DEL-SL4-FL120-A
DEL-SL4-FL120-A
    EATON(伊顿)
    VISUAL SIGNAL INDICATOR, 40MM, 120V, AMBER
DEL-SL4-FL120-A 数据手册
SL7 and SL4 signal towers Product Range Catalog Clearly brighter, louder und faster Eaton Online Catalog – find product details quickly and efficiently! You can find comprehensive up-to-date product information at http://de.ecat.moeller.net Lookup You can search by keywords, product names, article numbers, technical data: The search understands everything and takes you straight to the product you’re looking for. Graphical navigation Graphical representation of the fields of application and product groups. Selection aids Tailored to the typical expert’s approach, this search aid helps you quickly find the product you need. HTML data sheet; can be saved as PDF file. Data sheets For every article the catalog can generate a technical data sheet, which you can convert to a PDF file for printing or saving with a single click. Parts lists From your search results you can create a parts list that you can then send to your Eaton sales partner as a query. Parts list, e.g. for queries to Eaton Sales. You can find comprehensive up-to-date information about Eaton’s automation products and switchgear in our Online Catalog. Doppelseite_GB.indd 23 10.05.12 14:42 Signal towers Signal towers SL7 6 System overview Ordering 8 Ordering 24 Complete devices 24 Customised complete unit 8 Customised complete unit 24 Card with LED 8 Card with LED 24 Flashing light Strobe light Card with high-output LED 8 Continuous light 24 9 Flashing light 25 Strobe light 26 Multistrobe light 26 10 11 Continuous light 11 Flashing light 11 Strobe light 11 Acoustic modules 27 11 Basic modules 28 Card for filament lamp Card for filament lamp 27 Continuous light 27 11 Mounting brackets 29 Acoustic modules 12 Including mounting bracket M20 cable gland 29 Basic modules 13 Tool for replacing filament lamp 29 Mounting brackets 14 Filament bulbs 29 Including mounting bracket M20 cable gland 14 Tool for replacing filament lamp 14 Filament bulbs 14 Technical data Dimensions Technical data 15 17 Complete devices 17 Light modules 17 Acoustic modules 17 Basic modules 18 Base module for connecting to SmartWire-DT® 20 Accessories 20 30 Dimensions 261 mm (10.28") Continuous light 295 mm (11.61") 22 8 Continuous light ⌀ 72 mm (⌀ 2.84") Signal towers SL4 System overview Complete devices 1 ⌀ 72 mm (⌀ 2.84") 32 Complete devices 32 Light modules 32 Acoustic modules 32 Basic modules 33 Base module for connecting to SmartWire-DT® 35 Accessories 35 ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") CA047002EN-INT www.eaton.eu Energizing a world that demands more. Discover today’s Eaton. Powering business worldwide As a global diversified power management company, we help customers worldwide manage the power needed for buildings, aircraft, trucks, cars, machinery and businesses. Eaton’s innovative technologies help customers manage electrical, hydraulic and mechanical power more reliably, efficiently, safely and sustainably. Unbenannt-1 2 25.04.13 11:24 We provide integrated solutions that help make energy, in all its forms, more practical and We deliver: s Electrical solutions that use less energy, improve power reliability and make the places we live and work safer and more comfortable accessible. With 2012 sales of $16.3 billion, Eaton s Hydraulic and electrical solutions that enable machines to deliver more productivity without wasting power s has approximately 103,000 employees Aerospace solutions that make aircraft lighter, safer and less costly to operate, and help airports operate more efficiently around the world and sells products in more than 175 countries. s Vehicle drivetrain and powertrain solutions that deliver more power to cars, trucks and buses, while reducing fuel consumption and emissions Eaton’s electrical business Eaton is a global leader with expertise in: %ATONISPOSITIONEDTHROUGHITSGLOBALSOLUTIONSTOANSWER TODAYSMOSTCRITICALELECTRICALPOWERMANAGEMENTCHALLENGES 7ITHYEARSOFELECTRICALEXPERIENCEBEHINDUS WERE ENERGIZEDBYTHECHALLENGEOFPOWERINGUPAWORLDTHAT DEMANDSTWICEASMUCHENERGYASTODAY7EREANTICIPATING NEEDS ENGINEERINGPRODUCTS ANDCREATINGSOLUTIONSTO ENERGIZEOURMARKETSTODAYANDINTHEFUTURE s 0OWERDISTRIBUTIONANDCIRCUITPROTECTION s "ACKUPPOWERPROTECTION s 3OLUTIONSFORHARSHANDHAZARDOUSENVIRONMENTS s ,IGHTINGANDSECURITY s 3TRUCTURALSOLUTIONSANDWIRINGDEVICES s #ONTROLANDAUTOMATION 7EAREDEDICATEDTOENSURINGTHATRELIABLE EFFICIENTANDSAFE POWERISAVAILABLEWHENITSNEEDEDMOST s %NGINEERINGSERVICES www.eaton.eu Unbenannt-1 3 25.04.13 11:24 Clearly Eaton! Eaton has the entire machine in view – from the control panel to the peripherals. Its optimized signal towers can now guarantee even better control over all key processes and with it increased availability for your machines. Clearly MORE EFFICIENT! An essential part of Eaton’s Lean Solution approach, SmartWire-DT is a technology designed to reduce electrical engineering costs for machines by up to 30%. Signal towers are an important component of this technology, since the advance warning function provides information that help the operator avoid potential standstills and increase availability Potential failures are not just detected in advance by intelligent switchgear, but in fact are also signalized by signal towers with SmartWire-DT. Example: Savings in every step of the life cycle Lean Solution Saving 30% Conventional solution Planning / engineering Material Wiring Commissioning Maintenance Clearly LOVELIER! An engaging design with smooth curves enhances the appeal of our new signal towers and, together with the control and signal units in the RMQ-Titan range of products, creates a standardized look for machines and systems. Katalog-Doppelseite.indd 4 05.04.13 10:56 Clearly LOUDER! Clearly BRIGHTER! Clearly MORE COMPACT! Clearly MORE FLEXIBLE! Acoustic modules with up to 8 selectable signals, as well as adjustable volume levels (up to 100 dB), make it possible to adapt perfectly to any environment. SL 7 70 mm SL 4 40 mm Signal towers indicate machine states by means of visual and acoustic signals. Accordingly, they must be easy to see from a distance, and the information they provide must be clear from the get-go. Orange has been added to the colors shown in order to comply with international standards. More importantly, Eaton has improved its signal towers exactly where it counts. Highperformance LEDs provide a level of brightness that will be reliably seen even under extremely adverse conditions. Benefit from better attention-getting power, stronger brightness and higher volumes as well as multiple tone variants to identify faults unambiguously or even help prevent them from occurring at all. Eaton signal towers have been designed with flexibility in mind so that they can be used regardless of adverse installation conditions, such as the lack of ceiling clearance and situations that require different signals on the right or left-hand side. Both signal tower sizes can also be installed vertically with up to 5 elements per side. Our new signal towers can be flexibly installed in any of 9 different ways. In addition to the option of mounting them on the side, there are various options for mounting the cupshaped base directly, as well as a variety of tube mounting options. In addition, tubes with lengths of 100, 250, and 400 mm make mounting even more flexible. Mounting and dismantling of protruding signal towers can be a major effort, particularly when transporting machines. The new rapid-mount system speeds up that process by up to 50%. Clearly STURDIER! Katalog-Doppelseite.indd 5 With a high IP66 degree of protection, our signal towers provide perfect protection even against water jets from all directions. These signal towers are meant for worldwide use. Type approvals and certifications for Europe and North American have already been obtained, and ship classifications and CCC are currently pending. The transportation cover protects cables and terminals. 05.04.13 10:56 6 Signal towers SL7 System overview SL7 5a 5b 7 7 5c 1 2, 2a, 2b 3 4, 4a, 4b, 4c 6, 6a 6b 6c 6d 6e 6f 6g 6h 7 7 CA047002EN-INT www.eaton.eu 6i Signal towers 7 SL7 Card for filament lamp, continuous light 1 Without light element (filament lamp with BA15d socket) Easy mounting with bayonet mount Modules can be arranged in any order Degree of protection IP66 Easy mounting with bayonet mount Flashing frequency 1.4 Hz Degree of protection IP66 → page 10 Including cover plate 4b with High Performance LED Base for mounting on both sides Flashing frequency 1.4 Hz → page 14 6a → page 11 Card with high-output LED 2 4c with High Performance LED with various strobe sequences Flashing frequency 1 - 2.6 Hz → page 11 Modules can be arranged in any order Degree of protection IP66 Acoustic module Max. 2 x 5 modules that can be actuated individually (two with base module SL7-CB-D only) Operating mode: 100 % DF (duty factor) Base with aluminium tube and plastic foot 5 6b Aluminium tube 100 mm, 250 mm or 400 mm → page 13 Base with aluminum tube and banjo bolt Easy mounting with bayonet mount 6c Aluminium tube 100 mm, 250 mm or 400 mm → page 13 Set up as topmost module 2a Max. 2 x 1 modules that can be actuated separately (two with base module SL7-CB-D only) Permanently integrated cover plate with LED Degree of protection IP66 → page 8 Operating mode: 100 % DF (duty factor) sound pressure 100 db, adjustable with internal potentiometer Card with high-output LED 6 Base module with LED Card with high-output LED Easy mounting with bayonet mount Card with LED 4a With spring-cage terminals Max. 2 x 5 modules that can be actuated individually (two with base module SL7-CB-D only) Operating mode: 100 % DF (duty factor) → page 11 Card with LED, continuous light Card with LED 2b Base with external fixing holes One-sided base with bracket Base with internal (on the inside) fixing holes 5a → page 11 Acoustic module Card with LED, flashing light Continuous tone or pulsed tone, adjustable with internal dip switches Frequency: 2800 Hz Base with built-in (pre-assembled) fixing screws → page 12 → page 13 with LED 6e → page 14 with High Performance LED 3 6d → page 13 6f → page 13 6g Easy mounting with bayonet mount Modules can be arranged in any order Degree of protection IP66 Acoustic module Max. 2 x 5 modules that can be actuated individually (two with base module SL7-CB-D only) Operating mode: 100 % DF (duty factor) Flashing frequency 2 Hz Acoustic module Easy mounting with bayonet mount Modules can be arranged in any order Degree of protection IP66 Max. 2 x 5 modules that can be actuated individually (two with base module SL7-CB-D only) Operating mode: 100 % DF (duty factor) 4 Continuous tone or pulsed tone; can be actuated externally; takes up 2 inputs (2 modules) Frequency: 2800 Hz → page 12 Base with base adapter for slipping onto place (rapid mounting and wiring system) 6h Aluminium tube 100 mm, 250 mm or 400 mm → page 13 → page 12 → page 9 Card with LED, strobe light 5b Multi-tone (8 tones) adjustable with internal dip switch Frequency 500 - 2700 Hz 5c Base with base adapter for slipping onto place (rapid mounting and wiring system) and SmartWire-DT connection 6i Aluminium tube 100 mm → page 13 Accessory Considerations 7 Mounting brackets Including mounting bracket M20 cable gland Tool for replacing filament lamp Filament lamp → page 14 CA047002EN-INT www.eaton.eu 8 Signal towers SL7, Complete devices, Light modules Ordering SL7, Complete devices, Light modules Rated operational voltage Ue Number of modules Colour Function Part no. Article no. Price see price list Std. pack V Complete devices Continuous light, LED, IP66, Base module with foot and 100 mm tube 24 V AC/DC 2 SL7-100-L-RG-24LED 171424 1 off SL7-100-L-RYG-24LED 171425 3 Customised complete unit Order on request , * = Freely selectable customer identification or stock no., Maximum 10 characters - Rated operational voltage Ue Colour Function SL7-COMBINATION-* 171386 Part no. Article no. 1 off Price see price list Std. pack V Card with LED Continuous light IP66 Notes SL7-L24-B 171461 SL7-L24-G 171462 SL7-L24-R 171463 SL7-L24-W 171464 SL7-L24-Y 171465 SL7-L24-A 171466 110/120 V AC SL7-L120-B 171467 SL7-L120-G 171468 SL7-L120-R 171469 SL7-L120-W 171470 SL7-L120-Y 171471 SL7-L120-A 171472 230/240 V AC SL7-L230-B 171473 SL7-L230-G 171474 SL7-L230-R 171475 SL7-L230-W 171476 SL7-L230-Y 171477 SL7-L230-A 171426 1 off Information relevant for export to North America Product Standards UL File No. UL CCN CA047002EN-INT 24 V AC/DC www.eaton.eu IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 1410; CSA-C22.2 No. 94-91; CE marking E29184 NKCR CSA File No. CSA Class No. NA Certification Degree of Protection UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 Signal towers 9 SL7, Light modules SL7, Light modules Rated operational voltage Ue Colour Function Part no. Article no. Price see price list Std. pack V Card with LED Flashing light IP66 2 Hz Notes 24 V AC/DC SL7-BL24-B 171439 SL7-BL24-G 171440 SL7-BL24-R 171441 SL7-BL24-W 171442 SL7-BL24-Y 171388 SL7-BL24-A 171389 110/120 V AC SL7-BL120-B 171390 SL7-BL120-G 171391 SL7-BL120-R 171392 SL7-BL120-W 171393 SL7-BL120-Y 171394 SL7-BL120-A 171395 230/240 V AC SL7-BL230-B 171396 SL7-BL230-G 171397 SL7-BL230-R 171398 SL7-BL230-W 171399 SL7-BL230-Y 171400 SL7-BL230-A 171401 1 off Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 CA047002EN-INT www.eaton.eu 10 Signal towers SL7, Light modules Rated operational voltage Ue Colour Function Part no. Article no. Price see price list Std. pack V Card with LED Strobe light IP66 1.4 Hz Notes SL7-FL24-B 171402 SL7-FL24-G 171403 SL7-FL24-R 171404 SL7-FL24-W 171405 SL7-FL24-Y 171406 SL7-FL24-A 171407 110/120 V AC SL7-FL120-B 171408 SL7-FL120-G 171409 SL7-FL120-R 171410 SL7-FL120-W 171411 SL7-FL120-Y 171412 SL7-FL120-A 171413 230/240 V AC SL7-FL230-B 171414 SL7-FL230-G 171415 SL7-FL230-R 171416 SL7-FL230-W 171417 SL7-FL230-Y 171418 SL7-FL230-A 171419 Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection CA047002EN-INT 24 V AC/DC www.eaton.eu IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 1 off Signal towers 11 SL7, Light modules Rated operational voltage Ue Colour Function Part no. Article no. Price see price list Std. pack V Card with high-output LED Continuous light IP66 High-performance LED for maximum signaling effect High Performance LED 24 V AC/DC SL7-L24-B-HP 171427 SL7-L24-G-HP 171428 SL7-L24-R-HP 171429 SL7-L24-W-HP 171430 SL7-L24-Y-HP 171431 SL7-L24-A-HP 171432 Strobe light IP66 High-performance LED for maximum signaling effect High Performance LED 1.4 Hz 24 V AC/DC SL7-FL24-B-HP 171420 SL7-FL24-G-HP 171421 SL7-FL24-R-HP 171422 SL7-FL24-W-HP 171423 SL7-FL24-Y-HP 171273 SL7-FL24-A-HP 171274 Multistrobe light IP66 High-performance LED for maximum signaling effect High Performance LED 1 - 2.6 Hz 24 V AC/DC SL7-FL24-B-HPM 171275 SL7-FL24-G-HPM 171276 SL7-FL24-R-HPM 171277 SL7-FL24-W-HPM 171278 SL7-FL24-Y-HPM 171279 SL7-FL24-A-HPM 171280 < 250 V AC/DC SL7-L-B 171433 SL7-L-G 171434 SL7-L-R 171435 SL7-L-W 171436 SL7-L-Y 171437 SL7-L-A 171438 1 off Card for filament lamp Continuous light IP66 without light elements Filament lamp max. 7 W Filament bulbs → page 14 Notes 1 off Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 CA047002EN-INT www.eaton.eu 12 Signal towers SL7, Acoustic modules SL7, Acoustic modules Rated operational voltage Ue Rated operational current Ie V mA Colour Function Sound type Part no. Article no. Price see price list Std. pack Acoustic modules Continuous tone or pulsed tone, adjustable with internal dip switches. Sound pressure 100 db, adjustable with internal potentiometer. f = 2800 Hz Place only at the highest position on a pole IP66 24 V AC/DC max. 92 110/120 V AC max. 41 230/240 V AC max. 43 Continuous tone or pulsed tone, external actuation. Assigned two inputs (2 modules). Sound pressure 100 db, adjustable with internal potentiometer. f = 2800 Hz Place only at the highest position on a pole IP66 24 V AC/DC max. 92 110/120 V AC max. 41 230/240 V AC max. 43 Multi-tone; 8 tones, adjustable with internal dip switch. Sound pressure 100 db, adjustable with internal potentiometer. f = 500 - 2700 Hz Place only at the highest position on a pole IP66 24 V AC/DC max. 115 Notes 110/120 V AC max. 45 230/240 V AC max. 43 1 off SL7-AP24-E 171284 SL7-AP120-E 171285 SL7-AP230-E 171286 1 off SL7-AP24-M 171287 SL7-AP120-M 171288 SL7-AP230-M 171289 1 off Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection CA047002EN-INT SL7-AP24 171281 SL7-AP120 171282 SL7-AP230 171283 www.eaton.eu IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 Signal towers 13 SL7, Basic modules SL7, Basic modules Tube length Colour For use with Part no. Article no. 100 mm black Aluminum color tube SL7-L-… SL7-BL-… SL7-FL-… SL7-AP-… SL7-CB-100 171443 SL7-CB-250 171444 SL7-CB-400 171445 Price see price list Std. pack Basic modules for horizontal mounting including cover max. 5 modules Base with aluminium tube and plastic foot Spring-loaded terminals 250 mm 400 mm Base with aluminum tube and banjo bolt Spring-loaded terminals SL7-CB-T-100 171452 SL7-CB-T-250 171453 SL7-CB-T-400 171454 100 mm 250 mm 400 mm SL7-CB-IMH1) 171447 Base with internal (on the inside) fixing holes Spring-loaded terminals - Base with built-in (pre-assembled) fixing screws Spring-loaded terminals - SL7-CB-IMS 171448 Base with external fixing holes Spring-loaded terminals - SL7-CB-EMH 171449 Base with base adapter for slipping onto place (rapid mounting and wiring system) Screw terminals 100 mm 250 mm black black Aluminum color tube 400 mm Base with base adapter for slipping onto place (rapid mounting and wiring system) Blade terminal SWD4-8MF2 max. 0.3 A per module External power supply connectable (24 V DC) Configurable with SWD‐Assist (planning and ordering help) Notes 1 off SL7-FMS-100 171456 SL7-FMS-250 171457 SL7-FMS-400 171458 SL7-SWD2) 171459 100 mm Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 1410; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 1) Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 1410; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 1 2) Product Standards NA Certification Degree of Protection CA047002EN-INT IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSAC22.2 No. 94-91; CE marking Request filed for UL and CSA UL Type 4, 4X, 13 www.eaton.eu 14 Signal towers SL7, Basic modules, Accessories SL7, Basic modules, Accessories Colour For use with Part no. Article no. Price see price list black SL7-L-… SL7-BL-… SL7-FL-… SL7-AP-… SL7-CB-FW 171450 1 off black SL7-L-… SL7-BL-… SL7-FL-… SL7-AP-… SL7-CB-D 171451 1 off Power For use with Part no. Article no. - SL4-PIB… SL7-CB... SL7/4-FW 171446 1 off - - SL4-PIB-T… SL7-CB-T... SL7/4-FW-T 171455 1 off - - - - SL7/4-BET 171294 1 off > 3000 12 V 5W SL7-L-… 1 off 24 V 6.5 W 120 V 7W 230 V 6.5 W SL7-L12 171290 SL7-L24 171291 SL7-L120 171292 SL7-L230 171293 Std. pack Basic modules for vertical mounting, including cover, max. 5 modules One-sided base with bracket Spring-loaded terminals for vertical mounting on both sides, including cover, max. 2 x 5 modules Base with external fixing holes Spring-loaded terminals lifespan Rated operational voltage Ue h V Price see price list Std. pack Mounting brackets for vertical mounting, Plastic - - Including mounting bracket M20 cable gland for vertical mounting, Metal - Tool for replacing filament lamp Filament bulbs Mounting: Ba15d Notes Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection CA047002EN-INT www.eaton.eu IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 Signal towers 15 SL7 Technical data SL7 SL7-… General Standards IEC/EN 60947-5-1 Climatic proofing Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60069-2-30 As required Mounting position Mechanical shock resistance g > 15 according to IEC 60068-2-27 Shock duration 11 ms Sinusoidal IP66 IEC/EN 60529 Type 4, 4X, 13 IEC degree of protection Protection type UL Material Enclosure: Polycarbonate (PC), black Cap: Polycarbonate (PC) Cap colour blue, green, red, clear, yellow, orange Ambient temperature °C -30 - +60 Number of signal elements Max. 5 with standard base Max. 10 with base for mounting on both sides Terminal capacity Solid or flexible conductor mm2 0.13 - 2.5 Flexible with ferrule with plastic collar mm2 0.25 - 1.5 AWG 24 - AWG 14 Contacts Rated impulse withstand voltage Uimp V AC 4000 Rated insulation voltage Ui V 250 Overvoltage category/pollution degree III/3 SL7-L-…-… SL7-BL-…-… SL7-FL-…-… SL7-L24-…-HP Flashing light Strobe light Light elements Continuous light LED Mounting - - Flashing/strobe frequency - 2 Hz Transmission angle 360° SL7-FL24-…-HP SL7-FL24-…-HPM SL7-L-… Continuous Strobe light light High Performance LED Multistrobe light Continuous light - - - - Filament lamp max. 7 W Ba15d 1.4 Hz - 1.4 Hz 1 - 2.6 Hz - Module Type of light Leakage current A < 0.003 Current-/power consumption 24 V AC/DC A 0.049 - 0.054 0.058 0.130 - 0.135 0.170 - 0.200 0.260 - 0.265 0.260 - 0.265 - 110 /120 V AC A 0.028 - 0.031 0.028 - 0.030 0.010 - - - - 230 /240V AC A 0.027 - 0.028 0.030 - 0.031 0.010 - - - - - - - - - - Max. 7 W with the specified voltages up to 250 V AC/DC Power consumption Voltage levels lifespan h 24 V AC/DC ± 10 % 110/120 V AC ± 10 % 230/240 V AC ± 10 % > 100000 Weight g 80 18-30 V DC/18-26 V AC > 50000 > 3000 CA047002EN-INT www.eaton.eu 16 Signal towers SL7 SL7-AP… SL7-AP…-E SL7-AP…-M Type of tone Continuous or pulsed tone Continuous or pulsed tone Types of sound 2 versions, table of sound types 2 versions, table of sound types Continuous or pulsed tone 8 types of sound 8 versions, table of sound types Sound setting Internal; 1 pole DIP can be externally actuated Internal; 3 pole DIP 100 100 100 Built-in, potentiometer Built-in, potentiometer Built-in, potentiometer 88 dB 88 dB 88 dB 360° 360° 360° Acoustic modules Sound pressure dB Sound pressure level adjustment Sound_pressure_can_be_low ered_to_a_minimum_of Transmission angle Current-/power consumption 24 V AC/DC A 0.092 0.092 0.115 110 /120 V AC A 0.041 0.041 0.045 230 /240V AC A 0.043 0.043 0.043 g 24 V AC/DC ± 10 % 110/120 V AC ± 10 % 230/240 V AC ± 10 % 102 24 V AC/DC ± 10 % 110/120 V AC ± 10 % 230/240 V AC ± 10 % 102 24 V AC/DC ± 10 % 110/120 V AC ± 10 % 230/240 V AC ± 10 % 102 Voltage levels Weight Table of sound types Sound type Frequency Diagram Repeat rate Special application Hz SL7-AP… SL7-AP…-E SL7-AP…-M CA047002EN-INT Max. volume dB Continuous tone approx. 2800 - - 100 Pulsed tone approx. 2800 approx. 2 Hz - 100 Continuous tone approx. 2800 - - 100 Pulsed tone approx. 2800 approx. 2 Hz - 100 Continuous tone 2700 - - 100 Continuous tone 1350 - - 100 Pulsed tone 2700 250 ms on, 250 ms off - 100 Pulsed tone 1350 250 ms on, 250 ms off - 100 falling 1200 - 500 1 Hz Evacuation, Germany, DIN 3304-3 98 Rising 500 - 1200 Rising 3 s, 0.5 s off Netherlands NEN 2575:2000 98 Alternating 800 - 1000 2 Hz 94 rising/falling 500 - 1500 10 Hz 94 www.eaton.eu Signal towers 17 SL7 Dimensions SL7 Complete devices SL7-100-L-RYG-24LED 356 mm (14.02") 295 mm (11.61") SL7-100-L-RG-24LED ⌀ 72 mm (⌀ 2.84") ⌀ 72 mm (⌀ 2.84") ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") Acoustic modules SL7-(B)(F)L … SL7-AP… 61 mm (2.4") 71 mm (2.8") Light modules ⌀ 73 mm (⌀ 2.87") ⌀ 73.2 mm (⌀ 2.88") CA047002EN-INT www.eaton.eu 18 Signal towers SL7 Basic modules SL7-CB-… SL7-CB-T-… Part no. Part no. SL7-CB-T-100 SL7-CB-T-250 SL7-CB-T-400 a a SL7-CB-100 SL7-CB-250 SL7-CB-400 a mm (inch) 171 (6.73) 321 (12.64) 471 (18.54) ⌀ 72 mm (⌀ 2.83") M20 ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") SL7-CB-EMH 84 mm (3.31") 82 mm (3.23") 96 mm (3.78") ⌀ 5.8 mm (⌀ 0.23") CA047002EN-INT www.eaton.eu 82.5 mm (3.25") 31 mm (1.22") 119 mm (4.68") SL7-CB-D ⌀ 100 mm (⌀ 3.94") ⌀ 5.8 mm (⌀ 0.23") ⌀ 85 mm (⌀ 3.35") a mm (inch) 190 (7.48) 340 (13.38) 490 (19.29) Signal towers 19 SL7 Basic modules 84 mm (3.31") 70 mm (2.76") 90 mm (3.54") SL7-CB-IMS 82 mm (3.23") SL7-CB-IMH ⌀ 6 mm (⌀ 0.24") 107 mm (4.21") SL7-CB-FW 73 mm (2.87") ⌀ 5.8 mm (⌀ 0.23") ⌀ 52 mm (⌀ 2.05") SL7-FMS-… Part no. M5 52 mm (2.05") 73 mm (2.87") 20 mm (0.79") a 82 mm (3.23") SL7-FMS-100 SL7-FMS-250 SL7-FMS-400 a mm (inch) 192 (7.55) 342 (13.46) 492 (19.37) ⌀ 80 mm (⌀ 3.15") ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") CA047002EN-INT www.eaton.eu 20 Signal towers SL7 Base module for connecting to SmartWire-DT® 192 mm (7.56") SL7-SWD ⌀ 80 mm (⌀ 3.15") ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") Mounting brackets SL7/4-FW SL7/4-FW-T 65 mm (2.56") 70 mm (2.76") 46 mm (1.81") 50 mm (1.97") 91 mm (3.58") 72 mm (2.83") ⌀ 5.5 mm (⌀ 0.22") 44 mm (1.73") ⌀ 54 mm (⌀ 2.13") SL7/4-BET 17 mm (0.67") ⌀ 12 mm (⌀ 0.47") ⌀ 20 mm (⌀ 0.79") ⌀ 16.2 mm (⌀ 0.64") CA047002EN-INT 75.5 mm (2.97") Tool for replacing filament lamp SL7-L12 35 mm (1.38") Filament bulbs ⌀ 13 mm (⌀ 0.51") ⌀ 15.3 mm (⌀ 0.6") www.eaton.eu 24 mm (0.94") 54 mm (2.13") ⌀ 6.4 mm (⌀ 0.25") 35 mm (1.38") Signal towers 21 Notes Notes CA047002EN-INT www.eaton.eu 22 Signal towers SL4 System overview SL4 5 7 7 1 2 3 4, 4a, 4b 6, 6a 6b 6c 6d 6e 6i 6f 6g 6h 7 7 CA047002EN-INT www.eaton.eu Signal towers 23 SL4 Card for filament lamp, continuous light 1 5 Continuous tone or pulsed tone, adjustable with internal dip switches Sound pressure 80 dB, adjustable with internal potentiometer, frequency 4000 Hz Easy mounting with bayonet mount Without light element (filament lamp with BA15d socket) Easy mounting with bayonet mount Modules can be arranged in any order Degree of protection IP66 6i → page 28 7 Accessory Considerations Max. 2 x 1 modules that can be individually actuated (two with base module SL7-CB-D only) Permanently integrated cover plate Mounting brackets Including mounting bracket M20 cable gland Tool for replacing filament lamp Degree of protection IP66 2 Base with base adapter for slipping onto place (rapid mounting and wiring system) and SmartWire-DT connection Aluminium tube 100 mm Set up as topmost module Max. 2 x 5 modules that can be actuated individually (two with base module SL7-CB-D only) Operating mode: 100 % DF (duty factor) → page 27 Card with LED, continuous light Acoustic module Filament lamp Operating mode: 100 % DF (duty factor) → page 27 → page 29 with LED Easy mounting with bayonet mount Base module Modules can be arranged in any order Degree of protection IP66 6 Easy mounting with bayonet mount Degree of protection IP66 Max. 2 x 5 modules that can be actuated individually (two with base module SL7-CB-D only) Operating mode: 100 % DF (duty factor) → page 24 Including cover plate with Push in terminals Base for mounting on both sides 6a → page 29 Card with LED, flashing light 3 Base with aluminium tube and plastic foot with LED Easy mounting with bayonet mount 6b Aluminium tube 100 mm, 250 mm or 400 mm → page 28 Modules can be arranged in any order Degree of protection IP66 Max. 2 x 5 modules that can be actuated individually (two with base module SL7-CB-D only) Operating mode: 100 % DF (duty factor) Flashing frequency 2 Hz Base with aluminum tube and banjo bolt 6c Aluminium tube 100 mm, 250 mm or 400 mm → page 28 → page 25 Base with external fixing holes Card with LED, strobe light 4 6d → page 28 Easy mounting with bayonet mount One-sided base with bracket Modules can be arranged in any order Degree of protection IP66 Max. 2 x 5 modules that can be actuated individually (two with base module SL7-CB-D only) Operating mode: 100 % DF (duty factor) Card with LED 6e → page 29 Base with internal (on the inside) fixing holes 6f → page 28 4a with LED Base with built-in (pre-assembled) fixing screws 6g → page 28 Flashing frequency 1.4 Hz → page 26 Card with LED With LED for effective signaling effect with various flashing sequences Flashing frequency approx. 1 -2.6 Hz Base with base adapter for slipping onto place (rapid mounting and wiring system) 4b 6h Aluminium tube 100 mm, 250 mm or 400 mm → page 28 → page 26 CA047002EN-INT www.eaton.eu 24 Signal towers SL4, Complete devices, Light modules Ordering SL4, Complete devices, Light modules Rated operational voltage Number of modules Colour Function Ue Part no. Article no. Price see price list Std. pack V Complete devices Continuous light, LED, IP66, Base module with foot and 100 mm tube 24 V AC/DC 2 SL4-100-L-RG-24LED 171295 1 off SL4-100-L-RYG-24LED 171296 3 Customised complete unit Order on request , * = Freely selectable customer identification or stock no., Maximum 10 characters - Rated operational voltage Ue Colour Function SL4-COMBINATION-* 171387 Part no. Article no. 1 off Price see price list Std. pack V Card with LED Continuous light IP66 Notes SL4-L24-B 171313 SL4-L24-G 171314 SL4-L24-R 171315 SL4-L24-W 171316 SL4-L24-Y 171317 SL4-L24-A 171318 110/120 V AC SL4-L120-B 171319 SL4-L120-G 171320 SL4-L120-R 171321 SL4-L120-W 171322 SL4-L120-Y 171323 SL4-L120-A 171324 230/240 V AC SL4-L230-B 171325 SL4-L230-G 171326 SL4-L230-R 171327 SL4-L230-W 171328 SL4-L230-Y 171329 SL4-L230-A 171330 Information relevant for export to North America Product Standards UL File No. UL CCN CA047002EN-INT 24 V AC/DC www.eaton.eu IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 1410; CSA-C22.2 No. 94-91; CE marking E29184 NKCR CSA File No. CSA Class No. NA Certification Degree of Protection UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 1 off Signal towers 25 SL4, Light modules SL4, Light modules Rated operational voltage Ue Colour Function Part no. Article no. Price see price list Std. pack V Card with LED Flashing light IP66 2 Hz Notes 24 V AC/DC SL4-BL24-B 171337 SL4-BL24-G 171338 SL4-BL24-R 171339 SL4-BL24-W 171340 SL4-BL24-Y 171341 SL4-BL24-A 171342 110/120 V AC SL4-BL120-B 171343 SL4-BL120-G 171344 SL4-BL120-R 171345 SL4-BL120-W 171346 SL4-BL120-Y 171347 SL4-BL120-A 171348 230/240 V AC SL4-BL230-B 171349 SL4-BL230-G 171350 SL4-BL230-R 171351 SL4-BL230-W 171352 SL4-BL230-Y 171353 SL4-BL230-A 171354 1 off Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 CA047002EN-INT www.eaton.eu 26 Signal towers SL4, Light modules Rated operational voltage Ue Colour Function Part no. Article no. Price see price list Std. pack V Card with LED Strobe light IP66 1.4 Hz Multistrobe light IP66 LED for effective signaling effect With various strobe sequences 1 - 2.6 Hz Notes SL4-FL24-B 171355 SL4-FL24-G 171356 SL4-FL24-R 171357 SL4-FL24-W 171358 SL4-FL24-Y 171359 SL4-FL24-A 171360 110/120 V AC SL4-FL120-B 171361 SL4-FL120-G 171362 SL4-FL120-R 171363 SL4-FL120-W 171364 SL4-FL120-Y 171365 SL4-FL120-A 171366 230/240 V AC SL4-FL230-B 171367 SL4-FL230-G 171368 SL4-FL230-R 171369 SL4-FL230-W 171370 SL4-FL230-Y 171371 SL4-FL230-A 171372 24 V AC/DC SL4-FL24-B-M 171373 SL4-FL24-G-M 171374 SL4-FL24-R-M 171375 SL4-FL24-W-M 171376 SL4-FL24-Y-M 171377 SL4-FL24-A-M 171378 Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection CA047002EN-INT 24 V AC/DC www.eaton.eu IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 1 off 1 off Signal towers 27 SL4, Light modules, Acoustic modules SL4, Light modules, Acoustic modules Rated operational voltage Ue Colour Part no. Article no. Function Price see price list Std. pack V Card for filament lamp Continuous light IP66 without light elements Filament lamp max. 4 W Filament bulbs → page 29 Rated operational voltage Ue Ie V mA SL4-L-B 171331 SL4-L-G 171332 SL4-L-R 171333 SL4-L-W 171334 SL4-L-Y 171335 SL4-L-A 171336 < 250 V AC/DC Rated operational current Colour Function Sound type Part no. Article no. 1 off Price see price list Std. pack Acoustic modules Continuous tone or pulsed tone, adjustable with internal dip switches. Sound pressure 80 db, adjustable with internal potentiometer. f = 4000 Hz Place only at the highest position on a pole IP66 24 V AC/DC max. 39 Notes 110/120 V AC max. 21 230/240 V AC max. 21 SL4-AP24 171379 SL4-AP120 171380 SL4-AP230 171381 1 off Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 CA047002EN-INT www.eaton.eu 28 Signal towers SL4, Basic modules SL4, Basic modules Tube length Colour For use with Part no. Article no. 100 mm black Aluminum color tube SL4-L-… SL4-BL-… SL4-FL-… SL4-AP-... SL4-PIB-100 171297 SL4-PIB-250 171298 SL4-PIB-400 171299 Price see price list Std. pack Basic modules for horizontal mounting including cover max. 5 modules Base with aluminium tube and plastic foot Push in terminals 250 mm 400 mm Base with aluminum tube and banjo bolt Push in terminals SL4-PIB-T-100 171305 SL4-PIB-T-250 171306 SL4-PIB-T-400 171307 100 mm 250 mm 400 mm Base with external fixing holes Push in terminals - SL4-PIB-EMH 171302 black Base with internal (on the inside) fixing holes Push in terminals SL4-PIB-IMH1) 171300 Base with built-in (pre-assembled) fixing screws Push in terminals - SL4-PIB-IMS 171301 Base with base adapter for slipping onto place (rapid mounting and wiring system) Screw terminals 100 mm black Aluminum color tube 250 mm 400 mm SL4-FMS-100 171308 SL4-FMS-250 171309 SL4-FMS-400 171310 SL4-SWD2) 171311 Base with base adapter for slipping onto 100 mm place (rapid mounting and wiring system) Blade terminal SWD4-8MF2 max. 0.3 A per module External power supply connectable (24 V DC) Configurable with SWD‐Assist (planning and ordering help) Notes 1 off Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection CA047002EN-INT www.eaton.eu IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 1410; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 1) Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 1410; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 1 2) Product Standards NA Certification Degree of Protection IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSAC22.2 No. 94-91; CE marking Request filed for UL and CSA UL Type 4, 4X, 13 Signal towers 29 SL4, Basic modules, Accessories SL4, Basic modules, Accessories Colour For use with Part no. Article no. Price see price list for vertical mounting including cover One-sided base with bracket Push in terminals max. 5 modules black SL4-L-… SL4-BL-… SL4-FL-… SL4-AP-... SL4-PIB-FW 171303 1 off for vertical mounting on both sides including cover Base with external fixing holes Push in terminals max. 2 x 5 modules black SL4-L-… SL4-BL-… SL4-FL-… SL4-AP-... SL4-PIB-D 171304 1 off Power For use with Part no. Article no. - SL4-PIB… SL7-CB... SL7/4-FW 171446 1 off - - SL4-PIB-T… SL7-CB-T... SL7/4-FW-T 171455 1 off - - - - SL7/4-BET 171294 1 off > 3000 12 V 4W SL4-L-… SL4-L12 171382 SL4-L24 171383 SL4-L120 171384 SL4-L230 171385 1 off Std. pack Basic modules lifespan Rated operational voltage Ue h V Price see price list Std. pack Mounting brackets for vertical mounting, Plastic - - Including mounting bracket M20 cable gland for vertical mounting, Metal - Tool for replacing filament lamp Filament bulbs Mounting: Ba15d 24 V 120 V 230 V Notes Information relevant for export to North America Product Standards UL File No. UL CCN CSA File No. CSA Class No. NA Certification Degree of Protection IEC/EN 60947-5-1; UL 508; CSA-C22.2 No. 14-10; CSA-C22.2 No. 94-91; CE marking E29184 NKCR UL report applies to both US and Canada NKCR7 UL listed, certified by UL for use in Canada UL Type 4, 4X, 13 CA047002EN-INT www.eaton.eu 30 Signal towers SL4 Technical data SL4 SL4-… General Standards IEC/EN 60947-5-1 Climatic proofing Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60069-2-30 As required Mounting position Mechanical shock resistance > 15 according to IEC 60068-2-27 Shock duration 11 ms Sinusoidal IP66 IEC/EN 60529 Type 4, 4X, 13 g IEC degree of protection Protection type UL Material Enclosure: Polycarbonate (PC), black Cap: Polycarbonate (PC) Cap colour blue, green, red, clear, yellow, orange Ambient temperature -30 - +60 °C Max. 5 with standard base Max. 10 with base for mounting on both sides Number of signal elements Terminal capacity Solid or flexible conductor mm2 0.2 - 1.5 Solid or flexible conductor, with ferrule mm2 0.25 - 1.5 Flexible with ferrule with plastic collar mm2 0.25 - 0.75 AWG 24 - AWG 16 Contacts Rated impulse withstand voltage Uimp V AC 4000 Rated insulation voltage Ui V 250 Overvoltage category/pollution degree III/3 SL4-L…-… SL4-BL…-… SL4-FL…-… SL4-FL24-…-M SL4-L… Flashing light Strobe light Multistrobe light Continuous light Light modules Type of light Continuous light Light elements LED Mounting - - - - Filament lamp max. 4 W Ba15d Flashing/strobe frequency - 2 Hz 1.4 Hz 1 - 2.6 Hz - Transmission angle 360° Leakage current A < 0.003 Current-/power consumption 24 V AC/DC A 0.022 - 0.033 0.028 - 0.036 0.035 - 0.065 0.048 - 0.068 - 110 /120 V AC A 0.030 0.030 0.10 - - 230 /240V AC A 0.030 0.030 0.10 - - - - - - Max. 4 W with the specified voltages up to 250 V AC/DC Power consumption Voltage levels lifespan h 24 V AC/DC ± 10 % 110/120 V AC ± 10 % 230/240 V AC ± 10 % > 100000 Weight g 45 CA047002EN-INT www.eaton.eu 24 V AC/DC ± 10 % Signal towers 31 SL4 SL4-AP… Acoustic modules Type of tone Continuous or pulsed tone Types of sound 2 versions, table of sound types Sound setting Internal; 1 pole DIP Sound pressure dB 80 Sound pressure level adjustment - Sound_pressure_can_be_lowered_t o_a_minimum_of Transmission angle 360° Current-/power consumption 24 V AC/DC A 0.039 110 /120 V AC A 0.021 230 /240V AC A 0.021 g 24 V AC/DC ± 10 % 110/120 V AC ± 10 % 230/240 V AC ± 10 % 43 Voltage levels Weight Table of sound types Sound type SL4-AP… Continuous tone Pulsed tone Frequency Hz approx. 4000 approx. 4000 Diagram Repeat rate Special application approx. 2 Hz - Max. volume dB 80 80 CA047002EN-INT www.eaton.eu 32 Signal towers SL4 Dimensions SL4 Complete devices SL4-100-L-RYG-24LED 323 mm (12.72") 261 mm (10.28") SL4-100-L-RG-24LED ⌀ 72 mm (⌀ 2.84") ⌀ 72 mm (⌀ 2.84") ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") Acoustic modules SL4-(B)(F)L … SL4-AP… 62 mm (2.44") 71 mm (2.80") Light modules ⌀ 44 mm (⌀ 1.73") ⌀ 43 mm (⌀ 1.69") CA047002EN-INT www.eaton.eu Signal towers 33 SL4 Basic modules SL4-PIB-… SL4-PIB-T-… Part no. Part no. SL4-PIB-T-100 SL4-PIB-T-250 SL4-PIB-T-400 a mm (inch) 150 (5.90) 300 (11.81) 450 (17.72) a a SL4-PIB-100 SL4-PIB-250 SL4-PIB-400 a mm (inch) 136 (3.53) 286 (11.26) 436 (17.16) ⌀ 72 mm (⌀ 2.83") M20 ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") 56 mm (2.21") 45 mm (1.77") 57 mm (2.24") 35 mm (1.38") 97 mm (3.82") SL4-PIB-EMH ⌀ 5.9 mm (⌀ 0.23") SL4-PIB-D ⌀ 69 mm (⌀ 2.72") ⌀ 5.8 mm (⌀ 0.23") ⌀ 54 mm (⌀ 2.13") 62 mm (2.44") CA047002EN-INT www.eaton.eu 34 Signal towers SL4 Basic modules 56 mm (2.21") 45 mm (1.77") 57 mm (2.24") SL4-PIB-IMH ⌀ 5.8 mm (⌀ 0.23") 80 mm (3.15") SL4-PIB-FW 43 mm (1.34") ⌀ 5.8 mm (⌀ 0.23") ⌀ 22 mm (⌀ 0.87") 65 mm (2.56") SL4-PIB-IMS SL4-FMS-… Part no. 22 mm (0.87") M5 43 mm (1.69") 21 mm (0.83") a 57 mm (2.24") SL4-FMS-100 SL4-FMS-250 SL4-FMS-400 ⌀ 80 mm (⌀ 3.15") ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") CA047002EN-INT www.eaton.eu a mm (inch) 157 (6.18) 307 (12.09) 457 (17.99) Signal towers 35 SL4 Base module for connecting to SmartWire-DT® 157 mm (6.18") SL4-SWD ⌀ 80 mm (⌀ 3.15") ⌀ 5.5 mm (⌀ 0.22") ⌀ 54 mm (⌀ 2.13") Mounting brackets SL7/4-FW SL7/4-FW-T 65 mm (2.56") 70 mm (2.76") 46 mm (1.81") 50 mm (1.97") 91 mm (3.58") 72 mm (2.83") ⌀ 5.5 mm (⌀ 0.22") 44 mm (1.73") 75.5 mm (2.97") SL7/4-BET 35 mm (1.38") Tool for replacing filament lamp SL7-L12 17 mm (0.67") 35 mm (1.38") ⌀ 54 mm (⌀ 2.13") Filament bulbs ⌀ 13 mm (⌀ 0.51") ⌀ 15.3 mm (⌀ 0.6") 24 mm (0.94") 54 mm (2.13") ⌀ 6.4 mm (⌀ 0.25") ⌀ 12 mm (⌀ 0.47") ⌀ 20 mm (⌀ 0.79") ⌀ 16.2 mm (⌀ 0.64") CA047002EN-INT www.eaton.eu 36 Signal towers Notes Notes CA047002EN-INT www.eaton.eu The power of fusion. 1833 1874 1886 1893 1897 1899 1906 1908 1911 1914 1934 1961 1962 1963 1967 1977 1983 1984 1989 There’s a certain energy at Eaton. It’s the power of uniting some of the world’s most respected names to build a brand you can trust to meet your every power management need. Eaton is dedicated to ensuring that reliable, efficient and safe power is available when it’s needed most. Building on over 100 years of experience in electrical power management, the experts at Eaton deliver customized, integrated solutions to solve your most critical challenges. To learn more visit www.eaton.eu/electrical. All of the above are trademarks of Eaton or its affiliates.  Eaton has a license to use the Westinghouse brand name in Asia Pacific. ©2013 Eaton. Brand-Orbit-A4-English.indd 1 19.04.13 11:13 Eaton is dedicated to ensuring that reliable, efficient and safe power is available when it’s needed most. With unparalleled knowledge of electrical power management across industries, experts at Eaton deliver customized, integrated solutions to solve our customers’ most critical challenges. Our focus is on delivering the right solution for the application. But, decision makers demand more than just innovative products. They turn to Eaton for an unwavering commitment to personal support that makes customer success a top priority. For more information, visit www.eaton.eu/electrical. To contact an Eaton salesperson or local distributor/agent, please visit www.eaton.eu/electrical/customersupport Changes to the products, to the information contained in this document, and to prices are reserved; so are errors and omissions. Only order confirmations and technical documentation by Eaton is binding. Photos and pictures also do not warrant a specific layout or functionality. Their use in whatever form is subject to prior approval by Eaton. The same applies to Trademarks (especially Eaton, Moeller, Cutler-Hammer). The Terms and Conditions of Eaton apply, as referenced on Eaton internet pages and Eaton order confirmations. Eaton Industries GmbH Hein-Moeller-Str. 7–11 D-53115 Bonn/Germany © 2013 by Eaton Corporation All rights reserved Printed in Germany 05/13 Publication No.: CA047002EN-INT Doku/DHW/bb/dfs 04/13 Article No.: 171892 Eaton is a registered trademark of Eaton Corporation. All other trademarks are property of their respective owners. SmartWire-DT® is a registered trademark of Eaton Corporation.
DEL-SL4-FL120-A 价格&库存
很抱歉,暂时无法提供与“DEL-SL4-FL120-A”相匹配的价格&库存,您可以联系我们找货
