BK/GMA-15-R
BK/GMA-15-R
    EATON(伊顿)
    D5.2xL20mm
    一次性保险丝(熔断) 15A 125V
BK/GMA-15-R 数据手册
Effective May 2017 Supersedes April 2010 Technical Data 2017 GMA 5 mm x 20 mm Fast-acting glass tube fuses Agency information • UL Listed, Guide JDYX, File E19180, 63mA-6A • UL Recognized, Guide JDYX2, File E19180, 7-15A • CSA Certified, Class 1422-01, File 53787, 63mA-6A • PSE Approval, 1A-15A Ordering • • Product features • Fast-acting, low breaking capacity Optional axial leads available 5 x 20mm physical size Glass tube, silver-plated (63mA-315mA) and nickel-plated (500mA-15A) brass endcap construction • Designed to UL/CSA 248-14 • • • • Product Code GMA-63-R GMA-100-R GMA-125-R GMA-200-R GMA-250-R GMA-300-R GMA-315-R GMA-500-R GMA-600-R GMA-750-R GMA-800-R GMA-1-R GMA-1.25-R GMA-1.5-R GMA-1.6-R GMA-2-R GMA-2.5-R GMA-3-R GMA-3.15-R GMA-3.5-R GMA-4-R GMA-5-R GMA-6-R GMA-7-R GMA-8-R GMA-10-R GMA-15-R * ** † ‡ Amp Rating 63mA 100mA 125mA 200mA 250mA 300mA 315mA 500mA 600mA 750mA 800mA 1 1.25 1.5 1.6 2 2.5 3 3.15 3.5 4 5 6 7 8 10 15 Voltage Rating Vac 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 250 125 125 125 125 125 125 125 125 125 Specify packaging, product, and option code Ratings above 6.3A have a 0.8 mm diameter lead With TR2 packaging code, lead wire length is 19.05 mm Rated Current 63mA - 15A Specifications Interrupting Rating (amps)* 250Vaa c 125Vac 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 35 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 100 10,000 10,000 10,000 10,000 10,000 10,000 200 200 200 150 Typical DC Cold Resistance (Ω)** 15.750 7.840 4.895 2.500 1.735 0.906 0.839 0.454 0.256 0.186 0.170 0.163 0.122 0.090 0.080 0.066 0.046 0.039 0.036 0.030 0.026 0.021 0.017 0.012 0.009 0.006 0.004 Electrical Characteristics % of Amp Rating Opening Time 100% None 135% 60 minutes maximum 200% 2 minutes maximum Typical Pre-Arc I 2t Vac† 0.00024 0.0001 0.0024 0.001 0.018 0.019 0.019 0.15 0.32 0.47 0.70 0.48 0.84 1.6 2.0 3.1 4.9 8.8 9.7 13 19 29 45 150 280 280 950 Maximum Voltage Drop (mV)‡ 4700 4300 2600 3400 2200 470 450 230 200 200 180 300 290 270 260 250 240 215 210 210 205 200 180 110 110 110 100 Interrupting ratings: Interrupting ratings for 63mA - 6A were measured at 70% - 80% power factor on AC. The interrupting ratings for 7A - 15A were measured at 100% power factor on AC. DC Cold Resistance (Measured at
BK/GMA-15-R 价格&库存
很抱歉,暂时无法提供与“BK/GMA-15-R”相匹配的价格&库存,您可以联系我们找货
