80NHG000B
80NHG000B
    EATON(伊顿)
    Rectangular,Blade
    FUSE SQUARE 80A 500VAC/250VDC
80NHG000B 数据手册
NH DIN Dual Indication Fuse Links NH Class gG/gL, 500Vac, 2 to 1250 Amps, Sizes 000 to 4 Standards/Approvals l IEC 60269, VDE 0636, DIN 43620 Part 1 and 3 Description A square bodied range of industrial fuse links for a wide variety of applications. Packaging All fuse links are packed in 3’s, except size 4 packed individually. Technical Data l Size: 000 to 4 l Rated voltage: 500Vac/250Vdc l Amps: 2 to 1250A l Rated breaking capacity: 120kA l Operating frequency: 45-62Hz l Design - Steatite insulator - Corrosion-resistant aluminium end plates - Corrosion-resistant plated steel screws l Contact blade: Full contact silver plated brass blades Catalogue Symbol l With metal gripping lugs: (amp)NHG(Size)B l With insulated metal gripping lugs: (amp)NHG(Size)BI Operation Class: gG/gL Fuse Holders l Fuse bases: SB*-D single-pole, TB*-D three-pole l Fuse rails - vertical: BFR l Fuse switch disconnectors vertical: BFD l Fuse switch disconnectors horizontal: BFH Environmental l 100% recyclable (including packaging) l RoHS compliant l Cadmium and lead free for sizes 000 to 4 Features l Reliable dual indicator system l Available with or without insulated metal gripping lugs * Select required size of fuse base Dimensions - mm Size a1 a2 (max) 78.5±1.5 54 000 78.5±1.5 0 125±2.5 00 01 1 02 2 03 3 4 23-04-09 135±2.5 135±2.5 150±2.5 150±2.5 150±2.5 150±2.5 200 a3 a4 b c1 c2 d e1 (max) e2 (max) e3 (max) e4 f (max) 2±0.5 48 30 25 6 15 6 15 54 45±1.5 49±1.5 15 35 10 2±0.5 68 62+3/-1.5 68+1.5/-3 15 35 11 2.5±0.5 75 62±2.5 68±2.5 11 2.5±0.5 75 75 75 75 75 84 SB-SB09366 45±1.5 62±2.5 62±2.5 62±2.5 62±2.5 62±2.5 80 49±1.5 68±2.5 68±2.5 68±2.5 68±2.5 68±2.5 90 15 15 20 20 25 25 32 50 Form No.NH500V 35 40 40 48 48 60 60 85 11 11 2.5±0.5 11 2.5±0.5 11 2.5±0.5 11 11 2.5±0.5 10 3±0.5 3 Page 1 of 9 41 48 48 53 53 61 61 75 102 21 30 30 52 52 60 60 70 87 Data Sheet 2142 16 25 25 25 25 25 25 25 - 6 6 6 6 6 6 6 8 8 15 15 15 15 15 18 30 NH DIN Dual Indication Fuse Links NH Class gG/gL, 500Vac, 2 to 100 Amps, Size 000 Size 000 Time-Current Characteristics 10 000 6 4 100 80 2 63 1 000 50 40 6 4 35 2 6 32 25 20 4 16 TIME (Seconds) 100 10 2 10 6 4 2 1 6 4 2 0.1 6 6 4 4 2 2 0.01 2 4 6 8 10 2 4 6 8 100 2 CURRENT (Amps) C 4 6 8 1000 2 Size 000 Technical Data Part Numbers with Metal Gripping Lugs Part Numbers with Insulated Metal Gripping Lugs 2NHG000B 4NHG000B I2t (Amps2 Seconds) Amp Rating Minimum Pre-arcing 20 x In @ 500Vac *I1 120kA @ 500Vac Watts Loss 2NHG000BI 2 4 4NHG000BI 4 6 - 6 3.9 - 12 6NHG000B 6NHG000BI 6 1.8 14 - 21 10NHG000B 10NHG000BI 2.0 10 58 290 252 16NHG000B 1.5 16NHG000BI 16 234 1170 1000 2.3 20NHG000B 20NHG000BI 20 584 3000 2400 2.2 25NHG000B 25NHG000BI 25 1000 4600 3700 2.8 32NHG000B 32NHG000BI 32 2400 11800 9400 3.7 35NHG000B 35NHG000BI 35 2400 11800 9400 3.7 40NHG000B 40NHG000BI 40 3300 16500 13200 4.0 50NHG000B 50NHG000BI 50 5600 27800 16700 4.9 63NHG000B 63NHG000BI 63 6300 24900 18700 4.6 80NHG000B 80NHG000BI 80 9800 38900 29200 6.3 100NHG000B 100NHG000BI 100 18100 72300 54300 7.4 * I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirement. Dimensions - mm 23-04-09 SB-SB09366 Form No.NH500V Page 2 of 9 Data Sheet 2142 Net Weight per Fuse 0.13 kg NH DIN Dual Indication Fuse Links NH Class gG/gL, 500Vac, 125 & 160 Amps, Size 00 Size 00 Time-Current Characteristics 10 000 6 4 160 125 2 1 000 6 4 2 100 6 TIME (Seconds) 4 2 10 6 4 2 1 6 4 2 0.1 6 4 2 0.01 6 8 10 2 4 6 8 100 2 CURRENT (Amps) 4 6 8 1000 2 4 6 Size 00 Technical Data Part Numbers with Metal Gripping Lugs Part Numbers with Insulated Metal Gripping Lugs 125NHG00B 160NHG00B I2t (Amps2 Seconds) Amp Rating Minimum Pre-arcing 20 x In @ 500Vac *I1 120kA @ 500Vac Watts Loss 125NHG00BI 125 25000 160NHG00BI 160 62000 125000 80000 11.2 310000 204600 11.2 * I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements. Dimensions - mm 23-04-09 SB-SB09366 Form No.NH500V Page 3 of 9 Data Sheet 2142 Net Weight per Fuse 0.190 kg NH DIN Dual Indication Fuse Links NH Class gG/gL, 500Vac, 10 to 160 Amps, Size 0 Size 0 Time-Current Characteristics 10 000 6 250 4 224 2 200 160 1 000 6 125 4 100 80 2 63 100 50 40 TIME (Seconds) 6 4 35 2 32 25 10 6 4 2 1 6 20 4 16 2 10 0.1 6 4 2 0.01 8 10 6 2 4 6 8 100 CURRENT (Amps) 2 4 6 8 1000 2 4 6 Size 0 Technical Data I2t (Amps2 Seconds) Part Number Amp Rating 10NHG0B *I1 120kA Watts Loss Minimum Pre-arcing 20 x In @ 500Vac 10 58 290 240 2.0 16NHG0B 16 240 1200 1000 3.0 20NHG0B 20 490 2500 2000 3.6 25NHG0B 25 1200 5600 4500 4.0 32NHG0B 32 1800 9000 7200 5.1 35NHG0B 35 2400 11800 9400 5.2 40NHG0B 40 3300 16500 13200 5.6 50NHG0B 50 5600 22300 16700 7.0 63NHG0B 63 6600 26100 19600 7.0 80NHG0B 80 9800 38900 29200 7.9 100NHG0B 100 20600 82300 61700 9.2 125NHG0B 125 25000 125000 72500 13.1 160NHG0B 160 62000 310000 179800 14.1 @ 500Vac * I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements. Dimensions - mm 23-04-09 SB-SB09366 Form No.NH500V Net Weight per Fuse Page 4 of 9 Data Sheet 2142 0.26kg NH DIN Dual Indication Fuse Links NH Class gG/gL, 500Vac, 10 to 250 Amps, Sizes 01 & 1 Sizes 01 & 1 Time-Current Characteristics 10 000 6 250 4 224 2 200 160 1 000 6 125 4 100 80 2 63 100 50 40 6 TIME (Seconds) 4 35 32 2 25 10 6 4 2 1 6 20 4 16 2 10 0.1 6 4 2 0.01 8 10 6 2 4 CURRENT (Amps) 6 8 100 2 4 6 8 1000 2 4 6 Sizes 01 & 1 Technical Data I2t (Amps2 Seconds) Part Numbers with Metal Gripping Lugs Part Numbers with Insulated Metal Gripping Lugs Amp Rating 10NHG01B 10NHG01BI 10 58 16NHG01B 16NHG01BI 16 240 20NHG01B 20NHG01BI 20 490 25NHG01B 25NHG01BI 25 32NHG01B 32NHG01BI 35NHG01B *I1 120kA @ 500Vac Watts Loss 300 300 2.0 1200 1000 3.0 2500 2000 3.6 1200 5600 4500 4.0 32 1800 9000 7200 5.1 35NHG01BI 35 2400 11800 9400 5.2 40NHG01B 40NHG01BI 40 3300 16500 13200 5.6 50NHG01B 50NHG01BI 50 5600 22300 16700 7.0 63NHG01B 63NHG01BI 63 6600 26100 19600 7.0 80NHG01B 80NHG01BI 80 9800 38900 29200 7.9 100NHG01B 100NHG01BI 100 20600 82300 61700 9.2 125NHG01B 125NHG01BI 125 25000 125000 72500 13.1 160NHG01B 160NHG01BI 160 62000 310000 179800 14.1 200NHG1B 200NHG1BI 200 97000 368600 291000 17.0 224NHG1B 224NHG1BI 224 124000 471200 372000 19.0 250NHG1B 250NHG1BI 250 151300 574900 453800 22.0 Minimum Pre-arcing 20 x In @ 500Vac * I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements. Dimensions - mm Size 1 Size 01 23-04-09 SB-SB09366 Form No.NH500V Page 5 of 9 Data Sheet 2142 Net Weight per Fuse 0.270kg 0.387kg NH DIN Dual Indication Fuse Links NH Class gG/gL, 500Vac, 35 to 400 Amps, Sizes 02 & 2 Sizes 02 & 2 Time-Current Characteristics 10 000 400 6 355 4 315 2 250 1 000 224 6 200 4 160 125 2 100 100 80 6 63 TIME (Seconds) 4 50 40 2 35 10 6 4 2 1 6 4 2 0.1 6 4 2 0.01 6 8 100 2 CURRENT (Amps) C 4 6 8 1000 2 4 6 8 10 000 2 Sizes 02 & 2 Technical Data I2t (Amps2 Seconds) Part Numbers with Metal Gripping Lugs Part Numbers with Insulated Metal Gripping Lugs Amp Rating 35NHG02B 35NHG02BI 40NHG02B 40NHG02BI 50NHG02B 20 x In *I1 120kA @ 500Vac @ 500Vac 35 2400 11800 9400 4.7 40 3300 16500 13200 5.2 50NHG02BI 50 5600 22300 16700 7.0 63NHG02B 63NHG02BI 63 6600 26100 19600 7.0 80NHG02B 80NHG02BI 80 9800 38900 29200 8.2 100NHG02B 100NHG02BI 100 20600 82300 61700 9.5 125NHG02B 125NHG02BI 125 25000 100000 72500 12.5 160NHG02B 160NHG02BI 160 62000 248000 179800 13.3 200NHG02B 200NHG02BI 200 96900 367900 290500 18.0 224NHG02B 224NHG02BI 224 124000 472000 372000 20.0 250NHG02B 250NHG02BI 250 151300 574900 453800 23.0 315NHG2B 315NHG2BI 315 361700 1446500 940300 26.0 355NHG2B 355NHG2BI 355 446500 1785800 1160800 31.0 400NHG2B 400NHG2BI 400 642900 2571500 1671500 34.0 * I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements. Dimensions - mm Size 2 Size 02 23-04-09 Watts Loss Minimum Pre-arcing SB-SB09366 Form No.NH500V Page 6 of 9 Data Sheet 2142 Net Weight per Fuse 0.402kg 0.630kg NH DIN Dual Indication Fuse Links NH Class gG/gL, 500Vac, 250 to 630 Amps, Sizes 03 & 3 Sizes 03 & 3 Time-Current Characteristics CURRENT (Amps) Sizes 03 & 3 Technical Data Part Numbers with Metal Gripping Lugs Part Numbers with Insulated Metal Gripping Lugs Amp Rating 250NHG03B 250NHG03BI 250 315NHG03B 315NHG03BI 315 355NHG03B 355NHG03BI 400NHG03B Minimum Pre-arcing I2t (Amps2 Seconds) 20 x In Watts Loss @ 500Vac *I1 120kA @ 500Vac 160800 642900 417900 23.0 361700 1446500 940300 26.0 355 446500 1785800 1160800 30.0 400NHG03BI 400 642900 2571500 1671500 35.0 500NHG3B 500NHG3BI 500 886000 3898400 2923800 37.0 630NHG3B 630NHG3BI 630 1590000 6996000 5406000 46.0 * I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements. Dimensions - mm Size 3 Size 03 23-04-09 SB-SB09366 Form No.NH500V Page 7 of 9 Data Sheet 2142 Net Weight per Fuse 0.64kg 1.050kg NH DIN Dual Indication Fuse Links NH Class gG/gL, 500Vac, 500 to 1250 Amps, Size 4 Size 4 Time-Current Characteristics CURRENT (Amps) Size 4 Technical Data I2t (Amps2 Seconds) Part Numbers with Metal Gripping Lugs Amp Rating Minimum Pre-arcing @ 500Vac 500NHG4G 500 800,000 3,850,000 37.0 630NHG4G 630 880,000 4,100,000 47.0 800NHG4G 800 1,500,000 6,480,000 68.0 1000NHG4G 1000 4,800,000 13,000,000 80.0 1250NHG4G 1250 7,000,000 18,000,000 108.0 *I1 120kA Watts Loss Net Weight per Fuse 2.2kg * I1 is the maximum breaking capacity test at rated voltage according to IEC 60269 requirements. Dimensions - mm Size 4 23-04-09 SB-SB09366 Form No.NH500V Page 8 of 9 Data Sheet 2142 NH DIN Dual Indication Fuse Links NH Class gG/gL, 500Vac, 2 to 1250 Amps, Sizes 000 to 4 Sizes 000 to 3 Cut-Off Current Characteristics PROSPECTIVE CURRENT (SYM. RMS kA) CUT-OFF CURRENT (kA PEAK) Size 4 Cut-Off Current Characteristics PROSPECTIVE CURRENT (SYM. RMS kA) 23-04-09 SB-SB09366 Form No.NH500V Page 9 of 9 Data Sheet 2142
80NHG000B 价格&库存
很抱歉,暂时无法提供与“80NHG000B”相匹配的价格&库存,您可以联系我们找货
