AGA-3
AGA-3
    EATON(伊顿)
    D6.4xL15.88mm
    一次性保险丝(熔断) 3A 250V
AGA-3 数据手册
/4" x 5/8" Fast-Acting, Glass Tube Fuses 1 AGA Series Ordering • Specify packaging, product and option code Dimensions - mm (in) Description • • • • • Fast-acting /4" x 5/8" (6.4 x 15.9mm) physical size Glass tube, nickel-plated brass endcap construction Optional axial leaded version available UL Listed product meets standard 248-14 1 Rated Current /4 - 10A 1 Electrical characteristics % of Amp Rating Opening Time 100% 4 hours minimum 135% 60 minutes maximum 200% 120 seconds maximum Agency Information • UL Listed, Guide JDYX, File E19180 (AGA: 0 - 3 1/2A) • UL Recognized, Guide JDYX2, File E19180 (AGA: 12 - 30A) Specifications Part Number (Amps) AGA-1/10 AGA-1/4 AGA-1/2 AGA-3/4 AGA-1 AGA-1-1/2 AGA-2 AGA-2-1/2 AGA-3 AGA-5 AGA-6 AGA-7 AGA-7-1/2 AGA-10 AGA-15*** AGA-20*** AGA-25*** AGA-30*** Voltage Rating Vac 250 250 250 250 250 250 250 250 250 125 125 125 125 125 32 32 32 32 AC Interrupting Rating* (Amps) 250Vac 125Vac 32Vac 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 100 10,000 100 200 100 200 100 200 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 Typical DC ColdResistance (Ω)** Lower Upper 6.186 8.370 0.649 0.879 0.223 0.301 0.116 0.157 0.088 0.118 0.056 0.076 0.038 0.052 0.027 0.036 0.022 0.030 0.013 0.017 0.011 0.015 0.008 0.011 0.008 0.010 0.006 0.008 0.003 0.004 0.002 0.003 0.001 0.002 0.001 0.002 * Interrupting Rating: Interrupting ratings has been measured at 70%-80% power factor. ** DC Cold Resistance (Measured at
AGA-3
PDF文档中包含了以下信息: 1. 物料型号:型号为LM358P。
2. 器件简介:LM358P是一款双运算放大器,具有低功耗、低输入偏置电流、高输入阻抗等特点,适用于各种线性应用。
3. 引脚分配:LM358P有8个引脚,包括电源、地、输入和输出引脚。
4. 参数特性:包括电源电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:LM358P可以用于信号放大、滤波、比较器等多种应用。
6. 应用信息:适用于工业控制、医疗设备、消费电子等领域。
7. 封装信息:提供多种封装形式,如SOIC、DIP等。
AGA-3 价格&库存
很抱歉,暂时无法提供与“AGA-3”相匹配的价格&库存,您可以联系我们找货
AGA-3
    • 1+3.58560
    • 200+1.43640
    • 500+1.38240
    • 1000+1.36080
