BK/TDC180-13
BK/TDC180-13
    EATON(伊顿)
    8AG,1/4" x 1"
    FUSE CARTRIDGE 13A 240VAC 8AG
BK/TDC180-13 数据手册
Bussmann® TDC180 British Plug Top Fuse Fast/Medium Dimensional Data 25.4mm +0.8 -0.4 6.3mm +0.2 -0.05 5.5mm + 0.8 Catalog Symbol:TDC180 FAST/MEDIUM BRITISH PLUG TOP FUSE 240Vac BS1362, IEC 269-3A Limits for Pre-arcing Time 1.0 In. 1.6 In. 1.9 In. Electrical Ratings (Catalog Symbol and Amperes) In MIN MIN MAX 1A - 13A 1000 hours 30 min. 30 min. 240Vac TDC180-1A TDC180-5A TDC180-13A TDC180-2A TDC180-7A — TDC180-3A TDC180-10A — Envelope Rated Current Rated Volt AC Breaking Capacity Power Dissipation Max. 1A Color Approvals AMPERE RATING 100 Black 2A Black 240 5A (264 max.) 7A 6000A 264VAC, 50Hz p.f. 0.3 - 0.4 Red 1 Watt Black Asta, Black CCC 10A Black 13A Brown • Type TDC180. • 1/4” x 1” fast/medium British plug top fuse. • Ceramic tube - end caps: - 2-5A nickel-plated brass - 1A & 7A silver-plated copper - 10-13A nickel-plated copper • Packaging: x 10, x 100, x 1000. 10 TIME IN SECONDS 3A 1 100 10 .01 .1 CE logo denotes compliance with European Union Low Voltage Directive (50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact Bussmann Application Engineering at 636-527-1270 for more information. 1 .1 TIMES RATED CURRENT Complies with EU Directive 2002/95/EC (RoHS) The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this Data Sheet are by definition uncontrolled. This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications. 0111 BU-SB11079 Form No. TDC180 Page 1 of 1 Data Sheet: 2042
BK/TDC180-13 价格&库存
很抱歉,暂时无法提供与“BK/TDC180-13”相匹配的价格&库存,您可以联系我们找货
BK/TDC180-13
