ACE1V2012-361-R
ACE1V2012-361-R
    EATON(伊顿)
    水平式,4 PC 板
    2 线路共模扼流圈 表面贴装型 360 Ohms @ 100 MHz 280mA DCR 400 毫欧
ACE1V2012-361-R 数据手册
Technical Data 10984 Effective October 2020 Supersedes November 2019 ACE1V2012 Automotive grade common-mode chip inductor Applications Product features • Controller area network (CAN) • Ethernet architectures • Automotive signal line filter • Advanced driver assistance systems (ADAS) • Infotainment, safety cameras, sensors, xEV, Powertrain • AEC-Q200 qualified Engine control unit (ECU) • • 0805 (2012 metric) package Electric power steering system (EPS) • • Impedance range from 90 ohms to 2200 ohms Battery management systems (BMS) • • Moisture sensitivity level (MSL): 1 Environmental compliance and general specifications • Operating temperature range: -40 °C to +105 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE ACE1V2012 Automotive grade common-mode chip inductor  Technical Data 10984 Effective October 2020 Product specifications Part number Common-mode impedance Z (Ω) at 100 MHz DCR (Ω) @ +25 °C maximum Idc (mA) maximum Rated voltage (Vdc) typical Insulation resistance (MΩ) minimum Withstanding voltage (Vdc) typical ACE1V2012-900-R 90 ±25% 0.3 400 50 10 125 ACE1V2012-121-R 120 ±25% 0.3 370 50 10 125 ACE1V2012-201-R 200 ±25% 0.35 330 50 10 125 ACE1V2012-361-R 360 ±25% 0.4 280 50 10 125 ACE1V2012-681-R 680 ±25% 0.8 220 50 10 125 ACE1V2012-102-R 1000 ±25% 1.5 190 50 10 125 ACE1V2012-222-R 2200 ±25% 2.0 150 50 10 125 1. Part Number Definition: ACE1V2012-xxn-R ACE1V2012 = Product code and size xx= impedance value in ohms, n= multiplication factor: 10^n (i.e. 900 = 90 * 10^0 = 90 ohms) -R suffix = RoHS compliant Mechanical parameters, schematic, pad layout (mm) Recommended pad layout B A Epoxy C D Terminations Wires E E F F Equivalent circuit 1 4 2 3 No polarity Part Number A B C D E F ACE1V2012-xxn-R 2.0 ±0.2 1.2 ±0.2 1.2 ±0.2 0.2 ±0.1 0.40 typ 0.45 typ All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended 2 www.eaton.com/electronics Technical Data 10984 ACE1V2012  Automotive grade common-mode chip inductor Effective October 2020  Packaging information (mm) Supplied in tape and reel packaging, 2000 parts per 7” diameter reel Ao 1.50±0.10 Bo 2.35±0.10 Ko 1.45±0.10 W 8.00±0.20 E 1.75±0.10 F 3.50±0.05 Po 4.0±0.05 P1 4.0±0.10 Do 1.0±0.1 www.eaton.com/electronics 3 ACE1V2012 Automotive grade common-mode chip inductor  Technical Data 10984 Effective October 2020 Performance curves ACE1V2012-121-R Impedance (Ω) Impedance (Ω) ACE1V2012-900-R Frequency (MHz) Frequency (MHz) ACE1V2012-201-R Impedance (Ω) Impedance (Ω) ACE1V2012-361-R Frequency (MHz) Frequency (MHz) Frequency (MHz) 4 ACE1V2012-102-R Impedance (Ω) Impedance (Ω) ACE1V2012-681-R www.eaton.com/electronics Frequency (MHz) ACE1V2012  Automotive grade common-mode chip inductor Technical Data 10984 Effective October 2020  Performance curves Impedance (Ω) ACE1V2012-222-R Frequency (MHz) Common mode measurement method: Differential mode measurement method: www.eaton.com/electronics 5 Technical Data 10984 ACE1V2012 Automotive grade common-mode chip inductor  Effective October 2020 Solder reflow profile Table 1 - Standard SnPb solder (Tc) Package thickness Volume mm3
ACE1V2012-361-R 价格&库存
很抱歉,暂时无法提供与“ACE1V2012-361-R”相匹配的价格&库存,您可以联系我们找货
ACE1V2012-361-R
    ACE1V2012-361-R
    • 1+4.787791+0.61938
    • 10+3.9272710+0.50806
    • 25+3.6301925+0.46962
    • 50+3.4216250+0.44264
    • 100+3.22627100+0.41737
    • 250+2.98459250+0.38611
    • 500+2.81417500+0.36406
    • 1000+2.653431000+0.34326
    库存:1268
    ACE1V2012-361-R
    • 2000+3.291492000+0.42581
    • 4000+3.103994000+0.40155
    • 6000+2.999426000+0.38802
    • 10000+2.8728310000+0.37165
    • 14000+2.7924414000+0.36125
    • 20000+2.7097820000+0.35056
    库存:1268
    ACE1V2012-361-R
    • 2000+2.68421
    • 10000+2.07966
    库存:1990
