
3
3
3
3
3
3
3
3
3
The iProx® represents the
highest performance, most
versatile tubular inductive
sensor offered by Eaton’s
electrical sector. By utilizing
an embedded microprocessor and exclusive
SmartSense™ technology,
iProx can sense up to three
times farther than typical
sensors of its class, while
providing an unheard-of level
of customization.
Application Description
The iProx also includes a
wide range of advanced
features that can be enabled
via optional programming
tools. Using the ProxView
Windows-based software
package, an entirely custom
sensor can be programmed
to perfectly fit an application.
Features
Typical Applications
Automotive
Machine Tool
Material Handling
Metalworking
3
3
With extended sensing
range, quality construction
and the ability to adapt to its
environment, iProx is the
ideal choice for even the
most demanding inductive
Both shielded and unshielded
versions of iProx feature
extended sensing ranges.
This allows the sensor to be
mounted farther from the
target, thereby reducing the
potential for target impacts and
increasing the sensing
reliability of your application.
3
3
Sensor characteristics, such
as sensing range, can be
customized down to the
nearest tenth of a millimeter.
Outputs can be changed from
NO to NC. The iProx even
features built-in timing delays
and speed detection logic—
no PLC programming is
necessary.
For the most current information
on this product, visit our Web site:
www.eaton.com
V8-T3-10
Available in AC two-wire,
DC three-wire and
unique DC four-wire with
complementary (NO-NC)
or dual NO outputs
Reliably detect metal
targets at up to three times
the range of conventional
shielded or unshielded
tubular inductive sensors
Quality construction using
a stainless steel barrel,
360-degree dual-color
LED indicator, Ryton®
impact-resistant face cap
and vibration-absorbing
potting compound
automatically detects a
(PNP) connection and
switches the sensor
user intervention
Exclusive SmartSense
technology allows for
customizable range, band
sensing, nuisance metal
rejection, timing delays
and over/under speed
detection
Optional computer
configuration software
sensors
Withstands high electrical
noise (up to 20 V/m)
Resistant to extreme
temperatures (–40°F
[–40°C])
Standards and Certifications
cUL Listed
CE
DANGER
THIS SENSOR IS NOT A
SAFETY DEVICE AND IS NOT
INTENDED TO BE USED AS A
SAFETY DEVICE. This sensor
is designed only to detect
and read certain data in an
electronic manner and
perform no use apart from
that, specifically no safetyrelated use. This sensor
product does not include
self-checking redundant
circuitry, and the failure of
this sensor product could
cause either an energized
or de-energized output
condition, which could result
in death, serious bodily
injury, or property damage.
iProx Sensors
3.1
Product Selection
3
iProx Sensors
3
Note: Custom iProx models can also be ordered directly from the factory with pre-set ranges, outputs and connectors.
Consult the Eaton Application Engineers at 1-800-426-9184 for more information.
3
Two-Wire Sensors
Operating
Voltage
Extended Range
Sensing
Range
Shielding
Connection Type 1
NO Output
Catalog Number 2
NC Output
Catalog Number 2
Shielded
3-pin micro AC connector
E59-M12A105A01-A1
E59-M12A105A01-A2
3-pin micro AC pigtail 3
E59-M12A105A01P-A1
E59-M12A105A01P-A2
3-pin mini AC pigtail 3
E59-M12A105A01PB-A1
E59-M12A105A01PB-A2
2-meter cable
E59-M12A105C02-A1
E59-M12A105C02-A2
4 mm
Standard Range
10 mm
Unshielded
E59-M12C110A01-A1
E59-M12C110A01-A2
E59-M12C110A01P-A1
E59-M12C110A01P-A2
E59-M12C110A01PB-A1
E59-M12C110A01PB-A2
2-meter cable
E59-M12C110C02-A1
E59-M12C110C02-A2
E59-M18A109A01-A1
E59-M18A109A01-A2
E59-M18A109A01P-A1
E59-M18A109A01P-A2
E59-M18A109A01PB-A1
E59-M18A109A01PB-A2
2-meter cable
E59-M18A109C02-A1
E59-M18A109C02-A2
E59-M18C118A01-A1
E59-M18C118A01-A2
3
3
3
3
3
18 mm Diameter
20–132 Vac
8 mm
Shielded
Standard Range
18 mm
Extended Range
3
12 mm Diameter
20–132 Vac
Extended Range
3
Unshielded
3
E59-M18C118A01P-A1
E59-M18C118A01P-A2
E59-M18C118A01PB-A1
E59-M18C118A01PB-A2
2-meter cable
E59-M18C118C02-A1
E59-M18C118C02-A2
E59-M30A115A01-A1
E59-M30A115A01-A2
E59-M30A115A01P-A1
E59-M30A115A01P-A2
E59-M30A115A01PB-A1
E59-M30A115A01PB-A2
2-meter cable
E59-M30A115C02-A1
E59-M30A115C02-A2
E59-M30C129A01-A1
E59-M30C129A01-A2
E59-M30C129A01P-A1
E59-M30C129A01P-A2
E59-M30C129A01PB-A1
E59-M30C129A01PB-A2
2-meter cable
E59-M30C129C02-A1
E59-M30C129C02-A2
3
3
3
3
3
30 mm Diameter
20–132 Vac
Standard Range
15 mm
29 mm
Shielded
Unshielded
3
3
3
3
3
3
Notes
See listing of compatible connector cables on Page V8-T3-14.
1
2
3
3
For sensors with custom cable lengths or PUR jackets, contact Application Engineering at 1-800-426-9184.
Sensors are ordered with pre-set outputs from the factory, but can be later programmed either NO or NC using the ProxView software.
Standard pigtail cable length is 12 in.
3
3
3
3
3
3
3
3
V8-T3-11
3.1
3
iProx Sensors
3
Three-Wire Sensors
Operating
Voltage
3
3
Extended Range
Sensing
Range
3
6–48 Vdc
4 mm
10 mm
Unshielded
6–48 Vdc
8 mm
Shielded
18 mm
Unshielded
3
Extended Range
E59-M12A105D01P-D1
E59-M12A105D01P-D2
E59-M12A105C02-D1
E59-M12A105C02-D2
4-pin micro DC connector
E59-M12C110D01-D1
E59-M12C110D01-D2
4-pin micro DC pigtail
E59-M12C110D01P-D1
E59-M12C110D01P-D2
2-meter cable
E59-M12C110C02-D1
E59-M12C110C02-D2
E59-M18A108D01-D1
E59-M18A108D01-D2
4-pin micro DC pigtail 3
E59-M18A108D01P-D1
E59-M18A108D01P-D2
2-meter cable
E59-M18A108C02-D1
E59-M18A108C02-D2
E59-M18C116D01-D1
E59-M18C116D01-D2
E59-M18C116D01P-D1
E59-M18C116D01P-D2
2-meter cable
E59-M18C116C02-D1
E59-M18C116C02-D2
E59-M30A115D01-D1
E59-M30A115D01-D2
E59-M30A115D01P-D1
E59-M30A115D01P-D2
2-meter cable
E59-M30A115C02-D1
E59-M30A115C02-D2
E59-M30C129D01-D1
E59-M30C129D01-D2
E59-M30C129D01P-D1
E59-M30C129D01P-D2
2-meter cable
E59-M30C129C02-D1
E59-M30C129C02-D2
3
30 mm Diameter
6–48 Vdc
15 mm
Shielded
3
3
3
Standard Range
3
3
E59-M12A105D01-D2
18 mm Diameter
3
3
E59-M12A105D01-D1
3
2-meter cable
Standard Range
Extended Range
Shielded
12 mm Diameter
3
3
NC Output
Catalog Number 2
Connection Type 1
3
3
NO Output
Catalog Number 2
Shielding
Standard Range
29 mm
3
3
Unshielded
Notes
3
1
3
2
3
3
3
3
3
3
3
3
3
3
V8-T3-12
iProx Sensors
3.1
3
Four-Wire Sensors
Operating
Voltage
Extended Range
Sensing
Range
Shielding
Output Type
Connection Type
Shielded
NPN (sinking)
E59-M12A105D01-D3NN
2-meter cable
E59-M12A105C02-D3NN
E59-M12A105C02-D1NN
E59-M12A105D01-D3PP
E59-M12A105D01-D1PP
2-meter cable
E59-M12A105C02-D3PP
E59-M12A105C02-D1PP
E59-M12C110D01-D3NN
E59-M12C110D01-D1NN
2-meter cable
E59-M12C110C02-D3NN
E59-M12C110C02-D1NN
E59-M12C110D01-D3PP
E59-M12C110D01-D1PP
2-meter cable
E59-M12C110C02-D3PP
E59-M12C110C02-D1PP
3
E59-M18A108D01-D3NN
E59-M18A108D01-D1NN
3
2-meter cable
E59-M18A108C02-D3NN
E59-M18A108C02-D1NN
E59-M18A108D01-D3PP
E59-M18A108D01-D1PP
2-meter cable
E59-M18A108C02-D3PP
E59-M18A108C02-D1PP
E59-M18C116D01-D3NN
E59-M18C116D01-D1NN
2-meter cable
E59-M18C116C02-D3NN
E59-M18C116C02-D1NN
4 mm
PNP (sourcing)
Standard Range
10 mm
Unshielded
NPN (sinking)
PNP (sourcing)
E59-M12A105D01-D1NN
3
18 mm Diameter
6–48 Vdc
8 mm
Shielded
NPN (sinking)
PNP (sourcing)
Standard Range
18 mm
Unshielded
NPN (sinking)
PNP (sourcing)
Extended Range
Dual NO Output
Catalog Number 1
12 mm Diameter
6–48 Vdc
Extended Range
3
Complementary Output
(1NO-1NC)
Catalog Number
15 mm
Shielded
NPN (sinking)
PNP (sourcing)
Standard Range
29 mm
Unshielded
NPN (sinking)
PNP (sourcing)
3
3
3
3
3
E59-M18C116D01-D3PP
E59-M18C116D01-D1PP
2-meter cable
E59-M18C116C02-D3PP
E59-M18C116C02-D1PP
E59-M30A115D01-D3NN
E59-M30A115D01-D1NN
2-meter cable
E59-M30A115C02-D3NN
E59-M30A115C02-D1NN
3
3
3
E59-M30A115D01-D3PP
E59-M30A115D01-D1PP
2-meter cable
E59-M30A115C02-D3PP
E59-M30A115C02-D1PP
E59-M30C129D01-D3NN
E59-M30C129D01-D1NN
2-meter cable
E59-M30C129C02-D3NN
E59-M30C129C02-D1NN
E59-M30C129D01-D3PP
E59-M30C129D01-D1PP
2-meter cable
E59-M30C129C02-D3PP
E59-M30C129C02-D1PP
3
3
3
3
Notes
1
3
3
30 mm Diameter
6–48 Vdc
3
3
At this time, iProx Complementary and Dual Output models are not available with auto-sink/source detection.
Therefore, PNP (sourcing) and NPN (sinking) models must be ordered separately.
3
3
3
3
3
3
3
3
3
V8-T3-13
3.1
3
3
iProx Sensors
Standard Cables 1
3
3
Current Rating Voltage
at 600V
Style
Micro-Style
Straight Female
Number
of Pins
Gauge
Length
3-pin,
3-wire
22 AWG
6.0 ft (2m)
4-pin,
4-wire
22 AWG
6.0 ft (2m)
16 AWG
6 ft (2m)
Pin Configuration/Wire Colors
(Face View Female Shown)
3
3
Mini-Style
Straight Female
AC
DC
1-Brown
2-White
3-Blue
4-Black
13A
3-pin
1-Green
2-Black
3-White
Accessories
iProx Sensors
3
3
Description
Catalog Number
Software
Step-by-step programming software required to program iProx. Compatible with
Microsoft Windows® and Windows® Mobile devices.
E59SW1
Cable
The iProx programming cable is used to program individual iProx sensors, providing
a connection between the computer and the sensor. Connects to computer via a
serial (RS-232) or USB port. (USB connection requires an adapter which is included
with purchase.)
E59RP1
Labels
Field applied labels for iProx sensor (100 pcs)
E59LABEL
3
3
3
3
3
3
3
3
Note
1 For a full selection of connector cables, see Tab 10, section 10.1.
3
3
3
3
3
3
3
3
V8-T3-14
CSAS3F3RY2202
CSDS4A4CY2202
CSDS4A4RY2202
Catalog Number
Mini-Style, Straight Female
3
3
CSAS3F3CY2202
1-Green
2-Red/Black
3-Red/White
3
3
PUR Jacket
Catalog Number
Micro-Style, Straight Female
3
3
PVC Jacket
Catalog Number
CSMS3F3CY1602
iProx Sensors
Starter Kit
3.1
iProx Starter Kits
Description
3
Catalog Number
3
Interested in custom programming iProx sensors to fit your application?
These kits include everything needed to get the most out of iProx: a sensor, a programming cable (E59RP1),
a micro connector cable (CSDS4A4CY2202) and ProxView software on CD-ROM (E59SW1).
3
Starter kit includes:
Demo Kit
12 mm AC unshielded iProx sensor (E59-M12C110A01-A1)
E5912ACKIT
12 mm DC unshielded iProx sensor (E59-M12C110D01-D1)
E5912DCKIT
18 mm AC unshielded iProx sensor (E59-M18C118A01-A1)
E5918ACKIT
18 mm DC unshielded iProx sensor (E59-M18C116D01-D1)
E5918DCKIT
30 mm AC unshielded iProx sensor (E59-M30C129A01-A1)
E5930ACKIT
30 mm DC unshielded iProx sensor (E59-M30C129D01-D1)
E5930DCKIT
3
3
3
3
iProx Demonstration Kit
Description
Catalog Number
A powered, briefcase demo kit show-casing the capabilities of iProx and AccuProx
sensors. Kit includes one 18 mm iProx sensor and one 18 mm AccuProx sensor.
A quick disconnect cable and mounting system allow for fast swapping of sensors.
Demo kit is powered by two replaceable 9-volt alkaline batteries.
E59DEMO1
3
3
3
3
3
3
iProx Sensors
Description
Two-Wire Sensors
Three-Wire Sensors
Input voltage
20–132 Vac
6–48 Vdc
Load current
12 mm: 5–300 mA, 200 mA >122°F (50°C)
≤500 mA at 6–30 Vdc; ≤300 mA at 32–48 Vdc
Leakage current
≤1.7 mA at 32°F (0°C), 2.0 mA at –40°F (–40°C)
≤150 μA
Voltage drop
20 V/m)
Description
Two-Wire Sensors
All Two-Wire Models
Notes
2
3
Our products conform to NEMA tests as indicated, however, some severe washdown applications can exceed these NEMA test specifications.
iProx sensors may be programmed to perform in side by side or high noise immunity applications using the iProx programming cable (E59RP1) and ProxView software (E59SW1).
Use the side by side response time parameter when using the iProx Tray Programmer (E59TP1), iProx programming cable (E59RP1) and ProxView software (E59SW1).
3
3
3
Ryton® is a registered trademark of Phillips Chemical (division of Phillips Petroleum).
1
3
3
3
V8-T3-15
3.1
3
iProx Sensors
Wiring Diagrams
Pin numbers are for reference, rely on pin location when wiring.
3
iProx Sensors
3
Operating
Voltage
3
Two-Wire Sensors
3
20–132 Vac
Connector Models (Face View Male Shown)
Output
Cable Models
NO and NC
BN
BU
3
3
3
6–48 Vdc
NO and NC
(NPN and PNP) 1
2
BK
L2 or
Load
L1 or
+V
L1
2
Load
+V
Load
Load
Four-Wire Dual Output and Complementary Sensors
6–48 Vdc
NO and NC (NPN)
3
BN
WH
BU
BL
3
NO and NC (PNP)
3
BN
WH
3
BU
BL
3
3
Load
+V
BU
3
3
L2
L2
Load
BN
3
3
L1
Mini
Three-Wire Sensors
3
3
Micro
3
Load
+V
+V
Load
Load
Load
3
+V
+V
Load
Load
Load
Load
Dimensions
Approximate Dimensions in Inches (mm)
Micro-Connector Models
Cable Models
3
3
3
3
Size
3
12 mm
3
18 mm
3
3
3
3
C
B
30 mm
Shielding
A
A
B
C
D
Size
Shielding
12 mm
Shielded
2.46 (62.4)
1.98 (50.3)
0.02 (0.5)
0.67 (17)
Unshielded
2.46 (62.4)
1.64 (41.6)
0.36 (9)
0.67 (17)
Shielded
2.54 (64.5)
2.00 (50.9)
0.02 (0.5)
0.94 (24)
Unshielded
2.54 (64.5)
1.47 (37.4)
0.55 (14)
0.94 (24)
Shielded
2.74 (69.6)
2.13 (54.1)
0.03 (0.75)
1.41 (36)
Unshielded
2.74 (69.6)
1.41 (35.8)
0.75 (19)
1.41 (36)
A
B
C
D
Shielded
2.71 (68.7)
1.98 (50.3)
0.02 (0.5)
0.67 (17)
Unshielded
2.71 (68.7)
1.64 (41.6)
0.36 (9)
0.67 (17)
18 mm
Shielded
2.73 (69.3)
2.00 (50.9)
0.02 (0.5)
0.94 (24)
Unshielded
2.73 (69.3)
1.47 (37.4)
0.55 (14)
0.94 (24)
30 mm
Shielded
2.92 (74.1)
2.13 (54.1)
0.03 (0.75)
1.41 (36)
Unshielded
2.92 (74.1)
1.41 (35.8)
0.75 (19)
1.41 (36)
Notes
1 The three-wire DC version of iProx automatically configures itself to NPN or PNP based on field wiring. No user intervention is required.
2 Pin numbers 2 and 4 are internally jumpered together. Either pin may be used.
3 The complementary (1NO-1NC) output models feature the NC output on pin 2 (white).
3
3
V8-T3-16
D
C
B
D
A
3.2
Contents
Description
Page
Product Selection
E57 Premium+ Sensors . . . . . . . . . . . . . . .
Compatible Connector Cables . . . . . . . . . . .
Wiring Diagrams . . . . . . . . . . . . . . . . . . . . . . . .
V8-T3-18
V8-T3-23
V8-T3-23
V8-T3-24
V8-T3-25
V8-T3-26
3
3
3
3
3
3
3
3
3
3
3
Product Description
Features
The Premium+ Series
have improved sensing
performance, product
durability and selection. This
improved line of sensors
carries the Premium+ Series
name because we have
upgraded the design to a
rugged stainless steel body,
shock-resistant front caps
compound. Plus, the
Premium+ Series line now
includes a choice of AC, AC/
DC and DC-only, 12, 18 and
30 mm sensors with
unmatched noise immunity of
greater than 20V/meter.
New expanded offering of
two-wire, three-wire, AC,
DC, and AC/DC multiple
range sensor models
Manufactured to take
physical and environmental
abuse
Designed with stainless
steel barrel and new
potting compound for
robust, high temperature,
high pressure washdown,
as well as intense shock
Unmatched high noise
immunity eliminates
problems associated with
electrical noise (all models
>20V/meter)
360° output status
indicator is visible from any
angle and in any light
condition
protection and reverse
polarity in select models
Right angle sensing
models offer unique
problem-solving
capabilities
Wide temperature range
–13° to 158°F (–25° to 70°C)
on cable, micro-style
connections
cUL Listed
models)
3
3
3
3
3
DANGER
3
3
3
3
3
3
3
3
3
3
3
3
www.eaton.com
V8-T3-17
3
3
3.2
3
3
Two-Wire Sensors
Operating
Voltage
Standard Range
Extended Range
3
3
20–132 Vac
3
3
2 mm
(standard range)
40–250 Vac
50/60 Hz 2
20–250 Vdc
3
3
3
Shielded
Unshielded
6 mm
(extended range)
Semi-shielded
2 mm
(standard range)
4 mm
(standard range)
Standard Range
Shielding
4 mm
(standard range)
10 mm
(extended range)
3
3
Sensing
Range (Sn)
Non-embeddable
Shielded
Unshielded
20–250 Vac
5 mm
(standard range)
Shielded
Extended Range
8 mm
(standard range)
3
Unshielded
3
20–132 Vac
3
12 mm
(extended range)
Semi-shielded
3
3
20 mm
(extended range)
Non-embeddable
3
3
40–250 Vac
50/60 Hz 2
20–250 Vdc
3
NO Output
Catalog Number
NC Output
Catalog Number
E57LBL12A2
2-meter cable
E57LAL12A2
E57LAL12A2SA
E57LBL12A2SA
3-pin micro AC pigtail connector
E57LAL12A2SP
E57LBL12A2SP
2-meter cable
E57LAL12A2E
E57LBL12A2E
E57LAL12A2EA
E57LBL12A2EA
E57LAL12A2EP
E57LBL12A2EP
2-meter cable
E57-12LE06-A
E57-12LE06-A1
E57-12LE06-AA
E57-12LE06-A1A
E57-12LE06-AP
2-meter cable
E57-12LE10-A
E57-12LE10-A1
E57-12LE10-AA
E57-12LE10-A1A
E57-12LE10-AP
E57-12LE10-A1P
2-meter cable
E57SAL12A2
E57SBL12A2
E57SAL12A2SA
E57SBL12A2SA
3-pin mini-connector
E57MAL12A2B1
2-meter cable
E57SAL12A2E
E57SBL12A2E
E57SAL12A2EA
E57SBL12A2EA
18 mm Diameter End Sensing
3
3
Connection Type 1
12 mm Diameter End Sensing
20–250 Vac
3
3
Product Selection
3
3
3
5 mm
(standard range)
Shielded
8 mm
(standard range)
Unshielded
2-meter cable
E57LAL18A2
E57LBL18A2
E57LAL18A2SA
E57LBL18A2SA
E57LAL18A2SP
E57LBL18A2SP
E57MAL18A2B1
E57MBL18A2B1
2-meter cable
E57LAL18A2E
E57LBL18A2E
E57LAL18A2EA
E57LBL18A2EA
E57LAL18A2EP
E57LBL18A2EP
E57MAL18A2EB1
E57MBL18A2EB1
2-meter cable
E57-18LE12-A
E57-18LE12-A1
E57-18LE12-AA
E57-18LE12-A1A
E57-18LE12-AP
E57-18LE12-A1P
E57-18LE12-AB
E57-18LE12-A1B
2-meter cable
E57-18LE20-A
E57-18LE20-A1
E57-18LE20-AA
E57-18LE20-A1A
E57-18LE20-AP
E57-18LE20-A1P
E57-18LE20-AB
E57-18LE20-A1B
2-meter cable
E57SAL18A2
E57SBL18A2
E57SAL18A2SA
E57SBL18A2SA
2-meter cable
E57SAL18A2E
E57SBL18A2E
E57SAL18A2EA
E57SBL18A2EA
3
Notes
See listing of compatible connector cables on Page V8-T3-23.
3
1
2
3
For cable lengths longer than 2 meters, add the number of the desired length in meters to the end of the listed catalog number (for catalog numbers ending with a
number, add an S and then the length). Examples for a 5-meter cable: E57-18LE12-A becomes E57-18LE12-A5; E57LAL12A2 becomes E57LAL12A2S5.
Avoid wiring these AC/DC models in series as the sensors may not perform reliably. Contact Eaton’s Applications Engineering at 1-800-426-9184 with questions.
3
V8-T3-18
3.2
Two-Wire Sensors, continued
Operating
Voltage
Right Angle
Sensing
Range (Sn)
Connection Type 1
NO Output
Catalog Number
3
NC Output
Catalog Number
3
18 mm Diameter Right Angle Sensing
20–250 Vac
5 mm
8 mm
Standard Range
Shielding
Shielded
Unshielded
2-meter cable
E57RAL18A2
E57RBL18A2
E57RAL18A2SA
E57RBL18A2SA
E57RAL18A2SP
E57RBL18A2SP
E57RAL18A2B1
E57RBL18A2B1
3
3
3
2-meter cable
E57RAL18A2E
E57RBL18A2E
E57RAL18A2EA
E57RBL18A2EA
E57RAL18A2EP
E57RBL18A2EP
E57RAL18A2EB1
E57RBL18A2EB1
3
3
3
30 mm Diameter End Sensing
20–250 Vac
10 mm
(standard range)
Shielded
Extended Range
15 mm
(standard range)
20–132 Vac
40–250 Vac
50/60 Hz 2
20–250 Vdc
22 mm
(extended range)
Unshielded
Semi-shielded
10 mm
(standard range)
Shielded
15 mm
(standard range)
Unshielded
2-meter cable
E57LAL30A2
E57LBL30A2
E57LAL30A2SA
E57LBL30A2SA
E57LAL30A2SP
E57LBL30A2SP
E57MAL30A2B1
E57MBL30A2B1
2-meter cable
E57LAL30A2E
E57LBL30A2E
E57LAL30A2EA
E57LBL30A2EA
E57LAL30A2EP
E57LBL30A2EP
E57MAL30A2EB1
E57MBL30A2EB1
2-meter cable
E57-30LE22-A
E57-30LE22-A1
E57-30LE22-AA
E57-30LE22-A1A
E57-30LE22-AP
E57-30LE22-A1P
E57-30LE22-AB
E57-30LE22-A1B
2-meter cable
E57SAL30A2
E57SBL30A2
E57SAL30A2SA
E57SBL30A2SA
2-meter cable
E57SAL30A2E
E57SBL30A2E
E57SAL30A2EA
E57SBL30A2EA
3
3
3
3
3
3
3
3
3
Notes
1
2
3
3
3
3
3
3
3
3
3
3
3
3
3
V8-T3-19
3.2
Three-Wire Sensors
3
3
Operating
Voltage
Standard Range
3
Sensing
Range (Sn)
Shielding
Connection Type 1
NO Output
Catalog Number
NC Output
Catalog Number
Shielded
(NPN)
2-meter cable
E57LAL12T110
E57LBL12T110
E57LAL12T110SD
E57LBL12T110SD
4-pin micro DC pigtail connector
E57LAL12T110SP
E57LBL12T110SP
2-meter cable
E57LAL12T111
E57LBL12T111
E57LAL12T111SD
E57LBL12T111SD
E57LAL12T111SP
E57LBL12T111SP
2-meter cable
E57LAL12T110E
E57LBL12T110E
E57LAL12T110ED
E57LBL12T110ED
E57LAL12T110EP
E57LBL12T110EP
2-meter cable
E57LAL12T111E
E57LBL12T111E
E57LAL12T111ED
E57LBL12T111ED
E57LAL12T111EP
E57LBL12T111EP
2-meter cable
E57-12LE06-C
E57-12LE06-C1
6–48 Vdc
2 mm
(standard range)
3
3
Extended Range
Shielded
(PNP)
3
4 mm
(standard range)
3
3
Unshielded
(PNP)
3
3
6 mm
(extended range)
3
3
10 mm
(extended range)
3
3
Non-embeddable
(NPN)
Non-embeddable
(PNP)
3
Standard Range
E57-12LE06-CD
E57-12LE06-C1D
E57-12LE06-CP
E57-12LE06-C1P
2-meter cable
E57-12LE06-B
E57-12LE06-B1
E57-12LE06-BD
E57-12LE06-B1D
E57-12LE06-BP
E57-12LE06-B1P
2-meter cable
E57-12LE10-C
E57-12LE10-C1
E57-12LE10-CD
E57-12LE10-C1D
E57-12LE10-CP
2-meter cable
E57-12LE10-B
E57-12LE10-B1
E57-12LE10-BD
E57-12LE10-B1D
E57-12LE10-BP
2-meter cable
E57LAL18T110
E57LBL18T110
E57LAL18T110SD
E57LBL18T110SD
E57LAL18T110SP
E57LBL18T110SP
4-pin mini-connector
E57MAL18T110B1
E57MBL18T110B1
2-meter cable
E57LAL18T111
E57LBL18T111
E57LAL18T111SD
E57LBL18T111SD
E57LAL18T111SP
E57LBL18T111SP
E57MAL18T111B1
E57MBL18T111B1
2-meter cable
E57LAL18T110E
E57LBL18T110E
E57LAL18T110ED
E57LBL18T110ED
E57LAL18T110EP
E57LBL18T110EP
E57MAL18T110EB1
E57MBL18T110EB1
2-meter cable
E57LAL18T111E
E57LBL18T111E
E57LAL18T111ED
E57LBL18T111ED
E57LAL18T111EP
E57LBL18T111EP
E57MAL18T111EB1
E57MBL18T111EB1
6–48 Vdc
3
3
Semi-shielded
(NPN)
Semi-shielded
(PNP)
3
3
Unshielded
(NPN)
5 mm
(standard range)
Shielded
(NPN)
Extended Range
Shielded
(PNP)
3
3
3
8 mm
(standard range)
Unshielded
(NPN)
3
3
Unshielded
(PNP)
3
3
3
Notes
3
1
3
3
V8-T3-20
3.2
Three-Wire Sensors, continued
Operating
Voltage
Standard Range
Sensing
Range (Sn)
Shielding
NO Output
Catalog Number
NC Output
Catalog Number
2-meter cable
E57-18LE12-C
E57-18LE12-C1
E57-18LE12-CD
E57-18LE12-C1D
E57-18LE12-CP
E57-18LE12-C1P
E57-18LE12-CB
E57-18LE12-C1B
2-meter cable
E57-18LE12-B
E57-18LE12-B1
E57-18LE12-BD
E57-18LE12-B1D
E57-18LE12-BP
E57-18LE12-B1P
E57-18LE12-BB
E57-18LE12-B1B
2-meter cable
E57-18LE20-C
E57-18LE20-C1
E57-18LE20-CD
E57-18LE20-C1D
E57-18LE20-CP
E57-18LE20-C1P
E57-18LE20-CB
E57-18LE20-C1B
2-meter cable
E57-18LE20-B
E57-18LE20-B1
E57-18LE20-BD
E57-18LE20-B1D
E57-18LE20-BP
E57-18LE20-B1P
E57-18LE20-BB
E57-18LE20-B1B
2-meter cable
E57RAL18T110
E57RBL18T110
E57RAL18T110SD
E57RBL18T110SD
E57RAL18T110SP
E57RBL18T110SP
E57RAL18T110B1
E57RBL18T110B1
2-meter cable
E57RAL18T111
E57RBL18T111
E57RAL18T111SD
E57RBL18T111SD
E57RAL18T111SP
E57RBL18T111SP
3
3
18 mm Diameter End Sensing, continued
6–48 Vdc
12 mm
(extended range)
Semi-shielded
(NPN)
Extended Range
Semi-shielded
(PNP)
20 mm
(extended range)
Non-embeddable
(NPN)
Non-embeddable
(PNP)
Right Angle
Connection Type 1
3
3
3
3
3
3
3
3
3
3
6–48 Vdc
5 mm
Shielded
(NPN)
Shielded
(PNP)
8 mm
Unshielded
(NPN)
Unshielded
(PNP)
E57RAL18T111B1
E57RBL18T111B1
2-meter cable
E57RAL18T110E
E57RBL18T110E
E57RAL18T110ED
E57RBL18T110ED
E57RAL18T110EP
E57RBL18T110EP
E57RAL18T110EB1
E57RBL18T110EB1
2-meter cable
E57RAL18T111E
E57RBL18T111E
E57RAL18T111ED
E57RBL18T111ED
E57RAL18T111EP
E57RBL18T111EP
E57RAL18T111EB1
E57RBL18T111EB1
3
3
3
3
3
3
3
3
3
3
Notes
1
3
3
3
3
3
3
3
3
V8-T3-21
3.2
3
3
Operating
Voltage
Standard Range
3
Sensing
Range (Sn)
Shielding
Connection Type 1
NO Output
Catalog Number
NC Output
Catalog Number
Shielded
(NPN)
2-meter cable
E57LAL30T110
E57LBL30T110
E57LAL30T110SD
E57LBL30T110SD
E57LAL30T110SP
E57LBL30T110SP
E57MAL30T110B1
E57MBL30T110B1
2-meter cable
E57LAL30T111
E57LBL30T111
E57LAL30T111SD
E57LBL30T111SD
E57LAL30T111SP
E57LBL30T111SP
6–48 Vdc
10 mm
(standard range)
3
3
Extended Range
Shielded
(PNP)
3
3
15 mm
(standard range)
3
Unshielded
(NPN)
3
3
Unshielded
(PNP)
3
3
22 mm
(extended range)
3
3
Semi-shielded
(NPN)
Semi-shielded
(PNP)
3
3
3
E57MAL30T111B1
E57MBL30T111B1
2-meter cable
E57LAL30T110E
E57LBL30T110E
E57LAL30T110ED
E57LBL30T110ED
E57LAL30T110EP
E57LBL30T110EP
E57MAL30T110EB1
E57MBL30T110EB1
2-meter cable
E57LAL30T111E
E57LBL30T111E
E57LAL30T111ED
E57LBL30T111ED
E57LAL30T111EP
E57LBL30T111EP
E57MAL30T111EB1
E57MBL30T111EB1
2-meter cable
E57-30LE22-C
E57-30LE22-C1
E57-30LE22-CD
E57-30LE22-C1D
E57-30LE22-CP
E57-30LE22-C1P
E57-30LE22-CB
E57-30LE22-C1B
2-meter cable
E57-30LE22-B
E57-30LE22-B1
E57-30LE22-BD
E57-30LE22-B1D
E57-30LE22-B1P
E57-30LE22-BB
E57-30LE22-B1B
Notes
3
1
3
3
3
3
3
3
3
3
3
3
3
3
V8-T3-22
3.2
3
Standard Cables 1
at 600V
Style
Micro-Style
Straight Female
Gauge
Length
22 AWG
6.0 ft (2m)
PVC Jacket
Catalog Number
PUR Jacket
Catalog Number
CSAS3F3CY2202
CSAS3F3RY2202
Mini-Style
Straight Female
Number
of Pins
AC
DC
3-pin,
3-wire
1-Green
2-Red/Black
3-Red/White
4-pin,
4-wire
22 AWG
6.0 ft (2m)
1-Brown
2-White
3-Blue
4-Black
13A
3-pin
16 AWG
6 ft (2m)
10A
AC/DC
4-pin,
4-wire
16 AWG
6 ft (2m)
1-Green
2-Black
3-White
1-Black
2-Blue
3-Brown
4-White
3
3
3
CSDS4A4CY2202
CSDS4A4RY2202
3
3
3
Catalog Number
3
CSMS3F3CY1602
3
3
CSMS4A4CY1602
3
3
3
Accessories
3
Description
Reference
3
Mounting brackets
See Tab 8,
section 8.2
3
Replacement mounting nuts and other accessories
See Tab 8,
section 8.3
3
Connector cables
See Tab 10,
section 10.1
3
3
Note
3
3
3
3
3
3
3
3
3
3
3
V8-T3-23
3.2
3
3
Description
Two-Wire AC Sensors
Two-Wire AC/DC Sensors
Three-Wire DC Only Sensors
3
Operating voltage
20–250 Vac
40–240 Vac 1
20–250 Vdc
6–48 Vdc
3
Maximum load current
500 mA at 77°F (25°C)
250 mA at 158°F (70°C)
500 mA at 6–30 Vdc
3
Switching frequency
20 Hz
60 Hz
12 mm: 800 Hz
18 mm: 500 Hz
30 mm: 300 Hz
Leakage current
1.7 mA maximum at 158°F (70°C)
≤2.0 mA
≤100 μA
Voltage drop
7V maximum
12V at 25 mA
≤2.5V
3
3
Holding current
5 mA minimum
5 mA minimum
Burden current
≤10 mA
3
Protection
Resettable short circuit; overload protection
Auto reset
Switching hysteresis
2 to 20% of rated sensing range
