Bussmann
Ferrule
6-32A
FWC 600V
Size
Electrical Characteristics
I2t (A2S)
Rated
Current
Clearing
RMS-Amps
Pre-arc
at 600V
Ordering Information
Watts
Loss
Part
Number
6
4
30
1.5
8
6
50
2.0
10
9
70
2.5
10 ≈ 38mm
12
15
120
3.0
(⁄‹Ω£™∑)
16
25
150
3.5
260
4.8
25
60
390
6.0
32
95
600
7.5
n Interrupting rating 200kA RMS Symmetrical.
n Watts loss provided at rated current.
n (400 Vdc/Interrupting rating 50kA) U.L. Recognition: 32A
n (700 Vdc/Interrupting rating 50kA) U.L. Recognition: 6 - 25A
FWC-6A10F
FWC-8A10F
FWC-10A10F
FWC-12A10F
FWC-16A10F
FWC-20A10F
FWC-25A10F
FWC-32A10F
Carton
Qty.
10
Dimensions
Curves
Carton
Weight
(kg)
Figure
Number
BIF #
0.100
Fig. 1
35785306
1 kg = 2.2 lbs.
1 lb = 0.45 kg
Dimensions
Fig. 1: 6-32 Amp Range
38.1
(1.500")
10.3
(0.406")
9.5
(0.375")
Dimension in mm.
1mm = 0.0394∑
1∑ = 25.4mm
Total Clearing I2t
The total clearing I2t at rated voltage and
at power factor of 15% are given in the
electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K , given as
a function of applied working voltage,
E g , (RMS).
Arc Voltage
This curve gives the peak arc voltage,
U L , which may appear across the fuse
during its operation as a function of the
applied working voltage, E g , (RMS) at a
power factor of 15%.
2.0
1.5
K
1.6
1.0
0.5
0.3
0.2
0.15
100
Power Losses
Watts loss at rated current is given in
the electrical characteristics. The curve
allows the calculation of the power
losses at load currents lower than the
rated current . The correction factor, K p ,
is given as a function of the RMS load
current, Ib , in % of the rated current .
1.0
Kp
0.8
UL
1.2
0.6
0.5
103
0.4
800
0.3
600
500
0.2
400
Eg
250
400
500
600
300
200
Eg
300
400
500
600
0.1
30 40 50
Ib
60
70
80 90 100%
The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled.
This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right,
without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without
notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
7-18-01
SB01191
Form No.
Page 1 of 1
BIF Doc #720011
很抱歉,暂时无法提供与“FWC-20A10F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+187.270211+24.15940
- 5+168.525675+21.74120
- 10+149.7811410+19.32300
- 20+140.4088720+18.11390
