DATASHEET - EASY-E4-DC-6AE1
I/O expansion, For use with easyE4, 24 V DC, Inputs expansion (number)
analog: 4, screw terminal
Delivery program
Part no.
Catalog No.
EL-Nummer
(Norway)
EASY-E4-DC-6AE1
197223
4500554
Product range
Control relays easyE4
Subrange
easyE4 analog input/output enhancements
Basic function
easyE4 extensions
Description
Input/output extension for easyE4 control relay
Expandable with the easyE4 series of digital input/output expansions with easy-E4CONNECT1 connector (Item Y7-197225)
Rated operating voltage 24V DC
Analog inputs: 4
Analog outputs: 2
Screw terminals
Inputs
Analog: 4
Analog
4
Display
with diagnostic LED
Software
Additional features
EASYSOFT-SWLIC/easySoft 7
Supply voltage
24 V DC
For use with
easyE4
Standards
EN 61000-6-2
EN 61000-6-3
IEC 60068-2-6
IEC 60068-2-27
IEC 60068-2-30
IEC 61131-2
EN 61010
EN 50178
Approvals
Technical data
General
Approvals
cULus
certificate
CE
shipping classification
DNV GL
Dimensions (W x H x D)
mm
35.5 x 90 x 58
Weight
kg
0.088
Mounting
Top-hat rail IEC/EN 60715, 35 mm or screw fixing using fixing brackets ZB4-101-GF1
(accessories)
Connection type
Screw terminal
Screw terminals
Terminal capacities
Solid
2
mm
0.2 - 4
flexible
mm
2
0.2 - 2.5
Solid or flexible conductor, with ferrule
mm
2
0,2 - 2,5
Solid or stranded
Standard screwdriver
AWG
22 - 12
mm
0.8 x 3.5
Tightening torque
Nm
0.5 - 0.7
Stripping length
mm
6.5
02/18/2020
Eaton Y7-197223 ED2020 V65.0 EN
1/6
Climatic environmental conditions
Operating ambient temperature
°C
-25 to 55, cold as per IEC 60068-2-1, heat as per IEC 60068-2-2
Condensation
Take appropriate measures to prevent condensation
Storage
ϑ
°C
-40 - +70
relative humidity
in accordance with IEC 60068-2-30, IEC 60068-2-78
5 - 95
Air pressure (operation)
hPa
795 - 1080
Protection type (IEC/EN 60529, EN50178, VBG 4)
IP20
Vibrations
Hz
In accordance with IEC 60068-2-6
constant amplitude 0.15 mm: 10 - 57
constant acceleration 2 g: 57 - 150
Mechanical shock resistance (IEC/EN 60068-2-27) semi-sinusoidal 15 g/11 ms
Impacts 18
Drop to IEC/EN 60068-2-31
Drop height
mm
50
Free fall, packaged (IEC/EN 60068-2-32)
m
0.3
Mounting position
Vertical or horizontal
Overvoltage category/pollution degree
III/2
Electrostatic discharge (ESD)
Ambient conditions, mechanical
Electromagnetic compatibility (EMC)
applied standard
according to IEC EN 61000-4-2
Air discharge
kV
8
Contact discharge
kV
6
Electromagnetic fields (RFI) to IEC EN 61000-4-3
V/m
0.8 - 1.0 GHz: 10
1.4 - 2 GHz: 3
2.0 - 2.7 GHz: 1
Radio interference suppression
EN 61000-6-3 Class B
Burst
kV
according to IEC/EN 61000-4-4
Supply cables: 2
Signal cables: 2
power pulses (Surge)
according to IEC/EN 61000-4-5
0.5 kV (supply cables, symmetrical)
1 kV (supply cables, asymmetrical)
Immunity to line-conducted interference to (IEC/EN 61000-4-6)
V
10
Clearance in air and creepage distances
nach EN 50178, EN 61010-2-201, UL61010-2-201, CSA-C22.2 NO. 61010-2-201
Insulation resistance
in accordance with EN 50178, EN 61010-2-201, UL61010-2-201, CSA-C22.2 NO.
61010-2-201
Rated operational voltage
Ue
V
24 DC (-15/+20%)
Permissible range
Ue
20.4 - 28.8 V DC
Residual ripple
≦5
Siemens MPI, (optional)
yes
Input current
max. 100 mA at Ue
Voltage dips
ms
≤ 10
Fuse
A
≧ 1A (T)
Power loss
P
W
Normally 2.5
Heat dissipation at 24 V DC
W
2.5
Number
4
Potential isolation
from power supply: no
to the in/outputs: no
to expansion devices: yes
Input type
Voltage or current, selectable per input
Signal range
0-10 V DC
0 - 20 mA
4 - 20 mA
Resolution
12 Bit (value 0 - 4095)
Cable length
m
≦ 10, screened
Number
2
Potential isolation
to the expansion units: yes
Power supply
Analog inputs
Analog outputs
02/18/2020
2/6
Output type
Signal range
0-10 V DC
0 - 20 mA
4 - 20 mA
Resolution
Accuracy
1
Cable length
-25 °C - 55 °C
m
≦ 10, shielded
Power loss
P
W
2.5
Supply voltage UAux
Design verification as per IEC/EN 61439
Technical data for design verification
Static heat dissipation, non-current-dependent
Pvs
W
2.5
Operating ambient temperature min.
°C
-25
Operating ambient temperature max.
°C
55
10.2 Strength of materials and parts
10.2.2 Corrosion resistance
Meets the product standard's requirements.
10.2.3.1 Verification of thermal stability of enclosures
10.2.3.2 Verification of resistance of insulating materials to normal heat
10.2.3.3 Verification of resistance of insulating materials to abnormal heat
and fire due to internal electric effects
10.2.4 Resistance to ultra-violet (UV) radiation
10.2.5 Lifting
Does not apply, since the entire switchgear needs to be evaluated.
10.2.6 Mechanical impact
10.2.7 Inscriptions
IEC/EN 61439 design verification
10.3 Degree of protection of ASSEMBLIES
10.4 Clearances and creepage distances
10.5 Protection against electric shock
10.6 Incorporation of switching devices and components
10.7 Internal electrical circuits and connections
Is the panel builder's responsibility.
10.8 Connections for external conductors
10.9 Insulation properties
10.9.2 Power-frequency electric strength
10.9.3 Impulse withstand voltage
10.9.4 Testing of enclosures made of insulating material
10.10 Temperature rise
The panel builder is responsible for the temperature rise calculation. Eaton will
provide heat dissipation data for the devices.
10.11 Short-circuit rating
10.12 Electromagnetic compatibility
10.13 Mechanical function
The device meets the requirements, provided the information in the instruction
leaflet (IL) is observed.
Technical data ETIM 7.0
PLC's (EG000024) / Logic module (EC001417)
Electric engineering, automation, process control engineering / Control / Programmable logic control (SPS) / Logic module (ecl@ss10.0.1-27-24-22-16 [AKE539014])
Supply voltage AC 50 Hz
V
0-0
Supply voltage AC 60 Hz
V
0-0
Supply voltage DC
V
20.4 - 28.8
Voltage type of supply voltage
DC
Switching current
A
0.5
Number of analogue inputs
4
Number of analogue outputs
2
Number of digital inputs
Number of digital outputs
With relay output
No
02/18/2020
3/6
Number of HW-interfaces industrial Ethernet
Number of interfaces PROFINET
Number of HW-interfaces RS-232
Number of HW-interfaces RS-422
Number of HW-interfaces RS-485
Number of HW-interfaces serial TTY
Number of HW-interfaces USB
Number of HW-interfaces parallel
Number of HW-interfaces Wireless
Number of HW-interfaces other
2
With optical interface
No
Supporting protocol for TCP/IP
No
Supporting protocol for PROFIBUS
No
Supporting protocol for CAN
No
Supporting protocol for INTERBUS
No
Supporting protocol for ASI
No
Supporting protocol for KNX
No
Supporting protocol for MODBUS
No
Supporting protocol for Data-Highway
No
Supporting protocol for DeviceNet
No
Supporting protocol for SUCONET
No
Supporting protocol for LON
No
Supporting protocol for PROFINET IO
No
Supporting protocol for PROFINET CBA
No
Supporting protocol for SERCOS
No
Supporting protocol for Foundation Fieldbus
No
Supporting protocol for EtherNet/IP
No
Supporting protocol for AS-Interface Safety at Work
No
Supporting protocol for DeviceNet Safety
No
Supporting protocol for INTERBUS-Safety
No
Supporting protocol for PROFIsafe
No
Supporting protocol for SafetyBUS p
No
Supporting protocol for other bus systems
No
Radio standard Bluetooth
No
Radio standard WLAN 802.11
No
Radio standard GPRS
No
Radio standard GSM
No
Radio standard UMTS
No
IO link master
No
Redundancy
No
With display
No
Degree of protection (IP)
IP20
Basic device
No
Expandable
Yes
Expansion device
Yes
With timer
No
Rail mounting possible
Yes
Wall mounting/direct mounting
Yes
Front build in possible
No
Rack-assembly possible
No
Suitable for safety functions
No
Category according to EN 954-1
SIL according to IEC 61508
None
Performance level acc. EN ISO 13849-1
None
Appendant operation agent (Ex ia)
No
02/18/2020
4/6
Appendant operation agent (Ex ib)
No
Explosion safety category for gas
None
Explosion safety category for dust
None
Width
mm
35.5
Height
mm
90
Depth
mm
58
UL File No.
E205091
UL Category Control No.
NRAQ/7
North America Certification
UL listed
Degree of Protection
IEC: IP20, UL/CSA Type: -
Approvals
Dimensions
02/18/2020
5/6
Assets (links)
Declaration of CE Conformity
00003205
Instruction Leaflets
IL050021ZU2019_02
Manuals
MN050009_EN (English)
Additional product information (links)
assembly instructions easyE4 IL050021ZU
ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL050021ZU2019_02.pdf
easyE4 (MN050009) manual
easyE4 – Handbuch (MN050009) - Deutsch
ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_DE.pdf
easyE4 (MN050009) manual - English
ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_EN.pdf
Manuale easy E4 (MN050009) - italiano
ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_IT.pdf
instrukcja easyE4 (MN050009) - polski
ftp://ftp.moeller.net/DOCUMENTATION/AWB_MANUALS/MN050009_PL.pdf
f1=1454&f2=1174&f3=1755;Download Software http://applications.eaton.eu/sdlc?LX=11&
easySoft V7
Product overview (WEB)
02/18/2020
http://www.eaton.eu/easyE4
Eaton Industries GmbH
http://www.eaton.eu
© 02/2020 by Eaton Industries GmbH
6/6
很抱歉,暂时无法提供与“EASY-E4-DC-6AE1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1700.969071+221.08450
