HS1225-3R8127-R
HS1225-3R8127-R
    EATON(伊顿)
    插件
    120 F (EDLC) 超级电容器 3.8 V 径向,Can 200 毫欧 70°C 时为 1000 小时
HS1225-3R8127-R 数据手册
Technical Data 11043 Effective April 2020 HS/HSL Supercapacitors Hybrid cylindrical cells HALOGEN Pb HF FREE Features and benefits • 3.8 V operating voltage for high energy • Low ESR for high power density • Up to 8 times energy density compared to standard supercapacitors • Low self discharge ideal for use with batteries • UL recognized Applications Description Eaton hybrid supercapacitors are high reliability, high power, ultra-high capacitance energy storage devices utilizing proprietary materials and processes. This combination of advanced technologies allows Eaton to offer a wide variety of capacitor solutions tailored to applications for backup power, pulse power and hybrid power systems. They can be applied as the sole energy storage or in combination with batteries to optimize cost, life time and run time. System requirements can range from a few microwatts to hundreds of watts. All products feature low ESR for high power density with environmentally friendly materials for a green power solution. Eaton supercapacitors are maintenance-free with design lifetimes up to 20 years* and operating temperatures down to -25 °C (HSL) and up to +85 °C (HS) . • Industrial backup/ride through • Backup for storage servers • Water and gas smart meters • IoT energy storage • Medical backup power/alarm • Commercial trucks/containers asset tracking *Supercapacitor lifetimes vary based on charge voltage and temperature. See Eaton’s application guidelines or contact your local Eaton sales representative for more information on lifetime estimates HS/HSL Supercapacitors Hybrid cylindrical cells  Technical Data 11043 Effective April 2020 Ratings Capacitance 30 F to 220 F Working voltage 3.8 V Minimum working voltage 2.2 V Surge voltage 4.0 V Capacitance tolerance -20% to +20% (+20 °C) Operating temperature range HSL: -25 °C to +60 °C HS: -15 °C to +70 °C Extended operating temperature range HS: -15 °C to +85 °C (with linear voltage derating to 3.5 V @ +85 °C) Specifications Capacitance1 (F) Part number Maximum initial ESR1 (mΩ) 30 HS/HSL1016-3R8306-R 550 Continuous current6 (A) 0.15 Peak current5 (A) Nominal leakage current2 (uA) HS/HSL Peak power4 (W) Stored energy3 (mWh) Short circuit current**7 (A) 2.7 3.0/4.0 6.6 40 7.0 50 HS/HSL1020-3R8506-R 450 0.25 3.4 4.0/5.0 8.0 67 9.0 70 HS/HSL1025-3R8706-R 250 0.35 6.1 5.0/8.0 14 93 15 120 HS/HSL1225-3R8127-R 200 0.6 7.7 7.0/12 18 160 19 220 HS/HSL1625-3R8227-R 100 1.1 15.3 12/25 36 293 38 ** Repeated short circuit current will permanently damage the leads. Performance Capacitance change (% of initial value) ESR (% of maximum initial value) Lifetime: (1000 hours, rated voltage, maximimum operating temperature) ≤ 30% ≤ 200% Charge/discharge cycles : HS: (500,000 at +20 °C), HSL: (250,000 at +20 °C) ≤ 30% ≤ 200% Storage: (3 years, uncharged,
HS1225-3R8127-R 价格&库存
很抱歉,暂时无法提供与“HS1225-3R8127-R”相匹配的价格&库存,您可以联系我们找货
HS1225-3R8127-R
  • 1000+67.61289
  • 10000+54.55461
库存:5
HS1225-3R8127-R
  • 1+96.16583
  • 3+91.70459
  • 5+87.24335
  • 10+82.78211
  • 20+78.32087
  • 50+73.93082
库存:19
HS1225-3R8127-R
